Kein iobroker Backup mehr über BackitUp Adapter
@simatec sagte in Kein iobroker Backup mehr über BackitUp Adapter:
apt policy influx*
otto@raspberrypi:/opt $ apt policy influx* influxdb2-cli: Installed: 2.7.3-1 Candidate: 2.7.3-1 Version table: *** 2.7.3-1 500 500 https://repos.influxdata.com/debian stable/main arm64 Packages 100 /var/lib/dpkg/status 2.7.1-2 500 500 https://repos.influxdata.com/debian stable/main arm64 Packages 2.6.1 500 500 https://repos.influxdata.com/debian stable/main arm64 Packages 2.6.0 500 500 https://repos.influxdata.com/debian stable/main arm64 Packages 2.5.0 500 500 https://repos.influxdata.com/debian stable/main arm64 Packages 2.4.0 500 500 https://repos.influxdata.com/debian stable/main arm64 Packages 2.3.0 500 500 https://repos.influxdata.com/debian stable/main arm64 Packages influxdb-client: Installed: (none) Candidate: 1.6.7~rc0-1+b5 Version table: 1.6.7~rc0-1+b5 500 500 http://deb.debian.org/debian bullseye/main arm64 Packages influxdb-dev: Installed: (none) Candidate: (none) Version table: influxdb2-client: Installed: (none) Candidate: 2.7.1-1 Version table: 2.7.1-1 500 500 https://repos.influxdata.com/debian stable/main arm64 Packages influxdb: Installed: (none) Candidate: 1.8.10-1 Version table: 1.8.10-1 500 500 https://repos.influxdata.com/debian stable/main arm64 Packages 1.6.7~rc0-1+b5 500 500 http://deb.debian.org/debian bullseye/main arm64 Packages influxctl: Installed: (none) Candidate: 2.3.1 Version table: 2.3.1 500 500 https://repos.influxdata.com/debian stable/main arm64 Packages 2.3.0 500 500 https://repos.influxdata.com/debian stable/main arm64 Packages 2.2.0 500 500 https://repos.influxdata.com/debian stable/main arm64 Packages 2.1.0 500 500 https://repos.influxdata.com/debian stable/main arm64 Packages 2.0.4 500 500 https://repos.influxdata.com/debian stable/main arm64 Packages 2.0.3 500 500 https://repos.influxdata.com/debian stable/main arm64 Packages 2.0.2 500 500 https://repos.influxdata.com/debian stable/main arm64 Packages 2.0.1 500 500 https://repos.influxdata.com/debian stable/main arm64 Packages 2.0.0 500 500 https://repos.influxdata.com/debian stable/main arm64 Packages influxdb2: Installed: 2.7.4-1 Candidate: 2.7.4-1 Version table: *** 2.7.4-1 500 500 https://repos.influxdata.com/debian stable/main arm64 Packages 100 /var/lib/dpkg/status 2.7.3-1 500 500 https://repos.influxdata.com/debian stable/main arm64 Packages 2.7.1-1 500 500 https://repos.influxdata.com/debian stable/main arm64 Packages 2.7.0-1 500 500 https://repos.influxdata.com/debian stable/main arm64 Packages 2.6.1-1 500 500 https://repos.influxdata.com/debian stable/main arm64 Packages 2.6.0-1 500 500 https://repos.influxdata.com/debian stable/main arm64 Packages 2.5.1-1 500 500 https://repos.influxdata.com/debian stable/main arm64 Packages 2.4.0-1 500 500 https://repos.influxdata.com/debian stable/main arm64 Packages 2.3.0-1 500 500 https://repos.influxdata.com/debian stable/main arm64 Packages 2.2.0 500 500 https://repos.influxdata.com/debian stable/main arm64 Packages otto@raspberrypi:/opt $
@laser Influxdb2 und influxdb2-cli sind installiert.
Zeige mal bitte die Config von Backitup (Influx-Tab) und die Config im Influx Adapter.
Hast du bei der Installation und Einrichtung den Admin Token notiert oder wegkopiert?
Der muss in Backitup eingetragen werden -
@simatec den Token habe ich mir seinerzeit in einen Texteditor kopiert und gespeichert.
Beim Backup kommt auch die Meldung, das influx Backup wurde erstellt. Ich finde es aber nicht auf meinem NAS.
@laser Die IP muss in der Config raus... Lass das Feld leer.
Vollständiger Pfad ist nur für die User, die die influx-cli nicht im Standardpfad /usr/bin liegen haben -
@simatec hier die Meldungen beim Backup:
Started iobroker ... [DEBUG] [mount] - noserverino option: false [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=iobroker,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=2.0 //192.168.2.57/backup /opt/iobroker/backups" [DEBUG] [mount] - mount successfully completed [DEBUG] [mount] - done [DEBUG] [iobroker] - host.raspberrypi 3145 states saved [DEBUG] [iobroker] - host.raspberrypi 3839 objects saved [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2023_11_20-10_31_13_backupiobroker.tar.gz [DEBUG] [iobroker] - This backup can only be restored with js-controller version up from 4.1 [DEBUG] [iobroker] - done [DEBUG] [influxDB] - InfluxDB-Backup started ... [DEBUG] [influxDB] - Start InfluxDB Backup ... [DEBUG] [influxDB] - InfluxDB Backup tmp directory created [DEBUG] [influxDB] - Try deleting the InfluxDB tmp directory: "/opt/iobroker/backups/influxDB_2023_11_20-10_31_26_backupiobroker" [DEBUG] [influxDB] - InfluxDB tmp directory "/opt/iobroker/backups/influxDB_2023_11_20-10_31_26_backupiobroker" successfully deleted [DEBUG] [influxDB] - [ERROR] [influxDB] - Error: Command failed: influx backup --bucket iobroker -t fPGvK9QsLi2jJWNN_q5ccAyETlJ9plh-1qxfgsxuOEPymu9SCsQVHI3j47j44UbAUfqMpv8_in5zeFDC8D2Q0Q== "/opt/iobroker/backups/influxDB_2023_11_20-10_31_26_backupiobroker" 2023/11/20 10:31:26 INFO: Downloading metadata snapshot Error: failed to backup metadata: failed to download metadata snapshot: 401 Unauthorized: read:authorizations is unauthorized [DEBUG] [influxDB] - InfluxDB-Backup for is finish [DEBUG] [influxDB] - done [DEBUG] [cifs] - used copy path: /backup [DEBUG] [cifs] - done [ERROR] [clean] - Backup files not deleted from /opt/iobroker/backups because some errors. [DEBUG] [clean] - done [DEBUG] [telegram] - done [DEBUG] [historyHTML] - new history html values created [DEBUG] [historyHTML] - done [DEBUG] [historyJSON] - new history json values created [DEBUG] [historyJSON] - done [DEBUG] [umount] - mount activ, umount is started ... [DEBUG] [umount] - umount successfully completed [DEBUG] [umount] - done [EXIT] 0
@laser sagte in Kein iobroker Backup mehr über BackitUp Adapter:
Dann ist es doch nicht der Operator-Token oder du hast ihn versehentlich gelöscht.
Du hast mit dem Token keine Berechtigung.Hier eine Anleitung, wie du ihn wieder herstellen kannst.
https://github.com/simatec/ioBroker.backitup/wiki/Diverse-Anleitungen-für-ioBroker.backitup#token-für-influxdb-2x-backup-richtig-erstellen -
@simatec OK. Mache ich jetzt.
@simantec den neuen Token erstellt. heißt jetzt: w_82OMhVzJnXMTItS43qdbAwWyvrguzgRAiSQqDuqmb9WohKS3dKqrez-tInxG17EE64gBAC7oihtfkeKcfJBw==
aber immer noch:Started iobroker ... [DEBUG] [mount] - noserverino option: false [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=iobroker,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=2.0 //192.168.2.57/backup /opt/iobroker/backups" [DEBUG] [mount] - mount successfully completed [DEBUG] [mount] - done [DEBUG] [iobroker] - host.raspberrypi 3145 states saved [DEBUG] [iobroker] - host.raspberrypi 3839 objects saved [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2023_11_20-10_53_09_backupiobroker.tar.gz [DEBUG] [iobroker] - This backup can only be restored with js-controller version up from 4.1 [DEBUG] [iobroker] - done [DEBUG] [influxDB] - InfluxDB-Backup started ... [DEBUG] [influxDB] - Start InfluxDB Backup ... [DEBUG] [influxDB] - InfluxDB Backup tmp directory created [DEBUG] [influxDB] - Try deleting the InfluxDB tmp directory: "/opt/iobroker/backups/influxDB_2023_11_20-10_53_21_backupiobroker" [DEBUG] [influxDB] - InfluxDB tmp directory "/opt/iobroker/backups/influxDB_2023_11_20-10_53_21_backupiobroker" successfully deleted [DEBUG] [influxDB] - [ERROR] [influxDB] - Error: Command failed: influx backup --bucket iobroker -t w_82OMhVzJnXMTItS43qdbAwWyvrguzgRAiSQqDuqmb9WohKS3dKqrez-tInxG17EE64gBAC7oihtfkeKcfJBw== "/opt/iobroker/backups/influxDB_2023_11_20-10_53_21_backupiobroker" 2023/11/20 10:53:21 INFO: Downloading metadata snapshot Error: failed to backup metadata: failed to download metadata snapshot: 401 Unauthorized: read:authorizations is unauthorized [DEBUG] [influxDB] - InfluxDB-Backup for is finish [DEBUG] [influxDB] - done [DEBUG] [cifs] - used copy path: /backup [DEBUG] [cifs] - done [ERROR] [clean] - Backup files not deleted from /opt/iobroker/backups because some errors. [DEBUG] [clean] - done [DEBUG] [telegram] - done [DEBUG] [historyHTML] - new history html values created [DEBUG] [historyHTML] - done [DEBUG] [historyJSON] - new history json values created [DEBUG] [historyJSON] - done [DEBUG] [umount] - mount activ, umount is started ... [DEBUG] [umount] - umount successfully completed [DEBUG] [umount] - done [EXIT] 0
Wenn ich den Befehl auf der Konsole ausführe:
otto@raspberrypi:/opt $ influx backup --bucket iobroker -t w_82OMhVzJnXMTItS43qdbAwWyvrguzgRAiSQqDuqmb9WohKS3dKqrez-tInxG17EE64gBAC7oihtfkeKcfJBw== "/opt/iobroker/backups/influxDB_2023_11_20-10_53_21_backupiobroker" 2023/11/20 10:56:29 INFO: Downloading metadata snapshot Error: failed to backup metadata: failed to download metadata snapshot: 401 Unauthorized: read:authorizations is unauthorized
@laser Zeige mal die Config deines Influx Adapters?
Was ist dort für Token hinterlegt? -
der eingetragene Token ist der Mit "strg&C" kopierte, neu erstellte Token. Den habe ich auch wieder in einer Textdatei gesichert. Für alle Fälle.
Habe ich mir auch anzeigen lassen. War identisch. -
neu erstellte Token
Da der Link zum Neuerstellen des Operator-Tokens ins Nirwana zeigt, frage ich mich gerade, wie du den Token erstellt hast. Was sagt denn:
influx auth list -t w_82OMhVzJnXMTItS43qdbAwWyvrguzgRAiSQqDuqmb9WohKS3dKqrez-tInxG17EE64gBAC7oihtfkeKcfJBw== --json
@laser Nein nicht die Config von Backitup... Bitte zeige den Influx Adapter
@marc-berg sagte in Kein iobroker Backup mehr über BackitUp Adapter:
Den Token habe ich so erstellt: was mache ich mit den "alten" Token?
otto@raspberrypi:/opt $ influx auth list -t w_82OMhVzJnXMTItS43qdbAwWyvrguzgRAiSQqDuqmb9WohKS3dKqrez-tInxG17EE64gBAC7oihtfkeKcfJBw== --json [ { "id": "0b4721ccc9305000", "description": "iobroker's Token", "token": "9RpnKWzJ2Vuq-Jg85pOljmMaF1PJP0YhAfXZcLYO7QRNUQtKUaV0ezcQeIpnmTR2K1Ve0YWl11lqKTsX2DvQvw==", "status": "active", "userName": "iobroker", "userID": "0b4721cca3305000", "permissions": [ "read:/authorizations", "write:/authorizations", "read:/buckets", "write:/buckets", "read:/dashboards", "write:/dashboards", "read:/orgs", "write:/orgs", "read:/sources", "write:/sources", "read:/tasks", "write:/tasks", "read:/telegrafs", "write:/telegrafs", "read:/users", "write:/users", "read:/variables", "write:/variables", "read:/scrapers", "write:/scrapers", "read:/secrets", "write:/secrets", "read:/labels", "write:/labels", "read:/views", "write:/views", "read:/documents", "write:/documents", "read:/notificationRules", "write:/notificationRules", "read:/notificationEndpoints", "write:/notificationEndpoints", "read:/checks", "write:/checks", "read:/dbrp", "write:/dbrp", "read:/notebooks", "write:/notebooks", "read:/annotations", "write:/annotations", "read:/remotes", "write:/remotes", "read:/replications", "write:/replications" ] }, { "id": "0b485bd1c75e4000", "description": "onboarding-cliWizard-token-1685530468858", "token": "zijB7piBzzSSLchg2TCyrp2MViRxSJ5_HQP_ynLZO_T8K6Wy-guPxh9uI75KjCKFKIhzTGhpSSeyMpp58Z_juw==", "status": "active", "userName": "iobroker", "userID": "0b4721cca3305000", "permissions": [ "read:orgs/56ed5fe7a100c804/annotations", "write:orgs/56ed5fe7a100c804/annotations", "read:orgs/56ed5fe7a100c804/authorizations", "write:orgs/56ed5fe7a100c804/authorizations", "read:orgs/56ed5fe7a100c804/buckets", "write:orgs/56ed5fe7a100c804/buckets", "read:orgs/56ed5fe7a100c804/checks", "write:orgs/56ed5fe7a100c804/checks", "read:orgs/56ed5fe7a100c804/dashboards", "write:orgs/56ed5fe7a100c804/dashboards", "read:orgs/56ed5fe7a100c804/dbrp", "write:orgs/56ed5fe7a100c804/dbrp", "read:orgs/56ed5fe7a100c804/documents", "write:orgs/56ed5fe7a100c804/documents", "read:orgs/56ed5fe7a100c804/labels", "write:orgs/56ed5fe7a100c804/labels", "read:orgs/56ed5fe7a100c804/notebooks", "write:orgs/56ed5fe7a100c804/notebooks", "read:orgs/56ed5fe7a100c804/notificationEndpoints", "write:orgs/56ed5fe7a100c804/notificationEndpoints", "read:orgs/56ed5fe7a100c804/notificationRules", "write:orgs/56ed5fe7a100c804/notificationRules", "read:/orgs/56ed5fe7a100c804", "read:orgs/56ed5fe7a100c804/remotes", "write:orgs/56ed5fe7a100c804/remotes", "read:orgs/56ed5fe7a100c804/replications", "write:orgs/56ed5fe7a100c804/replications", "read:orgs/56ed5fe7a100c804/scrapers", "write:orgs/56ed5fe7a100c804/scrapers", "read:orgs/56ed5fe7a100c804/secrets", "write:orgs/56ed5fe7a100c804/secrets", "read:orgs/56ed5fe7a100c804/sources", "write:orgs/56ed5fe7a100c804/sources", "read:orgs/56ed5fe7a100c804/tasks", "write:orgs/56ed5fe7a100c804/tasks", "read:orgs/56ed5fe7a100c804/telegrafs", "write:orgs/56ed5fe7a100c804/telegrafs", "read:/users/0b4721cca3305000", "write:/users/0b4721cca3305000", "read:orgs/56ed5fe7a100c804/variables", "write:orgs/56ed5fe7a100c804/variables", "read:orgs/56ed5fe7a100c804/views", "write:orgs/56ed5fe7a100c804/views" ] }, { "id": "0b4862a339de4000", "description": "iobroker", "token": "fPGvK9QsLi2jJWNN_q5ccAyETlJ9plh-1qxfgsxuOEPymu9SCsQVHI3j47j44UbAUfqMpv8_in5zeFDC8D2Q0Q==", "status": "active", "userName": "iobroker", "userID": "0b4721cca3305000", "permissions": [ "read:orgs/56ed5fe7a100c804/annotations", "write:orgs/56ed5fe7a100c804/annotations", "read:orgs/56ed5fe7a100c804/authorizations", "write:orgs/56ed5fe7a100c804/authorizations", "read:orgs/56ed5fe7a100c804/buckets", "write:orgs/56ed5fe7a100c804/buckets", "read:orgs/56ed5fe7a100c804/checks", "write:orgs/56ed5fe7a100c804/checks", "read:orgs/56ed5fe7a100c804/dashboards", "write:orgs/56ed5fe7a100c804/dashboards", "read:orgs/56ed5fe7a100c804/dbrp", "write:orgs/56ed5fe7a100c804/dbrp", "read:orgs/56ed5fe7a100c804/documents", "write:orgs/56ed5fe7a100c804/documents", "read:orgs/56ed5fe7a100c804/labels", "write:orgs/56ed5fe7a100c804/labels", "read:orgs/56ed5fe7a100c804/notebooks", "write:orgs/56ed5fe7a100c804/notebooks", "read:orgs/56ed5fe7a100c804/notificationEndpoints", "write:orgs/56ed5fe7a100c804/notificationEndpoints", "read:orgs/56ed5fe7a100c804/notificationRules", "write:orgs/56ed5fe7a100c804/notificationRules", "read:/orgs/56ed5fe7a100c804", "read:orgs/56ed5fe7a100c804/remotes", "write:orgs/56ed5fe7a100c804/remotes", "read:orgs/56ed5fe7a100c804/replications", "write:orgs/56ed5fe7a100c804/replications", "read:orgs/56ed5fe7a100c804/scrapers", "write:orgs/56ed5fe7a100c804/scrapers", "read:orgs/56ed5fe7a100c804/secrets", "write:orgs/56ed5fe7a100c804/secrets", "read:orgs/56ed5fe7a100c804/sources", "write:orgs/56ed5fe7a100c804/sources", "read:orgs/56ed5fe7a100c804/tasks", "write:orgs/56ed5fe7a100c804/tasks", "read:orgs/56ed5fe7a100c804/telegrafs", "write:orgs/56ed5fe7a100c804/telegrafs", "read:/users/0b4721cca3305000", "write:/users/0b4721cca3305000", "read:orgs/56ed5fe7a100c804/variables", "write:orgs/56ed5fe7a100c804/variables", "read:orgs/56ed5fe7a100c804/views", "write:orgs/56ed5fe7a100c804/views" ] }, { "id": "0c26fdf572986000", "description": "onboarding-cliWizard-token-1700471139713", "token": "oodzlogKQY9O0tCtNNDYiFxomFcAWJXjd-RTbC738Fkna1nzQiVXRjNVaKZDFt_lvWEYrZWhpUNIxsnMISQejg==", "status": "active", "userName": "iobroker", "userID": "0b4721cca3305000", "permissions": [ "read:orgs/56ed5fe7a100c804/annotations", "write:orgs/56ed5fe7a100c804/annotations", "read:orgs/56ed5fe7a100c804/authorizations", "write:orgs/56ed5fe7a100c804/authorizations", "read:orgs/56ed5fe7a100c804/buckets", "write:orgs/56ed5fe7a100c804/buckets", "read:orgs/56ed5fe7a100c804/checks", "write:orgs/56ed5fe7a100c804/checks", "read:orgs/56ed5fe7a100c804/dashboards", "write:orgs/56ed5fe7a100c804/dashboards", "read:orgs/56ed5fe7a100c804/dbrp", "write:orgs/56ed5fe7a100c804/dbrp", "read:orgs/56ed5fe7a100c804/documents", "write:orgs/56ed5fe7a100c804/documents", "read:orgs/56ed5fe7a100c804/labels", "write:orgs/56ed5fe7a100c804/labels", "read:orgs/56ed5fe7a100c804/notebooks", "write:orgs/56ed5fe7a100c804/notebooks", "read:orgs/56ed5fe7a100c804/notificationEndpoints", "write:orgs/56ed5fe7a100c804/notificationEndpoints", "read:orgs/56ed5fe7a100c804/notificationRules", "write:orgs/56ed5fe7a100c804/notificationRules", "read:/orgs/56ed5fe7a100c804", "read:orgs/56ed5fe7a100c804/remotes", "write:orgs/56ed5fe7a100c804/remotes", "read:orgs/56ed5fe7a100c804/replications", "write:orgs/56ed5fe7a100c804/replications", "read:orgs/56ed5fe7a100c804/scrapers", "write:orgs/56ed5fe7a100c804/scrapers", "read:orgs/56ed5fe7a100c804/secrets", "write:orgs/56ed5fe7a100c804/secrets", "read:orgs/56ed5fe7a100c804/sources", "write:orgs/56ed5fe7a100c804/sources", "read:orgs/56ed5fe7a100c804/tasks", "write:orgs/56ed5fe7a100c804/tasks", "read:orgs/56ed5fe7a100c804/telegrafs", "write:orgs/56ed5fe7a100c804/telegrafs", "read:/users/0b4721cca3305000", "write:/users/0b4721cca3305000", "read:orgs/56ed5fe7a100c804/variables", "write:orgs/56ed5fe7a100c804/variables", "read:orgs/56ed5fe7a100c804/views", "write:orgs/56ed5fe7a100c804/views" ] }, { "id": "0c2706d518d86000", "description": "Neuer Token", "token": "w_82OMhVzJnXMTItS43qdbAwWyvrguzgRAiSQqDuqmb9WohKS3dKqrez-tInxG17EE64gBAC7oihtfkeKcfJBw==", "status": "active", "userName": "iobroker", "userID": "0b4721cca3305000", "permissions": [ "read:orgs/56ed5fe7a100c804/annotations", "write:orgs/56ed5fe7a100c804/annotations", "read:orgs/56ed5fe7a100c804/authorizations", "write:orgs/56ed5fe7a100c804/authorizations", "read:orgs/56ed5fe7a100c804/buckets", "write:orgs/56ed5fe7a100c804/buckets", "read:orgs/56ed5fe7a100c804/checks", "write:orgs/56ed5fe7a100c804/checks", "read:orgs/56ed5fe7a100c804/dashboards", "write:orgs/56ed5fe7a100c804/dashboards", "read:orgs/56ed5fe7a100c804/dbrp", "write:orgs/56ed5fe7a100c804/dbrp", "read:orgs/56ed5fe7a100c804/documents", "write:orgs/56ed5fe7a100c804/documents", "read:orgs/56ed5fe7a100c804/labels", "write:orgs/56ed5fe7a100c804/labels", "read:orgs/56ed5fe7a100c804/notebooks", "write:orgs/56ed5fe7a100c804/notebooks", "read:orgs/56ed5fe7a100c804/notificationEndpoints", "write:orgs/56ed5fe7a100c804/notificationEndpoints", "read:orgs/56ed5fe7a100c804/notificationRules", "write:orgs/56ed5fe7a100c804/notificationRules", "read:/orgs/56ed5fe7a100c804", "read:orgs/56ed5fe7a100c804/remotes", "write:orgs/56ed5fe7a100c804/remotes", "read:orgs/56ed5fe7a100c804/replications", "write:orgs/56ed5fe7a100c804/replications", "read:orgs/56ed5fe7a100c804/scrapers", "write:orgs/56ed5fe7a100c804/scrapers", "read:orgs/56ed5fe7a100c804/secrets", "write:orgs/56ed5fe7a100c804/secrets", "read:orgs/56ed5fe7a100c804/sources", "write:orgs/56ed5fe7a100c804/sources", "read:orgs/56ed5fe7a100c804/tasks", "write:orgs/56ed5fe7a100c804/tasks", "read:orgs/56ed5fe7a100c804/telegrafs", "write:orgs/56ed5fe7a100c804/telegrafs", "read:/users/0b4721cca3305000", "write:/users/0b4721cca3305000", "read:orgs/56ed5fe7a100c804/variables", "write:orgs/56ed5fe7a100c804/variables", "read:orgs/56ed5fe7a100c804/views", "write:orgs/56ed5fe7a100c804/views" ] } ]
dann ist das hier dein Operator - Token:
@simantec Muß da auch der neu generierte Token rein? Vermutlich ja)
Ich möchte ungern die Datenbank unbrauchbar machen.
Ich starte den Pi gerade neu...
EDIT: wieder das gleiche Verhalten. Kann ich bei der Token- Generierung etwas falsch machen? Was tue ich mit den ganzen "alten" Token's? -
Hast du denn jetzt den Token
in Backitup eingetragen???
@marc-berg Ich habe die Token in Backitup und in influx eingetragen.
Gerade noch einen neuen Token erstellt. Muß der eine bestimmte Bezeichnung erhalten oder ist das nur ein Mektext?
Wieder das Gleiche beim Backup:Started iobroker ... [DEBUG] [mount] - noserverino option: false [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=iobroker,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=2.0 //192.168.2.57/backup /opt/iobroker/backups" [DEBUG] [mount] - mount successfully completed [DEBUG] [mount] - done [DEBUG] [iobroker] - host.raspberrypi 3166 states saved [DEBUG] [iobroker] - host.raspberrypi 3839 objects saved [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2023_11_20-11_34_13_backupiobroker.tar.gz [DEBUG] [iobroker] - This backup can only be restored with js-controller version up from 4.1 [DEBUG] [iobroker] - done [DEBUG] [influxDB] - InfluxDB-Backup started ... [DEBUG] [influxDB] - Start InfluxDB Backup ... [DEBUG] [influxDB] - InfluxDB Backup tmp directory created [DEBUG] [influxDB] - Try deleting the InfluxDB tmp directory: "/opt/iobroker/backups/influxDB_2023_11_20-11_34_26_backupiobroker" [DEBUG] [influxDB] - InfluxDB tmp directory "/opt/iobroker/backups/influxDB_2023_11_20-11_34_26_backupiobroker" successfully deleted [DEBUG] [influxDB] - [ERROR] [influxDB] - Error: Command failed: influx backup --bucket iobroker -t kENxxP6hxicSqtd1R1akRkvk1QF8F9xqW0fmydbvHhCoy5KpRIjFam_H-NxW6u4aKxwaXia4i-1CSqr70HH8kg== "/opt/iobroker/backups/influxDB_2023_11_20-11_34_26_backupiobroker" 2023/11/20 11:34:26 INFO: Downloading metadata snapshot Error: failed to backup metadata: failed to download metadata snapshot: 401 Unauthorized: read:authorizations is unauthorized [DEBUG] [influxDB] - InfluxDB-Backup for is finish [DEBUG] [influxDB] - done [DEBUG] [cifs] - used copy path: /backup [DEBUG] [cifs] - done [ERROR] [clean] - Backup files not deleted from /opt/iobroker/backups because some errors. [DEBUG] [clean] - done [DEBUG] [telegram] - done [DEBUG] [historyHTML] - new history html values created [DEBUG] [historyHTML] - done [DEBUG] [historyJSON] - new history json values created [DEBUG] [historyJSON] - done [DEBUG] [umount] - mount activ, umount is started ... [DEBUG] [umount] - umount successfully completed [DEBUG] [umount] - done [EXIT] 0
Welche?
Bezeichnung ist egal.
Jetzt heißt der neu generierte Token- in influx und Backitup eingetragen:
Das ist doch aber der Falsche. Du muss den Operator Token (siehe oben) eintragen.
