    4. Zigbee Thermometer kann nicht eingebunden werden
      Thomas Braun Most Active @ccbuddy last edited by
      @ccbuddy
      Der crasht aber mit Sicherheit nicht lautlos.
      Schau ins Log.
        ccbuddy @Thomas Braun last edited by
        @thomas-braun ok, hier mit etwas mehr Geräusch:
        Thomas Braun arteck 2 Replies Last reply Reply Quote 0
          @ccbuddy
          Als Text in CodeTags eingebettet, nicht als Screenshot.
            ccbuddy @Thomas Braun last edited by Homoran
            	2023-11-12 15:55:58.350	info	Starting Zigbee npm ...
            zigbee.0
            2023-11-12 15:55:58.348	info	delete old Backup files. keep only last 10
            zigbee.0
            2023-11-12 15:55:58.201	info	starting. Version 1.8.24 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.17.1, js-controller: 5.0.12
            zigbee.0
            2023-11-12 15:55:22.891	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
            zigbee.0
            2023-11-12 15:55:22.889	info	terminating
            zigbee.0
            2023-11-12 15:55:22.676	info	Zigbee: disabling joining new devices.
            zigbee.0
            2023-11-12 15:55:22.387	info	cleaned everything up...
            zigbee.0
            2023-11-12 15:55:22.382	error	Parameter "parentDevice" needs to be of type "string" but type "object" has been passed
            zigbee.0
            2023-11-12 15:55:22.382	error	Error: Parameter "parentDevice" needs to be of type "string" but type "object" has been passed at Validator.assertString (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/validator.js:168:19) at Zigbee.deleteState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:4146:31) at /opt/iobroker/node_modules/iobroker.zigbee/lib/exclude.js:111:34
            zigbee.0
            2023-11-12 15:55:22.379	error	unhandled promise rejection: Parameter "parentDevice" needs to be of type "string" but type "object" has been passed
            zigbee.0
            2023-11-12 15:55:22.379	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
              arteck Developer Most Active @ccbuddy last edited by
              @ccbuddy hmm.. der Fehler sollte schon behoben sein ..im GIT...
              dann schmeiss wech das olle ding...
              wechsel auf zigbee2mqtt .. kein plan was mit dem Ding nicht stimmt
              Cluni C 2 Replies Last reply Reply Quote 0
              • Cluni
                Cluni @arteck last edited by Cluni
                @arteck said in Zigbee Thermometer kann nicht eingebunden werden:
                Ich muss mal kurz nachfragen: Mit "dann schmeiss wech das olle ding..." meinst du den normalen Zigbee-Adapter? Oder verstehe ich das falsch? Ich habe das bis jetzt so verstanden, dass sowohl der Zigbee- als auch der Zigbee2MQTT-Adapter eigentlich gleichwertig sind und das eher "Geschmackssache" ist, für welchen man sich entscheidet?! Ist dem nicht so und der Zigbee2MQTT-Adapter wäre die bessere Wahl?
                Cluni 1 Reply Last reply Reply Quote 0
                  ccbuddy @arteck last edited by
                  @arteck meintest Du mit "schon gefixt im GIT" den Fehler, dass das Entfernen aus dem Exclude Tab nicht geht, oder dass das Thermometer dann funktionieren sollte?
                  Die GIT Version hatte ich zwar probiert, aber dadurch dass ich den Exclude Eintrag nicht entfernen kann, konnte ich es nicht final ausprobieren
                  Gibt es evtl. für den Exclude Eintrag die Möglichkeit ein File zu editieren? Um ihn so zu entfernen?
                    ccbuddy @ccbuddy last edited by
                    ich habe das Problem gelöst indem ich alle möglichen Thermometer in /opt/iobroker/node_modules/zigbee-herdsman-converters/devices/tuya.js durchprobiert habe
                    Wenn ich am Modell ZG-227ZL den Fingerprint meines Thermometers ('_TZE200_qyflbnbj') hinten dran hänge, so wie hier:
                        fingerprint: tuya.fingerprint('TS0601', ['_TZE200_qoy0ekbd', '_TZE200_znbl8dj5', '_TZE200_a8sdabtg',        '_TZE200_qyflbnbj'         ]),
                        model: 'ZG-227ZL',
                    dann kann ich die Datenpunkte:
                    [1, 'temperature'
                    [2, 'humidity'
                    [4, 'battery'
                    im Object Tree verwenden
                    (den derzeitigen Match unter
                        fingerprint: [{ modelID: 'TS0601', manufacturerName: '_TZE200_bq5c8xfe' },
                            { modelID: 'TS0601', manufacturerName: '_TZE200_bjawzodf' },
                            //{ modelID: 'TS0601', manufacturerName: '_TZE200_qyflbnbj' },
                            { modelID: 'TS0601', manufacturerName: '_TZE200_vs0skpuc' },
                            { modelID: 'TS0601', manufacturerName: '_TZE200_44af8vyi' },
                            { modelID: 'TS0601', manufacturerName: '_TZE200_zl1kmjqx' }],
                        model: 'TS0601_temperature_humidity_sensor_1',
                    habe ich auskommentiert, damit es keine Überlappungen gibt
                    Leider bin ich nicht so recht der Guru im ZigBee Adapter Code. Aber falls sich jemand angesprochen fühlt, darf er das gerne im GIT einchecken sodass ich diese Änderung nicht mehr bei jedem Update des Zigbbe Adapter manuell machen muss
                    Für mich funktioniert dies erst mal
                      @ccbuddy der ist doch schon längst drin
                      https://github.com/Koenkk/zigbee-herdsman-converters/blob/6ce404d203b0946b7eaefe7abfc211568c55774a/src/devices/tuya.ts#L609
                        @arteck ja,ja, schon richtig; hat aber halt nicht funktioniert; genau deshalb habe ich den thread ja aufgemacht.
                        So wie es für mich aussieht, liefer mein Thermometer die Daten etwas anders verpackt als in dem Handler angenommen. Der Converter für ZG-227ZL
                            fingerprint: tuya.fingerprint('TS0601', ['_TZE200_qoy0ekbd', '_TZE200_znbl8dj5', '_TZE200_a8sdabtg', '_TZE200_dikkika5']),
                            model: 'ZG-227ZL',
                            vendor: 'TuYa',
                            description: 'Temperature & humidity LCD sensor',
                            fromZigbee: [tuya.fz.datapoints],
                            toZigbee: [tuya.tz.datapoints],
                            configure: tuya.configureMagicPacket,
                            exposes: [e.temperature(), e.humidity(), tuya.exposes.temperatureUnit(), tuya.exposes.temperatureCalibration(),
                                tuya.exposes.humidityCalibration(), e.battery()],
                            whiteLabel: [
                                tuya.whitelabel('TuYa', 'ZG-227Z', 'Temperature and humidity sensor', ['_TZE200_a8sdabtg']),
                                tuya.whitelabel('KOJIMA', 'KOJIMA-THS-ZG-LCD', 'Temperature and humidity sensor', ['_TZE200_dikkika5']),
                            meta: {
                                tuyaDatapoints: [
                                    [1, 'temperature', tuya.valueConverter.divideBy10],
                                    [2, 'humidity', tuya.valueConverter.raw],
                                    [4, 'battery', tuya.valueConverter.raw],
                                    [9, 'temperature_unit', tuya.valueConverter.temperatureUnit],
                                    [23, 'temperature_calibration', tuya.valueConverter.divideBy10],
                                    [24, 'humidity_calibration', tuya.valueConverter.raw],
                        mapped die Datenpunkte anders; siehe meta:...
                        im "msg_from_zigbee" Datensatz aus dem Object Tree liefert er z.B. auch :
                        {"type":"commandDataResponse","data":{"seq":63232,"dpValues":[{"dp":1,"datatype":2,"data":{"type":"Buffer","data":[0,0,0,210]}}]},"linkquality":63,"groupID":0,"cluster":"manuSpecificTuya","meta":{"zclTransactionSequenceNumber":95,"manufacturerCode":null,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}},"endpoint_id":1}
                        Die Temperatur ist 21,0°C; die dp 1 ist für Temperatur, 2 wäre für Humidity
                        • Cluni
                          Cluni @Cluni last edited by
                          @cluni said in Zigbee Thermometer kann nicht eingebunden werden:
                          Keine Antwort? Würde mich echt interessieren!
                          LG Bernd
                            arteck Developer Most Active @Cluni last edited by
                            @cluni sry..bist mir duch die lappen gegangen.... aber hab ich doch geschrieben...
                            • Cluni
                              @arteck das heißt also jetzt im Klartext, dass man den "normalen" Zigbee-Adapter nicht mehr verwenden soll (weil obsolete?)? Ich wusste das ehrlich gesagt nicht und dachte, dass dies nur 2 unabhängige aber ebenbürtige Zweige sind. Vielleicht sollte man die in der Adapterbeschreibung mal mit einem Hinweis versehen, wenn lieber der Zigbee2MQTT verwendet werden soll. Oder habe ich das einfach nur irgendwo übersehen?
                                arteck Developer Most Active @Cluni last edited by arteck
                                @cluni
                                du hast es falsch verstanden..
                                es sind immer noch 2 Adapter die gepflegt werden.. PUNKT
                                die Thermostate sind in der Einbindung tricky.. und mir fehlt die Zeit sich damit auseinander zu setzten..
                                ausserdem habe ich die Hardware nicht hier.. deshalb ist es ratsam sich zigbee2mqtt zu installieren wenn du ein Zoo an sonder Geräten hast da die dorten besser unterstützt werden..
                                welchen Adapter du benutzt bleibt dir überlassen.. im Zigbee Adapter musst du nur damit rechnen, dass manche Thermostate nicht 100% gehen werden.. nicht mehr nicht weniger
                                C Cluni 2 Replies Last reply Reply Quote 0
                                  @arteck ah ok, ich habe Euren Dialog mitgelesen und mir war es auch erst nicht ganz klar. Nun aber schon. Kann verstehen, dass man bei den Thermometern verrückt werden kann. Ich habe am Wochenende einfach mal stur durchprobiert bis es irgendwie geklappt hat (s.o.).
                                  Noch eine finale Frage. Wenn man den Zigbee-Adapter und den Zigbee2MQTT-Adapter parallel auf einem iobroker installiert haben möchte, dann braucht man wohl auch zwei USB-nach-Zigbee-Dongle? die dann auch auf unterschiedlichen Zigbee Netzwerken arbeiten?
                                  Oder?
                                    @ccbuddy sagte in Zigbee Thermometer kann nicht eingebunden werden:
                                    Thermometern
                                    Thermostate... richtig lesen bitte.. sonst haben wir gleich wieder eine Diskussion
                                    wenn du beie Adapter Parallel laufen lassen willst dann .. ja brauchst 2 coordinatoren.. aber warum sollte man das tun..
                                    du kannst die Geräte alle von einem in den anderen Migrieren..
                                    nochmal funktionieren Geräte wie Thermostate nicht wie gewünscht im Zigbee Adapter kannst du dein komplettes Netzwerk rüber in den zigbee2mqtt Adapter ziehen (WIki lesen wie das geht)..
                                    wenn funktionen fehlen wie es bei dem FP1 von aqara ist.. dann nimm auch den zigbee2mqtt... alles andere macht keinen Sinn
                                    • Cluni
                                      @arteck Ahhhhhh, jetzt wird da ein Schuh draus. Danke für die Erläuterung. Hörte sich wie gesagt für mich anders an.
                                      2423
