    4. Raspberry Pi plötzlich nicht mehr erreichbar
      gammler2003 @Thomas Braun last edited by
      @thomas-braun said in Raspberry Pi in plötzlich nicht mehr erreichbar:
      iob diag
      Vielen Dank dir für den Hinweis. So sieht die Summary bei mir aus. Lässt sich daraus irgendein Hinweis auf das Phänomen ableiten?
      			v.2023-10-10
         Static hostname: phoscon
               Icon name: computer
        Operating System: Raspbian GNU/Linux 10 (buster)
                  Kernel: Linux 5.10.103-v7l+
            Architecture: arm
      Installation: 		native
      Kernel: 		armv7l
      Userland: 		armhf
      Timezone: 		Europe/Berlin (CET, +0100)
      User-ID: 		1000
      X-Server: 		true
      Boot Target: 		graphical.target
      Pending OS-Updates: 	282
      Pending iob updates: 	8
      /home/iobroker/.diag.sh: line 486: nodejs: command not found
      Nodejs-Installation:
      			/usr/local/bin/node 		v16.15.0
      			/usr/local/bin/npm 		8.5.5
      			/usr/local/bin/npx 		8.5.5
      			/usr/local/bin/corepack 	0.10.0
      Recommended versions are nodejs 18.18.2 and npm 9.8.1
      *** nodejs is NOT correctly installed ***
      Wrong installation path detected. This needs to be fixed.
      Please check
      https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian
      for more information on how to fix these errors.
      MEMORY:
      Mem:           3.8G        1.6G        1.5G         46M        718M        2.5G
      Swap:           99M          0B         99M
      Total:         3.9G        1.6G        1.6G
      Active iob-Instances: 	28
      Active repo(s): Stable (default)
      ioBroker Core: 		js-controller 		5.0.16
      			admin 			6.12.0
      ioBroker Status: 	iobroker is running on this host.
      Objects type: jsonl
      States  type: jsonl
      + system.adapter.admin.0                  : admin                 : phoscon                                  -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.web.0                    : web                   : phoscon                                  -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      Objects: 		13244
      States: 		10145
      Size of iob-Database:
      28M	/opt/iobroker/iobroker-data/objects.jsonl
      17M	/opt/iobroker/iobroker-data/objects.json.migrated
      17M	/opt/iobroker/iobroker-data/objects.json.bak.migrated
      4.8M	/opt/iobroker/iobroker-data/states.jsonl
      3.0M	/opt/iobroker/iobroker-data/states.json.migrated
      3.0M	/opt/iobroker/iobroker-data/states.json.bak.migrated
        Thomas Braun Most Active @gammler2003 last edited by
        @gammler2003 sagte in Raspberry Pi plötzlich nicht mehr erreichbar:
        (buster)
        Ist EOL, muss ersetzt werden. Aktuell ist Raspberry OS 12 'Bookworm'.
        X-Server: true
        Schalt den Desktop-Mumpitz aus.
        Halte das System immer auf Stand.
        Installier nodejs ordentlich.
          gammler2003 @Thomas Braun last edited by gammler2003
          @thomas-braun Vielen Dank dir für die Hinweise, die ich direkt umgesetzt habe! Jetzt warte ich mal ab, ob das System nun stabiler läuft. Ich berichte...
          			v.2023-10-10
                   Icon name: computer
            Operating System: Raspbian GNU/Linux 12 (bookworm)
                Architecture: arm
          Kernel: 		armv7l
          Userland: 		armhf
          User-ID: 		1000
          X-Server: 		false
          Boot Target: 		multi-user.target
          Pending OS-Updates: 	0
          Pending iob updates: 	1
          Nodejs-Installation: 	/usr/bin/nodejs 	v18.18.2
          			/usr/bin/node 		v18.18.2
          			/usr/bin/npm 		9.8.1
          			/usr/bin/npx 		9.8.1
          			/usr/bin/corepack 	0.19.0
          MEMORY:
          Mem:            3.8G        1.2G        2.0G        1.0M        622M        2.5G
          Swap:            99M          0B         99M
          Total:          3.9G        1.2G        2.1G
          			admin 			6.12.0
          Objects type: jsonl
          States  type: jsonl
          Objects: 		13250
          States: 		10150
          18M	/opt/iobroker/iobroker-data/objects.jsonl
          24M	/opt/iobroker/iobroker-data/states.jsonl
            @gammler2003
            Das ist nicht richtig. Bookworm kommt mit einem Kernel 6.1 daher.
              @thomas-braun Mhh...ok. Hast du mir einen Tipp, wie ich das mache? Hätte erwartet, das passiert automatisch mit dem Debian Upgrade. Danke dir.
                Thomas Braun Most Active @gammler2003 last edited by Thomas Braun
                Bei Debian passiert das auch, aber nicht bei Raspberry OS.
                Gibt aber mindestens zwei Threads dazu.
                Die Empfehlung ist und bleibt aber in dem Fall: Neuinstallation. Dann käme auch eine 64Bit-Installation in Frage (passende Hardware vorausgesetzt)
                  thoml last edited by
                  @gammler2003
                  Was hast du als Speicher an dem Pi?
                  Betreibst du zufällig ne SSD über nen USB Adapter daran?
                    gammler2003 @thoml last edited by
                    @thoml Eine SanDisk Extreme Pro 64 GB microSDXC Memory Card, welche direkt im Pi steckt.
                      @thomas-braun Alles klar, ich danke dir. Dann setze ich mich die Tage wohl tatsächlich mal an eine Neuinstallation und setze alles sauber auf.
                      Hast du eine Empfehlung, wie ich das am besten angehe (welches OS, fertiges Image, etc.)?
                      Nutze aktuell einen Raspberry Pi 4 Modell B; 4 GB, ARM-Cortex-A72 4 x, 1,50 GHz, 4 GB RAM. Macht es Sinn, mir direkt neue Hardware anzuschaffen oder reicht mein aktueller Raspberry Pi "locker" für ein bisschen ioBroker?
                        Homoran Global Moderator Administrators @gammler2003 last edited by
                        Raspberry Pi OS light 64 bit
                          nochmals vielen Dank für eure Hilfe und die Denkanstöße.
                          Ich habe mein System neu aufgesetzt und siehe da...es läuft wie geschmiert. Bisher konnte ich keine Ausfälle mehr feststellen.
                          1704
