      arteck Developer Most Active @Michael Roling last edited by arteck
      @michael-roling guckst du
      bei 0.8.7
      • Michael Roling
        Michael Roling Developer @arteck last edited by
        @arteck bei was passiert das?
          @michael-roling bei start
          • Michael Roling
            @arteck ohja ich habe es gesehen, kümmere ich mich drum
            • Michael Roling
              @arteck habe ich in der 0.9.1 gefixt
                Willi-Wunder @Michael Roling last edited by
                @michael-roling
                Bekomme beim Start diese Meldung, Adapter startet jetzt nicht mehr V0.9.1
                telegram-menu.0
                	2023-11-26 11:52:05.405	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                telegram-menu.0
                	2023-11-26 11:52:05.403	info	terminating
                telegram-menu.0
                	2023-11-26 11:52:05.379	error	Cannot convert undefined or null to object
                telegram-menu.0
                	2023-11-26 11:52:05.377	error	TypeError: Cannot convert undefined or null to object at Function.keys (<anonymous>) at TelegramMenu.onReady (/opt/iobroker/node_modules/iobroker.telegram-menu/main.js:64:30) at TelegramMenu.emit (node:events:517:28) at TelegramMenu._callReadyHandler (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:9108:18) at /opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:9087:26
                telegram-menu.0
                	2023-11-26 11:52:05.373	error	unhandled promise rejection: Cannot convert undefined or null to object
                telegram-menu.0
                	2023-11-26 11:52:05.372	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                • Michael Roling
                  Michael Roling Developer @Willi-Wunder last edited by
                  @willi-wunder du warst zu schnell installiere 0.9.2
                  • Rene55
                    Rene55 @Michael Roling last edited by
                    @michael-roling Fleißig, fleißig. Ist ja mal richtig gut aufgeräumt - alle Achtung. Wenn du mal viel Lust hast, kannst du bitte auch noch "Confirm message" eindeutschen.
                    • Michael Roling
                      Michael Roling Developer @Rene55 last edited by
                      @rene55 top, du hast recht! Das fehlt noch 😎
                      W 2 Replies Last reply Reply Quote 0
                        @michael-roling
                        Super, läuft wieder 👍
                          @michael-roling
                          Bei den Aktionen "GetState" + "SetState" kann man beim Bearbeiten den Rückgabetext nicht mehr markieren um diesen ggf. zu kopieren. Hier wird die ganze Zeile markiert. Im Menü geht das Markieren wie gewohnt.
                          • Michael Roling
                            @willi-wunder Okay, ja das ist eine css eigenschaft die ich da rein gemacht hatte weil sonst beim draggen alles markiert wurde. Schaue ich mir noch mal an
                              Hi, bastel mir gerade etwas zusammen. Aber irgendwie klappt das nicht so recht, kann mir da jemand einen Tipp geben?
                              Ich möchte beim Einstellen der Zirku Pumpe zuerst noch die aktuellen Werte von "Familie" + "Single" anzeigen lassen bevor ich etwas einstelle. Schöne wäre:
                              Zirku ein- oder ausschalten? (neue Zeile)
                              Familie Status xy (neue Zeile)
                              Single Status xy (neue Zeile)
                              Bei mir wird aktuell nur der erste Wert mit "true" angezeigt und nicht umgewandelt, beim zweiten Wert kommt der Code mit. Was mache ich falsch?
                              Vielen Dank.
                              Gruß Willi
                              • Michael Roling
                                @willi-wunder das geht erstmal nur mit einem datenpunkt
                                  @michael-roling
                                  Ah okay, danke für die Info. Aber die Umwandlung mit "true" und "false" sollte aber klappen, oder?
                                    @michael-roling
                                    Mir ist noch aufgefallen das nun alle Werte "&&" mit "&&amp" ersetzt wurden. Ist das so gewollt? Funktion ist nach wie vor da, jedoch wird es unübersichtlicher. Nur zur Info 🙂
                                    • Michael Roling
                                      @willi-wunder nein mit dem && ist nicht so gewollt. War mir selbst aber noch nicht aufgefallen.
                                      Mit dem change geht meine ich auch an der Stelle noch nicht.
                                      Ich komme aber leider erst am Wochenende wieder dazu.
                                      W Michael Roling 2 Replies Last reply Reply Quote 0
                                        @michael-roling
                                        Man denkt zuerst immer selbst an einen Anwendungsfehler, bin dann beruhigt wenn es nicht an mir lag. Mach dir keinen Stress, dein Einsatz ist eh schon hammer.
                                        • Michael Roling
                                          Michael Roling Developer @Michael Roling last edited by Michael Roling
                                          @Willi-Wunder Moin, so jetzt kannst du text markieren und auch das & sollte an allen Stellen weg sein.
                                          Als nächstes schaue ich mal nach dem change, du kannst in zwischenzeit schon mal testen wenn Zeit ist.
                                          Welche Fehler waren sonst noch da? Ich habe den Überblick verloren
                                          • Michael Roling
                                            @willi-wunder so jetzt sollte es mit change auch funktionieren
                                            1801
                                            793851
