    3. Off Topic
    4. InfluxDB
    5. mit backitup kein Influxdb und Grafana backup möglich
      Christian 5 @Christian 5 last edited by
      @christian-5 nach dem grafana backup diese Meldung:
      code_text
      ```Started restore ...
      [DEBUG] [grafana] - Start Grafana Restore ...
      [DEBUG] [grafana] - filename for restore: /opt/iobroker/backups/grafana_2023_11_23-04_46_57_Meine001Sicherung_backupiobroker.tar.gz
      [DEBUG] [grafana] - Grafana tmp directory created: /opt/iobroker/backups/grafana_tmp
      [DEBUG] [grafana] - start decompress
      [DEBUG] [grafana] - Grafana request started
      [DEBUG] [grafana] - Grafana is available ... Status: 200
      [DEBUG] [grafana] - Try to Restore: /opt/iobroker/backups/grafana_tmp/datasource/InfluxDB-1.json
      [DEBUG] [grafana] - Try to Restore: /opt/iobroker/backups/grafana_tmp/datasource/InfluxDB.json
      [DEBUG] [grafana] - cannot restore datasource "InfluxDB": "data source with the same name already exists"
      [DEBUG] [grafana] - cannot restore datasource "InfluxDB-1": "data source with the same name already exists"
      [DEBUG] [grafana] - Try to Restore: /opt/iobroker/backups/grafana_tmp/dashboards/dashboard-alles-mogliche-1woche.json
      [DEBUG] [grafana] - Try to Restore: /opt/iobroker/backups/grafana_tmp/dashboards/kurven-1jahr.json
      [DEBUG] [grafana] - Try to Restore: /opt/iobroker/backups/grafana_tmp/dashboards/pv1-pv2-leistung-1tag.json
      [DEBUG] [grafana] - cannot restore dashboard "dashboard-alles-mogliche-1woche": {"extra":null,"message":"organization not found","messageId":"org.notFound","statusCode":404,"traceID":""}
      [DEBUG] [grafana] - cannot restore dashboard "kurven-1jahr": {"extra":null,"message":"organization not found","messageId":"org.notFound","statusCode":404,"traceID":""}
      [DEBUG] [grafana] - cannot restore dashboard "pv1-pv2-leistung-1tag": {"extra":null,"message":"organization not found","messageId":"org.notFound","statusCode":404,"traceID":""}
      [DEBUG] [grafana] - Grafana request ended
      [DEBUG] [grafana] - Try deleting the Grafana tmp directory
      [DEBUG] [grafana] - Grafana tmp directory was successfully deleted
      [DEBUG] [grafana] - Grafana Restore completed successfully
      [EXIT] Grafana restore done
        Christian 5 @Homoran last edited by
        Bitte noch den provisorischen Threadtitel sinnvoll anpassen.
        aber wie?
        • Marc Berg
          Marc Berg Most Active @Christian 5 last edited by Marc Berg
          @christian-5 sagte in Influx/Grafana Probleme:
          Du musst die Buckets manuell vor dem Restore löschen und am besten die Adapter stoppen, damit nicht gleich wieder Daten reinfliegen. Die entsprechende Funktion in den Backitup Einstellungen funktioniert nicht (immer?).
          • Marc Berg
            aber wie?
            den ersten Post hier im Thread editieren.
              Christian 5 @Marc Berg last edited by
              @marc-berg danke, bucket in influx gelöscht, influx neu gestartet Adapter deaktiviert:
              code_text
              [DEBUG] [influxDB] - Created tmp directory
              [DEBUG] [influxDB] - Start infuxDB Restore ...
              [ERROR] [influxDB] - 2023/11/25 21:07:12 INFO: Restoring bucket "9d69ae680368264c" as "iobroker"
              Error: failed to restore bucket "iobroker": 401 Unauthorized: read:authorizations is unauthorized
              [DEBUG] [influxDB] - Try deleting the InfluxDB tmp directory
              [DEBUG] [influxDB] - InfluxDB tmp directory was successfully deleted
              [DEBUG] [influxDB] - infuxDB Restore completed successfully
              [EXIT] influxDB restore done
              • Marc Berg
                @christian-5 sagte in mit backitup kein Influxdb und Grafana backup möglich:
                Du benutzt einen falschen Token.
                https://github.com/simatec/ioBroker.backitup/wiki/Diverse-Anleitungen-für-ioBroker.backitup#influxdb2-restore
                  Christian 5 @Marc Berg last edited by Christian 5
                  @marc-berg neuen Token eingetragen und wieder das gleiche Ergebnis... ich bin zu blöd
                  C Marc Berg 2 Replies Last reply Reply Quote 0
                    Christian 5 @Christian 5 last edited by Christian 5
                    @christian-5 und in grafana das selbe jetzt hab ich den inhalt im Ordner /opt/iobroker/iobroker-data/backup-objects gelöscht, schau ma amoal
                    code_text
                    code_text
                      ich hab die beiden daten Quellen in Grafana aber gelöscht.
                    • Marc Berg
                      wo hast du den neuen Token her?
                        @marc-berg aus influxdb unter API Tokens influx token.png erzeugt
                        ich hab in eurer Anleitung zum backitup adapter gelesen das die influxdb cli installiert gehört, dachte die influxdb cli wird jetzt automatisch mit installiert.
                        • Marc Berg
                          aus influxdb unter API Tokens erzeugt
                          Und das ist falsch, darum hatte ich die Dokumentation dazu verlinkt, in der es erklärt ist.
                          Nein. Wer hat das je behauptet?
                            @marc-berg ok danke, dann ein weiterer Versuch, wie installier ich die cli auf dem raspi am einfachsten?
                            aber ein fehler das CLI nicht installiert ist hab ich auch keinen bekommen.
                            das heißt jetzt : Operator-Token für InfluxDB 2.x wiederherstellen
                            • Marc Berg
                              Marc Berg Most Active last edited by
                              Ich sehe jetzt gerade nicht mehr durch, was jetzt gerade das Problem ist. Die influxdb2-cli scheint doch schon installiert zu sein, sonst bekämst du nicht diese Fehlermeldung:
                                @marc-berg ich habs nicht explizit installiert, darum die frage. ...aber jetzt Token erzeugen???
                                ist eure Anleitung aktuell?
                                • Marc Berg
                                  Ja, wenn du die influxdb2 installierst, dann ist die cli mit dabei. Da hatte ich das "automatisch" falsch verstanden.
                                  In der Anleitung steht auch, wie der Operator Token AUSZULESEN ist. Wenn du den Token nicht gelöscht hast, würde das reichen.
                                    @marc-berg in der Anleitung steht ja auch: Für die Verwendung des InfluxDB Backups muss influxd installiert sein
                                    Installationsanleitung InfluxDB 1.x
                                    Installationsanleitung InfluxDB 2.x
                                    Installationsanleitung Influx-CLI für 2.x ???
                                    Operator docken auslese Anleitung finde ich jetzt nicht wirklich, überlesen..blind
                                    lg
                                    crunchip ? 2 Replies Last reply Reply Quote 0
                                      crunchip Forum Testing Most Active @Christian 5 last edited by
                                      steht doch da
                                      Nun benötigen wir für den ioBroker.backitup Adapter den neuen Operator-Token, welcher z.B. über die Linux-Kommandozeile durch
                                      influx auth list -t <ein all access token>
                                      über den ersten Eintrag der Ausgabe eingesehen werden kann. (Hinweis: Beim Kopieren in die Instanz-Settings auf Zeilenumbrüche etc. achten!).
                                        Christian 5 @crunchip last edited by Christian 5
                                        @crunchip sagte in mit backitup kein Influxdb und Grafana backup möglich:
                                        steht doch da
                                        $ influx auth list -t <ein all access token>
                                        -bash: syntax error near unexpected token `newline'
                                        ich versteh den Befehl ja so das ich da einen Token eintragen muß
                                          A Former User @Christian 5 last edited by
                                          Moin,
                                          ich hatte zwar vor mich hier nicht mehr einzumischen und habe, zu meiner Schande, die Doku nicht gelesen, will nur mal wieder Korinthen kacken 🙂
                                          • ioBroker und influxDB2 auf demselben Rechner, muss nichts weiter installiert werden, alles ok.
                                          • ioBroker auf einem Rechner und influxDB2 auf einem anderen, dann muss auf ioBroker auch influxDB2-cli installiert werden, es braucht für das Backup den influxd
                                          • ioBroker und influxDB auf demselben Rechner, dann alles ok
                                          • ioBroker auf einem Rechner und influxDB auf einem anderen, dann muss influxDB auch auf dem ioBroker Rechner installiert werden, wird dort aber nicht gestartet, es wird nur influxd genutzt, um Backups zu machen.
                                          VG
                                          Bernd
                                            Christian 5 @Guest last edited by Christian 5
                                            @dp20eic Danke für die Info, bei mir läuft iobroker, influxdb und grafana auf einem Raspi mit bookworm.
                                            Vieleicht ist auch das Bookworm System zu neu für eurer Backitup?
                                            Jetzt hab ich versucht den Befehl [influx auth list -t] ( mit meinen admin token zu füttern danach kommt:
                                            ~ $ influx auth list -t <JFDFtCoikpXsamvQ1FoN6lJ2sHepumBw5N4VviHmnywuWZ4A2xKOQPb1WISCw9i3y_17x7cHHJ3_pLwH0NJvMQ==>
                                            ich depp hab ja <> stehen lassen
                                            Thomas Braun crunchip 2 Replies Last reply Reply Quote 0
                                            119
                                            9921
