    4. Kein iobroker Backup mehr über BackitUp Adapter
    • Marc Berg
      Marc Berg Most Active @Laser last edited by
      @laser
      Okay, dann hast du wahrscheinlich mal ein Update von V1 gemacht. Also:
      influxd recovery auth create-operator --org privat --username iobroker --bolt-path /var/lib/influxdb/influxd.bolt
        Laser @Marc Berg last edited by Laser
        @marc-berg sagte in Kein iobroker Backup mehr über BackitUp Adapter:
        Ja, habe mal upgedatet!
        DerBefehl auch als "sudo"?
        otto@raspberrypi:/etc $ influxd recovery auth create-operator --org privat --username iobroker --bolt-path /var/lib/influxdb/influxd.bolt
        Error: stat /var/lib/influxdb/influxd.bolt: permission denied
        See 'influxd -h' for help
        otto@raspberrypi:/etc $ sudo influxd recovery auth create-operator --org privat --username iobroker --bolt-path /var/lib/influxdb/influxd.bolt
        2023-11-20T15:32:46.060743Z     info    Resources opened        {"log_id": "0lcLduR0000", "system": "bolt-kvstore", "path": "/var/lib/influxdb/influxd.bolt"}
        ID                      User Name       User ID                 Description                                     Token        Permissions
        0b485bd1c75e4000        iobroker        0b4721cca3305000        onboarding-cliWizard-token-1685530468858        zijB7piBzzSSLchg2TCyrp2MViRxSJ5_HQP_ynLZO_T8K6Wy-guPxh9uI75KjCKFKIhzTGhpSSeyMpp58Z_juw==        [read:orgs/56ed5fe7a100c804/annotations write:orgs/56ed5fe7a100c804/annotations read:orgs/56ed5fe7a100c804/authorizations write:orgs/56ed5fe7a100c804/authorizations read:orgs/56ed5fe7a100c804/buckets write:orgs/56ed5fe7a100c804/buckets read:orgs/56ed5fe7a100c804/checks write:orgs/56ed5fe7a100c804/checks read:orgs/56ed5fe7a100c804/dashboards write:orgs/56ed5fe7a100c804/dashboards read:orgs/56ed5fe7a100c804/dbrp write:orgs/56ed5fe7a100c804/dbrp read:orgs/56ed5fe7a100c804/documents write:orgs/56ed5fe7a100c804/documents read:orgs/56ed5fe7a100c804/labels write:orgs/56ed5fe7a100c804/labels read:orgs/56ed5fe7a100c804/notebooks write:orgs/56ed5fe7a100c804/notebooks read:orgs/56ed5fe7a100c804/notificationEndpoints write:orgs/56ed5fe7a100c804/notificationEndpoints read:orgs/56ed5fe7a100c804/notificationRules write:orgs/56ed5fe7a100c804/notificationRules read:orgs/56ed5fe7a100c804 read:orgs/56ed5fe7a100c804/remotes write:orgs/56ed5fe7a100c804/remotes read:orgs/56ed5fe7a100c804/replications write:orgs/56ed5fe7a100c804/replications read:orgs/56ed5fe7a100c804/scrapers write:orgs/56ed5fe7a100c804/scrapers read:orgs/56ed5fe7a100c804/secrets write:orgs/56ed5fe7a100c804/secrets read:orgs/56ed5fe7a100c804/sources write:orgs/56ed5fe7a100c804/sources read:orgs/56ed5fe7a100c804/tasks write:orgs/56ed5fe7a100c804/tasks read:orgs/56ed5fe7a100c804/telegrafs write:orgs/56ed5fe7a100c804/telegrafs read:users/0b4721cca3305000 write:users/0b4721cca3305000 read:orgs/56ed5fe7a100c804/variables write:orgs/56ed5fe7a100c804/variables read:orgs/56ed5fe7a100c804/views write:orgs/56ed5fe7a100c804/views]
        0c26fdf572986000        iobroker        0b4721cca3305000        onboarding-cliWizard-token-1700471139713        oodzlogKQY9O0tCtNNDYiFxomFcAWJXjd-RTbC738Fkna1nzQiVXRjNVaKZDFt_lvWEYrZWhpUNIxsnMISQejg==        [read:orgs/56ed5fe7a100c804/annotations write:orgs/56ed5fe7a100c804/annotations read:orgs/56ed5fe7a100c804/authorizations write:orgs/56ed5fe7a100c804/authorizations read:orgs/56ed5fe7a100c804/buckets write:orgs/56ed5fe7a100c804/buckets read:orgs/56ed5fe7a100c804/checks write:orgs/56ed5fe7a100c804/checks read:orgs/56ed5fe7a100c804/dashboards write:orgs/56ed5fe7a100c804/dashboards read:orgs/56ed5fe7a100c804/dbrp write:orgs/56ed5fe7a100c804/dbrp read:orgs/56ed5fe7a100c804/documents write:orgs/56ed5fe7a100c804/documents read:orgs/56ed5fe7a100c804/labels write:orgs/56ed5fe7a100c804/labels read:orgs/56ed5fe7a100c804/notebooks write:orgs/56ed5fe7a100c804/notebooks read:orgs/56ed5fe7a100c804/notificationEndpoints write:orgs/56ed5fe7a100c804/notificationEndpoints read:orgs/56ed5fe7a100c804/notificationRules write:orgs/56ed5fe7a100c804/notificationRules read:orgs/56ed5fe7a100c804 read:orgs/56ed5fe7a100c804/remotes write:orgs/56ed5fe7a100c804/remotes read:orgs/56ed5fe7a100c804/replications write:orgs/56ed5fe7a100c804/replications read:orgs/56ed5fe7a100c804/scrapers write:orgs/56ed5fe7a100c804/scrapers read:orgs/56ed5fe7a100c804/secrets write:orgs/56ed5fe7a100c804/secrets read:orgs/56ed5fe7a100c804/sources write:orgs/56ed5fe7a100c804/sources read:orgs/56ed5fe7a100c804/tasks write:orgs/56ed5fe7a100c804/tasks read:orgs/56ed5fe7a100c804/telegrafs write:orgs/56ed5fe7a100c804/telegrafs read:users/0b4721cca3305000 write:users/0b4721cca3305000 read:orgs/56ed5fe7a100c804/variables write:orgs/56ed5fe7a100c804/variables read:orgs/56ed5fe7a100c804/views write:orgs/56ed5fe7a100c804/views]
        0c2731d6a8bd8000        iobroker        0b4721cca3305000        iobroker                                        Z50uyViNwOSShEX2jY2A09cHyCCavlnqe1GFdkzGnYWZ4a2uQ2ghc9wahuCQwuNrpDuWHhGj7_wrrflgHMkpMA==        [read:orgs/56ed5fe7a100c804/annotations write:orgs/56ed5fe7a100c804/annotations read:orgs/56ed5fe7a100c804/authorizations write:orgs/56ed5fe7a100c804/authorizations read:orgs/56ed5fe7a100c804/buckets write:orgs/56ed5fe7a100c804/buckets read:orgs/56ed5fe7a100c804/checks write:orgs/56ed5fe7a100c804/checks read:orgs/56ed5fe7a100c804/dashboards write:orgs/56ed5fe7a100c804/dashboards read:orgs/56ed5fe7a100c804/dbrp write:orgs/56ed5fe7a100c804/dbrp read:orgs/56ed5fe7a100c804/documents write:orgs/56ed5fe7a100c804/documents read:orgs/56ed5fe7a100c804/labels write:orgs/56ed5fe7a100c804/labels read:orgs/56ed5fe7a100c804/notebooks write:orgs/56ed5fe7a100c804/notebooks read:orgs/56ed5fe7a100c804/notificationEndpoints write:orgs/56ed5fe7a100c804/notificationEndpoints read:orgs/56ed5fe7a100c804/notificationRules write:orgs/56ed5fe7a100c804/notificationRules read:orgs/56ed5fe7a100c804 read:orgs/56ed5fe7a100c804/remotes write:orgs/56ed5fe7a100c804/remotes read:orgs/56ed5fe7a100c804/replications write:orgs/56ed5fe7a100c804/replications read:orgs/56ed5fe7a100c804/scrapers write:orgs/56ed5fe7a100c804/scrapers read:orgs/56ed5fe7a100c804/secrets write:orgs/56ed5fe7a100c804/secrets read:orgs/56ed5fe7a100c804/sources write:orgs/56ed5fe7a100c804/sources read:orgs/56ed5fe7a100c804/tasks write:orgs/56ed5fe7a100c804/tasks read:orgs/56ed5fe7a100c804/telegrafs write:orgs/56ed5fe7a100c804/telegrafs read:users/0b4721cca3305000 write:users/0b4721cca3305000 read:orgs/56ed5fe7a100c804/variables write:orgs/56ed5fe7a100c804/variables read:orgs/56ed5fe7a100c804/views write:orgs/56ed5fe7a100c804/views]
        0c27485709bd8000        iobroker        0b4721cca3305000        neuer iobroker token                            Q494kw0QVOhk3if8D-cZsqjlggKCOIEJcD8gW1Za4vUzKGYYQO7RoraoIrmmPm-NjdaChpZAddzXtsQ7Mw5GBg==        [read:orgs/56ed5fe7a100c804/annotations write:orgs/56ed5fe7a100c804/annotations read:orgs/56ed5fe7a100c804/authorizations write:orgs/56ed5fe7a100c804/authorizations read:orgs/56ed5fe7a100c804/buckets write:orgs/56ed5fe7a100c804/buckets read:orgs/56ed5fe7a100c804/checks write:orgs/56ed5fe7a100c804/checks read:orgs/56ed5fe7a100c804/dashboards write:orgs/56ed5fe7a100c804/dashboards read:orgs/56ed5fe7a100c804/dbrp write:orgs/56ed5fe7a100c804/dbrp read:orgs/56ed5fe7a100c804/documents write:orgs/56ed5fe7a100c804/documents read:orgs/56ed5fe7a100c804/labels write:orgs/56ed5fe7a100c804/labels read:orgs/56ed5fe7a100c804/notebooks write:orgs/56ed5fe7a100c804/notebooks read:orgs/56ed5fe7a100c804/notificationEndpoints write:orgs/56ed5fe7a100c804/notificationEndpoints read:orgs/56ed5fe7a100c804/notificationRules write:orgs/56ed5fe7a100c804/notificationRules read:orgs/56ed5fe7a100c804 read:orgs/56ed5fe7a100c804/remotes write:orgs/56ed5fe7a100c804/remotes read:orgs/56ed5fe7a100c804/replications write:orgs/56ed5fe7a100c804/replications read:orgs/56ed5fe7a100c804/scrapers write:orgs/56ed5fe7a100c804/scrapers read:orgs/56ed5fe7a100c804/secrets write:orgs/56ed5fe7a100c804/secrets read:orgs/56ed5fe7a100c804/sources write:orgs/56ed5fe7a100c804/sources read:orgs/56ed5fe7a100c804/tasks write:orgs/56ed5fe7a100c804/tasks read:orgs/56ed5fe7a100c804/telegrafs write:orgs/56ed5fe7a100c804/telegrafs read:users/0b4721cca3305000 write:users/0b4721cca3305000 read:orgs/56ed5fe7a100c804/variables write:orgs/56ed5fe7a100c804/variables read:orgs/56ed5fe7a100c804/views write:orgs/56ed5fe7a100c804/views]
        0c27568e5bacd000        iobroker        0b4721cca3305000        iobroker's Recovery Token                       7wIc7VllUj3xRIfnu2jIxvPaLgMruI2ZHyUw2dYLeHSYrPQvPtS-1l8-_Jr43Nveb_aXW5cmzT11oM59gyKx6g==        [read:authorizations write:authorizations read:buckets write:buckets read:dashboards write:dashboards read:orgs write:orgs read:sources write:sources read:tasks write:tasks read:telegrafs write:telegrafs read:users write:users read:variables write:variables read:scrapers write:scrapers read:secrets write:secrets read:labels write:labels read:views write:views read:documents write:documents read:notificationRules write:notificationRules read:notificationEndpoints write:notificationEndpoints read:checks write:checks read:dbrp write:dbrp read:notebooks write:notebooks read:annotations write:annotations read:remotes write:remotes read:replications write:replications]
        otto@r
        simatec Marc Berg 2 Replies Last reply Reply Quote 0
        • simatec
          simatec Developer Most Active @Laser last edited by
          @laser
          influx auth list -t 7wIc7VllUj3xRIfnu2jIxvPaLgMruI2ZHyUw2dYLeHSYrPQvPtS-1l8-_Jr43Nveb_aXW5cmzT11oM59gyKx6g== --json
          • Marc Berg
            Marc Berg Most Active @Laser last edited by Marc Berg
            @laser
            Heureka!
            Jetzt nochmal den
            influx auth list -t 12345 --json
            Befehl mit dem zuletzt noch vorhandenen Token.
            EDIT: vorher die DB wieder starten
              @marc-berg soll ich den Token neu anlegen, oder den zuletzt notierten verwenden?
              influx auth list -t Q494kw0QVOhk3if8D-cZsqjlggKCOIEJcD8gW1Za4vUzKGYYQO7RoraoIrmmPm-NjdaChpZAddzXtsQ7Mw5GBg== --json
              • simatec
                @laser Habe ich doch oben geschrieben
                https://forum.iobroker.net/post/1083546
                  Laser @simatec last edited by Laser
                  @simatec
                  also:
                  otto@raspberrypi:/etc $ influx auth list -t 7wIc7VllUj3xRIfnu2jIxvPaLgMruI2ZHyUw2dYLeHSYrPQvPtS-1l8-_Jr43Nveb_aXW5cmzT11oM59gyKx6g== --json
                                  "id": "0b485bd1c75e4000",
                                  "description": "onboarding-cliWizard-token-1685530468858",
                                  "token": "zijB7piBzzSSLchg2TCyrp2MViRxSJ5_HQP_ynLZO_T8K6Wy-guPxh9uI75KjCKFKIhzTGhpSSeyMpp58Z_juw==",
                                  "status": "active",
                                  "userName": "iobroker",
                                  "userID": "0b4721cca3305000",
                                  "permissions": [
                                          "read:orgs/56ed5fe7a100c804/annotations",
                                          "write:orgs/56ed5fe7a100c804/annotations",
                                          "read:orgs/56ed5fe7a100c804/authorizations",
                                          "write:orgs/56ed5fe7a100c804/authorizations",
                                          "read:orgs/56ed5fe7a100c804/buckets",
                                          "write:orgs/56ed5fe7a100c804/buckets",
                                          "read:orgs/56ed5fe7a100c804/checks",
                                          "write:orgs/56ed5fe7a100c804/checks",
                                          "read:orgs/56ed5fe7a100c804/dashboards",
                                          "write:orgs/56ed5fe7a100c804/dashboards",
                                          "read:orgs/56ed5fe7a100c804/dbrp",
                                          "write:orgs/56ed5fe7a100c804/dbrp",
                                          "read:orgs/56ed5fe7a100c804/documents",
                                          "write:orgs/56ed5fe7a100c804/documents",
                                          "read:orgs/56ed5fe7a100c804/labels",
                                          "write:orgs/56ed5fe7a100c804/labels",
                                          "read:orgs/56ed5fe7a100c804/notebooks",
                                          "write:orgs/56ed5fe7a100c804/notebooks",
                                          "read:orgs/56ed5fe7a100c804/notificationEndpoints",
                                          "write:orgs/56ed5fe7a100c804/notificationEndpoints",
                                          "read:orgs/56ed5fe7a100c804/notificationRules",
                                          "write:orgs/56ed5fe7a100c804/notificationRules",
                                          "read:/orgs/56ed5fe7a100c804",
                                          "read:orgs/56ed5fe7a100c804/remotes",
                                          "write:orgs/56ed5fe7a100c804/remotes",
                                          "read:orgs/56ed5fe7a100c804/replications",
                                          "write:orgs/56ed5fe7a100c804/replications",
                                          "read:orgs/56ed5fe7a100c804/scrapers",
                                          "write:orgs/56ed5fe7a100c804/scrapers",
                                          "read:orgs/56ed5fe7a100c804/secrets",
                                          "write:orgs/56ed5fe7a100c804/secrets",
                                          "read:orgs/56ed5fe7a100c804/sources",
                                          "write:orgs/56ed5fe7a100c804/sources",
                                          "read:orgs/56ed5fe7a100c804/tasks",
                                          "write:orgs/56ed5fe7a100c804/tasks",
                                          "read:orgs/56ed5fe7a100c804/telegrafs",
                                          "write:orgs/56ed5fe7a100c804/telegrafs",
                                          "read:/users/0b4721cca3305000",
                                          "write:/users/0b4721cca3305000",
                                          "read:orgs/56ed5fe7a100c804/variables",
                                          "write:orgs/56ed5fe7a100c804/variables",
                                          "read:orgs/56ed5fe7a100c804/views",
                                          "write:orgs/56ed5fe7a100c804/views"
                                  "id": "0c26fdf572986000",
                                  "description": "onboarding-cliWizard-token-1700471139713",
                                  "token": "oodzlogKQY9O0tCtNNDYiFxomFcAWJXjd-RTbC738Fkna1nzQiVXRjNVaKZDFt_lvWEYrZWhpUNIxsnMISQejg==",
                                  "status": "active",
                                  "permissions": [
                                  "id": "0c2731d6a8bd8000",
                                  "description": "iobroker",
                                  "token": "Z50uyViNwOSShEX2jY2A09cHyCCavlnqe1GFdkzGnYWZ4a2uQ2ghc9wahuCQwuNrpDuWHhGj7_wrrflgHMkpMA==",
                                  "status": "active",
                                  "permissions": [
                                  "id": "0c27485709bd8000",
                                  "description": "neuer iobroker token",
                                  "token": "Q494kw0QVOhk3if8D-cZsqjlggKCOIEJcD8gW1Za4vUzKGYYQO7RoraoIrmmPm-NjdaChpZAddzXtsQ7Mw5GBg==",
                                  "status": "active",
                                  "permissions": [
                                  "id": "0c27568e5bacd000",
                                  "description": "iobroker's Recovery Token",
                                  "token": "7wIc7VllUj3xRIfnu2jIxvPaLgMruI2ZHyUw2dYLeHSYrPQvPtS-1l8-_Jr43Nveb_aXW5cmzT11oM59gyKx6g==",
                                  "status": "active",
                                  "permissions": [
                                          "read:/authorizations",
                                          "write:/authorizations",
                                          "read:/buckets",
                                          "write:/buckets",
                                          "read:/dashboards",
                                          "write:/dashboards",
                                          "read:/orgs",
                                          "write:/orgs",
                                          "read:/sources",
                                          "write:/sources",
                                          "read:/tasks",
                                          "write:/tasks",
                                          "read:/telegrafs",
                                          "write:/telegrafs",
                                          "read:/users",
                                          "write:/users",
                                          "read:/variables",
                                          "write:/variables",
                                          "read:/scrapers",
                                          "write:/scrapers",
                                          "read:/secrets",
                                          "write:/secrets",
                                          "read:/labels",
                                          "write:/labels",
                                          "read:/views",
                                          "write:/views",
                                          "read:/documents",
                                          "write:/documents",
                                          "read:/notificationRules",
                                          "write:/notificationRules",
                                          "read:/notificationEndpoints",
                                          "write:/notificationEndpoints",
                                          "read:/checks",
                                          "write:/checks",
                                          "read:/dbrp",
                                          "write:/dbrp",
                                          "read:/notebooks",
                                          "write:/notebooks",
                                          "read:/annotations",
                                          "write:/annotations",
                                          "read:/remotes",
                                          "write:/remotes",
                                          "read:/replications",
                                          "write:/replications"
                  Marc Berg simatec 2 Replies Last reply Reply Quote 0
                  • Marc Berg
                    @laser sagte in Kein iobroker Backup mehr über BackitUp Adapter:
                    Jetzt ist es NICHT MEHR der erste Eintrag, sondern der letzte:
                    "iobroker's Recovery Token", das ist jetzt dein neuer Operator Token:
                    Nicht wieder löschen.
                    simatec 1 Reply Last reply Reply Quote 1
                    • simatec
                      @laser Der letzte ist der Operator Token
                      • simatec
                        simatec Developer Most Active @Marc Berg last edited by
                        @marc-berg Ich schreib da mal ein Wiki Eintrag zu... Der externe Link ist ja tot...
                        Marc Berg 1 Reply Last reply Reply Quote 1
                        • Marc Berg
                          Marc Berg Most Active @simatec last edited by
                          @simatec sagte in Kein iobroker Backup mehr über BackitUp Adapter:
                          Ich habe ne Copy von der Seite, falls interessant.
                            @simatec Mein Gott, nun der Letzte- wie soll das ein Normalo kapieren?
                            Jetzt läuft der Testbefehl auf der Konsole erst mal an.
                            • Marc Berg
                              Wenn der Löschfinger nicht so locker sitzt, bleibt es ewig der erste Eintrag ... 🙂
                                @marc-berg Den Löschfinger hatte ich lange im Griff. Aber dann kam der vermeintliche Ordnungssinn hervor!
                                Der Backupbefehl auf der Konsole läuft erst mal. Wenn der fertig ist, mache ich das über BackItUp.
                                oder kann man das gefahrlos mit "strg C" abbrechen?
                                • Marc Berg
                                  Da passiert weiter nichts, außer ein paar Dateileichen. Ich würde mir aber Sorgen wegen der großen Datenmengen machen. Das ist auch nicht normal, wie sich das anhört.
                                    @marc-berg Ja, das sind riesige Dateimengen. Vermutlich lese ich Werte zu oft ein. Obwohl ich das schon einige Male durchgegangen bin.
                                    Muß jetzt erst mal kurz Feuer machen 10 Min...
                                    • Marc Berg
                                      Das kannst du mal in den Data Explorer geben und schauen, wo (besonders) der Schuh drückt:
                                      from(bucket: "iobroker")
                                        |> range(start: -10y)
                                        |> filter(fn: (r) => r["_field"] == "value")
                                        |> count()
                                        |> group()
                                        |> keep(columns: ["_measurement", "_value"])
                                        |> sort(columns: ["_value"], desc: true)
                                        |> rename(columns: {_value: "Anzahl"})
                                        @marc-berg Ist angelegt. Beobachte...
                                        Zu Beginn hatte ich wirklich im Sekundenabstand aufgezeichnet. Ist aber schon abgemildert. Aber die Altlasten sind noch da. Müßte die häufigen Aufzeichnungen "abschneiden" Die Werte von damals sind ohnehin nicht von Bedeutung gewesen.
                                        Und ich danke den Beteiligten für die Hilfe. Ich konnte jetzt auf "Bookworm" umziehen und dort das Backup wieder reinholen.
                                        • simatec
                                          So hier mal zum Abschluss noch der Wiki Beitrag.
                                          https://github.com/simatec/ioBroker.backitup/wiki/Diverse-Anleitungen-für-ioBroker.backitup#operator-token-für-influxdb-2x-wiederherstellen
                                          • Marc Berg
                                            Marc Berg Most Active last edited by
                                            Super beschrieben! 👍
                                            Vielleicht kannst du folgende Anleitung für das offizielle Influxdb-Docker-Image ergänzen, da sich in einem Docker-Container der influxdb Prozess nicht ohne weiteres beenden lässt und mit einer Kopie der *bolt Datei gearbeitet werden muss:
                                            su influxdb
                                            cd /var/lib/influxdb2
                                            cp influxd.bolt influxd2.bolt
                                            influxd recovery auth create-operator --org <deine_org> --username <dein_user> --bolt-path /var/lib/influxdb2/influxd2.bolt
                                            mv influxd2.bolt influxd.bolt
                                            kill 1
                                            Oder ist das zu speziell?
                                            5235
