    3. Off Topic
    4. Upgrade von Debian 11/Bullseye auf 12/Bookworm
    • lobomau
      lobomau @Guest last edited by
      @dp20eic ja, das war nur eine Momentaufnahme. Wobei diese Anzeige unter "hosts" nicht richtige Werte bei mir anzeigt. "hosts" sagt jetzt 48%, aber proxmox sagt 27%.
      • wendy2702
        wendy2702 last edited by
        habe vor einiger Zeit nach der Anleitung meine PI's 3B von Bullseye auf Bookworm gebracht.
        Heute dann mal ein update & upgrade machen wollen und bekomme das:
        sudo apt update
        Hit:1 http://archive.raspberrypi.org/debian bookworm InRelease
        Hit:2 http://deb.debian.org/debian bookworm InRelease
        Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
        Hit:4 http://security.debian.org/debian-security bookworm-security InRelease
        Hit:5 https://deb.nodesource.com/node_16.x bookworm InRelease
        Hit:6 https://deb.nodesource.com/node_18.x bookworm InRelease
        Reading package lists... Done
        Building dependency tree... Done
        1 package can be upgraded. Run 'apt list --upgradable' to see it.
        pi@pi-iobroker:~ $ sudo apt upgrade
        Calculating upgrade... Done
        The following packages have been kept back:
          libcamera-apps-lite
        0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
        2 not fully installed or removed.
        After this operation, 0 B of additional disk space will be used.
        Do you want to continue? [Y/n] y
        Setting up raspi-firmware (1:1.20231024+ds-1+rpt2) ...
        stat: cannot read file system information for '/boot/firmware': No such file or directory
        Error: missing /boot/firmware, did you forget to mount it?
        dpkg: error processing package raspi-firmware (--configure):
         installed raspi-firmware package post-installation script subprocess returned error exit status 1
        dpkg: dependency problems prevent configuration of rpi-eeprom:
         rpi-eeprom depends on raspi-firmware; however:
          Package raspi-firmware is not configured yet.
        dpkg: error processing package rpi-eeprom (--configure):
         dependency problems - leaving unconfigured
        Processing triggers for initramfs-tools (0.142) ...
        Errors were encountered while processing:
         raspi-firmware
         rpi-eeprom
        E: Sub-process /usr/bin/dpkg returned an error code (1)
        Hatte das sonst noch jemand?
        Habe mit Google diverse Lösungsansätze gefunden aber will jetzt nicht alle probieren.
        Wenn also jemand eine Lösung hat die dauerhaft ohne neu installation funktioniert wäre ich dankbar.
        Thomas Braun un99known99 2 Replies Last reply Reply Quote 0
          Thomas Braun Most Active @wendy2702 last edited by Thomas Braun
          @wendy2702 sagte in Upgrade von Debian 11/Bullseye auf 12/Bookworm:
          Ja, @mickym hatte das kürzlich. Das liegt daran, das Raspberry OS hier bei deren Geschmacksrichtung vom 'Bookworm' einiges umgestellt haben.
          Und weil das nicht so ganz trivial ist geht die Empfehlung diesmal noch mehr als sonst schon dahin, den ganzen Sums frisch von Grund auf neuaufzusetzen.
          Hier der Fred dazu:
          https://forum.iobroker.net/topic/70165/raspi-firmware-update-nach-bookworm-update-gelöst
          • un99known99
            un99known99 @wendy2702 last edited by un99known99
            @wendy2702
            habe mit einem bei rasperrypi kommuniziert und mein Googleergebnis gegenprüfen lassen, ist wohl ok und bei mir hats geklappt:
            Unmount your /boot directory with:
            umount /boot
            Make sure your /boot mount point is unmounted with the above command, "umount /boot" by doing:
            lsblk
            mkdir /boot/firmware
            /etc/fstab
            /boot => /boot/firmware
            systemctl daemon-reload
            mount -a
              Thomas Braun Most Active @un99known99 last edited by
              @un99known99
              Da kommt allerdings auch noch das neue Kernel-Paket dazu. Siehe obigen Thread.
              un99known99 1 Reply Last reply Reply Quote 0
              • un99known99
                un99known99 @Thomas Braun last edited by un99known99
                ich kann nur sagen das danach bei mir alles geklappt hat:
                raspi-firmware
                rpi-eeprom
                ließen sich problemlos installieren und seitdem keine weiteren Probleme
                  @un99known99
                  Ja, aber das ist nicht die einzige Stelle, an der Raspberry OS 12 'Bookworm' Änderungen erfahren hat.
                  • wendy2702
                    habe jetzt auch erstmal die hier und verlinkte Anleitung abgearbeitet.
                    Aktuell läuft alles.
                    Danke!
                      Diamand2k22 last edited by
                      @wendy2702 said in Upgrade von Debian 11/Bullseye auf 12/Bookworm:
                      sudo apt update
                        libcamera-apps-lite
                       raspi-firmware
                       rpi-eeprom
                      kommt der Fehler nur bei Raspberry Model < 4?
                      Bei meinem Raspberry 4B kam der Fehler mit der Firmware nicht!
                        Wildbill @Diamand2k22 last edited by
                        @diamand2k22 Bei meinem 3B mit Deconz und PiVVCU auch nicht. Ich vermute, das betrifft eher die 5er Generation?!
                        Gruss, Jürgen
                        • Siggi0904
                          Siggi0904 last edited by Siggi0904
                          Nein, das Thema ist die verwendete Distribution.
                          Wie ihr in den Screens seht, wird einmal Debian und einmal Raspberry.org also Raspberry OS verwendet.
                          Bei Raspbian OS hat man wohl sehr viel geändert, sodass ein Upgrade auf das aktuelle Raspbian OS nicht empfohlen wird, sondern eine komplette Neuinstallation.
                          Hebel zum möglich beheben wurden z.B. nier besprochen:
                          https://forum.iobroker.net/topic/70165/raspi-firmware-update-nach-bookworm-update-gelöst/4?_=1700678987748
                          https://forum.iobroker.net/topic/70165/raspi-firmware-update-nach-bookworm-update-gelöst/12?_=1700678987750
                          • un99known99
                            un99known99 @Wildbill last edited by
                            @Wildbill
                            umount /boot
                            lsblk
                            /etc/fstab
                            mount -a
                            W Thomas Braun 2 Replies Last reply Reply Quote 0
                              Wildbill @un99known99 last edited by
                              @un99known99 Was willst Du mir damit sagen? Bei mir läuft alles und ich bekomme bei apt update bzw apt upgrade keinerlei Fehler oder Warnungen angezeigt.
                              Gruss, Jürgen
                                @un99known99
                                Und die neuen Kernel-Pakete nicht vergessen.
                                • un99known99
                                  was meinst Du damit? Kernel Upgrade kommt via apt update doch mit, oder?
                                  raspi-firmware package und rpi-eeprom liessen sich problemlos installieren nach der Umstellung auf /boot/firmware - was / warum muss mit KERNEL gemacht werden?
                                  Verzeichnis sieht so aus:
                                  drwxr-xr-x 4 root root 4096 Jan 1 1970 firmware
                                  drwxr-xr-x 18 root root 4096 Oct 24 13:25 ..
                                  lrwxrwxrwx 1 root root 17 Nov 14 13:29 overlays -> firmware/overlays
                                  drwxr-xr-x 3 root root 4096 Nov 14 13:29 .
                                  sieht so aus als ob beim apt update/upgrade automatische Anlagen gemacht wurden
                                    @un99known99
                                    Das Paket mit dem Kernel heißt aber nun anders, nicht mehr 'raspberrypi-kernel'. Das muss also auch passend zur verwendeten Hardware installiert werden.
                                    • un99known99
                                      d.h.
                                      sudo apt install linux-image-rpi-v7 linux-headers-rpi-v7 # für 32bit?
                                      Kommen dann KERNEL upgrades via apt-update?
                                        @un99known99 sagte in Upgrade von Debian 11/Bullseye auf 12/Bookworm:
                                        Dann kommen natürlich auch Aktualisierungen wieder über apt. Aber das passende Paket muss zuvor installiert sein.
                                        • un99known99
                                          pi@jitsi:[/boot] $ sudo apt list | grep -i linux-image-rpi-v8
                                          WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
                                          linux-image-rpi-v8-dbg/stable 1:6.1.58-1+rpt2 arm64
                                          linux-image-rpi-v8/stable 1:6.1.58-1+rpt2 arm64
                                          pi@jitsi:[/boot] $ sudo apt list | grep -i linux-headers-rpi-v8
                                          linux-headers-rpi-v8/stable 1:6.1.58-1+rpt2 arm64
                                          ist schon da?
                                            ist schon da?
                                            Dann ist ja gut. Wird der auch geladen?
                                            uname -a
                                            upgrade bullseye bookworm
                                            51
                                            351
                                            88698
