    • Michael Roling
      Michael Roling Developer @arteck last edited by
      @arteck bei was passiert das?
        arteck Developer Most Active @Michael Roling last edited by
        @michael-roling bei start
        • Michael Roling
          @arteck ohja ich habe es gesehen, kümmere ich mich drum
          • Michael Roling
            @arteck habe ich in der 0.9.1 gefixt
              Willi-Wunder @Michael Roling last edited by
              @michael-roling
              Bekomme beim Start diese Meldung, Adapter startet jetzt nicht mehr V0.9.1
              telegram-menu.0
              	2023-11-26 11:52:05.405	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
              telegram-menu.0
              	2023-11-26 11:52:05.403	info	terminating
              telegram-menu.0
              	2023-11-26 11:52:05.379	error	Cannot convert undefined or null to object
              telegram-menu.0
              	2023-11-26 11:52:05.377	error	TypeError: Cannot convert undefined or null to object at Function.keys (<anonymous>) at TelegramMenu.onReady (/opt/iobroker/node_modules/iobroker.telegram-menu/main.js:64:30) at TelegramMenu.emit (node:events:517:28) at TelegramMenu._callReadyHandler (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:9108:18) at /opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:9087:26
              telegram-menu.0
              	2023-11-26 11:52:05.373	error	unhandled promise rejection: Cannot convert undefined or null to object
              telegram-menu.0
              	2023-11-26 11:52:05.372	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
              • Michael Roling
                Michael Roling Developer @Willi-Wunder last edited by
                @willi-wunder du warst zu schnell installiere 0.9.2
                • Rene55
                  Rene55 @Michael Roling last edited by
                  @michael-roling Fleißig, fleißig. Ist ja mal richtig gut aufgeräumt - alle Achtung. Wenn du mal viel Lust hast, kannst du bitte auch noch "Confirm message" eindeutschen.
                  • Michael Roling
                    Michael Roling Developer @Rene55 last edited by
                    @rene55 top, du hast recht! Das fehlt noch 😎
                    W 2 Replies Last reply Reply Quote 0
                      @michael-roling
                      Super, läuft wieder 👍
                        @michael-roling
                        Bei den Aktionen "GetState" + "SetState" kann man beim Bearbeiten den Rückgabetext nicht mehr markieren um diesen ggf. zu kopieren. Hier wird die ganze Zeile markiert. Im Menü geht das Markieren wie gewohnt.
                        • Michael Roling
                          @willi-wunder Okay, ja das ist eine css eigenschaft die ich da rein gemacht hatte weil sonst beim draggen alles markiert wurde. Schaue ich mir noch mal an
                            Hi, bastel mir gerade etwas zusammen. Aber irgendwie klappt das nicht so recht, kann mir da jemand einen Tipp geben?
                            Ich möchte beim Einstellen der Zirku Pumpe zuerst noch die aktuellen Werte von "Familie" + "Single" anzeigen lassen bevor ich etwas einstelle. Schöne wäre:
                            Zirku ein- oder ausschalten? (neue Zeile)
                            Familie Status xy (neue Zeile)
                            Single Status xy (neue Zeile)
                            Bei mir wird aktuell nur der erste Wert mit "true" angezeigt und nicht umgewandelt, beim zweiten Wert kommt der Code mit. Was mache ich falsch?
                            Vielen Dank.
                            Gruß Willi
                            • Michael Roling
                              @willi-wunder das geht erstmal nur mit einem datenpunkt
                                @michael-roling
                                Ah okay, danke für die Info. Aber die Umwandlung mit "true" und "false" sollte aber klappen, oder?
                                  @michael-roling
                                  Mir ist noch aufgefallen das nun alle Werte "&&" mit "&&amp" ersetzt wurden. Ist das so gewollt? Funktion ist nach wie vor da, jedoch wird es unübersichtlicher. Nur zur Info 🙂
                                  • Michael Roling
                                    @willi-wunder nein mit dem && ist nicht so gewollt. War mir selbst aber noch nicht aufgefallen.
                                    Mit dem change geht meine ich auch an der Stelle noch nicht.
                                    Ich komme aber leider erst am Wochenende wieder dazu.
                                    W Michael Roling 2 Replies Last reply Reply Quote 0
                                      @michael-roling
                                      Man denkt zuerst immer selbst an einen Anwendungsfehler, bin dann beruhigt wenn es nicht an mir lag. Mach dir keinen Stress, dein Einsatz ist eh schon hammer.
                                      • Michael Roling
                                        Michael Roling Developer @Michael Roling last edited by Michael Roling
                                        @Willi-Wunder Moin, so jetzt kannst du text markieren und auch das & sollte an allen Stellen weg sein.
                                        Als nächstes schaue ich mal nach dem change, du kannst in zwischenzeit schon mal testen wenn Zeit ist.
                                        Welche Fehler waren sonst noch da? Ich habe den Überblick verloren
                                        • Michael Roling
                                          @willi-wunder so jetzt sollte es mit change auch funktionieren
                                            @michael-roling
                                            Hi, hab gerade die neuste Version geladen 🙂
                                            Rückmeldung:
                                            && ist behoben und wird richtig dargestellt
                                            Change Befehl geht jetzt auch in der Navigation
                                            Das Markieren vom Text bei Aktion- Getstate+Setstate geht nicht. Dies geht nur bei Navigation.
                                            Frage:
                                            Die Abfrage mit den Status Befehl in der Navigation geht ja bisher nur mit einem Objekt. Ist dies noch vorgesehen das es auch mit mehreren geht?
                                            Wie kann man einen Zeilenumbruch in Navigation - bei Text erzwingen?
                                            1801
                                            793095
