    2. English
    3. ioBroker general
    4. Simple API Use SOLVED
      ap2017 @UncleSam last edited by ap2017
      @UncleSam Thank you, with subfolder "variables" added I am getting browser response
      {"id":"javascript.0.variables.PI-detection","value":true,"val":true}
      Now I need to figure out how MotionEye notification work, since I PI-detection does not change in response to motion
        @UncleSam Everything works now. I did not realized that I have to reset the web hook variable after motion is detected.
          tehMilcho @ap2017 last edited by
          Hey there,
          i got the same Error but little different problem. I have copyed the Object-Path with the little button.
          so i build this URL:
          http://SERVER:8087/set/0_userdata.0.VirtualDevices.hc3lite.FlurPIR-1?value=false&prettyPrint
          The Url works fine in any browser but when i try to use it in my code i get:
          "error: no value found for "0_userdata.0.VirtualDevices.hc3lite.FlurPIR-1". Use /set/id?value=1 or /set/id?value=1&wait=1000"
          I will use it in a Lua Script that runs on the "Fibaro Home center lite". When i rebuild the URL to "toggle" it works fine.. i have no clue whats the issue .. because it makes no sense for me.
          Lua Code:
          local value = fibaro.getValue(52, "value")
          local url
          -- Deside if value should be true or false
          if (fibaro.getValue(52, "value") == true) then
          url = 'http://SERVER:8087/set/0_userdata.0.VirtualDevices.hc3lite.FlurPIR-1?value=true&prettyPrint'
          elseif (fibaro.getValue(52, "value") == false) then
          url = 'SERVER/set/0_userdata.0.VirtualDevices.hc3lite.FlurPIR-1?value=false&prettyPrint'
          else
          print ("No Match")
          end
          print(url)
          local selfhttp = net.HTTPClient()
          local headers = {
                  ["Accept"] = "application/json",
                  ["Content-Type"] = 'application/json',
                  ["Cache-Control"] = "no-cache"
          selfhttp:request(url, {
            options={
              method = 'GET',
              headers = headers,
              timeout = 5000
           success = function(response)
                      print(response.status)
                      print(response.data)
              end,
              error = function(message)
                      print("error:", message)
              end
          anyone knows something? i think i had the same issue by try to use something like this in Android App - Tasker, but then give out and used toggle.
            MCU last edited by
            @tehmilcho sagte in Simple API Use SOLVED:
            Try to encode the URL
            let encodedUrl = encodeURIComponent(url);
              tehMilcho @MCU last edited by
              @mcu said in Simple API Use SOLVED:
              the Lua Script in Fibaro seems not happy about it:
              [24.11.2023] [22:43:48] [ERROR] [SCENE29]: (load):15: syntax error near 'encodedUrl
                MCU @tehMilcho last edited by
                @tehmilcho In LUA seems to be
                local encodedUrl = url.escape(url)
                  mhh seems like fibaro specail lua?
                  [24.11.2023] [22:54:25] [ERROR] [SCENE29]: (load):23: attempt to call a nil value (field 'escape')
                    @tehmilcho Do you use it so?
                    url = url.escape(url)
                      options={
                        method = 'GET',
                        headers = headers,
                        timeout = 5000
                      end,
                      end
                      @mcu yep this leads to "[24.11.2023] [22:54:25] [ERROR] [SCENE29]: (load):23: attempt to call a nil value (field 'escape')"
                        Try this
                        url = url:gsub("([^A-Za-z0-9_])", function(c) return string.format("%%%02X", string.byte(c)) end)
                          then it seems to get stuck, no error but will not finsh and also the state in iobroker is not changed, when you Output the new string you will get:
                          http%3A%2F%2F192%2E168%2E178%2E37%3A8087%2Fset%2F0_userdata%2E0%2EVirtualDevices%2Ehc3lite%2EFlurPIR%2D1%3Fvalue%3Dtrue%26prettyPrint
                            tehMilcho @tehMilcho last edited by
                            @MCU but this brings me on track, i now swap the "?" with "%3F" now it works .. damn @MCU you are f****** smart 🙂 Thanks a lot. spend already hours on this 🙂
                            1.3k
                            api simple api
                            4110
