    4. Sayit Adapter- Probleme nach Update
      fvp @Meister Mopper last edited by
      @meister-mopper Ich habe meinen Pi mal zum testen rausgekramt und aktualisiert. (Bullseye aktuell ; Node 18.18.2; ioBroker aktuell).
      Audio über 3,5mm.
      Sayit mit V3.0.5 ohne Vorversion
      Auch hier leider kein Ankündigungston.
      Getestet mit Typ System , Player mplayer und mpg321
      Meldungen im Log für mplayer
      sayit.0
      	2023-10-22 09:52:33.051	info	saying: hallo
      sayit.0
      	2023-10-22 09:52:27.724	error	amixer is not available, so you may hear no audio. Install manually!
      sayit.0
      	2023-10-22 09:52:27.719	error	stderr: amixer: Cannot find the given element from control default
      sayit.0
      	2023-10-22 09:52:27.635	error	Cannot write file: TypeError [ERR_INVALID_ARG_TYPE]: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
      sayit.0
      	2023-10-22 09:52:27.564	info	Upload announce mp3 files
      sayit.0
      	2023-10-22 09:52:27.524	info	starting. Version 3.0.5 in /opt/iobroker/node_modules/iobroker.sayit, node: v18.18.2, js-controller: 5.0.12
      Meldungen im Log für mpg321:
      sayit.0
      	2023-10-22 09:54:46.984	error	stderr: [0:00] Decoding of sayit.0.say.mp3 finished.
      sayit.0
      	2023-10-22 09:54:46.181	error	stderr: Directory: /opt/iobroker/iobroker-data/sayitPlaying MPEG stream from sayit.0.say.mp3 ...MPEG 2.0 layer III, 32 kbit/s, 24000 Hz mono
      sayit.0
      	2023-10-22 09:54:46.178	error	stderr: High Performance MPEG 1.0/2.0/2.5 Audio Player for Layer 1, 2, and 3.Version 0.3.2-1 (2012/03/25). Written and copyrights by Joe Drew,now maintained by Nanakos Chrysostomos and others.Uses code from various people. See 'README' for more!THIS SOFTWARE COMES WITH ABSOLUTELY NO WARRANTY! USE AT YOUR OWN RISK!tcgetattr(): Inappropriate ioctl for device
      sayit.0
      	2023-10-22 09:54:45.542	info	saying: Hallo
      sayit.0
      	2023-10-22 09:54:26.780	error	Cannot write file: TypeError [ERR_INVALID_ARG_TYPE]: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
      sayit.0
      	2023-10-22 09:54:26.701	info	Upload announce mp3 files
      sayit.0
      	2023-10-22 09:54:26.660	info	starting. Version 3.0.5 in /opt/iobroker/node_modules/iobroker.sayit, node: v18.18.2, js-controller: 5.0.12
      Auch das von @Bernd_M beschriebene Verhalten in der Oberfläche kann ich bestätigen.
        do5tj80 @fvp last edited by
        ich habe das Ankündigungston Problem leider auch.
        Ich denke da passt was im Code nicht:
        Leider bin ich da nicht wirklich fit drin sonst würde ich mir das mal ansehen.
        • DJMarc75
          DJMarc75 @do5tj80 last edited by
          @do5tj80 sagte in Sayit Adapter- Probleme nach Update:
          ob Du gewillt bist die Ausgabe von
          iob diag
          hier zu posten ?
          Bitte in Codetags und die Langfassung
            do5tj80 @DJMarc75 last edited by
            @djmarc75 said in Sayit Adapter- Probleme nach Update:
            iob diag
            v.2023-10-10
            Static hostname: iobroker
            Icon name: computer-vm
            Chassis: vm
            Virtualization: kvm
            Operating System: Debian GNU/Linux 11 (bullseye)
            Kernel: Linux 5.10.0-16-amd64
            Architecture: x86-64
            Installation: kvm
            Kernel: x86_64
            Userland: amd64
            Timezone: Europe/Berlin (CET, +0100)
            User-ID: 1000
            X-Server: false
            Boot Target: graphical.target
            Pending OS-Updates: 0
            Pending iob updates: 2
            This system needs to be REBOOTED NOW!
            ./diag.sh: line 486: nodejs: command not found
            Nodejs-Installation:
            /usr/bin/node v16.20.2
            /usr/bin/npm 8.19.4
            /usr/bin/npx 8.19.4
            /usr/bin/corepack 0.17.0
            Recommended versions are nodejs 18.18.2 and npm 9.8.1
            *** nodejs is NOT correctly installed ***
            Wrong installation path detected. This needs to be fixed.
            Please check
            https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian
            for more information on how to fix these errors.
            MEMORY:
            total used free shared buff/cache available
            Mem: 4.9G 4.2G 276M 0.0K 485M 513M
            Swap: 11G 1.7G 9.5G
            Total: 16G 5.9G 9.8G
            Active iob-Instances: 58
            Active repo(s): stable
            ioBroker Core: js-controller 5.0.16
            admin 6.12.0
            ioBroker Status: iobroker is running on this host.
            Objects type: jsonl
            States type: jsonl
            • system.adapter.admin.0 : admin : iobroker - enabled, port: 8081, bind: 0.0.0.0, run as: admin
            • system.adapter.web.0 : web : iobroker - enabled, port: 8082, bind: 0.0.0.0, run as: admin
            Objects: 54381
            States: 44373
            Size of iob-Database:
            63M /opt/iobroker/iobroker-data/objects.jsonl
            12M /opt/iobroker/iobroker-data/states.jsonl
              @djmarc75
              Wie komme ich an die Langfassung?
              DJMarc75 bahnuhr 2 Replies Last reply Reply Quote 0
              • DJMarc75
                indem Du nach der Ausgabe der Langfassung keine Taste drückst und Du dann auch, wie geschrieben, die Langfassung hier in CODETAGS einfügst
                Siehe hier:
                https://forum.iobroker.net/topic/51555/hinweise-für-gute-forenbeiträge
                • bahnuhr
                  bahnuhr Forum Testing Most Active @do5tj80 last edited by
                  @do5tj80
                  das was vorher kam kopieren.
                  @Thomas-Braun
                  Vielleicht solltest du das wirklich mal umstellen.
                    do5tj80 last edited by do5tj80
                    Skript v.2023-10-10
                    *** BASE SYSTEM ***
                               Chassis: vm
                        Virtualization: kvm
                    model name      : Common KVM processor
                    Docker          : false
                    Virtualization  : kvm
                    Kernel          : x86_64
                    Userland        : amd64
                    Systemuptime and Load:
                     18:29:23 up 7 days,  3:46,  1 user,  load average: 0.75, 0.84, 0.89
                    CPU threads: 4
                    This system needs to be REBOOTED!
                    *** Time and Time Zones ***
                                   Local time: Sun 2023-11-26 18:29:23 CET
                               Universal time: Sun 2023-11-26 17:29:23 UTC
                                     RTC time: Sun 2023-11-26 17:29:24
                                  NTP service: active
                              RTC in local TZ: no
                    *** User and Groups ***
                    thuebner
                    /home/thuebner
                    thuebner cdrom floppy audio dip video plugdev netdev
                    *** X-Server-Setup ***
                    X-Server:       false
                    Desktop:
                    Terminal:       tty
                    *** MEMORY ***
                    Mem:            4.9G        4.1G        357M        0.0K        492M        601M
                    Swap:            11G        1.7G        9.5G
                    Total:           16G        5.8G        9.8G
                             4933 M total memory
                             4082 M used memory
                             2900 M active memory
                             1305 M inactive memory
                              357 M free memory
                              102 M buffer memory
                              390 M swap cache
                            11215 M total swap
                             1727 M used swap
                             9488 M free swap
                    *** FAILED SERVICES ***
                    0 loaded units listed.
                    *** FILESYSTEM ***
                    Filesystem                    Type      Size  Used Avail Use% Mounted on
                    udev                          devtmpfs  2.4G     0  2.4G   0% /dev
                    tmpfs                         tmpfs     494M  572K  493M   1% /run
                    /dev/mapper/iobroker--vg-root ext4       38G  9.4G   27G  27% /
                    tmpfs                         tmpfs     2.5G     0  2.5G   0% /dev/shm
                    tmpfs                         tmpfs     5.0M     0  5.0M   0% /run/lock
                    /dev/vda1                     ext2      470M   86M  360M  20% /boot
                    tmpfs                         tmpfs     494M     0  494M   0% /run/user/0
                    [sudo] password for thuebner:
                    Sorry, user thuebner is not allowed to execute '/usr/bin/dmesg -T' as root on iobroker.huebner.local.
                    TARGET  SOURCE                        FSTYPE OPTIONS
                    /       /dev/mapper/iobroker--vg-root ext4   rw,relatime,errors=remount-ro
                    `-/boot /dev/vda1                     ext2   rw,relatime
                    /var:
                    Sorry, user thuebner is not allowed to execute '/usr/bin/du -h /var/' as root on iobroker.huebner.local.
                    Archived and active journals take up 16.0M in the file system.
                    /opt/iobroker/backups:
                    101M    /opt/iobroker/backups/
                    /opt/iobroker/iobroker-data:
                    772M    /opt/iobroker/iobroker-data/
                    557M    /opt/iobroker/iobroker-data/files
                    133M    /opt/iobroker/iobroker-data/backup-objects
                    89M     /opt/iobroker/iobroker-data/files/vis-2-beta
                    67M     /opt/iobroker/iobroker-data/files/javascript.admin
                    65M     /opt/iobroker/iobroker-data/objects.jsonl
                    35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
                    33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
                    21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
                    18M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.274a4d8d.js.map
                    USB-Devices by-id:
                    /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2426815-if00
                    *** NodeJS-Installation ***
                    ./diag.sh: line 277: nodejs: command not found
                    /usr/bin/npm            8.19.4
                    /usr/bin/npx            8.19.4
                    ./diag.sh: line 288: nodejs: command not found
                    nodejs:
                      Installed: 16.20.2-deb-1nodesource1
                      Candidate: 16.20.2-deb-1nodesource1
                      Version table:
                     *** 16.20.2-deb-1nodesource1 500
                            500 https://deb.nodesource.com/node_16.x bullseye/main amd64 Packages
                            100 /var/lib/dpkg/status
                         12.22.12~dfsg-1~deb11u4 500
                            500 http://ftp.tu-chemnitz.de/debian bullseye/main amd64 Packages
                            500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages
                         10.24.0~dfsg-1~deb10u1 500
                            500 http://ftp.de.debian.org/debian buster/main amd64 Packages
                    No problems detected
                    Errors in npm tree:
                    npm ERR! code ELSPROBLEMS
                    npm ERR! missing: node-ssh@^13.1.0, required by iobroker.javascript@7.1.6
                    npm ERR!     /home/thuebner/.npm/_logs/2023-11-26T17_29_31_386Z-debug-0.log
                    *** ioBroker-Installation ***
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    Core adapters versions
                    js-controller:  5.0.16
                    admin:          6.12.0
                    javascript:     7.1.6
                    Adapters from github:   5
                    Adapter State
                    + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                    + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
                    + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                    + system.adapter.bring.0                  : bring                 : iobroker                                 -  enabled
                      system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
                    + system.adapter.device-reminder.0        : device-reminder       : iobroker                                 -  enabled
                      system.adapter.devices.0                : devices               : iobroker                                 -  enabled
                    + system.adapter.email.0                  : email                 : iobroker                                 -  enabled
                    + system.adapter.ems-esp.0                : ems-esp               : iobroker                                 -  enabled
                    + system.adapter.energiefluss.0           : energiefluss          : iobroker                                 -  enabled
                    + system.adapter.evcc.0                   : evcc                  : iobroker                                 -  enabled, port: 7070
                    + system.adapter.evcc.1                   : evcc                  : iobroker                                 -  enabled, port: 7071
                    + system.adapter.fronius.0                : fronius               : iobroker                                 -  enabled
                    + system.adapter.fronius.1                : fronius               : iobroker                                 -  enabled
                    + system.adapter.fronius.2                : fronius               : iobroker                                 -  enabled
                      system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 - disabled
                    + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
                    + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
                    + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
                    + system.adapter.hm-rpc.2                 : hm-rpc                : iobroker                                 -  enabled, port: 0
                      system.adapter.ical.1                   : ical                  : iobroker                                 -  enabled
                      system.adapter.ical.2                   : ical                  : iobroker                                 -  enabled
                      system.adapter.ical.3                   : ical                  : iobroker                                 -  enabled
                      system.adapter.ical.4                   : ical                  : iobroker                                 -  enabled
                      system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : iobroker                                 -  enabled
                      system.adapter.icons-material-png.0     : icons-material-png    : iobroker                                 -  enabled
                      system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 -  enabled
                      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 -  enabled
                    + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
                    + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
                    + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
                    + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                      system.adapter.km200.0                  : km200                 : iobroker                                 - disabled
                    + system.adapter.knx.0                    : knx                   : iobroker                                 -  enabled, bind: 192.168.3.15
                    + system.adapter.lgtv.0                   : lgtv                  : iobroker                                 -  enabled
                    + system.adapter.mielecloudservice.0      : mielecloudservice     : iobroker                                 -  enabled
                    + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 192.168.3.15
                    + system.adapter.nut.0                    : nut                   : iobroker                                 -  enabled
                      system.adapter.owfs.0                   : owfs                  : iobroker                                 - disabled, port: 4304
                    + system.adapter.phantomjs.0              : phantomjs             : iobroker                                 -  enabled
                    + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
                      system.adapter.proxmox.0                : proxmox               : iobroker                                 - disabled, port: 8006
                    + system.adapter.pvforecast.0             : pvforecast            : iobroker                                 -  enabled
                    + system.adapter.roomba.0                 : roomba                : iobroker                                 -  enabled
                      system.adapter.s7.0                     : s7                    : iobroker                                 - disabled
                    + system.adapter.sainlogic.0              : sainlogic             : iobroker                                 -  enabled, port: 45000, bind: 192.168.3.15
                    + system.adapter.samsung.0                : samsung               : iobroker                                 -  enabled
                    + system.adapter.sayit.0                  : sayit                 : iobroker                                 -  enabled
                    + system.adapter.scenes.0                 : scenes                : iobroker                                 -  enabled
                    + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
                    + system.adapter.shelly.1                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                    + system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker                                 -  enabled
                    + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                    + system.adapter.socketio.0               : socketio              : iobroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
                    + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1884, bind: 0.0.0.0
                    + system.adapter.sonos.0                  : sonos                 : iobroker                                 -  enabled
                    + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
                    + system.adapter.sql.0                    : sql                   : iobroker                                 -  enabled, port: 3307
                    + system.adapter.synology.0               : synology              : iobroker                                 -  enabled, port: 5000
                    + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                    + system.adapter.text2command.0           : text2command          : iobroker                                 -  enabled
                    + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
                    + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
                    + system.adapter.unifi.0                  : unifi                 : iobroker                                 -  enabled
                    + system.adapter.vis-2-beta.0             : vis-2-beta            : iobroker                                 -  enabled
                      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 -  enabled
                      system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 -  enabled
                    + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
                      system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
                      system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
                    + system.adapter.vw-connect.0             : vw-connect            : iobroker                                 -  enabled
                    + system.adapter.vw-connect.1             : vw-connect            : iobroker                                 -  enabled
                    + system.adapter.vw-connect.2             : vw-connect            : iobroker                                 -  enabled
                    + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                    + system.adapter.wled.0                   : wled                  : iobroker                                 -  enabled
                    + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: /dev/ttyACM0
                    + instance is alive
                    ioBroker-Repositories
                    Installed ioBroker-Instances
                    Used repository: stable
                    Adapter    "admin"        : 6.12.0   , installed 6.12.0
                    Adapter    "alexa2"       : 3.26.1   , installed 3.26.1
                    Adapter    "backitup"     : 2.8.7    , installed 2.8.7
                    Adapter    "bring"        : 1.8.4    , installed 1.8.4
                    Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
                    Adapter    "device-reminder": 3.0.0  , installed 3.0.0
                    Adapter    "email"        : 1.2.0    , installed 1.2.0
                    Adapter    "ems-esp"      : 2.6.1    , installed 2.6.2
                    Adapter    "evcc"         : 0.0.10   , installed 0.0.10
                    Adapter    "fronius"      : 2.0.2    , installed 2.0.2
                    Adapter    "fullybrowser" : 3.0.6    , installed 2.2.0  [Updatable]
                    Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
                    Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
                    Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
                    Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
                    Adapter    "iot"          : 2.0.11   , installed 2.0.11
                    Adapter    "javascript"   : 7.1.6    , installed 7.1.6
                    Controller "js-controller": 5.0.16   , installed 5.0.16
                    Adapter    "km200"        : 2.0.3    , installed 2.0.3
                    Adapter    "knx"          : 2.0.23   , installed 2.0.23
                    Adapter    "lgtv"         : 2.1.2    , installed 2.1.2
                    Adapter    "mielecloudservice": 6.5.4, installed 6.5.4
                    Adapter    "modbus"       : 5.0.11   , installed 5.0.11
                    Adapter    "mqtt"         : 5.1.0    , installed 5.1.0
                    Adapter    "nina"         : 0.0.25   , installed 0.0.25
                    Adapter    "nut"          : 1.6.0    , installed 1.6.0
                    Adapter    "owfs"         : 0.7.0    , installed 0.7.0
                    Adapter    "phantomjs"    : 1.1.3    , installed 1.1.3
                    Adapter    "proxmox"      : 2.2.1    , installed 2.2.1
                    Adapter    "pvforecast"   : 2.9.0    , installed 2.9.0
                    Adapter    "roomba"       : 1.2.2    , installed 1.2.2
                    Adapter    "s7"           : 1.3.15   , installed 1.3.15
                    Adapter    "sainlogic"    : 0.10.5   , installed 0.10.5
                    Adapter    "samsung"      : 0.5.11   , installed 0.5.11
                    Adapter    "sayit"        : 3.0.5    , installed 3.0.5
                    Adapter    "shelly"       : 6.6.1    , installed 6.6.1
                    Adapter    "shuttercontrol": 1.6.3   , installed 1.6.3
                    Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
                    Adapter    "sonos"        : 3.0.0    , installed 3.0.0
                    Adapter    "spotify-premium": 1.3.1  , installed 1.3.1
                    Adapter    "sql"          : 2.2.0    , installed 2.2.0
                    Adapter    "squeezeboxrpc": 1.3.9    , installed 1.3.9
                    Adapter    "synology"     : 3.0.1    , installed 3.0.1
                    Adapter    "telegram"     : 2.0.1    , installed 2.0.1
                    Adapter    "text2command" : 3.0.2    , installed 3.0.2
                    Adapter    "trashschedule": 2.3.0    , installed 2.3.0
                    Adapter    "unifi"        : 0.6.6    , installed 0.6.6
                    Adapter    "vis"          : 1.4.16   , installed 1.4.16
                    Adapter    "vis-icontwo"  : 0.97.1   , installed 0.97.1
                    Adapter    "vis-justgage" : 2.0.2    , installed 2.0.1  [Updatable]
                    Adapter    "vw-connect"   : 0.0.67   , installed 0.0.67
                    Adapter    "web"          : 6.1.10   , installed 6.1.10
                    Adapter    "wled"         : 0.7.1    , installed 0.7.1
                    Adapter    "ws"           : 2.5.8    , installed 2.5.8
                    Adapter    "zigbee"       : 1.8.24   , installed 1.8.24
                    Objects and States
                    Objects:        54381
                    States:         44373
                    Sorry, user thuebner is not allowed to execute '/usr/bin/apt-get update' as root on iobroker.huebner.local.
                    Pending Updates: 0
                    *** Listening Ports ***
                    Sorry, user thuebner is not allowed to execute '/usr/bin/netstat -tulpen' as root on iobroker.huebner.local.
                    2023-11-26 18:30:06.044  - debug: ical.4 (291961) ev: {"type":"VEVENT","params":[],"start":"2023-10-24T15:00:00.000Z","datetype":"date-time","end":"2023-10-24T16:00:00.000Z","dtstamp":"2023-11-26T17:30:05.000Z","organizer":{"params":{"CN":"do5tj80@gmail.com"},"val":"mailto:do5tj80@gmail.com"},"uid":"f79t37oti7bdm0js41njjjgbic@google.com","attendee":[{"params":{"CUTYPE":"INDIVIDUAL","ROLE":"REQ-PARTICIPANT","PARTSTAT":"NEEDS-ACTION","CN":"huebner.justus.paul@gmail.com","X-NUM-GUESTS":0},"val":"mailto:huebner.justus.paul@gmail.com"},{"params":{"CUTYPE":"INDIVIDUAL","ROLE":"REQ-PARTICIPANT","PARTSTAT":"NEEDS-ACTION","CN":"huebner.ann@googlemail.com","X-NUM-GUESTS":0},"val":"mailto:huebner.ann@googlemail.com"},{"params":{"CUTYPE":"INDIVIDUAL","ROLE":"REQ-PARTICIPANT","PARTSTAT":"NEEDS-ACTION","CN":"huebner.clara.lena@gmail.com","X-NUM-GUESTS":0},"val":"mailto:huebner.clara.lena@gmail.com"},{"params":{"CUTYPE":"INDIVIDUAL","ROLE":"REQ-PARTICIPANT","PARTSTAT":"ACCEPTED","CN":"do5tj80@gmail.com","X-NUM-GUESTS":0},"val":"mailto:do5tj80@gmail.com"}],"GOOGLE-CONFERENCE":"https://meet.google.com/xyu-para-npo","created":"2023-10-23T04:49:38.000Z","description":"Über Google Meet teilnehmen: https://meet.google.com/xyu-para-npo\n\nWeitere Informationen zu Meet: https://support.google.com/a/users/answer/9282720","lastmodified":"2023-10-23T04:49:40.000Z","location":"Festplatz Gelenau, Ernst-Grohmann-Straße, 09423 Gelenau/Erzgeb., Deutschland","sequence":"0","status":"CONFIRMED","summary":"Altpapiersammlung","transparency":"OPAQUE","method":"PUBLISH"}
                    2023-11-26 18:30:06.045  - debug: ical.4 (291961) Single event: Altpapiersammlung; start:Tue Oct 24 2023 17:00:00 GMT+0200 (Mitteleuropäische Sommerzeit); end:Tue Oct 24 2023 18:00:00 GMT+0200 (Mitteleuropäische Sommerzeit); endpreview:Sun Dec 03 2023 18:30:06 GMT+0100 (Mitteleuropäische Normalzeit); startpreview:Sun Nov 26 2023 00:00:00 GMT+0100 (Mitteleuropäische Normalzeit); realnow:Sun Nov 26 2023 18:30:06 GMT+0100 (Mitteleuropäische Normalzeit)
                    2023-11-26 18:30:06.045  - debug: ical.4 (291961) Event (time) processing. Start: Tue Oct 24 2023 17:00:00 GMT+0200 (Mitteleuropäische Sommerzeit) End: Tue Oct 24 2023 18:00:00 GMT+0200 (Mitteleuropäische Sommerzeit)
                    2023-11-26 18:30:06.045  - debug: ical.4 (291961) Event " " Altpapiersammlung at Tue Oct 24 2023 17:00:00 GMT+0200 (Mitteleuropäische Sommerzeit) filtered out, because does not belongs to specified time interval
                    2023-11-26 18:30:06.045  - debug: ical.4 (291961) ev: {"type":"VEVENT","params":[],"start":"2023-10-24T15:30:00.000Z","datetype":"date-time","end":"2023-10-24T16:30:00.000Z","dtstamp":"2023-11-26T17:30:05.000Z","organizer":{"params":{"CN":"huebner.justus.paul@gmail.com"},"val":"mailto:huebner.justus.paul@gmail.com"},"uid":"A1E9AD76-8D6D-45B2-A4B7-D22ABDCB3D61","attendee":[{"params":{"CUTYPE":"INDIVIDUAL","ROLE":"REQ-PARTICIPANT","PARTSTAT":"ACCEPTED","CN":"do5tj80@gmail.com","X-NUM-GUESTS":0},"val":"mailto:do5tj80@gmail.com"},{"params":{"CUTYPE":"INDIVIDUAL","ROLE":"REQ-PARTICIPANT","PARTSTAT":"ACCEPTED","CN":"huebner.clara.lena@gmail.com","X-NUM-GUESTS":0},"val":"mailto:huebner.clara.lena@gmail.com"},{"params":{"CUTYPE":"INDIVIDUAL","ROLE":"REQ-PARTICIPANT","PARTSTAT":"ACCEPTED","CN":"huebner.justus.paul@gmail.com","X-NUM-GUESTS":0},"val":"mailto:huebner.justus.paul@gmail.com"}],"GOOGLE-CONFERENCE":"https://meet.google.com/cdk-spjy-ptp","created":"2023-09-26T14:47:05.000Z","description":"Über Google Meet teilnehmen: https://meet.google.com/cdk-spjy-ptp\n\nWeitere Informationen zu Meet: https://support.google.com/a/users/answer/9282720","lastmodified":"2023-10-24T01:42:18.000Z","sequence":"1","status":"CONFIRMED","summary":"Bibo Gelenau","transparency":"OPAQUE","APPLE-CREATOR-IDENTITY":"com.apple.mobilecal","APPLE-CREATOR-TEAM-IDENTITY":"0000000000","method":"PUBLISH"}
                    2023-11-26 18:30:06.045  - debug: ical.4 (291961) Single event: Bibo Gelenau; start:Tue Oct 24 2023 17:30:00 GMT+0200 (Mitteleuropäische Sommerzeit); end:Tue Oct 24 2023 18:30:00 GMT+0200 (Mitteleuropäische Sommerzeit); endpreview:Sun Dec 03 2023 18:30:06 GMT+0100 (Mitteleuropäische Normalzeit); startpreview:Sun Nov 26 2023 00:00:00 GMT+0100 (Mitteleuropäische Normalzeit); realnow:Sun Nov 26 2023 18:30:06 GMT+0100 (Mitteleuropäische Normalzeit)
                    2023-11-26 18:30:06.045  - debug: ical.4 (291961) Event (time) processing. Start: Tue Oct 24 2023 17:30:00 GMT+0200 (Mitteleuropäische Sommerzeit) End: Tue Oct 24 2023 18:30:00 GMT+0200 (Mitteleuropäische Sommerzeit)
                    2023-11-26 18:30:06.045  - debug: ical.4 (291961) Event " " Bibo Gelenau at Tue Oct 24 2023 17:30:00 GMT+0200 (Mitteleuropäische Sommerzeit) filtered out, because does not belongs to specified time interval
                    2023-11-26 18:30:06.045  - debug: ical.4 (291961) displaying dates because of callback
                    2023-11-26 18:30:06.046  - debug: ical.4 (291961) Dates array (data.table): [{"date":"Day After Tomorrow 15:15-16:45","event":"Pippisport","_class":"ical_Tischdienst Justus ical_dayafter","_date":"2023-11-28T14:15:00.000Z","_end":"2023-11-28T15:45:00.000Z","_IDID":"1spa6nra1auon528393aj0gk9n@google.com","_allDay":false,"_private":false,"_rule":" ","location":"Ringerhalle","_calName":"Tischdienst Justus","_calColor":"#186804","_object":{"type":"VEVENT","params":[],"start":"2023-11-28T14:15:00.000Z","datetype":"date-time","end":"2023-11-28T15:45:00.000Z","dtstamp":"2023-11-26T17:30:05.000Z","uid":"1spa6nra1auon528393aj0gk9n@google.com","created":"2023-09-28T15:35:00.000Z","lastmodified":"2023-09-28T15:35:00.000Z","location":"Ringerhalle","sequence":"0","status":"CONFIRMED","summary":"Pippisport","transparency":"OPAQUE","method":"PUBLISH"}},{"date":"In 4 days 16:30-17:30","event":"Reiten","_class":"ical_Tischdienst Clara ical_4days","_date":"2023-11-30T15:30:00.000Z","_end":"2023-11-30T16:30:00.000Z","_IDID":"1uksojk6m1bp444avbrev14dgg@google.com","_allDay":false,"_private":false,"_rule":" rrule ","location":"Scharfensteiner Str. 24, 09430 Drebach","_calName":"Tischdienst Clara","_calColor":"#e307ff","_object":{"type":"VEVENT","params":[],"start":"2023-11-30T15:30:00.000Z","datetype":"date-time","end":"2023-11-30T16:30:00.000Z","rrule":{"_cache":{"all":false,"before":[],"after":[],"between":[]},"origOptions":{"tzid":"Europe/Berlin","dtstart":"2023-09-07T14:30:00.000Z","freq":2,"byweekday":[{"weekday":3}]},"options":{"freq":2,"dtstart":"2023-09-07T14:30:00.000Z","interval":1,"wkst":0,"count":null,"until":null,"tzid":"Europe/Berlin","bysetpos":null,"bymonth":null,"bymonthday":[],"bynmonthday":[],"byyearday":null,"byweekno":null,"byweekday":[3],"bynweekday":null,"byhour":[14],"byminute":[30],"bysecond":[0],"byeaster":null}},"dtstamp":"2023-11-26T17:30:05.000Z","uid":"1uksojk6m1bp444avbrev14dgg@google.com","created":"2023-09-08T09:18:39.000Z","lastmodified":"2023-09-08T09:18:39.000Z","location":"Scharfensteiner Str. 24, 09430 Drebach","sequence":"0","status":"CONFIRMED","summary":"Reiten","transparency":"OPAQUE","method":"PUBLISH"}}]
                    2023-11-26 18:30:06.137  - debug: ical.4 (291961)     todayOnly = false: (Tue Nov 28 2023 15:15:00 GMT+0100 (Mitteleuropäische Normalzeit)-Tue Nov 28 2023 16:45:00 GMT+0100 (Mitteleuropäische Normalzeit)), alreadyStarted=false
                    2023-11-26 18:30:06.138  - debug: ical.4 (291961)     todayOnly = false: (Thu Nov 30 2023 16:30:00 GMT+0100 (Mitteleuropäische Normalzeit)-Thu Nov 30 2023 17:30:00 GMT+0100 (Mitteleuropäische Normalzeit)), alreadyStarted=false
                    2023-11-26 18:30:06.190  - debug: ical.4 (291961)     todayOnly = false: (Tue Nov 28 2023 15:15:00 GMT+0100 (Mitteleuropäische Normalzeit)-Tue Nov 28 2023 16:45:00 GMT+0100 (Mitteleuropäische Normalzeit)), alreadyStarted=false
                    2023-11-26 18:30:06.190  - debug: ical.4 (291961)     todayOnly = false: (Thu Nov 30 2023 16:30:00 GMT+0100 (Mitteleuropäische Normalzeit)-Thu Nov 30 2023 17:30:00 GMT+0100 (Mitteleuropäische Normalzeit)), alreadyStarted=false
                    2023-11-26 18:30:06.205  - debug: ical.4 (291961) Checking unprocessed event 0 today Tischdienst = false, state = false
                    2023-11-26 18:30:06.205  - debug: ical.4 (291961) Checking unprocessed event 0 now Tischdienst = false, state = false
                    2023-11-26 18:30:06.205  - debug: ical.4 (291961) Checking unprocessed event 0 later Tischdienst = false, state = false
                    2023-11-26 18:30:06.205  - debug: ical.4 (291961) Checking unprocessed event 1 null Tischdienst = false, state = false
                    2023-11-26 18:30:06.206  - debug: ical.4 (291961) Checking unprocessed event 2 null Tischdienst = false, state = false
                    2023-11-26 18:30:06.206  - debug: ical.4 (291961) Checking unprocessed event 3 null Tischdienst = false, state = false
                    2023-11-26 18:30:06.206  - debug: ical.4 (291961) Checking unprocessed event 4 null Tischdienst = false, state = false
                    2023-11-26 18:30:06.206  - debug: ical.4 (291961) Checking unprocessed event 5 null Tischdienst = false, state = false
                    2023-11-26 18:30:06.206  - debug: ical.4 (291961) Checking unprocessed event 6 null Tischdienst = false, state = false
                    2023-11-26 18:30:06.206  - debug: ical.4 (291961) Checking unprocessed event 7 null Tischdienst = false, state = false
                    2023-11-26 18:30:09.348  - info: ical.3 (291984) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                    iob diag has finished.
                      Thomas Braun Most Active @do5tj80 last edited by
                      Mach das...
                      Zuvor
                      iob nodejs-update
                        do5tj80 @Thomas Braun last edited by
                        thuebner@iobroker:~$ iob nodejs-update
                        iobroker nodejs-update [<major-version>]
                        Upgrade the Node.JS installation to the current LTS
                        Options:
                          --help  Show help  [boolean]
                        mehr kommt da nicht.
                          @do5tj80
                          iob stop
                          iob fix
                          iob nodejs-update
                          Und setz den User in die Gruppen 'sudo' und 'iobroker' rein.
                            Skript v.2023-10-10
                            *** BASE SYSTEM ***
                                       Chassis: vm
                                Virtualization: kvm
                                        Kernel: Linux 5.10.0-26-amd64
                            Docker          : false
                            Kernel          : x86_64
                            Userland        : amd64
                             18:49:14 up 5 min,  1 user,  load average: 1.05, 0.95, 0.45
                            CPU threads: 4
                                           Local time: Sun 2023-11-26 18:49:14 CET
                                       Universal time: Sun 2023-11-26 17:49:14 UTC
                                             RTC time: Sun 2023-11-26 17:49:15
                                          NTP service: active
                                      RTC in local TZ: no
                            thuebner
                            /home/thuebner
                            thuebner cdrom floppy sudo audio dip video plugdev netdev iobroker
                            X-Server:       false
                            Desktop:
                            Terminal:       tty
                            *** MEMORY ***
                            Mem:            4.9G        3.7G        817M        0.0K        410M        1.0G
                            Swap:            11G          0B         11G
                            Total:           16G        3.7G         12G
                                     4921 M total memory
                                     3693 M used memory
                                      159 M active memory
                                     3645 M inactive memory
                                      816 M free memory
                                       50 M buffer memory
                                      359 M swap cache
                                    11215 M total swap
                                        0 M used swap
                                    11215 M free swap
                            *** FILESYSTEM ***
                            tmpfs                         tmpfs     493M  540K  492M   1% /run
                            tmpfs                         tmpfs     493M     0  493M   0% /run/user/0
                            [Sun Nov 26 18:43:36 2023] EXT4-fs (dm-0): mounted filesystem with ordered data mode. Opts: (null)
                            [Sun Nov 26 18:43:36 2023] EXT4-fs (dm-0): re-mounted. Opts: errors=remount-ro
                            [Sun Nov 26 18:43:36 2023] EXT4-fs (vda1): mounting ext2 file system using the ext4 subsystem
                            [Sun Nov 26 18:43:36 2023] EXT4-fs (vda1): mounted filesystem without journal. Opts: (null)
                            /var:
                            2.8G    /var/
                            2.2G    /var/log/journal/14cb46b5198d45d6a08ee6b6ab2c73d2
                            2.2G    /var/log
                            382M    /var/cache
                            Archived and active journals take up 32.0M in the file system.
                            754M    /opt/iobroker/iobroker-data/
                            46M     /opt/iobroker/iobroker-data/objects.jsonl
                            USB-Devices by-id:
                            /usr/bin/nodejs         v18.18.2
                            /usr/bin/node           v18.18.2
                            /usr/bin/npm            9.8.1
                            /usr/bin/npx            9.8.1
                            /usr/bin/corepack       0.19.0
                            nodejs:
                              Installed: 18.18.2-1nodesource1
                              Candidate: 18.18.2-1nodesource1
                              Version table:
                             *** 18.18.2-1nodesource1 1001
                                    500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                                 18.18.1-1nodesource1 1001
                                 18.18.0-1nodesource1 1001
                                 18.17.1-1nodesource1 1001
                                 18.17.0-1nodesource1 1001
                                 18.16.1-1nodesource1 1001
                                 18.16.0-1nodesource1 1001
                                 18.15.0-1nodesource1 1001
                                 18.14.2-1nodesource1 1001
                                 18.14.1-1nodesource1 1001
                                 18.14.0-1nodesource1 1001
                                 18.13.0-1nodesource1 1001
                                 18.12.0-1nodesource1 1001
                                 18.11.0-1nodesource1 1001
                                 18.10.0-1nodesource1 1001
                                 18.9.1-1nodesource1 1001
                                 18.9.0-1nodesource1 1001
                                 18.8.0-1nodesource1 1001
                                 18.7.0-1nodesource1 1001
                                 18.6.0-1nodesource1 1001
                                 18.5.0-1nodesource1 1001
                                 18.4.0-1nodesource1 1001
                                 18.3.0-1nodesource1 1001
                                 18.2.0-1nodesource1 1001
                                 18.1.0-1nodesource1 1001
                                 18.0.0-1nodesource1 1001
                            Errors in npm tree:
                            ioBroker Status
                            Objects type: jsonl
                            States  type: jsonl
                            admin:          6.12.0
                            javascript:     7.1.6
                            Adapter State
                            + instance is alive
                            Objects and States
                            Objects:        54381
                            States:         44412
                            Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
                            Hit:2 https://repos.influxdata.com/debian stable InRelease
                            Hit:3 http://ftp.de.debian.org/debian buster InRelease
                            Hit:4 http://ftp.tu-chemnitz.de/debian bullseye InRelease
                            Hit:5 http://ftp.tu-chemnitz.de/debian bullseye-updates InRelease
                            Hit:6 https://deb.nodesource.com/node_18.x nodistro InRelease
                            Reading package lists... Done
                            Pending Updates: 0
                            tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       11979      416/iobroker.js-con
                            tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       13463      416/iobroker.js-con
                            tcp        0      0 192.168.3.15:9292       0.0.0.0:*               LISTEN      1001       13788      596/io.hm-rpc.0
                            tcp        0      0 0.0.0.0:55597           0.0.0.0:*               LISTEN      107        17824      950/rpc.statd
                            tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          11441      1/init
                            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13445      430/sshd: /usr/sbin
                            tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       15027      784/io.shelly.1
                            tcp        0      0 192.168.3.15:2010       0.0.0.0:*               LISTEN      1001       13865      626/io.hm-rpc.2
                            tcp        0      0 192.168.3.15:1883       0.0.0.0:*               LISTEN      1001       14822      701/io.mqtt.0
                            tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       15471      800/io.sonoff.0
                            tcp        0      0 192.168.3.15:8701       0.0.0.0:*               LISTEN      1001       14534      611/io.hm-rpc.1
                            tcp6       0      0 :::3500                 :::*                    LISTEN      1001       16498      898/io.sonos.0
                            tcp6       0      0 :::50125                :::*                    LISTEN      107        17830      950/rpc.statd
                            tcp6       0      0 :::111                  :::*                    LISTEN      0          11445      1/init
                            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       13561      449/io.admin.0
                            tcp6       0      0 :::8082                 :::*                    LISTEN      1001       22985      1711/io.web.0
                            tcp6       0      0 :::8084                 :::*                    LISTEN      1001       21247      1593/io.socketio.0
                            tcp6       0      0 :::22                   :::*                    LISTEN      0          13447      430/sshd: /usr/sbin
                            tcp6       0      0 :::8087                 :::*                    LISTEN      1001       21185      1577/io.simple-api.
                            udp        0      0 0.0.0.0:59512           0.0.0.0:*                           1001       33770      768/io.shelly.0
                            udp        0      0 192.168.3.15:39048      0.0.0.0:*                           1001       21048      1496/io.knx.0
                            udp        0      0 192.168.3.15:43214      0.0.0.0:*                           1001       21522      1496/io.knx.0
                            udp        0      0 192.168.3.15:51574      0.0.0.0:*                           1001       20870      1496/io.knx.0
                            udp        0      0 192.168.3.15:47927      0.0.0.0:*                           1001       20355      1496/io.knx.0
                            udp        0      0 192.168.3.15:48759      0.0.0.0:*                           1001       20752      1496/io.knx.0
                            udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          11442      1/init
                            udp        0      0 127.0.0.1:702           0.0.0.0:*                           0          17816      950/rpc.statd
                            udp        0      0 0.0.0.0:58089           0.0.0.0:*                           107        17821      950/rpc.statd
                            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       23602      1728/io.wled.0
                            udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       15383      768/io.shelly.0
                            udp6       0      0 :::57382                :::*                                107        17827      950/rpc.statd
                            udp6       0      0 :::111                  :::*                                0          11448      1/init
                            2023-11-26 18:48:24.757  - warn: influxdb.0 (491) All possible data points were written, others can not really be corrected
                            2023-11-26 18:48:26.958  - warn: influxdb.0 (491) Error on writeSeries: HttpError: failure writing points to database: partial write: points beyond retention policy dropped=9
                            2023-11-26 18:48:26.959  - warn: influxdb.0 (491) All possible data points were written, others can not really be corrected
                            2023-11-26 18:48:26.985  - warn: influxdb.0 (491) Error on writeSeries: HttpError: failure writing points to database: partial write: points beyond retention policy dropped=10
                            2023-11-26 18:48:26.985  - warn: influxdb.0 (491) All possible data points were written, others can not really be corrected
                            2023-11-26 18:48:27.437  - warn: influxdb.0 (491) Error on writeSeries: HttpError: failure writing points to database: partial write: points beyond retention policy dropped=4
                            2023-11-26 18:48:27.437  - warn: influxdb.0 (491) All possible data points were written, others can not really be corrected
                            2023-11-26 18:48:29.355  - warn: influxdb.0 (491) Error on writeSeries: HttpError: failure writing points to database: partial write: points beyond retention policy dropped=8
                            2023-11-26 18:48:29.356  - warn: influxdb.0 (491) All possible data points were written, others can not really be corrected
                            2023-11-26 18:48:29.383  - warn: influxdb.0 (491) Error on writeSeries: HttpError: failure writing points to database: partial write: points beyond retention policy dropped=10
                            2023-11-26 18:48:29.383  - warn: influxdb.0 (491) All possible data points were written, others can not really be corrected
                            2023-11-26 18:48:29.874  - warn: influxdb.0 (491) Error on writeSeries: HttpError: failure writing points to database: partial write: points beyond retention policy dropped=5
                            2023-11-26 18:48:29.874  - warn: influxdb.0 (491) All possible data points were written, others can not really be corrected
                            2023-11-26 18:48:32.046  - warn: influxdb.0 (491) Error on writeSeries: HttpError: failure writing points to database: partial write: points beyond retention policy dropped=7
                            2023-11-26 18:48:32.046  - warn: influxdb.0 (491) All possible data points were written, others can not really be corrected
                            2023-11-26 18:48:32.103  - warn: influxdb.0 (491) Error on writeSeries: HttpError: failure writing points to database: partial write: points beyond retention policy dropped=10
                            2023-11-26 18:48:32.103  - warn: influxdb.0 (491) All possible data points were written, others can not really be corrected
                            2023-11-26 18:48:32.610  - warn: influxdb.0 (491) Error on writeSeries: HttpError: failure writing points to database: partial write: points beyond retention policy dropped=6
                            2023-11-26 18:48:32.610  - warn: influxdb.0 (491) All possible data points were written, others can not really be corrected
                            2023-11-26 18:48:34.573  - warn: influxdb.0 (491) Error on writeSeries: HttpError: failure writing points to database: partial write: points beyond retention policy dropped=7
                            2023-11-26 18:48:34.573  - warn: influxdb.0 (491) All possible data points were written, others can not really be corrected
                            2023-11-26 18:48:34.610  - warn: influxdb.0 (491) Error on writeSeries: HttpError: failure writing points to database: partial write: points beyond retention policy dropped=10
                            2023-11-26 18:48:34.610  - warn: influxdb.0 (491) All possible data points were written, others can not really be corrected
                            2023-11-26 18:48:43.745  - warn: influxdb.0 (491) Error on writeSeries: HttpError: failure writing points to database: partial write: points beyond retention policy dropped=6
                            2023-11-26 18:48:43.745  - warn: influxdb.0 (491) All possible data points were written, others can not really be corrected
                              @do5tj80
                              Der Eintrag
                              muss raus.
                              Und setz den User auch noch in die Gruppe 'adm'.
                                @thomas-braun said in Sayit Adapter- Probleme nach Update:
                                Skript v.2023-10-10
                                *** BASE SYSTEM ***
                                           Chassis: vm
                                    Virtualization: kvm
                                Docker          : false
                                Kernel          : x86_64
                                Userland        : amd64
                                 19:08:23 up 24 min,  1 user,  load average: 0.34, 0.48, 0.53
                                CPU threads: 4
                                               Local time: Sun 2023-11-26 19:08:23 CET
                                           Universal time: Sun 2023-11-26 18:08:23 UTC
                                                 RTC time: Sun 2023-11-26 18:08:24
                                              NTP service: active
                                          RTC in local TZ: no
                                thuebner
                                /home/thuebner
                                thuebner adm cdrom floppy sudo audio dip video plugdev netdev iobroker
                                X-Server:       false
                                Desktop:
                                Terminal:       tty
                                *** MEMORY ***
                                Mem:            4.9G        4.0G        502M        0.0K        464M        746M
                                Swap:            11G        308M         10G
                                Total:           16G        4.3G         11G
                                         4921 M total memory
                                         3954 M used memory
                                          475 M active memory
                                         3651 M inactive memory
                                          502 M free memory
                                           29 M buffer memory
                                          434 M swap cache
                                        11215 M total swap
                                          308 M used swap
                                        10907 M free swap
                                *** FILESYSTEM ***
                                tmpfs                         tmpfs     493M  560K  492M   1% /run
                                /dev/mapper/iobroker--vg-root ext4       38G  9.5G   27G  27% /
                                /var:
                                2.8G    /var/
                                2.2G    /var/log
                                382M    /var/cache
                                Archived and active journals take up 2.1G in the file system.
                                767M    /opt/iobroker/iobroker-data/
                                59M     /opt/iobroker/iobroker-data/objects.jsonl
                                USB-Devices by-id:
                                /usr/bin/npm            9.8.1
                                /usr/bin/npx            9.8.1
                                nodejs:
                                  Version table:
                                Errors in npm tree:
                                ioBroker Status
                                Objects type: jsonl
                                States  type: jsonl
                                admin:          6.12.0
                                javascript:     7.1.6
                                Adapter State
                                + instance is alive
                                Objects and States
                                Objects:        54381
                                States:         44373
                                Hit:3 http://ftp.tu-chemnitz.de/debian bullseye InRelease
                                Hit:4 http://ftp.tu-chemnitz.de/debian bullseye-updates InRelease
                                Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
                                Pending Updates: 0
                                2023-11-26 19:00:06.574  - debug: ical.4 (3412) Checking unprocessed event 7 null Tischdienst = false, state = false
                                2023-11-26 19:00:07.195  - info: daswetter.0 (3395) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
                                2023-11-26 19:00:07.700  - info: daswetter.0 (3395) cleaned everything up...
                                2023-11-26 19:00:09.489  - info: ical.3 (3428) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                                2023-11-26 19:00:09.597  - info: ical.3 (3428) starting. Version 1.13.3 in /opt/iobroker/node_modules/iobroker.ical, node: v18.18.2, js-controller: 5.0.16
                                2023-11-26 19:00:10.151  - info: ical.3 (3428) processing URL: Clara https://calendar.google.com/calendar/ical/huebner.clara.lena%40gmail.com/private-c7b2ebacd70794015b5c85a248f7381a/basic.ics
                                2023-11-26 19:00:10.197  - info: ical.3 (3428) processing URL: Justus https://calendar.google.com/calendar/ical/huebner.justus.paul%40gmail.com/private-9522b9790da1082a532c5fba6ab42a2f/basic.ics
                                2023-11-26 19:00:10.310  - info: ical.3 (3428) processing URL: Anne https://calendar.google.com/calendar/ical/huebner.ann%40googlemail.com/private-b54c816b59835b0a4511e025822684c7/basic.ics
                                2023-11-26 19:00:10.488  - info: ical.3 (3428) processing URL: Tobias https://calendar.google.com/calendar/ical/do5tj80%40gmail.com/private-5cef9aaf7076853a604f44550c38fec5/basic.ics
                                2023-11-26 19:00:11.578  - debug: ical.4 (3412) Plugin sentry destroyed
                                2023-11-26 19:00:11.579  - info: ical.4 (3412) Terminated (NO_ERROR): Without reason
                                2023-11-26 19:00:13.114  - info: ical.2 (3444) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                                2023-11-26 19:00:13.244  - info: ical.2 (3444) starting. Version 1.13.3 in /opt/iobroker/node_modules/iobroker.ical, node: v18.18.2, js-controller: 5.0.16
                                2023-11-26 19:00:13.819  - info: ical.2 (3444) processing URL: Abfallkalender https://calendar.google.com/calendar/ical/vk2p9rt7v6kj28111j11mkh9i4%40group.calendar.google.com/private-b873761754a89930da3e7513a5680d17/basic.ics
                                2023-11-26 19:00:13.924  - warn: trashschedule.0 (1625) no events matches type "Biotonnenwäsche" with match "Biotonnenwäsche"
                                2023-11-26 19:00:15.578  - info: ical.3 (3428) Terminated (NO_ERROR): Without reason
                                2023-11-26 19:00:17.806  - info: ical.1 (3460) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                                2023-11-26 19:00:18.098  - info: ical.1 (3460) starting. Version 1.13.3 in /opt/iobroker/node_modules/iobroker.ical, node: v18.18.2, js-controller: 5.0.16
                                2023-11-26 19:00:18.920  - info: ical.2 (3444) Terminated (NO_ERROR): Without reason
                                2023-11-26 19:00:19.912  - info: ical.1 (3460) processing URL: Theater https://calendar.google.com/calendar/ical/gelenauermarionettenspiele%40googlemail.com/private-c5262fd3590ceb70dd87a8f8f5873b64/basic.ics
                                2023-11-26 19:00:25.451  - info: ical.1 (3460) Terminated (NO_ERROR): Without reason
                                2023-11-26 19:01:20.968  - info: javascript.0 (506) script.js.Verknuepfungen.BW_Flur_OG: true
                                2023-11-26 19:01:21.056  - info: javascript.0 (506) script.js.Verknuepfungen.BW_Flur_OG: true
                                2023-11-26 19:03:23.989  - info: javascript.0 (506) script.js.Verknuepfungen.BW_Flur_OG: true
                                2023-11-26 19:03:24.047  - info: javascript.0 (506) script.js.Verknuepfungen.BW_Flur_OG: true
                                in adm ist er jetzt und http://ftp.de.debian.org/debian buster InRelease sollte raus sein.
                                  @do5tj80
                                  Dann würde ich den Arbeitsspeicher anders verteilen.
                                  11GB für SWAP mach keinen Sinn, wenn nur 4GB primär zugeteilt werden.
                                    do5tj80 @Thomas Braun last edited by do5tj80
                                    Ok das schaue ich mir an.
                                    Aber generel erst mal Danke , das du so viele Tip's gibst.
                                      fvp @do5tj80 last edited by
                                      Ich habe Version 4.0 ausprobiert. Leider noch mit dem gleichen Problem.
                                      Zum Test habe ich eine Windows VM genommen und die 3.0.5 dort probiert. Auch hier kein Ankündigungston .
                                      sayit.0
                                      	2023-12-12 12:02:29.026	error	Cannot write file: TypeError [ERR_INVALID_ARG_TYPE]: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      sayit.0
                                      	2023-12-12 12:02:29.016	info	Upload announce mp3 files
                                      sayit.0
                                      	2023-12-12 12:02:29.012	info	starting. Version 3.0.5 in C:/ioBroker/node_modules/iobroker.sayit, node: v18.19.0, js-controller: 5.0.16
                                      Ich hoffe er erbarmt sich jemand mich zu Unterstützen.
                                      • bahnuhr
                                        bahnuhr Forum Testing Most Active @fvp last edited by
                                        @fvp
                                        Sende erst das mp3
                                        und nach x Sek. dann den Text.
                                        Dies funktioniert.
                                          fvp last edited by
                                          @bahnuhr Danke für die Rückmeldung! Da habe ich aktuell noch keine Idee wie ich das geht. Bis jetzt habe ich einfach den Datenpunkt sayit.0.tts.text oder die Blockly-Funktion genutzt.
                                          • bahnuhr
                                            @fvp sagte in Sayit Adapter- Probleme nach Update:
                                            Man muss halt auch mal die Hilfe der Adapter lesen.
                                            Bringt manchmal Erleuchtung.
                                            Denn da steht alles was du gerade suchst.
                                            51
                                            4230
