    4. ioBroker oder Admin Adapter startet immer neu
    • I
      IceD112 @Thomas Braun last edited by
      neee, sorry, ich hab das falsch interpretiert. Ich bin nicht so super fit mit der Arbeit auf dem Pi.
      hab den reboot gemacht und
      sudo apt update
      durchgeführt
      pi@ioBroker:~ $ sudo apt update
      Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
      Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
      Reading package lists... Done
      Building dependency tree... Done
      1 package can be upgraded. Run 'apt list --upgradable' to see it.
      pi@ioBroker:~ $ apt list --upgradable
      Listing... Done
      raspinfo/oldstable 20230123-1 all [upgradable from: 20221220-1]
      N: There is 1 additional version. Please use the '-a' switch to see it
        Thomas Braun Most Active @IceD112 last edited by
        @iced112
        sudo apt full-upgrade
        Und ein
        iob diag
        sagt nun?
        • I
          Skript v.2023-10-10
          *** BASE SYSTEM ***
             Static hostname: ioBroker
                   Icon name: computer
            Operating System: Raspbian GNU/Linux 11 (bullseye)
                      Kernel: Linux 6.1.21-v8+
                Architecture: arm64
          Model           : Raspberry Pi 4 Model B Rev 1.4
          Docker          : false
          Virtualization  : none
          Kernel          : aarch64
          Userland        : armhf
          Systemuptime and Load:
           21:25:09 up 10 min,  2 users,  load average: 2.23, 1.83, 1.21
          CPU threads: 4
          *** RASPBERRY THROTTLING ***
          Current issues:
          Previously detected issues:
          *** Time and Time Zones ***
                         Local time: Tue 2023-11-21 21:25:09 CET
                     Universal time: Tue 2023-11-21 20:25:09 UTC
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          *** User and Groups ***
          pi
          /home/pi
          pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
          *** X-Server-Setup ***
          X-Server:       false
          Desktop:
          Terminal:       tty
          Boot Target:    multi-user.target
          *** MEMORY ***
          Mem:            1.8G        1.5G        123M        0.0K        182M        241M
          Swap:            99M         99M        0.0K
          Total:          1.9G        1.6G        124M
                   1849 M total memory
                   1543 M used memory
                   1350 M active memory
                    244 M inactive memory
                    123 M free memory
                      8 M buffer memory
                    174 M swap cache
                     99 M total swap
                     99 M used swap
                      0 M free swap
          Raspberry only:
          oom events: 0
          *** FAILED SERVICES ***
          0 loaded units listed.
          *** FILESYSTEM ***
          /dev/root      ext4       29G  7.6G   21G  28% /
          devtmpfs       devtmpfs  667M     0  667M   0% /dev
          tmpfs          tmpfs     925M     0  925M   0% /dev/shm
          tmpfs          tmpfs     370M  828K  370M   1% /run
          /dev/mmcblk0p1 vfat      253M   51M  202M  20% /boot
          tmpfs          tmpfs     185M     0  185M   0% /run/user/1000
          [Tue Nov 21 21:14:22 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:CF:73:10 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=f85227ed-02 rootfstype=ext4 fsck.repair=yes rootwait
          [Tue Nov 21 21:14:23 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
          [Tue Nov 21 21:14:23 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
          [Tue Nov 21 21:14:25 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
          TARGET  SOURCE         FSTYPE OPTIONS
          /       /dev/mmcblk0p2 ext4   rw,noatime
          `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
          /var:
          3.5G    /var/
          2.9G    /var/log/journal/25070aeb79f44c94a7f7bcc85e4ba968
          2.9G    /var/log
          387M    /var/cache
          Archived and active journals take up 2.8G in the file system.
          /opt/iobroker/backups:
          74M     /opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          745M    /opt/iobroker/iobroker-data/
          381M    /opt/iobroker/iobroker-data/files
          274M    /opt/iobroker/iobroker-data/backup-objects
          74M     /opt/iobroker/iobroker-data/files/vis.0
          72M     /opt/iobroker/iobroker-data/files/telegram.admin
          52M     /opt/iobroker/iobroker-data/objects.jsonl
          38M     /opt/iobroker/iobroker-data/states.jsonl
          21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map
          15M     /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js.map
          8.9M    /opt/iobroker/iobroker-data/files/scenes.admin/static/js/2.7de3299d.chunk.js.map
          USB-Devices by-id:
          *** NodeJS-Installation ***
          /usr/bin/nodejs         v18.18.2
          /usr/bin/node           v18.18.2
          /usr/bin/npm            9.8.1
          /usr/bin/npx            9.8.1
          /usr/bin/corepack       0.19.0
          nodejs:
            Installed: 18.18.2-1nodesource1
            Candidate: 18.18.2-1nodesource1
            Version table:
           *** 18.18.2-1nodesource1 1001
                  500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
                  100 /var/lib/dpkg/status
               18.18.1-1nodesource1 1001
               18.18.0-1nodesource1 1001
               18.17.1-1nodesource1 1001
               18.17.0-1nodesource1 1001
               18.16.1-1nodesource1 1001
               18.16.0-1nodesource1 1001
               18.15.0-1nodesource1 1001
               18.14.2-1nodesource1 1001
               18.14.1-1nodesource1 1001
               18.14.0-1nodesource1 1001
               18.13.0-1nodesource1 1001
               18.12.0-1nodesource1 1001
               18.11.0-1nodesource1 1001
               18.10.0-1nodesource1 1001
               18.9.1-1nodesource1 1001
               18.9.0-1nodesource1 1001
               18.8.0-1nodesource1 1001
               18.7.0-1nodesource1 1001
               18.6.0-1nodesource1 1001
               18.5.0-1nodesource1 1001
               18.4.0-1nodesource1 1001
               18.3.0-1nodesource1 1001
               18.2.0-1nodesource1 1001
               18.1.0-1nodesource1 1001
               18.0.0-1nodesource1 1001
               12.22.12~dfsg-1~deb11u4 500
                  500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
          No problems detected
          Errors in npm tree:
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Core adapters versions
          js-controller:  5.0.16
          admin:          6.12.0
          javascript:     7.1.4
          Adapters from github:   1
          Adapter State
          + system.adapter.accuweather.0            : accuweather           : ioBroker                                 -  enabled
          + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          + system.adapter.alexa2.0                 : alexa2                : ioBroker                                 -  enabled
          + system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
            system.adapter.blink4home.0             : blink4home            : ioBroker                                 - disabled
          + system.adapter.bring.0                  : bring                 : ioBroker                                 -  enabled
            system.adapter.chromecast.0             : chromecast            : ioBroker                                 -  enabled
            system.adapter.daswetter.0              : daswetter             : ioBroker                                 -  enabled
          + system.adapter.denon.0                  : denon                 : ioBroker                                 -  enabled
          + system.adapter.discovery.0              : discovery             : ioBroker                                 -  enabled
            system.adapter.dwd.0                    : dwd                   : ioBroker                                 -  enabled
          + system.adapter.energiefluss.1           : energiefluss          : ioBroker                                 -  enabled
          + system.adapter.fb-checkpresence.0       : fb-checkpresence      : ioBroker                                 -  enabled
          + system.adapter.followthesun.0           : followthesun          : ioBroker                                 -  enabled
          + system.adapter.fronius-solarweb.0       : fronius-solarweb      : ioBroker                                 -  enabled
          + system.adapter.fronius.0                : fronius               : ioBroker                                 -  enabled
          + system.adapter.ham.0                    : ham                   : ioBroker                                 -  enabled
          + system.adapter.harmony.0                : harmony               : ioBroker                                 -  enabled
          + system.adapter.heos.0                   : heos                  : ioBroker                                 -  enabled
          + system.adapter.hue-extended.0           : hue-extended          : ioBroker                                 -  enabled
          + system.adapter.hue.0                    : hue                   : ioBroker                                 -  enabled, port: 443
            system.adapter.ical.0                   : ical                  : ioBroker                                 -  enabled
            system.adapter.icons-icons8.0           : icons-icons8          : ioBroker                                 - disabled
            system.adapter.icons-material-png.0     : icons-material-png    : ioBroker                                 - disabled
            system.adapter.icons-mfd-png.0          : icons-mfd-png         : ioBroker                                 - disabled
            system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : ioBroker                                 - disabled
          + system.adapter.javascript.0             : javascript            : ioBroker                                 -  enabled
          + system.adapter.lgtv.0                   : lgtv                  : ioBroker                                 -  enabled
          + system.adapter.lgtv11.0                 : lgtv11                : ioBroker                                 -  enabled, port: 8080
          + system.adapter.meross.0                 : meross                : ioBroker                                 -  enabled
          + system.adapter.modbus.0                 : modbus                : ioBroker                                 -  enabled
          + system.adapter.panasonic-viera.0        : panasonic-viera       : ioBroker                                 -  enabled
          + system.adapter.ping.0                   : ping                  : ioBroker                                 -  enabled
          + system.adapter.scenes.0                 : scenes                : ioBroker                                 -  enabled
          + system.adapter.shelly.0                 : shelly                : ioBroker                                 -  enabled, port: 1882, bind: 0.0.0.0
          + system.adapter.spotify-premium.0        : spotify-premium       : ioBroker                                 -  enabled
          + system.adapter.telegram.0               : telegram              : ioBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
          + system.adapter.tr-064.0                 : tr-064                : ioBroker                                 -  enabled
          + system.adapter.trashschedule.0          : trashschedule         : ioBroker                                 -  enabled
            system.adapter.vis-colorpicker.0        : vis-colorpicker       : ioBroker                                 - disabled
            system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBroker                                 - disabled
            system.adapter.vis-icontwo.0            : vis-icontwo           : ioBroker                                 - disabled
          + system.adapter.vis-inventwo.0           : vis-inventwo          : ioBroker                                 -  enabled
            system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBroker                                 - disabled
            system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBroker                                 - disabled
            system.adapter.vis.0                    : vis                   : ioBroker                                 -  enabled
          + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
            system.adapter.yr.0                     : yr                    : ioBroker                                 -  enabled
          + instance is alive
          ioBroker-Repositories
          Active repo(s): beta
          Installed ioBroker-Instances
          Used repository: beta
          Adapter    "accuweather"  : 1.3.1    , installed 1.3.1
          Adapter    "admin"        : 6.12.4   , installed 6.12.0 [Updatable]
          Adapter    "alexa2"       : 3.26.1   , installed 3.26.1
          Adapter    "backitup"     : 2.9.4    , installed 2.8.7  [Updatable]
          Adapter    "bring"        : 1.8.4    , installed 1.8.4
          Adapter    "bydhvs"       : 1.5.0    , installed 1.4.0  [Updatable]
          Adapter    "chromecast"   : 3.0.3    , installed 3.0.3
          Adapter    "daswetter"    : 3.1.11   , installed 3.1.10 [Updatable]
          Adapter    "denon"        : 1.15.4   , installed 1.15.4
          Adapter    "fb-checkpresence": 1.2.2 , installed 1.2.2
          Adapter    "followthesun" : 0.4.2    , installed 0.4.2
          Adapter    "fronius"      : 2.0.2    , installed 2.0.2
          Adapter    "fronius-solarweb": 0.0.3 , installed 0.0.3
          Adapter    "ham"          : 5.3.1    , installed 5.3.1
          Adapter    "harmony"      : 1.3.0    , installed 1.2.2  [Updatable]
          Adapter    "heos"         : 2.1.0    , installed 2.1.0
          Adapter    "hue"          : 3.10.1   , installed 3.10.1
          Adapter    "hue-extended" : 2.0.0    , installed 2.0.0
          Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
          Adapter    "javascript"   : 7.1.6    , installed 7.1.4  [Updatable]
          Controller "js-controller": 5.0.16   , installed 5.0.16
          Adapter    "lgtv"         : 2.1.2    , installed 2.1.1  [Updatable]
          Adapter    "lgtv11"       : 1.0.5    , installed 1.0.5
          Adapter    "meross"       : 1.15.1   , installed 1.15.1
          Adapter    "modbus"       : 6.0.1    , installed 5.0.11 [Updatable]
          Adapter    "panasonic-viera": 2.0.0  , installed 2.0.0
          Adapter    "shelly"       : 6.6.1    , installed 6.6.1
          Adapter    "socketio"     : 6.6.0    , installed 6.5.5  [Updatable]
          Adapter    "spotify-premium": 1.3.1  , installed 1.2.2  [Updatable]
          Adapter    "telegram"     : 3.0.0    , installed 1.16.0 [Updatable]
          Adapter    "trashschedule": 2.3.0    , installed 2.2.0  [Updatable]
          Adapter    "vis"          : 1.5.1    , installed 1.4.16 [Updatable]
          Adapter    "vis-icontwo"  : 0.97.3   , installed 0.96.0 [Updatable]
          Adapter    "web"          : 6.1.10   , installed 6.1.2  [Updatable]
          Adapter    "ws"           : 2.5.8    , installed 2.5.5  [Updatable]
          Adapter    "yr"           : 5.3.0    , installed 5.3.0
          Objects and States
          Objects:        36301
          States:         29693
          Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
          Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
          Pending Updates: 0
          *** Listening Ports ***
          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       13260      492/iobroker.js-con
          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       12171      492/iobroker.js-con
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14204      522/sshd: /usr/sbin
          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       21660      1583/io.web.0
          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       13308      804/io.admin.0
          tcp6       0      0 :::61991                :::*                    LISTEN      1001       21010      1362/io.harmony.0
          tcp6       0      0 :::22                   :::*                    LISTEN      0          14206      522/sshd: /usr/sbin
          udp        0      0 0.0.0.0:52690           0.0.0.0:*                           108        12954      353/avahi-daemon: r
          udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       21011      1362/io.harmony.0
          udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       17764      971/io.shelly.0
          udp        0      0 0.0.0.0:50951           0.0.0.0:*                           1001       21091      1408/io.heos.0
          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14500      723/dhcpcd
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12952      353/avahi-daemon: r
          udp6       0      0 :::546                  :::*                                0          14558      723/dhcpcd
          udp6       0      0 :::57204                :::*                                108        12955      353/avahi-daemon: r
          udp6       0      0 :::5353                 :::*                                108        12953      353/avahi-daemon: r
          2023-11-21 21:21:01.596  - error: modbus.0 (1049) Socket Error
          2023-11-21 21:21:01.597  - error: modbus.0 (1049) Client in error state.
          2023-11-21 21:21:01.597  - warn: modbus.0 (1049) On error: {"errno":-111,"code":"ECONNREFUSED","syscall":"connect","address":"192.168.178.152","port":502}
          2023-11-21 21:22:02.604  - error: modbus.0 (1049) Socket Error
          2023-11-21 21:22:02.605  - error: modbus.0 (1049) Client in error state.
          2023-11-21 21:22:02.606  - warn: modbus.0 (1049) On error: {"errno":-111,"code":"ECONNREFUSED","syscall":"connect","address":"192.168.178.152","port":502}
          2023-11-21 21:23:03.611  - error: modbus.0 (1049) Socket Error
          2023-11-21 21:23:03.612  - error: modbus.0 (1049) Client in error state.
          2023-11-21 21:23:03.613  - warn: modbus.0 (1049) On error: {"errno":-111,"code":"ECONNREFUSED","syscall":"connect","address":"192.168.178.152","port":502}
          2023-11-21 21:24:04.620  - error: modbus.0 (1049) Socket Error
          2023-11-21 21:24:04.621  - error: modbus.0 (1049) Client in error state.
          2023-11-21 21:24:04.622  - warn: modbus.0 (1049) On error: {"errno":-111,"code":"ECONNREFUSED","syscall":"connect","address":"192.168.178.152","port":502}
          2023-11-21 21:25:00.070  - info: host.ioBroker instance system.adapter.dwd.0 started with pid 2301
          2023-11-21 21:25:03.908  - info: dwd.0 (2301) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.18.2, js-controller: 5.0.16
          2023-11-21 21:25:05.246  - info: dwd.0 (2301) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          2023-11-21 21:25:05.627  - error: modbus.0 (1049) Socket Error
          2023-11-21 21:25:05.628  - error: modbus.0 (1049) Client in error state.
          2023-11-21 21:25:05.629  - warn: modbus.0 (1049) On error: {"errno":-111,"code":"ECONNREFUSED","syscall":"connect","address":"192.168.178.152","port":502}
          2023-11-21 21:25:05.781  - info: host.ioBroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2023-11-21 21:26:06.635  - error: modbus.0 (1049) Socket Error
          2023-11-21 21:26:06.636  - error: modbus.0 (1049) Client in error state.
          2023-11-21 21:26:06.636  - warn: modbus.0 (1049) On error: {"errno":-111,"code":"ECONNREFUSED","syscall":"connect","address":"192.168.178.152","port":502}
          2023-11-21 21:27:07.643  - error: modbus.0 (1049) Socket Error
          2023-11-21 21:27:07.644  - error: modbus.0 (1049) Client in error state.
          2023-11-21 21:27:07.645  - warn: modbus.0 (1049) On error: {"errno":-111,"code":"ECONNREFUSED","syscall":"connect","address":"192.168.178.152","port":502}
          iob diag has finished.
          Press any key for a summary
            @iced112
            Zu wenig RAM.
              @iced112
              Zu viel Beta-Zeugs aktiv.
                @thomas-braun sagte in ioBroker oder Admin Adapter startet immer neu:
                @iced112
                Zu wenig RAM.
                bei 32 aktiven Instanzen +scheduled kein Wunder mit einem Pi2GB
                und Beta Versionen on top
                • I
                  IceD112 @Thomas Braun last edited by IceD112
                  heißt, ich sollte da mal bisschen aufräumen und das system abspecken?
                  Codierknecht Thomas Braun 2 Replies Last reply Reply Quote 0
                  • Codierknecht
                    Codierknecht Developer Most Active @IceD112 last edited by
                    @iced112 sagte in ioBroker oder Admin Adapter startet immer neu:
                    Naja. Aufräumen und abspecken wird da wohl kaum reichen.
                    Ein Pi2 mit 2 GB reicht bestenfalls für 'ne handvoll Instanzen oder als Testkiste.
                    Da solltest Du eher ein paar € in die Hand nehmen und aufrüsten.
                    Statt 'nem Pi kriegt man generalüberholte Hardware auch schon für kleines Geld.
                    Lenovo ThinkCentre oder ein NUC. Mit 8 GB und 'ner ordenlichen CPU.
                    Langfristig hat man daran mehr Freude.
                      @iced112
                      Oder den Arbeitsspeicher aufspecken...
                      2GB ist die untere Grenze, wenn man etwas mit dem ioBroker anfangen will.
                      • I
                        wusste garnicht, dass man den PI mit RAM aufrüsten kann?
                        @Codierknecht
                        Wäre auch ne Überlegung wert
                          @iced112
                          Kann man auch nicht. Halt ein dickeres System beschaffen.
                          • I
                            ok, was wäre denn an der Stelle derzeit ratsam?
                              @iced112
                              Ich gebe ungern Hardware-Empfehlungen.
                              Irgendwas mit 4, besser 8 GB RAM.
                              • I
                                Klar, nach extern Empfehlungen auszusprechen, wo man nicht weis, was derjenige für Anforderungen hat, ist schwierig
                                Ging mir nur drum ne grobe Richtung zu haben. Eher schon einen Pi5 oder reicht Pi4 aus? Wenn ich da die aktuellen Preise sehe, ist ein Lenovo ThinkCenter ja tatsächlich nicht weit weg.
                                Die Instalation des ioB auf einem Windows PC ist mir gänzlich unbekannt
                                Thomas Braun Codierknecht 2 Replies Last reply Reply Quote 0
                                  @iced112
                                  Ich habe einen Pi4 / 8GB im Einsatz. Und der wird es mir auch noch eine geraume Zeit tun.
                                  I 2 Replies Last reply Reply Quote 0
                                  • I
                                    Gut, ich denke mir ja dann, dass ich bei einem neuen Pi, nach der Instalation mit einem Backup, das aktuelle System gut umziehen kann?
                                    Aber hat der andauernde Neustart dann damit zu tun, dass das System mit 2GB zu schwach ist?
                                    • Codierknecht
                                      Auf dem NUC oder dem Lenovo installiert man dann konsequenterweise natürlich ein aktuelles Linux.
                                      Nur so als Hausnummer: https://www.amazon.de/dp/B0B2MLV1LB
                                        Das hat damit zu tun, dass der Kernel in höchster Not anfängt 'unwichtige' Dinge abzuwerfen. Und der ioBroker ist aus Sicht des Kernels halt unwichtiges Zeug.
                                        • I
                                          Unwichtig 😲
                                          Wie kann der denn behaupten dass der unwichtig ist 😊
                                          Ok, gut, dann werde ich das Hardware Upgrade mal gedanklich angehen...
                                          • I
                                            IceD112 @Codierknecht last edited by
                                            @codierknecht said in [ioBroker oder Admin Adapter startet immer neu](/post
                                            den hatte ich grad unter der Lupe...
                                            Ich werd mich mal mit beiden Möglichkeiten auseinandersetzen.
                                            Ich denke schonmal für eure Hilfe und Ratschläge
                                            1622
