    4. Adapter Updates gehen nicht: Timeout
      wrod @Thomas Braun last edited by
      Danke, probiere ich gerade. Zusätzlich habe ich folgende Fehler:
      • "Cannot check node.js versions: Error: getaddrinfo EAI_AGAIN nodejs.org"
      • vis.0 "Cannot check license: Error: getaddrinfo EAI_AGAIN iobroker.net"
      OK: iob update sagt:
      Used repository: Stable (default)
      Cannot download repository hash file from "http://download.iobroker.net/sources-dist-hash.json": timeout of 10000ms exceeded
      Cannot download repository file from "http://download.iobroker.net/sources-dist.json": timeout of 10000ms exceeded
      Adapter    "admin"        : 6.12.0   , installed 6.10.1 [Updatable]
      Adapter    "backitup"     : 2.8.1    , installed 2.8.1
      Adapter    "ble"          : 0.13.4   , installed 0.13.4
      Adapter    "bydbatt"      : 1.0.8    , installed 1.0.8
      Adapter    "device-watcher": 2.9.3   , installed 2.9.3
      Adapter    "discovery"    : 3.1.0    , installed 3.1.0
      Adapter    "ds18b20"      : 2.0.4    , installed 2.0.4
      Adapter    "fritzdect"    : 2.3.1    , installed 2.3.1
      Adapter    "ham"          : 5.3.1    , installed 5.3.1
      Adapter    "hue"          : 3.10.1   , installed 3.10.1
      Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
      Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
      Adapter    "javascript"   : 7.1.4    , installed 7.1.4
      Controller "js-controller": 5.0.12   , installed 5.0.12
      Adapter    "lightcontrol" : 0.4.0    , installed 0.4.0
      Adapter    "modbus"       : 5.0.11   , installed 5.0.11
      Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
      Adapter    "radar2"       : 2.0.8    , installed 2.0.7  [Updatable]
      Adapter    "shelly"       : 6.4.5    , installed 6.4.1  [Updatable]
      Adapter    "smartcontrol" : 2.0.1    , installed 2.0.1
      Adapter    "smartmeter"   : 3.3.4    , installed 3.3.4
      Adapter    "smartthings"  : 0.0.4    , installed 0.0.4
      Adapter    "socketio"     : 6.5.5    , installed 6.5.5
      Adapter    "sonoff"       : 2.5.3    , installed 2.5.3
      Adapter    "statistics"   : 2.3.0    , installed 2.3.0
      Adapter    "synochat"     : 1.3.1    , installed 1.3.1
      Adapter    "synology"     : 3.0.0    , installed 3.0.0
      Adapter    "tuya"         : 3.14.2   , installed 3.14.2
      Adapter    "vis"          : 1.4.16   , installed 1.4.16
      Adapter    "vis-icontwo"  : 0.96.0   , installed 0.96.0
      Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
      Adapter    "web"          : 6.1.2    , installed 6.1.2
      Adapter    "wifilight"    : 1.1.4    , installed 1.1.4
      Adapter    "ws"           : 2.5.5    , installed 2.5.5
      iob upgrade all ergibt:
      This upgrade of "radar2" will introduce the following changes:
      -> 2.0.8:
      arp-scan detection for debian 12 has been fixed
      Would you like to upgrade radar2 from @2.0.7 to @2.0.8 now? [(y)es, (n)o]: y
      Update radar2 from @2.0.7 to @2.0.8
      NPM version: 10.1.0
      Installing iobroker.radar2@2.0.8... (System call)
      upload [8] radar2.admin /opt/iobroker/node_modules/iobroker.radar2/admin/index.html index.html text/html
      upload [7] radar2.admin /opt/iobroker/node_modules/iobroker.radar2/admin/index_m.html index_m.html text/html
      upload [6] radar2.admin /opt/iobroker/node_modules/iobroker.radar2/admin/network_test.js network_test.js application/javascript
      upload [5] radar2.admin /opt/iobroker/node_modules/iobroker.radar2/admin/node_ble_test.js node_ble_test.js application/javascript
      upload [4] radar2.admin /opt/iobroker/node_modules/iobroker.radar2/admin/radar2.png radar2.png image/png
      upload [3] radar2.admin /opt/iobroker/node_modules/iobroker.radar2/admin/tools.js tools.js application/javascript
      upload [2] radar2.admin /opt/iobroker/node_modules/iobroker.radar2/admin/vendors.json vendors.json application/json
      upload [1] radar2.admin /opt/iobroker/node_modules/iobroker.radar2/admin/words.js words.js application/javascript
      upload [0] radar2.admin /opt/iobroker/node_modules/iobroker.radar2/admin/words.json words.json application/json
      This upgrade of "admin" will at least introduce the following changes:
      -> 6.12.0:
      fixed issue when updating news in backend
      validate json config against the schema
      update socket-client to improve performance
      -> 6.11.0:
      jsonConfig type number now stores values as number instead of string
      objects browser number value input behavior change to allow leading minus
      Added component `interfaces` to the JSON config
      Implemented Backend to GUI communication
      -> 6.10.9:
      Improvement of the public accessibility check
      -> 6.10.8:
      update adapter-react-v5 to fix issues with object browser
      -> 6.10.7:
      Corrected adapter termination if the alias has no target
      -> 6.10.6:
      Added possibility to show the icon on JSON config tabs
      on upgrade all, not yet started commands can now be aborted
      Added security check if the server is available from the internet without protection
      Corrected navigation after the settings closing
      -> 6.10.5:
      JSON config component `port` does no longer mark port as occupied if it is only occupied on another host
      register news as notifications
      if upgrade all is stopped on error, activate close button
      Export/import objects with its values
      Would you like to upgrade admin from @6.10.1 to @6.12.0 now? [(y)es, (n)o]: y
      Update admin from @6.10.1 to @6.12.0
      host.iobrokerpi Adapter "system.adapter.admin.0" is stopped.
      NPM version: 10.1.0
      Installing iobroker.admin@6.12.0... (System call)
      upload [52] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
      upload [50] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/customComponents.js.map custom/customComponents.js.map application/json
      upload [40] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/zh-cn.json custom/i18n/zh-cn.json application/json
      upload [30] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_prop-types_index_js.512eddf9.chunk.js.map custom/static/js/node_modules_prop-types_index_js.512eddf9.chunk.js.map application/json
      upload [20] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map application/json
      upload [19] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js application/javascript
      upload [18] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map application/json
      upload [17] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js application/javascript
      upload [16] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js.map custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js.map application/json
      upload [15] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js application/javascript
      upload [14] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js.map custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js.map application/json
      upload [13] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js application/javascript
      upload [12] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js.map custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js.map application/json
      upload [11] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/de/translations.json i18n/de/translations.json application/json
      upload [10] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/en/translations.json i18n/en/translations.json application/json
      upload [9] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/es/translations.json i18n/es/translations.json application/json
      upload [8] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
      upload [7] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/it/translations.json i18n/it/translations.json application/json
      upload [6] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
      upload [5] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
      upload [4] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
      upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
      upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
      upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
      upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/jsonConfig.json5 jsonConfig.json5 application/json5
      host.iobrokerpi Adapter "system.adapter.admin.0" is started
      This upgrade of "shelly" will introduce the following changes:
      -> 6.4.5:
      Added Shelly Pro Dual Cover/Shutter PM
      Added Shelly Pro 3 EM 400A
      Added support of Shelly Plus 1 Mini + Shelly Plus 1 PM Mini
      Added support of Shelly Plus AddOn for Gen2 Devices.
      Added support of Plus PM Mini
      Would you like to upgrade shelly from @6.4.1 to @6.4.5 now? [(y)es, (n)o]: y
      Update shelly from @6.4.1 to @6.4.5
      NPM version: 10.1.0
      Installing iobroker.shelly@6.4.5... (System call)
      upload [13] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/de/translations.json i18n/de/translations.json application/json
      upload [12] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/en/translations.json i18n/en/translations.json application/json
      upload [11] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/es/translations.json i18n/es/translations.json application/json
      upload [10] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
      upload [9] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/it/translations.json i18n/it/translations.json application/json
      upload [8] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
      upload [7] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
      upload [6] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
      upload [5] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
      upload [4] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
      upload [3] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
      upload [2] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/jsonConfig.json jsonConfig.json application/json
      upload [1] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/shelly.png shelly.png image/png
      upload [0] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/words.js words.js application/javascript
      ABER:
      Danach sind die Adapter eben nicht installiert, sondern alles beim Alten:
      • 3 ausstehende Adapter (admin; radar2; shelly)
      • admin.0 2023-11-16 16:32:10.766 warn Cannot update rating: timeout of 15000ms exceeded
      auch behauptet die Instanz db1820, das remote-system sei nicht verbunden, es wird aber als verbunden angezeigt, wenn ich die Instanz öffne.
      Komisch, alles
        Thomas Braun Most Active @wrod last edited by
        @wrod
        Du scheinst Trouble in deinem Netzwerk zu haben.
          @thomas-braun Danke. Nur: welcher Art? Eine Idee, was ich monitoren könnte?
            @wrod
            Router mal neustarten?
              @thomas-braun bringt leider auch nichts. Nach mehreren Tagen selbes Bild.
              • Marc Berg
                Marc Berg Most Active @wrod last edited by
                @wrod
                Mach mal ein
                ping repo.iobroker.live
                sowie
                ping download.iobroker.net
                und zeige die Ergebnisse.
                  wrod @Marc Berg last edited by
                  @marc-berg said in Adapter Updates gehen nicht: Timeout:
                  Ja, scheint irgendwor dort zu liegen:
                  pi@iobrokerpi:~ $ ping repo.iobroker.live
                  ping: repo.iobroker.live: Tempor▒rer Fehler bei der Namensaufl▒sung
                  pi@iobrokerpi:~ $ ping download.iobroker.net
                  ping: download.iobroker.net: Tempor▒rer Fehler bei der Namensaufl▒sung
                  pi@iobrokerpi:~ $
                  Hmmm. Und nun?
                  • Marc Berg
                    @wrod sagte in Adapter Updates gehen nicht: Timeout:
                    Hmmm. Und nun?
                    Nun kennst du die Ursache. Deine DNS Einstellungen sind wohl irgendwie verbogen.
                    • Ro75
                      Ro75 last edited by
                      @wrod
                      piHole oder etwas in der Art bei dir aktiv?
                      Ro75.
                        wrod @Ro75 last edited by
                        @ro75 Nicht, dass ich wüsste.
                        Worauf könnte ich sonst prüfen?
                          @wrod
                          Du könntest per dig schauen, wer da was wo auflöst.
                          Schaut dann so aus:
                          echad@chet:~ $ dig repo.iobroker.live
                          ; <<>> DiG 9.19.17-1-Debian <<>> repo.iobroker.live
                          ;; global options: +cmd
                          ;; Got answer:
                          ;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 28877
                          ;; flags: qr rd ra ad; QUERY: 1, ANSWER: 3, AUTHORITY: 0, ADDITIONAL: 1
                          ;; OPT PSEUDOSECTION:
                          ; EDNS: version: 0, flags:; udp: 1232
                          ; PAD: (334 bytes)
                          ;; QUESTION SECTION:
                          ;repo.iobroker.live.            IN      A
                          ;; ANSWER SECTION:
                          repo.iobroker.live.     3066    IN      CNAME   repo.iobroker.live.cdn.cloudflare.net.
                          repo.iobroker.live.cdn.cloudflare.net. 300 IN A 104.21.86.170
                          repo.iobroker.live.cdn.cloudflare.net. 300 IN A 172.67.222.102
                          ;; Query time: 23 msec
                          ;; SERVER: 192.168.178.1#53(192.168.178.1) (UDP)
                          ;; WHEN: Sun Nov 19 18:22:19 CET 2023
                          ;; MSG SIZE  rcvd: 468
                          echad@chet:~ $ dig download.iobroker.net
                          ; <<>> DiG 9.19.17-1-Debian <<>> download.iobroker.net
                          ;; Got answer:
                          ;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 39317
                          ;; flags: qr rd ra; QUERY: 1, ANSWER: 1, AUTHORITY: 0, ADDITIONAL: 1
                          ; PAD: (398 bytes)
                          ;download.iobroker.net.         IN      A
                          ;; ANSWER SECTION:
                          download.iobroker.net.  1208    IN      A       93.90.206.45
                          ;; Query time: 15 msec
                          ;; WHEN: Sun Nov 19 18:22:49 CET 2023
                          echad@chet:~ $
                          dig muss gegebenenfalls nachinstalliert werden.
                            wrod @Thomas Braun last edited by wrod
                            @thomas-braun said in Adapter Updates gehen nicht: Timeout:
                            Hmm. Das ergibt Folgendes:
                            pi@iobrokerpi:~ $ dig repo.iobroker.live
                            ; <<>> DiG 9.16.44-Raspbian <<>> repo.iobroker.live
                            ;; connection timed out; no servers could be reached
                            pi@iobrokerpi:~ $
                            In der Fritzbox ist der lokale DNS Server auf ihre eigene Adresse gesetzt: 192.168.220.1 - und natürlich, dass DNS-Server des Internet-Anbieters genutzt werden sollen.
                            Thomas Braun R 2 Replies Last reply Reply Quote 0
                              @wrod
                              cat /etc/resolv.conf
                              sagt?
                                Komisch:
                                # Generated by resolvconf
                                search fritz.box
                                nameserver 127.0.0.1
                                  RoccoNaut @wrod last edited by
                                  @wrod ich hatte das Problem auch kürzlich.
                                  Bei mir lag der fehler in der
                                  /etc/resolv.conf
                                    wrod @RoccoNaut last edited by
                                    @rocconaut Danke. Dort steht
                                    domain fritz.box
                                    nameserver 192.168.220.1
                                    nameserver fd00::2e91:abff:fe26:4d04
                                    nameserver 2a02:8108:1b80:1229:2e91:abff:fe26:4d04
                                      @wrod
                                      Da muss natürlich die IP des DNS-Servers rein.
                                      Hast du da irgendwas in deinem Netzwerk seltsam eingestellt?
                                      Denn ich verstehe auch nicht so ganz, was du damit sagen willst:
                                      R W 2 Replies Last reply Reply Quote 0
                                        RoccoNaut @Thomas Braun last edited by RoccoNaut
                                        @thomas-braun man kann in der FB einen lokalen DNS Server eintragen, wenn man einen im Netzwerk hat. Aber da die IP der FB eintragen ist irgendwie komisch.
                                        (Kenne aber die Standard Konfig der FB nicht, nutze ich seit Jahren nicht mehr)
                                        Den lokalen DNS würde ich in der FB mal deaktivieren. Und den DNS des ISP würde ich auch mal "überdenken", aber das ist ein anderes Thema.
                                          Thomas Braun Most Active @RoccoNaut last edited by Thomas Braun
                                          @rocconaut sagte in Adapter Updates gehen nicht: Timeout:
                                          Allerdings.
                                          Edit:
                                          Musste jetzt erstmal selber bei mir schauen. Als 'Lokaler DNS-Server' steht da die IP der FritzBox selber drin.
                                            @thomas-braun In der Fritz!Box steht unter Internet/Zugangsdaten:
                                            und unter:
                                            Heimnetz/Netzwerk/Netzwerkeinstellungen/ipv4
                                            2262
