    4. Backup Größe ioBroker
    • I
      IceD112 @Thomas Braun last edited by
      ☺ Was meinst du mit ordenlich?
      • I
        IceD112 last edited by
        Skript v.2023-10-10
        *** BASE SYSTEM ***
           Static hostname: ioBroker
                 Icon name: computer
          Operating System: Raspbian GNU/Linux 11 (bullseye)
                    Kernel: Linux 6.1.21-v8+
              Architecture: arm64
        Model           : Raspberry Pi 4 Model B Rev 1.4
        Docker          : false
        Virtualization  : none
        Kernel          : aarch64
        Userland        : armhf
        Systemuptime and Load:
         16:24:58 up 20 min,  2 users,  load average: 1.68, 2.09, 1.90
        CPU threads: 4
        *** RASPBERRY THROTTLING ***
        Current issues:
        Previously detected issues:
        *** Time and Time Zones ***
                       Local time: Fri 2023-11-24 16:24:59 CET
                   Universal time: Fri 2023-11-24 15:24:59 UTC
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        *** User and Groups ***
        pi
        /home/pi
        pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
        *** X-Server-Setup ***
        X-Server:       false
        Desktop:
        Terminal:       tty
        Boot Target:    multi-user.target
        *** MEMORY ***
        Mem:            1.8G        1.5G        239M        0.0K        133M        307M
        Swap:            99M         80M         19M
        Total:          1.9G        1.6G        258M
                 1849 M total memory
                 1477 M used memory
                  533 M active memory
                  945 M inactive memory
                  238 M free memory
                    5 M buffer memory
                  127 M swap cache
                   99 M total swap
                   80 M used swap
                   19 M free swap
        Raspberry only:
        oom events: 0
        *** FAILED SERVICES ***
        0 loaded units listed.
        *** FILESYSTEM ***
        /dev/root      ext4       29G  7.6G   21G  28% /
        devtmpfs       devtmpfs  667M     0  667M   0% /dev
        tmpfs          tmpfs     925M     0  925M   0% /dev/shm
        tmpfs          tmpfs     370M  828K  370M   1% /run
        /dev/mmcblk0p1 vfat      253M   51M  202M  20% /boot
        tmpfs          tmpfs     185M     0  185M   0% /run/user/1000
        [Fri Nov 24 16:04:31 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:CF:73:10 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=f85227ed-02 rootfstype=ext4 fsck.repair=yes rootwait
        [Fri Nov 24 16:04:32 2023] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
        [Fri Nov 24 16:04:32 2023] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
        [Fri Nov 24 16:04:33 2023] EXT4-fs (mmcblk0p2): recovery complete
        [Fri Nov 24 16:04:33 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
        [Fri Nov 24 16:04:33 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
        [Fri Nov 24 16:04:35 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
        TARGET  SOURCE         FSTYPE OPTIONS
        /       /dev/mmcblk0p2 ext4   rw,noatime
        `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
        /var:
        3.5G    /var/
        2.9G    /var/log/journal/25070aeb79f44c94a7f7bcc85e4ba968
        2.9G    /var/log
        387M    /var/cache
        Archived and active journals take up 2.8G in the file system.
        /opt/iobroker/backups:
        74M     /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        737M    /opt/iobroker/iobroker-data/
        316M    /opt/iobroker/iobroker-data/files
        274M    /opt/iobroker/iobroker-data/backup-objects
        74M     /opt/iobroker/iobroker-data/files/vis.0
        67M     /opt/iobroker/iobroker-data/files/javascript.admin
        119M    /opt/iobroker/iobroker-data/states.jsonl
        29M     /opt/iobroker/iobroker-data/objects.jsonl
        21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
        8.9M    /opt/iobroker/iobroker-data/files/scenes.admin/static/js/2.7de3299d.chunk.js.map
        8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js
        USB-Devices by-id:
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v18.18.2
        /usr/bin/node           v18.18.2
        /usr/bin/npm            9.8.1
        /usr/bin/npx            9.8.1
        /usr/bin/corepack       0.19.0
        nodejs:
          Installed: 18.18.2-1nodesource1
          Candidate: 18.18.2-1nodesource1
          Version table:
         *** 18.18.2-1nodesource1 1001
                500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
                100 /var/lib/dpkg/status
             18.18.1-1nodesource1 1001
             18.18.0-1nodesource1 1001
             18.17.1-1nodesource1 1001
             18.17.0-1nodesource1 1001
             18.16.1-1nodesource1 1001
             18.16.0-1nodesource1 1001
             18.15.0-1nodesource1 1001
             18.14.2-1nodesource1 1001
             18.14.1-1nodesource1 1001
             18.14.0-1nodesource1 1001
             18.13.0-1nodesource1 1001
             18.12.0-1nodesource1 1001
             18.11.0-1nodesource1 1001
             18.10.0-1nodesource1 1001
             18.9.1-1nodesource1 1001
             18.9.0-1nodesource1 1001
             18.8.0-1nodesource1 1001
             18.7.0-1nodesource1 1001
             18.6.0-1nodesource1 1001
             18.5.0-1nodesource1 1001
             18.4.0-1nodesource1 1001
             18.3.0-1nodesource1 1001
             18.2.0-1nodesource1 1001
             18.1.0-1nodesource1 1001
             18.0.0-1nodesource1 1001
             12.22.12~dfsg-1~deb11u4 500
                500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
        No problems detected
        Errors in npm tree:
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Core adapters versions
        js-controller:  5.0.16
        admin:          6.12.4
        javascript:     7.1.6
        Adapters from github:   1
        Adapter State
        + system.adapter.accuweather.0            : accuweather           : ioBroker                                 -  enabled
        + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.alexa2.0                 : alexa2                : ioBroker                                 -  enabled
        + system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
        + system.adapter.bring.0                  : bring                 : ioBroker                                 -  enabled
          system.adapter.daswetter.0              : daswetter             : ioBroker                                 -  enabled
        + system.adapter.denon.0                  : denon                 : ioBroker                                 -  enabled
          system.adapter.dwd.0                    : dwd                   : ioBroker                                 -  enabled
        + system.adapter.energiefluss.1           : energiefluss          : ioBroker                                 -  enabled
        + system.adapter.fb-checkpresence.0       : fb-checkpresence      : ioBroker                                 -  enabled
        + system.adapter.followthesun.0           : followthesun          : ioBroker                                 -  enabled
        + system.adapter.fronius-solarweb.0       : fronius-solarweb      : ioBroker                                 -  enabled
        + system.adapter.ham.0                    : ham                   : ioBroker                                 -  enabled
        + system.adapter.harmony.0                : harmony               : ioBroker                                 -  enabled
        + system.adapter.heos.0                   : heos                  : ioBroker                                 -  enabled
        + system.adapter.hue-extended.0           : hue-extended          : ioBroker                                 -  enabled
        + system.adapter.hue.0                    : hue                   : ioBroker                                 -  enabled, port: 443
          system.adapter.ical.0                   : ical                  : ioBroker                                 -  enabled
          system.adapter.icons-icons8.0           : icons-icons8          : ioBroker                                 - disabled
          system.adapter.icons-material-png.0     : icons-material-png    : ioBroker                                 - disabled
          system.adapter.icons-mfd-png.0          : icons-mfd-png         : ioBroker                                 - disabled
          system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : ioBroker                                 - disabled
        + system.adapter.javascript.0             : javascript            : ioBroker                                 -  enabled
        + system.adapter.lgtv11.0                 : lgtv11                : ioBroker                                 -  enabled, port: 8080
        + system.adapter.meross.0                 : meross                : ioBroker                                 -  enabled
        + system.adapter.panasonic-viera.0        : panasonic-viera       : ioBroker                                 -  enabled
        + system.adapter.ping.0                   : ping                  : ioBroker                                 -  enabled
        + system.adapter.scenes.0                 : scenes                : ioBroker                                 -  enabled
        + system.adapter.shelly.0                 : shelly                : ioBroker                                 -  enabled, port: 1882, bind: 0.0.0.0
        + system.adapter.spotify-premium.0        : spotify-premium       : ioBroker                                 -  enabled
        + system.adapter.telegram.0               : telegram              : ioBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
        + system.adapter.tr-064.0                 : tr-064                : ioBroker                                 -  enabled
        + system.adapter.trashschedule.0          : trashschedule         : ioBroker                                 -  enabled
          system.adapter.vis-colorpicker.0        : vis-colorpicker       : ioBroker                                 - disabled
          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBroker                                 - disabled
          system.adapter.vis-icontwo.0            : vis-icontwo           : ioBroker                                 - disabled
        + system.adapter.vis-inventwo.0           : vis-inventwo          : ioBroker                                 -  enabled
          system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBroker                                 - disabled
          system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBroker                                 - disabled
          system.adapter.vis.0                    : vis                   : ioBroker                                 -  enabled
        + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          system.adapter.yr.0                     : yr                    : ioBroker                                 -  enabled
        + instance is alive
        ioBroker-Repositories
        Active repo(s): beta
        Installed ioBroker-Instances
        Used repository: beta
        Adapter    "accuweather"  : 1.3.1    , installed 1.3.1
        Adapter    "admin"        : 6.12.5   , installed 6.12.4 [Updatable]
        Adapter    "alexa2"       : 3.26.2   , installed 3.26.1 [Updatable]
        Adapter    "backitup"     : 2.9.4    , installed 2.9.4
        Adapter    "bring"        : 1.8.4    , installed 1.8.4
        Adapter    "daswetter"    : 3.1.11   , installed 3.1.11
        Adapter    "denon"        : 1.15.4   , installed 1.15.4
        Adapter    "fb-checkpresence": 1.2.2 , installed 1.2.2
        Adapter    "followthesun" : 0.4.2    , installed 0.4.2
        Adapter    "fronius-solarweb": 0.0.3 , installed 0.0.3
        Adapter    "ham"          : 5.3.1    , installed 5.3.1
        Adapter    "harmony"      : 1.3.0    , installed 1.3.0
        Adapter    "heos"         : 2.1.0    , installed 2.1.0
        Adapter    "hue"          : 3.10.1   , installed 3.10.1
        Adapter    "hue-extended" : 2.0.0    , installed 2.0.0
        Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
        Adapter    "javascript"   : 7.1.6    , installed 7.1.6
        Controller "js-controller": 5.0.16   , installed 5.0.16
        Adapter    "lgtv"         : 2.1.2    , installed 2.1.2
        Adapter    "lgtv11"       : 1.0.5    , installed 1.0.5
        Adapter    "meross"       : 1.15.1   , installed 1.15.1
        Adapter    "panasonic-viera": 2.0.0  , installed 2.0.0
        Adapter    "shelly"       : 6.6.1    , installed 6.6.1
        Adapter    "spotify-premium": 1.3.1  , installed 1.3.1
        Adapter    "telegram"     : 3.0.0    , installed 3.0.0
        Adapter    "trashschedule": 2.3.0    , installed 2.3.0
        Adapter    "vis"          : 1.5.1    , installed 1.5.1
        Adapter    "vis-icontwo"  : 0.97.3   , installed 0.97.3
        Adapter    "web"          : 6.1.10   , installed 6.1.10
        Adapter    "ws"           : 2.5.8    , installed 2.5.8
        Adapter    "yr"           : 5.3.0    , installed 5.3.0
        Objects and States
        Objects:        34709
        States:         28960
        Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
        Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
        Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12702      505/sshd: /usr/sbin
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       37937      3214/iobroker.js-co
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       37338      3214/iobroker.js-co
        tcp6       0      0 :::22                   :::*                    LISTEN      0          12704      505/sshd: /usr/sbin
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       35444      3232/io.admin.0
        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       39627      3782/io.web.0
        tcp6       0      0 :::61991                :::*                    LISTEN      1001       40041      3587/io.harmony.0
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12063      366/avahi-daemon: r
        udp        0      0 0.0.0.0:54738           0.0.0.0:*                           1001       38702      3614/io.heos.0
        udp        0      0 0.0.0.0:48670           0.0.0.0:*                           108        12065      366/avahi-daemon: r
        udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       40042      3587/io.harmony.0
        udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       37629      3400/io.shelly.0
        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15363      739/dhcpcd
        udp6       0      0 :::5353                 :::*                                108        12064      366/avahi-daemon: r
        udp6       0      0 :::546                  :::*                                0          12844      739/dhcpcd
        udp6       0      0 :::36996                :::*                                108        12066      366/avahi-daemon: r
        2023-11-24 16:24:57.534  - warn: javascript.0 (3243)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1266:38)
        2023-11-24 16:24:57.534  - warn: javascript.0 (3243)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:645:29)
        2023-11-24 16:24:57.534  - warn: javascript.0 (3243)     at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11220:62)
        2023-11-24 16:24:57.535  - warn: javascript.0 (3243)     at processImmediate (node:internal/timers:476:21)
        2023-11-24 16:24:57.541  - info: javascript.0 (3243) State value to set for "0_userdata.0.Anwesenheit.Anwesenheit" has to be stringified but received type "boolean"
        2023-11-24 16:25:00.142  - info: host.ioBroker instance system.adapter.dwd.0 started with pid 4474
        2023-11-24 16:25:05.250  - info: dwd.0 (4474) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.18.2, js-controller: 5.0.16
        2023-11-24 16:25:09.631  - info: dwd.0 (4474) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2023-11-24 16:25:10.170  - info: host.ioBroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2023-11-24 16:25:13.134  - warn: javascript.0 (3243) You are assigning a boolean to the state "0_userdata.0.Anwesenheit.Anwesenheit" which expects a object. Please fix your code to use a object or change the state type to boolean. This warning might become an error in future versions.
        2023-11-24 16:25:13.137  - warn: javascript.0 (3243)     at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1740:20)
        2023-11-24 16:25:13.138  - warn: javascript.0 (3243)     at Object.<anonymous> (script.js.Anwesenheit.Anwesenheit:3:5)
        2023-11-24 16:25:13.139  - warn: javascript.0 (3243)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1266:38)
        2023-11-24 16:25:13.140  - warn: javascript.0 (3243)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:645:29)
        2023-11-24 16:25:13.141  - warn: javascript.0 (3243)     at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11220:62)
        2023-11-24 16:25:13.142  - warn: javascript.0 (3243)     at processImmediate (node:internal/timers:476:21)
        2023-11-24 16:25:13.157  - info: javascript.0 (3243) State value to set for "0_userdata.0.Anwesenheit.Anwesenheit" has to be stringified but received type "boolean"
        2023-11-24 16:25:29.674  - warn: javascript.0 (3243) You are assigning a boolean to the state "0_userdata.0.Anwesenheit.Anwesenheit" which expects a object. Please fix your code to use a object or change the state type to boolean. This warning might become an error in future versions.
        2023-11-24 16:25:29.677  - warn: javascript.0 (3243)     at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1740:20)
        2023-11-24 16:25:29.677  - warn: javascript.0 (3243)     at Object.<anonymous> (script.js.Anwesenheit.Anwesenheit:5:5)
        2023-11-24 16:25:29.677  - warn: javascript.0 (3243)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1266:38)
        2023-11-24 16:25:29.678  - warn: javascript.0 (3243)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:645:29)
        2023-11-24 16:25:29.678  - warn: javascript.0 (3243)     at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11220:62)
        2023-11-24 16:25:29.678  - warn: javascript.0 (3243)     at processImmediate (node:internal/timers:476:21)
        2023-11-24 16:25:29.770  - info: javascript.0 (3243) State value to set for "0_userdata.0.Anwesenheit.Anwesenheit" has to be stringified but received type "boolean"
        iob diag has finished.
        • I
          IceD112 @IceD112 last edited by
          Woran liegt es denn, dass das Backup nicht vollständig ist?
          • Marc Berg
            Marc Berg Most Active @IceD112 last edited by Marc Berg
            @iced112
            was sagt
            ls -lah /opt/iobroker/backups
            EDIT: Ach Quatsch, das Verzeichnis ist ja gemountet. Was liegt in //192.168.178.1/IceDBox/IOBROKER/ioBroker ?
              Thomas Braun Most Active last edited by
              @iced112
              Mounte Mal mit der Option 'Cache Loose'.
              Unter Umständen erst in der Beta-Version von Backitup zu finden.
              • I
                @Marc-Berg said in Backup Größe ioBroker:
                1. Ist es plausibel, dass die Sicherung, bei 42 Installierten Adaptern nur 35,38 kb hat?
                Da liegen die Backups
                Die allermeisten sind 0 kb, also leer
                weis aber nicht warum
                • I
                  Wo Finde ich die Einstellung?
                  Meinst du den Verbindungstyp
                    Thomas Braun Most Active @IceD112 last edited by
                    @iced112
                    Nein, die Mountoption für ein CIFS/SMB Mount.
                    • I
                      Ah, wurde mir gerade erst angezeigt, komisch...
                      Den anderen Haken bei "noserverino" dafür entfernen?
                        @iced112
                        Nein, bei FritzNAS beides aktiv setzen.
                        • I
                          IceD112 @Thomas Braun last edited by IceD112
                          ok, dann sicher ich grade nochmal ein Backup
                          EDIT: Also an der Datei Größe hat sich nicht geändert
                          Started iobroker ...
                          [DEBUG] [mount] - mount activ... umount is started before mount!!
                          [DEBUG] [mount] - umount successfully completed
                          [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=ioB_Backup,password=****,noserverino,cache=loose,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.178.1/IceDBox/IOBROKER/ioBroker /opt/iobroker/backups"
                          [DEBUG] [mount] - mount successfully completed
                          [DEBUG] [mount] - done
                          [DEBUG] [iobroker] - host.ioBroker 28368 states saved
                          [DEBUG] [iobroker] - host.ioBroker 33321 objects saved
                          [DEBUG] [iobroker] - done
                          [DEBUG] [javascripts] - Created javascript_tmp directory: "/opt/iobroker/backups/tmpScripts"
                          [DEBUG] [javascripts] - found Script: Anwesenheit
                          [DEBUG] [javascripts] - found Script: Anwesenheit_Kinder
                          [DEBUG] [javascripts] - found Script: Blink-Kamera
                          [DEBUG] [javascripts] - found Script: Blink_Kamera
                          [DEBUG] [javascripts] - found Script: Garagenlicht
                          [DEBUG] [javascripts] - found Script: Licht_Esszimmer_normal
                          [DEBUG] [javascripts] - found Script: Weihnachten
                          [DEBUG] [javascripts] - found Script: Regenradar
                          [DEBUG] [javascripts] - found Script: Rollo_Fenster_Warnung
                          [DEBUG] [javascripts] - found Script: Rollo_Schlafzimmer
                          [DEBUG] [javascripts] - found Script: Rollo_Wochenende
                          [DEBUG] [javascripts] - found Script: Rollo_Wohnzimmer
                          [DEBUG] [javascripts] - found Script: Batterieüberwachung
                          [DEBUG] [javascripts] - found Script: Fenster_Bad
                          [DEBUG] [javascripts] - found Script: Fenster_Status
                          [DEBUG] [javascripts] - found Script: Stimmungslicht
                          [DEBUG] [javascripts] - found Script: Subwoofer_aus
                          [DEBUG] [javascripts] - found Script: Wecker
                          [DEBUG] [javascripts] - found Script: Fußball
                          [DEBUG] [javascripts] - found Script: Multiroom_starten
                          [DEBUG] [javascripts] - found Script: Telegrammbaustein
                          [DEBUG] [javascripts] - Try deleting the Javascript tmp directory: "/opt/iobroker/backups/tmpScripts"
                          [DEBUG] [javascripts] - Javascript tmp directory "/opt/iobroker/backups/tmpScripts" successfully deleted
                          [DEBUG] [javascripts] - Backup created: /opt/iobroker/backups/javascripts_2023_11_25-15_25_43_backupiobroker.tar.gz
                          [DEBUG] [javascripts] - done
                          [DEBUG] [cifs] - used copy path: /IceDBox/IOBROKER/ioBroker
                          [DEBUG] [cifs] - done
                          [ERROR] [clean] - Backup files not deleted from /opt/iobroker/backups because some errors.
                          [DEBUG] [clean] - done
                          [DEBUG] [historyHTML] - new history html values created
                          [DEBUG] [historyHTML] - done
                          [DEBUG] [historyJSON] - new history json values created
                          [DEBUG] [historyJSON] - done
                          [DEBUG] [umount] - mount activ, umount is started ...
                          [DEBUG] [umount] - umount successfully completed
                          [DEBUG] [umount] - done
                          [EXIT] 0
                          • I
                            Kann mir niemand beantworten, warum das Backup vom ioBroker nicht funktioniert?
                            • DJMarc75
                              DJMarc75 @IceD112 last edited by DJMarc75
                              @iced112 sagte in Backup Größe ioBroker:
                              wie ich ganz oben schon erwähnt habe bist Du "sportlich" unterwegs:
                              2GB Ram und 42 Adapter installiert. Da geht bei Dir nichts mehr wenn das Backup startet, denn dieser Start vom Backup braucht auch Speicher.
                              • I
                                IceD112 @DJMarc75 last edited by IceD112
                                @djmarc75
                                Hab den neuen PI mit 8gb schon hier vor mir. Ist fertig konfiguriert und ein neuer iob installiert.
                                Irgendwie muss das alte system doch zu sichern sein?
                                • DJMarc75
                                  Vom "neuen" iob bitte auch mal
                                  iob diag
                                  zeigen.
                                  Jo, dazu gibt es den Adapter "BackitUp".
                                  • I
                                    Damit arbeite ich ja.
                                    Die Sicherungen gehen auf die Fritzbox. Aber jedes Backup hat 0 MB. Weis aber nicht warum
                                    • DJMarc75
                                      Wir drehen uns im Kreis:
                                      https://forum.iobroker.net/topic/70494/backup-größe-iobroker/28?_=1700978716741
                                      @djmarc75 sagte in Backup Größe ioBroker:
                                      • I
                                        @djmarc75
                                        Ja, schon verstanden, aber das soll ja nicht bedeuten, dass ich ganz von vorne anfangen muss
                                        • I
                                          Wenn der Backitup Adapter ja so viel Leistung bindet, dass er kein Backup durchführen kann, muss es doch auch ne andere Lösung geben, ein Backup zu erstellen
                                          Marc Berg Homoran 2 Replies Last reply Reply Quote 0
                                          • Marc Berg
                                            Auch wenn es ziemlich wahrscheinlich ist, dass der RAM knapp wird, würde ich trotzdem mal versuchen, das Backup lokal zu speichern, um auszuschließen, dass es am Mount/an der Fritzbox liegt.
                                            7443
