    3. Off Topic
    4. Upgrade von Debian 11/Bullseye auf 12/Bookworm
      Diamand2k22 last edited by
      @wendy2702 said in Upgrade von Debian 11/Bullseye auf 12/Bookworm:
      habe vor einiger Zeit nach der Anleitung meine PI's 3B von Bullseye auf Bookworm gebracht.
      Heute dann mal ein update & upgrade machen wollen und bekomme das:
      sudo apt update
      Hit:1 http://archive.raspberrypi.org/debian bookworm InRelease
      Hit:2 http://deb.debian.org/debian bookworm InRelease
      Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
      Hit:4 http://security.debian.org/debian-security bookworm-security InRelease
      Hit:5 https://deb.nodesource.com/node_16.x bookworm InRelease
      Hit:6 https://deb.nodesource.com/node_18.x bookworm InRelease
      Reading package lists... Done
      Building dependency tree... Done
      1 package can be upgraded. Run 'apt list --upgradable' to see it.
      pi@pi-iobroker:~ $ sudo apt upgrade
      Calculating upgrade... Done
      The following packages have been kept back:
        libcamera-apps-lite
      0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
      2 not fully installed or removed.
      After this operation, 0 B of additional disk space will be used.
      Do you want to continue? [Y/n] y
      Setting up raspi-firmware (1:1.20231024+ds-1+rpt2) ...
      stat: cannot read file system information for '/boot/firmware': No such file or directory
      Error: missing /boot/firmware, did you forget to mount it?
      dpkg: error processing package raspi-firmware (--configure):
       installed raspi-firmware package post-installation script subprocess returned error exit status 1
      dpkg: dependency problems prevent configuration of rpi-eeprom:
       rpi-eeprom depends on raspi-firmware; however:
        Package raspi-firmware is not configured yet.
      dpkg: error processing package rpi-eeprom (--configure):
       dependency problems - leaving unconfigured
      Processing triggers for initramfs-tools (0.142) ...
      Errors were encountered while processing:
       raspi-firmware
       rpi-eeprom
      E: Sub-process /usr/bin/dpkg returned an error code (1)
      Hatte das sonst noch jemand?
      Habe mit Google diverse Lösungsansätze gefunden aber will jetzt nicht alle probieren.
      Wenn also jemand eine Lösung hat die dauerhaft ohne neu installation funktioniert wäre ich dankbar.
      kommt der Fehler nur bei Raspberry Model < 4?
      Bei meinem Raspberry 4B kam der Fehler mit der Firmware nicht!
        Wildbill @Diamand2k22 last edited by
        @diamand2k22 Bei meinem 3B mit Deconz und PiVVCU auch nicht. Ich vermute, das betrifft eher die 5er Generation?!
        Gruss, Jürgen
        un99known99 1 Reply Last reply Reply Quote 0
        • Siggi0904
          Siggi0904 last edited by Siggi0904
          Nein, das Thema ist die verwendete Distribution.
          Wie ihr in den Screens seht, wird einmal Debian und einmal Raspberry.org also Raspberry OS verwendet.
          Bei Raspbian OS hat man wohl sehr viel geändert, sodass ein Upgrade auf das aktuelle Raspbian OS nicht empfohlen wird, sondern eine komplette Neuinstallation.
          Hebel zum möglich beheben wurden z.B. nier besprochen:
          https://forum.iobroker.net/topic/70165/raspi-firmware-update-nach-bookworm-update-gelöst/4?_=1700678987748
          https://forum.iobroker.net/topic/70165/raspi-firmware-update-nach-bookworm-update-gelöst/12?_=1700678987750
          • un99known99
            un99known99 @Wildbill last edited by
            @Wildbill
            Unmount your /boot directory with:
            umount /boot
            Make sure your /boot mount point is unmounted with the above command, "umount /boot" by doing:
            lsblk
            mkdir /boot/firmware
            /etc/fstab
            /boot => /boot/firmware
            systemctl daemon-reload
            mount -a
            W Thomas Braun 2 Replies Last reply Reply Quote 0
              Wildbill @un99known99 last edited by
              @un99known99 Was willst Du mir damit sagen? Bei mir läuft alles und ich bekomme bei apt update bzw apt upgrade keinerlei Fehler oder Warnungen angezeigt.
              Gruss, Jürgen
                Thomas Braun Most Active @un99known99 last edited by
                @un99known99
                Und die neuen Kernel-Pakete nicht vergessen.
                • un99known99
                  un99known99 @Thomas Braun last edited by un99known99
                  was meinst Du damit? Kernel Upgrade kommt via apt update doch mit, oder?
                  raspi-firmware package und rpi-eeprom liessen sich problemlos installieren nach der Umstellung auf /boot/firmware - was / warum muss mit KERNEL gemacht werden?
                  Verzeichnis sieht so aus:
                  drwxr-xr-x 4 root root 4096 Jan 1 1970 firmware
                  drwxr-xr-x 18 root root 4096 Oct 24 13:25 ..
                  lrwxrwxrwx 1 root root 17 Nov 14 13:29 overlays -> firmware/overlays
                  drwxr-xr-x 3 root root 4096 Nov 14 13:29 .
                  sieht so aus als ob beim apt update/upgrade automatische Anlagen gemacht wurden
                    @un99known99
                    Das Paket mit dem Kernel heißt aber nun anders, nicht mehr 'raspberrypi-kernel'. Das muss also auch passend zur verwendeten Hardware installiert werden.
                    • un99known99
                      d.h.
                      sudo apt install linux-image-rpi-v7 linux-headers-rpi-v7 # für 32bit?
                      Kommen dann KERNEL upgrades via apt-update?
                        @un99known99 sagte in Upgrade von Debian 11/Bullseye auf 12/Bookworm:
                        Dann kommen natürlich auch Aktualisierungen wieder über apt. Aber das passende Paket muss zuvor installiert sein.
                        • un99known99
                          pi@jitsi:[/boot] $ sudo apt list | grep -i linux-image-rpi-v8
                          WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
                          linux-image-rpi-v8-dbg/stable 1:6.1.58-1+rpt2 arm64
                          linux-image-rpi-v8/stable 1:6.1.58-1+rpt2 arm64
                          pi@jitsi:[/boot] $ sudo apt list | grep -i linux-headers-rpi-v8
                          linux-headers-rpi-v8/stable 1:6.1.58-1+rpt2 arm64
                          ist schon da?
                            ist schon da?
                            Dann ist ja gut. Wird der auch geladen?
                            uname -a
                            • un99known99
                              @thomas-braun said in Upgrade von Debian 11/Bullseye auf 12/Bookworm:
                              uname -a
                              Linux jitsi 6.1.21-v8+ #1642 SMP PREEMPT Mon Apr 3 17:24:16 BST 2023 aarch64 GNU/Linux
                              Passt das?
                                @un99known99
                                Bei mir wird der aktuelle Kernel so gemeldet
                                echad@chet:~ $ uname -a
                                Linux chet 6.1.0-rpi6-rpi-v8 #1 SMP PREEMPT Debian 1:6.1.58-1+rpt2 (2023-10-27)
                                aarch64 GNU/Linux
                                echad@chet:~ $
                                un99known99 2 Replies Last reply Reply Quote 0
                                • un99known99
                                  un99known99 @Thomas Braun last edited by Homoran
                                  kann ja mal versuchen, ob
                                  # sudo apt install linux-image-rpi-v8 linux-headers-rpi-v8      # 64bit
                                  was bewirkt, grundsätzlich sieht Dein KERNEL neuer aus
                                  • un99known99
                                    pi@jitsi:[~] $ uname -a
                                    Linux jitsi 6.1.0-rpi6-rpi-v8 #1 SMP PREEMPT Debian 1:6.1.58-1+rpt2 (2023-10-27) aarch64 GNU/Linux
                                    sieht jetzt besser aus nach
                                    pi@jitsi:[/boot] $ ll
                                    total 19736
                                    -rw-r--r--  1 root root  8729756 Oct 27 16:31 vmlinuz-6.1.0-rpi6-rpi-v8
                                    -rw-r--r--  1 root root       83 Oct 27 16:31 System.map-6.1.0-rpi6-rpi-v8
                                    -rw-r--r--  1 root root   230383 Oct 27 16:31 config-6.1.0-rpi6-rpi-v8
                                    drwxr-xr-x 18 root root     4096 Nov 23 11:01 ..
                                    -rw-r--r--  1 root root 11225182 Nov 23 11:02 initrd.img-6.1.0-rpi6-rpi-v8
                                    drwxr-xr-x  3 root root     4096 Nov 23 11:02 .
                                    Sieht soweit gut aus oder?
                                    D.h. jetzt sollte via apt update auch wieder "normal" KERNEL-Updates kommen?
                                      @un99known99
                                      Ja, jetzt rutschen die gleichnamigen Pakete nach.
                                      un99known99 Michael Schmitt 2 Replies Last reply Reply Quote 0
                                      • un99known99
                                        Vielen Dank für die ganzen Tipps hier in dem Thread und Deine Anleitung 🙂
                                          reutli @un99known99 last edited by
                                          @un99known99
                                          und das nächste mal die Konsoleneingaben in
                                          code tags
                                          dann kann man das besser lesen 😀
                                          • un99known99
                                            un99known99 @reutli last edited by
                                            @reutli
                                            Danke 🙂
                                            upgrade bullseye bookworm
                                            51
                                            351
                                            88649
