    4. Bambulab 3d-Drucker adapter
    • skvarel
      skvarel Developer @Webranger last edited by
      @webranger sagte in Bambulab 3d-Drucker adapter:
      @dutchman
      Ich hab nen pixelit möchte einfach nur fertig um hh:mm und nicht fertig um jjjj:mm:dd hh:mm:sec
      Hier das Blockly für die Endzeit:
      Blockly Export:
      on({ id: [].concat(['bambulab.0.01P00A391200799.finishTime']), change: 'ne' }, async (obj) => {
        let value = obj.state.val;
        setState('0_userdata.0.3D-Druck.BambuLab.Druck_fertig_gegen' /* Druck fertig gegen */, formatDate(getDateObject((obj.state ? obj.state.val : "")), "hh:mm"), true);
      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
      • Dutchman
        Dutchman Developer Most Active Administrators @Webranger last edited by
        @dutchman
        verstanden, hmm eventuell sollte wir einen separaten Ordner machen fuer die Zeiten und diese dan in verschiedenen Formaten liefern.
        Wen du eine visu oder script benutzt, kannst du das das datum in HH:MM formatieren, wen es wirklich so in einem Datenpunkt stehen soll brauche wir unterschiedliche states
          homecineplexx last edited by
          Danke an alle für die Inputs bezüglich Drucker. Heute ist mein Bambu Lab P1S mit AMS geliefert bekommen und das Ding tut einfach
          Dutchman 1 Reply Last reply Reply Quote 1
          • Dutchman
            Dutchman Developer Most Active Administrators @homecineplexx last edited by
            @homecineplexx sagte in Bambulab 3d-Drucker adapter:
            gerne gerne und viel spass mit dem geraet :), inzwischen ist der adapter weitaus stabile leider noch ein par Fehlermeldungen im log worum ich mich kümmern muss (in progress)
            H Webranger 2 Replies Last reply Reply Quote 3
              homecineplexx @Dutchman last edited by
              @dutchman said in Bambulab 3d-Drucker adapter:
              danke für deinen Einsatz.
              Wo genau finde ich eigentlich den Token? Sollte mir der Drucker diesen irgendwo bereitstellen?
              • Dutchman
                jep, bei den Einstellungen unter netwerk
                H M 3 Replies Last reply Reply Quote 1
                • Webranger
                  Webranger @Dutchman last edited by
                  @dutchman auch von mir mal nen großes Danke für deine Arbeit.
                  Jetzt noch nen Ordner mit paar Zeiten 😉😋
                  Dutchman 1 Reply Last reply Reply Quote 2
                    @dutchman danke jetzt gerade gefunden.
                    meine app zeigt mir an, dass dieser drucker ja auch ein licht haben sollte, aber wenn ich da drauf klicke passiert nichts. soll das so sein oder muss ich da noch was einstellen?
                    skvarel 1 Reply Last reply Reply Quote 0
                    • skvarel
                      skvarel Developer @homecineplexx last edited by
                      .. beim P1S muss nichts weiter eingestellt werden. Das Licht befindet sich auf der linken Seite.
                      • Dutchman
                        Wie sollte der Ordner aussehen mit was für Zeiten und welchem Format? Bauen wir ein kein Problem ist denke ich mal praktisch für vis usw
                        Webranger 1 Reply Last reply Reply Quote 0
                        • Webranger
                          Webranger @Dutchman last edited by Webranger
                          @dutchman
                          Wie wäre es mit:
                          Tag hh:mm:ss
                          Tag hh:mm
                          hh:mm:ss
                          hh:mm
                          Wobei ich nicht weis ob man Tag braucht aber das kann ja beim nächsten schon wieder anders sein.
                            hennott @Webranger last edited by
                            @webranger ich drucke zwar immer wieder über Nacht, also wäre der Tag wohl interessant, aber mir ist auch klar, wenn ich Abends meine Drucke anstelle, dass 07:12 einfach am nächsten Tag ist. Es werden vielleicht nur wenige und sehr selten Drucke haben, die so lang gehen, dass man mit den Tagen durcheinander kommen kann?!
                              druckgott last edited by druckgott
                              Wäre cool wenn man entladen und laden über das system könnte, dann könnten man mit einem ESP und einer externen Rolle und Motor usw. ein art Single AMS für TPU bauen und 1 Farbe TPU über den Splitter einschläusen.
                              So wäre die Idee:
                              • Dutchman
                                Dutchman Developer Most Active Administrators @druckgott last edited by
                                @druckgott sagte in Bambulab 3d-Drucker adapter:
                                So wäre die Idee:
                                Müsste per g- ode oder auch Befehl möglich sein mir ist aber keinen bekannt
                                Wen den jemand rausfinden könnte 🫣
                                  druckgott @Dutchman last edited by druckgott
                                  So wäre die Idee:
                                  Ich hab mal im Github was gemacht, dass wir alles sammeln können.
                                  https://github.com/DrozmotiX/ioBroker.bambulab/issues/66
                                  Befehl müsste doch folgender sein:
                                  druckgott created this issue in DrozmotiX/ioBroker.bambulab
                                  closed Feature Request Load unload Filament and status #66
                                  • kmxak
                                    gibt ne neue x1c firmware... angeblich soll sich was am mqtt getan haben, weiß aber noch nix genaueres.
                                    • Webranger
                                      Webranger @kmxak last edited by
                                      Ich hab mal nen update gemacht.
                                      Hab zwar noch ne verbindung aber es wird mir das log voll geschrieben.
                                      bambulab.0
                                      2023-12-11 21:32:12.081	info	State value to set for "bambulab.0.00M09A361400xxx.finishTime" has to be type "date" but received type "string"
                                      bambulab.0
                                      2023-12-11 21:32:11.073	info	State value to set for "bambulab.0.00M09A361400xxx.finishTime" has to be type "date" but received type "string"
                                      bambulab.0
                                      2023-12-11 21:32:10.369	info	State value to set for "bambulab.0.00M09A361400xxx.finishTime" has to be type "date" but received type "string"
                                      bambulab.0
                                      2023-12-11 21:32:10.070	info	State value to set for "bambulab.0.00M09A361400xxx.finishTime" has to be type "date" but received type "string"
                                      bambulab.0
                                      2023-12-11 21:32:08.022	info	State value to set for "bambulab.0.00M09A361400xxx.finishTime" has to be type "date" but received type "string"
                                      bambulab.0
                                      2023-12-11 21:32:07.072	info	State value to set for "bambulab.0.00M09A361400xxx.finishTime" has to be type "date" but received type "string"
                                      bambulab.0
                                      2023-12-11 21:32:06.006	info	State value to set for "bambulab.0.00M09A361400xxx.finishTime" has to be type "date" but received type "string"
                                      bambulab.0
                                      2023-12-11 21:32:05.084	info	State value to set for "bambulab.0.00M09A361400xxx.finishTime" has to be type "date" but received type "string"
                                      BjoernF M 2 Replies Last reply Reply Quote 0
                                      • BjoernF
                                        BjoernF @Webranger last edited by
                                        @webranger jupp, hauts log zu und sobald die instanz läuft gehts ordentlich mit der CPU hoch....da hat sich mit der neuen Firmware beim X1C definitiv was mit MQTT verändert.....bei 3x X1C und 3 Instanzen aktuell net lustig leider 😞
                                          mick70 @Webranger last edited by mick70
                                          @webranger hier auch. Ich habe einfach das fragliche Objekt gelöscht und an gleicher Stelle ein neues mit gleichem Namen aber als String angelegt (Expertenmodus). Wird brav gefüllt, keine Fehler mehr. [Ed.: Einfacher kann man natürlich gleich den Typ entsprechend ändern]
                                          Ist halt ein workaround, va wenn man mit finishTime noch was machen will, muss man halt mehr tun.
                                          P1S übrigens hier.
                                          H BjoernF 2 Replies Last reply Reply Quote 0
                                            homecineplexx @mick70 last edited by
                                            @mick70 beim P1S gibts auch schon einen Update?
                                            BjoernF 1 Reply Last reply Reply Quote 0
                                            274
                                            86997
