    4. Iobroker nicht mehr erreichbar - Firewall?
      Thomas Braun Most Active @line last edited by
      @line
      pgrep -f "Xorg"
      Und nochmal die Ausgabe von
      iob diag
        line @Thomas Braun last edited by line
        pgrep -f "Xorg"
        673
        2969
        Ion diag
          system.adapter.admin.0                  : admin                 : raspberrypi                              - disabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
          system.adapter.apple-find-me.0          : apple-find-me         : raspberrypi                              - disabled
        + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
          system.adapter.ble.0                    : ble                   : raspberrypi                              - disabled
          system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled
        + system.adapter.denon.0                  : denon                 : raspberrypi                              -  enabled
        + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
          system.adapter.dwd.0                    : dwd                   : raspberrypi                              - disabled
        + system.adapter.energiefluss.0           : energiefluss          : raspberrypi                              -  enabled
        + system.adapter.evcc.0                   : evcc                  : raspberrypi                              -  enabled, port: 7070
          system.adapter.flot.0                   : flot                  : raspberrypi                              -  enabled
          system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi                              - disabled
        + system.adapter.history.0                : history               : raspberrypi                              -  enabled
        + system.adapter.homeconnect.0            : homeconnect           : raspberrypi                              -  enabled
          system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
          system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              -  enabled
        + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
        + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
        + system.adapter.lgtv.0                   : lgtv                  : raspberrypi                              -  enabled
        + system.adapter.mediola-gateway.0        : mediola-gateway       : raspberrypi                              -  enabled
        + system.adapter.meross.0                 : meross                : raspberrypi                              -  enabled
          system.adapter.modbus.0                 : modbus                : raspberrypi                              - disabled
          system.adapter.mqtt-client.0            : mqtt-client           : raspberrypi                              - disabled, port: 1883
          system.adapter.nuki-extended.0          : nuki-extended         : raspberrypi                              - disabled
          system.adapter.nuki.0                   : nuki                  : raspberrypi                              - disabled
        + system.adapter.openligadb.0             : openligadb            : raspberrypi                              -  enabled
          system.adapter.parser.0                 : parser                : raspberrypi                              - disabled
          system.adapter.pegelalarm.0             : pegelalarm            : raspberrypi                              -  enabled
        + system.adapter.pollenflug.0             : pollenflug            : raspberrypi                              -  enabled
        + system.adapter.radar2.0                 : radar2                : raspberrypi                              -  enabled
        + system.adapter.scenes.0                 : scenes                : raspberrypi                              -  enabled
        + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
        + system.adapter.shuttercontrol.0         : shuttercontrol        : raspberrypi                              -  enabled
        + system.adapter.socketio.0               : socketio              : raspberrypi                              -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
          system.adapter.solaredge.0              : solaredge             : raspberrypi                              - disabled
        + system.adapter.tesla-motors.0           : tesla-motors          : raspberrypi                              -  enabled
          system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              - disabled
          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              -  enabled
          system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              -  enabled
        + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
          system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              -  enabled
          system.adapter.vis-map.0                : vis-map               : raspberrypi                              -  enabled
          system.adapter.vis-material-advanced.0  : vis-material-advanced : raspberrypi                              -  enabled
          system.adapter.vis-materialdesign.0     : vis-materialdesign    : raspberrypi                              -  enabled
          system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              -  enabled
          system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
        + system.adapter.vw-connect.0             : vw-connect            : raspberrypi                              -  enabled
          system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi                              -  enabled
        + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 192.168.178.69, run as: admin
        + system.adapter.webcal.0                 : webcal                : raspberrypi                              -  enabled
        + system.adapter.yahka.0                  : yahka                 : raspberrypi                              -  enabled
        + instance is alive
        feline@raspberrypi:~ $ iob start admin
        The adapter "admin.0" was started.
        feline@raspberrypi:~ $ pgrep -f "Xorg"
        673
        2969
        feline@raspberrypi:~ $ iob diag
        *** iob diag is starting up, please wait ***
        *** ioBroker Diagnosis ***
        Please stretch the window of your terminal programm (puTTY) as wide as possible or switch to full screen
        The following checks may give hints to potential malconfigurations or errors, please post them in our forum:
        https://forum.iobroker.net
        Just copy and paste the Summary Page, including the ``` characters at start and end.
        It helps us to help you!
        Press any key to continue
        Skript v.2023-10-10
        *** BASE SYSTEM ***
           Static hostname: raspberrypi
                 Icon name: computer
          Operating System: Debian GNU/Linux 11 (bullseye)
                    Kernel: Linux 6.1.21-v8+
              Architecture: arm64
        Model           : Raspberry Pi 4 Model B Rev 1.5
        Docker          : false
        Virtualization  : none
        Kernel          : aarch64
        Userland        : arm64
        Systemuptime and Load:
         21:52:48 up 55 min,  3 users,  load average: 0.61, 0.54, 0.54
        CPU threads: 4
        *** RASPBERRY THROTTLING ***
        Current issues:
        Previously detected issues:
        *** Time and Time Zones ***
                       Local time: Fri 2023-11-17 21:52:48 CET
                   Universal time: Fri 2023-11-17 20:52:48 UTC
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        *** User and Groups ***
        feline
        /home/feline
        feline adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
        *** X-Server-Setup ***
        /home/iobroker/.diag.sh: line 200: [[: 673
        2969: syntax error in expression (error token is "2969")
        X-Server:       false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Mem:            7.8G        2.3G        4.1G         73M        1.4G        5.3G
        Swap:            99M          0B         99M
        Total:          7.9G        2.3G        4.2G
                 7812 M total memory
                 2335 M used memory
                 2930 M active memory
                  618 M inactive memory
                 4065 M free memory
                   75 M buffer memory
                 1335 M swap cache
                   99 M total swap
                    0 M used swap
                   99 M free swap
        Raspberry only:
        oom events: 0
        *** FAILED SERVICES ***
        0 loaded units listed.
        *** FILESYSTEM ***
        /dev/root      ext4       29G   20G  8.2G  71% /
        devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
        tmpfs          tmpfs     3.9G   24M  3.8G   1% /dev/shm
        tmpfs          tmpfs     1.6G  1.3M  1.6G   1% /run
        /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
        tmpfs          tmpfs     782M   28K  782M   1% /run/user/1000
        tmpfs          tmpfs     782M   28K  782M   1% /run/user/1002
        [Fri Nov 17 20:57:07 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:38:62:0F vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=b4c0fa64-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
        [Fri Nov 17 20:57:08 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
        [Fri Nov 17 20:57:08 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
        [Fri Nov 17 20:57:10 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
        TARGET                            SOURCE         FSTYPE            OPTIONS
        /                                 /dev/mmcblk0p2 ext4              rw,noatime
        |-/boot                           /dev/mmcblk0p1 vfat              rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
        `-/home/feline2/thinclient_drives xrdp-chansrv   fuse.xrdp-chansrv rw,nosuid,nodev,relatime,user_id=1002,group_id=1002
        /var:
        3.6G    /var/
        3.1G    /var/log
        2.9G    /var/log/journal/378e881158e14149bc4f8e6771c6d1d7
        205M    /var/cache
        Archived and active journals take up 2.8G in the file system.
        /opt/iobroker/backups:
        230M    /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        412M    /opt/iobroker/iobroker-data/
        310M    /opt/iobroker/iobroker-data/files
        52M     /opt/iobroker/iobroker-data/files/javascript.admin
        51M     /opt/iobroker/iobroker-data/backup-objects
        45M     /opt/iobroker/iobroker-data/files/devices.admin/static
        35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
        23M     /opt/iobroker/iobroker-data/states.jsonl
        21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map
        20M     /opt/iobroker/iobroker-data/objects.jsonl
        19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js.map
        USB-Devices by-id:
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v18.18.2
        /usr/bin/node           v18.18.2
        /usr/bin/npm            9.8.1
        /usr/bin/npx            9.8.1
        /usr/bin/corepack       0.19.0
        nodejs:
          Installed: 18.18.2-1nodesource1
          Candidate: 18.18.2-1nodesource1
          Version table:
         *** 18.18.2-1nodesource1 1001
                100 /var/lib/dpkg/status
             18.18.1-1nodesource1 1001
             18.18.0-1nodesource1 1001
             18.17.1-1nodesource1 1001
             18.17.0-1nodesource1 1001
             18.16.1-1nodesource1 1001
             18.16.0-1nodesource1 1001
             18.15.0-1nodesource1 1001
             18.14.2-1nodesource1 1001
             18.14.1-1nodesource1 1001
             18.14.0-1nodesource1 1001
             18.13.0-1nodesource1 1001
             18.12.0-1nodesource1 1001
             18.11.0-1nodesource1 1001
             18.10.0-1nodesource1 1001
             18.9.1-1nodesource1 1001
             18.9.0-1nodesource1 1001
             18.8.0-1nodesource1 1001
             18.7.0-1nodesource1 1001
             18.6.0-1nodesource1 1001
             18.5.0-1nodesource1 1001
             18.4.0-1nodesource1 1001
             18.3.0-1nodesource1 1001
             18.2.0-1nodesource1 1001
             18.1.0-1nodesource1 1001
             18.0.0-1nodesource1 1001
             12.22.12~dfsg-1~deb11u4 500
                500 http://deb.debian.org/debian bullseye/main arm64 Packages
                500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
        No problems detected
        Errors in npm tree:
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Core adapters versions
        js-controller:  5.0.16
        admin:          6.12.0
        javascript:     7.1.4
        Adapters from github:   8
        Adapter State
        + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        + instance is alive
        ioBroker-Repositories
        Active repo(s): stable
        Installed ioBroker-Instances
        Used repository: stable
        Adapter    "admin"        : 6.12.0   , installed 6.12.0
        Adapter    "alexa2"       : 3.26.1   , installed 3.26.1
        Adapter    "apple-find-me": 0.0.14   , installed 0.0.14
        Adapter    "backitup"     : 2.8.7    , installed 2.8.7
        Adapter    "ble"          : 0.13.4   , installed 0.13.4
        Adapter    "bshb"         : 0.2.4    , installed 0.2.4
        Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
        Adapter    "denon"        : 1.15.4   , installed 1.15.4
        Adapter    "discovery"    : 4.2.0    , installed 3.1.0  [Updatable]
        Adapter    "evcc"         : 0.0.10   , installed 0.0.10
        Adapter    "fullybrowser" : 2.2.0    , installed 2.2.0
        Adapter    "homeconnect"  : 1.1.1    , installed 1.1.1
        Adapter    "homekit-controller": 0.5.8, installed 0.5.8
        Adapter    "iot"          : 2.0.11   , installed 1.14.5 [Updatable]
        Adapter    "javascript"   : 7.1.4    , installed 7.1.4
        Controller "js-controller": 5.0.16   , installed 5.0.16
        Adapter    "lgtv"         : 2.1.2    , installed 2.1.1  [Updatable]
        Adapter    "mediola-gateway": 1.0.1  , installed 1.0.1
        Adapter    "meross"       : 1.15.1   , installed 1.15.1
        Adapter    "modbus"       : 5.0.11   , installed 5.0.11
        Adapter    "mqtt-client"  : 1.6.5    , installed 1.6.5
        Adapter    "nuki"         : 1.6.0    , installed 1.6.0
        Adapter    "nuki-extended": 2.6.5    , installed 2.6.5
        Adapter    "openligadb"   : 1.2.4    , installed 1.3.4
        Adapter    "parser"       : 2.0.7    , installed 1.3.2  [Updatable]
        Adapter    "pegelalarm"   : 1.3.1    , installed 1.3.1
        Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
        Adapter    "radar2"       : 2.0.8    , installed 2.0.8
        Adapter    "shelly"       : 6.6.1    , installed 6.6.1
        Adapter    "shuttercontrol": 1.6.2   , installed 1.6.2
        Adapter    "socketio"     : 6.5.5    , installed 6.5.5
        Adapter    "solarviewdatareader": 1.0.7, installed 1.0.7
        Adapter    "tesla-motors" : 1.3.2    , installed 1.3.2
        Adapter    "trashschedule": 2.3.0    , installed 2.2.0  [Updatable]
        Adapter    "tvprogram"    : 1.1.2    , installed 1.1.2
        Adapter    "vis"          : 1.4.16   , installed 1.4.16
        Adapter    "vis-icontwo"  : 0.96.0   , installed 0.96.0
        Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
        Adapter    "vw-connect"   : 0.0.67   , installed 0.0.67
        Adapter    "weatherunderground": 3.6.0, installed 3.6.0
        Adapter    "web"          : 6.1.10   , installed 6.1.2  [Updatable]
        Adapter    "ws"           : 2.5.8    , installed 2.5.5  [Updatable]
        Adapter    "yahka"        : 1.0.3    , installed 1.0.3
        Objects and States
        /Objects:       12529
                States:         10686
        Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
        Hit:2 http://deb.debian.org/debian bullseye InRelease
        Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
        Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
        Get:5 https://dl.cloudsmith.io/public/evcc/stable/deb/debian bullseye InRelease [5127 B]
        Hit:6 https://deb.nodesource.com/node_18.x nodistro InRelease
        Fetched 5127 B in 2s (3331 B/s)
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       23905      2764/io.shelly.0
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12146      652/sshd: /usr/sbin
        tcp        0      0 192.168.178.69:8082     0.0.0.0:*               LISTEN      1001       22476      2840/io.web.0
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       23627      2620/iobroker.js-co
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       23634      2620/iobroker.js-co
        tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          12213      611/cupsd
        tcp6       0      0 :::38137                :::*                    LISTEN      1001       27437      3826/io.yahka.0
        tcp6       0      0 ::1:631                 :::*                    LISTEN      0          12212      611/cupsd
        tcp6       0      0 :::4712                 :::*                    LISTEN      116        34678      5241/evcc
        tcp6       0      0 :::22                   :::*                    LISTEN      0          12148      652/sshd: /usr/sbin
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       34899      4873/io.admin.0
        tcp6       0      0 :::8084                 :::*                    LISTEN      1001       26414      3842/io.socketio.0
        tcp6       0      0 :::3389                 :::*                    LISTEN      117        12250      679/xrdp
        tcp6       0      0 :::7070                 :::*                    LISTEN      116        37154      5241/evcc
        tcp6       0      0 :::3000                 :::*                    LISTEN      120        19507      613/grafana
        tcp6       0      0 ::1:3350                :::*                    LISTEN      0          11133      645/xrdp-sesman
        udp        0      0 0.0.0.0:1902            0.0.0.0:*                           1001       24557      3407/io.mediola-gat
        udp        0      0 0.0.0.0:40074           0.0.0.0:*                           108        14830      467/avahi-daemon: r
        udp        0      0 0.0.0.0:41021           0.0.0.0:*                           1001       24558      3407/io.mediola-gat
        udp        0      0 0.0.0.0:67              0.0.0.0:*                           1001       22262      2753/io.radar2.0
        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14961      546/dhcpcd
        udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          12230      687/cups-browsed
        udp        0      0 224.0.0.251:5353        0.0.0.0:*                           1002       26205      3418/chromium-brows
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14828      467/avahi-daemon: r
        udp6       0      0 :::44206                :::*                                108        14831      467/avahi-daemon: r
        udp6       0      0 :::546                  :::*                                0          14990      546/dhcpcd
        udp6       0      0 :::5353                 :::*                                108        14829      467/avahi-daemon: r
        iob diag has finished.
        Press any key for a summary
        Copy text starting here:
                                v.2023-10-10
                 Icon name: computer
              Architecture: arm64
        Installation:           native
        Kernel:                 aarch64
        Userland:               arm64
        Timezone:               Europe/Berlin (CET, +0100)
        User-ID:                1000
        /home/iobroker/.diag.sh: line 469: [[: 673
        X-Server:               false
        Boot Target:            graphical.target
        Pending OS-Updates:     0
        Pending iob updates:    7
        Nodejs-Installation:    /usr/bin/nodejs         v18.18.2
                                /usr/bin/npm            9.8.1
                                /usr/bin/npx            9.8.1
        Recommended versions are nodejs 18.18.2 and npm 9.8.1
        MEMORY:
        Mem:            7.8G        2.4G        3.9G         73M        1.5G        5.2G
        Swap:            99M          0B         99M
        Total:          7.9G        2.4G        4.0G
        Active iob-Instances:   28
        ioBroker Core:          js-controller           5.0.16
                                admin                   6.12.0
        Objects type: jsonl
        States  type: jsonl
        Objects:                12529
        States:                 10686
        Size of iob-Database:
        === Mark text until here for copying ===
          Homoran Global Moderator Administrators @line last edited by Homoran
          @line der admin ist ja schon wieder deaktiviert!
          warum?
          edit
          im diag ist er aktiv
            @line sagte in Iobroker nicht mehr erreichbar - Firewall?:
            pc sieht es immer noch nicht besser aus
            Browsercache gelöscht?
              @line
              sudo systemctl set-default multi-user.target
              sudo systemctl isolate multi-user.target
              Der web-Adapter hat auch noch ein Binding...
              Bring die Adapter auf Stand:
                line @Homoran last edited by
                @homoran keine Ahnung. Ich hab ihn nochmals neu gestartet.
                Jetzt steht er auf enable.
                  @thomas-braun Ok, hab die Updates ausgeführt. Den Web Adapter das Binding raugommen. Jedoch erreiche ich ihn trotzdem nicht von einem pc oder pad
                           Icon name: computer
                        Architecture: arm64
                  Docker          : false
                  Kernel          : aarch64
                  Userland        : arm64
                   22:30:14 up  1:33,  2 users,  load average: 0.71, 1.18, 1.44
                  CPU threads: 4
                  Current issues:
                  ~ Under-voltage has occurred
                                 Local time: Fri 2023-11-17 22:30:14 CET
                             Universal time: Fri 2023-11-17 21:30:14 UTC
                                   RTC time: n/a
                                NTP service: active
                            RTC in local TZ: no
                  feline
                  /home/feline
                  X-Server:       true
                  Desktop:
                  Terminal:       tty
                  Boot Target:    multi-user.target
                  *** MEMORY ***
                  Mem:            7.8G        2.4G        3.6G         98M        1.8G        5.1G
                  Swap:            99M          0B         99M
                  Total:          7.9G        2.4G        3.7G
                           7812 M total memory
                           2437 M used memory
                           3037 M active memory
                            940 M inactive memory
                           3602 M free memory
                            117 M buffer memory
                           1655 M swap cache
                             99 M total swap
                              0 M used swap
                             99 M free swap
                  Raspberry only:
                  oom events: 0
                  *** FILESYSTEM ***
                  tmpfs          tmpfs     3.9G   60M  3.8G   2% /dev/shm
                  /var:
                  3.6G    /var/
                  3.1G    /var/log
                  205M    /var/cache
                  425M    /opt/iobroker/iobroker-data/
                  325M    /opt/iobroker/iobroker-data/files
                  33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
                  29M     /opt/iobroker/iobroker-data/states.jsonl
                  21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
                  12M     /opt/iobroker/iobroker-data/objects.jsonl
                  USB-Devices by-id:
                  /usr/bin/npm            9.8.1
                  /usr/bin/npx            9.8.1
                  nodejs:
                    Version table:
                  Errors in npm tree:
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  admin:          6.12.0
                  javascript:     7.1.4
                  Adapter State
                  + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                  + instance is alive
                  Adapter    "iot"          : 2.0.11   , installed 2.0.11
                  Adapter    "lgtv"         : 2.1.2    , installed 2.1.2
                  Adapter    "parser"       : 2.0.7    , installed 2.0.7
                  Adapter    "trashschedule": 2.3.0    , installed 2.3.0
                  Adapter    "web"          : 6.1.10   , installed 6.1.10
                  Adapter    "ws"           : 2.5.8    , installed 2.5.8
                  Objects and States
                  Objects:        12534
                  States:         10691
                  Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
                  Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
                  Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
                  Get:6 https://dl.cloudsmith.io/public/evcc/stable/deb/debian bullseye InRelease [5127 B]
                  Fetched 5127 B in 2s (2471 B/s)
                  Pending Updates: 0
                  tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       55250      9859/io.shelly.0
                  tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       56608      9666/iobroker.js-co
                  tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       54912      9666/iobroker.js-co
                  tcp6       0      0 :::4712                 :::*                    LISTEN      116        60025      10429/evcc
                  tcp6       0      0 :::41285                :::*                    LISTEN      1001       57653      10200/io.yahka.0
                  tcp6       0      0 :::8081                 :::*                    LISTEN      1001       56623      9684/io.admin.0
                  tcp6       0      0 :::8082                 :::*                    LISTEN      1001       60422      10318/io.web.0
                  tcp6       0      0 :::8084                 :::*                    LISTEN      1001       58764      10211/io.socketio.0
                  tcp6       0      0 :::7070                 :::*                    LISTEN      116        60830      10429/evcc
                  udp        0      0 0.0.0.0:1902            0.0.0.0:*                           1001       59512      10091/io.mediola-ga
                  udp        0      0 0.0.0.0:67              0.0.0.0:*                           1001       55168      9816/io.radar2.0
                  udp        0      0 224.0.0.251:5353        0.0.0.0:*                           1002       57876      3418/chromium-brows
                  udp        0      0 0.0.0.0:50693           0.0.0.0:*                           1001       59513      10091/io.mediola-ga
                  • Marc Berg
                    Marc Berg Most Active @line last edited by Marc Berg
                    gelöscht. Hier stand Unsinn.
                      line @Marc Berg last edited by
                      @marc-berg
                      Der Error im NMP Tree kann man ignorieren?
                      Hat sonst noch jemand eine Idee?
                        @line lösch vllt besser mal deine privaten ical Einträge aus dem log
                        eventuell mal deinen Router neu starten
                          line @crunchip last edited by line
                          @crunchip Danke für den Hinweis.
                          Router neu gestartet, keine Verbesserung. Ich werd noch verrückt.
                          Als ich die influx installiert habe, hatte ich eine Anleitung, die eine codezeile für die Installation braucht
                          ufw allow 22/tcp
                            crunchip Forum Testing Most Active @line last edited by
                            die da wäre?
                              @crunchip hab es disable gestellt, jetzt gehts. Also doch die Firewall. Shit. Vielen Dank für eure hilfe
                                @line
                                Ich weiß nicht was du da installiert hast, aber auf einem Standard Raspberry OS ist ufw gar nicht installiert, also kann man es weder aktivieren noch deaktivieren...
                                Du hast da eh wirres Zeug installiert.
                                1683
