    4. Adapter "smartmeter"
    • O
      oxident last edited by
      Hallo!
      Ich teste gerade, ob ich die SML-Daten der Tibber-Bridge mit dem Smartmeter-Adapter auslesen kann und kann diese mittlerweile direkt von der Bridge via HTTP auslesen.
      Leider mag der Adapter diese jedoch nicht korrekt interpretieren:
      Error while parsing SML message: Error: Unknown TL-Field 0x6ffd6 for OctetString [Offset: 41]!: Message: 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
      Ich frage mich nun, ob ich es mir zu einfach mache oder ob ich hier völlig auf dem Holzweg bin.
      Wenn ich die URL mit dem Browser öffne, dann erhalte ich eine Menge binärer Daten welche sich auch bei jedem Aufruf ändern. Denke also schon, es ist SML 😉
        apollon77 @oxident last edited by
        @oxident Naja er erkennt einen Fehler in den Daten.
        Frage: ist der Fehler immer an der gleichen stelle und der gleiche Fehler? Wenn ja muss ich schauen- >GitHub issue bitte.
        Wenn es immer eine andere Stelle/Meldung ist dann kippen Bits, dann Kopfsitz prüfen, ggf kabel anders verlegen, aktiven USB Hub,. Schirmung prüfen ......
        • O
          oxident @apollon77 last edited by
          @apollon77 Bisher ist der Fehler permanent und immer identisch.
          Wenn ich die gleichen Daten in Node Red mit der smllib verarbeite klappt es.
          Ich kümmere mich mal um ein Issue!
            SmartHomer 0 @Arni_Banone last edited by SmartHomer 0
            @arni_banone sagte in Adapter "smartmeter":
            Ich versuche gerade einen W610 per EHZ001K-> RS232 -> Wifi mit smartmeter Adapter zum Laufen zu bringen.
            Ich nutze meinen USR W-610 via WLAN zwischenzeitlich zwar ebenfalls mit dem Modbus-Adapter,
            hatte ihn aber auch schon am SmartMeter-Adapter "am Laufen".
            Einstellungen im SmartMeter-Adapter
            Einstellungen im USR-W610
            Mode Selection Parameter USR-W610
            AP Interface-Setting Parameter USR-W610
            Irrelevant, da oben unter Mode Selection "STA-Mode" ausgewählt wurde
            STA Interface-Setting Parameter USR-W610
            Application Setting / Wifu-Uart Setting Parameter USR-W610
            (Modbus-Polling-Settings müssten bei Dir dann "Aus"geschaltet werden, da kein ModBus, sondern reine ser. RS485-Übertragung)
            Ethernet Setting / Ethernet Ports Setting Parameter USR-W610
            HTTPD Client Mode Parameter USR-W610
            Irrelevant
            Advanced Settings Parameter USR-W610
            Device Management USR-W610
            Im Device Management braucht es evtl. einige "Restarts", bis alle Parameter übernommen werden, evtl. auch mal den USR-W610 stromlos machen, kurz warten und dann wieder einstecken - insbesondere zeigte er sich etwas "hartnäckig", bis er "Mode Selection"-Änderungen annimmt und sich das WLAN parametrieren lässt. Wenn erst einmal alles eingestellt ist, läuft der USR-W610 zuverlässig.
              @oxident sagte in Adapter "smartmeter":
              smllib
              Hm ... an sich ist im Adapter auch die smllib dahinter .. aber keine ahnung ... Naja es gab auch Firmwarebugs und sowas .. aber ja da muss man genau reinschauen
                Arni_Banone @GMJ last edited by
                @gmj
                Ich hatte ja neulich ein paar Frageb zum USR W610.
                Allerdings scheint das Problem woanders zu liegen.
                Ein USR-410S funktioniert mit meinem eskra Zähler einwandfrei.
                Am Logarex LK13BE hingegen blinkt die RS232 LED gar nicht los. Also werden keine Daten vom ehz001k empfangen.
                Selber Sensor, selbes USR-410S Modul. Die D0 LED scheint zu schwach zu sein.
                Auch bei offenem Zählerschrank kommen keine Daten.
                Gibt es bessere Sensoren. Oder nützt es was, den ehz001k mal aus seinem Gehäuse zu holen, um die Transmissionsverluste zu reduzieren?
                Danke euch.
                  klassisch Most Active @Arni_Banone last edited by klassisch
                  @arni_banone Das liegt wahrscheinlich nicht am Sensor, sondern am Zähler. Mein EHZ001K funktioniert noch immer einwandfrei und da der eigentlich für die Nutzung hinter der Plombe gebaut ist, wird er eine längere Lebensdauer haben.
                  Der Logarex steht (wie auch der Holley) auf der Weidmann Liste https://shop.weidmann-elektronik.de/media/files_public/67303f78bbcd558d664d0095291562d3/BekannteProblememitZhlermodellen.pdf der Zähler mit sterbenden Sende-IR-LEDs.
                  A G 2 Replies Last reply Reply Quote 1
                    Arni_Banone @klassisch last edited by
                    @klassisch said in Adapter "smartmeter":
                    Oh man, da kann man natürlich lange nach Fehlern suchen. Mal sehen, was der Messstellenbetreiber dazu sagt.
                    Aber danke für den Tipp.
                      klassisch Most Active last edited by klassisch
                      Byebye Smartmeter-Adapter?
                      Mein grundzuständiger Meßstellenbetreiber hat mir den Tausch der 9 Monate alten mME in ein intelligentes Meßsystem iMSys angekündigt. In der FNN dazu finde ich keine Forderung nach einer Info Schnittstelle. Da mein Meßstallenbetreiber eher zurückhaltend agiert, besteht die Gefahr, daß der neue Zähler die Info Schnittstelle nicht mehr unterstützen wird - zumal er für eine Übermittlung der Rohdaten über sein Portal zusätzlich zu den variablen Zählergebühren nochmals ca. 20EUR im Monat Jahr (edit: korrigiert) kassiert https://api.netze-bw.de/ctfservice/v1/assets/38mhEjtGLqRKVIig7qJav .
                      Man bekommt dann einmal täglich
                      • Werte/Werteart: Zählerstandsgang
                      • Wertegranularität: ¼ stündlich
                      • Energieflussrichtung: Erzeugung oder Verbrauch
                      • Übermittlungsintervall: täglich
                      • Wertequalität: Rohdaten
                      • Bereitstellung: standardisierte WEB-Schnittstelle
                      • Keine Plausibilisierung und Ersatzwertbildung
                      Wäre natürlich ein großer Rückschritt gegenüber der mME.
                      Haben wir im ioBroker Universum einen Adapter, der die Daten vom Meßstellenbetreiber abholen könnte?
                      apollon77 Homoran 2 Replies Last reply Reply Quote 0
                        apollon77 @klassisch last edited by
                        @klassisch ich fürchte bisher nicht. Müsste man dann bauen.
                          klassisch Most Active @apollon77 last edited by
                          @apollon77 Vielen Dank für die Antwort. Wir werden sehen, was der Spion im Haus dann können wird und was nicht.
                            Homoran Global Moderator Administrators @klassisch last edited by
                            @klassisch Owei!
                            Es hilft fir jetzt nicht, aber genau wegen so eines Szenarios habe ich mir nach dem EVU-Zähler einen SDM630 einbauen lassen.
                            Damit bekomme ich immerhin die aktuelle Leistung total und die der Phasen.
                            Für den Mehrpreis im Vergleich zum SDM72 hatte ich gehofft auch die Enegiewerte saldiert zu bekommen, was leider nicht der Fall ist.
                            Es werden nur die Energiewerte der Einzelphasen für In und Out angeboten, der vermeintliche saldierte Wert über alle Phasen ist nur die Bilanz zwischen Einspeisung und Bezug.
                            Laut Forum soll der WAGO Zähler die korrekte Saldierung können, kostet dann aber nochmal mehr
                            Bei 20 Teuros pro Monat hättest du den aber auch in einem Jahr amortisiert.
                            eine viertelstündliche Aktualisierung mag für dynamische Tarife ausreichend sein, für eine Leistungsüberwachung aber absolut unbrauchbar.
                            Die Kenndaten deuten daraufhin, dass in so einem Fall ohne Kundenschnittstelle nur die Interessen des EVU berücksichtigt werden.
                            • Vorbereitung auf Bereitstellung dynamischer Tarife
                            • geringer Datenverkehr
                            • geringere aufzuarbeitende Datenmengen
                            • (Gewinnmaximierung)
                            Allerdings könnte die viertelstündliche Übermittlung auch eine datenschutzrechtliche Ursache haben, um das Kundenprofil zu schützen und die Lebensgewohneiten nicht zu detailliert verfolgen zu können.
                            • wendy2702
                              wendy2702 last edited by
                              Ich habe mir den Inepro Pro380Eingebaut um unabhängig vom Anbieter sein zu können.
                              Lese damit aktuell diese Werte aus:
                                Homoran Global Moderator Administrators @wendy2702 last edited by
                                @wendy2702 passen die ersten beiden "Zählerstände" zu denen des EVU ?
                                • wendy2702
                                  wendy2702 @Homoran last edited by
                                  @homoran Nein.
                                  Wenn ich mich richtig erinnere kann man die setzen. Habe ich aber nicht umgesetzt da auch der Zähler vom EVU zwischenzeitlich 2x gewechselt wurde und die wieder mit neuen Werten gestartet haben.
                                  Aktuell rechne ich einmal am letzten Tag im Monat einfach den Monatsverbrauch bzw. die Einspeisung aus. und kann ja noch per Smartmeter den derzeitigen EVU Zähler abfragen.
                                  Intelligente Messeinrichtung soll ich (dank Freund) wenn als Pilot Kunde wohl mit vollem Zugriff auf die Daten und kostenlos bekommen.
                                  Die müssen sich nur noch entscheiden von welchem Anbieter Sie das Zeug kaufen.
                                    klassisch Most Active @Homoran last edited by klassisch
                                    [OT]
                                    @homoran Vielen Dank! Zuerst muß ich mich entschuldigen, die 20EUR sind Jahrespreis. Trotzdem zu teuer.
                                    15 Minuten Rasterung sind mir zu grob. Darauf kann man nicht ordentlich regeln und mit Auslieferung 1 mal pro Tag ist das Thema eh durch.
                                    Plan B ist das Fronius-Smartmeter, welches ohnehin für die Solaranlage direkt nach dem Netzzähler verbaut ist, zu nutzen.
                                    Das Einlesen läuft derzeit über den Gen24, allerdings recht langsam. Habe die Pollrate von 30 Sekunden auf 15 Sekunden herabgesetzt und beobachte das mal.
                                    Vielleicht kann man das Fronius Meter auch über Modbus Adapter als Slave auslesen ohne die Froinus Kommunikation zu stören.
                                    Das Fronius Meter stellt u.a. zur Verfügung:
                                    [OT²]
                                    Das iMsys wird gerade gepusht. Das Energiewirtschaftsgesetz wird gerade überarbeitet. §14a Anlagen (PV UND (Wallbox ODER Wärmepumpe)) müssen ab 1.1.2024 an diesem Prozeß teilnehmen und die Anlagen müssen entsprechend aufgerüstet werden. Also, wenn die technischen Randbedingungen mal geklärt sind. Wird wohl noch ein paar Jahre dauern. Leute, die da wahrscheinlich mehr wissen als ich, tippen auf EEBUS als Protokoll.
                                      Homoran Global Moderator Administrators @wendy2702 last edited by Homoran
                                      @wendy2702 sagte in Adapter "smartmeter":
                                      das meine ich nicht.
                                      Es geht um die Richtigkeit. Das kann man auch mit täglicher Differenz überprüfen.
                                      siehe diesen Thread zu den saldierten Werten
                                      https://forum.iobroker.net/post/1056035
                                      wendy2702 K 2 Replies Last reply Reply Quote 0
                                      • wendy2702
                                        @homoran Achso.
                                        Habe ich nicht explizit kontrolliert.
                                        Da ich den aber als geeichte Version habe gehe ich davon aus das es passt.
                                          @homoran sagte in Adapter "smartmeter":
                                          Für den Fronius habe ich das mal für einige Tage stichprobenartig gemacht.
                                          Bei nennenswerten Energien habe ich Abweichungen im Promille und Subpromille Bereich.
                                          Ich speichere derzeit nicht alle Energiewerte ab, sondern nur bei entsprechenden Änderungen. Deshalb berechne ich bei kleinen Tageswerten Abweichungen im niedrigen einstelligen Prozentbereich.
                                          Das Fronius Smartmeter scheint HW-seitig ein Carlo Gavazzi zu sein, allerdings wohl mit eigener Fronius Firmware
                                            hab ich auch, hat aber nur Einfluß auf die Richtigkeit der Leistungsmessung, nicht auf die Art der Kumulation der Energiewerte.
                                            Da bin ich auch drauf reingefallen.
                                            @klassisch sagte in Adapter "smartmeter":
                                            mein EM24 rechnet die Energie genau wie der SDM630.
                                            Die phasenübergreifende Saldierung scheint eine deutsche Spezialität zu sein.
                                            3625
                                            2286751
