    4. Vis über npm gibt EHOSTUNREACH
      apollon77 @Christian 5 last edited by apollon77
      @christian-5 Checke mal dein Netzwerk und Der kann den npm server nicht erreichen ... EHOST UNREACH ... Host unreachable .... Komisch wenn ping geht ... was sagt "curl "oder wget?
        Christian 5 @apollon77 last edited by Christian 5
        @apollon77 danke, ich hab jetzt iob diag laufen lassen und bekomm dort die meldung:
        Skript v.2023-10-25
        *** BASE SYSTEM ***
           Static hostname: iobroker
                 Icon name: computer
          Operating System: Debian GNU/Linux 11 (bullseye)
                    Kernel: Linux 6.1.21-v8+
              Architecture: arm64
        Model           : Raspberry Pi 4 Model B Rev 1.5
        Docker          : false
        Virtualization  : none
        Kernel          : aarch64
        Userland        : arm64
        Systemuptime and Load:
         17:49:26 up  2:07,  1 user,  load average: 1.77, 2.16, 2.39
        CPU threads: 4
        *** RASPBERRY THROTTLING ***
        Current issues:
        Previously detected issues:
        *** Time and Time Zones ***
                       Local time: Thu 2023-11-23 17:49:26 CET
                   Universal time: Thu 2023-11-23 16:49:26 UTC
                         RTC time: n/a
                        Time zone: Europe/Vienna (CET, +0100)
                      NTP service: active
                  RTC in local TZ: no
        *** User and Groups ***
        iobroker
        /home/iobroker
        iobroker adm tty dialout cdrom sudo audio video plugdev games users input render netdev bluetooth gpio i2c spi
        *** X-Server-Setup ***
        X-Server:       false
        Desktop:
        Terminal:       tty
        Boot Target:    multi-user.target
        *** MEMORY ***
        Mem:            7.8G        2.1G        2.9G        1.0M        2.9G        5.6G
        Swap:            99M          0B         99M
        Total:          7.9G        2.1G        3.0G
                 7811 M total memory
                 2081 M used memory
                 3245 M active memory
                 1469 M inactive memory
                 2861 M free memory
                  111 M buffer memory
                 2756 M swap cache
                   99 M total swap
                    0 M used swap
                   99 M free swap
        Raspberry only:
        oom events: 0
        *** FAILED SERVICES ***
        0 loaded units listed.
        *** FILESYSTEM ***
        /dev/root      ext4      118G   24G   89G  21% /
        devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
        tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
        tmpfs          tmpfs     1.6G  1.1M  1.6G   1% /run
        /dev/sda1      vfat      255M   31M  225M  13% /boot
        tmpfs          tmpfs     782M     0  782M   0% /run/user/1000
        [Thu Nov 23 15:42:01 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:2A:25:6C vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyAMA0,115200 console=tty1 root=PARTUUID=57cd214b-02 rootfstype=ext4 fsck.repair=yes rootwait
        [Thu Nov 23 15:42:04 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
        [Thu Nov 23 15:42:04 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
        [Thu Nov 23 15:42:09 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
        Show mounted filesystems:
        TARGET                       SOURCE     FSTYPE     OPTIONS
        /                            /dev/sda2  ext4       rw,noatime
        |-/dev                       devtmpfs   devtmpfs   rw,relatime,size=3735168k,nr_inodes=933792,mode=755
        | |-/dev/shm                 tmpfs      tmpfs      rw,nosuid,nodev
        | |-/dev/pts                 devpts     devpts     rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
        | `-/dev/mqueue              mqueue     mqueue     rw,nosuid,nodev,noexec,relatime
        |-/proc                      proc       proc       rw,relatime
        | `-/proc/sys/fs/binfmt_misc systemd-1  autofs     rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct
        |-/sys                       sysfs      sysfs      rw,nosuid,nodev,noexec,relatime
        | |-/sys/kernel/security     securityfs securityfs rw,nosuid,nodev,noexec,relatime
        | |-/sys/fs/cgroup           cgroup2    cgroup2    rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
        | |-/sys/fs/pstore           pstore     pstore     rw,nosuid,nodev,noexec,relatime
        | |-/sys/fs/bpf              bpf        bpf        rw,nosuid,nodev,noexec,relatime,mode=700
        | |-/sys/kernel/tracing      tracefs    tracefs    rw,nosuid,nodev,noexec,relatime
        | |-/sys/kernel/debug        debugfs    debugfs    rw,nosuid,nodev,noexec,relatime
        | |-/sys/kernel/config       configfs   configfs   rw,nosuid,nodev,noexec,relatime
        | `-/sys/fs/fuse/connections fusectl    fusectl    rw,nosuid,nodev,noexec,relatime
        |-/run                       tmpfs      tmpfs      rw,nosuid,nodev,size=1599760k,nr_inodes=819200,mode=755
        | |-/run/lock                tmpfs      tmpfs      rw,nosuid,nodev,noexec,relatime,size=5120k
        | |-/run/rpc_pipefs          sunrpc     rpc_pipefs rw,relatime
        | `-/run/user/1000           tmpfs      tmpfs      rw,nosuid,nodev,relatime,size=799876k,nr_inodes=199969,mode=700,uid=1000,gid=1000
        `-/boot                      /dev/sda1  vfat       rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
        /var:
        20G     /var/
        16G     /var/lib
        15G     /var/lib/influxdb/engine/data/9d69ae680368264c/autogen
        Archived and active journals take up 3.2G in the file system.
        /opt/iobroker/backups:
        139M    /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        399M    /opt/iobroker/iobroker-data/
        304M    /opt/iobroker/iobroker-data/files
        78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
        69M     /opt/iobroker/iobroker-data/backup-objects
        52M     /opt/iobroker/iobroker-data/files/javascript.admin
        23M     /opt/iobroker/iobroker-data/objects.jsonl
        21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map
        8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js
        7.1M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.f22de4ab.chunk.js.map
        6.6M    /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.8083c40d.js.map
        USB-Devices by-id:
        *** NodeJS-Installation ***
        ./iob_diag: line 283: nodejs: command not found
        /usr/bin/node           v16.20.2
        /usr/bin/npm            8.19.4
        /usr/bin/npx            8.19.4
        /usr/bin/corepack       0.17.0
        ./iob_diag: line 294: nodejs: command not found
        *** nodejs is NOT correctly installed ***
        Run ob nodejs-update to fix it.
        nodejs:
          Installed: 16.20.2-deb-1nodesource1
          Candidate: 16.20.2-deb-1nodesource1
          Version table:
         *** 16.20.2-deb-1nodesource1 500
                500 https://deb.nodesource.com/node_16.x bullseye/main arm64 Packages
                100 /var/lib/dpkg/status
             12.22.12~dfsg-1~deb11u4 500
                500 http://deb.debian.org/debian bullseye/main arm64 Packages
                500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
        No problems detected
        Errors in npm tree:
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Core adapters versions
        js-controller:  5.0.12
        admin:          6.8.0
        javascript:     7.1.4
        Adapters from github:   1
        Adapter State
        + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
        + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
        + system.adapter.bydhvs.0                 : bydhvs                : iobroker                                 -  enabled
          system.adapter.cloud.0                  : cloud                 : iobroker                                 - disabled
        + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
        + system.adapter.energiefluss.0           : energiefluss          : iobroker                                 -  enabled
        + system.adapter.fronius-solarweb.0       : fronius-solarweb      : iobroker                                 -  enabled
        + system.adapter.fronius.0                : fronius               : iobroker                                 -  enabled
        + system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 -  enabled
        + system.adapter.history.0                : history               : iobroker                                 -  enabled
        + system.adapter.hs100.0                  : hs100                 : iobroker                                 -  enabled
          system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: iobroker                                 -  enabled
          system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : iobroker                                 -  enabled
          system.adapter.icons-icons8.0           : icons-icons8          : iobroker                                 -  enabled
          system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 -  enabled
          system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 -  enabled
          system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker                                 -  enabled
          system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iobroker                                 -  enabled
        + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
        + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
        + system.adapter.linkeddevices.0          : linkeddevices         : iobroker                                 -  enabled
        + system.adapter.modbus.0                 : modbus                : iobroker                                 -  enabled
        + system.adapter.modbus.1                 : modbus                : iobroker                                 -  enabled
          system.adapter.moma.0                   : moma                  : iobroker                                 - disabled
        + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
        + system.adapter.rpi2.0                   : rpi2                  : iobroker                                 -  enabled
        + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
        + system.adapter.shelly.1                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
        + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1885, bind: 0.0.0.0
        + system.adapter.synology.0               : synology              : iobroker                                 -  enabled, port: 5000
          system.adapter.tapo.0                   : tapo                  : iobroker                                 - disabled
          system.adapter.vis-bars.0               : vis-bars              : iobroker                                 -  enabled
          system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 -  enabled
          system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker                                 -  enabled
          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 -  enabled
          system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 -  enabled
        + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
          system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 -  enabled
          system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 -  enabled
          system.adapter.vis-material-advanced.0  : vis-material-advanced : iobroker                                 -  enabled
          system.adapter.vis-metro.0              : vis-metro             : iobroker                                 -  enabled
          system.adapter.vis-rgraph.0             : vis-rgraph            : iobroker                                 -  enabled
          system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
          system.adapter.vis-weather.0            : vis-weather           : iobroker                                 -  enabled
          system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
        + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        + instance is alive
        ioBroker-Repositories
        Active repo(s): stable
        Installed ioBroker-Instances
        Used repository: stable
        Cannot download repository hash file from "http://download.iobroker.net/sources-dist-hash.json": connect EHOSTUNREACH 93.90.206.45:80
        Cannot download repository file from "http://download.iobroker.net/sources-dist.json": connect EHOSTUNREACH 93.90.206.45:80
        Adapter    "admin"        : 6.8.0    , installed 6.8.0
        Adapter    "alexa2"       : 3.24.1   , installed 3.24.1
        Adapter    "backitup"     : 2.6.23   , installed 2.6.23
        Adapter    "bydhvs"       : 1.4.0    , installed 1.4.0
        Adapter    "discovery"    : 3.1.0    , installed 3.1.0
        Adapter    "fronius"      : 1.1.3    , installed 2.0.1
        Adapter    "fronius-solarweb": 0.0.3 , installed 0.0.3
        Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
        Adapter    "history"      : 2.2.6    , installed 2.2.6
        Adapter    "hs100"        : 2.1.2    , installed 2.1.2
        Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
        Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.3
        Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
        Adapter    "javascript"   : 7.1.4    , installed 7.1.4
        Controller "js-controller": 5.0.12   , installed 5.0.12
        Adapter    "linkeddevices": 1.5.5    , installed 1.5.5
        Adapter    "modbus"       : 5.0.11   , installed 5.0.11
        Adapter    "moma"         : 1.2.9    , installed 1.2.9
        Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
        Adapter    "shelly"       : 6.4.1    , installed 6.4.1
        Adapter    "socketio"     : 6.5.5    , installed 6.5.5
        Adapter    "sonoff"       : 2.5.3    , installed 2.5.3
        Adapter    "synology"     : 2.1.13   , installed 2.1.13
        Adapter    "tapo"         : 0.0.8    , installed 0.0.8
        Adapter    "vis"          : 1.4.16   , installed 1.4.16
        Adapter    "vis-icontwo"  : 0.96.0   , installed 0.96.0
        Adapter    "vis-justgage" : 1.0.2    , installed 1.0.2
        Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
        Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
        Adapter    "web"          : 6.1.2    , installed 6.1.2
        Adapter    "ws"           : 2.5.5    , installed 2.5.5
        Objects and States
        Objects:        9734
        States:         7987
        W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://packages.grafana.com/oss/deb stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545
        W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://apt.grafana.com stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545
        W: Failed to fetch https://packages.grafana.com/oss/deb/dists/stable/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545
        W: Failed to fetch https://apt.grafana.com/dists/stable/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545
        W: Some index files failed to download. They have been ignored, or old ones used instead.
        W: Target Packages (main/binary-arm64/Packages) is configured multiple times in /etc/apt/sources.list.d/grafana.list:2 and /etc/apt/sources.list.d/grafana.list:3
        W: Target Packages (main/binary-armhf/Packages) is configured multiple times in /etc/apt/sources.list.d/grafana.list:2 and /etc/apt/sources.list.d/grafana.list:3
        W: Target Packages (main/binary-all/Packages) is configured multiple times in /etc/apt/sources.list.d/grafana.list:2 and /etc/apt/sources.list.d/grafana.list:3
        W: Target Translations (main/i18n/Translation-en) is configured multiple times in /etc/apt/sources.list.d/grafana.list:2 and /etc/apt/sources.list.d/grafana.list:3
        W: Target Translations (main/i18n/Translation-de) is configured multiple times in /etc/apt/sources.list.d/grafana.list:2 and /etc/apt/sources.list.d/grafana.list:3
        W: Target Packages (main/binary-arm64/Packages) is configured multiple times in /etc/apt/sources.list.d/grafana.list:2 and /etc/apt/sources.list.d/grafana.list:4
        W: Target Packages (main/binary-armhf/Packages) is configured multiple times in /etc/apt/sources.list.d/grafana.list:2 and /etc/apt/sources.list.d/grafana.list:4
        W: Target Packages (main/binary-all/Packages) is configured multiple times in /etc/apt/sources.list.d/grafana.list:2 and /etc/apt/sources.list.d/grafana.list:4
        W: Target Translations (main/i18n/Translation-en) is configured multiple times in /etc/apt/sources.list.d/grafana.list:2 and /etc/apt/sources.list.d/grafana.list:4
        W: Target Translations (main/i18n/Translation-de) is configured multiple times in /etc/apt/sources.list.d/grafana.list:2 and /etc/apt/sources.list.d/grafana.list:4
        W: Target Packages (main/binary-arm64/Packages) is configured multiple times in /etc/apt/sources.list.d/grafana.list:2 and /etc/apt/sources.list.d/grafana.list:5
        W: Target Packages (main/binary-armhf/Packages) is configured multiple times in /etc/apt/sources.list.d/grafana.list:2 and /etc/apt/sources.list.d/grafana.list:5
        W: Target Packages (main/binary-all/Packages) is configured multiple times in /etc/apt/sources.list.d/grafana.list:2 and /etc/apt/sources.list.d/grafana.list:5
        W: Target Translations (main/i18n/Translation-en) is configured multiple times in /etc/apt/sources.list.d/grafana.list:2 and /etc/apt/sources.list.d/grafana.list:5
        W: Target Translations (main/i18n/Translation-de) is configured multiple times in /etc/apt/sources.list.d/grafana.list:2 and /etc/apt/sources.list.d/grafana.list:5
        Hit:1 http://deb.debian.org/debian bullseye InRelease
        Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
        Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
        Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
        Hit:5 https://repos.influxdata.com/debian stable InRelease
        Get:6 https://packages.grafana.com/oss/deb stable InRelease [5984 B]
        Get:7 https://deb.nodesource.com/node_16.x bullseye InRelease [4586 B]
        Get:8 https://apt.grafana.com stable InRelease [5984 B]
        Err:6 https://packages.grafana.com/oss/deb stable InRelease
        Err:8 https://apt.grafana.com stable InRelease
        Fetched 4586 B in 9s (535 B/s)
        Reading package lists... Done
        Pending Updates: 61
        *** Listening Ports ***
        Netid     State       Recv-Q      Send-Q           Local Address:Port            Peer Address:Port     Process
        udp       UNCONN      0           0                      0.0.0.0:5353                 0.0.0.0:*         users:(("avahi-daemon",pid=390,fd=12))
        udp       UNCONN      0           0                      0.0.0.0:5683                 0.0.0.0:*         users:(("io.shelly.0",pid=1058,fd=29))
        udp       UNCONN      0           0                      0.0.0.0:51820                0.0.0.0:*
        udp       UNCONN      0           0                      0.0.0.0:68                   0.0.0.0:*         users:(("dhcpcd",pid=655,fd=10))
        udp       UNCONN      0           0                      0.0.0.0:49429                0.0.0.0:*         users:(("avahi-daemon",pid=390,fd=14))
        udp       UNCONN      0           0                            *:5353                       *:*         users:(("avahi-daemon",pid=390,fd=13))
        udp       UNCONN      0           0                            *:51820                      *:*
        udp       UNCONN      0           0                            *:51865                      *:*         users:(("avahi-daemon",pid=390,fd=15))
        udp       UNCONN      0           0                            *:546                        *:*         users:(("dhcpcd",pid=655,fd=15))
        tcp       LISTEN      0           511                  127.0.0.1:9001                 0.0.0.0:*         users:(("iobroker.js-con",pid=909,fd=21))
        tcp       LISTEN      0           511                  127.0.0.1:9000                 0.0.0.0:*         users:(("iobroker.js-con",pid=909,fd=27))
        tcp       LISTEN      0           511                    0.0.0.0:33709                0.0.0.0:*         users:(("io.alexa2.0",pid=1099,fd=29))
        tcp       LISTEN      0           128                    0.0.0.0:22                   0.0.0.0:*         users:(("sshd",pid=516,fd=3))
        tcp       LISTEN      0           511                    0.0.0.0:1885                 0.0.0.0:*         users:(("io.sonoff.0",pid=7091,fd=28))
        tcp       LISTEN      0           511                    0.0.0.0:1883                 0.0.0.0:*         users:(("io.mqtt.0",pid=1088,fd=29))
        tcp       LISTEN      0           511                    0.0.0.0:1882                 0.0.0.0:*         users:(("io.shelly.1",pid=1133,fd=29))
        tcp       LISTEN      0           100                    0.0.0.0:6080                 0.0.0.0:*         users:(("python3",pid=527,fd=3))
        tcp       LISTEN      0           4096                         *:3000                       *:*         users:(("grafana",pid=908,fd=9))
        tcp       LISTEN      0           4096                         *:8086                       *:*         users:(("influxd",pid=666,fd=242))
        tcp       LISTEN      0           511                          *:8082                       *:*         users:(("io.web.0",pid=1208,fd=29))
        tcp       LISTEN      0           511                          *:8081                       *:*         users:(("io.admin.0",pid=946,fd=31))
        tcp       LISTEN      0           128                       [::]:22                      [::]:*         users:(("sshd",pid=516,fd=4))
        2023-11-23 17:39:16.069  - warn: hs100.0 (1447) getDevice Socket connection Timeout ip: 10.0.0.43 please reconnect the Device
        2023-11-23 17:39:46.069  - warn: hs100.0 (1447) getDevice Socket connection Timeout ip: 10.0.0.43 please reconnect the Device
        2023-11-23 17:40:16.069  - warn: hs100.0 (1447) getDevice Socket connection Timeout ip: 10.0.0.43 please reconnect the Device
        2023-11-23 17:40:46.070  - warn: hs100.0 (1447) getDevice Socket connection Timeout ip: 10.0.0.43 please reconnect the Device
        kannst du mir  da weiterhelfen? Besten Dank für die Mühe glg
        mit wget:    wget http://registry.npmjs.org/iobroker.vis
        --2023-11-23 19:38:52--  http://registry.npmjs.org/iobroker.vis
        Auflösen des Hostnamens registry.npmjs.org (registry.npmjs.org)… 2606:4700::6810:1b22, 2606:4700::6810:1922, 2606:4700::6810:23, ...
        Verbindungsaufbau zu registry.npmjs.org (registry.npmjs.org)|2606:4700::6810:1b22|:80 … verbunden.
        HTTP-Anforderung gesendet, auf Antwort wird gewartet … 301 Moved Permanently
        Platz: https://registry.npmjs.org/iobroker.vis [folgend]
        --2023-11-23 19:38:55--  https://registry.npmjs.org/iobroker.vis
        Verbindungsaufbau zu registry.npmjs.org (registry.npmjs.org)|2606:4700::6810:1b22|:443 … verbunden.
        HTTP-Anforderung gesendet, auf Antwort wird gewartet … 200 OK
        Länge: 374234 (365K) [application/json]
        Wird in »iobroker.vis« gespeichert.
        iobroker.vis        100%[===================>] 365,46K  --.-KB/s    in 0,08s
        2023-11-23 19:38:56 (4,28 MB/s) - »iobroker.vis« gespeichert [374234/374234]
        und im iobroker noch immer !  vis 1.4.6!!!  ich bin am verzweifeln
        ![vis1.4.6.png](/assets/uploads/files/1700765656067-vis1.4.6.png)
        apollon77 Marc Berg Thomas Braun 3 Replies Last reply Reply Quote 0
          @christian-5 Das sollten wir in einen eigenen Thread abspalten und ich denke andere können da besser helfen @Thomas-Braun @Homoran
            Homoran Global Moderator Administrators @apollon77 last edited by
            @apollon77 sagte in Vis über npm gibt EHOSTUNREACH:
            ERLEDIGT!
            @Christian-5 Bitte Threadtitel sinnvoll ändern
            • Marc Berg
              Marc Berg Most Active @Christian 5 last edited by Marc Berg
              @christian-5 sagte in Vis über npm gibt EHOSTUNREACH:
              Die Kommunikation über IPv6 funktioniert, während sämtliche IPv4 Kommunikation gegen den Baum fährt. Das ist irgendwas in deinem Netzwerk verbogen, würde ich sagen.
              Mach mal
              ping -4 registry.npmjs.org
              ping -6 registry.npmjs.org
              Und das ganze auch mal vom PC oder was du so rumzustehen hast.
                Thomas Braun Most Active @Christian 5 last edited by Thomas Braun
                @christian-5
                Grafana-Repo und nodejs musst du auch anpacken.
                Grafana:
                sudo apt-get install -y apt-transport-https
                sudo apt-get install -y software-properties-common wget
                sudo wget -q -O /usr/share/keyrings/grafana.key https://apt.grafana.com/gpg.key
                echo "deb [signed-by=/usr/share/keyrings/grafana.key] https://apt.grafana.com stable main" | sudo tee /etc/apt/sources.list.d/grafana.list
                nodejs:
                iob stop
                iob fix
                iob nodejs-update
                Und das ganze Ding auf Stand bringen...
                Pending Updates: 61
                Sind 61 Updates zu viel.
                  Bitte kann mir jemand sagen was es mit dem Fehler auf sich hat. Ich wollte eigentlich nur auf vis 1.5.1 updaten sehe diese Version aber nirgends. hab bis jetzt schon sehr viel Tip von euch umgesetzt nur leider noch immer kein update möglich. der ping -4 registry.npmjs.org -->From iobroker.fritz.box (10.0.0.50) icmp_seq=2 Destination Host Unreachable.
                  hab die fritzbox Neu!!!? muss ich dort was einstellen. Der Vorschlag den Paketbeschleunigung auszuschalten brachte keinen Erfolg.
                  Skript v.2023-10-25
                  *** BASE SYSTEM ***
                           Icon name: computer
                        Architecture: arm64
                  Docker          : false
                  Kernel          : aarch64
                  Userland        : arm64
                   14:30:40 up 25 min,  1 user,  load average: 1.71, 1.30, 1.02
                  CPU threads: 4
                  Current issues:
                                 Local time: Fri 2023-11-24 14:30:40 CET
                             Universal time: Fri 2023-11-24 13:30:40 UTC
                                   RTC time: n/a
                                NTP service: active
                            RTC in local TZ: no
                  iobroker
                  /home/iobroker
                  X-Server:       false
                  Desktop:
                  Terminal:       tty
                  *** MEMORY ***
                  Mem:            7.8G        2.1G        4.9G        1.0M        859M        5.6G
                  Swap:            99M          0B         99M
                  Total:          7.9G        2.1G        5.0G
                           7811 M total memory
                           2060 M used memory
                           2439 M active memory
                            345 M inactive memory
                           4891 M free memory
                             84 M buffer memory
                            774 M swap cache
                             99 M total swap
                              0 M used swap
                             99 M free swap
                  Raspberry only:
                  oom events: 0
                  *** FILESYSTEM ***
                  /dev/root      ext4      118G   30G   84G  26% /
                  [sudo] password for iobroker:
                  [Fri Nov 24 14:05:05 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1                     snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.ena                    ble_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:2A:25:6C vc_mem.                    mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyAMA0,115200 console=t                    ty1 root=PARTUUID=57cd214b-02 rootfstype=ext4 fsck.repair=yes rootwait
                  [Fri Nov 24 14:05:09 2023] EXT4-fs (sda2): mounted filesystem with ordered data                     mode. Quota mode: none.
                  [Fri Nov 24 14:05:09 2023] VFS: Mounted root (ext4 filesystem) readonly on devic                    e 8:2.
                  [Fri Nov 24 14:05:11 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
                  |-/dev                       devtmpfs   devtmpf rw,relatime,size=3735168k,nr_ino
                  | |-/sys/kernel/security     securityfs securit rw,nosuid,nodev,noexec,relatime
                  | `-/sys/kernel/config       configfs   configf rw,nosuid,nodev,noexec,relatime
                  | |-/run/rpc_pipefs          sunrpc     rpc_pip rw,relatime
                  /var:
                  25G     /var/
                  22G     /var/lib/influxdb/engine/data/9d69ae680368264c/autogen
                  Archived and active journals take up 2.0G in the file system.
                  4.0K    /opt/iobroker/backups/
                  626M    /opt/iobroker/iobroker-data/
                  483M    /opt/iobroker/iobroker-data/files
                  158M    /opt/iobroker/iobroker-data/files/vis-2
                  81M     /opt/iobroker/iobroker-data/files/vis-2/static
                  80M     /opt/iobroker/iobroker-data/files/vis-2/static/js
                  76M     /opt/iobroker/iobroker-data/objects.jsonl
                  21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.m                    ap
                  21M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.0b890418.js.map
                  19M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.da06e220.js.map
                  19M     /opt/iobroker/iobroker-data/files/vis-2/customWidgets.js.map
                  USB-Devices by-id:
                  USB-Sticks -  Avoid direct links to /dev/* in your adapter setups, please always                     prefer the links 'by-id':
                  /usr/bin/nodejs         v16.20.2
                  /usr/bin/npm            8.19.4
                  /usr/bin/npx            8.19.4
                  nodejs:
                    Version table:
                  Errors in npm tree:
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  js-controller:  5.0.16
                  admin:          6.12.0
                  javascript:     7.1.4
                  Adapter State
                  + system.adapter.device-reminder.0        : device-reminder       : iobroker                                   -  enabled
                  + system.adapter.email.0                  : email                 : iobroker                                   -  enabled
                  + system.adapter.sainlogic.0              : sainlogic             : iobroker                                   -  enabled, port: 4500, bind: 0.0.0.0
                    system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: iobroker                                   -  enabled
                  + system.adapter.vis-2.0                  : vis-2                 : iobroker                                   -  enabled
                  + instance is alive
                  Adapter    "admin"        : 6.12.0   , installed 6.12.0
                  Adapter    "alexa2"       : 3.26.1   , installed 3.26.1
                  Adapter    "backitup"     : 2.8.7    , installed 2.8.7
                  Adapter    "device-reminder": 3.0.0  , installed 3.0.0
                  Adapter    "email"        : 1.2.0    , installed 1.2.0
                  Adapter    "fronius"      : 2.0.2    , installed 2.0.2
                  Adapter    "fullybrowser" : 3.0.6    , installed 3.0.3  [Updatable]
                  Adapter    "hs100"        : 2.2.0    , installed 2.2.0
                  Controller "js-controller": 5.0.16   , installed 5.0.16
                  Adapter    "mqtt"         : 5.1.0    , installed 5.1.0
                  Adapter    "sainlogic"    : 0.10.5   , installed 0.10.5
                  Adapter    "shelly"       : 6.6.1    , installed 6.6.1
                  Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
                  Adapter    "synology"     : 3.0.1    , installed 3.0.1
                  Adapter    "vis-justgage" : 2.0.0    , installed 2.0.0
                  Adapter    "web"          : 6.1.10   , installed 6.1.10
                  Adapter    "ws"           : 2.5.8    , installed 2.5.8
                  Objects and States
                  Objects:        10163
                  States:         8224
                  Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
                  Hit:2 http://deb.debian.org/debian bullseye InRelease
                  Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
                  Hit:6 https://apt.grafana.com stable InRelease
                  Fetched 4586 B in 8s (562 B/s)
                  Pending Updates: 17
                  udp       UNCONN     0          0                     0.0.0.0:68                   0.0.0.0:*         users:(("dhcpcd",pid=642,fd=10))
                  udp       UNCONN     0          0                     0.0.0.0:5353                 0.0.0.0:*         users:(("avahi-daemon",pid=378,fd=12))
                  udp       UNCONN     0          0                     0.0.0.0:5683                 0.0.0.0:*         users:(("io.shelly.0",pid=920,fd=30))
                  udp       UNCONN     0          0                     0.0.0.0:34546                0.0.0.0:*         users:(("avahi-daemon",pid=378,fd=14))
                  udp       UNCONN     0          0                     0.0.0.0:34563                0.0.0.0:*         users:(("systemd-timesyn",pid=342,fd=16))
                  udp       UNCONN     0          0                           *:56852                      *:*         users:(("avahi-daemon",pid=378,fd=15))
                  udp       UNCONN     0          0                           *:546                        *:*         users:(("dhcpcd",pid=642,fd=15))
                  udp       UNCONN     0          0                           *:5353                       *:*         users:(("avahi-daemon",pid=378,fd=13))
                  tcp       LISTEN     0          511                 127.0.0.1:9001                 0.0.0.0:*         users:(("iobroker.js-con",pid=779,fd=21))
                  tcp       LISTEN     0          511                 127.0.0.1:9000                 0.0.0.0:*         users:(("iobroker.js-con",pid=779,fd=27))
                  tcp       LISTEN     0          511                   0.0.0.0:4500                 0.0.0.0:*         users:(("io.sainlogic.0",pid=1281,fd=34))
                  tcp       LISTEN     0          128                   0.0.0.0:22                   0.0.0.0:*         users:(("sshd",pid=503,fd=3))
                  tcp       LISTEN     0          511                   0.0.0.0:38833                0.0.0.0:*         users:(("io.alexa2.0",pid=950,fd=29))
                  tcp       LISTEN     0          100                   0.0.0.0:6080                 0.0.0.0:*         users:(("python3",pid=500,fd=3))
                  tcp       LISTEN     0          511                   0.0.0.0:1885                 0.0.0.0:*         users:(("io.sonoff.0",pid=995,fd=34))
                  tcp       LISTEN     0          511                   0.0.0.0:1883                 0.0.0.0:*         users:(("io.mqtt.0",pid=1025,fd=29))
                  tcp       LISTEN     0          511                   0.0.0.0:1882                 0.0.0.0:*         users:(("io.shelly.1",pid=980,fd=30))
                  tcp       LISTEN     0          4096                        *:3000                       *:*         users:(("grafana",pid=778,fd=11))
                  tcp       LISTEN     0          4096                        *:8086                       *:*         users:(("influxd",pid=647,fd=306))
                  tcp       LISTEN     0          511                         *:8081                       *:*         users:(("io.admin.0",pid=805,fd=31))
                  tcp       LISTEN     0          511                         *:8082                       *:*         users:(("io.web.0",pid=1104,fd=29))
                  tcp       LISTEN     0          128                      [::]:22                      [::]:*         users:(("sshd",pid=503,fd=4))
                  tcp       LISTEN     0          511                         *:1875                       *:*         users:(("io.fullybrowser",pid=1330,fd=29))
                  2023-11-24 14:22:33.860  - info: shelly.1 (980) [MQTT] Device with client id "shellyplus1-441793ab4128" connected!
                  2023-11-24 14:22:34.243  - info: sonoff.0 (995) Client [SKGaragenCam] reconnected. Old secret 1700831197227_5904. New secret 1700832154243_4796
                  2023-11-24 14:22:34.296  - info: web.0 (1104) ==> Connected system.user.admin from ::ffff:10.0.0.36
                  2023-11-24 14:22:37.883  - info: shelly.1 (980) [MQTT] Device with client id "shellyplus1-80646fdaf810" connected!
                  2023-11-24 14:22:39.327  - info: web.0 (1104) <== Disconnect system.user.admin from ::ffff:10.0.0.36
                  2023-11-24 14:22:39.353  - info: web.0 (1104) <== Disconnect system.user.admin from ::ffff:10.0.0.36
                  2023-11-24 14:22:40.380  - info: web.0 (1104) ==> Connected system.user.admin from ::ffff:10.0.0.36
                  2023-11-24 14:22:44.291  - info: web.0 (1104) ==> Connected system.user.admin from ::ffff:10.0.0.36
                  2023-11-24 14:22:49.294  - info: web.0 (1104) <== Disconnect system.user.admin from ::ffff:10.0.0.36
                  2023-11-24 14:22:49.378  - info: web.0 (1104) <== Disconnect system.user.admin from ::ffff:10.0.0.36
                  2023-11-24 14:22:50.388  - info: web.0 (1104) ==> Connected system.user.admin from ::ffff:10.0.0.36
                  2023-11-24 14:22:54.302  - info: web.0 (1104) ==> Connected system.user.admin from ::ffff:10.0.0.36
                  2023-11-24 14:23:00.381  - info: web.0 (1104) <== Disconnect system.user.admin from ::ffff:10.0.0.36
                  2023-11-24 14:23:00.439  - info: web.0 (1104) <== Disconnect system.user.admin from ::ffff:10.0.0.36
                  2023-11-24 14:23:01.454  - info: web.0 (1104) ==> Connected system.user.admin from ::ffff:10.0.0.36
                  2023-11-24 14:23:04.289  - info: web.0 (1104) ==> Connected system.user.admin from ::ffff:10.0.0.36
                  2023-11-24 14:23:05.389  - info: web.0 (1104) <== Disconnect system.user.admin from ::ffff:10.0.0.36
                  2023-11-24 14:23:05.411  - info: web.0 (1104) <== Disconnect system.user.admin from ::ffff:10.0.0.36
                  2023-11-24 14:23:05.414  - info: web.0 (1104) ==> Connected system.user.admin from ::ffff:10.0.0.36
                  2023-11-24 14:23:05.416  - info: web.0 (1104) <== Disconnect system.user.admin from ::ffff:10.0.0.36
                  2023-11-24 14:23:05.563  - info: web.0 (1104) <== Disconnect system.user.admin from ::ffff:10.0.0.36
                  2023-11-24 14:23:07.763  - info: web.0 (1104) ==> Connected system.user.admin from ::ffff:10.0.0.36
                  2023-11-24 14:25:58.957  - info: influxdb.0 (834) Store 947 buffered influxDB history points
                  2023-11-24 14:29:41.305  - info: admin.0 (805) ==> Connected system.user.admin from ::ffff:10.0.0.13
                  2023-11-24 14:29:55.019  - warn: admin.0 (805) Cannot update rating: connect EHOSTUNREACH 93.90.206.45:443
                  • Marc Berg
                    Marc Berg Most Active last edited by
                    Es könnte für die Fehlersuche hilfreich sein, wenn du Anfragen komplett beantwortest.
                    Thomas Braun C 2 Replies Last reply Reply Quote 0
                      Thomas Braun Most Active @Marc Berg last edited by
                      @marc-berg
                      Das tut man dann lieber in zig parallelen Threads... 😞
                      https://forum.iobroker.net/topic/70492/errors-in-npm-tree-ich-sehe-keine-update
                        @thomas-braun entschultigung
                          Christian 5 @Marc Berg last edited by
                          @marc-berg meinst du "Sind 61 Updates zu viel."
                          ich weiß jetzt nicht was das bedeutet
                            Das bedeutet, das du offenbar nie Updates einspielst...
                            sudo apt update
                            sudo apt full-upgrade
                            sudo reboot
                            Regelmäßig eigenständig ausführen.
                              Christian 5 @Thomas Braun last edited by
                              @thomas-braun mach ich eigentlich auch immer, hab da ein Backup all so einen alten Clone der ssd im Einsatz. Da ich meine aktuelle Installation komplett zerschossen hab. werde die Update jetzt mal machen Danke hatte nicht daran gedacht.
                                @thomas-braun diag:
                                Skript v.2023-10-25
                                *** BASE SYSTEM ***
                                         Icon name: computer
                                      Architecture: arm64
                                Docker          : false
                                Kernel          : aarch64
                                Userland        : arm64
                                 15:38:56 up 2 min,  1 user,  load average: 3.15, 1.06, 0.39
                                CPU threads: 4
                                Current issues:
                                               Local time: Fri 2023-11-24 15:38:56 CET
                                           Universal time: Fri 2023-11-24 14:38:56 UTC
                                                 RTC time: n/a
                                              NTP service: active
                                          RTC in local TZ: no
                                iobroker
                                /home/iobroker
                                X-Server:       false
                                Desktop:
                                Terminal:       tty
                                *** MEMORY ***
                                Mem:            7.8G        1.9G        5.2G        1.0M        724M        5.8G
                                Swap:            99M          0B         99M
                                Total:          7.9G        1.9G        5.3G
                                         7811 M total memory
                                         1927 M used memory
                                         2276 M active memory
                                          250 M inactive memory
                                         5159 M free memory
                                           62 M buffer memory
                                          662 M swap cache
                                           99 M total swap
                                            0 M used swap
                                           99 M free swap
                                Raspberry only:
                                oom events: 0
                                *** FILESYSTEM ***
                                [Fri Nov 24 15:36:35 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=                          0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:D                          D:2A:25:6C vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyAMA0,115200 console=tty1 root=PART                          UUID=57cd214b-02 rootfstype=ext4 fsck.repair=yes rootwait
                                [Fri Nov 24 15:36:39 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
                                [Fri Nov 24 15:36:39 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
                                [Fri Nov 24 15:36:41 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
                                /var:
                                25G     /var/
                                566M    /opt/iobroker/iobroker-data/
                                21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
                                14M     /opt/iobroker/iobroker-data/files/vis-2/static/js/258.6829e51a.chunk.js.map
                                USB-Devices by-id:
                                /usr/bin/npm            8.19.4
                                /usr/bin/npx            8.19.4
                                nodejs:
                                  Version table:
                                Errors in npm tree:
                                ioBroker Status
                                Objects type: jsonl
                                States  type: jsonl
                                admin:          6.12.0
                                javascript:     7.1.4
                                Adapter State
                                + instance is alive
                                stable        : http://repo.iobroker.live/sources-dist.json
                                Cannot download repository hash file from "http://repo.iobroker.live/sources-dist-hash.json": connect EHOSTUNRE                          ACH 104.21.86.170:80
                                Cannot download repository file from "http://repo.iobroker.live/sources-dist.json": connect EHOSTUNREACH 104.21                          .86.170:80
                                Objects and States
                                Objects:        10163
                                States:         8229
                                Hit:1 https://repos.influxdata.com/debian stable InRelease
                                Hit:2 https://apt.grafana.com stable InRelease
                                Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
                                Hit:4 http://deb.debian.org/debian bullseye InRelease
                                Hit:5 http://deb.debian.org/debian bullseye-updates InRelease
                                Get:6 https://deb.nodesource.com/node_16.x bullseye InRelease [4586 B]
                                Hit:7 http://security.debian.org/debian-security bullseye-security InRelease
                                Fetched 4586 B in 8s (560 B/s)
                                Pending Updates: 0
                                udp   UNCONN 0      0            0.0.0.0:5353         0.0.0.0:*     users:(("avahi-daemon",pid=379,fd=12))
                                udp   UNCONN 0      0            0.0.0.0:5683         0.0.0.0:*     users:(("io.shelly.0",pid=1045,fd=30))
                                udp   UNCONN 0      0            0.0.0.0:68           0.0.0.0:*     users:(("dhcpcd",pid=643,fd=10))
                                udp   UNCONN 0      0            0.0.0.0:57439        0.0.0.0:*     users:(("avahi-daemon",pid=379,fd=14))
                                udp   UNCONN 0      0                  *:546                *:*     users:(("dhcpcd",pid=643,fd=15))
                                udp   UNCONN 0      0                  *:5353               *:*     users:(("avahi-daemon",pid=379,fd=13))
                                udp   UNCONN 0      0                  *:56472              *:*     users:(("avahi-daemon",pid=379,fd=15))
                                tcp   LISTEN 0      511          0.0.0.0:4500         0.0.0.0:*     users:(("io.sainlogic.0",pid=1672,fd=34))
                                tcp   LISTEN 0      128          0.0.0.0:22           0.0.0.0:*     users:(("sshd",pid=507,fd=3))
                                tcp   LISTEN 0      100          0.0.0.0:6080         0.0.0.0:*     users:(("python3",pid=501,fd=3))
                                tcp   LISTEN 0      511          0.0.0.0:1885         0.0.0.0:*     users:(("io.sonoff.0",pid=1209,fd=34))
                                tcp   LISTEN 0      511          0.0.0.0:1883         0.0.0.0:*     users:(("io.mqtt.0",pid=1261,fd=29))
                                tcp   LISTEN 0      511          0.0.0.0:1882         0.0.0.0:*     users:(("io.shelly.1",pid=1149,fd=30))
                                tcp   LISTEN 0      511          0.0.0.0:39387        0.0.0.0:*     users:(("io.alexa2.0",pid=1097,fd=29))
                                tcp   LISTEN 0      511        127.0.0.1:9000         0.0.0.0:*     users:(("iobroker.js-con",pid=811,fd=27))
                                tcp   LISTEN 0      511        127.0.0.1:9001         0.0.0.0:*     users:(("iobroker.js-con",pid=811,fd=21))
                                tcp   LISTEN 0      128             [::]:22              [::]:*     users:(("sshd",pid=507,fd=4))
                                tcp   LISTEN 0      511                *:1875               *:*     users:(("io.fullybrowser",pid=1790,fd=29))
                                tcp   LISTEN 0      4096               *:3000               *:*     users:(("grafana",pid=810,fd=21))
                                tcp   LISTEN 0      4096               *:8086               *:*     users:(("influxd",pid=647,fd=180))
                                tcp   LISTEN 0      511                *:8082               *:*     users:(("io.web.0",pid=1341,fd=29))
                                tcp   LISTEN 0      511                *:8081               *:*     users:(("io.admin.0",pid=870,fd=31))
                                2023-11-24 15:39:01.599  - info: linkeddevices.0 (1589) [createLinkedObject] linked object 'fronius.0.site.P_PV                          ' to 'linkeddevices.0.P_PV'
                                2023-11-24 15:39:01.684  - info: linkeddevices.0 (1589) [createLinkedObject] linked object 'fronius.0.ohmpilot.                          0.EnergyReal_WAC_Sum_Consumed' to 'linkeddevices.0.EnergyReal_WAC_Sum_Consumed'
                                2023-11-24 15:39:01.728  - info: linkeddevices.0 (1589) [createLinkedObject] linked object 'mqtt.0.watermeter.m                          ain.raw' to 'linkeddevices.0.raw'
                                2023-11-24 15:39:01.732  - info: linkeddevices.0 (1589) [createAllLinkedObjects] count of active linkedObjects:                           19
                                2023-11-24 15:39:01.738  - info: linkeddevices.0 (1589) [initialObjects] finished
                                2023-11-24 15:39:02.034  - info: device-reminder.0 (1734) starting. Version 3.0.0 in /opt/iobroker/node_modules                          /iobroker.device-reminder, node: v16.20.2, js-controller: 5.0.16
                                2023-11-24 15:39:02.492  - info: host.iobroker instance system.adapter.vis-2.0 started with pid 1764
                                2023-11-24 15:39:02.734  - warn: device-reminder.0 (1734) State "device-reminder.0.info.connection" has no exis                          ting object, this might lead to an error in future versions
                                2023-11-24 15:39:04.880  - info: vis-2.0 (1764) starting. Version 2.3.5 in /opt/iobroker/node_modules/iobroker.                          vis-2, node: v16.20.2, js-controller: 5.0.16
                                2023-11-24 15:39:06.450  - info: host.iobroker instance system.adapter.fullybrowser.0 started with pid 1790
                                2023-11-24 15:39:09.050  - info: fullybrowser.0 (1790) starting. Version 3.0.3 in /opt/iobroker/node_modules/io                          broker.fullybrowser, node: v16.20.2, js-controller: 5.0.16
                                2023-11-24 15:39:09.096  - info: fullybrowser.0 (1790) 🗸 10.0.0.36 (10.0.0.36): Config successfully verified.
                                2023-11-24 15:39:09.289  - info: fullybrowser.0 (1790) 🚀 Start RESTApi request intervall
                                2023-11-24 15:39:09.291  - info: fullybrowser.0 (1790) 🚀 MQTT Server started and is listening on port 1875.
                                2023-11-24 15:39:11.182  - error: vis-2.0 (1764) Cannot check license: Error: connect EHOSTUNREACH 82.165.135.2                          39:443
                                2023-11-24 15:39:39.272  - info: fullybrowser.0 (1790) 🔑 MQTT Client 10.0.0.36 (10.0.0.36) successfully authen                          ticated.
                                2023-11-24 15:39:39.283  - info: fullybrowser.0 (1790) 🔗 MQTT Client 10.0.0.36 (10.0.0.36) successfully connec                          ted.
                                2023-11-24 15:39:39.286  - warn: fullybrowser.0 (1790) 10.0.0.36 is connected (MQTT: client connected)
                                2023-11-24 15:39:42.323  - info: shelly.1 (1149) [MQTT] Device with client id "shellyplus1-80646fcb137c" connec                          ted!
                                2023-11-24 15:39:43.883  - info: shelly.1 (1149) [MQTT] Device with client id "shellyplus1-80646fcadb20" connec                          ted!
                                2023-11-24 15:39:45.777  - info: shelly.1 (1149) [MQTT] Device with client id "shellyplus1-80646fdc7284" connec                          ted!
                                2023-11-24 15:39:47.626  - info: shelly.1 (1149) [MQTT] Device with client id "shellyplus1-80646fcb0870" connec                          ted!
                                2023-11-24 15:39:52.303  - info: shelly.1 (1149) [MQTT] Device with client id "shellyplus1-441793ab4100" connec                          ted!
                                2023-11-24 15:39:53.203  - info: shelly.1 (1149) [MQTT] Device with client id "shellyplus1-441793ab4128" connec                          ted!
                                2023-11-24 15:39:54.391  - info: shelly.1 (1149) [MQTT] Device with client id "shellyplus1-80646fdaf810" connec                          ted!
                                die Meldung kommt halt leider noch immer: Cannot download repository hash file from "http://repo.iobroker.live/sources-dist-hash.json": connect EHOSTUNRE
                                habs auch mit http://download.iobroker.net/sources-dist.json versucht
                                danke für eure Geduld lg
                                  @christian-5
                                  iob nodejs-update
                                    und auf die Antwort auf die Frage von @Marc-Berg warten wir leider noch immer
                                      Christian 5 @Homoran last edited by Homoran
                                      @homoran hab ich überlesen:
                                      vom PC :
                                      Ping wird ausgeführt für registry.npmjs.org [104.16.26.34] mit 32 Bytes Daten:
                                      Antwort von 104.16.26.34: Bytes=32 Zeit=13ms TTL=57
                                      vom Raspi:
                                      PING  (104.16.26.34) 56(84) bytes of data.
                                      From iobroker.fritz.box (10.0.0.50) icmp_seq=1 Destination Host Unreachable
                                      • Marc Berg
                                        vom PC : ping -4 registry.npmjs.org
                                        Gut, dann ist dein Netzwerk nicht komplett Schrott, sondern nur irgendwas am Raspi. Was sagt
                                        ifconfig
                                          Christian 5 last edited by Homoran
                                          @marc-berg
                                          eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
                                                  inet 10.0.0.50  netmask 255.255.255.0  broadcast 10.0.0.255
                                                  inet6 2001:871:20c:d8bc:91e4:15cf:502f:a54a  prefixlen 64  scopeid 0x0<global>
                                                  inet6 fe80::3363:509d:93ea:a9b8  prefixlen 64  scopeid 0x20<link>
                                                  ether d8:3a:dd:2a:25:6c  txqueuelen 1000  (Ethernet)
                                                  RX packets 89619  bytes 21175291 (20.1 MiB)
                                                  RX errors 0  dropped 0  overruns 0  frame 0
                                                  TX packets 75940  bytes 10170846 (9.6 MiB)
                                                  TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
                                          lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
                                                  inet 127.0.0.1  netmask 255.0.0.0
                                                  inet6 ::1  prefixlen 128  scopeid 0x10<host>
                                                  loop  txqueuelen 1000  (Lokale Schleife)
                                                  RX packets 859145  bytes 303299033 (289.2 MiB)
                                                  TX packets 859145  bytes 303299033 (289.2 MiB)
                                          • Marc Berg
                                            @christian-5
                                            ip route
                                            sagt?
                                            3022
