    4. [Vorlage] Konfigurierte Script um States zu zahlen [lowbat, dimmer, shutter, chromecast, etc]
    • Dutchman
      @tempestas:
      Darauf war meine Antwort bezogen. `
      sorry du hast recht mein fehler ! @FuXXz kannst du es dan mal so testen ?
      //Add device rules
      addDeviceCounter("lowbat",         $('channel[state.id=*.LOW_BAT]'),                     true);
      addDeviceCounter("lowbat",         $('channel[state.id=*.LOWBAT]'),                      true);
      addDeviceCounter("sticky_unreach", $('channel[state.id=*.STICKY_UNREACH]'),              true);
      addDeviceCounter("unreach",        $('channel[state.id=*.UNREACH]'),                     true);
      addDeviceCounter("config_pending", $('channel[state.id=*.CONFIG_PENDING]'),              true);
      addDeviceCounter("open_windows",   $('channel{TYPE=SHUTTER_CONTACT}[state.id=*.STATE]'), true);
      addDeviceCounter("on_lights",      $('channel{TYPE=DIMMER}[state.id=*.LEVEL]'),          function(state){return state>0;});
      addDeviceCounter("open_shutters",  $('channel{TYPE=BLIND}[state.id=*.LEVEL]'),           function(state){return state>0;});
      addDeviceCounter("playing_music",  $('channel[state.id=*audio-*.playing]'),              true);
       * Code - do not change anything bellow this line *
      function addDeviceCounter(name, selector, val_to_count) {
          //Total amount of devices found by selector
          var state_total = 'deviceCounter.' + name + '.total';
          createState(state_total, 0);
          //List of devices that match condition
          var state_list = 'deviceCounter.' + name + '.list';
          createState(state_list, "");
          //Number of devices that match condition
          var state_counter = 'deviceCounter.' + name + '.counter';
          createState(state_counter, 0);
          function countDevs(obj) {
              var d_count = 0;
              var d_list  = [];
              selector.each(function (id, i) {
                  var status = getState(id).val;
                  var obj    = getObject(id);
                  if ((typeof val_to_count === 'function' && val_to_count(status)) ||
                      (typeof val_to_count === 'boolean'  && val_to_count == status)) {
                      //Get parent object
                      var parentChannelId = id.slice(id.lastIndexOf("."));
                      var parentDevicelId = id.split(".").slice(0,-2).join(".");
                      var deviceObject = getObject(parentDevicelId);
                      //remember device name
                      d_list.push(deviceObject.common.name);
                  ++d_count;                                                 // Zählt die Anzahl der vorhandenen Geräte unabhängig vom Status
              log(name + "(" + d_count + "): " + d_list);
              setState(state_list,     d_list.join('
              setState(state_counter,  d_list.length);
              setState(state_total,    d_count);
          //Re-evaluate when a device status changes
          selector.on(function(obj) {    // bei Zustandänderung *. LOWBAT in allen Gewerken
              countDevs(obj);
          //Re-evaluate each hour
          schedule("*/60 * * * *", countDevs);
          //Evaluate for the first time
          countDevs();
        FuXXz last edited by
        ich wollte den Fensterkontakt zählen lassen, ich glaube diese Zeile ist dafür zuständig.
        Ich glaube aber dass die HM IP Kontakte SENSOR heissen, aber wenn ich dies im Script ändere, passiert nichts.
        Unter Objekte lowbat_IP sind counter und total beides auf 0
        • Dutchman
          @FuXXz:
          Unter Objekte lowbat_IP sind counter und total beides auf 0 `
          oeffne mal bitte die raw data des kanaal 1 (ganz rechts auf dem bleistift und dan tab raw(expert).
          dan sehen wir was fuer ein typ das ist, sollte dieser abweischen von TYPE=BLIND komt da das problem her
            Blind sind glaube ich Rolladen, in diesem Fall ist es ein Fensterkontakt.
            Aber dort steht Shutter_contact. Also müsste das doch laufen :roll:
            Etwas verwirrend im Script!
            open_windows sind dort shutter contact = Fensterkontakt
            open_shutter sind dort Blind = Rolladen
            Unter Objekte -> Javascript.0 ->deviceCounter ->open_shutters habe ich also Gesamtzahl der Rolladen, geöffnete und in der Liste die Namen
            Unter Objekte -> Javascript.0 ->deviceCounter ->open_windows habe ich counter und total bei 0 und die Liste ist leer.
            Ich besitze jedoch einen Fensterkontakt der auf Open (1) steht.
              "_id": "hm-rpc.1.xxxxxxxxxxx1",
              "type": "channel",
              "common": {
                "name": "Fensterkontakt_1",
                "role": "sensor"
              "native": {
                "TYPE": "SHUTTER_CONTACT",
                "SUBTYPE": "",
                "ADDRESS": "00109709A3B4AD:1",
                "RF_ADDRESS": 0,
                "CHILDREN": [],
                "PARENT": "00109709A3B4AD",
                "PARENT_TYPE": "HmIP-SWDO-I",
                "INDEX": 1,
                "AES_ACTIVE": 1,
                "PARAMSETS": [
                  "MASTER",
                  "VALUES",
                  "LINK",
                  "SERVICE"
            • Dutchman
              dan sollte er eigentlich durch diese regel mitgenommen werden:
              also als open_windows
                Was soll ich sagen :roll:
                Wird er nicht 😞
                  Seehofweg last edited by
                  kurze Frage zwischendrin…die einzelnen Geräte mit z. B. Lowbat werden in der Datenbank unter "javascript.0.deviceCounter.lowbat.list" abgelegt.
                  Wie kann ich denn die "Liste" abrufen und an z. B. Pushover weiterleiten. Ich habe bereits mit getstate einige Versuche gemacht, bekomme aber nur Fehler. :? Es ist also was anderes, wie wenn ich reine Variable abrufe.
                  Viele Grüße
                  Tobi
                    pix last edited by
                    @Seehofweg:
                    Ich habe bereits mit getstate einige Versuche gemacht, bekomme aber nur Fehler. :? Es ist also was anderes, wie wenn ich reine Variable abrufe. `
                    Was hast du probiert und was ist der Fehler? Screenshots? Logs?
                    log(getState("javascript.0.deviceCounter.lowbat.list").val);
                    Das sollte reichen, um die List zB im Log auszugeben. Ist doch eine Zeichenkette.
                    Pix
                      Hi Pix,
                      keine Ahnung woran es lag…habe die Zeilen nochmal neu geschrieben und jetzt bekomme ich die Daten. Seltsam. 😉
                      Wie auch immer...wenn ich mit diesem Script arbeite...
                          var hm = getState("javascript.0.deviceCounter.lowbat.list").val;
                          var hmip = getState("javascript.0.deviceCounter.lowbat_IP.list").val;
                          sendTo("system.adapter.pushover.0", 'Batteriestand niedrig: ' + hm + hmip);
                          var reach = getState("javascript.0.deviceCounter.unreach.list").val;
                          sendTo("system.adapter.pushover.0", 'Nicht erreichbare Geräte: ' + reach);
                      …dann bekomme ich für jedes Gerät bzw. jeden Listeneintrag eine Pushover Nachricht...diese aber mit allen Geräten.
                      Wie bekomme ich das denn in einen Eintrag?
                        Kann mir jemand helfen zu den Dimmern, noch die Schalter zu addieren?
                        Folgende Zeile habe ich hinzugefügt, aber dann habe ich natürlich 2 Listen. Ich würde gerne on_lights mit allen Schaltern und Dimmern haben.
                        addDeviceCounter("on_lights",      $('channel{TYPE=SWITCH}[state.id=*.STATE]'),          function(state){return state>0;});
                        addDeviceCounter("on_lights2",     $('channel{TYPE=DIMMER}[state.id=*.LEVEL]'),          function(state){return state>0;});
                          Kann oder möchte hier niemand helfen?
                            knax last edited by
                            ich habe den fhem Adapter mit MAX Thermostaten und Fensterkontakten eingebunden.
                            Da gibt es dann leider einen Textstatus.
                            Mit
                            addDeviceCounter("open_windows",   $('channel[state.id=*fhem.0*SW.state]'), true);
                            wird schon mal die Anzahl gezählt aber der Status ist dann opened oder closed und dann zählt er nicht die offenen Fenster.
                            Ich habe true auch mal durch 'opened' ersetzt aber anscheinend habe ich die Funktion noch nicht verstanden.
                            Wie mache ich das richtig?
                            Schöne Grüße
                            Thorsten
                            • N
                              newbie0815 last edited by
                              Hallo, ich benutze das Skript für Low Batterie und zu überprüfen ob alle Fenster geschlossen sind und es läuft wirklich gut (alles Homematic Sensoren). Nun möchte ich den Bewegungsmelder Zustand auslesen und habe folgende Zeile hinzugefügt
                              addDeviceCounter("motion", $('channel[state.id=*.MOTION]'), true);
                              Das funktioniert auch sehr gut, jedoch möchte ich noch zwischen Bewegung Aussen und Innen unterscheiden. Ich habe jetzt den Bewegungsmeldern Innen einen eindeutigen Namen gegeben und alle fangen mit BW… an, ich habe das * gegen BW* ausgetauscht aber das funktioniert leider nicht. Kann jemand helfen ?
                              45
                              9712
