    4. Vis über npm gibt EHOSTUNREACH
      Christian 5 @Christian 5 last edited by
      @christian-5 nur leider bekomme ich noch immer kein VIS 1.5.1 auch nicht im beta Respositorie
      Latest: http://download.iobroker.net/sources-dist-latest.json
      Latest: http://repo.iobroker.live/sources-dist-latest.json
      http://iobroker.live/repo/sources-dist-latest.json
        Thomas Braun Most Active @Christian 5 last edited by
        @christian-5
        iob repo list
        iob update
        sagt?
          Christian 5 @Thomas Braun last edited by
          Skript v.2023-10-10
          *** BASE SYSTEM ***
           Static hostname: iobroker
                 Icon name: computer
                    Kernel: Linux 6.1.0-rpi6-rpi-v8
              Architecture: arm64
          Model           : Raspberry Pi 4 Model B Rev 1.5
          Docker          : false
          Virtualization  : none
          Kernel          : aarch64
          Userland        : arm64
          Systemuptime and Load:
           23:19:29 up 29 min,  2 users,  load average: 1.60, 1.45, 1.15
          CPU threads: 4
          *** RASPBERRY THROTTLING ***
          Current issues:
          Previously detected issues:
          *** Time and Time Zones ***
                         Local time: Fri 2023-11-24 23:19:29 CET
                     Universal time: Fri 2023-11-24 22:19:29 UTC
                           RTC time: n/a
                          Time zone: Europe/Vienna (CET, +0100)
                        NTP service: active
                    RTC in local TZ: no
          *** User and Groups ***
          Christian
          /home/Christian
          Christian adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
          *** X-Server-Setup ***
          X-Server:       false
          Desktop:
          Terminal:       tty
          Boot Target:    multi-user.target
          *** MEMORY ***
          Mem:            8.2G        1.0G        4.5G        1.2M        2.8G        7.2G
          Swap:           104M          0B        104M
          Total:          8.3G        1.0G        4.7G
                   7810 M total memory
                    971 M used memory
                   1069 M active memory
                   2097 M inactive memory
                   4336 M free memory
                     86 M buffer memory
                   2538 M swap cache
                     99 M total swap
                      0 M used swap
                     99 M free swap
          Raspberry only:
          oom events: 0
          *** FAILED SERVICES ***
          0 loaded units listed.
          *** FILESYSTEM ***
          udev           devtmpfs  3.6G     0  3.6G   0% /dev
          tmpfs          tmpfs     782M  1.2M  780M   1% /run
          /dev/sda2      ext4      117G  4.5G  107G   5% /
          tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
          /dev/sda1      vfat      510M   61M  450M  12% /boot/firmware
          tmpfs          tmpfs     782M     0  782M   0% /run/user/1000
          [Fri Nov 24 22:50:13 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:2A:25:6C vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=167ecb30-02 rootfstype=ext4 fsck.repair=yes rootwait
          [Fri Nov 24 22:50:16 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
          [Fri Nov 24 22:50:18 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
          TARGET           SOURCE    FSTYPE OPTIONS
          /                /dev/sda2 ext4   rw,noatime
          `-/boot/firmware /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
          /var:
          629M    /var/
          317M    /var/cache
          311M    /var/cache/apt
          200M    /var/cache/apt/archives
          163M    /var/lib
          Archived and active journals take up 48.2M in the file system.
          /opt/iobroker/backups:
          15M     /opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          455M    /opt/iobroker/iobroker-data/
          403M    /opt/iobroker/iobroker-data/files
          132M    /opt/iobroker/iobroker-data/files/vis-2
          81M     /opt/iobroker/iobroker-data/files/vis-2/static
          80M     /opt/iobroker/iobroker-data/files/vis-2/static/js
          51M     /opt/iobroker/iobroker-data/objects.jsonl
          21M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.0b890418.js.map
          19M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.da06e220.js.map
          19M     /opt/iobroker/iobroker-data/files/vis-2/customWidgets.js.map
          14M     /opt/iobroker/iobroker-data/files/vis-2/static/js/258.6829e51a.chunk.js.map
          USB-Devices by-id:
          *** NodeJS-Installation ***
          /usr/bin/nodejs         v18.17.1
          /usr/bin/node           v18.17.1
          /usr/bin/npm            9.6.7
          /usr/bin/npx            9.6.7
          /usr/bin/corepack       0.18.0
          nodejs:
            Installed: 18.17.1-deb-1nodesource1
            Candidate: 18.17.1-deb-1nodesource1
            Version table:
           *** 18.17.1-deb-1nodesource1 500
                  500 https://deb.nodesource.com/node_18.x bookworm/main arm64 Packages
                  100 /var/lib/dpkg/status
               18.13.0+dfsg1-1 500
          No problems detected
          Errors in npm tree:
          npm ERR! code ELSPROBLEMS
          npm ERR! extraneous: @types/minimist@ /opt/iobroker/node_modules/@types/minimist
          npm ERR! extraneous: @types/parse-json@ /opt/iobroker/node_modules/@types/parse-json
          npm ERR! extraneous: array-union@ /opt/iobroker/node_modules/array-union
          npm ERR! extraneous: arrify@ /opt/iobroker/node_modules/arrify
          npm ERR! extraneous: async-exit-hook@ /opt/iobroker/node_modules/async-exit-hook
          npm ERR! extraneous: camelcase-keys@ /opt/iobroker/node_modules/camelcase-keys
          npm ERR! extraneous: decamelize-keys@ /opt/iobroker/node_modules/decamelize-keys
          npm ERR! extraneous: duplexer3@ /opt/iobroker/node_modules/duplexer3
          npm ERR! extraneous: hard-rejection@ /opt/iobroker/node_modules/hard-rejection
          npm ERR! extraneous: iobroker.vis-inventwo@ /opt/iobroker/node_modules/iobroker.vis-inventwo
          npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/kind-of
          npm ERR! extraneous: map-age-cleaner@ /opt/iobroker/node_modules/map-age-cleaner
          npm ERR! extraneous: map-obj@ /opt/iobroker/node_modules/map-obj
          npm ERR! extraneous: min-indent@ /opt/iobroker/node_modules/min-indent
          npm ERR! extraneous: minimist-options@ /opt/iobroker/node_modules/minimist-options
          npm ERR! extraneous: p-defer@ /opt/iobroker/node_modules/p-defer
          npm ERR! extraneous: p-event@ /opt/iobroker/node_modules/p-event
          npm ERR! extraneous: p-finally@ /opt/iobroker/node_modules/p-finally
          npm ERR! extraneous: p-reflect@ /opt/iobroker/node_modules/p-reflect
          npm ERR! extraneous: p-settle@ /opt/iobroker/node_modules/p-settle
          npm ERR! extraneous: path-parse@ /opt/iobroker/node_modules/path-parse
          npm ERR! extraneous: prepend-http@ /opt/iobroker/node_modules/prepend-http
          npm ERR! extraneous: redent@ /opt/iobroker/node_modules/redent
          npm ERR! extraneous: resolve@ /opt/iobroker/node_modules/resolve
          npm ERR! extraneous: strip-indent@ /opt/iobroker/node_modules/strip-indent
          npm ERR! extraneous: supports-preserve-symlinks-flag@ /opt/iobroker/node_modules/supports-preserve-symlinks-flag
          npm ERR! extraneous: to-readable-stream@ /opt/iobroker/node_modules/to-readable-stream
          npm ERR! extraneous: trim-newlines@ /opt/iobroker/node_modules/trim-newlines
          npm ERR! extraneous: url-parse-lax@ /opt/iobroker/node_modules/url-parse-lax
          npm ERR! extraneous: yaml@ /opt/iobroker/node_modules/yaml
          npm ERR! extraneous: camelcase@5.3.1 /opt/iobroker/node_modules/camelcase-keys/node_modules/camelcase
          npm ERR! extraneous: quick-lru@4.0.1 /opt/iobroker/node_modules/camelcase-keys/node_modules/quick-lru
          npm ERR! extraneous: map-obj@1.0.1 /opt/iobroker/node_modules/decamelize-keys/node_modules/map-obj
          npm ERR! extraneous: @iobroker/adapter-core@2.6.8 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/@iobroker/adapter-core
          npm ERR! extraneous: @sindresorhus/is@ /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/@sindresorhus/is
          npm ERR! extraneous: @szmarczak/http-timer@4.0.6 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/@szmarczak/http-timer
          npm ERR! extraneous: aggregate-error@3.1.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/aggregate-error
          npm ERR! extraneous: any-observable@ /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/any-observable
          npm ERR! extraneous: boxen@5.1.2 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/boxen
          npm ERR! extraneous: brace-expansion@1.1.11 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/brace-expansion
          npm ERR! extraneous: cacheable-lookup@2.0.1 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/cacheable-lookup
          npm ERR! extraneous: cacheable-request@7.0.4 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/cacheable-request
          npm ERR! extraneous: callsites@3.1.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/callsites
          npm ERR! extraneous: camelcase@6.3.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/camelcase
          npm ERR! extraneous: chalk@4.1.2 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/chalk
          npm ERR! extraneous: ci-info@2.0.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/ci-info
          npm ERR! extraneous: clean-stack@2.2.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/clean-stack
          npm ERR! extraneous: cli-boxes@2.2.1 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/cli-boxes
          npm ERR! extraneous: cli-width@3.0.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/cli-width
          npm ERR! extraneous: configstore@5.0.1 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/configstore
          npm ERR! extraneous: cosmiconfig@ /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/cosmiconfig
          npm ERR! extraneous: crypto-random-string@2.0.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/crypto-random-string
          npm ERR! extraneous: decompress-response@5.0.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/decompress-response
          npm ERR! extraneous: del@ /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/del
          npm ERR! extraneous: dot-prop@6.0.1 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/dot-prop
          npm ERR! extraneous: escape-goat@ /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/escape-goat
          npm ERR! extraneous: escape-string-regexp@ /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/escape-string-regexp
          npm ERR! extraneous: figures@3.2.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/figures
          npm ERR! extraneous: get-stream@5.2.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/get-stream
          npm ERR! extraneous: global-dirs@2.1.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/global-dirs
          npm ERR! extraneous: globby@ /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/globby
          npm ERR! extraneous: got@ /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/got
          npm ERR! extraneous: has-yarn@2.1.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/has-yarn
          npm ERR! extraneous: hosted-git-info@ /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/hosted-git-info
          npm ERR! extraneous: ignore-walk@3.0.4 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/ignore-walk
          npm ERR! extraneous: import-lazy@2.1.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/import-lazy
          npm ERR! extraneous: indent-string@4.0.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/indent-string
          npm ERR! extraneous: ini@1.3.7 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/ini
          npm ERR! extraneous: inquirer@ /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/inquirer
          npm ERR! extraneous: is-ci@2.0.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/is-ci
          npm ERR! extraneous: is-docker@2.2.1 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/is-docker
          npm ERR! extraneous: is-installed-globally@0.3.2 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/is-installed-globally
          npm ERR! extraneous: is-interactive@1.0.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/is-interactive
          npm ERR! extraneous: is-npm@5.0.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/is-npm
          npm ERR! extraneous: is-path-cwd@2.2.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/is-path-cwd
          npm ERR! extraneous: is-path-inside@3.0.3 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/is-path-inside
          npm ERR! extraneous: is-scoped@2.1.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/is-scoped
          npm ERR! extraneous: is-unicode-supported@0.1.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/is-unicode-supported
          npm ERR! extraneous: is-url-superb@4.0.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/is-url-superb
          npm ERR! extraneous: is-yarn-global@0.3.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/is-yarn-global
          npm ERR! extraneous: issue-regex@3.1.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/issue-regex
          npm ERR! extraneous: json-buffer@3.0.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/json-buffer
          npm ERR! extraneous: latest-version@5.1.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/latest-version
          npm ERR! extraneous: locate-path@5.0.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/locate-path
          npm ERR! extraneous: log-symbols@4.1.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/log-symbols
          npm ERR! extraneous: lowercase-keys@2.0.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/lowercase-keys
          npm ERR! extraneous: meow@8.1.2 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/meow
          npm ERR! extraneous: mimic-fn@3.1.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/mimic-fn
          npm ERR! extraneous: mimic-response@2.1.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/mimic-response
          npm ERR! extraneous: minimatch@3.1.2 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/minimatch
          npm ERR! extraneous: new-github-release-url@1.0.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/new-github-release-url
          npm ERR! extraneous: normalize-url@6.1.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/normalize-url
          npm ERR! extraneous: np@ /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/np
          npm ERR! extraneous: npm-name@6.0.1 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/npm-name
          npm ERR! extraneous: open@ /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/open
          npm ERR! extraneous: ow@ /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/ow
          npm ERR! extraneous: p-cancelable@2.1.1 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/p-cancelable
          npm ERR! extraneous: p-limit@2.3.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/p-limit
          npm ERR! extraneous: p-locate@4.1.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/p-locate
          npm ERR! extraneous: p-map@4.0.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/p-map
          npm ERR! extraneous: p-memoize@4.0.4 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/p-memoize
          npm ERR! extraneous: p-timeout@4.1.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/p-timeout
          npm ERR! extraneous: package-json@6.5.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/package-json
          npm ERR! extraneous: path-exists@4.0.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/path-exists
          npm ERR! extraneous: pkg-dir@5.0.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/pkg-dir
          npm ERR! extraneous: pupa@2.1.1 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/pupa
          npm ERR! extraneous: read-pkg-up@7.0.1 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/read-pkg-up
          npm ERR! extraneous: read-pkg@5.2.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/read-pkg
          npm ERR! extraneous: registry-url@5.1.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/registry-url
          npm ERR! extraneous: responselike@2.0.1 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/responselike
          npm ERR! extraneous: run-async@2.4.1 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/run-async
          npm ERR! extraneous: rxjs@ /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/rxjs
          npm ERR! extraneous: scoped-regex@2.1.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/scoped-regex
          npm ERR! extraneous: semver-diff@3.1.1 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/semver-diff
          npm ERR! extraneous: slash@3.0.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/slash
          npm ERR! extraneous: symbol-observable@ /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/symbol-observable
          npm ERR! extraneous: terminal-link@2.1.1 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/terminal-link
          npm ERR! extraneous: tslib@1.14.1 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/tslib
          npm ERR! extraneous: type-fest@0.18.1 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/type-fest
          npm ERR! extraneous: unique-string@2.0.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/unique-string
          npm ERR! extraneous: update-notifier@ /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/update-notifier
          npm ERR! extraneous: widest-line@3.1.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/widest-line
          npm ERR! extraneous: xdg-basedir@4.0.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/xdg-basedir
          npm ERR! invalid: yargs-parser@ /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/yargs-parser
          npm ERR! extraneous: yargs-parser@ /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/yargs-parser
          npm ERR! extraneous: is-plain-obj@1.1.0 /opt/iobroker/node_modules/minimist-options/node_modules/is-plain-obj
          npm ERR! extraneous: p-timeout@3.2.0 /opt/iobroker/node_modules/p-event/node_modules/p-timeout
          npm ERR! extraneous: p-limit@2.3.0 /opt/iobroker/node_modules/p-settle/node_modules/p-limit
          npm ERR! extraneous: indent-string@4.0.0 /opt/iobroker/node_modules/redent/node_modules/indent-string
          npm ERR! extraneous: type-fest@0.20.2 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/boxen/node_modules/type-fest
          npm ERR! extraneous: dot-prop@5.3.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/configstore/node_modules/dot-prop
          npm ERR! extraneous: escape-string-regexp@1.0.5 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/figures/node_modules/escape-string-regexp
          npm ERR! extraneous: type-fest@0.10.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/got/node_modules/type-fest
          npm ERR! invalid: @types/minimist@ /opt/iobroker/node_modules/@types/minimist
          npm ERR! invalid: camelcase-keys@ /opt/iobroker/node_modules/camelcase-keys
          npm ERR! invalid: decamelize-keys@ /opt/iobroker/node_modules/decamelize-keys
          npm ERR! invalid: hard-rejection@ /opt/iobroker/node_modules/hard-rejection
          npm ERR! invalid: minimist-options@ /opt/iobroker/node_modules/minimist-options
          npm ERR! invalid: redent@ /opt/iobroker/node_modules/redent
          npm ERR! invalid: trim-newlines@ /opt/iobroker/node_modules/trim-newlines
          npm ERR! extraneous: type-fest@0.4.1 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/new-github-release-url/node_modules/type-fest
          npm ERR! invalid: got@ /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/got
          npm ERR! extraneous: p-map@3.0.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/npm-name/node_modules/p-map
          npm ERR! extraneous: @sindresorhus/is@4.6.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/ow/node_modules/@sindresorhus/is
          npm ERR! extraneous: type-fest@0.20.2 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/ow/node_modules/type-fest
          npm ERR! invalid: map-age-cleaner@ /opt/iobroker/node_modules/map-age-cleaner
          npm ERR! invalid: p-settle@ /opt/iobroker/node_modules/p-settle
          npm ERR! extraneous: @sindresorhus/is@0.14.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/package-json/node_modules/@sindresorhus/is
          npm ERR! extraneous: @szmarczak/http-timer@1.1.2 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/package-json/node_modules/@szmarczak/http-timer
          npm ERR! extraneous: cacheable-request@6.1.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/package-json/node_modules/cacheable-request
          npm ERR! extraneous: decompress-response@3.3.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/package-json/node_modules/decompress-response
          npm ERR! extraneous: defer-to-connect@1.1.3 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/package-json/node_modules/defer-to-connect
          npm ERR! extraneous: got@9.6.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/package-json/node_modules/got
          npm ERR! extraneous: keyv@3.1.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/package-json/node_modules/keyv
          npm ERR! extraneous: mimic-response@1.0.1 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/package-json/node_modules/mimic-response
          npm ERR! extraneous: normalize-url@4.5.1 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/package-json/node_modules/normalize-url
          npm ERR! extraneous: p-cancelable@1.1.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/package-json/node_modules/p-cancelable
          npm ERR! extraneous: responselike@1.0.2 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/package-json/node_modules/responselike
          npm ERR! extraneous: semver@6.3.1 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/package-json/node_modules/semver
          npm ERR! extraneous: to-readable-stream@1.0.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/package-json/node_modules/to-readable-stream
          npm ERR! extraneous: escape-goat@2.1.1 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/pupa/node_modules/escape-goat
          npm ERR! extraneous: find-up@4.1.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/read-pkg-up/node_modules/find-up
          npm ERR! extraneous: type-fest@0.8.1 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/read-pkg-up/node_modules/type-fest
          npm ERR! extraneous: hosted-git-info@2.8.9 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/read-pkg/node_modules/hosted-git-info
          npm ERR! extraneous: normalize-package-data@2.5.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/read-pkg/node_modules/normalize-package-data
          npm ERR! extraneous: semver@5.7.2 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/read-pkg/node_modules/semver
          npm ERR! extraneous: type-fest@0.6.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/read-pkg/node_modules/type-fest
          npm ERR! extraneous: semver@6.3.1 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/semver-diff/node_modules/semver
          npm ERR! extraneous: global-dirs@3.0.1 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/update-notifier/node_modules/global-dirs
          npm ERR! extraneous: ini@2.0.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/update-notifier/node_modules/ini
          npm ERR! extraneous: is-installed-globally@0.4.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/update-notifier/node_modules/is-installed-globally
          npm ERR! invalid: p-finally@ /opt/iobroker/node_modules/p-finally
          npm ERR! invalid: fsevents@ /opt/iobroker/node_modules/fsevents
          npm ERR! invalid: duplexer3@ /opt/iobroker/node_modules/duplexer3
          npm ERR! extraneous: get-stream@4.1.0 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/package-json/node_modules/got/node_modules/get-stream
          npm ERR! extraneous: lowercase-keys@1.0.1 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/package-json/node_modules/got/node_modules/lowercase-keys
          npm ERR! invalid: url-parse-lax@ /opt/iobroker/node_modules/url-parse-lax
          npm ERR! extraneous: lowercase-keys@1.0.1 /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/package-json/node_modules/responselike/node_modules/lowercase-keys
          npm ERR! invalid: resolve@ /opt/iobroker/node_modules/resolve
          npm ERR! A complete log of this run can be found in: /home/Christian/.npm/_logs/2023-11-24T22_19_36_820Z-debug-0.log
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Core adapters versions
          js-controller:  5.0.16
          admin:          6.12.0
          javascript:     7.1.4
          Adapters from github:   2
          Adapter State
          + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
            system.adapter.alexa2.0                 : alexa2                : iobroker                                 - disabled
          + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
            system.adapter.bydhvs.0                 : bydhvs                : iobroker                                 - disabled
            system.adapter.cloud.0                  : cloud                 : iobroker                                 - disabled
            system.adapter.device-reminder.0        : device-reminder       : iobroker                                 - disabled
            system.adapter.discovery.0              : discovery             : iobroker                                 - disabled
            system.adapter.email.0                  : email                 : iobroker                                 - disabled
            system.adapter.energiefluss.0           : energiefluss          : iobroker                                 - disabled
            system.adapter.fronius-solarweb.0       : fronius-solarweb      : iobroker                                 - disabled
            system.adapter.fronius.0                : fronius               : iobroker                                 -  enabled
            system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 - disabled
            system.adapter.hs100.0                  : hs100                 : iobroker                                 - disabled
            system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: iobroker                                 - disabled
            system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : iobroker                                 - disabled
            system.adapter.icons-icons8.0           : icons-icons8          : iobroker                                 - disabled
            system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 - disabled
            system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 - disabled
            system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker                                 - disabled
            system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iobroker                                 - disabled
            system.adapter.influxdb.0               : influxdb              : iobroker                                 - disabled, port: 8086
            system.adapter.javascript.0             : javascript            : iobroker                                 - disabled
            system.adapter.linkeddevices.0          : linkeddevices         : iobroker                                 - disabled
            system.adapter.modbus.0                 : modbus                : iobroker                                 - disabled
            system.adapter.modbus.1                 : modbus                : iobroker                                 - disabled
            system.adapter.moma.0                   : moma                  : iobroker                                 - disabled
            system.adapter.mqtt.0                   : mqtt                  : iobroker                                 - disabled, port: 1883, bind: 0.0.0.0
            system.adapter.rpi2.0                   : rpi2                  : iobroker                                 - disabled
            system.adapter.sainlogic.0              : sainlogic             : iobroker                                 - disabled, port: 4500, bind: 0.0.0.0
            system.adapter.shelly.0                 : shelly                : iobroker                                 - disabled, port: 1882, bind: 0.0.0.0
            system.adapter.shelly.1                 : shelly                : iobroker                                 - disabled, port: 1882, bind: 0.0.0.0
            system.adapter.sonoff.0                 : sonoff                : iobroker                                 - disabled, port: 1885, bind: 0.0.0.0
            system.adapter.synology.0               : synology              : iobroker                                 - disabled, port: 5000
            system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: iobroker                                 - disabled
            system.adapter.vis-2.0                  : vis-2                 : iobroker                                 - disabled
            system.adapter.vis-bars.0               : vis-bars              : iobroker                                 - disabled
            system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 - disabled
            system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker                                 - disabled
            system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
            system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 - disabled
            system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 - disabled
            system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 - disabled
            system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 - disabled
            system.adapter.vis-material-advanced.0  : vis-material-advanced : iobroker                                 - disabled
            system.adapter.vis-metro.0              : vis-metro             : iobroker                                 - disabled
            system.adapter.vis-rgraph.0             : vis-rgraph            : iobroker                                 - disabled
            system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
            system.adapter.vis-weather.0            : vis-weather           : iobroker                                 - disabled
            system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
            system.adapter.web.0                    : web                   : iobroker                                 - disabled, port: 8082, bind: 0.0.0.0, run as: admin
          + instance is alive
          ioBroker-Repositories
          beta          : http://iobroker.live/repo/sources-dist-latest.json
          Active repo(s): beta
          Installed ioBroker-Instances
          Used repository: beta
          Adapter    "admin"        : 6.12.5   , installed 6.12.0 [Updatable]
          Adapter    "alexa2"       : 3.26.2   , installed 3.26.1 [Updatable]
          Adapter    "backitup"     : 2.9.4    , installed 2.8.7  [Updatable]
          Adapter    "bydhvs"       : 1.5.0    , installed 1.4.0  [Updatable]
          Adapter    "device-reminder": 3.0.0  , installed 3.0.0
          Adapter    "email"        : 1.2.0    , installed 1.2.0
          Adapter    "fronius"      : 2.0.2    , installed 2.0.2
          Adapter    "fronius-solarweb": 0.0.3 , installed 0.0.3
          Adapter    "fullybrowser" : 3.0.7    , installed 3.0.6  [Updatable]
          Adapter    "hs100"        : 2.2.0    , installed 2.2.0
          Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
          Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.3
          Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
          Adapter    "javascript"   : 7.1.6    , installed 7.1.4  [Updatable]
          Controller "js-controller": 5.0.16   , installed 5.0.16
          Adapter    "linkeddevices": 1.5.5    , installed 1.5.5
          Adapter    "modbus"       : 6.0.1    , installed 5.0.11 [Updatable]
          Adapter    "moma"         : 1.2.9    , installed 1.2.9
          Adapter    "mqtt"         : 5.1.0    , installed 5.1.0
          Adapter    "sainlogic"    : 0.10.5   , installed 0.10.5
          Adapter    "shelly"       : 6.6.1    , installed 6.6.1
          Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
          Adapter    "synology"     : 3.0.1    , installed 3.0.1
          Adapter    "vis-2"        : 2.8.0    , installed 2.3.5  [Updatable]
          Adapter    "vis-2-widgets-material": 1.3.11, installed 1.3.3 [Updatable]
          Adapter    "vis-icontwo"  : 0.97.3   , installed 0.96.0 [Updatable]
          Objects and States
          Objects:        10202
          States:         7978
          Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
          Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
          Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
          Hit:5 https://deb.nodesource.com/node_18.x bookworm InRelease
          Reading package lists...
          Pending Updates: 0
          *** Listening Ports ***
          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       16667      1053/iobroker.js-co
          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       16660      1053/iobroker.js-co
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14610      694/sshd: /usr/sbin
          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       14987      1081/io.admin.0
          tcp6       0      0 :::22                   :::*                    LISTEN      0          14612      694/sshd: /usr/sbin
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        14505      554/avahi-daemon: r
          udp        0      0 0.0.0.0:42398           0.0.0.0:*                           104        14507      554/avahi-daemon: r
          udp6       0      0 :::36421                :::*                                104        14508      554/avahi-daemon: r
          udp6       0      0 fe80::6309:a8e9:9c6:546 :::*                                0          12075      628/NetworkManager
          udp6       0      0 :::5353                 :::*                                104        14506      554/avahi-daemon: r
          2023-11-24 23:20:15.356  - info: host.iobroker iobroker npm-install: Installing iobroker.vis-justgage@2.0.0... (System call)
          2023-11-24 23:20:30.425  - info: host.iobroker iobroker npm-install: added 1 package in 14s244 packages are looking for funding  run `npm fund` for detailshost.iobroker install adapter vis-justgage@2.0.0
          2023-11-24 23:20:30.542  - info: host.iobroker iobroker npm-install: upload [2] vis-justgage.admin /opt/iobroker/node_modules/iobroker.vis-justgage/admin/index.html index.html text/html
          2023-11-24 23:20:30.567  - info: host.iobroker iobroker npm-install: upload [1] vis-justgage.admin /opt/iobroker/node_modules/iobroker.vis-justgage/admin/index_m.html index_m.html text/html
          2023-11-24 23:20:30.578  - info: host.iobroker iobroker npm-install: upload [0] vis-justgage.admin /opt/iobroker/node_modules/iobroker.vis-justgage/admin/justgage.png justgage.png image/png
          2023-11-24 23:20:30.590  - info: host.iobroker iobroker npm-install: INFO: Directory "/opt/iobroker/node_modules/iobroker.vis-justgage/www" was not found! Nothing was uploaded or deleted.
          2023-11-24 23:20:30.660  - info: host.iobroker "system.adapter.vis.0" disabled
          2023-11-24 23:20:30.728  - info: host.iobroker "system.adapter.vis.0" enabled
          2023-11-24 23:20:30.734  - info: host.iobroker iobroker npm-install: Adapter "system.adapter.vis.0" restarted.
          2023-11-24 23:20:30.894  - info: host.iobroker iobroker npm-install: host.iobroker object system.adapter.vis-justgage created/updated
          2023-11-24 23:20:32.004  - info: host.iobroker iobroker npm-install: exit 0
          2023-11-24 23:20:33.005  - warn: host.iobroker startInstance cannot find adapter "vis-material-advanced@1.7.4". Try to install it... 1 attempt
          2023-11-24 23:20:33.005  - info: host.iobroker iobroker install vis-material-advanced@1.7.4 using installedFrom
          2023-11-24 23:20:37.173  - info: host.iobroker iobroker npm-install: NPM version: 9.6.7
          2023-11-24 23:20:37.178  - info: host.iobroker iobroker npm-install: Installing iobroker.vis-material-advanced@1.7.4... (System call)
          2023-11-24 23:20:50.739  - info: host.iobroker iobroker npm-install: added 1 package in 13s
          2023-11-24 23:20:50.740  - info: host.iobroker iobroker npm-install: 244 packages are looking for funding  run `npm fund` for details
          2023-11-24 23:20:50.791  - info: host.iobroker iobroker npm-install: host.iobroker install adapter vis-material-advanced@1.7.4
          2023-11-24 23:20:51.106  - info: host.iobroker iobroker npm-install: upload [1] vis-material-advanced.admin /opt/iobroker/node_modules/iobroker.vis-material-advanced/admin/vis-material-advanced.png vis-material-advanced.png image/png
          2023-11-24 23:20:51.136  - info: host.iobroker iobroker npm-install: upload [0] vis-material-advanced.admin /opt/iobroker/node_modules/iobroker.vis-material-advanced/admin/words.js words.js application/javascript
          2023-11-24 23:20:51.151  - info: host.iobroker iobroker npm-install: INFO: Directory "/opt/iobroker/node_modules/iobroker.vis-material-advanced/www" was not found! Nothing was uploaded or deleted.
          2023-11-24 23:20:51.214  - info: host.iobroker "system.adapter.vis.0" disabled
          2023-11-24 23:20:51.226  - info: host.iobroker "system.adapter.vis.0" enabled
          2023-11-24 23:20:51.335  - info: host.iobroker iobroker npm-install: Adapter "system.adapter.vis.0" restarted.
          2023-11-24 23:20:51.552  - info: host.iobroker iobroker npm-install: host.iobroker object system.adapter.vis-material-advanced created/updated
            @christian-5
            iob nodejs-update
              Thomas Braun Most Active @Christian 5 last edited by Thomas Braun
              @christian-5 sagte in Vis über npm gibt EHOSTUNREACH:
              Installier den iobroker.vis-inventwo nochmal neu.
              Dann die ganzen Adapter auf Stand bringen.
              C 2 Replies Last reply Reply Quote 0
                @thomas-braun Besten Dank, scheint jetzt zu funktionieren. SUUUPER Gute Nacht!!
                  @christian-5
                  iob diag
                  sagt?
                    inventwo Icon Set
                    inventwo Design Widgets
                    beide deinstallieren und dann neu..
                      @thomas-braun sagte in Vis über npm gibt EHOSTUNREACH:
                      iob diag
                      alles grün
                      Skript v.2023-10-10
                      *** BASE SYSTEM ***
                             Icon name: computer
                          Architecture: arm64
                      Docker          : false
                      Kernel          : aarch64
                      Userland        : arm64
                       23:36:54 up 46 min,  2 users,  load average: 0.26, 0.33, 0.69
                      CPU threads: 4
                      Current issues:
                                     Local time: Fri 2023-11-24 23:36:54 CET
                                 Universal time: Fri 2023-11-24 22:36:54 UTC
                                       RTC time: n/a
                                    NTP service: active
                                RTC in local TZ: no
                      Christian
                      /home/Christian
                      X-Server:       false
                      Desktop:
                      Terminal:       tty
                      *** MEMORY ***
                      Mem:            8.2G        752M        4.3G        1.2M        3.2G        7.4G
                      Swap:           104M          0B        104M
                      Total:          8.3G        752M        4.4G
                               7810 M total memory
                                717 M used memory
                                737 M active memory
                               2585 M inactive memory
                               4116 M free memory
                                146 M buffer memory
                               2952 M swap cache
                                 99 M total swap
                                  0 M used swap
                                 99 M free swap
                      Raspberry only:
                      oom events: 0
                      *** FILESYSTEM ***
                      /dev/sda2      ext4      117G  4.8G  107G   5% /
                      /var:
                      656M    /var/
                      345M    /var/cache
                      339M    /var/cache/apt
                      227M    /var/cache/apt/archives
                      163M    /var/lib
                      516M    /opt/iobroker/iobroker-data/
                      455M    /opt/iobroker/iobroker-data/files
                      59M     /opt/iobroker/iobroker-data/objects.jsonl
                      21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
                      USB-Devices by-id:
                      /usr/bin/nodejs         v18.18.2
                      /usr/bin/node           v18.18.2
                      /usr/bin/npm            9.8.1
                      /usr/bin/npx            9.8.1
                      /usr/bin/corepack       0.19.0
                      nodejs:
                        Installed: 18.18.2-1nodesource1
                        Candidate: 18.18.2-1nodesource1
                        Version table:
                       *** 18.18.2-1nodesource1 1001
                           18.18.1-1nodesource1 1001
                           18.18.0-1nodesource1 1001
                           18.17.1-1nodesource1 1001
                           18.17.0-1nodesource1 1001
                           18.16.1-1nodesource1 1001
                           18.16.0-1nodesource1 1001
                           18.15.0-1nodesource1 1001
                           18.14.2-1nodesource1 1001
                           18.14.1-1nodesource1 1001
                           18.14.0-1nodesource1 1001
                           18.13.0+dfsg1-1 500
                           18.13.0-1nodesource1 1001
                           18.12.0-1nodesource1 1001
                           18.11.0-1nodesource1 1001
                           18.10.0-1nodesource1 1001
                           18.9.1-1nodesource1 1001
                           18.9.0-1nodesource1 1001
                           18.8.0-1nodesource1 1001
                           18.7.0-1nodesource1 1001
                           18.6.0-1nodesource1 1001
                           18.5.0-1nodesource1 1001
                           18.4.0-1nodesource1 1001
                           18.3.0-1nodesource1 1001
                           18.2.0-1nodesource1 1001
                           18.1.0-1nodesource1 1001
                           18.0.0-1nodesource1 1001
                      Errors in npm tree:
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      admin:          6.12.0
                      javascript:     7.1.4
                      Adapter State
                      + system.adapter.fronius.0                : fronius               : iobroker                                 -  enabled
                      + instance is alive
                      Adapter    "vis"          : 1.5.1    , installed 1.4.16 [Updatable]
                      Adapter    "vis-justgage" : 2.0.1    , installed 2.0.0  [Updatable]
                      Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
                      Adapter    "web"          : 6.1.10   , installed 6.1.10
                      Adapter    "ws"           : 2.5.8    , installed 2.5.8
                      Objects and States
                      Objects:        10202
                      States:         7988
                      Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
                      Pending Updates: 0
                      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       32280      6971/iobroker.js-co
                      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       31547      6971/iobroker.js-co
                      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       33209      6992/io.admin.0
                      2023-11-24 23:29:21.578  - info: host.iobroker Delete state "system.host.iobroker.versions.npmNewestNext"
                      2023-11-24 23:29:21.585  - info: host.iobroker Some obsolete host states deleted.
                      2023-11-24 23:29:24.288  - info: admin.0 (6992) starting. Version 6.12.0 in /opt/iobroker/node_modules/iobroker.admin, node: v18.18.2, js-controller: 5.0.16
                      2023-11-24 23:29:24.346  - info: admin.0 (6992) requesting all objects
                      2023-11-24 23:29:26.579  - info: admin.0 (6992) received all objects
                      2023-11-24 23:29:26.732  - info: host.iobroker instance system.adapter.backitup.0 started with pid 7014
                      2023-11-24 23:29:27.345  - info: admin.0 (6992) socket.io server listening on port 8081
                      2023-11-24 23:29:27.351  - info: admin.0 (6992) http server listening on port 8081
                      2023-11-24 23:29:27.352  - info: admin.0 (6992) Use link "http://127.0.0.1:8081" to configure.
                      2023-11-24 23:29:29.180  - info: backitup.0 (7014) starting. Version 2.8.7 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.18.2, js-controller: 5.0.16
                      2023-11-24 23:29:29.258  - info: backitup.0 (7014) [iobroker] backup will be activated at 02:40 every 2 day(s)
                      2023-11-24 23:29:29.374  - info: host.iobroker instance system.adapter.fronius.0 started with pid 7034
                      2023-11-24 23:29:31.508  - info: fronius.0 (7034) starting. Version 2.0.2 in /opt/iobroker/node_modules/iobroker.fronius, node: v18.18.2, js-controller: 5.0.16
                      2023-11-24 23:29:35.372  - info: vis.0 (7057) starting. Version 1.4.16 in /opt/iobroker/node_modules/iobroker.vis, node: v18.18.2, js-controller: 5.0.16
                      2023-11-24 23:29:35.716  - info: vis.0 (7057) vis license is OK.
                      2023-11-24 23:29:36.727  - info: vis.0 (7057) Changes in index.html detected => update cache.manifest
                      2023-11-24 23:29:36.751  - info: vis.0 (7057) Upload vis anew, while changes detected...
                      2023-11-24 23:29:37.042  - info: admin.0 (6992) ==> Connected system.user.admin from ::ffff:10.0.0.13
                      2023-11-24 23:29:40.228  - info: host.iobroker "system.adapter.vis.0" disabled
                      2023-11-24 23:29:40.230  - info: host.iobroker stopInstance system.adapter.vis.0 (force=false, process=true)
                      2023-11-24 23:29:40.241  - info: host.iobroker "system.adapter.vis.0" enabled
                      2023-11-24 23:29:40.242  - info: host.iobroker stopInstance system.adapter.vis.0 (force=false, process=true)
                      2023-11-24 23:30:00.184  - info: vis.0 (7057) Uploaded. 0
                      2023-11-24 23:30:00.699  - info: vis.0 (7057) Terminated (NO_ERROR): Without reason
                      2023-11-24 23:30:01.357  - info: host.iobroker instance system.adapter.vis.0 terminated while should be started once
                        Da isser doch.
                        3022
