    4. Test Adapter vodafone-speedtest v0.0.x GitHub/Latest
    • Knallochse
      Knallochse last edited by
      Installation unter Node Version 18.15.0 nicht mehr möglich
      $ iobroker add vofo-speedtest auto --host buanet-iobroker1 --debug
      NPM version: 9.5.0
      Installing iobroker.vofo-speedtest@0.0.13... (System call)
      npm ERR! code 1
      npm ERR! gyp info spawn args '-f',npm ERR! gyp info spawn args 'make',npm ERR! gyp info spawn args '-I',npm ERR! gyp info spawn args '/opt/iobroker/node_modules/node-libcurl/build/config.gypi',npm ERR! gyp info spawn args '-I',npm ERR! gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/addon.gypi',npm ERR! gyp info spawn args '-I',npm ERR! gyp info spawn args '/opt/iobroker/.cache/node-gyp/18.15.0/include/node/common.gypi',npm ERR! gyp info spawn args '-Dlibrary=shared_library',npm ERR! gyp info spawn args '-Dvisibility=default',npm ERR! gyp info spawn args '-Dnode_root_dir=/opt/iobroker/.cache/node-gyp/18.15.0',npm ERR! gyp info spawn args '-Dnode_gyp_dir=/usr/lib/node_modules/npm/node_modules/node-gyp',npm ERR! gyp info spawn args '-Dnode_lib_file=/opt/iobroker/.cache/node-gyp/18.15.0/<(target_arch)/node.lib',npm ERR! gyp info spawn args '-Dmodule_root_dir=/opt/iobroker/node_modules/node-libcurl',npm ERR! gyp info spawn args '-Dnode_engine=v8',npm ERR! gyp info spawn args '--depth=.',npm ERR! gyp info spawn args '--no-parallel',npm ERR! gyp info spawn args '--generator-output',npm ERR! gyp info spawn args 'build',npm ERR! gyp info spawn args '-Goutput_dir=.'npm ERR! gyp info spawn args ]npm ERR! Could not run curl-config, please make sure libcurl dev package is installed.
      npm ERR! A complete log of this run can be found in:npm ERR! /opt/iobroker/.npm/_logs/2023-04-04T09_56_47_982Z-debug-0.log
      host.buanet-iobroker1 Cannot install iobroker.vofo-speedtest@0.0.13: 1
      ERROR: Process exited with code 25
      Github Issues dazu
      • wendy2702
        wendy2702 @Knallochse last edited by
        @knallochse sagte in Test Adapter vodafone-speedtest v0.0.x GitHub/Latest:
        Mal hier gschaut: https://forum.iobroker.net/topic/57337/fehler-25-217-oder-enotempty-bei-adapter-install-update/2
          Thomas Braun Most Active @wendy2702 last edited by
          @wendy2702
          Du bist zu spät. Wurde schon gelöst:
          Kein Issue mit nodejs, da fehlen dev-packages.
          sudo apt update
          apt policy libcurl4-gnutls-dev libcurl4-nss-dev libcurl4-openssl-dev
          • wendy2702
            wendy2702 @Thomas Braun last edited by
            @thomas-braun Ups...
            OK.
              PatrickFro last edited by
              Moin,
              ich habe den Adapter gerade erst gefunden und installiert. So wie es scheint wird er ja nun doch weiterentwickelt, zumindest gab es einige Änderungen im letzten Monat.
              Ich verstehe die Ergebnisse jedoch noch nicht:
              9b7898b3-a51f-4574-92ba-4dd798486539-image.png im Vergleich zu baeddd3f-17c8-40c9-8d9c-148a2baf8fc2-image.png
              Schaue ich mir die Downloadraten an, sehe ich über die Webseite vom Speedtest 269 Mbit/s, über den Adapter eine Minute vor der Messung per Webseite 55,842 MB/s.
              Wenn ich die verschiedenen Werte richtig zuordnete, müsste ich bei MB/s x 8,25 rechnen um auf Mbit/s zu kommen. Das aber ergäbe 470 Mbit/s. Wo ist hier mein Denkfehler?
              • wollerosekaufe
                wollerosekaufe last edited by wollerosekaufe
                verstehe es auch nicht so ganz.
                auf npm ist version 1.0.1, aber nur dependencies aktualisiert und kein release.
                haben wir noch chancen dass der adapter gefixt wird? @Bluefox @peterbaumert 🙂
                anyway, der adapter läuft bei mir nicht. habe ebenso das problem von @PatrickFro mit VIEL zu niedrigen DL rates.
                dazu klappt der UL test erst gar nicht, der adapter stoppt einfach "ohne fehlermeldung", vofo-speedtest.0.Results.upload_MB etc. bleibt alles leer.
                host.iobroker
                	2023-11-17 22:57:39.204	info	instance system.adapter.vofo-speedtest.0 terminated with code 0 (NO_ERROR)
                vofo-speedtest.0
                	2023-11-17 22:57:38.631	info	Terminated (NO_ERROR): Without reason
                vofo-speedtest.0
                	2023-11-17 22:57:38.577	info	cleaned everything up...
                vofo-speedtest.0
                	2023-11-17 22:57:38.576	info	starting cleanup...
                vofo-speedtest.0
                	2023-11-17 22:57:38.563	info	Vofo-Speedtest finished with 184.013mbit download speed and 0mbit upload speed.
                vofo-speedtest.0
                	2023-11-17 22:57:04.317	info	starting. Version 1.0.1 in /opt/iobroker/node_modules/iobroker.vofo-speedtest, node: v18.18.2, js-controller: 5.0.16
                host.iobroker
                	2023-11-17 22:57:00.080	info	instance system.adapter.vofo-speedtest.0 started with pid 509363
                mit CURL ist das ganze noch schlimmer, da crasht der adapter mit UNCAUGHT_EXCEPTION:
                host.iobroker
                	2023-11-17 23:01:44.523	error	instance system.adapter.vofo-speedtest.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                vofo-speedtest.0
                	2023-11-17 23:01:43.944	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                vofo-speedtest.0
                	2023-11-17 23:01:43.941	info	terminating
                vofo-speedtest.0
                	2023-11-17 23:01:43.938	info	cleaned everything up...
                vofo-speedtest.0
                	2023-11-17 23:01:43.937	info	starting cleanup...
                vofo-speedtest.0
                	2023-11-17 23:01:43.799	error	Curl handle is closed.
                vofo-speedtest.0
                	2023-11-17 23:01:43.798	error	Error: Curl handle is closed. at Curl.close (/opt/iobroker/node_modules/node-libcurl/dist/Curl.js:588:21) at VofoSpeedtest.stopDownloadTest (/opt/iobroker/node_modules/iobroker.vofo-speedtest/main.js:824:29) at Timeout.<anonymous> (/opt/iobroker/node_modules/iobroker.vofo-speedtest/main.js:540:39) at listOnTimeout (node:internal/timers:569:17) at process.processTimers (node:internal/timers:512:7)
                vofo-speedtest.0
                	2023-11-17 23:01:43.787	error	uncaught exception: Curl handle is closed.
                vofo-speedtest.0
                	2023-11-17 23:00:03.861	info	starting. Version 1.0.1 in /opt/iobroker/node_modules/iobroker.vofo-speedtest, node: v18.18.2, js-controller: 5.0.16
                host.iobroker
                	2023-11-17 23:00:00.125	info	instance system.adapter.vofo-speedtest.0 started with pid 509581
                iobroker läuft auf buanet/docker mit libcurl4-openssl-dev package
                btw: bei mir wird die config nicht richtig aktualisiert, daher meldet npm permanent die alte version. alle anderen dateien werden sauber von 1.0.1 geladen, code auf dem iobroker entspricht den neuen github files - das update klappt also. adapter mehrmals de- und neu installiert, hilft nichts. hab die config nun manuell angepasst damit die update-meldung nicht nervt.
                  Bongo last edited by
                  @wollerosekaufe
                  Ich hatte meinen buanet/Docker Container upgegradet. Dabei wurde auch ein Upgrade von node 16 auf 18 gemacht. Darauf hin kam unter anderem JS_CONTROLLER_STOPPED.
                  Ich habe dann die Version v0.0.13 über Github auf v1.0.1 gebracht. Jetzt gibt es keine Fehlermeldung mehr. Download passt aber Upload war immer 0.
                  Dann habe ich CURL aktiviert. Dann war der Upload wieder korrekt.
                  Hilft dir vermutlich nicht weiter aber bei mir funktioniert wieder alles.
                  Von welcher Config sprichst du?
                  wollerosekaufe 1 Reply Last reply Reply Quote 0
                  • wollerosekaufe
                    wollerosekaufe @Bongo last edited by
                    @bongo said in Test Adapter vodafone-speedtest v0.0.x GitHub/Latest:
                    bei mir wird die io-package.json scheinbar nicht geladen, alles andere wie gesagt schon. aus der datei holt sich iobroker/npm dann wohl die version zum update-abgleich. hab da manuell 1.0.1 hinterlegt:
                    cat io-package.json
                      "common": {
                        "name": "vofo-speedtest",
                        "version": "1.0.1",
                        "news": {
                          "0.0.13": {
                            "en": "some more \"already running\" fixes",
                    über github bekomme ich auch nur die alte version, die 1.0.1 ist da nicht released.
                      Bongo @wollerosekaufe last edited by
                      @wollerosekaufe sagte in Test Adapter vodafone-speedtest v0.0.x GitHub/Latest:
                      Ich habe die 1.0.1 über die Katze installiert. In der Instanz wird zwar die alte Version angezeigt aber wenn das Programm startet sieht man im Protokoll die 1.0.1.
                      • wollerosekaufe
                        wollerosekaufe @Bongo last edited by wollerosekaufe
                        @bongo
                        jau, in den logs und in den dateien (bis auf o.g.) war bei mir auch alles korrekt. nur im admin wurde weiter die alte version angezeigt.
                        aber habe es nun im vierten anlauf löschen-und-neu aus npm mal "vollständig" installiert bekommen. probleme bleiben dieselben 😕
                          mhuber last edited by
                          was ist eigentlich der Unterschied zw. "download_Mb" und "download_Mb_calc"?
                            mhuber @wollerosekaufe last edited by
                            @wollerosekaufe habe ähnliche Probleme. es läuft 0.0.13 bzw. 1.0.1, aber eigentlich keine Fehlermeldungen im Log.
                            Nur mit CURL bekomm ich falsche DL rates, Upload passt. Ohne CURL passt die DL rate aber ich bekomme keine UL rates....
                            @Bluefox @peterbaumert wäre super wenn Ihr Euch das mal ansehen könnt. Das mit den DL rates ist übrigens erst seit kurzem
                              Bei mir ist seit Gestern auch der Download falsch und der Ping springt hin und her:
                              Die ganzen Internetspeedtest zeigen noch die ganz normalen Werte:
                                mhuber @Bongo last edited by
                                @bongo bei mir ists seit gestern Abend wieder normal....vielleicht ein Problem bei Vodafone gewesen!?
                                  Bongo @mhuber last edited by
                                  @mhuber Bei mir ist es auch wieder normal:
                                  Gut wenn man sich austauscht. Dann sucht man nicht da nach Problemen wo keine sind.
                                    Seit ein paar Tagen bekomme ich keine Upload Werte mehr vom Adapter, download geht, hat das noch jemand?
                                      Ja, bei mir auch schon seit längerem.
                                        @bongo hab mal ein issue aufgemacht -> https://github.com/iobroker-community-adapters/ioBroker.vofo-speedtest/issues/253
                                        mhuber77 created this issue in iobroker-community-adapters/ioBroker.vofo-speedtest
                                        open upload vaules missing #253
                                          Bongo last edited by Bongo
                                          Gibt es schon neue Erkenntnisse? Habe jetzt schon seit Wochen 0 Mb/s upload.
                                          Friedhofsblond 1 Reply Last reply Reply Quote 0
                                          • Friedhofsblond
                                            Friedhofsblond @Bongo last edited by Friedhofsblond
                                            @bongo
                                            Moin,
                                            habe gerade Probleme mit Router oder Kabelanschluss und den Adapter installiert.
                                            (Debian12 auf Dell-Wyse)
                                            Soweit läuft alles bei mir sauber:
                                            hatte mit der Fritzbox aber bessere Werte als hier mit dem Kabelmodem:
                                            (ich brauche ja Argumente bei AVM oder VF - jeder schiebt das Problem auf den anderen)
                                            So dann werd ich mal auf die DB speichern.
                                            Danke für den Adapter 👍
                                            31.7k
                                            79.8k
                                            vodafone speedtest
                                            42
                                            202
                                            25293
