    4. Kein iobroker Backup mehr über BackitUp Adapter
      Laser @Marc Berg last edited by
      @marc-berg sagte in Kein iobroker Backup mehr über BackitUp Adapter:
      Ich habe die Token in Backitup und in influx eingetragen.
      Jetzt heißt der neu generierte Token- in influx und Backitup eingetragen:
      • Marc Berg
        Marc Berg Most Active @Laser last edited by Marc Berg
        @laser sagte in Kein iobroker Backup mehr über BackitUp Adapter:
        Das ist doch aber der Falsche. Du muss den Operator Token (siehe oben) eintragen.
        dann ist das hier dein Operator - Token:
        9RpnKWzJ2Vuq-Jg85pOljmMaF1PJP0YhAfXZcLYO7QRNUQtKUaV0ezcQeIpnmTR2K1Ve0YWl11lqKTsX2DvQvw==
          Laser @Marc Berg last edited by Laser
          @marc-berg OK. kENxxP6hxicSqtd1R1akRkvk1QF8F9xqW0fmydbvHhCoy5KpRIjFam_H-NxW6u4aKxwaXia4i-1CSqr70HH8kg==
          dieser Token muß in den Backitup und influx - Adapter eingetragen werden? Mache ich jetzt.
          Started iobroker ...
          [DEBUG] [mount] - mount activ... umount is started before mount!!
          [DEBUG] [mount] - umount successfully completed
          [DEBUG] [mount] - noserverino option: false
          [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=iobroker,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=2.0 //192.168.2.57/backup /opt/iobroker/backups"
          [DEBUG] [mount] - mount successfully completed
          [DEBUG] [mount] - done
          [DEBUG] [iobroker] - host.raspberrypi 3145 states saved
          [DEBUG] [iobroker] - host.raspberrypi 3839 objects saved
          [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2023_11_20-11_47_58_backupiobroker.tar.gz
          [DEBUG] [iobroker] - This backup can only be restored with js-controller version up from 4.1
          [DEBUG] [iobroker] - done
          [DEBUG] [influxDB] - InfluxDB-Backup started ...
          [DEBUG] [influxDB] - Start InfluxDB Backup ...
          [DEBUG] [influxDB] - InfluxDB Backup tmp directory created
          [DEBUG] [influxDB] - Try deleting the InfluxDB tmp directory: "/opt/iobroker/backups/influxDB_2023_11_20-11_48_11_backupiobroker"
          [DEBUG] [influxDB] - InfluxDB tmp directory "/opt/iobroker/backups/influxDB_2023_11_20-11_48_11_backupiobroker" successfully deleted
          [ERROR] [influxDB] - Error: Command failed: influx backup --bucket iobroker -t kENxxP6hxicSqtd1R1akRkvk1QF8F9xqW0fmydbvHhCoy5KpRIjFam_H-NxW6u4aKxwaXia4i-1CSqr70HH8kg== "/opt/iobroker/backups/influxDB_2023_11_20-11_48_11_backupiobroker"
          2023/11/20 11:48:11 INFO: Downloading metadata snapshot
          Error: failed to backup metadata: failed to download metadata snapshot: 401 Unauthorized: read:authorizations is unauthorized
          [DEBUG] [influxDB] - InfluxDB-Backup for is finish
          [DEBUG] [influxDB] - done
          [DEBUG] [cifs] - used copy path: /backup
          [DEBUG] [cifs] - done
          [ERROR] [clean] - Backup files not deleted from /opt/iobroker/backups because some errors.
          [DEBUG] [clean] - done
          [DEBUG] [telegram] - done
          [DEBUG] [historyHTML] - new history html values created
          [DEBUG] [historyHTML] - done
          [DEBUG] [historyJSON] - new history json values created
          [DEBUG] [historyJSON] - done
          [DEBUG] [umount] - mount activ, umount is started ...
          [DEBUG] [umount] - umount successfully completed
          [DEBUG] [umount] - done
          [EXIT] 0
          • Marc Berg
            Du willst mich jetzt vera.., oder?
            Ich hatte jetzt 3x geschrieben, dass dieser Token rein muss:
              @marc-berg ich kapiere es nicht! Wo nehme ich den her? Aus der Ausgabe von:
              influx auth list -t kENxxP6hxicSqtd1R1akRkvk1QF8F9xqW0fmydbvHhCoy5KpRIjFam_H-NxW6u4aKxwaXia4i-1CSqr70HH8kg== --json ?
              Da gibt es bei mir 4 Token:
              otto@raspberrypi:~ $ influx auth list -t kENxxP6hxicSqtd1R1akRkvk1QF8F9xqW0fmydbvHhCoy5KpRIjFam_H-NxW6u4aKxwaXia4i-1CSqr70HH8kg== --json
                              "id": "0b4721ccc9305000",
                              "description": "iobroker's Token",
                              "token": "9RpnKWzJ2Vuq-Jg85pOljmMaF1PJP0YhAfXZcLYO7QRNUQtKUaV0ezcQeIpnmTR2K1Ve0YWl11lqKTsX2DvQvw==",
                              "status": "active",
                              "userName": "iobroker",
                              "userID": "0b4721cca3305000",
                              "permissions": [
                                      "read:/authorizations",
                                      "write:/authorizations",
                                      "read:/buckets",
                                      "write:/buckets",
                                      "read:/dashboards",
                                      "write:/dashboards",
                                      "read:/orgs",
                                      "write:/orgs",
                                      "read:/sources",
                                      "write:/sources",
                                      "read:/tasks",
                                      "write:/tasks",
                                      "read:/telegrafs",
                                      "write:/telegrafs",
                                      "read:/users",
                                      "write:/users",
                                      "read:/variables",
                                      "write:/variables",
                                      "read:/scrapers",
                                      "write:/scrapers",
                                      "read:/secrets",
                                      "write:/secrets",
                                      "read:/labels",
                                      "write:/labels",
                                      "read:/views",
                                      "write:/views",
                                      "read:/documents",
                                      "write:/documents",
                                      "read:/notificationRules",
                                      "write:/notificationRules",
                                      "read:/notificationEndpoints",
                                      "write:/notificationEndpoints",
                                      "read:/checks",
                                      "write:/checks",
                                      "read:/dbrp",
                                      "write:/dbrp",
                                      "read:/notebooks",
                                      "write:/notebooks",
                                      "read:/annotations",
                                      "write:/annotations",
                                      "read:/remotes",
                                      "write:/remotes",
                                      "read:/replications",
                                      "write:/replications"
                              "id": "0b485bd1c75e4000",
                              "description": "onboarding-cliWizard-token-1685530468858",
                              "token": "zijB7piBzzSSLchg2TCyrp2MViRxSJ5_HQP_ynLZO_T8K6Wy-guPxh9uI75KjCKFKIhzTGhpSSeyMpp58Z_juw==",
                              "status": "active",
                              "permissions": [
                                      "read:orgs/56ed5fe7a100c804/annotations",
                                      "write:orgs/56ed5fe7a100c804/annotations",
                                      "read:orgs/56ed5fe7a100c804/authorizations",
                                      "write:orgs/56ed5fe7a100c804/authorizations",
                                      "read:orgs/56ed5fe7a100c804/buckets",
                                      "write:orgs/56ed5fe7a100c804/buckets",
                                      "read:orgs/56ed5fe7a100c804/checks",
                                      "write:orgs/56ed5fe7a100c804/checks",
                                      "read:orgs/56ed5fe7a100c804/dashboards",
                                      "write:orgs/56ed5fe7a100c804/dashboards",
                                      "read:orgs/56ed5fe7a100c804/dbrp",
                                      "write:orgs/56ed5fe7a100c804/dbrp",
                                      "read:orgs/56ed5fe7a100c804/documents",
                                      "write:orgs/56ed5fe7a100c804/documents",
                                      "read:orgs/56ed5fe7a100c804/labels",
                                      "write:orgs/56ed5fe7a100c804/labels",
                                      "read:orgs/56ed5fe7a100c804/notebooks",
                                      "write:orgs/56ed5fe7a100c804/notebooks",
                                      "read:orgs/56ed5fe7a100c804/notificationEndpoints",
                                      "write:orgs/56ed5fe7a100c804/notificationEndpoints",
                                      "read:orgs/56ed5fe7a100c804/notificationRules",
                                      "write:orgs/56ed5fe7a100c804/notificationRules",
                                      "read:/orgs/56ed5fe7a100c804",
                                      "read:orgs/56ed5fe7a100c804/remotes",
                                      "write:orgs/56ed5fe7a100c804/remotes",
                                      "read:orgs/56ed5fe7a100c804/replications",
                                      "write:orgs/56ed5fe7a100c804/replications",
                                      "read:orgs/56ed5fe7a100c804/scrapers",
                                      "write:orgs/56ed5fe7a100c804/scrapers",
                                      "read:orgs/56ed5fe7a100c804/secrets",
                                      "write:orgs/56ed5fe7a100c804/secrets",
                                      "read:orgs/56ed5fe7a100c804/sources",
                                      "write:orgs/56ed5fe7a100c804/sources",
                                      "read:orgs/56ed5fe7a100c804/tasks",
                                      "write:orgs/56ed5fe7a100c804/tasks",
                                      "read:orgs/56ed5fe7a100c804/telegrafs",
                                      "write:orgs/56ed5fe7a100c804/telegrafs",
                                      "read:/users/0b4721cca3305000",
                                      "write:/users/0b4721cca3305000",
                                      "read:orgs/56ed5fe7a100c804/variables",
                                      "write:orgs/56ed5fe7a100c804/variables",
                                      "read:orgs/56ed5fe7a100c804/views",
                                      "write:orgs/56ed5fe7a100c804/views"
                              "id": "0b4862a339de4000",
                              "description": "iobroker",
                              "token": "fPGvK9QsLi2jJWNN_q5ccAyETlJ9plh-1qxfgsxuOEPymu9SCsQVHI3j47j44UbAUfqMpv8_in5zeFDC8D2Q0Q==",
                              "status": "active",
                              "permissions": [
                              "id": "0c26fdf572986000",
                              "description": "onboarding-cliWizard-token-1700471139713",
                              "token": "oodzlogKQY9O0tCtNNDYiFxomFcAWJXjd-RTbC738Fkna1nzQiVXRjNVaKZDFt_lvWEYrZWhpUNIxsnMISQejg==",
                              "status": "active",
                              "permissions": [
                              "id": "0c271185effd8000",
                              "token": "kENxxP6hxicSqtd1R1akRkvk1QF8F9xqW0fmydbvHhCoy5KpRIjFam_H-NxW6u4aKxwaXia4i-1CSqr70HH8kg==",
                              "status": "active",
                              "permissions": [
              • Marc Berg
                Korrekt, das ist aber in dem Dokument, welches @simatec dir verlinkt hatte, sehr gut beschrieben.
                  @marc-berg
                  Der Erste Token der Ausgabe ist also immer der Richtige. Egal, wie viele ich dann noch generiere. Das steht im verlinkten Dok. so da, habe ich aber nicht richtig verstanden.
                  Mit diesem Token passiert auch etwas, geht aber nicht weiter. Es werden aber auch sehr viele tar.gz Dateien generiert.
                  Ich warte ab, was passiert...
                  [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2023_11_20-11_52_12_backupiobroker.tar.gz
                    Laser @Laser last edited by Laser
                    @Marc-Berg @simatec
                    Es werden jetzt im NAS sehr viele Dateien in einem neu angelegtem Verzeichnis generiert. Das dauert scheinbar lange.
                    Ich warte es ab und werde dann versuchen, auf dem Neuen PI (bzw. der neuen SSD ) das Backup zurückzuholen. So der Plan. Aber ist scheinbar wieder etwas fehlgeschlagen (das temporäre Verzeichnis auf dem NAS ist wieder gelöscht):
                    [DEBUG] [influxDB] - Try deleting the InfluxDB tmp directory: "/opt/iobroker/backups/influxDB_2023_11_20-11_52_25_backupiobroker"
                    [DEBUG] [influxDB] - InfluxDB tmp directory "/opt/iobroker/backups/influxDB_2023_11_20-11_52_25_backupiobroker" successfully deleted
                    [ERROR] [influxDB] - Error: Command failed: influx backup --bucket iobroker -t 9RpnKWzJ2Vuq-Jg85pOljmMaF1PJP0YhAfXZcLYO7QRNUQtKUaV0ezcQeIpnmTR2K1Ve0YWl11lqKTsX2DvQvw== "/opt/iobroker/backups/influxDB_2023_11_20-11_52_25_backupiobroker"
                    2023/11/20 11:52:25 INFO: Downloading metadata snapshot
                    2023/11/20 11:52:25 INFO: Backing up TSM for shard 1
                    2023/11/20 11:54:00 INFO: Backing up TSM for shard 2
                    2023/11/20 11:55:36 INFO: Backing up TSM for shard 3
                    2023/11/20 11:57:00 INFO: Backing up TSM for shard 4
                    2023/11/20 11:58:31 INFO: Backing up TSM for shard 5
                    2023/11/20 11:59:51 INFO: Backing up TSM for shard 6
                    2023/11/20 12:01:12 INFO: Backing up TSM for shard 7
                    2023/11/20 12:02:39 INFO: Backing up TSM for shard 8
                    2023/11/20 12:03:57 INFO: Backing up TSM for shard 9
                    2023/11/20 12:05:28 INFO: Backing up TSM for shard 10
                    2023/11/20 12:07:17 INFO: Backing up TSM for shard 11
                    2023/11/20 12:09:37 INFO: Backing up TSM for shard 12
                    2023/11/20 12:14:06 INFO: Backing up TSM for shard 13
                    2023/11/20 12:22:22 INFO: Backing up TSM for shard 14
                    2023/11/20 12:28:52 INFO: Backing up TSM for shard 15
                    2023/11/20 12:36:47 INFO: Backing up TSM for shard 16
                    2023/11/20 12:43:47 INFO: Backing up TSM for shard 17
                    2023/11/20 12:52:28 INFO: Backing up TSM for shard 18
                    Error: failed to backup bucket data: failed to download snapshot of shard 18: 401 Unauthorized: unauthorized access
                    [EXIT] 0
                      @Marc-Berg Es ist Alles supertoll beschrieben! Aber es klappt einfach nicht. OK, das mit dem ersten Eintrag als Operator Token benutzen habe ich verpennt!
                      • Ich generiere einen neuen Token in der Influx GUI:
                        Z50uyViNwOSShEX2jY2A09cHyCCavlnqe1GFdkzGnYWZ4a2uQ2ghc9wahuCQwuNrpDuWHhGj7_wrrflgHMkpMA==
                      • mit diesem Token führe ich aus:
                        influx auth list -t Z50uyViNwOSShEX2jY2A09cHyCCavlnqe1GFdkzGnYWZ4a2uQ2ghc9wahuCQwuNrpDuWHhGj7_wrrflgHMkpMA== --json
                      • den ersten Token kopiere ich.
                        das ist der "Operator Token"
                      • der kommt in die BackitUp- Instanz rein.
                      • und in die Influx.db Instanz - ist das richtig oder muß da der ursprünglich generierte
                        rein?
                        Ich habe jetzt alle Versionen durchprobiert.
                        Beim ausführen des Befehles:
                        influx backup --bucket iobroker -t Z50uyViNwOSShEX2jY2A09cHyCCavlnqe1GFdkzGnYWZ4a2uQ2ghc9wahuCQwuNrpDuWHhGj7_wrrflgHMkpMA== "/opt/iobroker/backups/influxDB_2023_11_20-10_53_21_backupiobroker" kommt immer:
                      otto@raspberrypi:/opt/iobroker/backups $ influx backup --bucket iobroker --host http://192.168.2.54:8086 -t zijB7piBzzSSLchg2TCyrp2MViRxSJ5_HQP_ynLZO_T8K6Wy-guPxh9uI75KjCKFKIhzTGhpSSeyMpp58Z_juw== "/tmp/influx-test"
                      2023/11/20 14:20:01 INFO: Downloading metadata snapshot
                      • simatec
                        @laser Wie groß ist deine DB? Führe mal den Befehl erstmal manuell aus, um zu schauen, ob alles funktioniert
                        mkdir -p /opt/iobroker/backups/influxdb2-tmp
                        influx backup --bucket iobroker -t 9RpnKWzJ2Vuq-Jg85pOljmMaF1PJP0YhAfXZcLYO7QRNUQtKUaV0ezcQeIpnmTR2K1Ve0YWl11lqKTsX2DvQvw== "/opt/iobroker/backups/influxdb2-tmp"
                          Laser @simatec last edited by Laser
                          @simatec sagte in Kein iobroker Backup mehr über BackitUp Adapter:
                          Korrektur:
                          otto@raspberrypi:/opt/iobroker/backups $ mkdir -p /opt/iobroker/backups/influxdb2-tmp
                          otto@raspberrypi:/opt/iobroker/backups $ influx backup --bucket iobroker -t 9RpnKWzJ2Vuq-Jg85pOljmMaF1PJP0YhAfXZcLYO7QRNUQtKUaV0ezcQeIpnmTR2K1Ve0YWl11lqKTsX2DvQvw== "/opt/iobroker/backups/influxdb2-tmp"
                          2023/11/20 14:38:28 INFO: Downloading metadata snapshot
                          Error: failed to backup metadata: failed to download metadata snapshot: 401 Unauthorized: unauthorized access
                            @simatec sind denn die Befehle, wie ich sie oben aufgelistet habe überhaupt richtig? Ich bekomme immer einen anderen Operator- Token angezeigt, niemals
                            • Marc Berg
                              Niemals? Und was ist das hier?
                              https://forum.iobroker.net/post/1083285
                              Ich würde sagen, du hast den Operator Token jetzt gelöscht. Glückwunsch!
                                @marc-berg deshalb war meine Frage: "was mache ich mit den anderen Tokens neben dem neu Angelegten?" Habe ich gelöscht. War das ein Fehler?
                                • simatec
                                  simatec Developer Most Active @Laser last edited by
                                  @laser Zeige mal, was hier für Token angelegt sind
                                  Was kommt für eine Ausgabe, wenn du den Befehl absetzt?
                                  influx auth list -t <TOKEN> --json
                                    @simatec soll ich dazu den letzten generierten Token einsetzen?
                                    otto@raspberrypi:/opt/iobroker/backups $ influx auth list -t Z50uyViNwOSShEX2jY2A09cHyCCavlnqe1GFdkzGnYWZ4a2uQ2ghc9wahuCQwuNrpDuWHhGj7_wrrflgHMkpMA== --json
                                                    "status": "active",
                                                    "permissions": [
                                    ]       }       ]       "write:orgs/56ed5fe7a100c804/views"les",s",les",ts",ghc9wahuCQwuNrpDuWHhGj7_wrrflgHMkpMA==",
                                    • simatec
                                      @laser Wie erstellst du denn die ganzen Token?
                                      Bist du als Admin im WebUi von Influx angemeldet?
                                      Zeige doch mal bitte deinen Weg...
                                      Hier ist alles gut beschrieben...
                                        @simatec Diese Beschreibung habe ich ständig aufgeklappt und versuche, Schritt für Schritt durchzugehen.
                                        In der Influx-DB bin ich als Admin eingeloggt. Ich erzeuge jetzt nochmal einen neuen all-access- API-Token.
                                        Q494kw0QVOhk3if8D-cZsqjlggKCOIEJcD8gW1Za4vUzKGYYQO7RoraoIrmmPm-NjdaChpZAddzXtsQ7Mw5GBg==
                                        otto@raspberrypi:/opt/iobroker/backups $ influx auth list -t Q494kw0QVOhk3if8D-cZsqjlggKCOIEJcD8gW1Za4vUzKGYYQO7RoraoIrmmPm-NjdaChpZAddzXtsQ7Mw5GBg== --json
                                                        "status": "active",
                                        ist das ober der Operator Token oder ist der unwiederbringlich weg? Auszug aus der Beschreibung:
                                        5. Wenn es keinen solchen Eintrag gibt, dann wurde das Operator-Token gelöscht. Auch das kann repariert werden. Hier ist ein Link zu einem Artikel Link
                                        (Der Link zum Neu- Anlegen des Operator Tokens funktioniert nicht)
                                        simatec 2 Replies Last reply Reply Quote 0
                                        • simatec
                                          @laser Der Link ist extern und leider nicht für uns greifbar
                                          Versuche hiermit mal einen neuen zu erstellen
                                          https://docs.influxdata.com/influxdb/v2/reference/cli/influxd/recovery/auth/
                                          • simatec
                                            @laser
                                            Versuche es mal wie folgt...
                                            influxd recovery auth create-operator --username admin --org privat
                                            Dieser Befehl kann nur ausgeführt werden, wenn der InfluxDB-Server ( influxd) nicht läuft.
                                            5235
