    4. Backup Größe ioBroker
    • I
      IceD112 @Thomas Braun last edited by
      Ah, wurde mir gerade erst angezeigt, komisch...
      Den anderen Haken bei "noserverino" dafür entfernen?
        Thomas Braun Most Active @IceD112 last edited by
        @iced112
        Nein, bei FritzNAS beides aktiv setzen.
        • I
          IceD112 @Thomas Braun last edited by IceD112
          ok, dann sicher ich grade nochmal ein Backup
          EDIT: Also an der Datei Größe hat sich nicht geändert
          Started iobroker ...
          [DEBUG] [mount] - mount activ... umount is started before mount!!
          [DEBUG] [mount] - umount successfully completed
          [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=ioB_Backup,password=****,noserverino,cache=loose,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.178.1/IceDBox/IOBROKER/ioBroker /opt/iobroker/backups"
          [DEBUG] [mount] - mount successfully completed
          [DEBUG] [mount] - done
          [DEBUG] [iobroker] - host.ioBroker 28368 states saved
          [DEBUG] [iobroker] - host.ioBroker 33321 objects saved
          [DEBUG] [iobroker] - done
          [DEBUG] [javascripts] - Created javascript_tmp directory: "/opt/iobroker/backups/tmpScripts"
          [DEBUG] [javascripts] - found Script: Anwesenheit
          [DEBUG] [javascripts] - found Script: Anwesenheit_Kinder
          [DEBUG] [javascripts] - found Script: Blink-Kamera
          [DEBUG] [javascripts] - found Script: Blink_Kamera
          [DEBUG] [javascripts] - found Script: Garagenlicht
          [DEBUG] [javascripts] - found Script: Licht_Esszimmer_normal
          [DEBUG] [javascripts] - found Script: Weihnachten
          [DEBUG] [javascripts] - found Script: Regenradar
          [DEBUG] [javascripts] - found Script: Rollo_Fenster_Warnung
          [DEBUG] [javascripts] - found Script: Rollo_Schlafzimmer
          [DEBUG] [javascripts] - found Script: Rollo_Wochenende
          [DEBUG] [javascripts] - found Script: Rollo_Wohnzimmer
          [DEBUG] [javascripts] - found Script: Batterieüberwachung
          [DEBUG] [javascripts] - found Script: Fenster_Bad
          [DEBUG] [javascripts] - found Script: Fenster_Status
          [DEBUG] [javascripts] - found Script: Stimmungslicht
          [DEBUG] [javascripts] - found Script: Subwoofer_aus
          [DEBUG] [javascripts] - found Script: Wecker
          [DEBUG] [javascripts] - found Script: Fußball
          [DEBUG] [javascripts] - found Script: Multiroom_starten
          [DEBUG] [javascripts] - found Script: Telegrammbaustein
          [DEBUG] [javascripts] - Try deleting the Javascript tmp directory: "/opt/iobroker/backups/tmpScripts"
          [DEBUG] [javascripts] - Javascript tmp directory "/opt/iobroker/backups/tmpScripts" successfully deleted
          [DEBUG] [javascripts] - Backup created: /opt/iobroker/backups/javascripts_2023_11_25-15_25_43_backupiobroker.tar.gz
          [DEBUG] [javascripts] - done
          [DEBUG] [cifs] - used copy path: /IceDBox/IOBROKER/ioBroker
          [DEBUG] [cifs] - done
          [ERROR] [clean] - Backup files not deleted from /opt/iobroker/backups because some errors.
          [DEBUG] [clean] - done
          [DEBUG] [historyHTML] - new history html values created
          [DEBUG] [historyHTML] - done
          [DEBUG] [historyJSON] - new history json values created
          [DEBUG] [historyJSON] - done
          [DEBUG] [umount] - mount activ, umount is started ...
          [DEBUG] [umount] - umount successfully completed
          [DEBUG] [umount] - done
          [EXIT] 0
          • I
            Kann mir niemand beantworten, warum das Backup vom ioBroker nicht funktioniert?
            • DJMarc75
              DJMarc75 @IceD112 last edited by DJMarc75
              @iced112 sagte in Backup Größe ioBroker:
              wie ich ganz oben schon erwähnt habe bist Du "sportlich" unterwegs:
              2GB Ram und 42 Adapter installiert. Da geht bei Dir nichts mehr wenn das Backup startet, denn dieser Start vom Backup braucht auch Speicher.
              • I
                IceD112 @DJMarc75 last edited by IceD112
                @djmarc75
                Hab den neuen PI mit 8gb schon hier vor mir. Ist fertig konfiguriert und ein neuer iob installiert.
                Irgendwie muss das alte system doch zu sichern sein?
                • DJMarc75
                  Vom "neuen" iob bitte auch mal
                  iob diag
                  zeigen.
                  Jo, dazu gibt es den Adapter "BackitUp".
                  • I
                    Damit arbeite ich ja.
                    Die Sicherungen gehen auf die Fritzbox. Aber jedes Backup hat 0 MB. Weis aber nicht warum
                    • DJMarc75
                      Wir drehen uns im Kreis:
                      https://forum.iobroker.net/topic/70494/backup-größe-iobroker/28?_=1700978716741
                      @djmarc75 sagte in Backup Größe ioBroker:
                      • I
                        @djmarc75
                        Ja, schon verstanden, aber das soll ja nicht bedeuten, dass ich ganz von vorne anfangen muss
                        • I
                          Wenn der Backitup Adapter ja so viel Leistung bindet, dass er kein Backup durchführen kann, muss es doch auch ne andere Lösung geben, ein Backup zu erstellen
                          Marc Berg Homoran 2 Replies Last reply Reply Quote 0
                          • Marc Berg
                            Marc Berg Most Active @IceD112 last edited by
                            Auch wenn es ziemlich wahrscheinlich ist, dass der RAM knapp wird, würde ich trotzdem mal versuchen, das Backup lokal zu speichern, um auszuschließen, dass es am Mount/an der Fritzbox liegt.
                            • I
                              IceD112 @Marc Berg last edited by
                              @marc-berg Dazu mach ich den Haken bei NAS weg und starte eine neue Sicherung?
                              Wo genau finde ich sie dann?
                              • Marc Berg
                                unter /opt/iobroker/backups
                                • I
                                  @marc-berg
                                  Ist es normal dass der Admin Adapter beim Backup neu startet?
                                  Ich verstehe halt nur nicht, ich sicher ja auch JavaScript und da sind Dateien drin, dann dürfte es eigentlich ja nicht am Mount liegen?
                                  Marc Berg 2 Replies Last reply Reply Quote 0
                                  • Marc Berg
                                    Nö, aber das spricht für die RAM Theorie.
                                    • Marc Berg
                                      Ja, ist auch nur ein Versuch, um die Anzahl der Variablen zu reduzieren. Jedenfalls versuche ich mich immer so einem Problem zu nähern. Es KÖNNTE ja sein, dass die Größe der Dateien beim Mount ein Problem ist oder der Speicherplatz nicht reicht.
                                      • I
                                        @marc-berg
                                        Dumme Frage, aber ich nehme an, die SD Karte aus dem 2GB PI in den 8GB Pi stecken, bringt nichts
                                        Was kann ich sonst versuchen?
                                        • Marc Berg
                                          Keine Ahnung, ob das funktioniert. Ein Versuch wäre aber noch, vor dem Backup alle Adapter zu stoppen, um RAM zu sparen. Es geht ja nur darum, das Backup 1x durchzuziehen, richtig?
                                          • I
                                            @marc-berg Richtig, Gute Idee. das probiere ich noch
                                            Und ggf über filezilla irgendwie was sichern? Also falls das andere nicht geht?
                                            7443
