    3. Off Topic
    4. Proxmox
    5. Proxmox: Fehlermeldung bei backup - vzdump ?
      GOETSCHHOFER @Guest last edited by
      @dp20eic
      root@NUC:~# mount
      sysfs on /sys type sysfs (rw,nosuid,nodev,noexec,relatime)
      proc on /proc type proc (rw,relatime)
      udev on /dev type devtmpfs (rw,nosuid,relatime,size=8104840k,nr_inodes=2026210,mode=755)
      devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000)
      tmpfs on /run type tmpfs (rw,nosuid,noexec,relatime,size=1626552k,mode=755)
      /dev/mapper/pve-root on / type ext4 (rw,relatime,errors=remount-ro)
      securityfs on /sys/kernel/security type securityfs (rw,nosuid,nodev,noexec,relatime)
      tmpfs on /dev/shm type tmpfs (rw,nosuid,nodev)
      tmpfs on /run/lock type tmpfs (rw,nosuid,nodev,noexec,relatime,size=5120k)
      tmpfs on /sys/fs/cgroup type tmpfs (ro,nosuid,nodev,noexec,mode=755)
      cgroup2 on /sys/fs/cgroup/unified type cgroup2 (rw,nosuid,nodev,noexec,relatime)
      cgroup on /sys/fs/cgroup/systemd type cgroup (rw,nosuid,nodev,noexec,relatime,xattr,name=systemd)
      pstore on /sys/fs/pstore type pstore (rw,nosuid,nodev,noexec,relatime)
      efivarfs on /sys/firmware/efi/efivars type efivarfs (rw,nosuid,nodev,noexec,relatime)
      none on /sys/fs/bpf type bpf (rw,nosuid,nodev,noexec,relatime,mode=700)
      cgroup on /sys/fs/cgroup/pids type cgroup (rw,nosuid,nodev,noexec,relatime,pids)
      cgroup on /sys/fs/cgroup/net_cls,net_prio type cgroup (rw,nosuid,nodev,noexec,relatime,net_cls,net_prio        )
      cgroup on /sys/fs/cgroup/cpuset type cgroup (rw,nosuid,nodev,noexec,relatime,cpuset)
      cgroup on /sys/fs/cgroup/devices type cgroup (rw,nosuid,nodev,noexec,relatime,devices)
      cgroup on /sys/fs/cgroup/perf_event type cgroup (rw,nosuid,nodev,noexec,relatime,perf_event)
      cgroup on /sys/fs/cgroup/memory type cgroup (rw,nosuid,nodev,noexec,relatime,memory)
      cgroup on /sys/fs/cgroup/cpu,cpuacct type cgroup (rw,nosuid,nodev,noexec,relatime,cpu,cpuacct)
      cgroup on /sys/fs/cgroup/freezer type cgroup (rw,nosuid,nodev,noexec,relatime,freezer)
      cgroup on /sys/fs/cgroup/hugetlb type cgroup (rw,nosuid,nodev,noexec,relatime,hugetlb)
      cgroup on /sys/fs/cgroup/rdma type cgroup (rw,nosuid,nodev,noexec,relatime,rdma)
      cgroup on /sys/fs/cgroup/blkio type cgroup (rw,nosuid,nodev,noexec,relatime,blkio)
      systemd-1 on /proc/sys/fs/binfmt_misc type autofs (rw,relatime,fd=31,pgrp=1,timeout=0,minproto=5,maxpro        to=5,direct,pipe_ino=19609)
      hugetlbfs on /dev/hugepages type hugetlbfs (rw,relatime,pagesize=2M)
      debugfs on /sys/kernel/debug type debugfs (rw,relatime)
      mqueue on /dev/mqueue type mqueue (rw,relatime)
      sunrpc on /run/rpc_pipefs type rpc_pipefs (rw,relatime)
      fusectl on /sys/fs/fuse/connections type fusectl (rw,relatime)
      configfs on /sys/kernel/config type configfs (rw,relatime)
      /dev/nvme0n1p2 on /boot/efi type vfat (rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=iso8859        -1,shortname=mixed,errors=remount-ro)
      lxcfs on /var/lib/lxcfs type fuse.lxcfs (rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other)
      /dev/sdb1 on /media/usb_backup type ext4 (rw,nosuid,nodev,noexec,relatime,sync)
      /dev/fuse on /etc/pve type fuse (rw,nosuid,nodev,relatime,user_id=0,group_id=0,default_permissions,allo        w_other)
      tracefs on /sys/kernel/debug/tracing type tracefs (rw,relatime)
      binfmt_misc on /proc/sys/fs/binfmt_misc type binfmt_misc (rw,relatime)
      tmpfs on /run/user/0 type tmpfs (rw,nosuid,nodev,relatime,size=1626548k,mode=700)
      root@NUC:~# cat /pve/storage.cfg
      cat: /pve/storage.cfg: No such file or directory
      root@NUC:~#
        A Former User @GOETSCHHOFER last edited by
        @goetschhofer sagte in Proxmox: Fehlermeldung bei backup - vzdump ?:
        Moin,
        nicht
        sondern
        # cat /etc/pve/storage.cfg
        Dann es ist nur das gemountet
        Was ist denn Backup_USB-Stick auch ein USB oder eine Partition auf der Festplatte?
        VG
        Bernd
        • Meister Mopper
          Meister Mopper @GOETSCHHOFER last edited by Meister Mopper
          Ich habe vor ca. 4 Monaten versucht bei laufendem Betrieb mit dem Staubsauger seitlich den Staub wegzusaugen und seit dem macht er fallweise diese lauten Geräusche.
          Omg, da feilen die jahrelang an filigranen, platzsparenden Mini-PC und DU kommst im laufenden Betrieb mit dem Staubsauger 😂 🤔 ?
            @dp20eic said in Proxmox: Fehlermeldung bei backup - vzdump ?:
            Moin,
            nicht
            sondern
            VG
            Bernd
            login as: karl
            karl@192.168.1.140's password:
            Linux NUC 5.4.143-1-pve #1 SMP PVE 5.4.143-1 (Tue, 28 Sep 2021 09:10:37 +0200) x86_64
            The programs included with the Debian GNU/Linux system are free software;
            the exact distribution terms for each program are described in the
            individual files in /usr/share/doc/*/copyright.
            Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
            permitted by applicable law.
            Last login: Thu Nov 23 15:09:51 2023 from 192.168.1.3
            karl@NUC:~$ cat /etc/pve/storage.cfg
            cat: /etc/pve/storage.cfg: Permission denied
            karl@NUC:~$
            Backup_USB-Stick ist auch USB für BACKUP.
            Es gibt 2:
            1. Backup-USB-Stick (NUC) mit 64 GB
            2. usb_backup_120 GB(NUC)
              login as: karl
              Moin,
              es ist ja schön, dass Du nicht als root unterwegs bist, aber dann muss man auch wissen und lesen 😉
              Dann musst Du, wenn Du als User auf dem Proxmox Rechner eingeloggt bist auch ein sudo vor den Befehl machen.
              Warum machst Du Dir das Leben so schwer, die WEB UI von Proxmox bietet doch alles, was man braucht.
              Es gibt 2:
              Ja, und das verstehe ich nicht, warum/wofür? Wie und wo werden die Sticks gemountet, wie sehen den die Einstellungen im BackupitUp Adapter aus?
              VG
              Bernd
              crunchip G 2 Replies Last reply Reply Quote 1
                crunchip Forum Testing Most Active @Guest last edited by
                @dp20eic sagte in Proxmox: Fehlermeldung bei backup - vzdump ?:
                weil sich da einer beschwert hat und ihm nahe gelegt hatte sich einen User anzulegen und niemals mehr mit root einloggen😜 (ich wars aber nicht)
                wenn ich mich recht entsinne, war der erste Stick um darauf die Maschinen zu sichern, da aber der Speicher zu klein(weil zu viele backups) hat er sich noch den zweiten zugelegt, bzw laufen da glaub ich auch die backups via backitup drauf.
                Thomas Braun G 2 Replies Last reply Reply Quote 1
                  Thomas Braun Most Active @crunchip last edited by
                  @crunchip sagte in Proxmox: Fehlermeldung bei backup - vzdump ?:
                  weil sich da einer beschwert hat und ihm nahe gelegt hatte sich einen User anzulegen und niemals mehr mit root einloggen (ich wars aber nicht)
                  War ich vermutlich. Was soll daran falsch sein?
                  ? 1 Reply Last reply Reply Quote 1
                    @dp20eic
                    Ich mache die backups nicht über den backitup-Adapter sondern in proxmox.
                    login as: root
                    root@192.168.1.140's password:
                    Access denied
                    Linux NUC 5.4.143-1-pve #1 SMP PVE 5.4.143-1 (Tue, 28 Sep 2021 09:10:37 +0200) x        86_64
                    Last login: Wed Nov 22 12:23:49 2023 from 192.168.1.3
                    root@NUC:~# cat /etc/pve/storage.cfg
                    dir: local
                            path /var/lib/vz
                            content iso,rootdir
                            prune-backups keep-daily=5,keep-last=5
                            shared 0
                    lvmthin: local-lvm
                            thinpool data
                            vgname pve
                            content rootdir,images
                    dir: Backup-USB-Stick
                            path /media/USB-NUC-NAS
                            content backup,vztmpl
                            nodes NUC
                            prune-backups keep-last=3
                            shared 0
                    dir: usb_backup_120GB
                            path /media/usb_backup
                            nodes NUC
                            prune-backups keep-last=14
                            shared 0
                    root@NUC:~#
                      GOETSCHHOFER @crunchip last edited by GOETSCHHOFER
                      @crunchip
                      Ja, genau so war es, der 1. USB-Stick wurde rasch zu klein.
                      Du hast echt ein sehr gutes Gedächtnis. 👍 😀
                      • Meister Mopper
                        @crunchip
                        😊 Ich glaube eher, dass Mario sehr gut dokumentiert. Soviel treffsichere Links kann sich ja kein menschliches Hirn merken.
                        😉 @crunchip
                          A Former User @Thomas Braun last edited by
                          @thomas-braun sagte in Proxmox: Fehlermeldung bei backup - vzdump ?:
                          Moin,
                          weil es Proxmox ist und es da dann auch ein Rollen/Rechte System gibt, wo man sich dann User mit den nötigen Rollen einrichtet.
                          Ich lass' das dann mal, das wird dann schon jemand richten 🙂
                          VG
                          Bernd
                          Meister Mopper Thomas Braun 2 Replies Last reply Reply Quote 1
                          • Meister Mopper
                            Meister Mopper @Guest last edited by Meister Mopper
                            Ich denke nicht, dass es jemand richten wird.
                            Aber tatsächlich kann man bei Proxmox den root nicht ausknipsen wie in nativen Systemen.
                            Aber es sollte meines Erachtens immer wieder darauf hingewiesen werden, dass auch in der Proxmox-cli als normaler User mit sudo (wenn nötig) gearbeitet werden muss, um Kollateralschäden zu vermeiden, so wie es @Thomas-Braun richtigerweise immer wieder propagiert.
                            Also root arbeiten bedeutet eine Operation am offenen Herzen, und das sollten Spezialisten tun.
                              Ja, mein Reden...
                              crunchip 1 Reply Last reply Reply Quote 1
                                Thomas Braun Most Active @Meister Mopper last edited by
                                @meister-mopper sagte in Proxmox: Fehlermeldung bei backup - vzdump ?:
                                Der ist in nativen Systemen ja auch nicht 'ausgeknipst' (geht auch gar nicht, weil der ja im Hintergrund aktiv sein muss), er wird aber nicht direkt/aktiv verwendet.
                                Meister Mopper 1 Reply Last reply Reply Quote 1
                                • Meister Mopper
                                  Meister Mopper @Thomas Braun last edited by
                                  Natürlich!
                                    crunchip Forum Testing Most Active @Thomas Braun last edited by
                                    @thomas-braun er meint direkt in Proxmox
                                    ne net wirklich, aber manch Sachen bleiben in Erinnerung
                                      @crunchip
                                      Möchte ein kurzes Feedback zu meinem Problem geben.
                                      Habe gestern die beiden dump Verzeichnisse in proxmox mit root😁 bereinigt und die backups in proxmox von beiden USB-Sticks wieder aktiviert.
                                      Siehe da, jetzt laufen die seit gestern wieder normal ohne Fehlermeldung durch.
                                      Vielen Dank nochmals für die Hilfe an Alle. 👍
                                        crunchip Forum Testing Most Active @GOETSCHHOFER last edited by
                                        @goetschhofer wenn dem so ist, müsste local ja wieder die Ursprungsinstalltonsgröße haben, bzw dürfte dann in
                                        /opt/iobroker/
                                        Kein backup liegen
                                          @crunchip said in Proxmox: Fehlermeldung bei backup - vzdump ?:
                                          /opt/iobroker/
                                          Kein backup liegen
                                          Meinst du dies hier ?
                                            @goetschhofer dein opt/iobroker/backups ist leer, passt
                                            Aber dein local ist ja schon wieder angestiegen
                                            81.1k
                                            33993
