keine Geräte im Zigbee Adapter [gelöst - Vielen Dank]
Ich seh nix. Text auch als Text in CodeTags eingebettet hier rein.
Kommt gleich..Zwischenstand:
======================= SUMMARY ======================= v.2023-10-10 Static hostname: iobroker Icon name: computer-vm Chassis: vm Virtualization: microsoft Operating System: Ubuntu 20.04.6 LTS Kernel: Linux 5.4.0-166-generic Architecture: x86-64 Installation: microsoft Kernel: x86_64 Userland: amd64 Timezone: Europe/Berlin (CET, +0100) User-ID: 1000 X-Server: false Boot Target: graphical.target Pending OS-Updates: 0 node:internal/modules/cjs/loader:1080 throw err; ^ Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js' at Module._resolveFilename (node:internal/modules/cjs/loader:1077:15) at Module._load (node:internal/modules/cjs/loader:922:27) at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:86:12) at node:internal/main/run_main_module:23:47 { code: 'MODULE_NOT_FOUND', requireStack: [] } Node.js v18.18.2 Pending iob updates: 0 Nodejs-Installation: /usr/bin/nodejs v18.18.2 /usr/bin/node v18.18.2 /usr/bin/npm 9.8.1 /usr/bin/npx 9.8.1 /usr/bin/corepack 0.19.0 Recommended versions are nodejs and npm Your nodejs installation is correct MEMORY: total used free shared buff/cache available Mem: 3.9G 423M 2.3G 0.0K 1.2G 3.2G Swap: 2.0G 43M 1.9G Total: 5.9G 467M 4.2G node:internal/modules/cjs/loader:1080 throw err; ^ Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js' at Module._resolveFilename (node:internal/modules/cjs/loader:1077:15) at Module._load (node:internal/modules/cjs/loader:922:27) at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:86:12) at node:internal/main/run_main_module:23:47 { code: 'MODULE_NOT_FOUND', requireStack: [] } Node.js v18.18.2 Active iob-Instances: 0 node:internal/modules/cjs/loader:1080 throw err; ^ Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js' at Module._resolveFilename (node:internal/modules/cjs/loader:1077:15) at Module._load (node:internal/modules/cjs/loader:922:27) at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:86:12) at node:internal/main/run_main_module:23:47 { code: 'MODULE_NOT_FOUND', requireStack: [] } Node.js v18.18.2 node:internal/modules/cjs/loader:1080 throw err; ^ Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js' at Module._resolveFilename (node:internal/modules/cjs/loader:1077:15) at Module._load (node:internal/modules/cjs/loader:922:27) at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:86:12) at node:internal/main/run_main_module:23:47 { code: 'MODULE_NOT_FOUND', requireStack: [] } Node.js v18.18.2 ioBroker Core: js-controller node:internal/modules/cjs/loader:1080 throw err; ^ Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js' at Module._resolveFilename (node:internal/modules/cjs/loader:1077:15) at Module._load (node:internal/modules/cjs/loader:922:27) at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:86:12) at node:internal/main/run_main_module:23:47 { code: 'MODULE_NOT_FOUND', requireStack: [] } Node.js v18.18.2 admin node:internal/modules/cjs/loader:1080 throw err; ^ Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js' at Module._resolveFilename (node:internal/modules/cjs/loader:1077:15) at Module._load (node:internal/modules/cjs/loader:922:27) at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:86:12) at node:internal/main/run_main_module:23:47 { code: 'MODULE_NOT_FOUND', requireStack: [] } Node.js v18.18.2 ioBroker Status: Status admin and web instance: node:internal/modules/cjs/loader:1080 throw err; ^ Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js' at Module._resolveFilename (node:internal/modules/cjs/loader:1077:15) at Module._load (node:internal/modules/cjs/loader:922:27) at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:86:12) at node:internal/main/run_main_module:23:47 { code: 'MODULE_NOT_FOUND', requireStack: [] } Node.js v18.18.2 Objects: 0 States: 0 Size of iob-Database: 16M /opt/iobroker/iobroker-data/objects.jsonl 9.7M /opt/iobroker/iobroker-data/objects.json.migrated 9.7M /opt/iobroker/iobroker-data/objects.json.bak.migrated 0 /opt/iobroker/iobroker-data/objects.json.broken 2.6M /opt/iobroker/iobroker-data/states.jsonl 1.3M /opt/iobroker/iobroker-data/states.json.migrated 1.3M /opt/iobroker/iobroker-data/states.json.bak.migrated 0 /opt/iobroker/iobroker-data/states.json.broken =================== END OF SUMMARY ====================
ich kann Dir den Text vom Energieflussadapter nicht reinkopieren, im moment kann ich nichtmal den Admin Adapter aufrufen. Hab versucht den manuell zu starten, Dann kommt das
iob start admin node:internal/modules/cjs/loader:1080 throw err; ^ Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js' at Module._resolveFilename (node:internal/modules/cjs/loader:1077:15) at Module._load (node:internal/modules/cjs/loader:922:27) at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:86:12) at node:internal/main/run_main_module:23:47 { code: 'MODULE_NOT_FOUND', requireStack: [] } Node.js v18.18.2
cd /opt/iobroker sudo -H -u iobroker npm install iobroker.js-controller
/opt/iobroker$ sudo -H -u iobroker npm install iobroker.js-controller (#####⠂⠂⠂⠂⠂⠂⠂⠂⠂⠂⠂⠂⠂) ⠸ idealTree:@root/greenlock: sill placeDep ROOT @root/keypairs@0.9.0 OK for: greenlock@4.0.(#####⠂⠂⠂⠂⠂⠂⠂⠂⠂⠂⠂⠂⠂) ⠸ idealTree:@root/greenlock: sill placeDep ROOT @root/keypairs@0.9.0 OK for: greenlock@4.0.npm WARN skipping integrity check for git dependency ssh://git@github.com/SKB-CGN/ioBroker.energiefluss.git npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies. npm WARN deprecated crypto@1.0.1: This package is no longer supported. It's now a built-in Node module. If you've depended on crypto, you should switch to the one that's built-in. npm WARN deprecated @types/bl@5.1.0: This is a stub types definition. bl provides its own type definitions, so you do not need this installed. npm WARN deprecated source-map-url@0.4.1: See https://github.com/lydell/source-map-url#deprecated npm WARN deprecated request-promise-native@1.0.9: request-promise-native has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142 npm WARN deprecated urix@0.1.0: Please see https://github.com/lydell/urix#deprecated npm WARN deprecated string-similarity@4.0.4: Package no longer supported. Contact Support at https://www.npmjs.com/support for more info. npm WARN deprecated har-validator@5.1.5: this library is no longer supported npm WARN deprecated resolve-url@0.2.1: https://github.com/lydell/resolve-url#deprecated npm WARN deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3 npm WARN deprecated source-map-resolve@0.5.3: See https://github.com/lydell/source-map-resolve#deprecated npm WARN deprecated w3c-hr-time@1.0.2: Use your platform's native performance.now() and performance.timeOrigin. npm WARN deprecated xmldom@0.1.31: Deprecated due to CVE-2021-21366 resolved in 0.5.0 npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained. npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797) npm WARN deprecated querystring@0.2.0: The querystring API is considered Legacy. new code should use the URLSearchParams API instead. npm WARN deprecated phantomjs-prebuilt@2.1.16: this package is now deprecated npm WARN deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details. npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142 npm WARN deprecated axios@0.19.2: Critical security vulnerability fixed in v0.21.1. For more information, see https://github.com/axios/axios/pull/3410 npm WARN deprecated xmldom@0.1.16: Deprecated due to CVE-2021-21366 resolved in 0.5.0 added 6 packages, and changed 1963 packages in 15m 176 packages are looking for funding run `npm fund` for details iobroker@iobroker:/opt/iobroker$ npm fund iobroker.inst@2.0.3 ├── https://github.com/sponsors/jaredhanson │ └── passport@0.5.3 ├── https://github.com/sponsors/RubenVerborgh │ └── follow-redirects@1.15.3 ├── https://github.com/sponsors/ljharb │ └── qs@6.11.0, side-channel@1.0.4, call-bind@1.0.5, function-bind@1.1.2, gopd@1.0.1, has-property-descriptors@1.0.1, get-intrinsic@1.2.2, has-proto@1.0.1, has-symbols@1.0.3, object-inspect@1.13.1, is-arguments@1.1.1, has-tostringtag@1.0.0, is-generator-function@1.0.10, is-typed-array@1.1.12, which-typed-array@1.1.13, available-typed-arrays@1.0.5, is-callable@1.2.7, resolve@1.22.8, is-core-module@2.13.1, supports-preserve-symlinks-flag@1.0.0, minimist@1.2.8, is-nan@1.3.2, define-properties@1.2.1, object-is@1.1.5, traverse@0.6.7, is-object@1.0.2, deep-equal@1.1.2, is-date-object@1.0.5, is-regex@1.1.4, regexp.prototype.flags@1.5.1, functions-have-names@1.2.3, object.assign@4.1.4 ├── https://github.com/sponsors/feross │ └── safe-buffer@5.2.1, base64-js@1.5.1, ieee754@1.2.1, simple-concat@1.0.1, buffer@6.0.3, run-parallel@1.2.0, queue-microtask@1.2.3 ├── https://github.com/sponsors/broofa │ └── uuid@9.0.1 ├── https://github.com/sponsors/sindresorhus │ └── is-stream@2.0.1, responselike@2.0.1, clone-response@1.0.3, get-stream@5.2.0, normalize-url@6.1.0, component-emitter@1.3.1, make-dir@3.1.0, mimic-response@2.1.0, onetime@5.1.2, multimatch@5.0.0, throttleit@1.0.1, sort-keys@4.2.0, p-limit@2.3.0, p-queue@6.6.2, any-observable@0.5.1, del@6.1.1, globby@11.1.0, p-map@4.0.0, escape-goat@3.0.0, escape-string-regexp@4.0.0, import-local@3.1.0, is-installed-globally@0.3.2, global-dirs@2.1.0, log-symbols@4.1.0, is-unicode-supported@0.1.0, meow@8.1.2, camelcase-keys@6.2.2, map-obj@4.3.0, decamelize-keys@1.1.1, type-fest@0.18.1, npm-name@6.0.1, p-event@4.2.0, type-fest@0.10.0, is-url-superb@4.0.0, open@7.4.2, is-docker@2.2.1, ow@0.21.0, dot-prop@6.0.1, type-fest@0.20.2, p-settle@4.1.1, read-pkg-up@7.0.1, terminal-link@2.1.1, boxen@5.1.2, camelcase@6.3.0, cli-boxes@2.2.1, is-installed-globally@0.4.0, global-dirs@3.0.1, is-npm@5.0.0, import-fresh@3.3.0, parse-json@5.2.0, ansi-escapes@4.3.2, type-fest@0.21.3, figures@3.2.0, find-up@5.0.0, locate-path@6.0.0, p-locate@5.0.0, p-limit@3.1.0, yocto-queue@0.1.0, hex-rgb@4.3.0 ├─┬ https://github.com/sindresorhus/got?sponsor=1 │ │ └── got@11.8.6, got@10.7.0 │ └── https://github.com/sindresorhus/is?sponsor=1 │ └── @sindresorhus/is@4.6.0, @sindresorhus/is@2.1.1 ├── https://github.com/sponsors/epoberezkin │ └── ajv@6.12.6 ├── https://github.com/sponsors/NaturalIntelligence │ └── fast-xml-parser@4.3.2 ├── https://github.com/sponsors/isaacs │ └── minimatch@9.0.3, rimraf@3.0.2, glob@7.2.3 ├─┬ https://opencollective.com/node-fetch │ │ └── node-fetch@3.3.2 │ └── https://github.com/sponsors/jimmywarting │ └── fetch-blob@3.2.0, node-domexception@1.0.0 ├── https://opencollective.com/serialport/donate │ └── serialport@10.5.0, @serialport/bindings-cpp@10.8.0, @serialport/parser-byte-length@10.5.0, @serialport/parser-cctalk@10.5.0, @serialport/parser-delimiter@10.5.0, @serialport/parser-inter-byte-timeout@10.5.0, @serialport/parser-readline@10.5.0, @serialport/parser-ready@10.5.0, @serialport/parser-regex@10.5.0, @serialport/parser-slip-encoder@10.5.0, @serialport/parser-spacepacket@10.5.0, @serialport/stream@10.5.0, @serialport/bindings-cpp@12.0.1, @serialport/parser-delimiter@12.0.0, @serialport/stream@12.0.0 ├── https://www.buymeacoffee.com/systeminfo │ └── systeminformation@5.21.17 ├── https://opencollective.com/date-fns │ └── date-fns@2.30.0 ├── https://opencollective.com/ioredis │ └── ioredis@4.28.5 ├── https://github.com/sindresorhus/execa?sponsor=1 │ └── execa@5.1.1 ├─┬ https://paulmillr.com/funding/ │ │ └── chokidar@3.5.3 │ └── https://github.com/sponsors/jonschlinkert │ └── picomatch@2.3.1, set-value@4.1.0 ├── https://github.com/sponsors/sibiraj-s │ └── ci-info@3.9.0 ├─┬ https://github.com/chalk/wrap-ansi?sponsor=1 │ │ └── wrap-ansi@7.0.0 │ └── https://github.com/chalk/ansi-styles?sponsor=1 │ └── ansi-styles@4.3.0 ├── https://opencollective.com/browserslist │ └── browserslist@4.22.1, caniuse-lite@1.0.30001563, update-browserslist-db@1.0.13 ├── https://opencollective.com/core-js │ └── core-js@3.33.3, core-js-compat@3.33.3 ├─┬ https://opencollective.com/javascript-obfuscator │ │ └── javascript-obfuscator@3.2.7 │ └── https://github.com/chalk/chalk?sponsor=1 │ └── chalk@4.1.2 ├── https://github.com/sponsors/wooorm │ └── levenshtein-edit-distance@2.0.5 ├── https://opencollective.com/js-sdsl │ └── js-sdsl@4.3.0 └─┬ https://github.com/sindresorhus/np?sponsor=1 │ └── np@7.7.0 ├── https://github.com/sindresorhus/p-memoize?sponsor=1 │ └── p-memoize@4.0.4 └── https://github.com/yeoman/update-notifier?sponsor=1 └── update-notifier@5.1.0
Die Web Oberfläche klappt wieder , ENERGIEFLUSS läßt sich deinstallieren.
Dann bleibt noch der fronius
Kurzes Status Update.
Ich update gerade 30 Adapter, pro Adapter dauert es anscheinend mehr als 5 Minuten. -
Ja, das ist möglich.
das Updaten der Adapter dauert leider sehr lange.
Es gibt bei einigen Adaptern Fehlermeldungen sowohl beim Updaten, als auch beim löschen wie z.B. hier bei Openweather Map.
Da steht man soll den Adapter von Hand löschen, aber trotz intensiver suche weiss ich nicht wo die Dateien liegen. Da brauch ich noch einmal Hilfe:ERROR: Process exited with code 25 weniger mehr $ iobroker upgrade openweathermap@0.4.5 Update openweathermap from @0.3.11 to @0.4.5 NPM version: 9.8.1 Installing iobroker.openweathermap@0.4.5... (System call) host.iobroker Cannot install iobroker.openweathermap@0.4.5: 217 ERROR: Process exited with code 25
Ich hab die meisten Module hier gefunden, aber nicht openweathermap
/opt/iobroker/iobroker-data/files$ ls admin.admin javascript.admin vis-2-beta alias-manager.admin knx.admin vis-2-beta.0 backitup.admin lg-thinq.admin vis-2-beta.admin bydbatt.admin lgtv.admin vis.admin bydhvs.admin midea.admin vis-bars.admin cloud.admin mihome.admin vis-canvas-gauges.admin daswetter.admin mihome-vacuum.admin vis-colorpicker.admin device-reminder.admin mobile vis-fancyswitch.admin discovery.admin mobile.admin vis-google-fonts.admin dwd.admin moma.admin vis-history.admin easee.admin onkyo.admin vis-hqwidgets.admin echarts parser.admin vis-icontwo echarts.admin phantomjs.admin vis-icontwo.admin fakeroku.admin pi-hole.admin vis-inventwo.admin feiertage.admin ping.admin vis-jqui-mfd.admin flot pvforecast.admin vis-justgage.admin flot.admin sayit.0 vis-keyboard.admin fronius.admin sayit.admin vis-lcars.admin fronius-solarweb.admin scenes.admin vis-map.admin habpanel schwoerer-ventcube.admin vis-material.admin habpanel.admin shelly.0 vis-material-advanced.admin harmony.admin shelly.admin vis-metro.admin history.admin shuttercontrol.admin vis-players.admin ical.admin simple-api.admin vis-plumb.admin icons-addictive-flavour-png socketio.admin vis-rgraph.admin icons-addictive-flavour-png.admin sonoff.admin vis-timeandweather.admin icons-mfd-svg sourceanalytix.admin vis-weather.admin icons-mfd-svg.admin tado.admin web icons-open-icon-library-png tankerkoenig.admin web.admin icons-open-icon-library-png.admin tr-064.admin web-speedy.admin influxdb.admin trashschedule.admin wifilight.admin info.admin tuya.admin wled.admin iqontrol.meta unifi.admin zigbee.admin jarvis vis jarvis.admin vis.0
Ok, mach ich.Ich hab da ganz viel Meldungen vom Tpy
chown: changing ownership of '/opt/iobroker/backups/sqlite_2023_09_26-02_01_42_backupiobroker.sql': Permission denied chown: changing ownership of '/opt/iobroker/backups/influxDB_2023_10_30-02_01_00_backupiobroker.tar.gz': Permission denied chown: changing ownership of '/opt/iobroker/backups/influxDB_2023_09_13-02_00_24_backupiobroker.tar.gz': Permission denied chown: changing ownership of '/opt/iobroker/backups/iobroker_2023_03_08-02_00_21_backupiobroker.tar.gz': Permission denied chown: changing ownership of '/opt/iobroker/backups/iobroker_2023_10_04-02_00_22_backupiobroker.tar.gz': Permission denied chown: changing ownership of '/opt/iobroker/backups/sqlite_2023_09_18-02_01_41_backupiobroker.sql': Permission denied chown: changing ownership of '/opt/iobroker/backups/iobroker_2023_10_02-02_00_22_backupiobroker.tar.gz': Permission denied chown: changing ownership of '/opt/iobroker/backups/zigbee.0_2023_03_05-02_01_29_backupiobroker.tar.gz': Permission denied chown: changing ownership of '/opt/iobroker/backups/influxDB_2023_10_21-02_00_43_backupiobroker.tar.gz': Permission denied chown: changing ownership of '/opt/iobroker/backups/iobroker_2023_09_28-02_00_22_backupiobroker.tar.gz': Permission denied chown: changing ownership of '/opt/iobroker/backups/sqlite_2023_11_09-02_01_14_backupiobroker.sql': Permission denied chown: changing ownership of '/opt/iobroker/backups/influxDB_2023_09_29-02_00_45_backupiobroker.tar.gz': Permission denied chown: changing ownership of '/opt/iobroker/backups': Permission denied This system does not support setting default permissions. Do not use npm to manually install adapters unless you know what you are doing!
Ich hatte mal gelesen das man IOB mit SUDO nicht machen sollte.
Gilt das auch für IOB FIX ? -
@wolkenloser sagte in keine Geräte im Zigbee Adapter - funktioniert aber.:
Das gilt FÜR ALLES was mit iob / iobroker zu tun hat...
Nie, nie, niemals sudo vor iob / iobroker-Kommandos setzen. NIE!Das führt nämlich genau zu solch krummen Kisten wie bei dir gerade.
ok, hast Du trotzdem eine Idee wie ich den Backupordner wieder grade ziehen kann ?/opt/iobroker$ ls -l total 344 drwxrwxr-x+ 2 iobroker iobroker 4096 Sep 11 2022 backups drwxrwxr-x+ 2 iobroker iobroker 4096 Jan 11 2020 cache -rwxrwxrwx+ 1 iobroker iobroker 1049 Okt 19 2019 CHANGELOG_FIXER_LINUX.md -rwxrwxrwx+ 1 iobroker iobroker 3556 Okt 19 2019 CHANGELOG_INSTALLER_LINUX.md -rwxrwxrwx+ 1 iobroker iobroker 23988 Okt 19 2019 fix_installation.sh drwxrwxrwx+ 3 iobroker iobroker 4096 Okt 19 2019 install -rwxrwxrwx+ 1 iobroker iobroker 1938 Nov 21 10:50 INSTALLER_INFO.txt lrwxrwxrwx 1 iobroker iobroker 22 Nov 21 10:50 iob -> /opt/iobroker/iobroker -rwxr-xr-x+ 1 iobroker iobroker 677 Nov 21 10:50 iobroker drwxrwxrwx+ 15 iobroker iobroker 4096 Nov 21 10:54 iobroker-data drwxrwxrwx+ 2 iobroker iobroker 4096 Okt 19 2019 lib -rwxrwxrwx+ 1 iobroker iobroker 1137 Okt 19 2019 LICENSE drwxrwxrwx+ 2 iobroker iobroker 4096 Nov 21 11:08 log drwxrwxr-x+ 2293 iobroker iobroker 86016 Nov 21 11:02 node_modules -rwxrwxrwx+ 1 iobroker iobroker 3889 Nov 20 19:58 package.json -rwxrwxrwx+ 1 iobroker iobroker 169201 Okt 19 2019 package-lock.json -rwxrwxrwx+ 1 iobroker iobroker 6101 Okt 19 2019 README.md -rwxrwxrwx+ 1 iobroker iobroker 5693 Aug 11 2021 reinstall.js
hat geholfenProcess exited with code 0 weniger mehr $ iobroker del openweathermap --custom Delete adapter "openweathermap" host.iobroker object openweathermap deleted host.iobroker object openweathermap.admin deleted added 5 packages, removed 843 packages, and changed 2303 packages in 13m263 packages are looking for funding run `npm fund` for details Adapter "system.adapter.vis.0" restarted. Adapter "system.adapter.vis-2-beta.0" restarted. Process exited with code 0
hat geholfen
Natürlich. Wenn man mit dem iobroker richtig umgeht funktioniert das auch.
@thomas-braun sagte in keine Geräte im Zigbee Adapter - funktioniert aber.:
hat geholfen
Der ursprüngliche Fehler besteht auch immer noch.
Keine Geräte im Zigbee Adapter.Ich habe aber noch 5 Adapter die sich derzeit micht Updaten lassen.
Meistens nach IOB FIX geht es wiieder für ein paar Adapter.
Das versuche ich erstmal sauber zu bekommen.
Und dann steht da immer noch das HOST Update im IOBROKER....Beim Zigbee hab ich die Befürchtung, wenn ich den gelöscht bekomme und dann neu installiere muß ich alle Datenpunkte in meinen Scripten neu zuordnen, Oder ?
Ich habe mehrere Bewegungsmelder, Türkontakte und Thermometer im Einsatz -
noch 3
Ich habe es jetzt endlich geschafft.
Alle Adapter sind up to Date.
Ich bin jetzt an der Stelle wo ich den Host updaten kann.In der Anweisung stehen folgende Befehle.
Ist das jetzt anzuraten oder lieber nicht ?
Beim letzen Versuch lief bei mir der IOBROKER nicht mehriobroker stop iobroker update iobroker fix iobroker upgrade self iobroker start
Aktueller stand ist derzeit
Skript v.2023-10-10 *** BASE SYSTEM *** Static hostname: iobroker Icon name: computer-vm Chassis: vm Virtualization: microsoft Operating System: Ubuntu 20.04.6 LTS Kernel: Linux 5.4.0-167-generic Architecture: x86-64 model name : Intel(R) Celeron(R) CPU J3455 @ 1.50GHz Docker : false Virtualization : microsoft Kernel : x86_64 Userland : amd64 Systemuptime and Load: 10:47:12 up 1:35, 1 user, load average: 0.16, 0.26, 0.52 CPU threads: 4 *** Time and Time Zones *** Local time: Wed 2023-11-22 10:47:12 CET Universal time: Wed 2023-11-22 09:47:12 UTC RTC time: Wed 2023-11-22 09:47:13 Time zone: Europe/Berlin (CET, +0100) System clock synchronized: yes NTP service: active RTC in local TZ: no *** User and Groups *** iobroker /home/iobroker iobroker adm tty dialout cdrom sudo audio dip video plugdev lxd *** X-Server-Setup *** X-Server: false Desktop: Terminal: tty Boot Target: graphical.target *** MEMORY *** total used free shared buff/cache available Mem: 5.9G 497M 3.4G 1.0M 2.0G 5.2G Swap: 2.0G 15M 2.0G Total: 7.9G 512M 5.4G 5929 M total memory 497 M used memory 975 M active memory 910 M inactive memory 3409 M free memory 378 M buffer memory 1643 M swap cache 1969 M total swap 15 M used swap 1954 M free swap *** FAILED SERVICES *** UNIT LOAD ACTIVE SUB DESCRIPTION * iobroker.service loaded failed failed ioBroker Server LOAD = Reflects whether the unit definition was properly loaded. ACTIVE = The high-level unit activation state, i.e. generalization of SUB. SUB = The low-level unit activation state, values depend on unit type. 1 loaded units listed. *** FILESYSTEM *** Filesystem Type Size Used Avail Use% Mounted on udev devtmpfs 2.9G 0 2.9G 0% /dev tmpfs tmpfs 593M 1.2M 592M 1% /run /dev/sda2 ext4 50G 34G 13G 73% / tmpfs tmpfs 2.9G 0 2.9G 0% /dev/shm tmpfs tmpfs 5.0M 0 5.0M 0% /run/lock tmpfs tmpfs 2.9G 0 2.9G 0% /sys/fs/cgroup /dev/loop3 squashfs 56M 56M 0 100% /snap/core18/2796 /dev/loop0 squashfs 106M 106M 0 100% /snap/core/16202 /dev/loop2 squashfs 56M 56M 0 100% /snap/core18/2790 /dev/loop5 squashfs 64M 64M 0 100% /snap/core20/2015 /dev/loop1 squashfs 106M 106M 0 100% /snap/core/16091 /dev/loop4 squashfs 64M 64M 0 100% /snap/core20/1974 /dev/loop6 squashfs 92M 92M 0 100% /snap/lxd/23991 /dev/loop8 squashfs 128K 128K 0 100% /snap/ncdu/62 /dev/loop7 squashfs 92M 92M 0 100% /snap/lxd/24061 /dev/loop9 squashfs 128K 128K 0 100% /snap/ncdu/64 /dev/loop10 squashfs 4.3M 4.3M 0 100% /snap/tree/18 tmpfs tmpfs 593M 0 593M 0% /run/user/1000 Messages concerning ext4 filesystem in dmesg: [Wed Nov 22 09:11:55 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null) [Wed Nov 22 09:12:02 2023] EXT4-fs (sda2): re-mounted. Opts: (null) Show mounted filesystems \(real ones only\): TARGET SOURCE FSTYPE OPTIONS / /dev/sda2 ext4 rw,relatime |-/sys/kernel/tracing tracefs tracefs rw,nosuid,nodev,noexec,relatime |-/snap/core18/2796 /dev/loop3 squashfs ro,nodev,relatime |-/snap/core/16202 /dev/loop0 squashfs ro,nodev,relatime |-/snap/core18/2790 /dev/loop2 squashfs ro,nodev,relatime |-/snap/core20/2015 /dev/loop5 squashfs ro,nodev,relatime |-/snap/core/16091 /dev/loop1 squashfs ro,nodev,relatime |-/snap/core20/1974 /dev/loop4 squashfs ro,nodev,relatime |-/snap/lxd/23991 /dev/loop6 squashfs ro,nodev,relatime |-/snap/ncdu/62 /dev/loop8 squashfs ro,nodev,relatime |-/snap/lxd/24061 /dev/loop7 squashfs ro,nodev,relatime |-/snap/ncdu/64 /dev/loop9 squashfs ro,nodev,relatime `-/snap/tree/18 /dev/loop10 squashfs ro,nodev,relatime Files in neuralgic directories: /var: 5.6G /var/ 4.0G /var/log/journal/4c4f1c196fd742fb8ea78816d6e03b15 4.0G /var/log/journal 4.0G /var/log 1.5G /var/lib Archived and active journals take up 3.9G in the file system. /opt/iobroker/backups: 12M /opt/iobroker/backups/ /opt/iobroker/iobroker-data: 17G /opt/iobroker/iobroker-data/ 16G /opt/iobroker/iobroker-data/history 668M /opt/iobroker/iobroker-data/files 155M /opt/iobroker/iobroker-data/backup-objects 113M /opt/iobroker/iobroker-data/files/vis-2-beta The five largest files in iobroker-data are: 24M /opt/iobroker/iobroker-data/files/echarts/static/js/main.5f66c5d9.js.map 24M /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.9f2a6569.js.map 24M /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.5f66c5d9.js.map 21M /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map 17M /opt/iobroker/iobroker-data/files/echarts/preview/static/js/main.f79fb97a.js.map USB-Devices by-id: USB-Sticks - Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id': /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0 *** NodeJS-Installation *** /usr/bin/nodejs v18.18.2 /usr/bin/node v18.18.2 /usr/bin/npm 9.8.1 /usr/bin/npx 9.8.1 /usr/bin/corepack 0.19.0 nodejs: Installed: 18.18.2-1nodesource1 Candidate: 18.18.2-1nodesource1 Version table: *** 18.18.2-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 100 /var/lib/dpkg/status 18.18.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.18.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.17.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.17.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.16.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.16.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.15.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.14.2-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.14.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.14.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.13.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.12.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.11.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.10.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.9.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.9.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.8.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.7.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.6.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.5.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.4.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.3.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.2.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.1.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.0.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 10.19.0~dfsg-3ubuntu1.3 500 500 http://de.archive.ubuntu.com/ubuntu focal-updates/universe amd64 Packages 500 http://de.archive.ubuntu.com/ubuntu focal-security/universe amd64 Packages 10.19.0~dfsg-3ubuntu1 500 500 http://de.archive.ubuntu.com/ubuntu focal/universe amd64 Packages Temp directories causing npm8 problem: 0 No problems detected Errors in npm tree: npm ERR! code ELSPROBLEMS npm ERR! invalid: iobroker.fronius@2.0.2 /opt/iobroker/node_modules/iobroker.fronius npm ERR! invalid: iobroker.labcom@0.1.1 /opt/iobroker/node_modules/iobroker.labcom npm ERR! invalid: eiscp@0.0.1 /opt/iobroker/node_modules/eiscp npm ERR! invalid: buffer@5.7.1 /opt/iobroker/node_modules/buffer npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-22T09_47_33_666Z-debug-0.log *** ioBroker-Installation *** ioBroker Status iobroker is not running on this host. Objects type: jsonl States type: jsonl Core adapters versions js-controller: 4.0.24 admin: 6.12.0 javascript: 7.1.4 npm ERR! code ELSPROBLEMS npm ERR! invalid: iobroker.fronius@2.0.2 /opt/iobroker/node_modules/iobroker.fronius npm ERR! invalid: iobroker.labcom@0.1.1 /opt/iobroker/node_modules/iobroker.labcom npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-22T09_48_06_617Z-debug-0.log Adapters from github: 2 Adapter State system.adapter.admin.0 : admin : iobroker - enabled, port: 8081, bind: 0.0.0.0, run as: admin system.adapter.alias-manager.0 : alias-manager : iobroker - disabled system.adapter.backitup.0 : backitup : iobroker - enabled system.adapter.discovery.0 : discovery : iobroker - disabled system.adapter.easee.0 : easee : iobroker - disabled system.adapter.echarts.0 : echarts : iobroker - enabled system.adapter.fakeroku.0 : fakeroku : iobroker - enabled system.adapter.flot.0 : flot : iobroker - disabled system.adapter.fronius-solarweb.0 : fronius-solarweb : iobroker - enabled system.adapter.fronius.0 : fronius : iobroker - enabled system.adapter.habpanel.0 : habpanel : iobroker - disabled system.adapter.harmony.0 : harmony : iobroker - enabled system.adapter.history.0 : history : iobroker - enabled system.adapter.ical.0 : ical : iobroker - enabled system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: iobroker - disabled system.adapter.icons-mfd-svg.0 : icons-mfd-svg : iobroker - enabled system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker - disabled system.adapter.influxdb.0 : influxdb : iobroker - enabled, port: 8086 system.adapter.info.0 : info : iobroker - enabled system.adapter.jarvis.0 : jarvis : iobroker - disabled system.adapter.javascript.0 : javascript : iobroker - enabled system.adapter.knx.0 : knx : iobroker - enabled, bind: 192.168.8.67 system.adapter.lg-thinq.0 : lg-thinq : iobroker - enabled system.adapter.lgtv.0 : lgtv : iobroker - enabled system.adapter.mobile.0 : mobile : iobroker - disabled system.adapter.moma.0 : moma : iobroker - enabled system.adapter.onkyo.0 : onkyo : iobroker - enabled system.adapter.openweathermap.0 : openweathermap : iobroker - enabled system.adapter.parser.0 : parser : iobroker - disabled system.adapter.pi-hole.0 : pi-hole : iobroker - disabled system.adapter.ping.0 : ping : iobroker - enabled system.adapter.pvforecast.0 : pvforecast : iobroker - enabled system.adapter.sayit.0 : sayit : iobroker - disabled, port: 0 system.adapter.scenes.0 : scenes : iobroker - enabled system.adapter.shelly.0 : shelly : iobroker - enabled, port: 1886, bind: 0.0.0.0 system.adapter.simple-api.0 : simple-api : iobroker - enabled, port: 8087, bind: 0.0.0.0, run as: admin system.adapter.sonoff.0 : sonoff : iobroker - enabled, port: 1883, bind: 0.0.0.0 system.adapter.trashschedule.0 : trashschedule : iobroker - enabled system.adapter.tuya.0 : tuya : iobroker - enabled system.adapter.vis-2-beta.0 : vis-2-beta : iobroker - enabled system.adapter.vis-bars.0 : vis-bars : iobroker - disabled system.adapter.vis-canvas-gauges.0 : vis-canvas-gauges : iobroker - disabled system.adapter.vis-colorpicker.0 : vis-colorpicker : iobroker - disabled system.adapter.vis-fancyswitch.0 : vis-fancyswitch : iobroker - disabled system.adapter.vis-google-fonts.0 : vis-google-fonts : iobroker - disabled system.adapter.vis-history.0 : vis-history : iobroker - disabled system.adapter.vis-hqwidgets.0 : vis-hqwidgets : iobroker - disabled system.adapter.vis-icontwo.0 : vis-icontwo : iobroker - disabled system.adapter.vis-inventwo.0 : vis-inventwo : iobroker - enabled system.adapter.vis-jqui-mfd.0 : vis-jqui-mfd : iobroker - disabled system.adapter.vis-justgage.0 : vis-justgage : iobroker - disabled system.adapter.vis-keyboard.0 : vis-keyboard : iobroker - disabled system.adapter.vis-lcars.0 : vis-lcars : iobroker - disabled system.adapter.vis-map.0 : vis-map : iobroker - disabled system.adapter.vis-material-advanced.0 : vis-material-advanced : iobroker - enabled system.adapter.vis-material.0 : vis-material : iobroker - disabled system.adapter.vis-metro.0 : vis-metro : iobroker - disabled system.adapter.vis-players.0 : vis-players : iobroker - disabled system.adapter.vis-plumb.0 : vis-plumb : iobroker - disabled system.adapter.vis-rgraph.0 : vis-rgraph : iobroker - disabled system.adapter.vis-timeandweather.0 : vis-timeandweather : iobroker - disabled system.adapter.vis-weather.0 : vis-weather : iobroker - disabled system.adapter.vis.0 : vis : iobroker - enabled system.adapter.web.0 : web : iobroker - enabled, port: 8082, bind: 0.0.0.0, run as: admin system.adapter.wifilight.0 : wifilight : iobroker - enabled system.adapter.wled.0 : wled : iobroker - enabled system.adapter.zigbee.0 : zigbee : iobroker - enabled, port: /dev/ttyUSB0 + instance is alive Enabled adapters with bindings system.adapter.admin.0 : admin : iobroker - enabled, port: 8081, bind: 0.0.0.0, run as: admin system.adapter.influxdb.0 : influxdb : iobroker - enabled, port: 8086 system.adapter.shelly.0 : shelly : iobroker - enabled, port: 1886, bind: 0.0.0.0 system.adapter.simple-api.0 : simple-api : iobroker - enabled, port: 8087, bind: 0.0.0.0, run as: admin system.adapter.sonoff.0 : sonoff : iobroker - enabled, port: 1883, bind: 0.0.0.0 system.adapter.web.0 : web : iobroker - enabled, port: 8082, bind: 0.0.0.0, run as: admin system.adapter.zigbee.0 : zigbee : iobroker - enabled, port: /dev/ttyUSB0 ioBroker-Repositories stable : http://download.iobroker.net/sources-dist.json beta : http://download.iobroker.net/sources-dist-latest.json Active repo(s): stable Installed ioBroker-Instances Used repository: stable Adapter "admin" : 6.12.0 , installed 6.12.0 Adapter "alias-manager": 1.2.6 , installed 1.2.6 Adapter "backitup" : 2.8.7 , installed 2.9.4 Adapter "bydbatt" : 1.1.0 , installed 1.1.0 Adapter "bydhvs" : 1.5.0 , installed 1.5.0 Adapter "cloud" : 4.4.1 , installed 4.4.1 Adapter "daswetter" : 3.1.10 , installed 3.1.11 Adapter "discovery" : 4.2.0 , installed 4.2.0 Adapter "easee" : 1.0.10 , installed 1.0.10 Adapter "echarts" : 1.5.4 , installed 1.5.4 Adapter "fakeroku" : 0.2.2 , installed 0.2.2 Adapter "feiertage" : 1.1.4 , installed 1.1.4 Adapter "flot" : 1.12.0 , installed 1.12.0 Adapter "fronius" : 2.0.2 , installed 2.0.2 Adapter "fronius-solarweb": 0.0.3 , installed 0.0.3 Adapter "habpanel" : 0.5.0 , installed 0.5.0 Adapter "harmony" : 1.2.2 , installed 1.3.0 Adapter "history" : 3.0.1 , installed 3.0.1 Adapter "ical" : 1.13.3 , installed 1.13.3 Adapter "icons-addictive-flavour-png": 0.1.0, installed 0.1.0 Adapter "icons-mfd-svg": 1.1.0 , installed 1.1.0 Adapter "icons-open-icon-library-png": 0.1.2, installed 0.1.2 Adapter "influxdb" : 3.2.0 , installed 3.2.0 Adapter "info" : 2.0.0 , installed 2.0.0 Adapter "jarvis" : 3.1.8 , installed 3.1.8 Adapter "javascript" : 7.1.4 , installed 7.1.4 Controller "js-controller": 5.0.16 , installed 4.0.24 [Updatable] Adapter "knx" : 2.0.23 , installed 2.0.23 Adapter "lg-thinq" : 0.1.4 , installed 0.1.4 Adapter "lgtv" : 2.1.2 , installed 2.1.2 Adapter "midea" : 0.0.7 , installed 0.0.7 Adapter "mihome" : 1.4.0 , installed 1.4.0 Adapter "mobile" : 1.0.1 , installed 1.0.1 Adapter "moma" : 1.2.9 , installed 1.2.9 Adapter "onkyo" : 2.1.2 , installed 2.1.2 Adapter "openweathermap": 0.4.5 , installed 0.4.5 Adapter "parser" : 2.0.7 , installed 2.0.7 Adapter "phantomjs" : 1.1.3 , installed 1.1.3 Adapter "pi-hole" : 1.3.6 , installed 1.3.6 Adapter "ping" : 1.6.2 , installed 1.6.2 Adapter "pvforecast" : 2.9.0 , installed 2.9.0 Adapter "sayit" : 3.0.5 , installed 3.0.5 Adapter "scenes" : 2.3.9 , installed 2.3.9 Adapter "shelly" : 6.6.1 , installed 6.6.1 Adapter "shuttercontrol": 1.6.3 , installed 1.6.3 Adapter "simple-api" : 2.7.2 , installed 2.7.2 Adapter "smartmeter" : 3.3.4 , installed 3.3.4 Adapter "socketio" : 6.5.5 , installed 6.5.5 Adapter "sonoff" : 3.0.3 , installed 3.0.3 Adapter "tankerkoenig" : 3.3.7 , installed 3.3.7 Adapter "tr-064" : 4.2.18 , installed 4.2.18 Adapter "trashschedule": 2.3.0 , installed 2.3.0 Adapter "tuya" : 3.14.2 , installed 3.14.2 Adapter "unifi" : 0.6.6 , installed 0.6.6 Adapter "vis" : 1.4.16 , installed 1.5.1 Adapter "vis-bars" : 0.1.4 , installed 0.1.4 Adapter "vis-canvas-gauges": 1.0.1, installed 1.0.1 Adapter "vis-colorpicker": 2.0.3 , installed 2.0.3 Adapter "vis-fancyswitch": 1.1.0 , installed 1.1.0 Adapter "vis-google-fonts": 1.0.4 , installed 1.0.4 Adapter "vis-history" : 1.0.0 , installed 1.0.0 Adapter "vis-hqwidgets": 1.4.0 , installed 1.4.0 Adapter "vis-icontwo" : 0.97.1 , installed 0.97.1 Adapter "vis-inventwo" : 3.3.3 , installed 3.3.3 Adapter "vis-jqui-mfd" : 1.0.12 , installed 1.0.12 Adapter "vis-justgage" : 2.0.0 , installed 2.0.0 Adapter "vis-keyboard" : 0.0.2 , installed 0.0.2 Adapter "vis-lcars" : 1.1.1 , installed 1.1.1 Adapter "vis-map" : 1.0.4 , installed 1.0.4 Adapter "vis-material" : 0.1.3 , installed 0.1.3 Adapter "vis-material-advanced": 1.7.4, installed 1.7.4 Adapter "vis-metro" : 1.2.0 , installed 1.2.0 Adapter "vis-players" : 0.1.6 , installed 0.1.6 Adapter "vis-plumb" : 1.0.2 , installed 1.0.2 Adapter "vis-rgraph" : 0.0.2 , installed 0.0.2 Adapter "vis-timeandweather": 1.2.2, installed 1.2.2 Adapter "vis-weather" : 2.5.6 , installed 2.5.6 Adapter "web" : 6.1.10 , installed 6.1.10 Adapter "wifilight" : 1.1.4 , installed 1.1.4 Adapter "wled" : 0.7.1 , installed 0.7.1 Adapter "ws" : 2.5.8 , installed 2.5.8 Adapter "zigbee" : 1.8.24 , installed 1.8.24 Objects and States Please stand by - This may take a while Objects: 11401 States: 10304 *** OS-Repositories and Updates *** Hit:1 http://de.archive.ubuntu.com/ubuntu focal InRelease Hit:2 http://de.archive.ubuntu.com/ubuntu focal-updates InRelease Hit:3 http://de.archive.ubuntu.com/ubuntu focal-backports InRelease Hit:4 http://de.archive.ubuntu.com/ubuntu focal-security InRelease Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease Reading package lists... Pending Updates: 0 *** Listening Ports *** Active Internet connections (only servers) Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name tcp 0 0 0.0.0.0:10000 0.0.0.0:* LISTEN 0 28932 1063/perl tcp 0 0 127.0.0.53:53 0.0.0.0:* LISTEN 101 20806 663/systemd-resolve tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 26317 818/sshd: /usr/sbin tcp 0 0 127.0.0.1:8088 0.0.0.0:* LISTEN 999 26362 810/influxd tcp6 0 0 :::8086 :::* LISTEN 999 29471 810/influxd tcp6 0 0 :::22 :::* LISTEN 0 26319 818/sshd: /usr/sbin tcp6 0 0 :::3000 :::* LISTEN 111 28897 784/grafana-server udp 0 0 127.0.0.53:53 0.0.0.0:* 101 20805 663/systemd-resolve udp 0 0 192.168.8.67:68 0.0.0.0:* 100 22851 661/systemd-network udp 0 0 0.0.0.0:10000 0.0.0.0:* 0 28933 1063/perl udp6 0 0 fe80::11:32ff:fe2d::546 :::* 100 24053 661/systemd-network *** Log File - Last 25 Lines *** 2023-11-22 10:36:45.421 - info: host.iobroker instance system.adapter.admin.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP) 2023-11-22 10:36:45.422 - info: host.iobroker instance system.adapter.info.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP) 2023-11-22 10:36:45.455 - info: host.iobroker instance system.adapter.lgtv.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP) 2023-11-22 10:36:45.507 - info: tuya.0 (1832) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason 2023-11-22 10:36:45.506 - info: host.iobroker instance system.adapter.trashschedule.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP) 2023-11-22 10:36:45.507 - info: host.iobroker instance system.adapter.wled.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP) 2023-11-22 10:36:45.985 - warn: host.iobroker instance system.adapter.javascript.0 terminated due to SIGTERM 2023-11-22 10:36:45.986 - info: host.iobroker instance system.adapter.javascript.0 terminated with code null () 2023-11-22 10:36:46.048 - warn: host.iobroker instance system.adapter.ping.0 terminated due to SIGTERM 2023-11-22 10:36:46.049 - info: host.iobroker instance system.adapter.ping.0 terminated with code null () 2023-11-22 10:36:46.050 - warn: host.iobroker instance system.adapter.sonoff.0 terminated due to SIGTERM 2023-11-22 10:36:46.050 - info: host.iobroker instance system.adapter.sonoff.0 terminated with code null () 2023-11-22 10:36:46.122 - warn: host.iobroker instance system.adapter.zigbee.0 terminated due to SIGTERM 2023-11-22 10:36:46.123 - info: host.iobroker instance system.adapter.zigbee.0 terminated with code null () 2023-11-22 10:36:46.123 - warn: host.iobroker instance system.adapter.fronius.0 terminated due to SIGTERM 2023-11-22 10:36:46.123 - info: host.iobroker instance system.adapter.fronius.0 terminated with code null () 2023-11-22 10:36:46.203 - warn: host.iobroker instance system.adapter.web.0 terminated due to SIGTERM 2023-11-22 10:36:46.204 - info: host.iobroker instance system.adapter.web.0 terminated with code null () 2023-11-22 10:36:46.205 - warn: host.iobroker instance system.adapter.echarts.0 terminated due to SIGTERM 2023-11-22 10:36:46.205 - info: host.iobroker instance system.adapter.echarts.0 terminated with code null () 2023-11-22 10:36:46.232 - info: host.iobroker instance system.adapter.influxdb.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP) 2023-11-22 10:36:46.438 - info: host.iobroker instance system.adapter.history.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP) 2023-11-22 10:36:46.463 - info: host.iobroker instance system.adapter.tuya.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP) 2023-11-22 10:36:46.463 - info: host.iobroker All instances are stopped. 2023-11-22 10:36:46.878 - info: host.iobroker terminated
iob diag has finished.
