    4. Test Adapter onvif camera v1.x.x
      tombox @Knusterus last edited by
      @knusterus Ja vielleicht mal Hersteller wegen onvif events anfragen
      K 2 Replies Last reply Reply Quote 0
        Knusterus @tombox last edited by
        @tombox
        Habe ich bereits getan, warte auf Antwort. Melde mich sobald ich eine Antwort habe.
          micw42 @Knusterus last edited by
          seit Version 1.1.1 startet der Adapter nicht mehr, Fehlermeldung ist folgende:
          TypeError: callback.call is not a function at Cam.<anonymous> (/opt/iobroker/node_modules/onvif/lib/events.js:309:14) at ClientRequest.<anonymous> (/opt/iobroker/node_modules/onvif/lib/cam.js:328:4) at ClientRequest.emit (node:events:525:35) at ClientRequest.emit (node:domain:489:12) at Socket.socketErrorListener (node:_http_client:494:9) at Socket.emit (node:events:513:28) at Socket.emit (node:domain:489:12) at emitErrorNT (node:internal/streams/destroy:157:8) at emitErrorCloseNT (node:internal/streams/destroy:122:3) at processTicksAndRejections (node:internal/process/task_queues:83:21)
          Jemand eine Idee?
            Thomas Braun Most Active @micw42 last edited by
            @micw42 sagte in Test Adapter onvif camera v1.0.0:
            Jemand eine Idee?
            Das Umfeld schaut wie aus?
            iob diag
            anschauen.
            XBiT 1 Reply Last reply Reply Quote 0
            • XBiT
              XBiT @Thomas Braun last edited by
              @thomas-braun @micw42
              bei mir leider das gleiche..
              Log:
              host.IoBroker
              2023-11-20 13:32:55.269	info	Restart adapter system.adapter.onvif.0 because enabled
              host.IoBroker
              2023-11-20 13:32:55.269	error	instance system.adapter.onvif.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
              host.IoBroker
              2023-11-20 13:32:55.269	error	Caught by controller[0]: at processTicksAndRejections (node:internal/process/task_queues:82:21)
              host.IoBroker
              2023-11-20 13:32:55.269	error	Caught by controller[0]: at endReadableNT (node:internal/streams/readable:1368:12)
              host.IoBroker
              2023-11-20 13:32:55.269	error	Caught by controller[0]: at IncomingMessage.emit (node:domain:489:12)
              host.IoBroker
              2023-11-20 13:32:55.269	error	Caught by controller[0]: at IncomingMessage.emit (node:events:529:35)
              host.IoBroker
              2023-11-20 13:32:55.269	error	Caught by controller[0]: at IncomingMessage.<anonymous> (/opt/iobroker/node_modules/onvif/lib/cam.js:297:4)
              host.IoBroker
              2023-11-20 13:32:55.269	error	Caught by controller[0]: at parseSOAPString (/opt/iobroker/node_modules/onvif/lib/utils.js:108:3)
              host.IoBroker
              2023-11-20 13:32:55.269	error	Caught by controller[0]: at Cam.<anonymous> (/opt/iobroker/node_modules/onvif/lib/events.js:309:14)
              host.IoBroker
              2023-11-20 13:32:55.269	error	Caught by controller[0]: TypeError: callback.call is not a function
              onvif.0
              2023-11-20 13:32:55.037	error	callback.call is not a function
              onvif.0
              2023-11-20 13:32:55.036	error	TypeError: callback.call is not a function at Cam.<anonymous> (/opt/iobroker/node_modules/onvif/lib/events.js:309:14) at parseSOAPString (/opt/iobroker/node_modules/onvif/lib/utils.js:108:3) at IncomingMessage.<anonymous> (/opt/iobroker/node_modules/onvif/lib/cam.js:297:4) at IncomingMessage.emit (node:events:529:35) at IncomingMessage.emit (node:domain:489:12) at endReadableNT (node:internal/streams/readable:1368:12) at processTicksAndRejections (node:internal/process/task_queues:82:21)
              onvif.0
              2023-11-20 13:32:55.036	error	uncaught exception: callback.call is not a function
              onvif.0
              2023-11-20 13:32:43.482	info	Starting snapshot server
              onvif.0
              2023-11-20 13:32:43.481	info	Finished onvif discovery
              onvif.0
              2023-11-20 13:32:41.644	info	Data: undefined xml: undefined
              iob_diag:
              Skript v.2023-10-10
              *** BASE SYSTEM ***
                 Static hostname: IoBroker
                       Icon name: computer-vm
                         Chassis: vm
                  Virtualization: kvm
                Operating System: Debian GNU/Linux 10 (buster)
                          Kernel: Linux 4.19.0-24-amd64
                    Architecture: x86-64
              model name      : Common KVM processor
              Docker          : false
              Virtualization  : kvm
              Kernel          : x86_64
              Userland        : amd64
              Systemuptime and Load:
               13:33:48 up 16 days, 18:50,  1 user,  load average: 0.50, 0.66, 0.67
              CPU threads: 8
              *** Time and Time Zones ***
                             Local time: Mon 2023-11-20 13:33:49 CET
                         Universal time: Mon 2023-11-20 12:33:49 UTC
                               RTC time: Mon 2023-11-20 12:33:50
                            NTP service: active
                        RTC in local TZ: no
              *** User and Groups ***
              stephan
              /home/stephan
              stephan cdrom floppy sudo audio dip video plugdev netdev
              *** X-Server-Setup ***
              X-Server:       false
              Desktop:
              Terminal:       tty
              *** MEMORY ***
              Mem:            16G        3.4G         10G         24M        2.1G         12G
              Swap:          6.1G          0B        6.1G
              Total:          22G        3.4G         16G
                      16042 M total memory
                       3423 M used memory
                       4064 M active memory
                        987 M inactive memory
                      10474 M free memory
                        482 M buffer memory
                       1662 M swap cache
                       6140 M total swap
                          0 M used swap
                       6140 M free swap
              *** FAILED SERVICES ***
              0 loaded units listed. Pass --all to see loaded but inactive units, too.
              To show all installed unit files use 'systemctl list-unit-files'.
              *** FILESYSTEM ***
              udev           devtmpfs  7.9G     0  7.9G   0% /dev
              tmpfs          tmpfs     1.6G   25M  1.6G   2% /run
              /dev/sda1      ext4       34G  7.8G   24G  25% /
              tmpfs          tmpfs     7.9G     0  7.9G   0% /dev/shm
              tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
              tmpfs          tmpfs     7.9G     0  7.9G   0% /sys/fs/cgroup
              tmpfs          tmpfs     1.6G     0  1.6G   0% /run/user/1000
              [Fri Nov  3 18:43:46 2023] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
              [Fri Nov  3 18:43:46 2023] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
              TARGET        SOURCE    FSTYPE OPTIONS
              /             /dev/sda1 ext4   rw,relatime,errors=remount-ro
              `-/sys/fs/bpf bpf       bpf    rw,nosuid,nodev,noexec,relatime,mode=700
              /var:
              565M    /var/
              392M    /var/cache
              385M    /var/cache/apt
              324M    /var/cache/apt/archives
              156M    /var/lib
                    Users in the 'systemd-journal' group can see all messages. Pass -q to
                    turn off this notice.
              No journal files were opened due to insufficient permissions.
              /opt/iobroker/backups:
              379M    /opt/iobroker/backups/
              /opt/iobroker/iobroker-data:
              747M    /opt/iobroker/iobroker-data/
              402M    /opt/iobroker/iobroker-data/files
              238M    /opt/iobroker/iobroker-data/backup-objects
              94M     /opt/iobroker/iobroker-data/files/vis-2-beta
              52M     /opt/iobroker/iobroker-data/files/javascript.admin
              43M     /opt/iobroker/iobroker-data/objects.jsonl
              21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
              21M     /opt/iobroker/iobroker-data/files/eventlist/static/js/main.605c1bc5.js.map
              21M     /opt/iobroker/iobroker-data/files/eventlist.admin/static/js/main.605c1bc5.js.map
              20M     /opt/iobroker/iobroker-data/objects.json.migrated
              USB-Devices by-id:
              *** NodeJS-Installation ***
              /usr/bin/nodejs         v18.18.2
              /usr/bin/node           v18.18.2
              /usr/bin/npm            9.8.1
              /usr/bin/npx            9.8.1
              /usr/bin/corepack       0.19.0
              nodejs:
                Installed: 18.18.2-1nodesource1
                Candidate: 18.18.2-1nodesource1
                Version table:
               *** 18.18.2-1nodesource1 1001
                      500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                      100 /var/lib/dpkg/status
                   18.18.1-1nodesource1 1001
                   18.18.0-1nodesource1 1001
                   18.17.1-1nodesource1 1001
                   18.17.0-1nodesource1 1001
                   18.16.1-1nodesource1 1001
                   18.16.0-1nodesource1 1001
                   18.15.0-1nodesource1 1001
                   18.14.2-1nodesource1 1001
                   18.14.1-1nodesource1 1001
                   18.14.0-1nodesource1 1001
                   18.13.0-1nodesource1 1001
                   18.12.0-1nodesource1 1001
                   18.11.0-1nodesource1 1001
                   18.10.0-1nodesource1 1001
                   18.9.1-1nodesource1 1001
                   18.9.0-1nodesource1 1001
                   18.8.0-1nodesource1 1001
                   18.7.0-1nodesource1 1001
                   18.6.0-1nodesource1 1001
                   18.5.0-1nodesource1 1001
                   18.4.0-1nodesource1 1001
                   18.3.0-1nodesource1 1001
                   18.2.0-1nodesource1 1001
                   18.1.0-1nodesource1 1001
                   18.0.0-1nodesource1 1001
                   10.24.0~dfsg-1~deb10u3 500
                      500 http://security.debian.org/debian-security buster/updates/main amd64 Packages
                   10.24.0~dfsg-1~deb10u1 500
                      500 http://deb.debian.org/debian buster/main amd64 Packages
              No problems detected
              Errors in npm tree:
              *** ioBroker-Installation ***
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              Core adapters versions
              js-controller:  5.0.16
              admin:          6.12.0
              javascript:     7.1.4
              Adapters from github:   11
              Adapter State
              + system.adapter.admin.0                  : admin                 : IoBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                system.adapter.alias-manager.0          : alias-manager         : IoBroker                                 - disabled
              + system.adapter.backitup.0               : backitup              : IoBroker                                 -  enabled
              + system.adapter.device-watcher.0         : device-watcher        : IoBroker                                 -  enabled
              + system.adapter.discovery.0              : discovery             : IoBroker                                 -  enabled
              + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: IoBroker                                 -  enabled
              + system.adapter.enigma2.0                : enigma2               : IoBroker                                 -  enabled
              + system.adapter.enigma2.1                : enigma2               : IoBroker                                 -  enabled
              + system.adapter.enigma2.2                : enigma2               : IoBroker                                 -  enabled
                system.adapter.feiertage.0              : feiertage             : IoBroker                                 -  enabled
                system.adapter.flot.0                   : flot                  : IoBroker                                 - disabled
              + system.adapter.followthesun.0           : followthesun          : IoBroker                                 -  enabled
              + system.adapter.fullybrowser.0           : fullybrowser          : IoBroker                                 -  enabled
              + system.adapter.google-sharedlocations.0 : google-sharedlocations: IoBroker                                 -  enabled
              + system.adapter.hm-rega.0                : hm-rega               : IoBroker                                 -  enabled
              + system.adapter.hm-rpc.0                 : hm-rpc                : IoBroker                                 -  enabled, port: 0
              + system.adapter.hm-rpc.1                 : hm-rpc                : IoBroker                                 -  enabled, port: 0
              + system.adapter.hm-rpc.2                 : hm-rpc                : IoBroker                                 -  enabled, port: 0
              + system.adapter.hm-rpc.3                 : hm-rpc                : IoBroker                                 -  enabled, port: 0
                system.adapter.ical.0                   : ical                  : IoBroker                                 -  enabled
                system.adapter.icons-mfd-png.0          : icons-mfd-png         : IoBroker                                 - disabled
              + system.adapter.info.0                   : info                  : IoBroker                                 -  enabled
              + system.adapter.javascript.0             : javascript            : IoBroker                                 -  enabled
              + system.adapter.logparser.0              : logparser             : IoBroker                                 -  enabled
              + system.adapter.lovelace.0               : lovelace              : IoBroker                                 -  enabled, port: 8091, bind: 192.168.1.251, run as: admin
              + system.adapter.meater.0                 : meater                : IoBroker                                 -  enabled
              + system.adapter.mercedesme.0             : mercedesme            : IoBroker                                 -  enabled
              + system.adapter.mihome-vacuum.0          : mihome-vacuum         : IoBroker                                 -  enabled, port: 54321
              + system.adapter.omada.0                  : omada                 : IoBroker                                 -  enabled, port: 8043
                system.adapter.onvif.0                  : onvif                 : IoBroker                                 - disabled, port: 80, 7575, 8000, 8080, 8081, 8899
              + system.adapter.ping.0                   : ping                  : IoBroker                                 -  enabled
              + system.adapter.proxmox.0                : proxmox               : IoBroker                                 -  enabled, port: 8006
                system.adapter.roborock.0               : roborock              : IoBroker                                 - disabled
              + system.adapter.sayit.0                  : sayit                 : IoBroker                                 -  enabled
              + system.adapter.shelly.1                 : shelly                : IoBroker                                 -  enabled, port: 2023, bind: 0.0.0.0
              + system.adapter.sia.0                    : sia                   : IoBroker                                 -  enabled, port: 50001, bind: 0.0.0.0
              + system.adapter.sonos.0                  : sonos                 : IoBroker                                 -  enabled
              + system.adapter.sony-bravia.0            : sony-bravia           : IoBroker                                 -  enabled
              + system.adapter.sourceanalytix.0         : sourceanalytix        : IoBroker                                 -  enabled
              + system.adapter.sql.0                    : sql                   : IoBroker                                 -  enabled, port: 3306
              + system.adapter.synochat.0               : synochat              : IoBroker                                 -  enabled
              + system.adapter.synology.0               : synology              : IoBroker                                 -  enabled, port: 5000
              + system.adapter.tankerkoenig.0           : tankerkoenig          : IoBroker                                 -  enabled
              + system.adapter.telegram.0               : telegram              : IoBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
              + system.adapter.telegram.1               : telegram              : IoBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
              + system.adapter.telegram.2               : telegram              : IoBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
              + system.adapter.tr-064.0                 : tr-064                : IoBroker                                 -  enabled
              + system.adapter.trashschedule.0          : trashschedule         : IoBroker                                 -  enabled
              + system.adapter.upnp.0                   : upnp                  : IoBroker                                 -  enabled
              + system.adapter.viessmannapi.0           : viessmannapi          : IoBroker                                 -  enabled
                system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : IoBroker                                 - disabled
              + system.adapter.vis-inventwo.0           : vis-inventwo          : IoBroker                                 -  enabled
                system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : IoBroker                                 - disabled
                system.adapter.vis-metro.0              : vis-metro             : IoBroker                                 - disabled
                system.adapter.vis-players.0            : vis-players           : IoBroker                                 - disabled
                system.adapter.vis-plumb.0              : vis-plumb             : IoBroker                                 - disabled
                system.adapter.vis-timeandweather.0     : vis-timeandweather    : IoBroker                                 - disabled
                system.adapter.vis.0                    : vis                   : IoBroker                                 -  enabled
              + system.adapter.web.0                    : web                   : IoBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
              + instance is alive
              ioBroker-Repositories
              Active repo(s): stable
              Installed ioBroker-Instances
              Used repository: stable
              Adapter    "admin"        : 6.12.0   , installed 6.12.0
              Adapter    "backitup"     : 2.8.7    , installed 2.8.7
              Adapter    "coronavirus-statistics": 0.8.7, installed 0.8.7
              Adapter    "device-watcher": 2.9.4   , installed 2.9.4
              Adapter    "enigma2"      : 2.0.5    , installed 2.0.5
              Adapter    "eventlist"    : 2.0.0    , installed 2.0.0
              Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
              Adapter    "followthesun" : 0.4.2    , installed 0.4.2
              Adapter    "fullybrowser" : 3.0.6    , installed 3.0.6
              Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
              Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
              Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
              Adapter    "javascript"   : 7.1.4    , installed 7.1.4
              Controller "js-controller": 5.0.16   , installed 5.0.16
              Adapter    "logparser"    : 2.2.0    , installed 2.2.0
              Adapter    "lovelace"     : 3.0.1    , installed 3.0.1
              Adapter    "meater"       : 1.0.2    , installed 1.0.2
              Adapter    "mercedesme"   : 0.1.1    , installed 0.1.1
              Adapter    "mihome-vacuum": 4.1.0    , installed 4.1.0
              Adapter    "onvif"        : 1.1.1    , installed 1.1.1
              Adapter    "proxmox"      : 2.2.1    , installed 2.2.1
              Adapter    "roborock"     : 0.4.4    , installed 0.4.4
              Adapter    "sayit"        : 3.0.5    , installed 3.0.5
              Adapter    "shelly"       : 6.6.1    , installed 6.6.1
              Adapter    "sia"          : 1.0.4    , installed 1.0.4
              Adapter    "socketio"     : 6.5.5    , installed 6.5.5
              Adapter    "sonos"        : 3.0.0    , installed 3.0.0
              Adapter    "sony-bravia"  : 1.0.9    , installed 1.0.9
              Adapter    "sql"          : 2.2.0    , installed 2.2.0
              Adapter    "synochat"     : 1.3.1    , installed 1.3.1
              Adapter    "synology"     : 3.0.1    , installed 3.0.1
              Adapter    "telegram"     : 2.0.1    , installed 2.0.1
              Adapter    "trashschedule": 2.3.0    , installed 2.3.0
              Adapter    "upnp"         : 1.0.21   , installed 1.0.21
              Adapter    "viessmannapi" : 2.3.0    , installed 2.3.0
              Adapter    "vis"          : 1.4.16   , installed 1.4.16
              Adapter    "web"          : 6.1.10   , installed 6.1.10
              Adapter    "ws"           : 2.5.8    , installed 2.5.8
              Objects and States
              Objects:        30217
              States:         24890
              Hit:1 http://deb.debian.org/debian buster InRelease
              Hit:2 http://deb.debian.org/debian buster-updates InRelease
              Hit:3 http://security.debian.org/debian-security buster/updates InRelease
              Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
              Reading package lists...
              Pending Updates: 0
              *** Listening Ports ***
              tcp        0      0 192.168.1.251:42010     0.0.0.0:*               LISTEN      1001       42089991   4473/io.hm-rpc.1
              tcp        0      0 192.168.1.251:8091      0.0.0.0:*               LISTEN      1001       42092665   5196/io.lovelace.0
              tcp        0      0 192.168.1.251:8701      0.0.0.0:*               LISTEN      1001       42088993   4503/io.hm-rpc.3
              tcp        0      0 0.0.0.0:2023            0.0.0.0:*               LISTEN      1001       42089126   4632/io.shelly.1
              tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       42088726   4305/iobroker.js-co
              tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       42090513   4305/iobroker.js-co
              tcp        0      0 192.168.1.251:49292     0.0.0.0:*               LISTEN      1001       42090005   4488/io.hm-rpc.2
              tcp        0      0 0.0.0.0:5005            0.0.0.0:*               LISTEN      0          5652559    12204/node
              tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          12300      1/init
              tcp        0      0 0.0.0.0:50001           0.0.0.0:*               LISTEN      1001       42093859   5245/io.sia.0
              tcp        0      0 192.168.1.251:42001     0.0.0.0:*               LISTEN      1001       42088247   4458/io.hm-rpc.0
              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14888      400/sshd
              tcp6       0      0 :::8000                 :::*                    LISTEN      1001       42096728   5308/io.upnp.0
              tcp6       0      0 :::3500                 :::*                    LISTEN      0          5652562    12204/node
              tcp6       0      0 :::3501                 :::*                    LISTEN      1001       42088329   4566/io.sonos.0
              tcp6       0      0 :::111                  :::*                    LISTEN      0          2523       1/init
              tcp6       0      0 :::8081                 :::*                    LISTEN      1001       42088772   4326/io.admin.0
              tcp6       0      0 :::8082                 :::*                    LISTEN      1001       42092359   5372/io.web.0
              tcp6       0      0 :::22                   :::*                    LISTEN      0          14890      400/sshd
              tcp6       0      0 :::3000                 :::*                    LISTEN      1001       42095759   5533/io.fullybrowse
              udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       42090843   4533/io.mihome-vacu
              udp        0      0 192.168.1.251:5353      0.0.0.0:*                           1001       42090232   4616/io.tr-064.0
              udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          12301      1/init
              udp        0      0 0.0.0.0:50001           0.0.0.0:*                           1001       42093860   5245/io.sia.0
              udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       42092344   5308/io.upnp.0
              udp        0      0 0.0.0.0:42883           0.0.0.0:*                           1001       42094828   5308/io.upnp.0
              udp6       0      0 :::111                  :::*                                0          2526       1/init
              2023-11-20 13:33:20.553  - info: host.IoBroker "system.adapter.onvif.0" disabled
              2023-11-20 13:33:26.814  - error: onvif.0 (5601) adapter disabled
              2023-11-20 13:33:26.826  - warn: javascript.0 (4353) getState "system.adapter.onvif.0.cpu" not found (3)
              2023-11-20 13:33:26.827  - warn: javascript.0 (4353)     at tabelle_generieren (script.js.common.0_userdata_0_.Home.Status.Adapter.adapterstatus:56:20)
              2023-11-20 13:33:26.827  - warn: javascript.0 (4353)     at Object.<anonymous> (script.js.common.0_userdata_0_.Home.Status.Adapter.adapterstatus:92:3)
              2023-11-20 13:33:26.827  - warn: javascript.0 (4353) getState "system.adapter.onvif.0.memHeapUsed" not found (3)
              2023-11-20 13:33:26.827  - warn: javascript.0 (4353)     at tabelle_generieren (script.js.common.0_userdata_0_.Home.Status.Adapter.adapterstatus:61:20)
              2023-11-20 13:33:26.861  - warn: onvif.0 (5601) Terminated (NO_ADAPTER_CONFIG_FOUND): Without reason
              2023-11-20 13:33:27.457  - error: host.IoBroker instance system.adapter.onvif.0 terminated with code 3 (NO_ADAPTER_CONFIG_FOUND)
              2023-11-20 13:33:27.458  - info: host.IoBroker Do not restart adapter system.adapter.onvif.0 because disabled or deleted
              2023-11-20 13:33:34.843  - info: mihome-vacuum.0 (4533) create states for mop
              2023-11-20 13:33:34.846  - info: mihome-vacuum.0 (4533) change states from State control.fan_power
              2023-11-20 13:33:34.846  - info: mihome-vacuum.0 (4533) create states for water box
              2023-11-20 13:33:34.850  - info: mihome-vacuum.0 (4533) create states for water box mode
              2023-11-20 13:33:34.922  - info: mihome-vacuum.0 (4533) change states from State control.fan_power mihome-vacuum.0.rooms.218001011242.roomFanPower
              2023-11-20 13:33:34.922  - info: mihome-vacuum.0 (4533) change states from State control.fan_power mihome-vacuum.0.rooms.218001011304.roomFanPower
              2023-11-20 13:33:34.923  - info: mihome-vacuum.0 (4533) change states from State control.fan_power mihome-vacuum.0.rooms.218001011305.roomFanPower
              2023-11-20 13:33:34.923  - info: mihome-vacuum.0 (4533) change states from State control.fan_power mihome-vacuum.0.rooms.room1.roomFanPower
              2023-11-20 13:33:34.923  - info: mihome-vacuum.0 (4533) change states from State control.fan_power mihome-vacuum.0.rooms.room16.roomFanPower
              2023-11-20 13:33:34.924  - info: mihome-vacuum.0 (4533) change states from State control.fan_power mihome-vacuum.0.rooms.room17.roomFanPower
              2023-11-20 13:33:34.924  - info: mihome-vacuum.0 (4533) change states from State control.fan_power mihome-vacuum.0.rooms.room18.roomFanPower
              2023-11-20 13:33:34.924  - info: mihome-vacuum.0 (4533) change states from State control.fan_power mihome-vacuum.0.rooms.room19.roomFanPower
              2023-11-20 13:33:34.924  - info: mihome-vacuum.0 (4533) change states from State control.fan_power mihome-vacuum.0.rooms.room2.roomFanPower
              2023-11-20 13:33:34.924  - info: mihome-vacuum.0 (4533) change states from State control.fan_power mihome-vacuum.0.rooms.room20.roomFanPower
                Thomas Braun Most Active @XBiT last edited by
                @xbit sagte in Test Adapter onvif camera v1.0.0:
                buster
                Muss durch ein lebendes Release ersetzt werden.
                Deutlich zu viele GitHub-Installationen. Du führst für alle diese Adapter Alpha-Testings durch?
                Wage ich zu bezweifeln.
                • XBiT
                  Okay auf bullseye kann ich wechseln aber die 11 git Adapter kommen doch schnell zusammen (hier der Adapter, Lovelace, energiefluss-erweiter usw.)...
                  Werde berichten ob der Adapter danach läuft.
                    Ich habe auch buster. Ist bullseye denn jetzt Voraussetzung für iobroker?
                    Alle anderen Adapter laufen reibungslos.
                      @xbit
                      Bookworm / Debian 12 ist das aktuelle Stable-Release.
                        Ein stabiles Release ist allgemeine Voraussetzung. Der Hersteller hat Debian 10 halt abgekündigt, da passiert nix mehr.
                        • XBiT
                          Update ist durch
                          stephan@IoBroker:~$ cat /etc/os-release
                          PRETTY_NAME="Debian GNU/Linux 12 (bookworm)"
                          NAME="Debian GNU/Linux"
                          VERSION_ID="12"
                          VERSION="12 (bookworm)"
                          VERSION_CODENAME=bookworm
                          ID=debian
                          HOME_URL="https://www.debian.org/"
                          SUPPORT_URL="https://www.debian.org/support"
                          BUG_REPORT_URL="https://bugs.debian.org/"
                          aber leider startet der Adapter noch nicht.
                            @tombox
                            So Antwort von Ctronics ist da .
                            Die Kamera unterstützt nur ONVIF Profil S , damit werden keine Events übertragen.
                            Naja ist nicht schlimm die Kamera ist ja auch schon 4 Jahre alt.
                            Danke für die Hilfe
                            Knusterus
                            • David G.
                              Wollte mir den Adapter auch gerade mal anschauen.
                              Allerdings möchte die Installation nicht durchlaufen.
                              $ iobroker url https://github.com/iobroker-community-adapters/ioBroker.onvif --host iobroker --debug
                              install iobroker-community-adapters/ioBroker.onvif#4032e14fe6267e5fd2e13857bd36a06378007c7f
                              NPM version: 10.2.3Installing iobroker-community-adapters/ioBroker.onvif#4032e14fe6267e5fd2e13857bd36a06378007c7f... (System call)
                              npm WARN skipping integrity check for git dependency ssh://git@github.com/iobroker-community-adapters/ioBroker.onvif.git
                              npm ERR! code 2
                              host.iobroker Cannot install iobroker-community-adapters/ioBroker.onvif#4032e14fe6267e5fd2e13857bd36a06378007c7f: 2
                              ERROR: Process exited with code 25
                              Skript v.2023-10-10
                              *** BASE SYSTEM ***                                            Static hostname: iobroker
                                       Chassis: vm 🖴
                                Virtualization: kvm
                              Operating System: Debian GNU/Linux 12 (bookworm)                        Kernel: Linux 6.1.0-13-amd64
                               Hardware Vendor: QEMU
                                Hardware Model: Standard PC _i440FX + PIIX, 1996_
                              Firmware Version: rel-1.16.2-0-gea1b7a073390-prebuilt.qemu.org
                              model name      : 12th Gen Intel(R) Core(TM) i3-12100
                              Docker          : false
                              Kernel          : x86_64
                              Userland        : amd64
                               16:16:13 up 6 days,  4:40,  2 users,  load average: 0.84, 0.96, 0.64
                              CPU threads: 1
                                             Local time: Thu 2023-12-28 16:16:13 CET
                                         Universal time: Thu 2023-12-28 15:16:13 UTC
                                               RTC time: Thu 2023-12-28 15:16:13
                                            NTP service: active
                                        RTC in local TZ: no
                              iobroker
                              /home/iobroker
                              iobroker tty dialout cdrom floppy sudo audio dip video plugdev users netdev
                              X-Server:       false
                              Desktop:
                              Terminal:       tty
                              *** MEMORY ***
                              Mem:            7.3G        4.0G        2.1G        487K        1.5G        3.3G
                              Swap:           1.0G        520K        1.0G
                              Total:          8.3G        4.0G        3.1G
                                       6933 M total memory
                                       3787 M used memory
                                        744 M active memory
                                       3703 M inactive memory
                                       1995 M free memory
                                        250 M buffer memory
                                       1195 M swap cache
                                        974 M total swap
                                          0 M used swap
                                        974 M free swap
                              *** FILESYSTEM ***
                              udev           devtmpfs  3.4G     0  3.4G   0% /dev
                              tmpfs          tmpfs     694M  520K  693M   1% /run
                              /dev/sda1      ext4       31G  9.3G   20G  32% /
                              tmpfs          tmpfs     3.4G     0  3.4G   0% /dev/shm
                              tmpfs          tmpfs     694M     0  694M   0% /run/user/1000
                              [sudo] password for iobroker:
                              [Fri Dec 22 11:35:23 2023] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
                              [Fri Dec 22 11:35:23 2023] EXT4-fs (sda1): re-mounted. Quota mode: none.
                              /var:
                              1.3G    /var/
                              575M    /var/log
                              559M    /var/log/journal/c2f62aa20c614a09b8a2622bde83939a
                              531M    /var/cache
                              Archived and active journals take up 79.1M in the file system.
                              1.1G    /opt/iobroker/backups/
                              1.1G    /opt/iobroker/iobroker-data/
                              717M    /opt/iobroker/iobroker-data/files
                              278M    /opt/iobroker/iobroker-data/backup-objects
                              153M    /opt/iobroker/iobroker-data/files/vis-2
                              111M    /opt/iobroker/iobroker-data/files/0_userdata.0/SqlBackup
                              111M    /opt/iobroker/iobroker-data/files/0_userdata.0/SqlBackup/sql.sql
                              35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
                              34M     /opt/iobroker/iobroker-data/states.jsonl
                              33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
                              USB-Devices by-id:
                              /dev/serial/by-id/usb-Silicon_Labs_CP2102N_USB_to_UART_Bridge_Controller_e28d28580194eb11a604aa5b3d98b6d1-if00-port0
                              /usr/bin/nodejs         v18.19.0
                              /usr/bin/node           v18.19.0
                              /usr/bin/npm            10.2.3
                              /usr/bin/npx            10.2.3
                              /usr/bin/corepack       0.22.0
                              nodejs:
                                Installed: 18.19.0-1nodesource1
                                Candidate: 18.19.0-1nodesource1
                                Version table:
                                   18.19.0+dfsg-6~deb12u1 500
                                      500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
                               *** 18.19.0-1nodesource1 1001
                                   18.13.0+dfsg1-1 500
                                      500 http://deb.debian.org/debian bookworm/main amd64 Packages
                              Errors in npm tree:
                              ioBroker Status
                              Objects type: jsonl
                              States  type: jsonl
                              js-controller:  5.0.12
                              admin:          6.12.0
                              javascript:     7.1.6
                              Adapters from github:   8
                              Adapter State
                              + system.adapter.accuweather.0            : accuweather           : iobroker                                 -  enabled
                              + system.adapter.adb.0                    : adb                   : iobroker                                 -  enabled
                              + system.adapter.adguard.0                : adguard               : iobroker                                 -  enabled
                              + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                                system.adapter.alias-manager.0          : alias-manager         : iobroker                                 - disabled
                              + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                                system.adapter.birthdays.0              : birthdays             : iobroker                                 - disabled
                                system.adapter.bosesoundtouch.0         : bosesoundtouch        : iobroker                                 - disabled
                              + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
                              + system.adapter.countdown.0              : countdown             : iobroker                                 -  enabled
                                system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
                                system.adapter.daswetter.1              : daswetter             : iobroker                                 - disabled
                                system.adapter.device-reminder.0        : device-reminder       : iobroker                                 - disabled
                              + system.adapter.device-watcher.0         : device-watcher        : iobroker                                 -  enabled
                                system.adapter.devices.0                : devices               : iobroker                                 - disabled
                                system.adapter.discovery.0              : discovery             : iobroker                                 - disabled
                              + system.adapter.echarts.0                : echarts               : iobroker                                 -  enabled
                              + system.adapter.email.0                  : email                 : iobroker                                 -  enabled
                              + system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker                                 -  enabled
                                system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
                                system.adapter.flot.0                   : flot                  : iobroker                                 - disabled
                              + system.adapter.google-sharedlocations.0 : google-sharedlocations: iobroker                                 -  enabled
                                system.adapter.hass.0                   : hass                  : iobroker                                 - disabled, port: 8123
                              + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
                              + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
                              + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
                              + system.adapter.hmip.0                   : hmip                  : iobroker                                 -  enabled
                                system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
                                system.adapter.ical.1                   : ical                  : iobroker                                 -  enabled
                                system.adapter.iceroad.0                : iceroad               : iobroker                                 - disabled
                                system.adapter.icons-icons8.0           : icons-icons8          : iobroker                                 - disabled
                                system.adapter.icons-material-png.0     : icons-material-png    : iobroker                                 - disabled
                              + system.adapter.imap.0                   : imap                  : iobroker                                 -  enabled
                              + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
                              + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
                              + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                              + system.adapter.linux-control.0          : linux-control         : iobroker                                 -  enabled
                                system.adapter.logparser.0              : logparser             : iobroker                                 - disabled
                              + system.adapter.lovelace.0               : lovelace              : iobroker                                 -  enabled, port: 8091, bind: 0.0.0.0, run as: admin
                              + system.adapter.lovelace.1               : lovelace              : iobroker                                 -  enabled, port: 8092, bind: 0.0.0.0, run as: admin
                              + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1884, bind: 0.0.0.0
                                system.adapter.nina.0                   : nina                  : iobroker                                 - disabled
                              + system.adapter.notification-manager.0   : notification-manager  : iobroker                                 -  enabled
                              + system.adapter.nut.0                    : nut                   : iobroker                                 -  enabled
                                system.adapter.openweathermap.0         : openweathermap        : iobroker                                 -  enabled
                                system.adapter.parcel.0                 : parcel                : iobroker                                 - disabled
                                system.adapter.parcel.1                 : parcel                : iobroker                                 - disabled
                                system.adapter.parser.0                 : parser                : iobroker                                 - disabled
                              + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
                              + system.adapter.places.0                 : places                : iobroker                                 -  enabled
                              + system.adapter.proxmox.0                : proxmox               : iobroker                                 -  enabled, port: 8006
                                system.adapter.proxy.0                  : proxy                 : iobroker                                 - disabled
                                system.adapter.pushover.0               : pushover              : iobroker                                 - disabled
                              + system.adapter.reolink.0                : reolink               : iobroker                                 -  enabled
                                system.adapter.rest-api.0               : rest-api              : iobroker                                 - disabled, port: 8093, bind: 0.0.0.0, run as: admin
                                system.adapter.roborock.0               : roborock              : iobroker                                 - disabled
                                system.adapter.rpi2.0                   : rpi2                  : iobroker                                 - disabled
                                system.adapter.sayit.0                  : sayit                 : iobroker                                 - disabled
                              + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1888, bind: 192.168.99.33
                              + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                              + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
                              + system.adapter.sony-bravia.0            : sony-bravia           : iobroker                                 -  enabled
                              + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
                              + system.adapter.sql.0                    : sql                   : iobroker                                 -  enabled, port: 3306
                              + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
                                system.adapter.telegram-menu.0          : telegram-menu         : iobroker                                 - disabled
                              + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                                system.adapter.telegram.1               : telegram              : iobroker                                 - disabled, port: 8443, bind: 0.0.0.0
                              + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
                              + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
                              + system.adapter.upnp.0                   : upnp                  : iobroker                                 -  enabled
                                system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : iobroker                                 - disabled
                                system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : iobroker                                 - disabled
                                system.adapter.vis-2-widgets-jaeger-design.0: vis-2-widgets-jaeger-design: iobroker                                 - disabled
                                system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: iobroker                                 - disabled
                                system.adapter.vis-2.0                  : vis-2                 : iobroker                                 - disabled
                                system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 - disabled
                                system.adapter.vw-connect.0             : vw-connect            : iobroker                                 - disabled
                              + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0 (SSL), run as: admin
                              + system.adapter.web.1                    : web                   : iobroker                                 -  enabled, port: 8083, bind: 0.0.0.0, run as: admin
                              + system.adapter.wireguard.0              : wireguard             : iobroker                                 -  enabled
                              + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: /dev/serial/by-id/usb-Silicon_Labs_CP2102N_USB_to_UART_Bridge_Controller_e28d28580194eb11a604aa5b3d98b6d1-if00-port0
                              + instance is alive
                              Stable (default): http://download.iobroker.net/sources-dist.json
                              Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
                              Active repo(s): Stable (default)
                              Used repository: Stable (default)
                              Adapter    "accuweather"  : 1.3.2    , installed 1.3.2
                              Adapter    "adb"          : 0.0.7    , installed 0.0.7
                              Adapter    "adguard"      : 0.0.8    , installed 0.0.8
                              Adapter    "backitup"     : 2.9.8    , installed 2.8.7  [Updatable]
                              Adapter    "birthdays"    : 2.4.1    , installed 2.4.1
                              Adapter    "bosesoundtouch": 0.10.3  , installed 0.10.3
                              Adapter    "countdown"    : 2.2.0    , installed 2.2.0
                              Adapter    "daswetter"    : 3.1.11   , installed 3.1.11
                              Adapter    "device-reminder": 3.0.0  , installed 3.0.0
                              Adapter    "device-watcher": 2.9.6   , installed 2.9.6
                              Adapter    "echarts"      : 1.5.4    , installed 1.5.4
                              Adapter    "email"        : 1.2.1    , installed 1.2.0  [Updatable]
                              Adapter    "fb-checkpresence": 1.2.2 , installed 1.2.2
                              Adapter    "hass"         : 1.4.0    , installed 1.4.0
                              Adapter    "hmip"         : 1.20.0   , installed 1.20.0
                              Adapter    "iceroad"      : 1.2.1    , installed 1.2.1
                              Adapter    "icons-material-png": 0.1.0, installed 0.1.1
                              Adapter    "imap"         : 0.1.1    , installed 0.1.1
                              Adapter    "iot"          : 2.0.11   , installed 2.0.11
                              Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
                              Adapter    "javascript"   : 7.1.6    , installed 7.1.6
                              Controller "js-controller": 5.0.17   , installed 5.0.12 [Updatable]
                              Adapter    "linux-control": 1.1.5    , installed 1.1.5
                              Adapter    "lovelace"     : 3.0.1    , installed 4.0.12
                              Adapter    "moma"         : 1.2.9    , installed 1.2.9
                              Adapter    "mqtt"         : 5.1.0    , installed 5.1.0
                              Adapter    "nina"         : 0.0.25   , installed 0.0.25
                              Adapter    "notification-manager": 1.0.0, installed 1.0.0
                              Adapter    "nut"          : 1.6.0    , installed 1.6.0
                              Adapter    "openweathermap": 0.4.5   , installed 0.4.5
                              Adapter    "parcel"       : 0.0.27   , installed 0.1.1
                              Adapter    "parser"       : 2.0.7    , installed 2.0.7
                              Adapter    "places"       : 1.1.2    , installed 1.1.2
                              Adapter    "proxmox"      : 2.2.2    , installed 2.2.2
                              Adapter    "proxy"        : 1.3.2    , installed 1.3.2
                              Adapter    "pushover"     : 3.0.6    , installed 3.0.6
                              Adapter    "reolink"      : 1.0.2    , installed 1.0.2
                              Adapter    "rest-api"     : 1.1.0    , installed 1.1.0
                              Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
                              Adapter    "telegram"     : 3.0.1    , installed 3.0.0  [Updatable]
                              Adapter    "telegram-menu": 1.5.1    , installed 0.8.5  [Updatable]
                              Adapter    "vw-connect"   : 0.0.67   , installed 0.0.67
                              Adapter    "wireguard"    : 1.6.1    , installed 1.6.1
                              Adapter    "zigbee"       : 1.8.25   , installed 1.8.24 [Updatable]
                              Objects and States
                              Objects:        32736
                              States:         29860
                              Hit:1 http://security.debian.org/debian-security bookworm-security InRelease
                              Hit:2 http://deb.debian.org/debian bookworm InRelease
                              Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
                              Hit:5 https://packagecloud.io/ookla/speedtest-cli/debian bookworm InRelease
                              Pending Updates: 6
                              tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       10986669   1474482/iobroker.js
                              tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       10986662   1474482/iobroker.js
                              tcp        0      0 127.0.0.1:5037          0.0.0.0:*               LISTEN      1000       10989477   1475102/adb
                              tcp        0      0 192.168.99.33:42010     0.0.0.0:*               LISTEN      1000       10987316   1474629/io.hm-rpc.0
                              tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1000       10988468   1474941/io.sonoff.0
                              tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1000       10987646   1474704/io.mqtt.0
                              tcp        0      0 192.168.99.33:1888      0.0.0.0:*               LISTEN      1000       10988338   1474919/io.shelly.0
                              tcp        0      0 192.168.99.33:49292     0.0.0.0:*               LISTEN      1000       10987374   1474644/io.hm-rpc.1
                              tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          13251      1/init
                              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          16486      534/sshd: /usr/sbin
                              tcp6       0      0 :::8091                 :::*                    LISTEN      1000       10993483   1476066/io.lovelace
                              tcp6       0      0 :::8092                 :::*                    LISTEN      1000       10993587   1476106/io.lovelace
                              tcp6       0      0 :::8083                 :::*                    LISTEN      1000       10994313   1476222/io.web.1
                              tcp6       0      0 :::8082                 :::*                    LISTEN      1000       10994197   1476204/io.web.0
                              tcp6       0      0 :::8081                 :::*                    LISTEN      1000       10986790   1474500/io.admin.0
                              tcp6       0      0 :::8087                 :::*                    LISTEN      1000       10993665   1476123/io.simple-a
                              tcp6       0      0 :::111                  :::*                    LISTEN      0          13257      1/init
                              tcp6       0      0 :::22                   :::*                    LISTEN      0          16500      534/sshd: /usr/sbin
                              udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       10995213   1476298/io.upnp.0
                              udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14482      425/dhclient
                              udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          13254      1/init
                              udp        0      0 192.168.99.33:5353      0.0.0.0:*                           1000       10989088   1474991/io.tr-064.0
                              udp6       0      0 :::111                  :::*                                0          13260      1/init
                              2023-12-28 16:13:16.540  - info: fb-checkpresence.0 (1476275) createFbDeviceObjects finished successfully
                              2023-12-28 16:13:16.541  - info: fb-checkpresence.0 (1476275) states successfully subscribed
                              2023-12-28 16:13:16.541  - info: fb-checkpresence.0 (1476275) loop successfully started
                              2023-12-28 16:14:17.666  - info: host.iobroker iobroker url https://github.com/iobroker-community-adapters/ioBroker.onvif --host iobroker --debug
                              2023-12-28 16:14:18.869  - info: host.iobroker iobroker install iobroker-community-adapters/ioBroker.onvif#4032e14fe6267e5fd2e13857bd36a06378007c7f
                              2023-12-28 16:14:19.270  - info: host.iobroker iobroker NPM version: 10.2.3Installing iobroker-community-adapters/ioBroker.onvif#4032e14fe6267e5fd2e13857bd36a06378007c7f... (System call)2023-12-28 16:14:27.410  - info: host.iobroker iobroker npm WARN skipping integrity check for git dependency ssh://git@github.com/iobroker-community-adapters/ioBroker.onvif.git
                              2023-12-28 16:14:31.684  - info: host.iobroker iobroker npm ERR! code 2
                              2023-12-28 16:14:31.686  - info: host.iobroker iobroker npm ERR! path /opt/iobroker/node_modules/json2iob
                              2023-12-28 16:14:31.692  - info: host.iobroker iobroker npm ERR! command failed
                              2023-12-28 16:14:31.693  - info: host.iobroker iobroker npm ERR! command sh -c npm run build
                              2023-12-28 16:14:31.694  - info: host.iobroker iobroker npm ERR! > json2iob@2.6.0 build
                              2023-12-28 16:14:31.695  - info: host.iobroker iobroker npm ERR! > tsc
                              2023-12-28 16:14:31.696  - info: host.iobroker iobroker npm ERR!
                              2023-12-28 16:14:31.697  - info: host.iobroker iobroker npm ERR! error TS2688: Cannot find type definition file for 'bl'.
                              2023-12-28 16:14:31.698  - info: host.iobroker iobroker npm ERR!   The file is in the program because:
                              2023-12-28 16:14:31.699  - info: host.iobroker iobroker npm ERR!     Entry point for implicit type library 'bl'
                              2023-12-28 16:14:31.701  - info: host.iobroker iobroker
                              2023-12-28 16:14:31.702  - info: host.iobroker iobroker npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-12-28T15_14_19_468Z-debug-0.log
                              2023-12-28 16:14:31.749  - error: host.iobroker iobroker npm WARN skipping integrity check for git dependency ssh://git@github.com/iobroker-community-adapters/ioBroker.onvif.git npm ERR! code 2npm ERR! path /opt/iobroker/node_modules/json2iobnpm ERR! command failednpm ERR! command sh -c npm run buildnpm ERR! > json2iob@2.6.0 buildnpm ERR! > tscnpm ERR! npm ERR! error TS2688: Cannot find type definition file for 'bl'.npm ERR!   The file is in the program because:npm ERR!     Entry point for implicit type library 'bl'npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-12-28T15_14_19_Copy text starting here:
                              • wendy2702
                                @david-g
                                https://forum.iobroker.net/search?term=Error 25&in=titlesposts
                                  Thomas Braun Most Active @David G. last edited by Thomas Braun
                                  @david-g
                                  Hau die anderen Updates drauf. Insbesondere den js-controller.
                                  • David G.
                                    @wendy2702 sagte in Test Adapter onvif camera v1.0.0:
                                    @david-g
                                    Die Lösungen zu dem Problem sind so weit ich weiß in iob fix eingebaut.
                                    @thomas-braun sagte in Test Adapter onvif camera v1.0.0:
                                    @david-g
                                    Habe alles aktualisiert. Meldung bleibt identisch.
                                    Thomas Braun wendy2702 2 Replies Last reply Reply Quote 0
                                      @david-g sagte in Test Adapter onvif camera v1.0.0:
                                      Muss aber was individuelles bei dir sein, hier läuft es nämlich einwandfrei durch:
                                      echad@chet:~ $ iobroker url https://github.com/iobroker-community-adapters/ioBroker.onvif --debug
                                      NPM version: 10.2.4
                                      added 29 packages, removed 149 packages, and changed 1 package in 26s
                                      106 packages are looking for funding
                                        run `npm fund` for details
                                      upload [1] onvif.admin /opt/iobroker/node_modules/iobroker.onvif/admin/jsonConfig.json jsonConfig.json application/json
                                      upload [0] onvif.admin /opt/iobroker/node_modules/iobroker.onvif/admin/onvif.png onvif.png image/png
                                      echad@chet:~ $
                                      • wendy2702
                                        wendy2702 @David G. last edited by
                                        Ist das so? Dann habe ich das nicht mitbekommen.
                                        Kann aber auch nicht sehen das der Fix lief.
                                        • David G.
                                          David G. @wendy2702 last edited by
                                          Jepp,
                                          kann es leider nicht zitieren.
                                          Oh, muss ich versehentlich gelöscht haben, als ich das Ergebnis vom iob diag von der Kurz- zu Langfassung abgeändert habe...
                                          wendy2702 Thomas Braun 2 Replies Last reply Reply Quote 0
                                          • wendy2702
                                            @david-g OK.
                                            Da steht aber auch „sollte“ was für mich keine 100% Garantie ist das es auch wirklich dein spezielles Problem löst.
                                            341
                                            51905
