    2. English
    3. ioBroker general
    4. Simple API Use SOLVED
    • UncleSam
      UncleSam Developer @ap2017 last edited by
      @ap2017 So, did you copy the state ID the way I asked you to?
      Because it seems to me that the name should be javascript.0.variables.PI-detection
      A 2 Replies Last reply Reply Quote 0
        ap2017 @UncleSam last edited by ap2017
        @UncleSam Thank you, with subfolder "variables" added I am getting browser response
        {"id":"javascript.0.variables.PI-detection","value":true,"val":true}
        Now I need to figure out how MotionEye notification work, since I PI-detection does not change in response to motion
          @UncleSam Everything works now. I did not realized that I have to reset the web hook variable after motion is detected.
            tehMilcho @ap2017 last edited by
            Hey there,
            i got the same Error but little different problem. I have copyed the Object-Path with the little button.
            so i build this URL:
            http://SERVER:8087/set/0_userdata.0.VirtualDevices.hc3lite.FlurPIR-1?value=false&prettyPrint
            The Url works fine in any browser but when i try to use it in my code i get:
            "error: no value found for "0_userdata.0.VirtualDevices.hc3lite.FlurPIR-1". Use /set/id?value=1 or /set/id?value=1&wait=1000"
            I will use it in a Lua Script that runs on the "Fibaro Home center lite". When i rebuild the URL to "toggle" it works fine.. i have no clue whats the issue .. because it makes no sense for me.
            Lua Code:
            local value = fibaro.getValue(52, "value")
            local url
            -- Deside if value should be true or false
            if (fibaro.getValue(52, "value") == true) then
            url = 'http://SERVER:8087/set/0_userdata.0.VirtualDevices.hc3lite.FlurPIR-1?value=true&prettyPrint'
            elseif (fibaro.getValue(52, "value") == false) then
            url = 'SERVER/set/0_userdata.0.VirtualDevices.hc3lite.FlurPIR-1?value=false&prettyPrint'
            else
            print ("No Match")
            end
            print(url)
            local selfhttp = net.HTTPClient()
            local headers = {
                    ["Accept"] = "application/json",
                    ["Content-Type"] = 'application/json',
                    ["Cache-Control"] = "no-cache"
            selfhttp:request(url, {
              options={
                method = 'GET',
                headers = headers,
                timeout = 5000
             success = function(response)
                        print(response.status)
                        print(response.data)
                end,
                error = function(message)
                        print("error:", message)
                end
            anyone knows something? i think i had the same issue by try to use something like this in Android App - Tasker, but then give out and used toggle.
              MCU last edited by
              @tehmilcho sagte in Simple API Use SOLVED:
              Try to encode the URL
              let encodedUrl = encodeURIComponent(url);
                tehMilcho @MCU last edited by
                @mcu said in Simple API Use SOLVED:
                the Lua Script in Fibaro seems not happy about it:
                [24.11.2023] [22:43:48] [ERROR] [SCENE29]: (load):15: syntax error near 'encodedUrl
                  MCU @tehMilcho last edited by
                  @tehmilcho In LUA seems to be
                  local encodedUrl = url.escape(url)
                    mhh seems like fibaro specail lua?
                    [24.11.2023] [22:54:25] [ERROR] [SCENE29]: (load):23: attempt to call a nil value (field 'escape')
                      @tehmilcho Do you use it so?
                      url = url.escape(url)
                        options={
                          method = 'GET',
                          headers = headers,
                          timeout = 5000
                        end,
                        end
                        @mcu yep this leads to "[24.11.2023] [22:54:25] [ERROR] [SCENE29]: (load):23: attempt to call a nil value (field 'escape')"
                          Try this
                          url = url:gsub("([^A-Za-z0-9_])", function(c) return string.format("%%%02X", string.byte(c)) end)
                            then it seems to get stuck, no error but will not finsh and also the state in iobroker is not changed, when you Output the new string you will get:
                            http%3A%2F%2F192%2E168%2E178%2E37%3A8087%2Fset%2F0_userdata%2E0%2EVirtualDevices%2Ehc3lite%2EFlurPIR%2D1%3Fvalue%3Dtrue%26prettyPrint
                              tehMilcho @tehMilcho last edited by
                              @MCU but this brings me on track, i now swap the "?" with "%3F" now it works .. damn @MCU you are f****** smart 🙂 Thanks a lot. spend already hours on this 🙂
                              1.2k
                              api simple api
                              4110
