    2. English
    3. ioBroker general
    4. Simple API Use SOLVED
    • UncleSam
      UncleSam Developer @ap2017 last edited by
      @ap2017 Can you please share a screenshot of your object tree in ioBroker where we can see the mentioned state (and its parents)?
        ap2017 @UncleSam last edited by
        @UncleSam Here the screenshot. Do I need to have subfolder variables in my URL?
        paul53 UncleSam 2 Replies Last reply Reply Quote 0
          paul53 @ap2017 last edited by paul53
          @ap2017
          URL: http://iobrokerip:8087/set/javascript.0.variables.PI-detection?value=true
          • UncleSam
            @ap2017 So, did you copy the state ID the way I asked you to?
            Because it seems to me that the name should be javascript.0.variables.PI-detection
            A 2 Replies Last reply Reply Quote 0
              ap2017 @UncleSam last edited by ap2017
              @UncleSam Thank you, with subfolder "variables" added I am getting browser response
              {"id":"javascript.0.variables.PI-detection","value":true,"val":true}
              Now I need to figure out how MotionEye notification work, since I PI-detection does not change in response to motion
                @UncleSam Everything works now. I did not realized that I have to reset the web hook variable after motion is detected.
                  tehMilcho @ap2017 last edited by
                  Hey there,
                  i got the same Error but little different problem. I have copyed the Object-Path with the little button.
                  so i build this URL:
                  http://SERVER:8087/set/0_userdata.0.VirtualDevices.hc3lite.FlurPIR-1?value=false&prettyPrint
                  The Url works fine in any browser but when i try to use it in my code i get:
                  "error: no value found for "0_userdata.0.VirtualDevices.hc3lite.FlurPIR-1". Use /set/id?value=1 or /set/id?value=1&wait=1000"
                  I will use it in a Lua Script that runs on the "Fibaro Home center lite". When i rebuild the URL to "toggle" it works fine.. i have no clue whats the issue .. because it makes no sense for me.
                  Lua Code:
                  local value = fibaro.getValue(52, "value")
                  local url
                  -- Deside if value should be true or false
                  if (fibaro.getValue(52, "value") == true) then
                  url = 'http://SERVER:8087/set/0_userdata.0.VirtualDevices.hc3lite.FlurPIR-1?value=true&prettyPrint'
                  elseif (fibaro.getValue(52, "value") == false) then
                  url = 'SERVER/set/0_userdata.0.VirtualDevices.hc3lite.FlurPIR-1?value=false&prettyPrint'
                  else
                  print ("No Match")
                  end
                  print(url)
                  local selfhttp = net.HTTPClient()
                  local headers = {
                          ["Accept"] = "application/json",
                          ["Content-Type"] = 'application/json',
                          ["Cache-Control"] = "no-cache"
                  selfhttp:request(url, {
                    options={
                      method = 'GET',
                      headers = headers,
                      timeout = 5000
                   success = function(response)
                              print(response.status)
                              print(response.data)
                      end,
                      error = function(message)
                              print("error:", message)
                      end
                  anyone knows something? i think i had the same issue by try to use something like this in Android App - Tasker, but then give out and used toggle.
                    MCU last edited by
                    @tehmilcho sagte in Simple API Use SOLVED:
                    Try to encode the URL
                    let encodedUrl = encodeURIComponent(url);
                      tehMilcho @MCU last edited by
                      @mcu said in Simple API Use SOLVED:
                      the Lua Script in Fibaro seems not happy about it:
                      [24.11.2023] [22:43:48] [ERROR] [SCENE29]: (load):15: syntax error near 'encodedUrl
                        MCU @tehMilcho last edited by
                        @tehmilcho In LUA seems to be
                        local encodedUrl = url.escape(url)
                          mhh seems like fibaro specail lua?
                          [24.11.2023] [22:54:25] [ERROR] [SCENE29]: (load):23: attempt to call a nil value (field 'escape')
                            @tehmilcho Do you use it so?
                            url = url.escape(url)
                              options={
                                method = 'GET',
                                headers = headers,
                                timeout = 5000
                              end,
                              end
                              @mcu yep this leads to "[24.11.2023] [22:54:25] [ERROR] [SCENE29]: (load):23: attempt to call a nil value (field 'escape')"
                                Try this
                                url = url:gsub("([^A-Za-z0-9_])", function(c) return string.format("%%%02X", string.byte(c)) end)
                                  then it seems to get stuck, no error but will not finsh and also the state in iobroker is not changed, when you Output the new string you will get:
                                  http%3A%2F%2F192%2E168%2E178%2E37%3A8087%2Fset%2F0_userdata%2E0%2EVirtualDevices%2Ehc3lite%2EFlurPIR%2D1%3Fvalue%3Dtrue%26prettyPrint
                                    tehMilcho @tehMilcho last edited by
                                    @MCU but this brings me on track, i now swap the "?" with "%3F" now it works .. damn @MCU you are f****** smart 🙂 Thanks a lot. spend already hours on this 🙂
                                    1.3k
                                    api simple api
                                    4110
