    4. keine Geräte im Zigbee Adapter [gelöst - Vielen Dank]
      wolkenloser @Thomas Braun last edited by
      Mehr als 1000 Zeilen, muss ich splitten
      Skript v.2023-10-10
      *** BASE SYSTEM ***
         Static hostname: iobroker
               Icon name: computer-vm
                 Chassis: vm
          Virtualization: microsoft
        Operating System: Ubuntu 20.04.6 LTS
                  Kernel: Linux 5.4.0-166-generic
            Architecture: x86-64
      model name      : Intel(R) Celeron(R) CPU J3455 @ 1.50GHz
      Docker          : false
      Virtualization  : microsoft
      Kernel          : x86_64
      Userland        : amd64
      Systemuptime and Load:
       12:00:09 up 25 min,  1 user,  load average: 0.44, 0.64, 1.09
      CPU threads: 2
      *** Time and Time Zones ***
                     Local time: Mon 2023-11-20 12:00:10 CET
                 Universal time: Mon 2023-11-20 11:00:10 UTC
                       RTC time: Mon 2023-11-20 11:00:11
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      iobroker
      /home/iobroker
      iobroker adm tty dialout cdrom sudo audio dip video plugdev lxd
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:           3.9G        2.7G        119M        1.0M        1.1G        1.1G
      Swap:          2.0G        3.0M        2.0G
      Total:         5.9G        2.7G        2.1G
               3919 M total memory
               2689 M used memory
               2743 M active memory
                726 M inactive memory
                119 M free memory
                145 M buffer memory
                965 M swap cache
               1969 M total swap
                  3 M used swap
               1966 M free swap
      *** FAILED SERVICES ***
        UNIT           LOAD   ACTIVE SUB    DESCRIPTION
      * fstrim.service loaded failed failed Discard unused blocks on filesystems from /etc/fstab
      LOAD   = Reflects whether the unit definition was properly loaded.
      ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
      SUB    = The low-level unit activation state, values depend on unit type.
      1 loaded units listed.
      *** FILESYSTEM ***
      udev           devtmpfs  1.9G     0  1.9G   0% /dev
      tmpfs          tmpfs     392M  1.1M  391M   1% /run
      /dev/sda2      ext4       50G   34G   13G  73% /
      tmpfs          tmpfs     2.0G     0  2.0G   0% /dev/shm
      tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
      tmpfs          tmpfs     2.0G     0  2.0G   0% /sys/fs/cgroup
      /dev/loop0     squashfs  106M  106M     0 100% /snap/core/16091
      /dev/loop1     squashfs  106M  106M     0 100% /snap/core/16202
      /dev/loop3     squashfs   56M   56M     0 100% /snap/core18/2796
      /dev/loop2     squashfs   56M   56M     0 100% /snap/core18/2790
      /dev/loop5     squashfs   64M   64M     0 100% /snap/core20/2015
      /dev/loop6     squashfs   92M   92M     0 100% /snap/lxd/23991
      /dev/loop7     squashfs   92M   92M     0 100% /snap/lxd/24061
      /dev/loop8     squashfs  128K  128K     0 100% /snap/ncdu/62
      /dev/loop4     squashfs   64M   64M     0 100% /snap/core20/1974
      /dev/loop10    squashfs  4.3M  4.3M     0 100% /snap/tree/18
      /dev/loop9     squashfs  128K  128K     0 100% /snap/ncdu/64
      tmpfs          tmpfs     392M     0  392M   0% /run/user/1000
      [sudo] password for iobroker:
      [Mon Nov 20 11:34:45 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
      [Mon Nov 20 11:35:02 2023] EXT4-fs (sda2): re-mounted. Opts: (null)
      TARGET                SOURCE      FSTYPE   OPTIONS
      /                     /dev/sda2   ext4     rw,relatime
      |-/sys/kernel/tracing tracefs     tracefs  rw,nosuid,nodev,noexec,relatime
      |-/snap/core/16091    /dev/loop0  squashfs ro,nodev,relatime
      |-/snap/core/16202    /dev/loop1  squashfs ro,nodev,relatime
      |-/snap/core18/2796   /dev/loop3  squashfs ro,nodev,relatime
      |-/snap/core18/2790   /dev/loop2  squashfs ro,nodev,relatime
      |-/snap/core20/2015   /dev/loop5  squashfs ro,nodev,relatime
      |-/snap/lxd/23991     /dev/loop6  squashfs ro,nodev,relatime
      |-/snap/lxd/24061     /dev/loop7  squashfs ro,nodev,relatime
      |-/snap/ncdu/62       /dev/loop8  squashfs ro,nodev,relatime
      |-/snap/core20/1974   /dev/loop4  squashfs ro,nodev,relatime
      |-/snap/tree/18       /dev/loop10 squashfs ro,nodev,relatime
      `-/snap/ncdu/64       /dev/loop9  squashfs ro,nodev,relatime
      /var:
      5.6G    /var/
      4.1G    /var/log
      4.0G    /var/log/journal/4c4f1c196fd742fb8ea78816d6e03b15
      1.5G    /var/lib
      Archived and active journals take up 3.9G in the file system.
      /opt/iobroker/backups:
      12M     /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      17G     /opt/iobroker/iobroker-data/
      16G     /opt/iobroker/iobroker-data/history
      650M    /opt/iobroker/iobroker-data/files
      170M    /opt/iobroker/iobroker-data/files/javascript.admin
      158M    /opt/iobroker/iobroker-data/backup-objects
      39M     /opt/iobroker/iobroker-data/objects.jsonl
      12M     /opt/iobroker/iobroker-data/states.jsonl
      12M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js/12.1aeaa68b.chunk.js.map
      9.8M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/2.f6fd0e72.chunk.js.map
      9.7M    /opt/iobroker/iobroker-data/objects.json.migrated
      USB-Devices by-id:
      /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.17.1
      /home/iobroker/.nvm/versions/node/v18.9.0/bin/node              v18.9.0
      /home/iobroker/.nvm/versions/node/v18.9.0/bin/npm               8.19.1
      /home/iobroker/.nvm/versions/node/v18.9.0/bin/npx               8.19.1
      /home/iobroker/.nvm/versions/node/v18.9.0/bin/corepack  0.14.0
      *** nodejs is NOT correctly installed ***
      nodejs:
        Installed: 18.17.1-deb-1nodesource1
        Candidate: 18.17.1-deb-1nodesource1
        Version table:
       *** 18.17.1-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_18.x focal/main amd64 Packages
              100 /var/lib/dpkg/status
           10.19.0~dfsg-3ubuntu1.2 500
              500 http://de.archive.ubuntu.com/ubuntu focal-updates/universe amd64 Packages
              500 http://de.archive.ubuntu.com/ubuntu focal-security/universe amd64 Packages
           10.19.0~dfsg-3ubuntu1 500
              500 http://de.archive.ubuntu.com/ubuntu focal/universe amd64 Packages
      No problems detected
        wolkenloser @wolkenloser last edited by
        Dann ganz viele hiervon, und das ist nur die Hälfte
        Errors in npm tree:
        npm ERR! code ELSPROBLEMS
        npm ERR! extraneous: @types/caseless@0.12.4 /opt/iobroker/node_modules/@types/caseless
        npm ERR! extraneous: @types/request@2.48.11 /opt/iobroker/node_modules/@types/request
        npm ERR! extraneous: @types/tough-cookie@4.0.4 /opt/iobroker/node_modules/@types/tough-cookie
        npm ERR! extraneous: coffeescript@1.12.7 /opt/iobroker/node_modules/coffeescript
        npm ERR! invalid: iobroker.energiefluss@3.6.0 /opt/iobroker/node_modules/iobroker.energiefluss
        npm ERR! invalid: iobroker.fronius@2.0.2 /opt/iobroker/node_modules/iobroker.fronius
        npm ERR! invalid: iobroker.labcom@0.1.1 /opt/iobroker/node_modules/iobroker.labcom
        npm ERR! extraneous: jsonata@2.0.3 /opt/iobroker/node_modules/jsonata
        npm ERR! extraneous: node-inspect@2.0.0 /opt/iobroker/node_modules/node-inspect
        npm ERR! extraneous: suncalc2@1.8.1 /opt/iobroker/node_modules/suncalc2
        npm ERR! extraneous: typescript@4.7.4 /opt/iobroker/node_modules/typescript
        npm ERR! extraneous: virtual-tsc@0.6.2 /opt/iobroker/node_modules/virtual-tsc
        npm ERR! extraneous: wake_on_lan@1.0.0 /opt/iobroker/node_modules/wake_on_lan
        npm ERR! extraneous: form-data@2.5.1 /opt/iobroker/node_modules/@types/request/node_modules/form-data
        npm ERR! extraneous: @aashutoshrathi/word-wrap@1.2.6 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@aashutoshrathi/word-wrap
        npm ERR! extraneous: @alcalzone/pak@0.8.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/pak
        npm ERR! extraneous: @alcalzone/release-script-core@3.5.9 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script-core
        npm ERR! extraneous: @alcalzone/release-script-plugin-changelog@3.5.9 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script-plugin-changelog
        npm ERR! extraneous: @alcalzone/release-script-plugin-exec@3.5.9 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script-plugin-exec
        npm ERR! extraneous: @alcalzone/release-script-plugin-git@3.6.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script-plugin-git
        npm ERR! extraneous: @alcalzone/release-script-plugin-iobroker@3.6.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script-plugin-iobroker
        npm ERR! extraneous: @alcalzone/release-script-plugin-license@3.5.9 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script-plugin-license
        npm ERR! extraneous: @alcalzone/release-script-plugin-package@3.6.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script-plugin-package
        npm ERR! extraneous: @alcalzone/release-script-plugin-version@3.6.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script-plugin-version
        npm ERR! extraneous: @alcalzone/release-script@3.6.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script
        npm ERR! extraneous: @eslint-community/eslint-utils@4.4.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@eslint-community/eslint-utils
        npm ERR! extraneous: @eslint-community/regexpp@4.10.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@eslint-community/regexpp
        npm ERR! extraneous: @eslint/eslintrc@2.1.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@eslint/eslintrcnpm ERR! extraneous: @eslint/js@8.53.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@eslint/js
        npm ERR! extraneous: @humanwhocodes/config-array@0.11.13 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@humanwhocodes/config-array
        npm ERR! extraneous: @humanwhocodes/module-importer@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@humanwhocodes/module-importer
        npm ERR! extraneous: @humanwhocodes/object-schema@2.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@humanwhocodes/object-schema
        npm ERR! extraneous: @iobroker/dev-server@0.6.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@iobroker/dev-server
        npm ERR! extraneous: @iobroker/testing@4.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@iobroker/testing
        npm ERR! extraneous: @nodelib/fs.scandir@2.1.5 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@nodelib/fs.scandir
        npm ERR! extraneous: @nodelib/fs.stat@2.0.5 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@nodelib/fs.statnpm ERR! extraneous: @nodelib/fs.walk@1.2.8 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@nodelib/fs.walknpm ERR! extraneous: @sinonjs/commons@2.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@sinonjs/commonsnpm ERR! extraneous: @sinonjs/fake-timers@9.1.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@sinonjs/fake-timers
        npm ERR! extraneous: @sinonjs/samsam@7.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@sinonjs/samsam
        npm ERR! extraneous: @sinonjs/text-encoding@0.7.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@sinonjs/text-encoding
        npm ERR! extraneous: @socket.io/component-emitter@3.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@socket.io/component-emitter
        npm ERR! extraneous: @types/cookie@0.4.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/cookie
        npm ERR! extraneous: @types/cors@2.8.15 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/cors
        npm ERR! extraneous: @types/expect@1.20.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/expect
        npm ERR! extraneous: @types/http-proxy@1.17.13 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/http-proxy
        npm ERR! extraneous: @types/vinyl@2.0.9 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/vinyl
        npm ERR! extraneous: @ungap/structured-clone@1.2.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@ungap/structured-clone
        npm ERR! extraneous: abbrev@1.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/abbrev
        npm ERR! extraneous: accepts@1.3.8 /opt/iobroker/node_modules/iobroker.javascript/node_modules/accepts
        npm ERR! extraneous: acorn-globals@1.0.9 /opt/iobroker/node_modules/iobroker.javascript/node_modules/acorn-globals
        npm ERR! extraneous: acorn-jsx@5.3.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/acorn-jsx
        npm ERR! extraneous: acorn@8.11.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/acorn
        npm ERR! extraneous: alcalzone-shared@4.0.8 /opt/iobroker/node_modules/iobroker.javascript/node_modules/alcalzone-sharednpm ERR! extraneous: ansi-align@3.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/ansi-align
        npm ERR! extraneous: ansi-colors@4.1.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/ansi-colors
        npm ERR! extraneous: ansi-gray@0.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/ansi-gray
        npm ERR! extraneous: ansi-regex@5.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/ansi-regex
        npm ERR! extraneous: ansi-styles@4.3.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/ansi-styles
        npm ERR! extraneous: ansi-wrap@0.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/ansi-wrap
        npm ERR! extraneous: anymatch@3.1.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/anymatch
        npm ERR! extraneous: append-buffer@1.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/append-buffer
        npm ERR! extraneous: archy@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/archy
        npm ERR! extraneous: argparse@2.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/argparse
        npm ERR! extraneous: arr-diff@4.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/arr-diff
        npm ERR! extraneous: arr-filter@1.1.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/arr-filter
        npm ERR! extraneous: arr-flatten@1.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/arr-flatten
        npm ERR! extraneous: arr-map@2.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/arr-map
        npm ERR! extraneous: arr-union@3.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/arr-union
        npm ERR! extraneous: array-each@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/array-each
        npm ERR! extraneous: array-flatten@1.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/array-flatten
        npm ERR! extraneous: array-initial@1.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/array-initial
        npm ERR! extraneous: array-last@1.3.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/array-last
        npm ERR! extraneous: array-slice@1.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/array-slice
        npm ERR! extraneous: array-sort@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/array-sort
        npm ERR! extraneous: array-unique@0.3.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/array-unique
        npm ERR! extraneous: assertion-error@1.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/assertion-error
        npm ERR! extraneous: assign-symbols@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/assign-symbols
        npm ERR! extraneous: astral-regex@2.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/astral-regex
        npm ERR! extraneous: async-done@1.3.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/async-done
        npm ERR! extraneous: async-each-series@0.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/async-each-series
        npm ERR! extraneous: async-each@1.0.6 /opt/iobroker/node_modules/iobroker.javascript/node_modules/async-each
        npm ERR! extraneous: async-settle@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/async-settle
        npm ERR! extraneous: async@2.6.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/async
        npm ERR! extraneous: atob@2.1.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/atob
        npm ERR! extraneous: bach@1.2.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/bach
        npm ERR! extraneous: balanced-match@1.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/balanced-match
        npm ERR! extraneous: base@0.11.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/base
        npm ERR! extraneous: base64id@2.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/base64id
        npm ERR! extraneous: batch@0.6.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/batch
        npm ERR! extraneous: binary-extensions@2.2.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/binary-extensions
        npm ERR! extraneous: binaryextensions@2.3.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/binaryextensionsnpm ERR! extraneous: body-parser@1.20.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/body-parser
        npm ERR! extraneous: boxen@5.1.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/boxen
        npm ERR! extraneous: brace-expansion@1.1.11 /opt/iobroker/node_modules/iobroker.javascript/node_modules/brace-expansion
        npm ERR! extraneous: braces@3.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/braces
        npm ERR! extraneous: browser-request@0.3.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/browser-request
        npm ERR! extraneous: browser-stdout@1.3.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/browser-stdout
        npm ERR! extraneous: browser-sync-client@2.29.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/browser-sync-client
        npm ERR! extraneous: browser-sync-ui@2.29.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/browser-sync-ui
        npm ERR! extraneous: browser-sync@2.29.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/browser-sync
        npm ERR! extraneous: bs-html-injector@3.0.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/bs-html-injectornpm ERR! extraneous: bs-recipes@1.3.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/bs-recipes
        npm ERR! extraneous: buffer-equal@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/buffer-equal
        npm ERR! extraneous: buffer-from@1.1.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/buffer-from
        npm ERR! extraneous: bytes@3.1.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/bytes
        npm ERR! extraneous: cache-base@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/cache-base
        npm ERR! extraneous: call-bind@1.0.5 /opt/iobroker/node_modules/iobroker.javascript/node_modules/call-bind
        npm ERR! extraneous: callsites@3.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/callsites
        npm ERR! extraneous: camelcase@6.3.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/camelcase
        npm ERR! extraneous: chai-as-promised@7.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/chai-as-promisednpm ERR! extraneous: chai@4.3.10 /opt/iobroker/node_modules/iobroker.javascript/node_modules/chai
        npm ERR! extraneous: chalk@4.1.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/chalk
        npm ERR! extraneous: check-error@1.0.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/check-error
        npm ERR! extraneous: chokidar@3.5.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/chokidar
        npm ERR! extraneous: class-utils@0.3.6 /opt/iobroker/node_modules/iobroker.javascript/node_modules/class-utils
        npm ERR! extraneous: cli-boxes@2.2.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/cli-boxes
        npm ERR! extraneous: cliui@8.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/cliui
        npm ERR! extraneous: clone-buffer@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/clone-buffer
        npm ERR! extraneous: clone-stats@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/clone-stats
        npm ERR! extraneous: clone@2.1.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/clone
        npm ERR! extraneous: cloneable-readable@1.1.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/cloneable-readable
        npm ERR! extraneous: code-point-at@1.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/code-point-at
        npm ERR! extraneous: collection-map@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/collection-map
        npm ERR! extraneous: collection-visit@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/collection-visitnpm ERR! extraneous: color-convert@2.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/color-convert
        npm ERR! extraneous: color-name@1.1.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/color-name
        npm ERR! extraneous: color-support@1.1.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/color-support
        npm ERR! extraneous: colors@1.4.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/colors
        npm ERR! extraneous: commander@2.20.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/commander
        npm ERR! extraneous: component-emitter@1.3.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/component-emitter
        npm ERR! extraneous: concat-map@0.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/concat-map
        npm ERR! extraneous: concat-stream@1.6.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/concat-stream
        npm ERR! extraneous: connect-history-api-fallback@1.6.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/connect-history-api-fallback
        npm ERR! extraneous: connect@3.6.6 /opt/iobroker/node_modules/iobroker.javascript/node_modules/connect
        npm ERR! extraneous: content-disposition@0.5.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/content-disposition
        npm ERR! extraneous: content-type@1.0.5 /opt/iobroker/node_modules/iobroker.javascript/node_modules/content-type
        npm ERR! extraneous: convert-source-map@1.9.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/convert-source-map
        npm ERR! extraneous: cookie-signature@1.0.6 /opt/iobroker/node_modules/iobroker.javascript/node_modules/cookie-signaturenpm ERR! extraneous: cookie@0.5.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/cookie
        npm ERR! extraneous: copy-descriptor@0.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/copy-descriptor
        npm ERR! extraneous: copy-props@2.0.5 /opt/iobroker/node_modules/iobroker.javascript/node_modules/copy-props
        npm ERR! extraneous: cors@2.8.5 /opt/iobroker/node_modules/iobroker.javascript/node_modules/cors
        npm ERR! extraneous: cross-spawn@7.0.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/cross-spawn
        npm ERR! extraneous: cssom@0.3.8 /opt/iobroker/node_modules/iobroker.javascript/node_modules/cssom
        npm ERR! extraneous: cssstyle@0.2.37 /opt/iobroker/node_modules/iobroker.javascript/node_modules/cssstyle
        npm ERR! extraneous: d@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/d
        npm ERR! extraneous: decamelize@4.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/decamelize
        npm ERR! extraneous: decode-uri-component@0.2.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/decode-uri-component
        npm ERR! extraneous: deep-eql@4.1.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/deep-eql
        npm ERR! extraneous: deep-is@0.1.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/deep-is
        npm ERR! extraneous: default-compare@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/default-compare
        npm ERR! extraneous: default-resolution@2.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/default-resolution
        npm ERR! extraneous: define-data-property@1.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/define-data-property
        npm ERR! extraneous: define-properties@1.2.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/define-properties
        npm ERR! extraneous: define-property@2.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/define-property
        npm ERR! extraneous: depd@2.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/depd
        npm ERR! extraneous: destroy@1.2.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/destroy
        npm ERR! extraneous: detect-file@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/detect-file
        npm ERR! extraneous: dev-ip@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/dev-ip
        npm ERR! extraneous: diff@5.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/diff
        npm ERR! extraneous: doctrine@3.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/doctrine
        npm ERR! extraneous: dom-compare-temp@0.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/dom-compare-tempnpm ERR! extraneous: dom-serializer@0.2.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/dom-serializer
        npm ERR! extraneous: domelementtype@1.3.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/domelementtype
        npm ERR! extraneous: domhandler@2.4.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/domhandler
        npm ERR! extraneous: domutils@1.7.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/domutils
        npm ERR! extraneous: duplexer@0.1.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/duplexer
        npm ERR! extraneous: duplexify@3.7.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/duplexify
        npm ERR! extraneous: each-props@1.3.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/each-props
        npm ERR! extraneous: easy-extender@2.3.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/easy-extender
        npm ERR! extraneous: eazy-logger@4.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/eazy-logger
        npm ERR! extraneous: ee-first@1.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/ee-first
        npm ERR! extraneous: emoji-regex@8.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/emoji-regex
        npm ERR! extraneous: encodeurl@1.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/encodeurl
        npm ERR! extraneous: end-of-stream@1.4.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/end-of-stream
        npm ERR! extraneous: engine.io-client@6.5.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/engine.io-clientnpm ERR! extraneous: engine.io-parser@5.2.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/engine.io-parsernpm ERR! extraneous: engine.io@6.5.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/engine.io
        npm ERR! extraneous: enquirer@2.4.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/enquirer
        npm ERR! extraneous: entities@1.1.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/entities
        npm ERR! extraneous: error-ex@1.3.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/error-ex
        npm ERR! extraneous: es5-ext@0.10.62 /opt/iobroker/node_modules/iobroker.javascript/node_modules/es5-ext
        npm ERR! extraneous: es6-iterator@2.0.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/es6-iterator
        npm ERR! extraneous: es6-symbol@3.1.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/es6-symbol
        npm ERR! extraneous: es6-weak-map@2.0.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/es6-weak-map
        npm ERR! extraneous: escalade@3.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/escalade
        npm ERR! extraneous: escape-html@1.0.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/escape-html
        npm ERR! extraneous: escape-string-regexp@4.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/escape-string-regexp
        npm ERR! extraneous: escodegen@1.14.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/escodegen
        npm ERR! extraneous: eslint-scope@7.2.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/eslint-scope
        npm ERR! extraneous: eslint-visitor-keys@3.4.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/eslint-visitor-keys
        npm ERR! extraneous: eslint@8.53.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/eslint
        npm ERR! extraneous: espree@9.6.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/espree
        npm ERR! extraneous: esprima@4.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/esprima
        npm ERR! extraneous: esquery@1.5.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/esquery
        npm ERR! extraneous: esrecurse@4.3.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/esrecurse
        npm ERR! extraneous: estraverse@5.3.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/estraverse
        npm ERR! extraneous: esutils@2.0.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/esutils
        npm ERR! extraneous: etag@1.8.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/etag
        npm ERR! extraneous: event-stream@3.3.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/event-stream
        npm ERR! extraneous: eventemitter3@4.0.7 /opt/iobroker/node_modules/iobroker.javascript/node_modules/eventemitter3
        npm ERR! extraneous: execa@5.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/execa
        npm ERR! extraneous: expand-brackets@2.1.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/expand-brackets
        npm ERR! extraneous: expand-tilde@2.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/expand-tilde
        npm ERR! extraneous: express@4.18.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/express
        npm ERR! extraneous: ext@1.7.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/ext
        npm ERR! extraneous: extend-shallow@3.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/extend-shallow
        npm ERR! extraneous: extglob@2.0.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/extglob
        npm ERR! extraneous: fancy-log@1.3.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/fancy-log
        npm ERR! extraneous: fast-glob@3.3.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/fast-glob
        npm ERR! extraneous: fast-levenshtein@2.0.6 /opt/iobroker/node_modules/iobroker.javascript/node_modules/fast-levenshteinnpm ERR! extraneous: fastq@1.15.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/fastq
        npm ERR! extraneous: file-entry-cache@6.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/file-entry-cachenpm ERR! extraneous: fill-range@7.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/fill-range
        npm ERR! extraneous: finalhandler@1.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/finalhandler
        npm ERR! extraneous: find-up@5.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/find-up
          Hier der Rest...
          npm ERR!     /home/iobroker/.npm/_logs/2023-11-20T11_01_09_978Z-debug-0.log
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Core adapters versions
          js-controller:  4.0.24
          admin:          6.2.23
          javascript:     6.2.0
          npm ERR!     /home/iobroker/.npm/_logs/2023-11-20T11_01_43_451Z-debug-0.log
          Adapters from github:   3
          Adapter State
          + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
            system.adapter.alias-manager.0          : alias-manager         : iobroker                                 - disabled
          + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
            system.adapter.discovery.0              : discovery             : iobroker                                 - disabled
            system.adapter.easee.0                  : easee                 : iobroker                                 - disabled
          + system.adapter.echarts.0                : echarts               : iobroker                                 -  enabled
          + system.adapter.energiefluss.0           : energiefluss          : iobroker                                 -  enabled
          + system.adapter.fakeroku.0               : fakeroku              : iobroker                                 -  enabled
            system.adapter.flot.0                   : flot                  : iobroker                                 - disabled
          + system.adapter.fronius-solarweb.0       : fronius-solarweb      : iobroker                                 -  enabled
          + system.adapter.fronius.0                : fronius               : iobroker                                 -  enabled
            system.adapter.habpanel.0               : habpanel              : iobroker                                 - disabled
          + system.adapter.harmony.0                : harmony               : iobroker                                 -  enabled
          + system.adapter.history.0                : history               : iobroker                                 -  enabled
            system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
            system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: iobroker                                 - disabled
            system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 -  enabled
            system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker                                 - disabled
          + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
          + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
            system.adapter.jarvis.0                 : jarvis                : iobroker                                 - disabled
          + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
          + system.adapter.knx.0                    : knx                   : iobroker                                 -  enabled, bind: 192.168.8.67
            system.adapter.labcom.0                 : labcom                : iobroker                                 - disabled
          + system.adapter.lg-thinq.0               : lg-thinq              : iobroker                                 -  enabled
          + system.adapter.lgtv.0                   : lgtv                  : iobroker                                 -  enabled
          + system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker                                 -  enabled, port: 54321
            system.adapter.mobile.0                 : mobile                : iobroker                                 - disabled
          + system.adapter.moma.0                   : moma                  : iobroker                                 -  enabled
          + system.adapter.onkyo.0                  : onkyo                 : iobroker                                 -  enabled
            system.adapter.openweathermap.0         : openweathermap        : iobroker                                 -  enabled
            system.adapter.parser.0                 : parser                : iobroker                                 - disabled
            system.adapter.pi-hole.0                : pi-hole               : iobroker                                 - disabled
          + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
          + system.adapter.pvforecast.0             : pvforecast            : iobroker                                 -  enabled
            system.adapter.sayit.0                  : sayit                 : iobroker                                 - disabled, port: 0
          + system.adapter.scenes.0                 : scenes                : iobroker                                 -  enabled
          + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1886, bind: 0.0.0.0
          + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
          + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
          + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
          + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
          + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
            system.adapter.unifi.0                  : unifi                 : iobroker                                 - disabled
          + system.adapter.vis-2-beta.0             : vis-2-beta            : iobroker                                 -  enabled
            system.adapter.vis-bars.0               : vis-bars              : iobroker                                 - disabled
            system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 - disabled
            system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker                                 - disabled
            system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker                                 - disabled
            system.adapter.vis-google-fonts.0       : vis-google-fonts      : iobroker                                 - disabled
            system.adapter.vis-history.0            : vis-history           : iobroker                                 - disabled
            system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
            system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 - disabled
          + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
            system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 - disabled
            system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 - disabled
            system.adapter.vis-keyboard.0           : vis-keyboard          : iobroker                                 - disabled
            system.adapter.vis-lcars.0              : vis-lcars             : iobroker                                 - disabled
            system.adapter.vis-map.0                : vis-map               : iobroker                                 - disabled
            system.adapter.vis-material-advanced.0  : vis-material-advanced : iobroker                                 -  enabled
            system.adapter.vis-material.0           : vis-material          : iobroker                                 - disabled
            system.adapter.vis-metro.0              : vis-metro             : iobroker                                 - disabled
            system.adapter.vis-players.0            : vis-players           : iobroker                                 - disabled
            system.adapter.vis-plumb.0              : vis-plumb             : iobroker                                 - disabled
            system.adapter.vis-rgraph.0             : vis-rgraph            : iobroker                                 - disabled
            system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
            system.adapter.vis-weather.0            : vis-weather           : iobroker                                 - disabled
            system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
          + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          + system.adapter.wifilight.0              : wifilight             : iobroker                                 -  enabled
          + system.adapter.wled.0                   : wled                  : iobroker                                 -  enabled
          + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: /dev/ttyUSB0
          + instance is alive
          ioBroker-Repositories
          Active repo(s): stable
          Installed ioBroker-Instances
          Used repository: stable
          Adapter    "admin"        : 6.12.0   , installed 6.2.23 [Updatable]
          Adapter    "backitup"     : 2.8.7    , installed 2.9.1
          Adapter    "bydbatt"      : 1.1.0    , installed 1.1.0
          Adapter    "bydhvs"       : 1.4.0    , installed 1.5.0
          Adapter    "chromecast"   : 3.0.3    , installed 2.3.1  [Updatable]
          Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
          Adapter    "device-reminder": 3.0.0  , installed 1.2.9  [Updatable]
          Adapter    "discovery"    : 4.2.0    , installed 3.2.0  [Updatable]
          Adapter    "easee"        : 1.0.10   , installed 1.0.10
          Adapter    "echarts"      : 1.5.4    , installed 1.0.12 [Updatable]
          Adapter    "fakeroku"     : 0.2.2    , installed 0.2.2
          Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
          Adapter    "fritzbox"     : 0.5.0    , installed 0.2.1  [Updatable]
          Adapter    "fronius"      : 2.0.2    , installed 2.0.2
          Adapter    "fronius-solarweb": 0.0.3 , installed 0.0.3
          Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
          Adapter    "harmony"      : 1.2.2    , installed 1.2.2
          Adapter    "history"      : 3.0.1    , installed 2.2.6  [Updatable]
          Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
          Adapter    "info"         : 2.0.0    , installed 1.9.26 [Updatable]
          Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
          Adapter    "javascript"   : 7.1.4    , installed 6.2.0  [Updatable]
          Controller "js-controller": 5.0.16   , installed 4.0.24 [Updatable]
          Adapter    "knx"          : 2.0.23   , installed 2.0.13 [Updatable]
          Adapter    "lg-thinq"     : 0.1.4    , installed 0.1.4
          Adapter    "lgtv"         : 2.1.2    , installed 1.1.12 [Updatable]
          Adapter    "midea"        : 0.0.7    , installed 0.0.7
          Adapter    "mihome"       : 1.4.0    , installed 1.4.0
          Adapter    "mihome-vacuum": 4.1.0    , installed 3.8.6  [Updatable]
          Adapter    "mobile"       : 1.0.1    , installed 1.0.1
          Adapter    "moma"         : 1.2.9    , installed 1.2.9
          Adapter    "onkyo"        : 2.1.2    , installed 2.1.2
          Adapter    "openweathermap": 0.4.5   , installed 0.3.11 [Updatable]
          Adapter    "parser"       : 2.0.7    , installed 1.3.2  [Updatable]
          Adapter    "phantomjs"    : 1.1.3    , installed 1.1.3
          Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
          Adapter    "pvforecast"   : 2.9.0    , installed 2.7.1  [Updatable]
          Adapter    "sayit"        : 3.0.5    , installed 1.13.0 [Updatable]
          Adapter    "schwoerer-ventcube": 1.4.2, installed 1.4.2
          Adapter    "shelly"       : 6.6.1    , installed 6.0.0  [Updatable]
          Adapter    "shuttercontrol": 1.6.2   , installed 1.6.3
          Adapter    "smartmeter"   : 3.3.4    , installed 3.3.4
          Adapter    "socketio"     : 6.5.5    , installed 4.2.0  [Updatable]
          Adapter    "sonoff"       : 3.0.3    , installed 2.5.7  [Updatable]
          Adapter    "tankerkoenig" : 3.3.7    , installed 2.1.1  [Updatable]
          Adapter    "trashschedule": 2.3.0    , installed 2.0.3  [Updatable]
          Adapter    "tuya"         : 3.14.2   , installed 3.9.4  [Updatable]
          Adapter    "unifi"        : 0.6.6    , installed 0.5.10 [Updatable]
          Adapter    "vis"          : 1.4.16   , installed 1.4.16
          Adapter    "vis-canvas-gauges": 1.0.1, installed 0.1.5  [Updatable]
          Adapter    "vis-colorpicker": 2.0.3  , installed 1.2.0  [Updatable]
          Adapter    "vis-icontwo"  : 0.96.0   , installed 0.90.0 [Updatable]
          Adapter    "vis-justgage" : 2.0.0    , installed 1.0.2  [Updatable]
          Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
          Adapter    "vis-lcars"    : 1.1.1    , installed 1.1.1
          Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
          Adapter    "vis-material" : 0.1.3    , installed 0.1.3
          Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
          Adapter    "web"          : 6.1.10   , installed 4.3.0  [Updatable]
          Adapter    "wifilight"    : 1.1.4    , installed 1.1.4
          Adapter    "wled"         : 0.7.1    , installed 0.6.7  [Updatable]
          Adapter    "ws"           : 2.5.8    , installed 1.3.0  [Updatable]
          Adapter    "zigbee"       : 1.8.24   , installed 1.8.24
          Objects and States
          Objects:        11799
          States:         10540
          Hit:1 http://de.archive.ubuntu.com/ubuntu focal InRelease
          Hit:2 http://de.archive.ubuntu.com/ubuntu focal-updates InRelease
          Hit:3 http://de.archive.ubuntu.com/ubuntu focal-backports InRelease
          Hit:4 http://de.archive.ubuntu.com/ubuntu focal-security InRelease
          Hit:5 https://deb.nodesource.com/node_18.x focal InRelease
          Reading package lists...
          Pending Updates: 15
          *** Listening Ports ***
          tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1000       35070      2326/io.shelly.0
          tcp        0      0 192.168.8.67:9093       0.0.0.0:*               LISTEN      1000       35419      2573/io.fakeroku.0
          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       32795      1756/iobroker.js-co
          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       32532      1756/iobroker.js-co
          tcp        0      0 0.0.0.0:10000           0.0.0.0:*               LISTEN      0          28197      1027/perl
          tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      101        21935      641/systemd-resolve
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          25514      811/sshd: /usr/sbin
          tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        31602      1777/influxd
          tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1000       34927      2333/io.sonoff.0
          tcp6       0      0 :::61991                :::*                    LISTEN      1000       36326      2653/io.harmony.0
          tcp6       0      0 :::8081                 :::*                    LISTEN      1000       34086      2132/io.admin.0
          tcp6       0      0 :::8082                 :::*                    LISTEN      1000       37649      2882/io.web.0
          tcp6       0      0 :::8086                 :::*                    LISTEN      999        32766      1777/influxd
          tcp6       0      0 :::22                   :::*                    LISTEN      0          25516      811/sshd: /usr/sbin
          tcp6       0      0 :::8087                 :::*                    LISTEN      1000       37894      3013/io.simple-api.
          tcp6       0      0 :::3000                 :::*                    LISTEN      111        27368      783/grafana-server
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       37506      2935/io.wled.0
          udp        0      0 0.0.0.0:10000           0.0.0.0:*                           0          28198      1027/perl
          udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       35420      2573/io.fakeroku.0
          udp        0      0 192.168.8.67:53249      0.0.0.0:*                           1000       35708      2690/io.knx.0
          udp        0      0 127.0.0.53:53           0.0.0.0:*                           101        21934      641/systemd-resolve
          udp        0      0 192.168.8.67:68         0.0.0.0:*                           100        21920      635/systemd-network
          udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1000       35977      2473/io.mihome-vacu
          udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1000       36336      2494/io.tuya.0
          udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1000       36337      2494/io.tuya.0
          udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1000       36327      2653/io.harmony.0
          udp6       0      0 fe80::11:32ff:fe2d::546 :::*                                100        20383      635/systemd-network
          2023-11-20 12:02:11.075  - debug: fronius.0 (2593) Response to http://192.168.8.54/solar_api/v1/GetInverterInfo.cgi: {"Body":{"Data":{"1":{"CustomName":"Sonnenstudio360","DT":1,"ErrorCode":1130,"InverterState":"Running","PVPower":11600,"Show":1,"StatusCode":7,"UniqueID":"31558765"}}},"Head":{"RequestArguments":{},"Status":{"Code":0,"Reason":"","UserMessage":""},"Timestamp":"2023-11-20T11:02:11+00:00"}}
          2023-11-20 12:02:40.671  - debug: fronius.0 (2593) Response to http://192.168.8.54/solar_api/v1/GetInverterRealtimeData.cgi?Scope=Device&DeviceId=1&DataCollection=MinMaxInverterData: {"Body":{"Data":{}},"Head":{"RequestArguments":{"DataCollection":"MinMaxInverterData","Scope":"Device"},"Status":{"Code":11,"Reason":"Parameter 'MinMaxInverterData' for attribute 'DataCollection' not supported. Use one of 'CumulationInverterData', 'CommonInverterData', '3PInverterData'.","UserMessage":""},"Timestamp":"2023-11-20T11:02:40+00:00"}}
          2023-11-20 12:02:40.683  - debug: fronius.0 (2593) Response to http://192.168.8.54/solar_api/v1/GetMeterRealtimeData.cgi?Scope=Device&DeviceId=0: {"Body":{"Data":{"Current_AC_Phase_1":0.732,"Current_AC_Phase_2":-0.69,"Current_AC_Phase_3":1.231,"Current_AC_Sum":1.2730000000000001,"Details":{"Manufacturer":"Fronius","Model":"Smart Meter TS 65A-3","Serial":"1659699688"},"Enable":1,"EnergyReactive_VArAC_Sum_Consumed":787465,"EnergyReactive_VArAC_Sum_Produced":5086507,"EnergyReal_WAC_Minus_Absolute":7490523,"EnergyReal_WAC_Plus_Absolute":4746701,"EnergyReal_WAC_Sum_Consumed":4746701,"EnergyReal_WAC_Sum_Produced":7490523,"Frequency_Phase_Average":50,"Meter_Location_Current":0,"PowerApparent_S_Phase_1":54.5,"PowerApparent_S_Phase_2":151.6,"PowerApparent_S_Phase_3":195.1,"PowerApparent_S_Sum":401.4,"PowerFactor_Phase_1":0.714,"PowerFactor_Phase_2":-0.881,"PowerFactor_Phase_3":0.515,"PowerFactor_Sum":0.019,"PowerReactive_Q_Phase_1":-38.2,"PowerReactive_Q_Phase_2":-71.5,"PowerReactive_Q_Phase_3":-166.6,"PowerReactive_Q_Sum":-276.4,"PowerReal_P_Phase_1":38.9,"PowerReal_P_Phase_2":-133.6,"PowerReal_P_Phase_3":101.6,"PowerReal_P_Sum":6.8,"TimeStamp":1700478159,"Visible":1,"Voltage_AC_PhaseToPhase_12":410.1,"Voltage_AC_PhaseToPhase_23":411,"Voltage_AC_PhaseToPhase_31":406.1,"Voltage_AC_Phase_1":241.2,"Voltage_AC_Phase_2":230,"Voltage_AC_Phase_3":237.7}},"Head":{"RequestArguments":{"DeviceId":"0","Scope":"Device"},"Status":{"Code":0,"Reason":"","UserMessage":""},"Timestamp":"2023-11-20T11:02:40+00:00"}}
          2023-11-20 12:02:40.726  - debug: fronius.0 (2593) Response to http://192.168.8.54/solar_api/v1/GetStorageRealtimeData.cgi?Scope=Device&DeviceId=0: {"Body":{"Data":{"Controller":{"Capacity_Maximum":10240,"Current_DC":1.2981114032990677,"DesignedCapacity":10240,"Details":{"Manufacturer":"BYD","Model":"BYD Battery-Box Premium HV","Serial":"P030T020Z2010263183     "},"Enable":1,"StateOfCharge_Relative":17.8,"Status_BatteryCell":3,"Temperature_Cell":12,"TimeStamp":1700478156,"Voltage_DC":418.3},"Modules":[]}},"Head":{"RequestArguments":{"DeviceId":"0","Scope":"Device"},"Status":{"Code":0,"Reason":"","UserMessage":""},"Timestamp":"2023-11-20T11:02:40+00:00"}}
          2023-11-20 12:02:40.767  - debug: fronius.0 (2593) Response to http://192.168.8.54/solar_api/v1/GetPowerFlowRealtimeData.fcgi: {"Body":{"Data":{"Inverters":{"1":{"Battery_Mode":"normal","DT":1,"E_Day":null,"E_Total":23263193.850555554,"E_Year":null,"P":460.24041748046875,"SOC":17.8}},"SecondaryMeters":{},"Site":{"BackupMode":false,"BatteryStandby":true,"E_Day":null,"E_Total":23263193.850555554,"E_Year":null,"Meter_Location":"grid","Mode":"bidirectional","P_Akku":-666.0352783203125,"P_Grid":6.8,"P_Load":-467.79334716796876,"P_PV":1129.3310546875,"rel_Autonomy":98.54636667212833,"rel_SelfConsumption":100},"Smartloads":{"Ohmpilots":{}},"Version":"12"}},"Head":{"RequestArguments":{},"Status":{"Code":0,"Reason":"","UserMessage":""},"Timestamp":"2023-11-20T11:02:40+00:00"}}
          2023-11-20 12:02:40.769  - debug: fronius.0 (2593) Response to http://192.168.8.54/solar_api/v1/GetOhmPilotRealtimeData.cgi?Scope=System: {"Body":{"Data":{}},"Head":{"RequestArguments":{"Scope":"System"},"Status":{"Code":0,"Reason":"","UserMessage":""},"Timestamp":"2023-11-20T11:02:40+00:00"}}
          2023-11-20 12:02:40.773  - debug: fronius.0 (2593) API Objekt E_Day is null, object inverter.1.E_Day will be set to 0!
          2023-11-20 12:02:40.782  - debug: fronius.0 (2593) API Objekt E_Year is null, object inverter.1.E_Year will be set to 0!2023-11-20 12:02:40.783  - debug: fronius.0 (2593) API Objekt E_Day is null, object site.E_Day will be set to 0!
          2023-11-20 12:02:40.784  - debug: fronius.0 (2593) API Objekt E_Year is null, object site.E_Year will be set to 0!
          2023-11-20 12:02:40.928  - debug: fronius.0 (2593) Response to http://192.168.8.54/solar_api/v1/GetInverterInfo.cgi: {"Body":{"Data":{"1":{"CustomName":"Sonnenstudio360","DT":1,"ErrorCode":1130,"InverterState":"Running","PVPower":11600,"Show":1,"StatusCode":7,"UniqueID":"31558765"}}},"Head":{"RequestArguments":{},"Status":{"Code":0,"Reason":"","UserMessage":""},"Timestamp":"2023-11-20T11:02:40+00:00"}}
          2023-11-20 12:02:41.004  - debug: fronius.0 (2593) Response to http://192.168.8.54/solar_api/v1/GetInverterRealtimeData.cgi?Scope=Device&DeviceId=1&DataCollection=CommonInverterData: {"Body":{"Data":{"DAY_ENERGY":{"Unit":"Wh","Value":null},"DeviceStatus":{"ErrorCode":1130,"InverterState":"Running","StatusCode":7},"FAC":{"Unit":"Hz","Value":50.00504684448242},"IAC":{"Unit":"A","Value":1.970382273197174},"IDC":{"Unit":"A","Value":1.233007550239563},"IDC_2":{"Unit":"A","Value":1.0074610710144043},"IDC_3":{"Unit":"A","Value":null},"IDC_4":{"Unit":"A","Value":null},"PAC":{"Unit":"W","Value":463.17767333984375},"SAC":{"Unit":"VA","Value":463.22857666015625},"TOTAL_ENERGY":{"Unit":"Wh","Value":23263193.850555554},"UAC":{"Unit":"V","Value":234.6595916748047},"UDC":{"Unit":"V","Value":528.879150390625},"UDC_2":{"Unit":"V","Value":555.4661254882812},"UDC_3":{"Unit":"V","Value":null},"UDC_4":{"Unit":"V","Value":null},"YEAR_ENERGY":{"Unit":"Wh","Value":null}}},"Head":{"RequestArguments":{"DataCollection":"CommonInverterData","DeviceId":"1","Scope":"Device"},"Status":{"Code":0,"Reason":"","UserMessage":""},"Timestamp":"2023-11-20T11:02:40+00:00"}}
          2023-11-20 12:02:41.041  - debug: fronius.0 (2593) Response to http://192.168.8.54/solar_api/v1/GetInverterRealtimeData.cgi?Scope=Device&DeviceId=1&DataCollection=3PInverterData: {"Body":{"Data":{"IAC_L1":{"Unit":"A","Value":0.6535905599594116},"IAC_L2":{"Unit":"A","Value":0.6578454971313477},"IAC_L3":{"Unit":"A","Value":0.6589462161064148},"UAC_L1":{"Unit":"V","Value":234.55113220214844},"UAC_L2":{"Unit":"V","Value":236.23095703125},"UAC_L3":{"Unit":"V","Value":234.4892120361328}}},"Head":{"RequestArguments":{"DataCollection":"3PInverterData","DeviceId":"1","Scope":"Device"},"Status":{"Code":0,"Reason":"","UserMessage":""},"Timestamp":"2023-11-20T11:02:41+00:00"}}
          2023-11-20 12:03:00.036  - warn: javascript.0 (2207) State "sonoff.0.WIFI-STECKDOSE-5.POWER" not found
          2023-11-20 12:03:00.038  - warn: javascript.0 (2207)     at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1729:20)
          2023-11-20 12:03:00.038  - warn: javascript.0 (2207)     at Object.<anonymous> (script.js.Heizung.Gartenhütte_Heizung:15:5)
          2023-11-20 12:03:00.039  - warn: javascript.0 (2207)     at Job.job (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1605:34)
          2023-11-20 12:03:00.039  - warn: javascript.0 (2207)     at Job.invoke (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Job.js:171:15)
          2023-11-20 12:03:00.039  - warn: javascript.0 (2207)     at /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:268:28
          2023-11-20 12:03:00.040  - warn: javascript.0 (2207)     at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:228:7)
          2023-11-20 12:03:00.040  - warn: javascript.0 (2207)     at listOnTimeout (node:internal/timers:564:17)
          2023-11-20 12:03:00.040  - warn: javascript.0 (2207)     at processTimers (node:internal/timers:507:7)
          2023-11-20 12:03:00.040  - info: javascript.0 (2207) script.js.Heizung.Gartenhütte_Heizung: 25.2
          2023-11-20 12:03:00.041  - info: javascript.0 (2207) script.js.Heizung.Gartenhütte_Heizung: E-Heizung Gartenhütte - AUS
          2023-11-20 12:03:02.105  - warn: sonoff.0 (2333) Client [] has invalid password or username
          iob diag has finished.
          Press any key for a summary
          Thomas Braun W 2 Replies Last reply Reply Quote 0
            Thomas Braun Most Active @wolkenloser last edited by
            @wolkenloser
            Dein nodejs ist noch schief.
            Kratz das alles raus.
            rm -rf /home/iobroker/.nvm
            Danach
            iob fix
            iob nodejs-update
              Wie gesagt, die ganzen Updateable Adapters lassen sich nicht updaten.
              Das Problem fing vor 2 Monaten an, als ich den Energiefluss Adapter installiert hatte....
                @wolkenloser sagte in keine Geräte im Zigbee Adapter - funktioniert aber.:
                Nein, das fing damit an, dass du da per nvm ein nodejs 18.9.0 reingeklatscht hast...
                  wolkenloser @Thomas Braun last edited by wolkenloser
                  wie gesagt, ich bin auch nur Benutzer.
                  Aber ich lerne gerne dazu, weil interessieren tut es mich ja.
                  Man nennt das wohl auchg auch "gefährliches Halbwissen"
                  Wenn das so ist wie Du es sagst habe ich das wohl aus irgendeiner Intention, oder wegen einer Anleitung im Internet gemacht.
                  Der Energiefluss Adapter lies sich damals nicht über die Oberfläche installieren, dann hab ich gesucht wie es noch geht. Irgendwann war er drin.
                  Ich versuch jetzzt das was Du oben geschrieben hast...
                  Thomas Braun 3 Replies Last reply Reply Quote 0
                    Was kann ich denn jetzt am besten machen ohne bei Null anzufangen ?
                    Hab ich doch vor 15 Minuten oben geschrieben...
                    Den Kram löschen und nodejs ordentlich installieren wäre schon mal ein erster Schritt.
                      @wolkenloser
                      Und schalt den
                      debug: fronius.0
                      aus. Der kübelt dir sonst zu viel in das Log rein.
                        Thomas Braun Most Active @wolkenloser last edited by Thomas Braun
                        @wolkenloser
                        Wenn nodejs sauber installiert ist und die ganzen npm-Fehler dann immer noch aufkreuzen:
                        Installier mindestens diese drei Adapter nochmal:
                        Sind alle über github und nicht 'ordentlich' installiert, oder?
                          Energiefluss auf jeden Fall
                          den Labcom brauch ich nicht mehr den deinstalliere ich.
                          Fronius ist mit am wichtigsten wegen diverser Scripte.... ich schau mal.
                          Wenn ich den neu installiere sollten die Datenpunkte ja wieder so wie bisher aktualisiert werden.....
                            wolkenloser @wolkenloser last edited by wolkenloser
                            Labcom ist weg....
                            Hast Du dafür auch eine Lösung ?
                              @wolkenloser
                              Ich seh nix. Text auch als Text in CodeTags eingebettet hier rein.
                                Kommt gleich..
                                Zwischenstand:
                                                        v.2023-10-10
                                           Chassis: vm
                                Installation:           microsoft
                                Kernel:                 x86_64
                                Userland:               amd64
                                Timezone:               Europe/Berlin (CET, +0100)
                                User-ID:                1000
                                X-Server:               false
                                Boot Target:            graphical.target
                                Pending OS-Updates:     0
                                node:internal/modules/cjs/loader:1080
                                  throw err;
                                Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                                    at Module._resolveFilename (node:internal/modules/cjs/loader:1077:15)
                                    at Module._load (node:internal/modules/cjs/loader:922:27)
                                    at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:86:12)
                                    at node:internal/main/run_main_module:23:47 {
                                  code: 'MODULE_NOT_FOUND',
                                  requireStack: []
                                Node.js v18.18.2
                                Pending iob updates:    0
                                Nodejs-Installation:    /usr/bin/nodejs         v18.18.2
                                                        /usr/bin/node           v18.18.2
                                                        /usr/bin/npm            9.8.1
                                                        /usr/bin/npx            9.8.1
                                                        /usr/bin/corepack       0.19.0
                                Recommended versions are nodejs  and npm
                                MEMORY:
                                Mem:           3.9G        423M        2.3G        0.0K        1.2G        3.2G
                                Swap:          2.0G         43M        1.9G
                                Total:         5.9G        467M        4.2G
                                  throw err;
                                  requireStack: []
                                Node.js v18.18.2
                                Active iob-Instances:   0
                                  throw err;
                                  requireStack: []
                                Node.js v18.18.2
                                  throw err;
                                  requireStack: []
                                Node.js v18.18.2
                                ioBroker Core:          js-controller
                                  throw err;
                                  requireStack: []
                                Node.js v18.18.2
                                                        admin
                                  throw err;
                                  requireStack: []
                                Node.js v18.18.2
                                ioBroker Status:
                                  throw err;
                                  requireStack: []
                                Node.js v18.18.2
                                Objects:                0
                                States:                 0
                                Size of iob-Database:
                                16M     /opt/iobroker/iobroker-data/objects.jsonl
                                9.7M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
                                0       /opt/iobroker/iobroker-data/objects.json.broken
                                2.6M    /opt/iobroker/iobroker-data/states.jsonl
                                1.3M    /opt/iobroker/iobroker-data/states.json.migrated
                                1.3M    /opt/iobroker/iobroker-data/states.json.bak.migrated
                                0       /opt/iobroker/iobroker-data/states.json.broken
                                  ich kann Dir den Text vom Energieflussadapter nicht reinkopieren, im moment kann ich nichtmal den Admin Adapter aufrufen. Hab versucht den manuell zu starten, Dann kommt das
                                  iob start admin
                                    throw err;
                                    requireStack: []
                                  Node.js v18.18.2
                                    @wolkenloser
                                    cd /opt/iobroker
                                    sudo -H -u iobroker npm install iobroker.js-controller
                                      /opt/iobroker$ sudo -H -u iobroker npm install iobroker.js-controller
                                      (#####⠂⠂⠂⠂⠂⠂⠂⠂⠂⠂⠂⠂⠂) ⠸ idealTree:@root/greenlock: sill placeDep ROOT @root/keypairs@0.9.0 OK for: greenlock@4.0.(#####⠂⠂⠂⠂⠂⠂⠂⠂⠂⠂⠂⠂⠂) ⠸ idealTree:@root/greenlock: sill placeDep ROOT @root/keypairs@0.9.0 OK for: greenlock@4.0.npm WARN skipping integrity check for git dependency ssh://git@github.com/SKB-CGN/ioBroker.energiefluss.git
                                      npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
                                      npm WARN deprecated crypto@1.0.1: This package is no longer supported. It's now a built-in Node module. If you've depended on crypto, you should switch to the one that's built-in.
                                      npm WARN deprecated @types/bl@5.1.0: This is a stub types definition. bl provides its own type definitions, so you do not need this installed.
                                      npm WARN deprecated source-map-url@0.4.1: See https://github.com/lydell/source-map-url#deprecated
                                      npm WARN deprecated request-promise-native@1.0.9: request-promise-native has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
                                      npm WARN deprecated urix@0.1.0: Please see https://github.com/lydell/urix#deprecated
                                      npm WARN deprecated string-similarity@4.0.4: Package no longer supported. Contact Support at https://www.npmjs.com/support for more info.
                                      npm WARN deprecated har-validator@5.1.5: this library is no longer supported
                                      npm WARN deprecated resolve-url@0.2.1: https://github.com/lydell/resolve-url#deprecated
                                      npm WARN deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
                                      npm WARN deprecated source-map-resolve@0.5.3: See https://github.com/lydell/source-map-resolve#deprecated
                                      npm WARN deprecated w3c-hr-time@1.0.2: Use your platform's native performance.now() and performance.timeOrigin.
                                      npm WARN deprecated xmldom@0.1.31: Deprecated due to CVE-2021-21366 resolved in 0.5.0
                                      npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
                                      npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
                                      npm WARN deprecated querystring@0.2.0: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
                                      npm WARN deprecated phantomjs-prebuilt@2.1.16: this package is now deprecated
                                      npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
                                      npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                                      npm WARN deprecated axios@0.19.2: Critical security vulnerability fixed in v0.21.1. For more information, see https://github.com/axios/axios/pull/3410
                                      npm WARN deprecated xmldom@0.1.16: Deprecated due to CVE-2021-21366 resolved in 0.5.0
                                      added 6 packages, and changed 1963 packages in 15m
                                      176 packages are looking for funding
                                        run `npm fund` for details
                                      iobroker@iobroker:/opt/iobroker$ npm fund
                                      iobroker.inst@2.0.3
                                      ├── https://github.com/sponsors/jaredhanson
                                      │   └── passport@0.5.3
                                      ├── https://github.com/sponsors/RubenVerborgh
                                      │   └── follow-redirects@1.15.3
                                      ├── https://github.com/sponsors/ljharb
                                      │   └── qs@6.11.0, side-channel@1.0.4, call-bind@1.0.5, function-bind@1.1.2, gopd@1.0.1, has-property-descriptors@1.0.1, get-intrinsic@1.2.2, has-proto@1.0.1, has-symbols@1.0.3, object-inspect@1.13.1, is-arguments@1.1.1, has-tostringtag@1.0.0, is-generator-function@1.0.10, is-typed-array@1.1.12, which-typed-array@1.1.13, available-typed-arrays@1.0.5, is-callable@1.2.7, resolve@1.22.8, is-core-module@2.13.1, supports-preserve-symlinks-flag@1.0.0, minimist@1.2.8, is-nan@1.3.2, define-properties@1.2.1, object-is@1.1.5, traverse@0.6.7, is-object@1.0.2, deep-equal@1.1.2, is-date-object@1.0.5, is-regex@1.1.4, regexp.prototype.flags@1.5.1, functions-have-names@1.2.3, object.assign@4.1.4
                                      ├── https://github.com/sponsors/feross
                                      │   └── safe-buffer@5.2.1, base64-js@1.5.1, ieee754@1.2.1, simple-concat@1.0.1, buffer@6.0.3, run-parallel@1.2.0, queue-microtask@1.2.3
                                      ├── https://github.com/sponsors/broofa
                                      │   └── uuid@9.0.1
                                      ├── https://github.com/sponsors/sindresorhus
                                      │   └── is-stream@2.0.1, responselike@2.0.1, clone-response@1.0.3, get-stream@5.2.0, normalize-url@6.1.0, component-emitter@1.3.1, make-dir@3.1.0, mimic-response@2.1.0, onetime@5.1.2, multimatch@5.0.0, throttleit@1.0.1, sort-keys@4.2.0, p-limit@2.3.0, p-queue@6.6.2, any-observable@0.5.1, del@6.1.1, globby@11.1.0, p-map@4.0.0, escape-goat@3.0.0, escape-string-regexp@4.0.0, import-local@3.1.0, is-installed-globally@0.3.2, global-dirs@2.1.0, log-symbols@4.1.0, is-unicode-supported@0.1.0, meow@8.1.2, camelcase-keys@6.2.2, map-obj@4.3.0, decamelize-keys@1.1.1, type-fest@0.18.1, npm-name@6.0.1, p-event@4.2.0, type-fest@0.10.0, is-url-superb@4.0.0, open@7.4.2, is-docker@2.2.1, ow@0.21.0, dot-prop@6.0.1, type-fest@0.20.2, p-settle@4.1.1, read-pkg-up@7.0.1, terminal-link@2.1.1, boxen@5.1.2, camelcase@6.3.0, cli-boxes@2.2.1, is-installed-globally@0.4.0, global-dirs@3.0.1, is-npm@5.0.0, import-fresh@3.3.0, parse-json@5.2.0, ansi-escapes@4.3.2, type-fest@0.21.3, figures@3.2.0, find-up@5.0.0, locate-path@6.0.0, p-locate@5.0.0, p-limit@3.1.0, yocto-queue@0.1.0, hex-rgb@4.3.0
                                      ├─┬ https://github.com/sindresorhus/got?sponsor=1
                                      │ │ └── got@11.8.6, got@10.7.0
                                      │ └── https://github.com/sindresorhus/is?sponsor=1
                                      │     └── @sindresorhus/is@4.6.0, @sindresorhus/is@2.1.1
                                      ├── https://github.com/sponsors/epoberezkin
                                      │   └── ajv@6.12.6
                                      ├── https://github.com/sponsors/NaturalIntelligence
                                      │   └── fast-xml-parser@4.3.2
                                      ├── https://github.com/sponsors/isaacs
                                      │   └── minimatch@9.0.3, rimraf@3.0.2, glob@7.2.3
                                      ├─┬ https://opencollective.com/node-fetch
                                      │ │ └── node-fetch@3.3.2
                                      │ └── https://github.com/sponsors/jimmywarting
                                      │     └── fetch-blob@3.2.0, node-domexception@1.0.0
                                      ├── https://opencollective.com/serialport/donate
                                      │   └── serialport@10.5.0, @serialport/bindings-cpp@10.8.0, @serialport/parser-byte-length@10.5.0, @serialport/parser-cctalk@10.5.0, @serialport/parser-delimiter@10.5.0, @serialport/parser-inter-byte-timeout@10.5.0, @serialport/parser-readline@10.5.0, @serialport/parser-ready@10.5.0, @serialport/parser-regex@10.5.0, @serialport/parser-slip-encoder@10.5.0, @serialport/parser-spacepacket@10.5.0, @serialport/stream@10.5.0, @serialport/bindings-cpp@12.0.1, @serialport/parser-delimiter@12.0.0, @serialport/stream@12.0.0
                                      ├── https://www.buymeacoffee.com/systeminfo
                                      │   └── systeminformation@5.21.17
                                      ├── https://opencollective.com/date-fns
                                      │   └── date-fns@2.30.0
                                      ├── https://opencollective.com/ioredis
                                      │   └── ioredis@4.28.5
                                      ├── https://github.com/sindresorhus/execa?sponsor=1
                                      │   └── execa@5.1.1
                                      ├─┬ https://paulmillr.com/funding/
                                      │ │ └── chokidar@3.5.3
                                      │ └── https://github.com/sponsors/jonschlinkert
                                      │     └── picomatch@2.3.1, set-value@4.1.0
                                      ├── https://github.com/sponsors/sibiraj-s
                                      │   └── ci-info@3.9.0
                                      ├─┬ https://github.com/chalk/wrap-ansi?sponsor=1
                                      │ │ └── wrap-ansi@7.0.0
                                      │ └── https://github.com/chalk/ansi-styles?sponsor=1
                                      │     └── ansi-styles@4.3.0
                                      ├── https://opencollective.com/browserslist
                                      │   └── browserslist@4.22.1, caniuse-lite@1.0.30001563, update-browserslist-db@1.0.13
                                      ├── https://opencollective.com/core-js
                                      │   └── core-js@3.33.3, core-js-compat@3.33.3
                                      ├─┬ https://opencollective.com/javascript-obfuscator
                                      │ │ └── javascript-obfuscator@3.2.7
                                      │ └── https://github.com/chalk/chalk?sponsor=1
                                      │     └── chalk@4.1.2
                                      ├── https://github.com/sponsors/wooorm
                                      │   └── levenshtein-edit-distance@2.0.5
                                      ├── https://opencollective.com/js-sdsl
                                      │   └── js-sdsl@4.3.0
                                      └─┬ https://github.com/sindresorhus/np?sponsor=1
                                        │ └── np@7.7.0
                                        ├── https://github.com/sindresorhus/p-memoize?sponsor=1
                                        │   └── p-memoize@4.0.4
                                        └── https://github.com/yeoman/update-notifier?sponsor=1
                                            └── update-notifier@5.1.0
                                      mikeal created this issue in request/request
                                      open Request’s Past, Present and Future #3142
                                      Qix- created this issue in visionmedia/debug
                                      closed ReDos Vulnerability Regression Visibility Notice #797
                                      timemachine3030 created this issue in axios/axios
                                      closed Hotfix: Prevent SSRF #3410
                                        Die Web Oberfläche klappt wieder , ENERGIEFLUSS läßt sich deinstallieren.
                                        Dann bleibt noch der fronius
                                          Kurzes Status Update.
                                          Ich update gerade 30 Adapter, pro Adapter dauert es anscheinend mehr als 5 Minuten.
                                            @wolkenloser
                                            Ja, das ist möglich.
                                            zigbee-adapter
                                            2371
