    4. [gelöst] - Fritzbox-Adapter startet nicht
    • Codierknecht
      Codierknecht Developer Most Active @Papi 0 last edited by
      @papi-0
      Zeig mal die Ausgabe von
      iob diag
        Papi 0 @Codierknecht last edited by Papi 0
        @codierknecht
        Skript v.2023-10-10
        *** BASE SYSTEM ***
        Hardware Vendor : Insyde
        Kernel          : x86_64
        Userland        : amd64
        Docker          : v8.1.0
        Virtualization  : Docker
        Kernel          : x86_64
        Userland        : amd64
        Systemuptime and Load:
         22:34:22 up 7 days,  4:34,  0 users,  load average: 3.25, 3.02, 2.95
        CPU threads: 4
        *** Time and Time Zones ***
        Wed Nov 22 21:34:22 UTC 2023
        Wed Nov 22 22:34:22 CET 2023
        CET +0100
        Etc/UTC
        *** User and Groups ***
        root
        /root
        root
        *** X-Server-Setup ***
        X-Server:       false
        Desktop:
        Terminal:
        *** MEMORY ***
        Mem:             16G        4.6G        163M         46M         11G         11G
        Swap:           2.0G        1.4G        663M
        Total:           18G        5.9G        827M
                16041 M total memory
                 4547 M used memory
                 4971 M active memory
                 5567 M inactive memory
                  166 M free memory
                   48 M buffer memory
                11278 M swap cache
                 2047 M total swap
                 1384 M used swap
                  663 M free swap
        *** FILESYSTEM ***
        Filesystem        Type   Size  Used Avail Use% Mounted on
        /dev/vg2/volume_1 btrfs   48T   27T   21T  58% /
        tmpfs             tmpfs   64M     0   64M   0% /dev
        tmpfs             tmpfs  7.9G     0  7.9G   0% /sys/fs/cgroup
        shm               tmpfs   64M     0   64M   0% /dev/shm
        /dev/vg2/volume_1 btrfs   48T   27T   21T  58% /opt/iobroker
        /dev/vg2/volume_1 btrfs   48T   27T   21T  58% /etc/hosts
        tmpfs             tmpfs  7.9G     0  7.9G   0% /proc/asound
        tmpfs             tmpfs  7.9G     0  7.9G   0% /proc/acpi
        tmpfs             tmpfs  7.9G     0  7.9G   0% /proc/scsi
        tmpfs             tmpfs  7.9G     0  7.9G   0% /sys/firmware
        [Wed Nov 15 18:00:05 2023] EXT4-fs (md0): barriers disabled
        [Wed Nov 15 18:00:05 2023] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts:
        [Wed Nov 15 18:00:07 2023] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: barrier=1
        [Wed Nov 15 18:00:08 2023] EXT4-fs (md0): re-mounted. Opts: (null)
        TARGET             SOURCE        FSTYPE OPTIONS
        /                  /dev/vg2/volume_1[/@docker/btrfs/subvolumes/9ab1c3faaeadf83f6f62dd1db43a34333cd29699762986eb66ad4c0a09a102a4]       btrfs  rw,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50
        |-/opt/iobroker    /dev/vg2/volume_1[/docker/iobroker1_data]        btrfs  rw,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50
        |-/etc/resolv.conf /dev/vg2/volume_1[/@docker/containers/1a7f7c299ee380d7f600c1de144d6c14a8d7d32d35a0d83dcef115c7819c7e29/resolv.conf] btrfs  rw,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50
        |-/etc/hostname    /dev/vg2/volume_1[/@docker/containers/1a7f7c299ee380d7f600c1de144d6c14a8d7d32d35a0d83dcef115c7819c7e29/hostname]    btrfs  rw,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50
        `-/etc/hosts       /dev/vg2/volume_1[/@docker/containers/1a7f7c299ee380d7f600c1de144d6c14a8d7d32d35a0d83dcef115c7819c7e29/hosts]       btrfs  rw,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50
        /var:
        33M     /var/
        30M     /var/lib
        18M     /var/lib/apt/lists
        18M     /var/lib/apt
        13M     /var/lib/dpkg
        /opt/iobroker/backups:
        48M     /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        311M    /opt/iobroker/iobroker-data/
        201M    /opt/iobroker/iobroker-data/files
        77M     /opt/iobroker/iobroker-data/backup-objects
        52M     /opt/iobroker/iobroker-data/files/javascript.admin
        43M     /opt/iobroker/iobroker-data/files/iot.admin
        33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
        21M     /opt/iobroker/iobroker-data/objects.jsonl
        21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
        13M     /opt/iobroker/iobroker-data/states.jsonl
        8.5M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js
        USB-Devices by-id:
        /home/iobroker/.diag.sh: line 277: nodejs: command not found
        *** NodeJS-Installation ***
        /usr/bin/node           v18.17.1
        /usr/bin/npm            9.6.7
        /usr/bin/npx            9.6.7
        /usr/bin/corepack       0.18.0
        /home/iobroker/.diag.sh: line 288: nodejs: command not found
        *** nodejs is NOT correctly installed ***
        nodejs:
          Installed: 18.17.1-deb-1nodesource1
          Candidate: 18.17.1-deb-1nodesource1
          Version table:
         *** 18.17.1-deb-1nodesource1 500
                500 https://deb.nodesource.com/node_18.x bullseye/main amd64 Packages
                100 /var/lib/dpkg/status
             12.22.12~dfsg-1~deb11u4 500
                500 http://deb.debian.org/debian bullseye/main amd64 Packages
                500 http://deb.debian.org/debian-security bullseye-security/main amd64 Packages
        No problems detected
        Errors in npm tree:
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Core adapters versions
        js-controller:  5.0.16
        admin:          6.12.0
        javascript:     7.1.4
        Adapters from github:   0
        Adapter State
        + system.adapter.admin.1                  : admin                 : iobroker1                                -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.alexa2.0                 : alexa2                : iobroker1                                -  enabled
        + system.adapter.backitup.0               : backitup              : iobroker1                                -  enabled
          system.adapter.daswetter.0              : daswetter             : iobroker1                                -  enabled
        + system.adapter.discovery.0              : discovery             : iobroker1                                -  enabled
        + system.adapter.divera247.0              : divera247             : iobroker1                                -  enabled
          system.adapter.dwd.0                    : dwd                   : iobroker1                                -  enabled
        + system.adapter.email.0                  : email                 : iobroker1                                -  enabled
        + system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker1                                -  enabled
          system.adapter.fritzbox.0               : fritzbox              : iobroker1                                -  enabled
        + system.adapter.fritzdect.0              : fritzdect             : iobroker1                                -  enabled
        + system.adapter.fullybrowser.0           : fullybrowser          : iobroker1                                -  enabled
        + system.adapter.hm-rega.0                : hm-rega               : iobroker1                                -  enabled
        + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker1                                -  enabled, port: 0
        + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker1                                -  enabled, port: 0
        + system.adapter.hm-rpc.2                 : hm-rpc                : iobroker1                                -  enabled, port: 0
        + system.adapter.hm-rpc.3                 : hm-rpc                : iobroker1                                -  enabled, port: 0
        + system.adapter.info.0                   : info                  : iobroker1                                -  enabled
        + system.adapter.iot.0                    : iot                   : iobroker1                                -  enabled
        + system.adapter.javascript.0             : javascript            : iobroker1                                -  enabled
          system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker1                                - disabled, port: 54321
        + system.adapter.net-tools.0              : net-tools             : iobroker1                                -  enabled
          system.adapter.openweathermap.0         : openweathermap        : iobroker1                                -  enabled
        + system.adapter.ping.0                   : ping                  : iobroker1                                -  enabled
        + system.adapter.pushover.0               : pushover              : iobroker1                                -  enabled
        + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker1                                -  enabled
        + system.adapter.tr-064.0                 : tr-064                : iobroker1                                -  enabled
        + system.adapter.vesync.0                 : vesync                : iobroker1                                -  enabled
          system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker1                                - disabled
          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker1                                - disabled
          system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker1                                - disabled
        + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker1                                -  enabled
          system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker1                                - disabled
          system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker1                                - disabled
          system.adapter.vis-weather.0            : vis-weather           : iobroker1                                - disabled
          system.adapter.vis.0                    : vis                   : iobroker1                                -  enabled
        + system.adapter.web.0                    : web                   : iobroker1                                -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
        + system.adapter.worx.0                   : worx                  : iobroker1                                -  enabled
        + system.adapter.ws.0                     : ws                    : iobroker1                                -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
          system.adapter.yr.0                     : yr                    : iobroker1                                -  enabled
        + instance is alive
        ioBroker-Repositories
        sources       : conf/sources-dist.json
        online        : https://raw.githubusercontent.com/ioBroker/ioBroker.repositories/master/sources-dist.json
        Active repo(s): stable
        Installed ioBroker-Instances
        Used repository: stable
        Adapter    "admin"        : 6.12.0   , installed 6.12.0
        Adapter    "alexa2"       : 3.26.1   , installed 3.26.1
        Adapter    "backitup"     : 2.8.7    , installed 2.8.7
        Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
        Adapter    "divera247"    : 0.2.0    , installed 0.2.0
        Adapter    "email"        : 1.2.0    , installed 1.2.0
        Adapter    "fb-checkpresence": 1.2.2 , installed 1.2.2
        Adapter    "fritzbox"     : 0.5.0    , installed 0.5.0
        Adapter    "fritzdect"    : 2.3.1    , installed 2.3.1
        Adapter    "fullybrowser" : 3.0.6    , installed 2.2.0  [Updatable]
        Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
        Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
        Adapter    "iot"          : 2.0.11   , installed 2.0.11
        Adapter    "javascript"   : 7.1.4    , installed 7.1.4
        Controller "js-controller": 5.0.16   , installed 5.0.16
        Adapter    "mihome-vacuum": 4.1.0    , installed 4.1.0
        Adapter    "openweathermap": 0.4.5   , installed 0.4.5
        Adapter    "pushover"     : 3.0.3    , installed 3.0.3
        Adapter    "socketio"     : 6.5.5    , installed 6.6.0
        Adapter    "vesync"       : 0.0.3    , installed 0.0.3
        Adapter    "vis"          : 1.4.16   , installed 1.4.16
        Adapter    "vis-icontwo"  : 0.97.1   , installed 0.97.1
        Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
        Adapter    "web"          : 6.1.10   , installed 6.1.10
        Adapter    "worx"         : 2.3.4    , installed 2.3.4
        Adapter    "ws"           : 2.5.8    , installed 2.5.8
        Adapter    "yr"           : 5.3.0    , installed 5.3.0
        Objects and States
        Objects:        23727
        States:         20029
        Hit:1 http://deb.debian.org/debian bullseye InRelease
        Hit:2 http://deb.debian.org/debian-security bullseye-security InRelease
        Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
        Hit:4 https://deb.nodesource.com/node_18.x bullseye InRelease
        Reading package lists...
        Pending Updates: 35
        *** Listening Ports ***
        tcp        0      0 0.0.0.0:8701            0.0.0.0:*               LISTEN      1000       130242998  -
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       130236565  -
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       130234447  -
        tcp        0      0 0.0.0.0:9292            0.0.0.0:*               LISTEN      1000       130243065  -
        tcp        0      0 0.0.0.0:2001            0.0.0.0:*               LISTEN      1000       130243663  -
        tcp        0      0 0.0.0.0:2010            0.0.0.0:*               LISTEN      1000       130243202  -
        tcp6       0      0 :::8081                 :::*                    LISTEN      1000       130238696  -
        tcp6       0      0 :::8084                 :::*                    LISTEN      1000       130264322  -
        tcp6       0      0 :::8088                 :::*                    LISTEN      1000       130259813  -
        udp        0      0 0.0.0.0:8472            0.0.0.0:*                           0          130214941  -
        2023-11-22 22:30:08.403  - info: host.iobroker1 instance system.adapter.yr.0 started with pid 5343
        2023-11-22 22:30:11.070  - info: yr.0 (5343) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
        2023-11-22 22:30:11.243  - info: yr.0 (5343) starting. Version 5.3.0 in /opt/iobroker/node_modules/iobroker.yr, node: v18.17.1, js-controller: 5.0.16
        2023-11-22 22:30:11.290  - info: yr.0 (5343) longitude/longitude not set, get data from system
        2023-11-22 22:30:11.326  - info: yr.0 (5343) system latitude: 51.28058000 longitude: 6.45123000
        2023-11-22 22:30:12.483  - info: host.iobroker1 instance system.adapter.daswetter.0 started with pid 5362
        2023-11-22 22:30:15.224  - info: daswetter.0 (5362) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
        2023-11-22 22:30:15.421  - info: daswetter.0 (5362) starting. Version 3.1.10 in /opt/iobroker/node_modules/iobroker.daswetter, node: v18.17.1, js-controller: 5.0.16
        2023-11-22 22:30:31.553  - info: openweathermap.0 (5321) Terminated (NO_ERROR): Without reason
        2023-11-22 22:30:32.093  - info: host.iobroker1 instance system.adapter.openweathermap.0 terminated with code 0 (NO_ERROR)
        2023-11-22 22:30:42.180  - info: yr.0 (5343) Data updated.
        2023-11-22 22:30:42.183  - info: yr.0 (5343) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2023-11-22 22:30:42.735  - info: host.iobroker1 instance system.adapter.yr.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2023-11-22 22:30:46.955  - info: daswetter.0 (5362) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
        2023-11-22 22:30:47.471  - info: daswetter.0 (5362) cleaned everything up...
        2023-11-22 22:30:47.502  - info: host.iobroker1 instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2023-11-22 22:31:10.559  - info: hm-rega.0 (291) pollingTrigger
        2023-11-22 22:33:11.546  - info: hm-rega.0 (291) pollingTrigger
        2023-11-22 22:34:17.747  - info: hm-rega.0 (291) pollingTrigger
        2023-11-22 22:35:00.072  - info: host.iobroker1 instance system.adapter.dwd.0 started with pid 6375
        2023-11-22 22:35:03.088  - info: dwd.0 (6375) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
        2023-11-22 22:35:03.524  - info: dwd.0 (6375) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.16
        2023-11-22 22:35:06.569  - info: dwd.0 (6375) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2023-11-22 22:35:07.109  - info: host.iobroker1 instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2023-11-22 22:35:16.459  - info: hm-rega.0 (291) pollingTrigger
        Copy text starting here:
                                v.2023-10-10
        model name      : Intel(R) Atom(TM) CPU  C2538  @ 2.40GHz
        Kernel          : x86_64
        Userland        : amd64
        Docker          : v8.1.0
        Installation:           Docker
        Kernel:                 x86_64
        Userland:               amd64
        Timezone:               Etc/UTC
        User-ID:                0
        X-Server:               false
        Pending OS-Updates:     35
        Pending iob updates:    1
        /home/iobroker/.diag.sh: line 486: nodejs: command not found
        Nodejs-Installation:
                                /usr/bin/npm            9.6.7
                                /usr/bin/npx            9.6.7
        Recommended versions are nodejs 18.18.2 and npm 9.8.1
        Wrong installation path detected. This needs to be fixed.
        Please check
        https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian
        for more information on how to fix these errors.
        MEMORY:
        Mem:             16G        4.5G        306M         46M         11G         11G
        Swap:           2.0G        1.4G        666M
        Total:           18G        5.9G        972M
        Active iob-Instances:   28
        ioBroker Core:          js-controller           5.0.16
                                admin                   6.12.0
        Objects type: jsonl
        States  type: jsonl
        Objects:                23727
        States:                 20029
        Size of iob-Database:
        15M     /opt/iobroker/iobroker-data/states.jsonl
        === Mark text until here for copying ===
        Ich sehe schon - *** nodejs is NOT correctly installed ***
        Hier ist aber mein Latein eingeschränkt, denn mit Linux habe ich es nicht so und ich weiß auch nicht, wo nodejs ansonsten hin muss und wie ich das bewerkstelligen muss.
        Codierknecht Thomas Braun 3 Replies Last reply Reply Quote 0
        • Codierknecht
          @papi-0
            @codierknecht
            Wo muss nodejs denn stattdessen hin und wie geht das?
            Welche OS-Updates sind denn da pending?
            Der Host meint zwar es gäbe ein Update von 5.0.16 auf 5.0.16 aber das hört sich etwas sinnfrei an.
            • Codierknecht
              Codierknecht Developer Most Active @Papi 0 last edited by Codierknecht
              @papi-0 sagte in Fritzbox-Adapter startet nicht:
              Du hast das Verzeichnis mit den Daten vom NAS in den Container gemappt?
              • Container stoppen (und löschen)
              • Neuen Container mit identischen EInstellungen erzeugen und starten
                Dazu am besten das aktuelle Image von buanet verwenden
              • warten, warten, warten ... voilá
              Container sind Wegwerfartikel. Dazu sind sie gedacht.
                @codierknecht
                Ja, ich habe das Verzeichnis mit den Daten vom NAS in den Container gemappt.
                Also mit Portainer einfach ein Recreate unter neuem Image ausführen?
                • Codierknecht
                  @papi-0
                  Ich habe das immer ohne Portainer gemacht.
                  Ist ja mit ein paar Klicks gemacht.
                  Mit Portainer müssen andere weiterhelfen.
                  Läuft auf dem NAS eigentlich noch etwas anderes, außer dass es als Datengrab dient?
                  Wenn Portkollisionen ausgeschlossen sind, könntest Du den neuen Container auch im Host-Modus betreiben. Spart das Durchreichen der einzelnen Ports.
                  P 2 Replies Last reply Reply Quote 0
                    @codierknecht
                    Ja, da läuft noch etwas viel Anderes, der Host-Mode wäre mir darum echt zu heikel.
                    Das Ding ist so ausgelastet, dass ich schon ein paar Container auf Raspi auslagern musste.
                    Bisher habe ich meine Ports aber noch genauestens im Griff, da sollte sich nichts überschneiden.
                    Ok, dann erstmal vielen Dank für die professionelle Hilfe!
                    Ich werde das wohl besser am Wochenende direkt zu Hause machen, da ich momentan auf Dienstreise bin, solche Sachen nicht gerne fernab der Basis per VPN mache, langsam in die Kiste muss und vorher alles wegsichern möchte, was erfahrungsgemäß eine Weile dauert, genauso, wie dann die Wiederherstellung des ioBrokers.
                    1000 Dank, ich werde wieder Rückmeldung erstatten.
                    Gruß Michael
                      Thomas Braun Most Active @Papi 0 last edited by Thomas Braun
                      Quark geschrieben...
                        Papi 0 @Thomas Braun last edited by
                        Was soll denn dieser Beitrag?
                        • DJMarc75
                          DJMarc75 @Papi 0 last edited by
                          @papi-0
                          wenn man selbst "Unsinn" geschrieben hat dann löscht man die eigenen Beiträge und schreibt dann eben so was wie "Quark geschrieben" !
                            @codierknecht
                            So, wie angekündigt, habe ich Deinen Rat gerade befolgt. Der ioBroker läuft mit aktuellem Image (buanet/iobroker:latest (22.11.2023)) wieder, aber das eingangs aufgeführte Problem hat sich leider nicht verflüchtigt, obwohl Nodejs wohl nun korrekt installiert ist, wie die Diagnose mitteilt:
                            Skript v.2023-10-10
                            *** BASE SYSTEM ***
                            Kernel          : x86_64
                            Userland        : amd64
                            Docker          : v9.0.1
                            Kernel          : x86_64
                            Userland        : amd64
                             08:37:26 up 10 days, 14:37,  0 user,  load average: 3.07, 3.85, 4.39
                            CPU threads: 4
                            Sun Nov 26 07:37:26 UTC 2023
                            Sun Nov 26 08:37:26 CET 2023
                            CET +0100
                            Etc/UTC
                            root
                            /root
                            root
                            X-Server:       false
                            Desktop:
                            Terminal:
                            *** MEMORY ***
                            Mem:             16G         15G        1.6G        243M         10G        1.6G
                            Swap:           2.1G        1.7G        461M
                            Total:           18G         16G        2.0G
                                    14550 M used memory
                                     4948 M active memory
                                     6405 M inactive memory
                                     1490 M free memory
                                       23 M buffer memory
                                     9796 M swap cache
                                     2047 M total swap
                                     1607 M used swap
                                      440 M free swap
                            *** FILESYSTEM ***
                            /                  /dev/vg2/volume_1[/@docker/btrfs/subvolumes/09dffbd202054221355666351eaac6b319b400c00c732f58fe9fa106a6f6ddc9]       btrfs  rw,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50
                            |-/etc/resolv.conf /dev/vg2/volume_1[/@docker/containers/028486a4b205d410539f43bd68ba301c328c01af9ee9251a6c3716fce2cc196e/resolv.conf] btrfs  rw,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50
                            |-/etc/hostname    /dev/vg2/volume_1[/@docker/containers/028486a4b205d410539f43bd68ba301c328c01af9ee9251a6c3716fce2cc196e/hostname]    btrfs  rw,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50
                            `-/etc/hosts       /dev/vg2/volume_1[/@docker/containers/028486a4b205d410539f43bd68ba301c328c01af9ee9251a6c3716fce2cc196e/hosts]       btrfs  rw,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50
                            /var:
                            15M     /var/
                            13M     /var/lib/dpkg
                            13M     /var/lib
                            12M     /var/lib/dpkg/info
                            1.9M    /var/cache
                            363M    /opt/iobroker/iobroker-data/
                            215M    /opt/iobroker/iobroker-data/files
                            78M     /opt/iobroker/iobroker-data/backup-objects
                            67M     /opt/iobroker/iobroker-data/files/javascript.admin
                            48M     /opt/iobroker/iobroker-data/files/javascript.admin/static
                            38M     /opt/iobroker/iobroker-data/states.jsonl
                            33M     /opt/iobroker/iobroker-data/objects.jsonl
                            USB-Devices by-id:
                            /usr/bin/nodejs         v18.18.2
                            /usr/bin/node           v18.18.2
                            /usr/bin/npm            9.8.1
                            /usr/bin/npx            9.8.1
                            /usr/bin/corepack       0.19.0
                            nodejs:
                              Installed: 18.18.2-1nodesource1
                              Candidate: 18.18.2-1nodesource1
                              Version table:
                             *** 18.18.2-1nodesource1 100
                            Errors in npm tree:
                            ioBroker Status
                            Objects type: jsonl
                            States  type: jsonl
                            admin:          6.12.0
                            javascript:     7.1.6
                            Adapter State
                            + system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker1                                -  enabled, port: 54321
                            + instance is alive
                            Adapter    "javascript"   : 7.1.6    , installed 7.1.6
                            Objects and States
                            Objects:        23731
                            States:         20046
                            Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
                            Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
                            Pending Updates: 0
                            tcp        0      0 0.0.0.0:8701            0.0.0.0:*               LISTEN      1000       192287449  -
                            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       192278619  -
                            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       192277686  -
                            tcp        0      0 0.0.0.0:9292            0.0.0.0:*               LISTEN      1000       192289429  -
                            tcp        0      0 0.0.0.0:2001            0.0.0.0:*               LISTEN      1000       192285535  -
                            tcp        0      0 0.0.0.0:2010            0.0.0.0:*               LISTEN      1000       192289513  -
                            tcp6       0      0 :::8081                 :::*                    LISTEN      1000       192283699  -
                            tcp6       0      0 :::8084                 :::*                    LISTEN      1000       192302715  -
                            tcp6       0      0 :::8088                 :::*                    LISTEN      1000       192303709  -
                            udp        0      0 0.0.0.0:8472            0.0.0.0:*                           0          192256079  -
                            udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1000       192475277  -
                            2023-11-26 08:36:52.394  - error: host.iobroker1 Caught by controller[4]:  4: 0x7f6e5c7c247c Context2d::GetImageData(Nan::FunctionCallbackInfo<v8::Value> const&) [/opt/iobroker/node_modules/canvas/build/Release/canvas.node]
                            2023-11-26 08:36:52.395  - error: host.iobroker1 Caught by controller[5]:  5: 0x7f6e5c7b43d3  [/opt/iobroker/node_modules/canvas/build/Release/canvas.node]
                            2023-11-26 08:36:52.395  - error: host.iobroker1 Caught by controller[6]:  6: 0xdc4e00  [io.mihome-vacuum.0]
                            2023-11-26 08:36:52.395  - error: host.iobroker1 Caught by controller[7]:  7: 0xdc633f v8::internal::Builtin_HandleApiCall(int, unsigned long*, v8::internal::Isolate*) [io.mihome-vacuum.0]
                            2023-11-26 08:36:52.395  - error: host.iobroker1 Caught by controller[8]:  8: 0x1705c39  [io.mihome-vacuum.0]
                            2023-11-26 08:36:52.396  - warn: host.iobroker1 instance system.adapter.mihome-vacuum.0 terminated due to SIGABRT
                            2023-11-26 08:36:52.396  - info: host.iobroker1 instance system.adapter.mihome-vacuum.0 terminated with code null ()
                            2023-11-26 08:36:52.396  - info: host.iobroker1 Restart adapter system.adapter.mihome-vacuum.0 because enabled
                            2023-11-26 08:37:22.690  - info: host.iobroker1 instance system.adapter.mihome-vacuum.0 started with pid 3593
                            2023-11-26 08:37:36.323  - error: mihome-vacuum.0 (3593) YOUR DEVICE IS CONNECTED BUT DID NOT ANSWER YET - CONNECTION CAN TAKE UP TO 10 MINUTES - PLEASE BE PATIENT AND DO NOT TURN THE ADAPTER OFF
                            2023-11-26 08:37:37.416  - info: hm-rega.0 (635) pollingTrigger
                            2023-11-26 08:38:03.653  - error: host.iobroker1 Caught by controller[0]: FATAL ERROR: v8::ToLocalChecked Empty MaybeLocal.
                            2023-11-26 08:38:03.654  - error: host.iobroker1 Caught by controller[1]:  1: 0xb85bc0 node::Abort() [io.mihome-vacuum.0]
                            2023-11-26 08:38:03.654  - error: host.iobroker1 Caught by controller[2]:  2: 0xa94749 node::OOMErrorHandler(char const*, bool) [io.mihome-vacuum.0]
                            2023-11-26 08:38:03.654  - error: host.iobroker1 Caught by controller[3]:  3: 0xd66a2a v8::Utils::ReportApiFailure(char const*, char const*) [io.mihome-vacuum.0]
                            2023-11-26 08:38:03.655  - error: host.iobroker1 Caught by controller[3]:  4: 0x7f0b7846847c Context2d::GetImageData(Nan::FunctionCallbackInfo<v8::Value> const&) [/opt/iobroker/node_modules/canvas/build/Release/canvas.node]
                            2023-11-26 08:38:03.655  - error: host.iobroker1 Caught by controller[3]:  5: 0x7f0b7845a3d3  [/opt/iobroker/node_modules/canvas/build/Release/canvas.node]
                            2023-11-26 08:38:03.655  - error: host.iobroker1 Caught by controller[4]:  6: 0xdc4e00  [io.mihome-vacuum.0]
                            2023-11-26 08:38:03.655  - error: host.iobroker1 Caught by controller[5]:  7: 0xdc633f v8::internal::Builtin_HandleApiCall(int, unsigned long*, v8::internal::Isolate*) [io.mihome-vacuum.0]
                            2023-11-26 08:38:03.655  - error: host.iobroker1 Caught by controller[6]:  8: 0x1705c39  [io.mihome-vacuum.0]
                            2023-11-26 08:38:03.656  - warn: host.iobroker1 instance system.adapter.mihome-vacuum.0 terminated due to SIGABRT
                            2023-11-26 08:38:03.656  - info: host.iobroker1 instance system.adapter.mihome-vacuum.0 terminated with code null ()
                            2023-11-26 08:38:03.656  - info: host.iobroker1 Restart adapter system.adapter.mihome-vacuum.0 because enabled
                            2023-11-26 08:38:17.891  - info: hm-rega.0 (635) pollingTrigger
                            2023-11-26 08:38:33.911  - info: host.iobroker1 instance system.adapter.mihome-vacuum.0 started with pid 4224
                            (Den Fully-Adapter habe ich übrigens extra noch auf 2.2.0, weil ichMQTT mit der 3.0.6 ad hoc auf den Displays nicht ans Laufen bekomme. Das Alte Display kann das eh nicht mehr)
                                                    v.2023-10-10
                            Kernel          : x86_64
                            Userland        : amd64
                            Docker          : v9.0.1
                            Kernel:                 x86_64
                            Userland:               amd64
                            Timezone:               Etc/UTC
                            User-ID:                0
                            X-Server:               false
                            Pending OS-Updates:     0
                            Nodejs-Installation:    /usr/bin/nodejs         v18.18.2
                                                    /usr/bin/npm            9.8.1
                                                    /usr/bin/npx            9.8.1
                            MEMORY:
                            Mem:             16G         15G        1.3G        243M         10G        1.3G
                            Total:           18G         17G        1.8G
                            Active iob-Instances:   29
                                                    admin                   6.12.0
                            Objects type: jsonl
                            States  type: jsonl
                            Objects:                23731
                            States:                 20046
                            40M     /opt/iobroker/iobroker-data/states.jsonl
                            Ich habe schonmal einen Vergleich zwischen den beiden Diags gemacht, mit dem Ergebnis, dass alles Negative wohl dankenswerterweise nun beseitigt ist.
                            Beim Starten des ioBrokers werde ich aber schon darauf hingewiesen, dass fritzbox.0 Ärger macht und ich mir das Log vor einem weiteren Restart ansehen soll.
                            Nachfolgend das Log, gefiltert auf den fritzbox.0-Adapter, ich meine, es steht dasselbe drin, wie zuvor:
                            fritzbox.0
                            2023-11-26 08:58:07.848	info	terminating
                            fritzbox.0
                            2023-11-26 08:58:07.346	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                            fritzbox.0
                            2023-11-26 08:58:07.335	info	terminating
                            fritzbox.0
                            2023-11-26 08:58:07.280	error	Cannot read properties of undefined (reading 'startsWith')
                            fritzbox.0
                            2023-11-26 08:58:07.279	error	TypeError: Cannot read properties of undefined (reading 'startsWith') at /opt/iobroker/node_modules/iobroker.fritzbox/main.js:1440:73 at Parser.<anonymous> (/opt/iobroker/node_modules/iobroker.fritzbox/node_modules/xml2js/lib/parser.js:304:18) at Parser.emit (node:events:517:28) at SAXParser.onclosetag (/opt/iobroker/node_modules/iobroker.fritzbox/node_modules/xml2js/lib/parser.js:262:26) at emit (/opt/iobroker/node_modules/sax/lib/sax.js:625:35) at emitNode (/opt/iobroker/node_modules/sax/lib/sax.js:630:5) at closeTag (/opt/iobroker/node_modules/sax/lib/sax.js:890:7) at SAXParser.write (/opt/iobroker/node_modules/sax/lib/sax.js:1437:13) at exports.Parser.Parser.parseString (/opt/iobroker/node_modules/iobroker.fritzbox/node_modules/xml2js/lib/parser.js:323:31) at Parser.parseString (/opt/iobroker/node_modules/iobroker.fritzbox/node_modules/xml2js/lib/parser.js:5:59)
                            fritzbox.0
                            2023-11-26 08:58:07.276	error	uncaught exception: Cannot read properties of undefined (reading 'startsWith')
                            fritzbox.0
                            2023-11-26 08:58:03.057	warn	TR-064: Error reading files from dir /tam: Error: ENOENT: no such file or directory, scandir 'tam'
                            fritzbox.0
                            2023-11-26 08:58:02.890	info	Successfully connected to TR-064
                            fritzbox.0
                            2023-11-26 08:57:57.551	info	adapter connected to fritzbox: 192.168.1.100
                            fritzbox.0
                            2023-11-26 08:57:57.494	info	Trying to connect to TR-064: 192.168.1.100:49000
                            fritzbox.0
                            2023-11-26 08:57:57.491	info	try to connect: 192.168.1.100
                            fritzbox.0
                            2023-11-26 08:57:57.426	info	starting. Version 0.5.0 in /opt/iobroker/node_modules/iobroker.fritzbox, node: v18.18.2, js-controller: 5.0.16
                            fritzbox.0
                            2023-11-26 08:57:55.343	info	Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                            Der Host meint übrigens wieder, dass er von 5.0.16 auf 5.0.16 geupdated werden könnte.
                            Auch ein Restart des ioBrokers überzeugt ihn nicht von seinem Glück, dass er bereits aktuell ist.
                            (Beim letzten Mal - vorige Tage - war es am nachfolgenden Tag nicht mehr zu sehen.)
                            Der Staubsauger macht übrigens auch wieder das gleiche Theater. 😕
                            Ich hänge ihn (mihome-vacuum.0) hier der Vollständigkeit halber noch debug-mäßig mit an:
                            mihome-vacuum.0
                            2023-11-26 09:26:14.727	debug	Message= {"id":16,"method":"get_consumable"}
                            mihome-vacuum.0
                            2023-11-26 09:26:14.727	debug	Startup: setGetCleanSummary Answer: false
                            mihome-vacuum.0
                            2023-11-26 09:26:14.726	debug	your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
                            mihome-vacuum.0
                            2023-11-26 09:26:14.418	debug	Time difference between Mihome Vacuum and ioBroker: 5487 sec
                            mihome-vacuum.0
                            2023-11-26 09:26:14.418	debug	Receive <<< Helo <<< 21310020000000000707a91265631695ffffffffffffffffffffffffffffffff
                            mihome-vacuum.0
                            2023-11-26 09:26:12.725	debug	Message= {"id":15,"method":"get_clean_summary"}
                            mihome-vacuum.0
                            2023-11-26 09:26:12.724	debug	your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
                            mihome-vacuum.0
                            2023-11-26 09:26:10.723	debug	Message= {"id":14,"method":"get_sound_volume"}
                            mihome-vacuum.0
                            2023-11-26 09:26:10.722	debug	your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
                            mihome-vacuum.0
                            2023-11-26 09:26:08.721	debug	Message= {"id":13,"method":"get_network_info"}
                            mihome-vacuum.0
                            2023-11-26 09:26:08.719	debug	your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
                            mihome-vacuum.0
                            2023-11-26 09:26:06.718	debug	Message= {"id":12,"method":"get_status"}
                            mihome-vacuum.0
                            2023-11-26 09:26:06.717	debug	get params for stock Vacuum
                            mihome-vacuum.0
                            2023-11-26 09:26:04.415	debug	Time difference between Mihome Vacuum and ioBroker: 5487 sec
                            mihome-vacuum.0
                            2023-11-26 09:26:04.414	debug	Receive <<< Helo <<< 21310020000000000707a9126563168bffffffffffffffffffffffffffffffff
                            mihome-vacuum.0
                            2023-11-26 09:25:54.411	debug	Time difference between Mihome Vacuum and ioBroker: 5487 sec
                            mihome-vacuum.0
                            2023-11-26 09:25:54.409	debug	Receive <<< Helo <<< 21310020000000000707a91265631681ffffffffffffffffffffffffffffffff
                            mihome-vacuum.0
                            2023-11-26 09:25:46.716	debug	Startup: setGetConsumable Answer: false
                            mihome-vacuum.0
                            2023-11-26 09:25:46.714	debug	your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
                            mihome-vacuum.0
                            2023-11-26 09:25:44.712	debug	Message= {"id":11,"method":"get_consumable"}
                            mihome-vacuum.0
                            2023-11-26 09:25:44.711	debug	Startup: setGetCleanSummary Answer: false
                            mihome-vacuum.0
                            2023-11-26 09:25:44.710	debug	your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
                            mihome-vacuum.0
                            2023-11-26 09:25:44.391	debug	Time difference between Mihome Vacuum and ioBroker: 5487 sec
                            mihome-vacuum.0
                            2023-11-26 09:25:44.390	debug	Receive <<< Helo <<< 21310020000000000707a91265631677ffffffffffffffffffffffffffffffff
                            mihome-vacuum.0
                            2023-11-26 09:25:42.708	debug	Message= {"id":10,"method":"get_clean_summary"}
                            mihome-vacuum.0
                            2023-11-26 09:25:42.708	debug	Startup: Delete getMultiMapsList
                            mihome-vacuum.0
                            2023-11-26 09:25:42.707	debug	Startup: getMultiMapsList Answer: true
                            mihome-vacuum.0
                            2023-11-26 09:25:42.707	debug	your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
                            mihome-vacuum.0
                            2023-11-26 09:25:40.703	debug	Message= {"id":9,"method":"get_multi_maps_list"}
                            mihome-vacuum.0
                            2023-11-26 09:25:40.701	debug	your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
                            mihome-vacuum.0
                            2023-11-26 09:25:38.699	debug	Message= {"id":8,"method":"get_sound_volume"}
                            mihome-vacuum.0
                            2023-11-26 09:25:38.698	debug	your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
                            mihome-vacuum.0
                            2023-11-26 09:25:36.696	debug	Message= {"id":7,"method":"get_network_info"}
                            mihome-vacuum.0
                            2023-11-26 09:25:36.692	debug	your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
                            mihome-vacuum.0
                            2023-11-26 09:25:35.215	info	settest next timer: not available
                            mihome-vacuum.0
                            2023-11-26 09:25:34.683	debug	Message= {"id":6,"method":"get_status"}
                            mihome-vacuum.0
                            2023-11-26 09:25:34.682	debug	get params for stock Vacuum
                            mihome-vacuum.0
                            2023-11-26 09:25:34.681	debug	Create State done!
                            mihome-vacuum.0
                            2023-11-26 09:25:34.680	debug	Create State for map: loadMap
                            mihome-vacuum.0
                            2023-11-26 09:25:34.679	debug	Create State for map: mapURL
                            mihome-vacuum.0
                            2023-11-26 09:25:34.679	debug	Create State for map: mapStatus
                            mihome-vacuum.0
                            2023-11-26 09:25:34.679	debug	Create State for map: actualMap
                            mihome-vacuum.0
                            2023-11-26 09:25:34.678	debug	Create State for map: map64
                            mihome-vacuum.0
                            2023-11-26 09:25:34.640	debug	Create State for map:
                            mihome-vacuum.0
                            2023-11-26 09:25:34.634	debug	Create State for Queue: queue
                            mihome-vacuum.0
                            2023-11-26 09:25:34.514	debug	Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
                            mihome-vacuum.0
                            2023-11-26 09:25:34.494	info	select standard vacuum protocol....
                            mihome-vacuum.0
                            2023-11-26 09:25:34.493	debug	DeviceModel selected to: roborock.vacuum.s5
                            mihome-vacuum.0
                            2023-11-26 09:25:34.492	warn	No Answer for DeviceModel use old one
                            mihome-vacuum.0
                            2023-11-26 09:25:34.492	error	YOUR DEVICE IS CONNECTED BUT DID NOT ANSWER YET - CONNECTION CAN TAKE UP TO 10 MINUTES - PLEASE BE PATIENT AND DO NOT TURN THE ADAPTER OFF
                            mihome-vacuum.0
                            2023-11-26 09:25:34.491	debug	Get Device data..4
                            mihome-vacuum.0
                            2023-11-26 09:25:34.491	debug	GETMODELFROMAPI:Data: {}
                            mihome-vacuum.0
                            2023-11-26 09:25:34.490	debug	your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
                            mihome-vacuum.0
                            2023-11-26 09:25:34.382	debug	Time difference between Mihome Vacuum and ioBroker: 5487 sec
                            mihome-vacuum.0
                            2023-11-26 09:25:34.382	debug	Receive <<< Helo <<< 21310020000000000707a9126563166dffffffffffffffffffffffffffffffff
                            mihome-vacuum.0
                            2023-11-26 09:25:32.485	debug	Message= {"id":5,"method":"miIO.info"}
                            mihome-vacuum.0
                            2023-11-26 09:25:32.485	debug	Get Device data..3
                            mihome-vacuum.0
                            2023-11-26 09:25:32.484	debug	GETMODELFROMAPI:Data: {}
                            mihome-vacuum.0
                            2023-11-26 09:25:32.483	debug	your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
                            mihome-vacuum.0
                            2023-11-26 09:25:30.481	debug	Message= {"id":4,"method":"miIO.info"}
                            mihome-vacuum.0
                            2023-11-26 09:25:30.480	debug	Get Device data..2
                            mihome-vacuum.0
                            2023-11-26 09:25:30.480	debug	GETMODELFROMAPI:Data: {}
                            mihome-vacuum.0
                            2023-11-26 09:25:30.479	debug	your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
                            mihome-vacuum.0
                            2023-11-26 09:25:28.475	debug	Message= {"id":3,"method":"miIO.info"}
                            mihome-vacuum.0
                            2023-11-26 09:25:28.474	debug	Get Device data..1
                            mihome-vacuum.0
                            2023-11-26 09:25:28.474	debug	GETMODELFROMAPI:Data: {}
                            mihome-vacuum.0
                            2023-11-26 09:25:28.473	debug	your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
                            mihome-vacuum.0
                            2023-11-26 09:25:26.471	debug	Message= {"id":2,"method":"miIO.info"}
                            mihome-vacuum.0
                            2023-11-26 09:25:26.471	debug	Get Device data..0
                            mihome-vacuum.0
                            2023-11-26 09:25:26.470	debug	GETMODELFROMAPI:Data: {}
                            mihome-vacuum.0
                            2023-11-26 09:25:26.469	debug	your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
                            mihome-vacuum.0
                            2023-11-26 09:25:24.462	debug	Message= {"id":1,"method":"miIO.info"}
                            mihome-vacuum.0
                            2023-11-26 09:25:24.453	debug	GETMODELFROMAPI: objModel: {"val":"roborock.vacuum.s5","ack":true,"ts":1700987084613,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":1669663806090}
                            mihome-vacuum.0
                            2023-11-26 09:25:24.378	debug	Time difference between Mihome Vacuum and ioBroker: 5487 sec
                            mihome-vacuum.0
                            2023-11-26 09:25:24.375	debug	MAIN: Connected to device, try to get model..
                            mihome-vacuum.0
                            2023-11-26 09:25:24.374	debug	Receive <<< Helo <<< 21310020000000000707a91265631663ffffffffffffffffffffffffffffffff
                            mihome-vacuum.0
                            2023-11-26 09:25:24.362	debug	server started on 0.0.0.0:53421
                            mihome-vacuum.0
                            2023-11-26 09:25:24.357	info	IOT enabled, create state
                            mihome-vacuum.0
                            2023-11-26 09:25:24.348	debug	MIIO: Config: ip:192.168.1.41 token: 436559496bXXXXXXXXX
                            mihome-vacuum.0
                            2023-11-26 09:25:24.346	debug	Create State for deviceInfounsupported
                            mihome-vacuum.0
                            2023-11-26 09:25:24.345	debug	Create State for deviceInfowifi_signal
                            mihome-vacuum.0
                            2023-11-26 09:25:24.343	debug	Create State for deviceInfofw_ver
                            mihome-vacuum.0
                            2023-11-26 09:25:24.342	debug	Create State for deviceInfomodel
                            mihome-vacuum.0
                            2023-11-26 09:25:24.341	debug	Create State for deviceInfomac
                            mihome-vacuum.0
                            2023-11-26 09:25:24.340	debug	Create State for deviceInfo
                            mihome-vacuum.0
                            2023-11-26 09:25:24.288	debug	load Map creator... true
                            mihome-vacuum.0
                            2023-11-26 09:25:24.184	info	starting. Version 4.1.0 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v18.18.2, js-controller: 5.0.16
                            mihome-vacuum.0
                            2023-11-26 09:25:23.615	info	Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                            mihome-vacuum.0
                            2023-11-26 09:25:23.599	debug	Plugin sentry Initialize Plugin (enabled=true)
                            mihome-vacuum.0
                            2023-11-26 09:25:23.470	debug	States connected to redis: 127.0.0.1:9000
                            mihome-vacuum.0
                            2023-11-26 09:25:23.292	debug	States create User PubSub Client
                            mihome-vacuum.0
                            2023-11-26 09:25:23.291	debug	States create System PubSub Client
                            mihome-vacuum.0
                            2023-11-26 09:25:23.223	debug	Redis States: Use Redis connection: 127.0.0.1:9000
                            mihome-vacuum.0
                            2023-11-26 09:25:23.070	debug	Objects connected to redis: 127.0.0.1:9001
                            mihome-vacuum.0
                            2023-11-26 09:25:23.059	debug	Objects client initialize lua scripts
                            mihome-vacuum.0
                            2023-11-26 09:25:22.831	debug	Objects create User PubSub Client
                            mihome-vacuum.0
                            2023-11-26 09:25:22.829	debug	Objects create System PubSub Client
                            mihome-vacuum.0
                            2023-11-26 09:25:22.719	debug	Objects client ready ... initialize now
                            mihome-vacuum.0
                            2023-11-26 09:25:21.705	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
                            mihome-vacuum.0
                            2023-11-26 09:24:45.858	debug	Message= {"id":21,"method":"get_clean_record","params":[1700314076]}
                            mihome-vacuum.0
                            2023-11-26 09:24:45.857	debug	MIIO RECIVE: {"result":[[1700317501,1700318356,769,13972500,0,0,3,1]],"id":20}
                            mihome-vacuum.0
                            2023-11-26 09:24:45.856	debug	MIIO MESSAGE TESTING: {"result":[[1700317501,1700318356,769,13972500,0,0,3,1]],"id":20}
                            mihome-vacuum.0
                            2023-11-26 09:24:45.835	debug	Message= {"id":20,"method":"get_clean_record","params":[1700317501]}
                            mihome-vacuum.0
                            2023-11-26 09:24:45.833	debug	MIIO RECIVE: {"result":[[1700403901,1700405572,1671,31715000,0,1,3,1]],"id":19}
                            mihome-vacuum.0
                            2023-11-26 09:24:45.831	debug	MIIO MESSAGE TESTING: {"result":[[1700403901,1700405572,1671,31715000,0,1,3,1]],"id":19}
                            mihome-vacuum.0
                            2023-11-26 09:24:45.813	debug	Message= {"id":19,"method":"get_clean_record","params":[1700403901]}
                            mihome-vacuum.0
                            2023-11-26 09:24:45.812	debug	MIIO RECIVE: {"result":[[1700486701,1700488361,1660,31490000,0,1,3,1]],"id":18}
                            mihome-vacuum.0
                            2023-11-26 09:24:45.811	debug	MIIO MESSAGE TESTING: {"result":[[1700486701,1700488361,1660,31490000,0,1,3,1]],"id":18}
                            mihome-vacuum.0
                            2023-11-26 09:24:45.801	debug	Message= {"id":18,"method":"get_clean_record","params":[1700486701]}
                            mihome-vacuum.0
                            2023-11-26 09:24:45.800	debug	MIIO RECIVE: {"result":[[1700573101,1700574894,1793,31385000,0,1,3,1]],"id":17}
                            mihome-vacuum.0
                            2023-11-26 09:24:45.799	debug	MIIO MESSAGE TESTING: {"result":[[1700573101,1700574894,1793,31385000,0,1,3,1]],"id":17}
                            mihome-vacuum.0
                            2023-11-26 09:24:45.797	debug	MIIO MESSAGE TESTING: {"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":16}
                            mihome-vacuum.0
                            2023-11-26 09:24:45.796	debug	MIIO RECIVE: {"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":16}
                            mihome-vacuum.0
                            2023-11-26 09:24:45.795	debug	MIIO MESSAGE TESTING: {"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":16}
                            mihome-vacuum.0
                            2023-11-26 09:24:45.773	debug	Message= {"id":17,"method":"get_clean_record","params":[1700573101]}
                            mihome-vacuum.0
                            2023-11-26 09:24:45.772	debug	MIIO MESSAGE TESTING: {"result":[[1700659501,1700661175,1674,31800000,0,1,3,1]],"id":15}
                            mihome-vacuum.0
                            2023-11-26 09:24:45.771	debug	MIIO RECIVE: {"result":[[1700659501,1700661175,1674,31800000,0,1,3,1]],"id":15}
                            mihome-vacuum.0
                            2023-11-26 09:24:45.770	debug	MIIO MESSAGE TESTING: {"result":[[1700659501,1700661175,1674,31800000,0,1,3,1]],"id":15}
                            mihome-vacuum.0
                            2023-11-26 09:24:45.767	debug	Message= {"id":16,"method":"get_carpet_mode"}
                            mihome-vacuum.0
                            2023-11-26 09:24:45.766	info	create state for carpet_mode
                            mihome-vacuum.0
                            2023-11-26 09:24:45.765	debug	MIIO MESSAGE TESTING: {"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":14}
                            mihome-vacuum.0
                            2023-11-26 09:24:45.764	debug	MIIO RECIVE: {"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":14}
                            mihome-vacuum.0
                            2023-11-26 09:24:45.763	debug	MIIO MESSAGE TESTING: {"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":14}
                            mihome-vacuum.0
                            2023-11-26 09:24:45.761	debug	Message= {"id":15,"method":"get_clean_record","params":[1700659501]}
                            mihome-vacuum.0
                            2023-11-26 09:24:45.760	debug	MIIO MESSAGE TESTING: {"result":[[1700745900,1700747612,1712,31885000,0,1,3,1]],"id":13}
                            mihome-vacuum.0
                            2023-11-26 09:24:45.760	debug	MIIO RECIVE: {"result":[[1700745900,1700747612,1712,31885000,0,1,3,1]],"id":13}
                            mihome-vacuum.0
                            2023-11-26 09:24:45.759	debug	MIIO MESSAGE TESTING: {"result":[[1700745900,1700747612,1712,31885000,0,1,3,1]],"id":13}
                            mihome-vacuum.0
                            2023-11-26 09:24:45.757	debug	Message= {"id":14,"method":"get_carpet_mode"}
                            mihome-vacuum.0
                            2023-11-26 09:24:45.755	debug	Startup: Delete setGetConsumable
                            mihome-vacuum.0
                            2023-11-26 09:24:45.755	debug	Startup: setGetConsumable Answer: true
                            mihome-vacuum.0
                            2023-11-26 09:24:45.753	debug	MIIO MESSAGE TESTING: {"result":[{"main_brush_work_time":1294324,"side_brush_work_time":420918,"filter_work_time":806724,"filter_element_work_time":0,"sensor_dirty_time":420768}],"id":12}
                            mihome-vacuum.0
                            2023-11-26 09:24:45.752	debug	MIIO RECIVE: {"result":[{"main_brush_work_time":1294324,"side_brush_work_time":420918,"filter_work_time":806724,"filter_element_work_time":0,"sensor_dirty_time":420768}],"id":12}
                            mihome-vacuum.0
                            2023-11-26 09:24:45.751	debug	MIIO MESSAGE TESTING: {"result":[{"main_brush_work_time":1294324,"side_brush_work_time":420918,"filter_work_time":806724,"filter_element_work_time":0,"sensor_dirty_time":420768}],"id":12}
                            mihome-vacuum.0
                            2023-11-26 09:24:45.749	debug	Message= {"id":13,"method":"get_clean_record","params":[1700745900]}
                            mihome-vacuum.0
                            2023-11-26 09:24:45.748	debug	MIIO MESSAGE TESTING: {"result":[[1700832301,1700834121,1820,31445000,0,1,3,1]],"id":11}
                            mihome-vacuum.0
                            2023-11-26 09:24:45.748	debug	MIIO RECIVE: {"result":[[1700832301,1700834121,1820,31445000,0,1,3,1]],"id":11}
                            mihome-vacuum.0
                            2023-11-26 09:24:45.747	debug	MIIO MESSAGE TESTING: {"result":[[1700832301,1700834121,1820,31445000,0,1,3,1]],"id":11}
                            mihome-vacuum.0
                            2023-11-26 09:24:45.745	debug	Message= {"id":12,"method":"get_consumable"}
                            mihome-vacuum.0
                            2023-11-26 09:24:45.744	debug	Startup: Delete setGetCleanSummary
                            mihome-vacuum.0
                            2023-11-26 09:24:45.744	debug	Startup: setGetCleanSummary Answer: true
                            mihome-vacuum.0
                            2023-11-26 09:24:45.742	debug	MIIO MESSAGE TESTING: {"result":[2925029,52405125000,1837,[1700918701,1700832301,1700745900,1700659501,1700573101,1700486701,1700403901,1700317501,1700314076,1700227501,1700141101,1700054701,1699968301,1699881901,1699799101,1699712701,1699622701,1699536301,1699449901,1699363501]],"id":10}
                            mihome-vacuum.0
                            2023-11-26 09:24:45.740	debug	MIIO RECIVE: {"result":[2925029,52405125000,1837,[1700918701,1700832301,1700745900,1700659501,1700573101,1700486701,1700403901,1700317501,1700314076,1700227501,1700141101,1700054701,1699968301,1699881901,1699799101,1699712701,1699622701,1699536301,1699449901,1699363501]],"id":10}
                            mihome-vacuum.0
                            2023-11-26 09:24:45.739	debug	MIIO MESSAGE TESTING: {"result":[2925029,52405125000,1837,[1700918701,1700832301,1700745900,1700659501,1700573101,1700486701,1700403901,1700317501,1700314076,1700227501,1700141101,1700054701,1699968301,1699881901,1699799101,1699712701,1699622701,1699536301,1699449901,1699363501]],"id":10}
                            mihome-vacuum.0
                            2023-11-26 09:24:45.724	debug	Message= {"id":11,"method":"get_clean_record","params":[1700832301]}
                            mihome-vacuum.0
                            2023-11-26 09:24:45.722	debug	MIIO MESSAGE TESTING: {"result":[[1700918701,1700920380,1679,31117500,0,1,3,1]],"id":9}
                            mihome-vacuum.0
                            2023-11-26 09:24:45.721	debug	MIIO RECIVE: {"result":[[1700918701,1700920380,1679,31117500,0,1,3,1]],"id":9}
                            mihome-vacuum.0
                            2023-11-26 09:24:45.720	debug	MIIO MESSAGE TESTING: {"result":[[1700918701,1700920380,1679,31117500,0,1,3,1]],"id":9}
                            mihome-vacuum.0
                            2023-11-26 09:24:45.711	debug	Message= {"id":10,"method":"get_clean_summary"}
                            mihome-vacuum.0
                            2023-11-26 09:24:45.710	debug	Startup: Delete getMultiMapsList
                            mihome-vacuum.0
                            2023-11-26 09:24:45.710	debug	Startup: getMultiMapsList Answer: true
                            mihome-vacuum.0
                            2023-11-26 09:24:45.709	debug	MIIO MESSAGE TESTING: {"result":"unknown_method","id":8}
                            mihome-vacuum.0
                            2023-11-26 09:24:45.708	debug	MIIO RECIVE: {"result":"unknown_method","id":8}
                            mihome-vacuum.0
                            2023-11-26 09:24:45.707	debug	MIIO MESSAGE TESTING: {"result":"unknown_method","id":8}
                            mihome-vacuum.0
                            2023-11-26 09:24:45.705	debug	Message= {"id":9,"method":"get_clean_record","params":[1700918701]}
                            mihome-vacuum.0
                            2023-11-26 09:24:45.702	debug	MIIO MESSAGE TESTING: {"result":[2925029,52405125000,1837,[1700918701,1700832301,1700745900,1700659501,1700573101,1700486701,1700403901,1700317501,1700314076,1700227501,1700141101,1700054701,1699968301,1699881901,1699799101,1699712701,1699622701,1699536301,1699449901,1699363501]],"id":7}
                            mihome-vacuum.0
                            2023-11-26 09:24:45.701	debug	MIIO RECIVE: {"result":[2925029,52405125000,1837,[1700918701,1700832301,1700745900,1700659501,1700573101,1700486701,1700403901,1700317501,1700314076,1700227501,1700141101,1700054701,1699968301,1699881901,1699799101,1699712701,1699622701,1699536301,1699449901,1699363501]],"id":7}
                            mihome-vacuum.0
                            2023-11-26 09:24:45.700	debug	MIIO MESSAGE TESTING: {"result":[2925029,52405125000,1837,[1700918701,1700832301,1700745900,1700659501,1700573101,1700486701,1700403901,1700317501,1700314076,1700227501,1700141101,1700054701,1699968301,1699881901,1699799101,1699712701,1699622701,1699536301,1699449901,1699363501]],"id":7}
                            mihome-vacuum.0
                            2023-11-26 09:24:45.696	debug	Message= {"id":8,"method":"get_multi_maps_list"}
                            mihome-vacuum.0
                            2023-11-26 09:24:45.695	debug	MIIO MESSAGE TESTING: {"result":[73],"id":6}
                            mihome-vacuum.0
                            2023-11-26 09:24:45.693	debug	MIIO RECIVE: {"result":[73],"id":6}
                            mihome-vacuum.0
                            2023-11-26 09:24:45.692	debug	MIIO MESSAGE TESTING: {"result":[73],"id":6}
                            mihome-vacuum.0
                            2023-11-26 09:24:45.689	debug	Message= {"id":7,"method":"get_clean_summary"}
                            mihome-vacuum.0
                            2023-11-26 09:24:45.684	debug	Message= {"id":6,"method":"get_sound_volume"}
                            mihome-vacuum.0
                            2023-11-26 09:24:45.622	debug	MIIO RECIVE: {"result":{"ssid":"Papi1","ip":"192.168.1.41","mac":"40:31:3c:aa:51:97","bssid":"e8:df:70:b8:a1:44","rssi":-57},"id":5}
                            mihome-vacuum.0
                            2023-11-26 09:24:45.619	debug	MIIO MESSAGE TESTING: {"result":{"ssid":"Papi1","ip":"192.168.1.41","mac":"40:31:3c:aa:51:97","bssid":"e8:df:70:b8:a1:44","rssi":-57},"id":5}
                            mihome-vacuum.0
                            2023-11-26 09:24:45.607	debug	MIIO MESSAGE TESTING: {"result":[{"main_brush_work_time":1294324,"side_brush_work_time":420918,"filter_work_time":806724,"filter_element_work_time":0,"sensor_dirty_time":420768}],"id":4}
                            mihome-vacuum.0
                            2023-11-26 09:24:45.605	debug	MIIO RECIVE: {"result":[{"main_brush_work_time":1294324,"side_brush_work_time":420918,"filter_work_time":806724,"filter_element_work_time":0,"sensor_dirty_time":420768}],"id":4}
                            mihome-vacuum.0
                            2023-11-26 09:24:45.604	debug	MIIO MESSAGE TESTING: {"result":[{"main_brush_work_time":1294324,"side_brush_work_time":420918,"filter_work_time":806724,"filter_element_work_time":0,"sensor_dirty_time":420768}],"id":4}
                            mihome-vacuum.0
                            2023-11-26 09:24:45.591	debug	Message= {"id":5,"method":"get_network_info"}
                            mihome-vacuum.0
                            2023-11-26 09:24:45.589	debug	Message= {"id":4,"method":"get_consumable"}
                            mihome-vacuum.0
                            2023-11-26 09:24:45.588	debug	MIIO RECIVE: {"result":[],"id":3}
                            mihome-vacuum.0
                            2023-11-26 09:24:45.586	debug	MIIO MESSAGE TESTING: {"result":[],"id":3}
                            mihome-vacuum.0
                            2023-11-26 09:24:45.570	debug	Message= {"id":3,"method":"get_room_mapping"}
                            mihome-vacuum.0
                            2023-11-26 09:24:45.545	info	settest next timer: not available
                            mihome-vacuum.0
                            2023-11-26 09:24:45.142	debug	Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
                            mihome-vacuum.0
                            2023-11-26 09:24:45.134	info	create states for water box
                            mihome-vacuum.0
                            2023-11-26 09:24:45.132	info	change states from State control.fan_power
                            mihome-vacuum.0
                            2023-11-26 09:24:45.131	debug	setGetStatus {"msg_ver":3,"msg_seq":502,"state":8,"battery":100,"clean_time":1679,"clean_area":31117500,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":104,"dnd_enabled":false,"map_status":3,"lock_status":0,"error_text":"No error"}
                            mihome-vacuum.0
                            2023-11-26 09:24:45.129	debug	MIIO RECIVE: {"result":[{"msg_ver":3,"msg_seq":502,"state":8,"battery":100,"clean_time":1679,"clean_area":31117500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":104,"dnd_enabled":0,"map_status":3,"lock_status":0}],"id":2}
                            mihome-vacuum.0
                            2023-11-26 09:24:45.128	debug	MIIO MESSAGE TESTING: {"result":[{"msg_ver":3,"msg_seq":502,"state":8,"battery":100,"clean_time":1679,"clean_area":31117500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":104,"dnd_enabled":0,"map_status":3,"lock_status":0}],"id":2}
                            mihome-vacuum.0
                            2023-11-26 09:24:45.119	debug	Message= {"id":2,"method":"get_status"}
                            mihome-vacuum.0
                            2023-11-26 09:24:45.118	debug	get params for stock Vacuum
                            mihome-vacuum.0
                            2023-11-26 09:24:45.117	debug	Create State done!
                            mihome-vacuum.0
                            2023-11-26 09:24:45.115	debug	Create State for map: loadMap
                            mihome-vacuum.0
                            2023-11-26 09:24:45.114	debug	Create State for map: mapURL
                            mihome-vacuum.0
                            2023-11-26 09:24:45.113	debug	Create State for map: mapStatus
                            mihome-vacuum.0
                            2023-11-26 09:24:45.113	debug	Create State for map: actualMap
                            mihome-vacuum.0
                            2023-11-26 09:24:45.112	debug	Create State for map: map64
                            mihome-vacuum.0
                            2023-11-26 09:24:45.074	debug	Create State for map:
                            mihome-vacuum.0
                            2023-11-26 09:24:45.067	debug	Create State for Queue: queue
                            mihome-vacuum.0
                            2023-11-26 09:24:44.730	debug	Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
                            mihome-vacuum.0
                            2023-11-26 09:24:44.690	info	select standard vacuum protocol....
                            mihome-vacuum.0
                            2023-11-26 09:24:44.682	debug	DeviceModel selected to: roborock.vacuum.s5
                            mihome-vacuum.0
                            2023-11-26 09:24:44.565	debug	Get Device data from robot.. {"hw_ver":"Linux","fw_ver":"3.5.7_002008","ap":{"ssid":"Papi1","bssid":"E8:DF:70:B8:A1:44","rssi":-57},"netif":{"localIp":"192.168.1.41","mask":"255.255.255.0","gw":"192.168.1.100"},"model":"roborock.vacuum.s5","mac":"40:31:3C:AA:51:97","token":"436559496bXXXXXX":27167}
                            mihome-vacuum.0
                            2023-11-26 09:24:44.564	debug	Get Device data..0
                            mihome-vacuum.0
                            2023-11-26 09:24:44.562	debug	GETMODELFROMAPI:Data: {"partner_id":"","id":1,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.5.7_002008","ap":{"ssid":"Papi1","bssid":"E8:DF:70:B8:A1:44","rssi":-57},"netif":{"localIp":"192.168.1.41","mask":"255.255.255.0","gw":"192.168.1.100"},"model":"roborock.vacuum.s5","mac":"40:31:3C:AA:51:97","token":"436559496bXXXXXX":27167}}
                            mihome-vacuum.0
                            2023-11-26 09:24:44.560	debug	MIIO RECIVE: {"partner_id":"","id":1,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.5.7_002008","ap":{"ssid":"Papi1","bssid":"E8:DF:70:B8:A1:44","rssi":-57},"netif":{"localIp":"192.168.1.41","mask":"255.255.255.0","gw":"192.168.1.100"},"model":"roborock.vacuum.s5","mac":"40:31:3C:AA:51:97","token":"436559496b50444c32686a316a6d3737","life":27167}}
                            mihome-vacuum.0
                            2023-11-26 09:24:44.558	debug	MIIO MESSAGE TESTING: {"partner_id":"","id":1,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.5.7_002008","ap":{"ssid":"Papi1","bssid":"E8:DF:70:B8:A1:44","rssi":-57},"netif":{"localIp":"192.168.1.41","mask":"255.255.255.0","gw":"192.168.1.100"},"model":"roborock.vacuum.s5","mac":"40:31:3C:AA:51:97","token":"436559496b50444c32686a316a6d3737","life":27167}}
                            mihome-vacuum.0
                            2023-11-26 09:24:44.542	debug	Message= {"id":1,"method":"miIO.info"}
                            mihome-vacuum.0
                            2023-11-26 09:24:44.540	debug	GETMODELFROMAPI: objModel: {"val":"roborock.vacuum.s5","ack":true,"ts":1700986820893,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":1669663806090}
                            mihome-vacuum.0
                            2023-11-26 09:24:44.456	debug	Time difference between Mihome Vacuum and ioBroker: 5487 sec
                            mihome-vacuum.0
                            2023-11-26 09:24:44.452	debug	MAIN: Connected to device, try to get model..
                            mihome-vacuum.0
                            2023-11-26 09:24:44.450	debug	Receive <<< Helo <<< 21310020000000000707a9126563163bffffffffffffffffffffffffffffffff
                            mihome-vacuum.0
                            2023-11-26 09:24:44.429	debug	server started on 0.0.0.0:53421
                            mihome-vacuum.0
                            2023-11-26 09:24:44.423	info	IOT enabled, create state
                            mihome-vacuum.0
                            2023-11-26 09:24:44.417	debug	MIIO: Config: ip:192.168.1.41 token: 436559496bXXXXXXXXX
                            mihome-vacuum.0
                            2023-11-26 09:24:44.415	debug	Create State for deviceInfounsupported
                            mihome-vacuum.0
                            2023-11-26 09:24:44.415	debug	Create State for deviceInfowifi_signal
                            mihome-vacuum.0
                            2023-11-26 09:24:44.414	debug	Create State for deviceInfofw_ver
                            mihome-vacuum.0
                            2023-11-26 09:24:44.413	debug	Create State for deviceInfomodel
                            mihome-vacuum.0
                            2023-11-26 09:24:44.413	debug	Create State for deviceInfomac
                            mihome-vacuum.0
                            2023-11-26 09:24:44.412	debug	Create State for deviceInfo
                            mihome-vacuum.0
                            2023-11-26 09:24:44.367	debug	load Map creator... true
                            mihome-vacuum.0
                            2023-11-26 09:24:44.285	info	starting. Version 4.1.0 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v18.18.2, js-controller: 5.0.16
                            mihome-vacuum.0
                            2023-11-26 09:24:44.049	info	Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                            mihome-vacuum.0
                            2023-11-26 09:24:44.041	debug	Plugin sentry Initialize Plugin (enabled=true)
                            mihome-vacuum.0
                            2023-11-26 09:24:43.940	debug	States connected to redis: 127.0.0.1:9000
                            mihome-vacuum.0
                            2023-11-26 09:24:43.763	debug	States create User PubSub Client
                            mihome-vacuum.0
                            2023-11-26 09:24:43.761	debug	States create System PubSub Client
                            mihome-vacuum.0
                            2023-11-26 09:24:43.681	debug	Redis States: Use Redis connection: 127.0.0.1:9000
                            mihome-vacuum.0
                            2023-11-26 09:24:43.534	debug	Objects connected to redis: 127.0.0.1:9001
                            mihome-vacuum.0
                            2023-11-26 09:24:43.517	debug	Objects client initialize lua scripts
                            mihome-vacuum.0
                            2023-11-26 09:24:43.274	debug	Objects create User PubSub Client
                            mihome-vacuum.0
                            2023-11-26 09:24:43.272	debug	Objects create System PubSub Client
                            mihome-vacuum.0
                            2023-11-26 09:24:43.269	debug	Objects client ready ... initialize now
                            mihome-vacuum.0
                            2023-11-26 09:24:43.165	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
                            Die Ports sind natürlich auch alle wieder durchgereicht (1012, 1880,1883, 2001, 8081, 8088, 8282, 8284, 49000, 49443 (alle TCP)).
                            So, ich muss nun wieder los, ich kann wohl erst morgen Abend wieder reinsehen, ob sich hier etwas getan hat. Also keinen Stress und auch jetzt schon wieder 1000 Dank!
                              Papi 0 @Papi 0 last edited by Papi 0
                              @Codierknecht
                              Jetzt habe ich es:
                              Zwar hatte ich den Adapter schon mehrfach erfolglos gelöscht, gedowngraded, und geupdated, aber jetzt, nachdem ich den ioBroker mit Deiner freundlichen Hilfe repariert habe, habe ich aus lauter Langeweile den Adapter nochmal gelöscht und wieder angelegt, jetzt funktioniert er plötzlich! Ihm haben wohl ständig irgendwelche Grundvoraussetzungen gefehlt, die er nun verfügbar hat.
                              Dasselbe hat ich dann auch gleich mit dem Staubsauger ausprobiert, mit selbem Ergebnis, alles läuft jetzt einwandfrei!
                              Vielen Dank für alles!
                              • Codierknecht
                                Prima!
                                Dann sei bitte so nett und markiere Deinen Beitrag als "gelöst".
                                Dazu den Eingangspost bearbeiten und ein "[gelöst] - " vor den Titel setzen.
                                1408
