      SirMiker @SirMiker last edited by SirMiker
      javascript.0 (23087) script.js.NSPANEL: TypeScript compilation failed: let name = <PageGrid>{ ^ ERROR: Conversion of type '{ type: "cardType"; heading: string; useColor: true; items: undefined[]; }' to type 'PageGrid' may be a mistake because neither type sufficiently overlaps with the other. If this was intentional, convert the expression to 'unknown' first. Type '{ type: "cardType"; heading: string; useColor: true; items: undefined[]; }' is missing the following properties from type 'PageGrid': subPage, parent, parentIcon, parentIconColor, and 9 more. let, name = <PageGrid>{ ^ ERROR: Identifier expected. 'let' is a reserved word in strict mode. Modules are automatically in strict mode. let, name = <PageGrid>{ ^ ERROR: No value exists in scope for the shorthand property 'let'. Either declare one or provide an initializer. let, name = <PageGrid>{ ^ ERROR: Did you mean to use a ':'? An '=' can only follow a property name when the containing object literal is part of a destructuring pattern. let, name = <PageGrid>{ ^ ERROR: Conversion of type '{ type: "cardType"; heading: string; useColor: true; items: undefined[]; }' to type 'PageGrid' may be a mistake because neither type sufficiently overlaps with the other. If this was intentional, convert the expression to 'unknown' first. Type '{ type: "cardType"; heading: string; useColor: true; items: undefined[]; }' is missing the following properties from type 'PageGrid': subPage, parent, parentIcon, parentIconColor, and 9 more.
      das habe ich eingefügt
                 NSPanel_Service         	//Auto-Alias Service Page
      	    //Unlock_Service            //Auto-Alias Service Page (Service Pages used with cardUnlock)
          'type': 'cardType',
          'heading': 'Eckstein',
          'useColor': true,
          'items': []
          subPages: [
      Armilar 2 Replies Last reply Reply Quote 0
      • Armilar
        Armilar Most Active Forum Testing @SirMiker last edited by Armilar
        @sirmiker
        viel wichtiger ist es jetzt zu zeigen, was du überhaupt in das Script eingefügt hast. Das der Fehler kommt, hat sicherlich etwas mit den folgenden Punkten zu tun.
        • Variablendefinition falsch
        • PageItem falsch
        • Komma in der Auflistung vergessen
        • Alias nicht über Geräte-Manager erstellt
        Also mehr Input zu deinen Aktionen als zum Fehler...
        • Armilar
          @sirmiker sagte in SONOFF NSPanel mit Lovelace UI:
              'type': 'cardType',
              'useColor': true,
              'items': []
              subPages: [
          Das ist völlig falsch...
          Die Variablendefinition einer Seite befindet sich immer im oberen Teil des Scriptes...
          Die Seite selbst wird später nur in das page-Array in der Config eingetragen...
          Sieh dir mal das Service-Menü an... Das ist im Prinzip schon eine gute Anleitung...
          Hier nochmal ein Beispiel wie es korrekt wäre:
          Im oberen Teil wird eine Seite definiert...
          im pages-Array rufe ich die Seite an der richtigen Position auf...
          Alles andere steht auch in einer richtig umfänglichen Wiki... die muss man aber lesen...
          Hier mal die wichtigsten Seiten:
          • https://github.com/joBr99/nspanel-lovelace-ui/wiki/ioBroker-Card-Definitionen-(Seiten)
          • https://github.com/joBr99/nspanel-lovelace-ui/wiki/NSPanel-Page-‐-Typen_How-2_Beispiele#how-2-page
          Und ganz viele Beispiele:
          https://github.com/joBr99/nspanel-lovelace-ui/wiki/ioBroker---FAQ-&-Anleitungen
          Der Rest ist auch nicht uninteressant...
          Jetzt noch ein kleines Beispiel für eine cardGrid:
          let Radiosender = <PageGrid>
              'type': 'cardGrid',
              'heading': 'Büro 2',
              'useColor': true,
              'items': [
                  <PageItem>{ id: 'alias.0.NSPanel_1.Radio.Bob', icon: 'radio', name: 'Radio BOB', onColor: colorRadio},
                  <PageItem>{ id: 'alias.0.NSPanel_1.Countdown', icon: 'timer-outline', name: 'Timer', onColor: White}
          Das ist bei mir die "Test"-Seite Radiosender. Jedes PageItem ist ein Steuerelement und muss mit einem "nicht selbstgebauten" Alias (https://github.com/joBr99/nspanel-lovelace-ui/wiki/ioBroker-ALIAS-Definitionen) erstellt werden und unter "id:" im PageItem eingetragen werden. Das Script sucht sich über den Alias-Channel dann den richtigen Typen zur Darstellung raus...
          Das Ergebnis in diesem Beispiel:
          Eine cardGrid mit einem Button um einen Radiosender zu starten und ein popupTimer
          Noch detaillierte für z.B. den Radiosender ist es hier beschrieben:
          https://github.com/joBr99/nspanel-lovelace-ui/wiki/ioBroker---FAQ-&-Anleitungen#9-alias-taste-für-auswahl-eines-radiosenders
          Wenn man das Erstellen erst einmal verstanden hat, dann geht es sehr schnell...
          • Stephan L
            Stephan L @Armilar last edited by
            @armilar said in SONOFF NSPanel mit Lovelace UI:
            Das Script muss nicht angepasst werden,
            Ich will folgendes Format: "%A - %m/%d/%Y"
            Im Klartext (fuer USA): Saturday - 11/18/2023
            Leider finde ich keine Schalter die mir das erlauben.
            Aber: meine kleine Aenderung fuegt einen Datenpunkt hinzu der mir die Kontrolle gibt. Keine TS leider nicht genug um zu wissen ob man absolute Freiheit wie in anderen Sprachen. Daher ist mein aktuelles Format: 'Saturday, 11/1/2023'.
            FAST richtig.
              SirMiker @Armilar last edited by SirMiker
              @armilar
              wirklich vielen dank für die ausführliche Erklärung!
              das mit der Pages klappt null bei mir....und ich verstehe auch mit durchlesen gar nicht was ich da machen muss...sorry...denke da habe ich mir diesmal eindeutig Zuviel vor genommen 😞
               pages: [
              Dort muss ich nach Pages den Namen einfügen den ich vergeben habe oder?
              • Stephan L
                Stephan L last edited by
                Ich verwende das 'alternative' screensaver Layout.
                Leider scheint das ein paar Problemchen zu haben.
                Links sind 2 Eintraege uebereinander, daneben sind 3 weitere nebeneinander.
                Problem: Der OBERE auf der linken Seite ist bei ioBroker IMMER das Wetter!
                Im Script zu finden beim Komentar (//Create Weather MainIcon)
                Mein Panel mit AppDaemon:
                Hier im Bild von AppDaemon sieht man dass ich dort was anderes hingelegt habe. Habe das aktuelle Wetter als erstes in der 3er Reihe (geht aber auch ganz ohne Wetter, meine Wahl)
                Ich ja bereits alle Werte und Infos in HA, daher verwende ich den ioBroker HA Adapter. Genial...
                Von dort kommt auch mein momentaner Stromverbrauch. Den konnte ich auch mit ioBroker anzeigen lassen. Aber warum auch immer wurde der Wert als 'String' erkannt. Und im Code gibt es dubiose logik die dann den Wert, z.B. "793" als DATUM umformatiert.
                Dafuer konnte ich einen einfachen Fix machen.
                Ein String x, der folgendes erfuellt ist KEIN Datum:
                if (parseFloat(val+"") == val)      // I have number that would fit this
                     val = parseFloat(val)
                Dann habe ich den State von 2 Lichtern (die letzten beiden in der Reihe unter dem Datum)
                Ich haette gerne wie mit AppDaemon das Icon in WEISS wenn das Licht aus ist und in Gelb wenn es an ist. Hab ich bisher nicht geschafft.
                Und zuletzt habe ich den State unter dem Icon. Auch hier konnte ich das in AppDaemon etwas schoener machen und den 1. Buchstaben mit 'capitalize' auf gross umstellen.
                Beides scheint es hier nicht zu geben?
                • Armilar
                  Armilar Most Active Forum Testing @Stephan L last edited by Armilar
                  @stephan-l
                  Okay - ich denke du meinst dann wohl das
                  Wir sind im ioBroker noch nicht ganz so International unterwegs... Ich werde mir für die Zukunft mal etwas überlegen.
                  Damit sollte es aber funktionieren:
                  const event = new Date();
                  let weekday = event.toLocaleString('en-US', { weekday: 'long' });
                  let day = event.toLocaleString('en-US', { year: 'numeric', month: '2-digit', day: '2-digit'});
                  console.log(weekday + ' - ' + day)
                  Stephan L 1 Reply Last reply Reply Quote 0
                  • Armilar
                    @stephan-l sagte in SONOFF NSPanel mit Lovelace UI:
                    1)
                    Zu 1)
                    Stimmt - mache bitte einen Feature Request:
                    wir implementieren dann noch:
                    ScreensaverEntityOnColor: Yellow,
                    ScreensaverEntityOffColor: White
                    Zu 2)
                    Kannst du über den Alias verändern:
                    Habe hier mal einen Datenpunkt, der "on"/"off" (klein) enthält
                    Device-Manager
                    unter fx:
                    val.charAt(0).toUpperCase() + val.slice(1);
                    Ergebnis:
                    Stephan L 2 Replies Last reply Reply Quote 0
                    • Armilar
                      if (parseFloat(val+"") == val)      // I have number that would fit this        val = parseFloat(val)
                      ... sehen wir uns an und machen einen Fix
                      Stephan L 1 Reply Last reply Reply Quote 1
                      • Stephan L
                        const dayjs = require('dayjs');
                        console.error(dayjs().format('dddd - DD/MM/YYYY'));
                        Bingo... der format-string kann dann ein Datenobjekt sein. Damit kann ich wie in anderen Sprachen das ganze komplett formatieren!
                        Siehe auch: https://day.js.org/docs/en/display/format
                        Ich bin kein Experte, habe aber wo gelesen dass 'moment' nicht mehr aktualisiert wird? Egal... DayJS kann alles was du brauchst mit minimalem Aufwand und 100% flexibel!
                        • Armilar
                          @stephan-l
                          sieht wirklich nach einer guten Lösung aus
                          • Stephan L
                            Zu 2)
                            Naja, dann muss ich also alles doppelt machen? Wenn ich im Panel ein anderes Licht anzeigen will, dann muss ich einen neuen Alias machen UND dann noch im TS skript das andere Licht anwaehlen. Also dopplete Arbeit? Oder hab ich was falsch verstanden?
                            • Stephan L
                              Yay! Das waere Supi....
                              Ich will auf keinen Fall auf AppDaemon zurueck. NSPanel mit ioBroker ist 10000000x mehr responsive!
                              Aber.... manches geht halt nicht 😉 Aber ich hoffe wir bekommen das hin.
                              Danke fuer die super schnellen Antworten!
                              Armilar 1 Reply Last reply Reply Quote 1
                              • Armilar
                                @sirmiker
                                Gib uns mal ein Anwendungsbeispiel für einen leichten Einstieg. Was soll als erstes passieren?
                                Eine neue Seite mit einer Lampe einbinden?
                                Dann benötigen wir erst einmal einen Datenpunkt der Lampe.
                                Step by Step...
                                • Armilar
                                  Aber.... manches geht halt nicht Aber ich hoffe wir bekommen das hin.
                                  Klar bekommen wir das hin 😊
                                  Am Besten aber in einen Feature Request auf Github. Dann geht es nicht so schnell verloren wie in diesem Thread...
                                  Du bist dann der erste "Test-Amerikaner" für das NSPanel im ioBroker 😉
                                  Kannst natürlich auch "Pull Requests" machen, falls die Lösung schon bekannt ist...
                                  • Stephan L
                                    https://github.com/joBr99/nspanel-lovelace-ui/issues/1045
                                    stleusc created this issue in joBr99/nspanel-lovelace-ui
                                    closed ioBroker - add support for on/off icon and text on screensaver #1045
                                    • Stephan L
                                      Ich denke das liegt daran dass doch einiges auf Deutsch dokumentiert ist 😉 Sowohl online als auch im Code.
                                      Nach 15+ Jahren USA ist Englisch eigentlich fuer mich inzwischen einfacher hahaha. Zumindest gefuehlt 😉
                                      Aber 30 Jahre Deutsch vergisst man dann ja doch nicht so schnell....
                                      Ich mache gerne PullRequest wenn es da nicht so viele Huerden gibt.
                                      In manchen Projekten ist das mega unkompliziert und in manchen eher das Gegenteil.
                                      Wenn es OK ist wuerde ich den Datumsfix machen, so als tester.
                                      Passt das? Ich wuerde dafuer gerne ein DatenObjekt nehmen das, wenn es exisitiert die UI Schalter ignoriert. Und es waere gut wenn eine Aenderung am DatenObjekt direkt erkannt wird und dann ein neues Datum rausgeschickt wird.
                                      Geht das? Wenn ja, wie?
                                      • Armilar
                                        Passt das?
                                        Ja, natürlich
                                        Habe ich noch nicht ganz verstanden. Meinst du als Daten-Objekt einen Datenpunkt unter 0_userdata.0. das durch das Script inoitial erstellt wird?
                                        • Stephan L
                                          Habe PR erstellt (https://github.com/joBr99/nspanel-lovelace-ui/pull/1046)
                                          closed ioBroker - support custom date format using optional .Config.Dateformat.customFormat object #1046
                                          • Stephan L
                                            Ja und nein... Datenpunkt unter dem panel basis pfad (.Config.Dateformat.customFormat)
                                            Der soll aber ja optional sein. Der user kann das anlegen und es wird verwendet. Der user loescht es wieder und die UI toggles gehen wieder.
                                            Was ich gemerkt habe, wenn ich in der UI die Locale einstelle passiert nix bis ich das TS Skript neu starte!
                                            Grund: die Locale wird ganz am Anfang gesetzt:
                                            const parseFormat = require('moment-parseformat');
                                            moment.locale(getState(NSPanel_Path + 'Config.locale').val);
                                            Der neue dayjs macht das jetzt genau gleich.
                                            Selbst Panel neustart hilft daher nicht.
                                            Was fehlt ist code der Locale change erkennt und dann
                                            moment.locale(getState(NSPanel_Path + 'Config.locale').val); ausfuehrt.
                                            Und mit meiner Aenderung dann auch dayjs.locale(getDayjsLocale());
                                            lovelace ui nspanel sonoff
                                            271
                                            7747
                                            6666064
