    4. Test Adapter KNX v2.x
    • Dutchman
      Dutchman Developer Most Active Administrators @blacksheep587 last edited by
      @blacksheep587 sagte in Test Adapter KNX v2.x:
      @peer69 war leider auch nicht erfolgreich. Wenn ich eine neue Instanz hinzufüge, dann funktioniert diese. Die alte aber nachwievor nicht. Ich habe mal noch die Logstufe vom KNX-Adapter erweitert:
      2023-11-17 12:34:08.811  - info: host.raspberrypi instance system.adapter.knx.0 started with pid 31285
      2023-11-17 12:34:12.629  - debug: knx.0 (31285) Redis Objects: Use Redis connection: 127.0.0.1:9001
      2023-11-17 12:34:12.708  - debug: knx.0 (31285) Objects client ready ... initialize now
      2023-11-17 12:34:12.712  - debug: knx.0 (31285) Objects create System PubSub Client
      2023-11-17 12:34:12.714  - debug: knx.0 (31285) Objects create User PubSub Client
      2023-11-17 12:34:12.774  - debug: knx.0 (31285) Objects client initialize lua scripts
      2023-11-17 12:34:12.785  - debug: knx.0 (31285) Objects connected to redis: 127.0.0.1:9001
      2023-11-17 12:34:12.834  - debug: knx.0 (31285) Redis States: Use Redis connection: 127.0.0.1:9000
      2023-11-17 12:34:12.853  - debug: knx.0 (31285) States create System PubSub Client
      2023-11-17 12:34:12.855  - debug: knx.0 (31285) States create User PubSub Client
      2023-11-17 12:34:12.932  - debug: knx.0 (31285) States connected to redis: 127.0.0.1:9000
      2023-11-17 12:34:12.985  - debug: knx.0 (31285) Plugin sentry Initialize Plugin (enabled=true)
      2023-11-17 12:34:13.795  - info: knx.0 (31285) starting. Version 2.0.23 in /opt/iobroker/node_modules/iobroker.knx, node: v18.18.2, js-controller: 5.0.16
      2023-11-17 12:34:20.308  - info: host.raspberrypi stopInstance system.adapter.knx.0 (force=false, process=true)
      2023-11-17 12:34:20.417  - info: knx.0 (31285) Got terminate signal TERMINATE_YOURSELF
      2023-11-17 12:34:20.425  - info: host.raspberrypi stopInstance system.adapter.knx.0 send kill signal
      2023-11-17 12:34:20.424  - debug: knx.0 (31285) Adapter close
      2023-11-17 12:34:20.426  - info: knx.0 (31285) terminating
      2023-11-17 12:34:20.427  - debug: knx.0 (31285) Plugin sentry destroyed
      2023-11-17 12:34:20.428  - info: knx.0 (31285) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-11-17 12:34:20.930  - info: knx.0 (31285) terminating
      2023-11-17 12:34:20.951  - error: knx.0 (31285) Cannot get objects: Error: Connection is closed.
      2023-11-17 12:34:21.069  - info: host.raspberrypi instance system.adapter.knx.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-11-17 12:34:23.688  - info: host.raspberrypi instance system.adapter.knx.0 started with pid 31300
      2023-11-17 12:34:27.588  - debug: knx.0 (31300) Redis Objects: Use Redis connection: 127.0.0.1:9001
      2023-11-17 12:34:27.662  - debug: knx.0 (31300) Objects client ready ... initialize now
      2023-11-17 12:34:27.666  - debug: knx.0 (31300) Objects create System PubSub Client
      2023-11-17 12:34:27.668  - debug: knx.0 (31300) Objects create User PubSub Client
      2023-11-17 12:34:27.727  - debug: knx.0 (31300) Objects client initialize lua scripts
      2023-11-17 12:34:27.737  - debug: knx.0 (31300) Objects connected to redis: 127.0.0.1:9001
      2023-11-17 12:34:27.786  - debug: knx.0 (31300) Redis States: Use Redis connection: 127.0.0.1:9000
      2023-11-17 12:34:27.806  - debug: knx.0 (31300) States create System PubSub Client
      2023-11-17 12:34:27.808  - debug: knx.0 (31300) States create User PubSub Client
      2023-11-17 12:34:27.888  - debug: knx.0 (31300) States connected to redis: 127.0.0.1:9000
      2023-11-17 12:34:27.943  - debug: knx.0 (31300) Plugin sentry Initialize Plugin (enabled=true)
      2023-11-17 12:34:28.821  - info: knx.0 (31300) starting. Version 2.0.23 in /opt/iobroker/node_modules/iobroker.knx, node: v18.18.2, js-controller: 5.0.16
      2023-11-17 12:34:38.769  - warn: knx.0 (31300) stateChange: not ready
      2023-11-17 12:34:40.283  - warn: knx.0 (31300) stateChange: not ready
      2023-11-17 12:34:40.361  - warn: knx.0 (31300) stateChange: not ready
      2023-11-17 12:34:49.161  - info: knx.0 (31300) knx license is OK.
      2023-11-17 12:34:49.164  - info: knx.0 (31300) Connecting to knx GW: 192.168.178.100:3671 with phy. Adr: 1.0.7
      2023-11-17 12:34:49.176  - info: knx.0 (31300) Debuglevel: 2    3
      2023-11-17 12:34:49.182  - info: knx.0 (31300) Event : UDP - listening
      2023-11-17 12:34:49.188  - info: knx.0 (31300) Connected  - local UDP Server listening on 192.168.178.59:51521
      2023-11-17 12:34:49.192  - info: knx.0 (31300) Send : description Request :        06 10 02 03 00 0e 08 01 c0 a8 b2 3b c9 41        sent to 192.168.178.100:3671
      2023-11-17 12:34:49.203  - info: knx.0 (31300) Send : searchReqExt Request :        06 10 02 0b 00 14 08 01 c0 a8 b2 3b c9 41 06 04 01 02 08 06        sent to 192.168.178.100:3671
      2023-11-17 12:34:49.204  - info: knx.0 (31300)  STATE_SEARCH_EXT_REQUEST : no defined handling for transition from State: STATE_DESCRIPTION_RESPONSE(18) to STATE_SEARCH_EXT_REQUEST(19).
      2023-11-17 12:34:49.209  - info: knx.0 (31300)  receiving descrExtResp
      2023-11-17 12:34:49.211  - info: knx.0 (31300) Send : UDP Connection Request :        06 10 02 05 00 1a 08 01 c0 a8 b2 3b c9 41 08 01 00 00 00 00 c9 41 04 04 02 00        sent to 192.168.178.100:3671
      2023-11-17 12:34:49.222  - info: knx.0 (31300) Received  CONNECTION_RESPONSE : 06 10 02 06 00 14 02 00 08 01 c0 a8 b2 64 0e 57 04 04 10 04    GW-IP: 192.168.178.100:3671 -  ChannelID: 2 cnt IN/OUT: 0/0
      #Hier wurden dann diverse Datenpunkte erzeugt...
      2023-11-17 12:34:49.306  - info: knx.0 (31300) Connected! :-)
      2023-11-17 12:34:49.542  - info: knx.0 (31300)  Has todo still 309 tasks, just processing : false
      2023-11-17 12:34:49.545  - info: knx.0 (31300) ( 1 ) Sending : GroupValueRead :   06 10 04 20 00 15 04 02 00 00 11 00 bc e0 10 07 38 01 01 00 00    sent to 192.168.178.100:3671  ChID: 2 SeqCntIN : 0 SeqCntOUT : 0 GA : 7/0/1 conCheck.conected : true
      2023-11-17 12:34:49.547  - info: knx.0 (31300) easy-knx: task.data : 06 10 04 20 00 15 04 02 00 00 11 00 bc e0 10 07 38 01 01 00 00  byteLen : 21
      2023-11-17 12:34:49.549  - info: knx.0 (31300) ( 2 ) Received TUNNEL_ACK      :             06 10 04 21 00 0a 04 02 00 00    from 192.168.178.100:3671 SeqCntIN : 0 SeqCntOUT : 1 GA : 0/0/0
      2023-11-17 12:34:49.550  - info: knx.0 (31300)  ==>  successful acknowledged previous package... processing next of 308
      2023-11-17 12:34:49.551  - info: knx.0 (31300)  ==> easy-knx.js: signal runtime : 0s  7.266345ms
      2023-11-17 12:34:49.552  - info: knx.0 (31300)  Has todo still 308 tasks, just processing : false
      2023-11-17 12:34:49.587  - info: knx.0 (31300) ( 3.6a ) Received L_DATA.con  06 10 04 20 00 15 04 02 00 00 2e 00 bc e0 10 07 38 01 01 00 00  was successfully processed by receiver.
      2023-11-17 12:34:49.588  - info: knx.0 (31300) =====> STATE_TUNNELING_ACK
      2023-11-17 12:34:49.597  - info: knx.0 (31300) ( 4 ) Sending Tunnel_Request ACK  : 06 10 04 21 00 0a 04 02 00 00   ChID : 2 SeqCntIN : 0 SeqCntOUT : 1 queue length : 308
      2023-11-17 12:34:49.598  - info: knx.0 (31300) ( 4.b ) return to STATE_READY, processing : false
      2023-11-17 12:34:49.599  - info: knx.0 (31300)  Has todo still 308 tasks, just processing : false
      2023-11-17 12:34:49.600  - info: knx.0 (31300) ( 3.2 ) Received TUNNEL_REQUEST (WRITE - send ACK )         :    06 10 04 20 00 17 04 02 01 00 29 00 bc e0 10 1e 10 01 03 00 80 00 2e   ChID: 2
      2023-11-17 12:34:49.607  - info: knx.0 (31300) WRITE : mappedName : Warmwasserzapftemperatur-soll    dest : 2/0/1  val: 46   (DPT7.000) Warmwasserzapftemperatur-soll
      2023-11-17 12:34:49.610  - info: knx.0 (31300) =====> STATE_TUNNELING_ACK
      2023-11-17 12:34:49.612  - info: knx.0 (31300) ( 4 ) Sending Tunnel_Request ACK  : 06 10 04 21 00 0a 04 02 01 00   ChID : 2 SeqCntIN : 1 SeqCntOUT : 1 queue length : 308
      2023-11-17 12:34:49.612  - info: knx.0 (31300) ( 4.b ) return to STATE_READY, processing : false
      2023-11-17 12:34:49.613  - info: knx.0 (31300)  Has todo still 308 tasks, just processing : false
      2023-11-17 12:34:49.622  - info: knx.0 (31300) ( 3.2 ) Received TUNNEL_REQUEST (WRITE - send ACK )         :    06 10 04 20 00 17 04 02 02 00 29 00 bc e0 10 1e 10 0d 03 00 80 00 00   ChID: 2
      2023-11-17 12:34:49.624  - info: knx.0 (31300) WRITE : mappedName : Waermepumpe Stoerung Puls    dest : 2/0/13  val: 0   (DPT7.001) Waermepumpe_Stoerung_Puls
      2023-11-17 12:34:49.625  - info: knx.0 (31300) =====> STATE_TUNNELING_ACK
      2023-11-17 12:34:49.627  - info: knx.0 (31300) ( 4 ) Sending Tunnel_Request ACK  : 06 10 04 21 00 0a 04 02 02 00   ChID : 2 SeqCntIN : 2 SeqCntOUT : 1 queue length : 308
      2023-11-17 12:34:49.628  - info: knx.0 (31300) ( 4.b ) return to STATE_READY, processing : false
      2023-11-17 12:34:49.628  - info: knx.0 (31300)  Has todo still 308 tasks, just processing : false
      2023-11-17 12:34:49.633  - info: knx.0 (31300) main.js :  tGA.write on Statechange : 2/0/51   P-032E-0_GA-1378  typeof val: number  5.475  DPT9.024
      2023-11-17 12:34:49.642  - info: knx.0 (31300) easy-knx.js groupValueWrite  value:  5.475    dpt : DPT9.024{"type":"Buffer","data":[6,16,4,32,0,23,4,2,1,0,17,0,188,224,16,7,16,51,3,0,128,2,35]}
      2023-11-17 12:34:49.651  - info: knx.0 (31300) ( 1 ) Sending : GroupValueRead :   06 10 04 20 00 15 04 02 01 00 11 00 bc e0 10 07 38 02 01 00 00    sent to 192.168.178.100:3671  ChID: 2 SeqCntIN : 2 SeqCntOUT : 1 GA : 7/0/2 conCheck.conected : true
      2023-11-17 12:34:49.652  - info: knx.0 (31300) easy-knx: task.data : 06 10 04 20 00 15 04 02 01 00 11 00 bc e0 10 07 38 02 01 00 00  byteLen : 21
      2023-11-17 12:34:49.656  - info: knx.0 (31300) ( 3.2 ) Received TUNNEL_REQUEST (WRITE - send ACK )         :    06 10 04 20 00 17 04 02 03 00 29 00 bc e0 10 1e 10 05 03 00 80 00 01   ChID: 2
      2023-11-17 12:34:49.657  - info: knx.0 (31300) WRITE : mappedName : Heizkreis A Betriebsart    dest : 2/0/5  val: 1   (DPT7.000) Heizkreis_A_Betriebsart
      2023-11-17 12:34:49.659  - info: knx.0 (31300) =====> STATE_TUNNELING_ACK newState: deferred
      2023-11-17 12:34:49.660  - info: knx.0 (31300) ( 4 ) Sending Tunnel_Request ACK  : 06 10 04 21 00 0a 04 02 03 00   ChID : 2 SeqCntIN : 3 SeqCntOUT : 2 queue length : 308
      2023-11-17 12:34:49.661  - info: knx.0 (31300) ( 4.b ) return to STATE_READY, processing : false
      2023-11-17 12:34:49.662  - info: knx.0 (31300)  Has todo still 308 tasks, just processing : false
      2023-11-17 12:34:49.662  - info: knx.0 (31300) ( 2 ) Received TUNNEL_ACK      :             06 10 04 21 00 0a 04 02 01 00    from 192.168.178.100:3671 SeqCntIN : 3 SeqCntOUT : 2 GA : 0/0/0
      2023-11-17 12:34:49.663  - info: knx.0 (31300)  ==>  successful acknowledged previous package... processing next of 308
      2023-11-17 12:34:49.664  - info: knx.0 (31300)  ==> easy-knx.js: signal runtime : 0s  13.023492ms
      2023-11-17 12:34:49.665  - info: knx.0 (31300)  Has todo still 308 tasks, just processing : false
      2023-11-17 12:34:49.666  - info: knx.0 (31300) ( 3.2 ) Received TUNNEL_REQUEST (WRITE - send ACK )         :    06 10 04 20 00 15 04 02 04 00 29 00 bc e0 10 03 10 0e 01 00 80   ChID: 2
      2023-11-17 12:34:49.668  - info: knx.0 (31300) WRITE : mappedName : Waermepumpe Stoerung bool    dest : 2/0/14  val: 0   (DPT1.001) Waermepumpe_Stoerung_bool
      2023-11-17 12:34:49.670  - info: knx.0 (31300) =====> STATE_TUNNELING_ACK
      2023-11-17 12:34:49.671  - info: knx.0 (31300) ( 4 ) Sending Tunnel_Request ACK  : 06 10 04 21 00 0a 04 02 04 00   ChID : 2 SeqCntIN : 4 SeqCntOUT : 2 queue length : 308
      2023-11-17 12:34:49.671  - info: knx.0 (31300) ( 4.b ) return to STATE_READY, processing : false
      2023-11-17 12:34:49.672  - info: knx.0 (31300)  Has todo still 308 tasks, just processing : false
      2023-11-17 12:34:49.683  - info: knx.0 (31300) easy-knx.js groupValueWrite  value:  5    dpt : DPT9.000{"type":"Buffer","data":[6,16,4,32,0,23,4,2,2,0,17,0,188,224,16,7,3,1,3,0,128,1,244]}
      2023-11-17 12:34:49.687  - info: knx.0 (31300) easy-knx.js groupValueWrite  value:  23    dpt : DPT9.000{"type":"Buffer","data":[6,16,4,32,0,23,4,2,2,0,17,0,188,224,16,7,3,0,3,0,128,12,126]}
      2023-11-17 12:34:49.690  - info: knx.0 (31300) easy-knx.js groupValueWrite  value:  0    dpt : DPT9.009{"type":"Buffer","data":[6,16,4,32,0,23,4,2,2,0,17,0,188,224,16,7,3,9,3,0,128,0,0]}
      2023-11-17 12:34:49.693  - info: knx.0 (31300) easy-knx.js groupValueWrite  value:  0.562    dpt : DPT14.076{"type":"Buffer","data":[6,16,4,32,0,25,4,2,2,0,17,0,188,224,16,7,3,7,5,0,128,63,15,223,59]}
      2023-11-17 12:34:49.696  - info: knx.0 (31300) easy-knx.js groupValueWrite  value:  80    dpt : DPT9.007{"type":"Buffer","data":[6,16,4,32,0,23,4,2,2,0,17,0,188,224,16,7,3,8,3,0,128,23,208]}
      2023-11-17 12:34:49.698  - info: knx.0 (31300) easy-knx.js groupValueWrite  value:  365    dpt : DPT9.000{"type":"Buffer","data":[6,16,4,32,0,23,4,2,2,0,17,0,188,224,16,7,3,17,3,0,128,44,116]}
      2023-11-17 12:34:49.700  - info: knx.0 (31300) easy-knx.js groupValueWrite  value:  99    dpt : DPT9.000{"type":"Buffer","data":[6,16,4,32,0,23,4,2,2,0,17,0,188,224,16,7,3,16,3,0,128,28,213]}
      2023-11-17 12:34:49.703  - info: knx.0 (31300) easy-knx.js groupValueWrite  value:  685    dpt : DPT9.000{"type":"Buffer","data":[6,16,4,32,0,23,4,2,2,0,17,0,188,224,16,7,3,4,3,0,128,52,46]}
      2023-11-17 12:34:49.706  - info: knx.0 (31300) easy-knx.js groupValueWrite  value:  0    dpt : DPT9.000{"type":"Buffer","data":[6,16,4,32,0,23,4,2,2,0,17,0,188,224,16,7,3,2,3,0,128,0,0]}
      2023-11-17 12:34:49.709  - info: knx.0 (31300) easy-knx.js groupValueWrite  value:  0    dpt : DPT9.000{"type":"Buffer","data":[6,16,4,32,0,23,4,2,2,0,17,0,188,224,16,7,3,3,3,0,128,0,0]}
      2023-11-17 12:34:49.724  - error: knx.0 (31300) uncaught exception: Cannot read properties of null (reading 'val')
      2023-11-17 12:34:49.725  - error: knx.0 (31300) TypeError: Cannot read properties of null (reading 'val')
          at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.knx/knx.js:1:380948)
          at processImmediate (node:internal/timers:478:21)
      2023-11-17 12:34:49.725  - error: knx.0 (31300) Cannot read properties of null (reading 'val')
      2023-11-17 12:34:49.752  - error: knx.0 (31300) uncaught exception: Cannot read properties of null (reading 'val')
      2023-11-17 12:34:49.753  - error: knx.0 (31300) TypeError: Cannot read properties of null (reading 'val')
      2023-11-17 12:34:49.753  - error: knx.0 (31300) Cannot read properties of null (reading 'val')
      2023-11-17 12:34:49.757  - error: knx.0 (31300) uncaught exception: Cannot read properties of null (reading 'val')
      2023-11-17 12:34:49.757  - error: knx.0 (31300) TypeError: Cannot read properties of null (reading 'val')
      2023-11-17 12:34:49.758  - error: knx.0 (31300) Cannot read properties of null (reading 'val')
      2023-11-17 12:34:49.761  - error: knx.0 (31300) uncaught exception: Cannot read properties of null (reading 'val')
      2023-11-17 12:34:49.762  - error: knx.0 (31300) TypeError: Cannot read properties of null (reading 'val')
      2023-11-17 12:34:49.762  - error: knx.0 (31300) Cannot read properties of null (reading 'val')
      2023-11-17 12:34:49.765  - error: knx.0 (31300) uncaught exception: Cannot read properties of null (reading 'val')
      2023-11-17 12:34:49.765  - error: knx.0 (31300) TypeError: Cannot read properties of null (reading 'val')
      2023-11-17 12:34:49.766  - error: knx.0 (31300) Cannot read properties of null (reading 'val')
      2023-11-17 12:34:49.770  - info: knx.0 (31300) easy-knx.js groupValueWrite  value:  12    dpt : DPT9.001{"type":"Buffer","data":[6,16,4,32,0,23,4,2,2,0,17,0,188,224,16,7,2,13,3,0,128,4,176]}
      2023-11-17 12:34:49.771  - info: knx.0 (31300) ( 1 ) Sending : GroupValueRead :   06 10 04 20 00 15 04 02 02 00 11 00 bc e0 10 07 38 04 01 00 00    sent to 192.168.178.100:3671  ChID: 2 SeqCntIN : 4 SeqCntOUT : 2 GA : 7/0/4 conCheck.conected : true
      2023-11-17 12:34:49.773  - info: knx.0 (31300) easy-knx: task.data : 06 10 04 20 00 15 04 02 02 00 11 00 bc e0 10 07 38 04 01 00 00  byteLen : 21
      2023-11-17 12:34:49.776  - info: knx.0 (31300) easy-knx.js groupValueWrite  value:  80    dpt : DPT9.007{"type":"Buffer","data":[6,16,4,32,0,23,4,2,3,0,17,0,188,224,16,7,2,15,3,0,128,23,208]}
      2023-11-17 12:34:49.779  - info: knx.0 (31300) easy-knx.js groupValueWrite  value:  1758    dpt : DPT9.004{"type":"Buffer","data":[6,16,4,32,0,23,4,2,3,0,17,0,188,224,16,7,2,12,3,0,128,61,93]}
      2023-11-17 12:34:49.783  - info: knx.0 (31300) easy-knx.js groupValueWrite  value:  13    dpt : DPT9.001{"type":"Buffer","data":[6,16,4,32,0,23,4,2,3,0,17,0,188,224,16,7,2,11,3,0,128,5,20]}
      2023-11-17 12:34:49.785  - info: knx.0 (31300) easy-knx.js groupValueWrite  value:  30    dpt : DPT9.007{"type":"Buffer","data":[6,16,4,32,0,23,4,2,3,0,17,0,188,224,16,7,2,10,3,0,128,13,220]}
      2023-11-17 12:34:49.787  - info: knx.0 (31300) easy-knx.js groupValueWrite  value:  57    dpt : DPT9.007{"type":"Buffer","data":[6,16,4,32,0,23,4,2,3,0,17,0,188,224,16,7,2,16,3,0,128,21,145]}
      2023-11-17 12:34:49.789  - info: knx.0 (31300) easy-knx.js groupValueWrite  value:  4    dpt : DPT9.001{"type":"Buffer","data":[6,16,4,32,0,23,4,2,3,0,17,0,188,224,16,7,2,23,3,0,128,1,144]}
      2023-11-17 12:34:49.791  - info: knx.0 (31300) easy-knx.js groupValueWrite  value:  90    dpt : DPT9.007{"type":"Buffer","data":[6,16,4,32,0,23,4,2,3,0,17,0,188,224,16,7,2,25,3,0,128,28,101]}
      2023-11-17 12:34:49.793  - info: knx.0 (31300) easy-knx.js groupValueWrite  value:  0    dpt : DPT9.004{"type":"Buffer","data":[6,16,4,32,0,23,4,2,3,0,17,0,188,224,16,7,2,22,3,0,128,0,0]}
      2023-11-17 12:34:49.795  - info: knx.0 (31300) easy-knx.js groupValueWrite  value:  8    dpt : DPT9.001{"type":"Buffer","data":[6,16,4,32,0,23,4,2,3,0,17,0,188,224,16,7,2,21,3,0,128,3,32]}
      2023-11-17 12:34:49.798  - info: knx.0 (31300) easy-knx.js groupValueWrite  value:  85    dpt : DPT9.007{"type":"Buffer","data":[6,16,4,32,0,23,4,2,3,0,17,0,188,224,16,7,2,20,3,0,128,28,38]}
      2023-11-17 12:34:49.801  - info: knx.0 (31300) easy-knx.js groupValueWrite  value:  0    dpt : DPT9.007{"type":"Buffer","data":[6,16,4,32,0,23,4,2,3,0,17,0,188,224,16,7,2,26,3,0,128,0,0]}
      2023-11-17 12:34:49.803  - info: knx.0 (31300) easy-knx.js groupValueWrite  value:  50    dpt : DPT9.007{"type":"Buffer","data":[6,16,4,32,0,23,4,2,3,0,17,0,188,224,16,7,2,35,3,0,128,20,226]}
      2023-11-17 12:34:49.805  - info: knx.0 (31300) easy-knx.js groupValueWrite  value:  12    dpt : DPT9.001{"type":"Buffer","data":[6,16,4,32,0,23,4,2,3,0,17,0,188,224,16,7,2,31,3,0,128,4,176]}
      2023-11-17 12:34:49.807  - info: knx.0 (31300) easy-knx.js groupValueWrite  value:  0    dpt : DPT9.007{"type":"Buffer","data":[6,16,4,32,0,23,4,2,3,0,17,0,188,224,16,7,2,30,3,0,128,0,0]}
      2023-11-17 12:34:49.809  - info: knx.0 (31300) easy-knx.js groupValueWrite  value:  12    dpt : DPT9.007{"type":"Buffer","data":[6,16,4,32,0,23,4,2,3,0,17,0,188,224,16,7,2,36,3,0,128,4,176]}
      2023-11-17 12:34:49.811  - info: knx.0 (31300) easy-knx.js groupValueWrite  value:  60    dpt : DPT9.007{"type":"Buffer","data":[6,16,4,32,0,23,4,2,3,0,17,0,188,224,16,7,2,45,3,0,128,21,220]}
      2023-11-17 12:34:49.820  - info: knx.0 (31300) ( 3.2 ) Received TUNNEL_REQUEST (WRITE - send ACK )         :    06 10 04 20 00 17 04 02 05 00 29 00 bc e0 10 1e 10 09 03 00 80 00 01   ChID: 2
      2023-11-17 12:34:49.821  - info: knx.0 (31300) WRITE : mappedName : Zonenmodul Modus    dest : 2/0/9  val: 1   (DPT7.000) Zonenmodul_Modus
      2023-11-17 12:34:49.822  - info: knx.0 (31300) =====> STATE_TUNNELING_ACK newState: deferred
      2023-11-17 12:34:49.823  - info: knx.0 (31300) ( 4 ) Sending Tunnel_Request ACK  : 06 10 04 21 00 0a 04 02 05 00   ChID : 2 SeqCntIN : 5 SeqCntOUT : 3 queue length : 334
      2023-11-17 12:34:49.824  - info: knx.0 (31300) ( 4.b ) return to STATE_READY, processing : false
      2023-11-17 12:34:49.824  - info: knx.0 (31300)  Has todo still 334 tasks, just processing : false
      2023-11-17 12:34:49.825  - info: knx.0 (31300) ( 2 ) Received TUNNEL_ACK      :             06 10 04 21 00 0a 04 02 02 00    from 192.168.178.100:3671 SeqCntIN : 5 SeqCntOUT : 3 GA : 0/0/0
      2023-11-17 12:34:49.826  - info: knx.0 (31300)  ==>  successful acknowledged previous package... processing next of 334
      2023-11-17 12:34:49.826  - info: knx.0 (31300)  ==> easy-knx.js: signal runtime : 0s  55.111437ms
      2023-11-17 12:34:49.827  - info: knx.0 (31300)  Has todo still 334 tasks, just processing : false
      2023-11-17 12:34:49.828  - info: knx.0 (31300) ( 3.6a ) Received L_DATA.con  06 10 04 20 00 15 04 02 06 00 2e 00 bc e0 10 07 38 02 01 00 00  was successfully processed by receiver.
      2023-11-17 12:34:49.828  - info: knx.0 (31300) =====> STATE_TUNNELING_ACK
      2023-11-17 12:34:49.829  - info: knx.0 (31300) ( 4 ) Sending Tunnel_Request ACK  : 06 10 04 21 00 0a 04 02 06 00   ChID : 2 SeqCntIN : 6 SeqCntOUT : 3 queue length : 334
      2023-11-17 12:34:49.830  - info: knx.0 (31300) ( 4.b ) return to STATE_READY, processing : false
      2023-11-17 12:34:49.830  - info: knx.0 (31300)  Has todo still 334 tasks, just processing : false
      2023-11-17 12:34:49.831  - info: knx.0 (31300) ( 3.3 ) Received TUNNEL_REQUEST (RESPONSE  - send ACK)      :    06 10 04 20 00 17 04 02 07 00 29 00 bc d0 11 0a 38 01 03 00 40 0c b6                2
      2023-11-17 12:34:49.833  - info: knx.0 (31300) main.js: onGroupValue_Response from 7/0/1
      2023-11-17 12:34:49.834  - info: knx.0 (31300) RESPONSE : mappedName : Windgeschwindigkeit    dest : 7/0/1  val: 24.12   (DPT9.005) Windgeschwindigkeit
      2023-11-17 12:34:49.835  - info: knx.0 (31300) RESPONSE single-array value : 24.12 auf knx.0.Wetter.Wetterstation.Windgeschwindigkeit
      2023-11-17 12:34:49.836  - info: knx.0 (31300) ( 3.4 ) Received TUNNEL_REQUEST for unexpected address
      2023-11-17 12:34:49.837  - info: knx.0 (31300) =====> STATE_TUNNELING_ACK
      2023-11-17 12:34:49.838  - info: knx.0 (31300) ( 4 ) Sending Tunnel_Request ACK  : 06 10 04 21 00 0a 04 02 07 00   ChID : 2 SeqCntIN : 7 SeqCntOUT : 3 queue length : 334
      2023-11-17 12:34:49.839  - info: knx.0 (31300) ( 4.b ) return to STATE_READY, processing : false
      2023-11-17 12:34:49.839  - info: knx.0 (31300)  Has todo still 334 tasks, just processing : false
      2023-11-17 12:34:49.841  - info: knx.0 (31300) ( 3.2 ) Received TUNNEL_REQUEST (WRITE - send ACK )         :    06 10 04 20 00 17 04 02 08 00 29 00 bc e0 10 1e 12 03 03 00 80 0c 1a   ChID: 2
      2023-11-17 12:34:49.842  - info: knx.0 (31300) WRITE : mappedName : A3_Raumtemperatur EG Flur -Soll    dest : 2/2/3  val: 21   (DPT9.001) A3_Raumtemperatur_EG_Flur_-Soll
      2023-11-17 12:34:49.843  - info: knx.0 (31300) =====> STATE_TUNNELING_ACK
      2023-11-17 12:34:49.844  - info: knx.0 (31300) ( 4 ) Sending Tunnel_Request ACK  : 06 10 04 21 00 0a 04 02 08 00   ChID : 2 SeqCntIN : 8 SeqCntOUT : 3 queue length : 334
      2023-11-17 12:34:49.845  - info: knx.0 (31300) ( 4.b ) return to STATE_READY, processing : false
      2023-11-17 12:34:49.846  - info: knx.0 (31300)  Has todo still 334 tasks, just processing : false
      2023-11-17 12:34:49.847  - info: knx.0 (31300) ( 3.2 ) Received TUNNEL_REQUEST (WRITE - send ACK )         :    06 10 04 20 00 17 04 02 09 00 29 00 bc e0 10 1e 12 04 03 00 80 07 6c   ChID: 2
      2023-11-17 12:34:49.848  - info: knx.0 (31300) WRITE : mappedName : A4_Raumtemperatur EG WC -Soll    dest : 2/2/4  val: 19   (DPT9.001) A4_Raumtemperatur_EG_WC_-Soll
      2023-11-17 12:34:49.848  - info: knx.0 (31300) =====> STATE_TUNNELING_ACK
      2023-11-17 12:34:49.850  - info: knx.0 (31300) ( 4 ) Sending Tunnel_Request ACK  : 06 10 04 21 00 0a 04 02 09 00   ChID : 2 SeqCntIN : 9 SeqCntOUT : 3 queue length : 334
      2023-11-17 12:34:49.850  - info: knx.0 (31300) ( 4.b ) return to STATE_READY, processing : false
      2023-11-17 12:34:49.851  - info: knx.0 (31300)  Has todo still 334 tasks, just processing : false
      2023-11-17 12:34:49.852  - info: knx.0 (31300) ( 3.6a ) Received L_DATA.con  06 10 04 20 00 15 04 02 0a 00 2e 00 bc e0 10 07 38 04 01 00 00  was successfully processed by receiver.
      2023-11-17 12:34:49.852  - info: knx.0 (31300) =====> STATE_TUNNELING_ACK
      2023-11-17 12:34:49.854  - info: knx.0 (31300) ( 4 ) Sending Tunnel_Request ACK  : 06 10 04 21 00 0a 04 02 0a 00   ChID : 2 SeqCntIN : 10 SeqCntOUT : 3 queue length : 334
      2023-11-17 12:34:49.855  - info: knx.0 (31300) ( 4.b ) return to STATE_READY, processing : false
      2023-11-17 12:34:49.855  - info: knx.0 (31300)  Has todo still 334 tasks, just processing : false
      2023-11-17 12:34:49.856  - info: knx.0 (31300) ( 3.2 ) Received TUNNEL_REQUEST (WRITE - send ACK )         :    06 10 04 20 00 17 04 02 0b 00 29 00 bc e0 10 1e 10 34 03 00 80 00 00   ChID: 2
      2023-11-17 12:34:49.857  - info: knx.0 (31300) WRITE : mappedName : PV_WP_Elektrische_Leistungsaufnahme    dest : 2/0/52  val: 0   (DPT9.001) PV_WP_Elektrische_Leistungsaufnahme
      2023-11-17 12:34:49.858  - info: knx.0 (31300) =====> STATE_TUNNELING_ACK
      2023-11-17 12:34:49.859  - info: knx.0 (31300) ( 4 ) Sending Tunnel_Request ACK  : 06 10 04 21 00 0a 04 02 0b 00   ChID : 2 SeqCntIN : 11 SeqCntOUT : 3 queue length : 334
      2023-11-17 12:34:49.860  - info: knx.0 (31300) ( 4.b ) return to STATE_READY, processing : false
      2023-11-17 12:34:49.860  - info: knx.0 (31300)  Has todo still 334 tasks, just processing : false
      2023-11-17 12:34:49.871  - info: knx.0 (31300)  Connection persists.....closing now
      2023-11-17 12:34:49.872  - info: knx.0 (31300)  ... not able to close connection, because already closed
      2023-11-17 12:34:49.873  - info: knx.0 (31300)  STATE_NOT_CONNECTED : Try to connect / reconnect :  STATE_READY(7) to STATE_NOT_CONNECTED(0).
      2023-11-17 12:34:49.874  - debug: knx.0 (31300) Adapter close
      2023-11-17 12:34:49.875  - info: knx.0 (31300) terminating
      2023-11-17 12:34:49.876  - debug: knx.0 (31300) Plugin sentry destroyed
      2023-11-17 12:34:49.876  - warn: knx.0 (31300) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2023-11-17 12:34:49.878  - info: knx.0 (31300) ( END ) Sending DISCONNECT_REQUEST :           06 10 02 09 00 10 02 00 08 01 c0 a8 b2 3b c9 41                                                        ChID : 0 SeqCntIN : 11 SeqCntOUT : 3  msgCode : [object Object]
      2023-11-17 12:34:49.879  - info: knx.0 (31300)  STATE_DISCONNECT_REQUEST : Transition from State:  STATE_NOT_CONNECTED(0) to STATE_DISCONNECT_REQUEST(15) not possible because of cancelled connection.
      2023-11-17 12:34:49.879  - info: knx.0 (31300)  Connection persists.....closing now
      2023-11-17 12:34:49.880  - info: knx.0 (31300)  ... not able to close connection, because already closed
      2023-11-17 12:34:49.881  - info: knx.0 (31300)  STATE_NOT_CONNECTED : Stop connection :  STATE_DISCONNECT_REQUEST(15) to STATE_NOT_CONNECTED(0).
      2023-11-17 12:34:49.914  - info: knx.0 (31300) easy-knx.js groupValueWrite  value:  11    dpt : DPT9.001{"type":"Buffer","data":[6,16,4,32,0,23,4,2,3,0,17,0,188,224,16,7,2,41,3,0,128,4,76]}
      2023-11-17 12:34:49.916  - info: knx.0 (31300) easy-knx.js groupValueWrite  value:  60    dpt : DPT9.007{"type":"Buffer","data":[6,16,4,32,0,23,4,2,3,0,17,0,188,224,16,7,2,40,3,0,128,21,220]}
      2023-11-17 12:34:49.919  - info: knx.0 (31300) easy-knx.js groupValueWrite  value:  51    dpt : DPT9.007{"type":"Buffer","data":[6,16,4,32,0,23,4,2,3,0,17,0,188,224,16,7,2,46,3,0,128,20,251]}
      2023-11-17 12:34:49.922  - info: knx.0 (31300) easy-knx.js groupValueWrite  value:  0.055    dpt : DPT9.024{"type":"Buffer","data":[6,16,4,32,0,23,4,2,3,0,17,0,188,224,16,7,16,50,3,0,128,0,5]}
      2023-11-17 12:34:49.925  - info: knx.0 (31300) easy-knx.js groupValueWrite  value:  5.475    dpt : DPT9.024{"type":"Buffer","data":[6,16,4,32,0,23,4,2,3,0,17,0,188,224,16,7,16,51,3,0,128,2,35]}
      2023-11-17 12:34:49.935  - info: knx.0 (31300)  STATE_DISCONNECT_RESPONSE : from State:  STATE_NOT_CONNECTED(0) to STATE_DISCONNECT_RESPONSE(16) ... connection closed
      2023-11-17 12:34:49.936  - info: knx.0 (31300) Received DISCONNECT_RESPONSE06 10 02 0a 00 08 02 00
      2023-11-17 12:34:49.937  - info: knx.0 (31300)  Connection persists.....closing now
      2023-11-17 12:34:49.939  - info: knx.0 (31300)  ... not able to close connection, because already closed
      2023-11-17 12:34:49.940  - info: knx.0 (31300)  STATE_NOT_CONNECTED : Stop connection :  STATE_DISCONNECT_RESPONSE(16) to STATE_NOT_CONNECTED(0).
      2023-11-17 12:34:50.418  - error: host.raspberrypi Caught by controller[0]: TypeError: Cannot read properties of null (reading 'val')
      2023-11-17 12:34:50.420  - error: host.raspberrypi Caught by controller[0]:     at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.knx/knx.js:1:380948)
      2023-11-17 12:34:50.420  - error: host.raspberrypi Caught by controller[0]:     at processImmediate (node:internal/timers:478:21)
      2023-11-17 12:34:50.420  - error: host.raspberrypi Caught by controller[1]: TypeError: Cannot read properties of null (reading 'val')
      2023-11-17 12:34:50.420  - error: host.raspberrypi Caught by controller[1]:     at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.knx/knx.js:1:380948)
      2023-11-17 12:34:50.420  - error: host.raspberrypi Caught by controller[1]:     at processImmediate (node:internal/timers:478:21)
      2023-11-17 12:34:50.420  - error: host.raspberrypi Caught by controller[2]: TypeError: Cannot read properties of null (reading 'val')
      2023-11-17 12:34:50.421  - error: host.raspberrypi Caught by controller[2]:     at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.knx/knx.js:1:380948)
      2023-11-17 12:34:50.421  - error: host.raspberrypi Caught by controller[2]:     at processImmediate (node:internal/timers:478:21)
      2023-11-17 12:34:50.421  - error: host.raspberrypi Caught by controller[3]: TypeError: Cannot read properties of null (reading 'val')
      2023-11-17 12:34:50.421  - error: host.raspberrypi Caught by controller[3]:     at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.knx/knx.js:1:380948)
      2023-11-17 12:34:50.421  - error: host.raspberrypi Caught by controller[3]:     at processImmediate (node:internal/timers:478:21)
      2023-11-17 12:34:50.421  - error: host.raspberrypi Caught by controller[4]: TypeError: Cannot read properties of null (reading 'val')
      2023-11-17 12:34:50.422  - error: host.raspberrypi Caught by controller[4]:     at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.knx/knx.js:1:380948)
      2023-11-17 12:34:50.422  - error: host.raspberrypi Caught by controller[4]:     at processImmediate (node:internal/timers:478:21)
      2023-11-17 12:34:50.422  - error: host.raspberrypi instance system.adapter.knx.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      2023-11-17 12:34:50.422  - info: host.raspberrypi Restart adapter system.adapter.knx.0 because enabled
      es sieht so aus also er sich hier komplett zerschossen hat, da eine 2te Instanz geht waehre es eine option die fehlerhafte zu löschen und neu an zu legen ?
        blacksheep587 @Dutchman last edited by
        @dutchman Ja, das habe ich gerade gemacht. Es hat aber nicht geholfen, die 0er Instanz zu deinstallieren und eine neue 0er zu erstellen. Ich baue jetzt auf 1. Instanz auf. Jetzt die Frage: kann ich InfluxDB Logs umhängen in eine andere Instanz?
        • Dutchman
          Dutchman Developer Most Active Administrators @blacksheep587 last edited by Dutchman
          hmm ja aber damit bekämpfen wir ein symptom und mache es komplex da wir mit aliassen arbeiten müssen.
          (die Datenpunkte ändern sich nämlich von knx.0 nach knx.1)
          Wieso lässt sich die erste Instanz nicht löschen, kommt da was im log oder ?
            @dutchman said in Test Adapter KNX v2.x:
            Ja, ich bekomme die gleiche Logschleife wie vorher.
            • Dutchman
              @ChefSache behällt der Adapter noch irgendwo anders Daten? Kannst du eventueel helfen als maintainer des Adapter ?
              @blacksheep587 alternatief koelte ich dich dabei unterstützen es auf einen knx.1 Instanz um zu setzen.
              Wen du Datenpunkte mit logging aktiv hast, muesste diese auf dem 2ten wieder aktiviert werden un der vorige als alias eingetragen (damit laufen das logging auf deine Datenbank weiter wie gehabt, sonst werden es neue Einträge)
              eventuelle scripte, visu Verweisungen usw müssten auch geändert werden. das das eventuell viel aufwand ist doch die frage ob wir die Instanz 0 nicht reanimieren/neu aufsetzen koennten
                @dutchman ja, das wäre gut, wenn wir die InfluxDB über Aliase umhängen könnten. Die Skripte habe ich gestern bereits geändert und als Visu habe ich eine native KNX Umgebung, da gibts nichts zu tun.
                • Dutchman
                  Wie wollen wir vorgehen? Bin gerne bereit dich hier im Forum, also das wir die Schritte durchgehen auch zum mitlesen für anderen, oder per discord/Teams dabei zu unterstützen
                    mibr85 last edited by
                    Hallo zusammen
                    enventuel gibt es ja hier eine ANtwort zu meinem Problem:
                    ich habe in meinem KNX Projekt über die Jahre einige GAs umbenannt oder gelöscht, im Objektbaum des ioBroker sind aber noch alle vorhanden und noch schlimmer ist, dass umbenannte GAs quasi nochmal im Objektbaum angelegt werden aber das neue Objekt hört nicht auf die GA, sondern immer das alte.
                    Das möchtre ich gern so einfach wie möglich bereinigen.
                    Welche Optionen habe ich dafür?
                    ganzen KNX adapter Objektbaum löschen und neu anlegen? Bleiben dabei verbindungen zB in Blockly bestehen oder muss ich alle neu anlegen?
                    Gibt es bessere Möglichkeiten? über 2000 GAs einzeln durchgehen ist sehr ineffektiv.
                      marlan99 @mibr85 last edited by
                      @mibr85 ich denke die einfachste Methode ist tatsächlich ganzen Baum löschen und Instanz neu starten.
                      Die Objekte in den Blockly werden beibehalten.
                      Eine andere Variante wäre ein Script zu schreiben um im KNX Baum nach Objekten zu suchen die seit einem bestimmten Datum nie mehr aktualisiert wurden. Sicher aufwändiger und je nachdem nicht so zuverlässig wie das löschen des Baums
                        mpl1338 @marlan99 last edited by
                        @marlan99 said in Test Adapter KNX v2.x:
                        Ich habe das selbe Problem. Ich habe das löschen und neu anlegen lassen mal versucht(IOB Kopie) ging leider schief.
                        In vielen KNX Datenpunkten waren die Flags danach falsch. Bei knapp 1000DP machts das keinen Spaß. Solch eine Funktion gehört in den Adapter rein.
                          marlan99 @mpl1338 last edited by
                          @mpl1338 wenn die Flags nach dem Import falsch sind, dann ist es bereits in der ETS nicht korrekt gesetzt. Ist eine Mordsarbeit, aber seither passt es bei jedem Import perfekt.
                          M M 2 Replies Last reply Reply Quote 0
                            mibr85 @marlan99 last edited by
                            @marlan99
                            wie genau bist du denn vorgegangen beim setzen deiner Flags?
                            welche KOs haben bei dir welche Flags bekommen?
                              @mibr85
                              Hier meine Notizen, die ich dann in der ETS konsequent angewendet hatte. Die Info habe ich vom KNX Adapter Entwickler irgendwo in den Weiten des Internets gefunden.
                              KNX Flags
                              Pro Datenobjekt darf nur 1 Leseflag gesetzt sein !!!
                              Standard Flags:
                              -Lichttaster: S Ü A
                              -Lichttaster LED: S A
                              -Taster sperre: S
                              -Lichtaktor Schalten: S
                              -Lichtaktor Schaltstatus: L Ü
                              -Rollladentaster: S Ü
                              -Rollladenaktor Schalten: S (A)
                              -Rollladenaktor Stati: L Ü (A)
                              K-Flag: Kommunikation ist eingeschaltet
                              L-Flag:
                              S-Flag: LED soll geschaltet werden, wenn jemand auf den Bus schreibt
                              Ü-Flag: Sollte die LED irgendwie intern geschaltet werden, zum Beispiel durch drücken einer Taste, soll der Zustand auf den Bus geschrieben (übertragen) werden.
                              A-Flag: Falls ein Gerät auf dem Bus die Adresse abfragt (also liest) soll der Zustand der LED auch Aktualisiert werden.
                              ioBroker KNX Importregeln
                                eben nicht 😕
                                8 GAs', 8 Aktorausgänge 1/1/0 - 1/1/7(DT 1001), Status 6/1/0 - 6/1/7(DT 1011) und trotzdem schafft es der Adapter den ein oder anderen Ausgang als Eingang zu deklaieren.
                                Mit Rollläden hatte ich die meisten Probleme.
                                Rollladen Zimmer XXX fahren absolute Position (flag schreiben )
                                Rollladen Zimmer XXX status absolute Position (flag lesen/übertragen)
                                nach dem Import kann ich "fahren absolute Position" nicht mehr beschreiben
                                  @dutchman
                                  Ich habe das Problem jetzt zusammen mit chefkoch009 gelöst;
                                  irgendwo gab es ein Problem beim Import meiner GAs auf Grund von falsch gesetzten Flags in der ETS;
                                  Wir haben die kompletten GAs der 0er Instanz gelöscht Flags korrigiert und neu eingelesen; die Influx-DB habe ich somit auch wieder an die alten Datenpunkte hängen können.
                                  Vielen Dank trotzdem für eure Unterstützung!
                                  Dutchman 1 Reply Last reply Reply Quote 1
                                  • Dutchman
                                    @dutchman
                                    super freut mich und damit auch vielen dank an @ChefSache fuer den support
                                      Hallo Zusammen
                                      ich habe ein Problem mit meinem KNX Adapter:
                                      alle 5-10 Tage habe ich festgestellt, dass die CPU Last meines Synology NAS (ioBroker läuft hierauf im Docker) plötzlich um 20-30% ansteigt.
                                      Jetzt habe ich im Ressourcenmanager geschaut was diesen Anstieg auslöst:
                                      Wenn ich die KNX Instanz im ioBroker stoppe, läuft dieser Prozess trotzdem weiter.
                                      wenn ich die KNX Instanz neustarte wird ein neuer Prozess gestartet:
                                      so sieht es im Docker aus:
                                      ich konnte den Prozess nur mit sudo kill -9 io.knx.0 stoppen
                                      Wie kann ich den Prozess stoppen?
                                      Wie kann ich herausfinden was zu diesem verhalten führt?
                                      Auszug aus iob diag:
                                      Skript v.2023-10-10
                                      *** BASE SYSTEM ***
                                      Hardware Vendor : Synology
                                      Kernel          : x86_64
                                      Userland        : amd64
                                      Docker          : v9.0.1
                                      Virtualization  : Docker
                                      Kernel          : x86_64
                                      Userland        : amd64
                                      Systemuptime and Load:
                                       02:36:03 up 13 days, 16:08,  0 user,  load average: 1.24, 2.29, 3.05
                                      CPU threads: 4
                                      *** Time and Time Zones ***
                                      Mon Dec 11 01:36:03 UTC 2023
                                      Mon Dec 11 02:36:03 CET 2023
                                      CET +0100
                                      Etc/UTC
                                      *** User and Groups ***
                                      root
                                      /root
                                      root
                                      *** X-Server-Setup ***
                                      X-Server:       false
                                      Desktop:
                                      Terminal:
                                      *** MEMORY ***
                                      Mem:            8.2G        4.0G        259M        182M        4.4G        4.2G
                                      Swap:           7.1G        1.8G        5.3G
                                      Total:           15G        5.7G        5.6G
                                               7802 M total memory
                                               3797 M used memory
                                               3200 M active memory
                                               2819 M inactive memory
                                                247 M free memory
                                                 16 M buffer memory
                                               4211 M swap cache
                                               6731 M total swap
                                               1673 M used swap
                                               5058 M free swap
                                      *** FILESYSTEM ***
                                      Filesystem             Type   Size  Used Avail Use% Mounted on
                                      /dev/mapper/cachedev_0 btrfs  5.3T  3.4T  2.0T  64% /
                                      tmpfs                  tmpfs   64M     0   64M   0% /dev
                                      tmpfs                  tmpfs  3.9G     0  3.9G   0% /sys/fs/cgroup
                                      shm                    tmpfs   64M     0   64M   0% /dev/shm
                                      /dev/mapper/cachedev_0 btrfs  5.3T  3.4T  2.0T  64% /opt/iobroker
                                      tmpfs                  tmpfs  3.9G     0  3.9G   0% /proc/acpi
                                      tmpfs                  tmpfs  3.9G     0  3.9G   0% /proc/scsi
                                      tmpfs                  tmpfs  3.9G     0  3.9G   0% /sys/firmware
                                      [Mon Nov 27 10:27:58 2023] EXT4-fs (md0): couldn't mount as ext3 due to feature incompatibilities
                                      [Mon Nov 27 10:27:58 2023] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: (null)
                                      [Mon Nov 27 10:27:58 2023] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: barrier=1
                                      [Mon Nov 27 10:27:58 2023] EXT4-fs (sdd2): couldn't mount as ext3 due to feature incompatibilities
                                      [Mon Nov 27 10:27:58 2023] EXT4-fs (sdd2): mounted filesystem with ordered data mode. Opts: (null)
                                      [Mon Nov 27 10:29:23 2023] EXT4-fs (md0): couldn't mount as ext3 due to feature incompatibilities
                                      [Mon Nov 27 10:29:23 2023] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: (null)
                                      [Mon Nov 27 10:29:23 2023] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: barrier=1
                                      TARGET             SOURCE        FSTYPE OPTIONS
                                      /                  /dev/mapper/cachedev_0[/@syno/@docker/btrfs/subvolumes/1ced23e2edec353cde2fe4d9270f5dcb50e5ee8b10733174734586bded77cb77]       btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,syno_allocator,subvolid=865,subvol=/@syno/@docker/btrfs/subvolumes/1ced23e2edec353cde2fe4d9270f5dcb50e5ee8b10733174734586bded77cb77
                                      |-/opt/iobroker    /dev/mapper/cachedev_0[/@syno/@docker/volumes/iobrokerVolume/_data]                                                            btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,syno_allocator,subvolid=257,subvol=/@syno
                                      |-/etc/resolv.conf /dev/mapper/cachedev_0[/@syno/@docker/containers/2d62f9c4b750cc523ec5c6240dcefc599d288730892369546e93bb18b849868b/resolv.conf] btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,syno_allocator,subvolid=257,subvol=/@syno
                                      |-/etc/hostname    /dev/mapper/cachedev_0[/@syno/@docker/containers/2d62f9c4b750cc523ec5c6240dcefc599d288730892369546e93bb18b849868b/hostname]    btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,syno_allocator,subvolid=257,subvol=/@syno
                                      `-/etc/hosts       /dev/mapper/cachedev_0[/@syno/@docker/containers/2d62f9c4b750cc523ec5c6240dcefc599d288730892369546e93bb18b849868b/hosts]       btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,syno_allocator,subvolid=257,subvol=/@syno
                                      /var:
                                      34M     /var/
                                      32M     /var/lib
                                      19M     /var/lib/apt/lists
                                      19M     /var/lib/apt
                                      13M     /var/lib/dpkg
                                      /opt/iobroker/backups:
                                      38M     /opt/iobroker/backups/
                                      /opt/iobroker/iobroker-data:
                                      368M    /opt/iobroker/iobroker-data/
                                      224M    /opt/iobroker/iobroker-data/files
                                      84M     /opt/iobroker/iobroker-data/backup-objects
                                      67M     /opt/iobroker/iobroker-data/files/javascript.admin
                                      48M     /opt/iobroker/iobroker-data/files/javascript.admin/static
                                      36M     /opt/iobroker/iobroker-data/objects.jsonl
                                      33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
                                      26M     /opt/iobroker/iobroker-data/states.jsonl
                                      21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
                                      18M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.274a4d8d.js.map
                                      USB-Devices by-id:
                                      *** NodeJS-Installation ***
                                      /usr/bin/nodejs         v18.18.2
                                      /usr/bin/node           v18.18.2
                                      /usr/bin/npm            9.8.1
                                      /usr/bin/npx            9.8.1
                                      /usr/bin/corepack       0.19.0
                                      nodejs:
                                        Installed: 18.18.2-1nodesource1
                                        Candidate: 18.18.2-1nodesource1
                                        Version table:
                                       *** 18.18.2-1nodesource1 500
                                              500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                                              100 /var/lib/dpkg/status
                                           18.18.1-1nodesource1 500
                                           18.18.0-1nodesource1 500
                                           18.17.1-1nodesource1 500
                                           18.17.0-1nodesource1 500
                                           18.16.1-1nodesource1 500
                                           18.16.0-1nodesource1 500
                                           18.15.0-1nodesource1 500
                                           18.14.2-1nodesource1 500
                                           18.14.1-1nodesource1 500
                                           18.14.0-1nodesource1 500
                                           18.13.0+dfsg1-1 500
                                              500 http://deb.debian.org/debian bookworm/main amd64 Packages
                                           18.13.0-1nodesource1 500
                                           18.12.0-1nodesource1 500
                                           18.11.0-1nodesource1 500
                                           18.10.0-1nodesource1 500
                                           18.9.1-1nodesource1 500
                                           18.9.0-1nodesource1 500
                                           18.8.0-1nodesource1 500
                                           18.7.0-1nodesource1 500
                                           18.6.0-1nodesource1 500
                                           18.5.0-1nodesource1 500
                                           18.4.0-1nodesource1 500
                                           18.3.0-1nodesource1 500
                                           18.2.0-1nodesource1 500
                                           18.1.0-1nodesource1 500
                                           18.0.0-1nodesource1 500
                                      No problems detected
                                      Errors in npm tree:
                                      *** ioBroker-Installation ***
                                      ioBroker Status
                                      Objects type: jsonl
                                      States  type: jsonl
                                      Core adapters versions
                                      admin:          6.12.0
                                      javascript:     7.1.6
                                      Adapters from github:   0
                                      Adapter State
                                      + system.adapter.admin.0                  : admin                 : MIBR-DS                                  -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                      + system.adapter.backitup.0               : backitup              : MIBR-DS                                  -  enabled
                                      + system.adapter.discovery.0              : discovery             : MIBR-DS                                  -  enabled
                                      + system.adapter.doorbird.0               : doorbird              : MIBR-DS                                  -  enabled
                                      + system.adapter.e3dc-rscp.0              : e3dc-rscp             : MIBR-DS                                  -  enabled
                                      + system.adapter.gruenbeck.0              : gruenbeck             : MIBR-DS                                  -  enabled
                                      + system.adapter.hue.0                    : hue                   : MIBR-DS                                  -  enabled, port: 443
                                      + system.adapter.hue.1                    : hue                   : MIBR-DS                                  -  enabled, port: 443
                                        system.adapter.ical.0                   : ical                  : MIBR-DS                                  -  enabled
                                      + system.adapter.info.0                   : info                  : MIBR-DS                                  -  enabled
                                      + system.adapter.iot.0                    : iot                   : MIBR-DS                                  -  enabled
                                      + system.adapter.javascript.0             : javascript            : MIBR-DS                                  -  enabled
                                      + system.adapter.klf200.0                 : klf200                : MIBR-DS                                  -  enabled
                                        system.adapter.knx.0                    : knx                   : MIBR-DS                                  - disabled
                                        system.adapter.lg-thinq.0               : lg-thinq              : MIBR-DS                                  - disabled
                                      + system.adapter.mihome-vacuum.0          : mihome-vacuum         : MIBR-DS                                  -  enabled, port: 54321
                                      + system.adapter.mqtt-client.0            : mqtt-client           : MIBR-DS                                  -  enabled, port: 1883
                                        system.adapter.node-red.0               : node-red              : MIBR-DS                                  - disabled, port: 1880, bind: 0.0.0.0
                                      + system.adapter.procon-ip.0              : procon-ip             : MIBR-DS                                  -  enabled
                                      + system.adapter.pvforecast.0             : pvforecast            : MIBR-DS                                  -  enabled
                                      + system.adapter.scenes.0                 : scenes                : MIBR-DS                                  -  enabled
                                      + system.adapter.shelly.0                 : shelly                : MIBR-DS                                  -  enabled, port: 1882, bind: 0.0.0.0
                                      + system.adapter.statistics.0             : statistics            : MIBR-DS                                  -  enabled
                                      + system.adapter.synology.0               : synology              : MIBR-DS                                  -  enabled, port: 5001
                                      + system.adapter.telegram.0               : telegram              : MIBR-DS                                  -  enabled, port: 8443, bind: 0.0.0.0
                                      + system.adapter.telegram.1               : telegram              : MIBR-DS                                  -  enabled, port: 8443, bind: 0.0.0.0
                                      + system.adapter.text2command.0           : text2command          : MIBR-DS                                  -  enabled
                                      + system.adapter.unifi.0                  : unifi                 : MIBR-DS                                  -  enabled
                                      + system.adapter.viessmannapi.0           : viessmannapi          : MIBR-DS                                  -  enabled
                                      + system.adapter.web.0                    : web                   : MIBR-DS                                  -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                        system.adapter.yahka.0                  : yahka                 : MIBR-DS                                  - disabled
                                      + instance is alive
                                      ioBroker-Repositories
                                      Active repo(s): stable
                                      Installed ioBroker-Instances
                                      Used repository: stable
                                      Adapter    "admin"        : 6.12.0   , installed 6.12.0
                                      Adapter    "backitup"     : 2.8.7    , installed 2.8.7
                                      Adapter    "doorbird"     : 1.3.0    , installed 1.3.0
                                      Adapter    "e3dc-rscp"    : 1.2.5    , installed 1.2.5
                                      Adapter    "gruenbeck"    : 0.0.42   , installed 0.0.42
                                      Adapter    "hue"          : 3.10.1   , installed 3.10.1
                                      Adapter    "iot"          : 2.0.11   , installed 2.0.11
                                      Adapter    "javascript"   : 7.1.6    , installed 7.1.6
                                      Controller "js-controller": 5.0.16   , installed 5.0.16
                                      Adapter    "klf200"       : 1.1.2    , installed 1.1.2
                                      Adapter    "knx"          : 2.0.23   , installed 2.0.23
                                      Adapter    "lg-thinq"     : 0.1.4    , installed 0.1.4
                                      Adapter    "mihome-vacuum": 4.1.0    , installed 4.1.0
                                      Adapter    "mqtt-client"  : 1.7.0    , installed 1.7.0
                                      Adapter    "node-red"     : 4.0.3    , installed 4.0.3
                                      Adapter    "procon-ip"    : 1.5.1    , installed 1.5.1
                                      Adapter    "pvforecast"   : 2.9.0    , installed 2.9.0
                                      Adapter    "shelly"       : 6.6.1    , installed 6.6.1
                                      Adapter    "statistics"   : 2.4.0    , installed 2.4.0
                                      Adapter    "synology"     : 3.0.1    , installed 3.0.1
                                      Adapter    "telegram"     : 3.0.0    , installed 3.0.0
                                      Adapter    "text2command" : 3.0.2    , installed 3.0.2
                                      Adapter    "unifi"        : 0.6.6    , installed 0.6.6
                                      Adapter    "viessmannapi" : 2.3.0    , installed 2.3.0
                                      Adapter    "web"          : 6.1.10   , installed 6.1.10
                                      Adapter    "ws"           : 2.5.8    , installed 2.5.8
                                      Adapter    "yahka"        : 1.0.3    , installed 1.0.3
                                      Objects and States
                                      Objects:        32437
                                        mibr85 @mibr85 last edited by
                                        Wenn der Adapter normal läuft schreiben mir diese meldungen den Log voll, wie kann ich die meldungen interpretieren und vermeiden:
                                          @mibr85 die "NOT CONNECTED" Meldungen habe ich mit der aktuellsten KNX Adapter Version auch immer wieder einmal, allerdings nicht so sehr häufig. Die Instanz verbindet sich dann auch wieder und läuft weiter.
                                          Die zwei Meldungen im Log "Value received on unknown GA" bedeutet, dass auf diesem GA (7/1/12) etwas gesendet wurde, in deiner knx Instanz auf dem iob aber nicht bekannt sind. Hier evtl. das ETS Projekt noch einmal importieren und die Option aktivieren, dass nur die neuen GA übernommen werden.
                                          Dein Problem mit einem hängenden Prozess konnte ich bei mir allerdings bisher noch nie feststellen (iob auf Raspi 4B)
                                            Leider kommt es immer wieder dazu, dass sich der KNX Adapter, wie oben beschrieben aufhängt.
                                            Wie kann ich denn eine tiefere Diagnose durchführen um den Fehler zu finden?
                                            31.7k
                                            79.8k
                                            421
                                            69207
