    4. Backup Größe ioBroker
    • I
      IceD112 @Thomas Braun last edited by IceD112
      ok, dann sicher ich grade nochmal ein Backup
      EDIT: Also an der Datei Größe hat sich nicht geändert
      Started iobroker ...
      [DEBUG] [mount] - mount activ... umount is started before mount!!
      [DEBUG] [mount] - umount successfully completed
      [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=ioB_Backup,password=****,noserverino,cache=loose,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.178.1/IceDBox/IOBROKER/ioBroker /opt/iobroker/backups"
      [DEBUG] [mount] - mount successfully completed
      [DEBUG] [mount] - done
      [DEBUG] [iobroker] - host.ioBroker 28368 states saved
      [DEBUG] [iobroker] - host.ioBroker 33321 objects saved
      [DEBUG] [iobroker] - done
      [DEBUG] [javascripts] - Created javascript_tmp directory: "/opt/iobroker/backups/tmpScripts"
      [DEBUG] [javascripts] - found Script: Anwesenheit
      [DEBUG] [javascripts] - found Script: Anwesenheit_Kinder
      [DEBUG] [javascripts] - found Script: Blink-Kamera
      [DEBUG] [javascripts] - found Script: Blink_Kamera
      [DEBUG] [javascripts] - found Script: Garagenlicht
      [DEBUG] [javascripts] - found Script: Licht_Esszimmer_normal
      [DEBUG] [javascripts] - found Script: Weihnachten
      [DEBUG] [javascripts] - found Script: Regenradar
      [DEBUG] [javascripts] - found Script: Rollo_Fenster_Warnung
      [DEBUG] [javascripts] - found Script: Rollo_Schlafzimmer
      [DEBUG] [javascripts] - found Script: Rollo_Wochenende
      [DEBUG] [javascripts] - found Script: Rollo_Wohnzimmer
      [DEBUG] [javascripts] - found Script: Batterieüberwachung
      [DEBUG] [javascripts] - found Script: Fenster_Bad
      [DEBUG] [javascripts] - found Script: Fenster_Status
      [DEBUG] [javascripts] - found Script: Stimmungslicht
      [DEBUG] [javascripts] - found Script: Subwoofer_aus
      [DEBUG] [javascripts] - found Script: Wecker
      [DEBUG] [javascripts] - found Script: Fußball
      [DEBUG] [javascripts] - found Script: Multiroom_starten
      [DEBUG] [javascripts] - found Script: Telegrammbaustein
      [DEBUG] [javascripts] - Try deleting the Javascript tmp directory: "/opt/iobroker/backups/tmpScripts"
      [DEBUG] [javascripts] - Javascript tmp directory "/opt/iobroker/backups/tmpScripts" successfully deleted
      [DEBUG] [javascripts] - Backup created: /opt/iobroker/backups/javascripts_2023_11_25-15_25_43_backupiobroker.tar.gz
      [DEBUG] [javascripts] - done
      [DEBUG] [cifs] - used copy path: /IceDBox/IOBROKER/ioBroker
      [DEBUG] [cifs] - done
      [ERROR] [clean] - Backup files not deleted from /opt/iobroker/backups because some errors.
      [DEBUG] [clean] - done
      [DEBUG] [historyHTML] - new history html values created
      [DEBUG] [historyHTML] - done
      [DEBUG] [historyJSON] - new history json values created
      [DEBUG] [historyJSON] - done
      [DEBUG] [umount] - mount activ, umount is started ...
      [DEBUG] [umount] - umount successfully completed
      [DEBUG] [umount] - done
      [EXIT] 0
      • I
        IceD112 last edited by
        Kann mir niemand beantworten, warum das Backup vom ioBroker nicht funktioniert?
        • DJMarc75
          DJMarc75 @IceD112 last edited by DJMarc75
          @iced112 sagte in Backup Größe ioBroker:
          wie ich ganz oben schon erwähnt habe bist Du "sportlich" unterwegs:
          2GB Ram und 42 Adapter installiert. Da geht bei Dir nichts mehr wenn das Backup startet, denn dieser Start vom Backup braucht auch Speicher.
          • I
            IceD112 @DJMarc75 last edited by IceD112
            @djmarc75
            Hab den neuen PI mit 8gb schon hier vor mir. Ist fertig konfiguriert und ein neuer iob installiert.
            Irgendwie muss das alte system doch zu sichern sein?
            • DJMarc75
              Vom "neuen" iob bitte auch mal
              iob diag
              zeigen.
              Jo, dazu gibt es den Adapter "BackitUp".
              • I
                Damit arbeite ich ja.
                Die Sicherungen gehen auf die Fritzbox. Aber jedes Backup hat 0 MB. Weis aber nicht warum
                • DJMarc75
                  Wir drehen uns im Kreis:
                  https://forum.iobroker.net/topic/70494/backup-größe-iobroker/28?_=1700978716741
                  @djmarc75 sagte in Backup Größe ioBroker:
                  • I
                    @djmarc75
                    Ja, schon verstanden, aber das soll ja nicht bedeuten, dass ich ganz von vorne anfangen muss
                    • I
                      Wenn der Backitup Adapter ja so viel Leistung bindet, dass er kein Backup durchführen kann, muss es doch auch ne andere Lösung geben, ein Backup zu erstellen
                      Marc Berg Homoran 2 Replies Last reply Reply Quote 0
                      • Marc Berg
                        Marc Berg Most Active @IceD112 last edited by
                        Auch wenn es ziemlich wahrscheinlich ist, dass der RAM knapp wird, würde ich trotzdem mal versuchen, das Backup lokal zu speichern, um auszuschließen, dass es am Mount/an der Fritzbox liegt.
                        • I
                          IceD112 @Marc Berg last edited by
                          @marc-berg Dazu mach ich den Haken bei NAS weg und starte eine neue Sicherung?
                          Wo genau finde ich sie dann?
                          • Marc Berg
                            unter /opt/iobroker/backups
                            • I
                              @marc-berg
                              Ist es normal dass der Admin Adapter beim Backup neu startet?
                              Ich verstehe halt nur nicht, ich sicher ja auch JavaScript und da sind Dateien drin, dann dürfte es eigentlich ja nicht am Mount liegen?
                              Marc Berg 2 Replies Last reply Reply Quote 0
                              • Marc Berg
                                Nö, aber das spricht für die RAM Theorie.
                                • Marc Berg
                                  Ja, ist auch nur ein Versuch, um die Anzahl der Variablen zu reduzieren. Jedenfalls versuche ich mich immer so einem Problem zu nähern. Es KÖNNTE ja sein, dass die Größe der Dateien beim Mount ein Problem ist oder der Speicherplatz nicht reicht.
                                  • I
                                    @marc-berg
                                    Dumme Frage, aber ich nehme an, die SD Karte aus dem 2GB PI in den 8GB Pi stecken, bringt nichts
                                    Was kann ich sonst versuchen?
                                    • Marc Berg
                                      Keine Ahnung, ob das funktioniert. Ein Versuch wäre aber noch, vor dem Backup alle Adapter zu stoppen, um RAM zu sparen. Es geht ja nur darum, das Backup 1x durchzuziehen, richtig?
                                      • I
                                        @marc-berg Richtig, Gute Idee. das probiere ich noch
                                        Und ggf über filezilla irgendwie was sichern? Also falls das andere nicht geht?
                                        • Marc Berg
                                          Weiß ich nicht. Geht bestimmt irgendwie, damit holt man sich aber sicher eine Reihe andere Probleme ins Haus.
                                            Homoran Global Moderator Administrators @IceD112 last edited by
                                            tut er nicht!
                                            iob backup wäre der Konsolenbefehl.
                                            Das nutzt dir aber nichts, wei backitup unter der Haube diesen Befehl vetwendet.
                                            Um das Bachup zu packen wird viel RAM benötigt, und das hast du nicht mehr.
                                            Dabei ist es egal, ob du manuell oder per backitup sichern willst.
                                            nein!
                                            dann reicht der RAM nicht und wahrscheinlich startet der gesamte ioBroker neu.
                                            I 2 Replies Last reply Reply Quote 0
                                            7443
