    4. [SourceAnalytix 0.4.8-Final] Released !
      crunchip Forum Testing Most Active @Dutchman last edited by
      @dutchman sagte in [SourceAnalytix 0.4.8-Final] Released !:
      das verstehe ich nicht,
      Ich ja eben auch nicht, muss ich mir in einer ruhigen Minute nochmal genauer ansehen.
      Schöner wäre es allerdings, ich würde die paar Tasmota auch hinbekommen, das sie sich nicht zurück setzen. Aber auch das gelingt mir nicht
      • Dutchman
        Dutchman Developer Most Active Administrators @Laser last edited by
        @laser sagte in [SourceAnalytix 0.4.8-Final] Released !:
        @dutchman
        2023-11-05 14:57:20.876  - error: modbus.0 (4041450) Request timed out.
        2023-11-05 14:57:20.877  - warn: modbus.0 (4041450) Poll error count: 1 code: {"err":"timeout","timeout":5000}
        2023-11-05 14:57:23.530  - info: host.raspberrypi stopInstance system.adapter.vedirect.0 (force=false, process=true)
        2023-11-05 14:57:23.542  - error: vedirect.0 (4061474) Sentry disabled, error catched : [onUnload] TypeError: SerialPort.close is not a function
        2023-11-05 14:57:23.576  - info: host.raspberrypi stopInstance system.adapter.vedirect.0 send kill signal
        2023-11-05 14:57:24.143  - info: host.raspberrypi instance system.adapter.vedirect.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2023-11-05 14:57:25.905  - info: host.raspberrypi instance system.adapter.vedirect.0 started with pid 4063780
        2023-11-05 14:58:00.003  - warn: javascript.0 (53524) State "javascript.0.variables.dayTime" has no existing object, this might lead to an error in future versions
        2023-11-05 14:59:00.002  - warn: javascript.0 (53524) State "javascript.0.variables.dayTime" has no existing object, this might lead to an error in future versions
        2023-11-05 15:00:00.013  - warn: javascript.0 (53524) State "javascript.0.variables.dayTime" has no existing object, this might lead to an error in future versions
        2023-11-05 15:01:00.005  - warn: javascript.0 (53524) State "javascript.0.variables.dayTime" has no existing object, this might lead to an error in future versions
        2023-11-05 15:01:01.013  - info: javascript.0 (53524) script.js.Heizung.TagNachtZeitraum: Tag:
        2023-11-05 15:02:00.004  - warn: javascript.0 (53524) State "javascript.0.variables.dayTime" has no existing object, this might lead to an error in future versions
        2023-11-05 15:03:00.004  - warn: javascript.0 (53524) State "javascript.0.variables.dayTime" has no existing object, this might lead to an error in future versions
        2023-11-05 15:04:00.003  - warn: javascript.0 (53524) State "javascript.0.variables.dayTime" has no existing object, this might lead to an error in future versions
        2023-11-05 15:05:00.003  - warn: javascript.0 (53524) State "javascript.0.variables.dayTime" has no existing object, this might lead to an error in future versions
        2023-11-05 15:06:00.002  - warn: javascript.0 (53524) State "javascript.0.variables.dayTime" has no existing object, this might lead to an error in future versions
        2023-11-05 15:07:00.002  - warn: javascript.0 (53524) State "javascript.0.variables.dayTime" has no existing object, this might lead to an error in future versions
        2023-11-05 15:08:00.003  - warn: javascript.0 (53524) State "javascript.0.variables.dayTime" has no existing object, this might lead to an error in future versions
        2023-11-05 15:09:00.021  - warn: javascript.0 (53524) State "javascript.0.variables.dayTime" has no existing object, this might lead to an error in future versions
        2023-11-05 15:10:00.004  - warn: javascript.0 (53524) State "javascript.0.variables.dayTime" has no existing object, this might lead to an error in future versions
        2023-11-05 15:10:01.007  - info: javascript.0 (53524) script.js.Heizung.TagNachtZeitraum: Tag:
        2023-11-05 15:11:00.005  - warn: javascript.0 (53524) State "javascript.0.variables.dayTime" has no existing object, this might lead to an error in future versions
        2023-11-05 15:12:00.005  - warn: javascript.0 (53524) State "javascript.0.variables.dayTime" has no existing object, this might lead to an error in future versions
        2023-11-05 15:13:00.003  - warn: javascript.0 (53524) State "javascript.0.variables.dayTime" has no existing object, this might lead to an error in future versions
        2023-11-05 15:14:00.011  - warn: javascript.0 (53524) State "javascript.0.variables.dayTime" has no existing object, this might lead to an error in future versions
        2023-11-05 15:15:00.023  - warn: javascript.0 (53524) State "javascript.0.variables.dayTime" has no existing object, this might lead to an error in future versions
        2023-11-05 15:16:00.014  - warn: javascript.0 (53524) State "javascript.0.variables.dayTime" has no existing object, this might lead to an error in future versions
        2023-11-05 15:17:00.009  - warn: javascript.0 (53524) State "javascript.0.variables.dayTime" has no existing object, this might lead to an error in future versions
        2023-11-05 15:18:00.003  - warn: javascript.0 (53524) State "javascript.0.variables.dayTime" has no existing object, this might lead to an error in future versions
        2023-11-05 15:19:00.009  - warn: javascript.0 (53524) State "javascript.0.variables.dayTime" has no existing object, this might lead to an error in future versions
        2023-11-05 15:20:00.004  - warn: javascript.0 (53524) State "javascript.0.variables.dayTime" has no existing object, this might lead to an error in future versions
        OK, diesen JS- Fehler werde ich eliminieren (ist eine andere Baustelle).
        Ich sehe hier keine Fehler von SA ? 😅
        • Dutchman
          Dutchman Developer Most Active Administrators @crunchip last edited by Dutchman
          @crunchip sagte in [SourceAnalytix 0.4.8-Final] Released !:
          Können gerne mal zusammen schauen oder das du mir wieder deine Logs von SA an meinen zentralen SEQ schickst
          Dan kan alles weiterlaufen und wen der Fehler auftritt hab ich die Info die ich brauche
          Wen möglich hätte ich das am liebsten, kan ich selber durch die log Daten stöbern.
            Laser @Dutchman last edited by Laser
            @dutchman ich sehe auch keine! Auch zu anderen Zeiten mit der Zacke nach unten sehe ich keine SA-Fehler im Protokoll.
              @dutchman machen wir bei Gelegenheit, hab allerdings aktuell anderweitig einiges um die Ohren.
              Wenn mal bisserl Luft ist, meld ich mich bei dir
                crunchip Forum Testing Most Active @Laser last edited by
                @laser da müste dann allerdings ne Meldung im Log erscheinen,... device reset....Erkannt
                  Laser @crunchip last edited by Laser
                  @crunchip Es kommt zu keiner Zeit diese Meldung! Ich werde das runtergeladene Log aber nochmal durchsuchen! Bisher nichts dergleichen gefunden. Zumindest nicht zu den Zeiten mit den Zacken. Woanders schon!
                   Device reset detected for alias.0.EnergieBattEntnahme.TotalEM0 store current cumulatedReading 676.0043000000001 as valueAtDeviceReset (previous valueAtDeviceReset : 424.93600000000004)
                  2023-11-05 05:10:57.102  - warn: sourceanalytix.0 (3493514) Device reset detected for alias.0.ACLaden_Total-EM1.Total-EM1 store current cumulatedReading 257.5341 as valueAtDeviceReset (previous valueAtDeviceReset : 165.17810000000003)
                  2023-11-05 05:10:57.105  - warn: sourceanalytix.0 (3493514) Device reset detected for shelly.1.SHEM#244CAB419A03#1.Emeter1.Total store current cumulatedReading 257.5341 as valueAtDeviceReset (previous valueAtDeviceReset : 165.17810000000003)
                  2023-11-05 05:10:57.148  - warn: sourceanalytix.0 (3493514) Object of state "sourceanalytix.0.alias__0__ACLaden_Total-EM1__Total-EM1.cumulativeReading" is missing the required property "common.type"
                  2023-11-05 05:10:57.161  - warn: sourceanalytix.0 (3493514) Object of state "sourceanalytix.0.shelly__1__SHEM#244CAB419A03#1__Emeter1__Total.cumulativeReading" is missing the required property "common.type"
                  2023-11-05 05:10:57.185  - warn: sourceanalytix.0 (3493514) Object of state "sourceanalytix.0.alias__0__ACLaden_Total-EM1__Total-EM1.2023.readingCumulative" is missing the required property "common.type"
                    spike2 last edited by spike2
                    Ist es möglich die geloggten Adapter - Daten von einer Steckdose auf einer andere zu übertragen?
                    Der Grund ist, ich habe eine Steckdose von einem anderen System im Einsatz und möchte die "alte" mit dem "neuen" System ersetzen.
                    Geht vermutlich nur händisch, die Daten auf
                    die "neue" zu übertragen, richtig?
                    Also wie im unten stehenden Bild.
                    Dutchman crunchip 2 Replies Last reply Reply Quote 0
                    • Dutchman
                      Dutchman Developer Most Active Administrators @spike2 last edited by
                      @spike2 sagte in [SourceAnalytix 0.4.8-Final] Released !:
                      das wird demnaest moeglich sein
                        spike2 @Dutchman last edited by
                        @dutchman ohh, dass wäre der Wahnsinn 🙂
                          crunchip Forum Testing Most Active @spike2 last edited by
                          @spike2 https://forum.iobroker.net/post/835238
                            spike2 @crunchip last edited by
                            @crunchip klingt vielversprechend, werde ich die Tage mal ausprobieren.
                            Danke 🙂
                            • Dutchman
                              der Grundgedanke ist das man einen alias definieren kann, damit haben wir in SA auch nicht mehr den langen Datenpunkt Namen sondern alias.
                              ich integriere das momentan, dazu gehört auch wen man den alias ändert das er die Daten umzieht.
                              Damit kann man dan auch alias einen andere state zuweisen was im Grunde ist was du brauchst 🙂
                                @dutchman Ja genau ich denke auch, dass es das ist was ich bräuchte 😉
                                Gibt es schon einen ungefähren Fahrplan wann das Update erscheinen könnte?
                                Bitte nicht falsch verstehen, ich will keineswegs Stress machen 😀
                                  badsnoopy667 last edited by badsnoopy667
                                  Ist es eigentlich möglich SourceAnlaytix auch zusammen mit einem variablen Stromtarif (z.B. Tibber) zu nutzen?
                                  Ich habe zwei Datenpunkte: "Verbrauch" und "aktueller_Preis", in kWh und €ent/kWh.
                                  Kann ich den variablen Preis als Rechengröße in Sourceanalytix verwenden?
                                  Ich möchte gerne wissen, wie viel ich mit dem variablen Stromtarif gegenüber meinem aktuell noch festen Tarif sparen würde, damit ich eine fundierte Entscheidung treffen kann.
                                  Vielen Dank im Vorraus! Ich hoffe die Frage hat hier noch keiner gestellt, aber bei meiner Forumsuche ist nix bei rumgekommen.
                                    crunchip Forum Testing Most Active @badsnoopy667 last edited by
                                    @badsnoopy667 nein, variabel geht (noch) nicht
                                    • nieIP
                                      nieIP last edited by nieIP
                                      Hallo
                                      ich nutze Version 0.4.8
                                      Wegen dem Reset des Zählerstandes auf 0 würde ich wie einige Seiten vorher beschrieben die
                                      iobroker/node_modules/iobroker.sourceanalytix/main.js
                                      editieren.
                                      Oder gibt es schon eine online verfügbare neuere Version, wo der code mit drin ist??
                                      EDIT in der 0.4.15 scheint die Änderung schon drin zu sein. erledigt.
                                      nieIP 1 Reply Last reply Reply Quote 0
                                      • nieIP
                                        nieIP @derelvis last edited by nieIP
                                        frisch gestrichen
                                          Laser @nieIP last edited by Laser
                                          Frage hat sich gerade erledigt
                                          • nieIP
                                            nieIP @nieIP last edited by
                                            mit der Version 0.4.15 habe ich beim Adapterstart bei 4 vom 12 Geräten eine Fehlermeldung.
                                            Kann mir jemand sagen, in welche Richtung ich da suchen muss ??
                                            2023-12-08 18:53:09.125 - info: sourceanalytix.0 (946) Initialization of hm-rega.0.44242 successfully
                                            2023-12-08 18:53:09.127 - info: sourceanalytix.0 (946) Initialising "hm-rpc.0.KEQ0971587.2.ENERGY_COUNTER" | (2 of 12)
                                            2023-12-08 18:53:09.197 - error: sourceanalytix.0 (946) Check settings for hm-rpc.0.KEQ0971587.2.ENERGY_COUNTER ! Known valueAtDeviceReset : (6.9214) > known cumulative value (6.921399994000001) cannot proceed
                                            2023-12-08 18:53:09.198 - error: sourceanalytix.0 (946) Troubleshoot Data hm-rpc.0.KEQ0971587.2.ENERGY_COUNTER custom Data : {"type":"state","common":{"def":0,"type":"number","read":true,"write":false,"min":0,"max":838860.7,"unit":"Wh","name":"ZwStecker_21-GetraenkeKuehschrank.ENERGY_COUNTER","role":"value.power.consumption","custom":{"sql.0":{"enabled":true,"storageType":"","counter":false,"aliasId":"","debounceTime":0,"blockTime":0,"changesOnly":true,"changesRelogInterval":"86400","changesMinDelta":"0.01","ignoreBelowNumber":"","disableSkippedValueLogging":false,"retention":0,"customRetentionDuration":365,"maxLength":10,"enableDebugLogs":false,"debounce":100},"sourceanalytix.0":{"enabled":true,"selectedUnit":"Detect automatically","deviceResetLogicEnabled":true,"threshold":0.0001,"start_day":6.2118,"start_week":5.669600000000001,"start_month":4.7242,"start_quarter":28.578500000000002,"start_year":0,"alias":"Getraenke_Leistung_Analyse","selectedPrice":"Strombezug","costs":true,"consumption":true,"valueAtDeviceReset":6.9214,"valueAtDeviceInit":6.921399994000001,"cumulativeValue":6.2118}}},"native":{"CONTROL":"POWERMETER.ENERGY_COUNTER","DEFAULT":0,"FLAGS":1,"ID":"ENERGY_COUNTER","MAX":838860.7,"MIN":0,"OPERATIONS":5,"TAB_ORDER":0,"TYPE":"FLOAT","UNIT":"Wh"},"_id":"hm-rpc.0.KEQ0971587.2.ENERGY_COUNTER","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"from":"system.adapter.sourceanalytix.0","user":"system.user.admin","ts":1701967931210}
                                            2023-12-08 18:53:09.199 - error: sourceanalytix.0 (946) Cannot handle calculations for hm-rpc.0.KEQ0971587.2.ENERGY_COUNTER, check log messages and adjust settings!
                                            2023-12-08 18:53:09.202 - error: sourceanalytix.0 (946) Initialization of hm-rpc.0.KEQ0971587.2.ENERGY_COUNTER failed, check warn messages !
                                            2023-12-08 18:53:09.203 - info: sourceanalytix.0 (946) Initialising "hm-rpc.0.LEQ1344854.2.ENERGY_COUNTER" | (3 of 12)
                                            2023-12-08 18:53:09.264 - error: sourceanalytix.0 (946) Check settings for hm-rpc.0.LEQ1344854.2.ENERGY_COUNTER ! Known valueAtDeviceReset : (53.9896) > known cumulative value (53.989599976) cannot proceed
                                            2023-12-08 18:53:09.266 - error: sourceanalytix.0 (946) Troubleshoot Data hm-rpc.0.LEQ1344854.2.ENERGY_COUNTER custom Data : {"type":"state","common":{"def":0,"type":"number","read":true,"write":false,"min":0,"max":838860.7,"unit":"Wh","name":"ZwStecker_Server-2.ENERGY_COUNTER","role":"value.power.consumption","custom":{"sql.0":{"enabled":true,"storageType":"","counter":false,"aliasId":"","debounceTime":0,"blockTime":0,"changesOnly":true,"changesRelogInterval":"86400","changesMinDelta":"0.01","ignoreBelowNumber":"","disableSkippedValueLogging":false,"retention":0,"customRetentionDuration":365,"maxLength":0,"enableDebugLogs":false,"debounce":100},"sourceanalytix.0":{"enabled":true,"selectedUnit":"Detect automatically","deviceResetLogicEnabled":true,"threshold":0.001,"start_day":48.4355,"start_week":41.325300000000006,"start_month":30.6427,"start_quarter":380.38259999999997,"start_year":0,"alias":"Server_Leistung_Analyse","selectedPrice":"Strombezug","costs":true,"consumption":true,"valueAtDeviceReset":53.9896,"valueAtDeviceInit":53.989599976,"cumulativeValue":48.4355}}},"native":{"CONTROL":"POWERMETER.ENERGY_COUNTER","DEFAULT":0,"FLAGS":1,"ID":"ENERGY_COUNTER","MAX":838860.7,"MIN":0,"OPERATIONS":5,"TAB_ORDER":0,"TYPE":"FLOAT","UNIT":"Wh"},"_id":"hm-rpc.0.LEQ1344854.2.ENERGY_COUNTER","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"from":"system.adapter.sourceanalytix.0","user":"system.user.admin","ts":1701968924431}
                                            2023-12-08 18:53:09.267 - error: sourceanalytix.0 (946) Cannot handle calculations for hm-rpc.0.LEQ1344854.2.ENERGY_COUNTER, check log messages and adjust settings!
                                            2023-12-08 18:53:09.269 - error: sourceanalytix.0 (946) Initialization of hm-rpc.0.LEQ1344854.2.ENERGY_COUNTER failed, check warn messages !
                                            2023-12-08 18:53:09.270 - info: sourceanalytix.0 (946) Initialising "hm-rpc.0.MEQ0025548.1.GAS_ENERGY_COUNTER" | (4 of 12)
                                            2023-12-08 18:53:09.328 - error: sourceanalytix.0 (946) Check settings for hm-rpc.0.MEQ0025548.1.GAS_ENERGY_COUNTER ! Known valueAtDeviceReset : (2385.4) > known cumulative value (2385.399998) cannot proceed
                                            2023-12-08 18:53:09.329 - error: sourceanalytix.0 (946) Troubleshoot Data hm-rpc.0.MEQ0025548.1.GAS_ENERGY_COUNTER custom Data : {"type":"state","common":{"def":0,"type":"number","read":true,"write":false,"min":0,"max":2147483.644531,"unit":"m3","name":"GAS_Zaehler_1-Gas.GAS_ENERGY_COUNTER","custom":{"sql.0":{"enabled":true,"changesOnly":true,"debounce":"1200","retention":0,"changesRelogInterval":"86400","changesMinDelta":0.01,"aliasId":"","storageType":"","debounceTime":0,"blockTime":1200,"ignoreBelowNumber":"","disableSkippedValueLogging":false,"counter":false,"customRetentionDuration":365,"maxLength":10,"enableDebugLogs":false},"sourceanalytix.0":{"enabled":true,"selectedUnit":"m³","deviceResetLogicEnabled":true,"threshold":1,"start_day":2375.47,"start_week":2362.31,"start_month":2340.72,"start_quarter":2154.71,"start_year":1588,"alias":"Gas_Kosten_Analyse","selectedPrice":"Gas","costs":true,"consumption":true,"meter_values":true,"valueAtDeviceReset":2385.4,"valueAtDeviceInit":2385.399998,"cumulativeValue":2375.47}}},"native":{"CONTROL":"POWERMETER_IGL.GAS_ENERGY_COUNTER","DEFAULT":0,"FLAGS":1,"ID":"GAS_ENERGY_COUNTER","MAX":2147483.644531,"MIN":0,"OPERATIONS":5,"TAB_ORDER":0,"TYPE":"FLOAT","UNIT":"m3"},"_id":"hm-rpc.0.MEQ0025548.1.GAS_ENERGY_COUNTER","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"from":"system.adapter.sourceanalytix.0","user":"system.user.admin","ts":1701967948852}
                                            2023-12-08 18:53:09.330 - error: sourceanalytix.0 (946) Cannot handle calculations for hm-rpc.0.MEQ0025548.1.GAS_ENERGY_COUNTER, check log messages and adjust settings!
                                            2023-12-08 18:53:09.332 - error: sourceanalytix.0 (946) Initialization of hm-rpc.0.MEQ0025548.1.GAS_ENERGY_COUNTER failed, check warn messages !
                                            2023-12-08 18:53:09.333 - info: sourceanalytix.0 (946) Initialising "hm-rpc.0.OEQ0070768.2.ENERGY_COUNTER" | (5 of 12)
                                            2023-12-08 18:53:09.396 - error: sourceanalytix.0 (946) Check settings for hm-rpc.0.OEQ0070768.2.ENERGY_COUNTER ! Known valueAtDeviceReset : (13.8524) > known cumulative value (13.852399997) cannot proceed
                                            2023-12-08 18:53:09.397 - error: sourceanalytix.0 (946) Troubleshoot Data hm-rpc.0.OEQ0070768.2.ENERGY_COUNTER custom Data : {"type":"state","common":{"def":0,"type":"number","read":true,"write":false,"min":0,"max":838860.699219,"unit":"Wh","name":"Klimatruhe-2-Klima.ENERGY_COUNTER","custom":{"sql.0":{"enabled":true,"changesOnly":true,"debounce":"1200","retention":0,"changesRelogInterval":"86400","changesMinDelta":0.01,"storageType":"","aliasId":"","debounceTime":0,"blockTime":1200,"ignoreBelowNumber":"","disableSkippedValueLogging":false,"counter":false,"customRetentionDuration":365,"maxLength":10,"enableDebugLogs":false},"sourceanalytix.0":{"enabled":true,"selectedUnit":"Detect automatically","deviceResetLogicEnabled":true,"threshold":0.001,"start_day":6.9262,"start_week":6.9262,"start_month":6.9262,"start_quarter":335.2113,"start_year":0,"alias":"Klima_Leistung_Analyse","selectedPrice":"Strombezug","costs":true,"consumption":true,"valueAtDeviceReset":13.8524,"valueAtDeviceInit":6.926199996999999,"cumulativeValue":6.9262}},"role":"value.power.consumption"},"native":{"CONTROL":"POWERMETER.ENERGY_COUNTER","DEFAULT":0,"FLAGS":1,"ID":"ENERGY_COUNTER","MAX":838860.699219,"MIN":0,"OPERATIONS":5,"TAB_ORDER":0,"TYPE":"FLOAT","UNIT":"Wh"},"_id":"hm-rpc.0.OEQ0070768.2.ENERGY_COUNTER","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"from":"system.adapter.sourceanalytix.0","user":"system.user.admin","ts":1701968930074}
                                            2023-12-08 18:53:09.398 - error: sourceanalytix.0 (946) Cannot handle calculations for hm-rpc.0.OEQ0070768.2.ENERGY_COUNTER, check log messages and adjust settings!
                                            2023-12-08 18:53:09.398 - error: sourceanalytix.0 (946) Initialization of hm-rpc.0.OEQ0070768.2.ENERGY_COUNTER failed, check warn messages !
                                            2023-12-08 18:53:09.399 - info: sourceanalytix.0 (946) Initialising "hm-rpc.1.0001D3C990BF8F.6.ENERGY_COUNTER" | (6 of 12)
                                            2023-12-08 18:53:16.583 - info: sourceanalytix.0 (946) Initialization of hm-rpc.1.0001D3C990BF8F.6.ENERGY_COUNTER successfully
                                            2023-12-08 18:53:16.585 - info: sourceanalytix.0 (946) Initialising "hm-rpc.1.0001D3C99C6758.6.ENERGY_COUNTER" | (7 of 12)
                                            2023-12-08 18:53:23.519 - info: sourceanalytix.0 (946) Initialization of hm-rpc.1.0001D3C99C6758.6.ENERGY_COUNTER successfully
                                            2023-12-08 18:53:23.520 - info: sourceanalytix.0 (946) Initialising "hm-rpc.1.0001D70994EA29.6.ENERGY_COUNTER" | (8 of 12)
                                            2023-12-08 18:53:30.298 - info: sourceanalytix.0 (946) Initialization of hm-rpc.1.0001D70994EA29.6.ENERGY_COUNTER successfully
                                            2023-12-08 18:53:30.298 - info: sourceanalytix.0 (946) Initialising "hm-rpc.1.0001D70994EA37.6.ENERGY_COUNTER" | (9 of 12)
                                            1.0k
                                            81.1k
                                            2302
                                            1149120
