    4. Sayit Adapter- Probleme nach Update
    • bahnuhr
      bahnuhr Forum Testing Most Active @do5tj80 last edited by
      @do5tj80
      das was vorher kam kopieren.
      @Thomas-Braun
      Vielleicht solltest du das wirklich mal umstellen.
        do5tj80 last edited by do5tj80
        Skript v.2023-10-10
        *** BASE SYSTEM ***
           Static hostname: iobroker
                 Icon name: computer-vm
                   Chassis: vm
            Virtualization: kvm
          Operating System: Debian GNU/Linux 11 (bullseye)
                    Kernel: Linux 5.10.0-16-amd64
              Architecture: x86-64
        model name      : Common KVM processor
        Docker          : false
        Virtualization  : kvm
        Kernel          : x86_64
        Userland        : amd64
        Systemuptime and Load:
         18:29:23 up 7 days,  3:46,  1 user,  load average: 0.75, 0.84, 0.89
        CPU threads: 4
        This system needs to be REBOOTED!
        *** Time and Time Zones ***
                       Local time: Sun 2023-11-26 18:29:23 CET
                   Universal time: Sun 2023-11-26 17:29:23 UTC
                         RTC time: Sun 2023-11-26 17:29:24
                      NTP service: active
                  RTC in local TZ: no
        *** User and Groups ***
        thuebner
        /home/thuebner
        thuebner cdrom floppy audio dip video plugdev netdev
        *** X-Server-Setup ***
        X-Server:       false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Mem:            4.9G        4.1G        357M        0.0K        492M        601M
        Swap:            11G        1.7G        9.5G
        Total:           16G        5.8G        9.8G
                 4933 M total memory
                 4082 M used memory
                 2900 M active memory
                 1305 M inactive memory
                  357 M free memory
                  102 M buffer memory
                  390 M swap cache
                11215 M total swap
                 1727 M used swap
                 9488 M free swap
        *** FAILED SERVICES ***
        0 loaded units listed.
        *** FILESYSTEM ***
        Filesystem                    Type      Size  Used Avail Use% Mounted on
        udev                          devtmpfs  2.4G     0  2.4G   0% /dev
        tmpfs                         tmpfs     494M  572K  493M   1% /run
        /dev/mapper/iobroker--vg-root ext4       38G  9.4G   27G  27% /
        tmpfs                         tmpfs     2.5G     0  2.5G   0% /dev/shm
        tmpfs                         tmpfs     5.0M     0  5.0M   0% /run/lock
        /dev/vda1                     ext2      470M   86M  360M  20% /boot
        tmpfs                         tmpfs     494M     0  494M   0% /run/user/0
        [sudo] password for thuebner:
        Sorry, user thuebner is not allowed to execute '/usr/bin/dmesg -T' as root on iobroker.huebner.local.
        TARGET  SOURCE                        FSTYPE OPTIONS
        /       /dev/mapper/iobroker--vg-root ext4   rw,relatime,errors=remount-ro
        `-/boot /dev/vda1                     ext2   rw,relatime
        /var:
        Sorry, user thuebner is not allowed to execute '/usr/bin/du -h /var/' as root on iobroker.huebner.local.
        Archived and active journals take up 16.0M in the file system.
        /opt/iobroker/backups:
        101M    /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        772M    /opt/iobroker/iobroker-data/
        557M    /opt/iobroker/iobroker-data/files
        133M    /opt/iobroker/iobroker-data/backup-objects
        89M     /opt/iobroker/iobroker-data/files/vis-2-beta
        67M     /opt/iobroker/iobroker-data/files/javascript.admin
        65M     /opt/iobroker/iobroker-data/objects.jsonl
        35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
        33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
        21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
        18M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.274a4d8d.js.map
        USB-Devices by-id:
        /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2426815-if00
        *** NodeJS-Installation ***
        ./diag.sh: line 277: nodejs: command not found
        /usr/bin/node           v16.20.2
        /usr/bin/npm            8.19.4
        /usr/bin/npx            8.19.4
        /usr/bin/corepack       0.17.0
        ./diag.sh: line 288: nodejs: command not found
        *** nodejs is NOT correctly installed ***
        nodejs:
          Installed: 16.20.2-deb-1nodesource1
          Candidate: 16.20.2-deb-1nodesource1
          Version table:
         *** 16.20.2-deb-1nodesource1 500
                500 https://deb.nodesource.com/node_16.x bullseye/main amd64 Packages
                100 /var/lib/dpkg/status
             12.22.12~dfsg-1~deb11u4 500
                500 http://ftp.tu-chemnitz.de/debian bullseye/main amd64 Packages
                500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages
             10.24.0~dfsg-1~deb10u1 500
                500 http://ftp.de.debian.org/debian buster/main amd64 Packages
        No problems detected
        Errors in npm tree:
        npm ERR! code ELSPROBLEMS
        npm ERR! missing: node-ssh@^13.1.0, required by iobroker.javascript@7.1.6
        npm ERR!     /home/thuebner/.npm/_logs/2023-11-26T17_29_31_386Z-debug-0.log
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Core adapters versions
        js-controller:  5.0.16
        admin:          6.12.0
        javascript:     7.1.6
        Adapters from github:   5
        Adapter State
        + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
        + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
        + system.adapter.bring.0                  : bring                 : iobroker                                 -  enabled
          system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
        + system.adapter.device-reminder.0        : device-reminder       : iobroker                                 -  enabled
          system.adapter.devices.0                : devices               : iobroker                                 -  enabled
        + system.adapter.email.0                  : email                 : iobroker                                 -  enabled
        + system.adapter.ems-esp.0                : ems-esp               : iobroker                                 -  enabled
        + system.adapter.energiefluss.0           : energiefluss          : iobroker                                 -  enabled
        + system.adapter.evcc.0                   : evcc                  : iobroker                                 -  enabled, port: 7070
        + system.adapter.evcc.1                   : evcc                  : iobroker                                 -  enabled, port: 7071
        + system.adapter.fronius.0                : fronius               : iobroker                                 -  enabled
        + system.adapter.fronius.1                : fronius               : iobroker                                 -  enabled
        + system.adapter.fronius.2                : fronius               : iobroker                                 -  enabled
          system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 - disabled
        + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
        + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
        + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
        + system.adapter.hm-rpc.2                 : hm-rpc                : iobroker                                 -  enabled, port: 0
          system.adapter.ical.1                   : ical                  : iobroker                                 -  enabled
          system.adapter.ical.2                   : ical                  : iobroker                                 -  enabled
          system.adapter.ical.3                   : ical                  : iobroker                                 -  enabled
          system.adapter.ical.4                   : ical                  : iobroker                                 -  enabled
          system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : iobroker                                 -  enabled
          system.adapter.icons-material-png.0     : icons-material-png    : iobroker                                 -  enabled
          system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 -  enabled
          system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 -  enabled
        + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
        + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
        + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
        + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
          system.adapter.km200.0                  : km200                 : iobroker                                 - disabled
        + system.adapter.knx.0                    : knx                   : iobroker                                 -  enabled, bind: 192.168.3.15
        + system.adapter.lgtv.0                   : lgtv                  : iobroker                                 -  enabled
        + system.adapter.mielecloudservice.0      : mielecloudservice     : iobroker                                 -  enabled
        + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 192.168.3.15
        + system.adapter.nut.0                    : nut                   : iobroker                                 -  enabled
          system.adapter.owfs.0                   : owfs                  : iobroker                                 - disabled, port: 4304
        + system.adapter.phantomjs.0              : phantomjs             : iobroker                                 -  enabled
        + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
          system.adapter.proxmox.0                : proxmox               : iobroker                                 - disabled, port: 8006
        + system.adapter.pvforecast.0             : pvforecast            : iobroker                                 -  enabled
        + system.adapter.roomba.0                 : roomba                : iobroker                                 -  enabled
          system.adapter.s7.0                     : s7                    : iobroker                                 - disabled
        + system.adapter.sainlogic.0              : sainlogic             : iobroker                                 -  enabled, port: 45000, bind: 192.168.3.15
        + system.adapter.samsung.0                : samsung               : iobroker                                 -  enabled
        + system.adapter.sayit.0                  : sayit                 : iobroker                                 -  enabled
        + system.adapter.scenes.0                 : scenes                : iobroker                                 -  enabled
        + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
        + system.adapter.shelly.1                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
        + system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker                                 -  enabled
        + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
        + system.adapter.socketio.0               : socketio              : iobroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
        + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1884, bind: 0.0.0.0
        + system.adapter.sonos.0                  : sonos                 : iobroker                                 -  enabled
        + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
        + system.adapter.sql.0                    : sql                   : iobroker                                 -  enabled, port: 3307
        + system.adapter.synology.0               : synology              : iobroker                                 -  enabled, port: 5000
        + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
        + system.adapter.text2command.0           : text2command          : iobroker                                 -  enabled
        + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
        + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
        + system.adapter.unifi.0                  : unifi                 : iobroker                                 -  enabled
        + system.adapter.vis-2-beta.0             : vis-2-beta            : iobroker                                 -  enabled
          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 -  enabled
          system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 -  enabled
        + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
          system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
          system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
        + system.adapter.vw-connect.0             : vw-connect            : iobroker                                 -  enabled
        + system.adapter.vw-connect.1             : vw-connect            : iobroker                                 -  enabled
        + system.adapter.vw-connect.2             : vw-connect            : iobroker                                 -  enabled
        + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        + system.adapter.wled.0                   : wled                  : iobroker                                 -  enabled
        + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: /dev/ttyACM0
        + instance is alive
        ioBroker-Repositories
        Active repo(s): stable
        Installed ioBroker-Instances
        Used repository: stable
        Adapter    "admin"        : 6.12.0   , installed 6.12.0
        Adapter    "alexa2"       : 3.26.1   , installed 3.26.1
        Adapter    "backitup"     : 2.8.7    , installed 2.8.7
        Adapter    "bring"        : 1.8.4    , installed 1.8.4
        Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
        Adapter    "device-reminder": 3.0.0  , installed 3.0.0
        Adapter    "email"        : 1.2.0    , installed 1.2.0
        Adapter    "ems-esp"      : 2.6.1    , installed 2.6.2
        Adapter    "evcc"         : 0.0.10   , installed 0.0.10
        Adapter    "fronius"      : 2.0.2    , installed 2.0.2
        Adapter    "fullybrowser" : 3.0.6    , installed 2.2.0  [Updatable]
        Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
        Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
        Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
        Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
        Adapter    "iot"          : 2.0.11   , installed 2.0.11
        Adapter    "javascript"   : 7.1.6    , installed 7.1.6
        Controller "js-controller": 5.0.16   , installed 5.0.16
        Adapter    "km200"        : 2.0.3    , installed 2.0.3
        Adapter    "knx"          : 2.0.23   , installed 2.0.23
        Adapter    "lgtv"         : 2.1.2    , installed 2.1.2
        Adapter    "mielecloudservice": 6.5.4, installed 6.5.4
        Adapter    "modbus"       : 5.0.11   , installed 5.0.11
        Adapter    "mqtt"         : 5.1.0    , installed 5.1.0
        Adapter    "nina"         : 0.0.25   , installed 0.0.25
        Adapter    "nut"          : 1.6.0    , installed 1.6.0
        Adapter    "owfs"         : 0.7.0    , installed 0.7.0
        Adapter    "phantomjs"    : 1.1.3    , installed 1.1.3
        Adapter    "proxmox"      : 2.2.1    , installed 2.2.1
        Adapter    "pvforecast"   : 2.9.0    , installed 2.9.0
        Adapter    "roomba"       : 1.2.2    , installed 1.2.2
        Adapter    "s7"           : 1.3.15   , installed 1.3.15
        Adapter    "sainlogic"    : 0.10.5   , installed 0.10.5
        Adapter    "samsung"      : 0.5.11   , installed 0.5.11
        Adapter    "sayit"        : 3.0.5    , installed 3.0.5
        Adapter    "shelly"       : 6.6.1    , installed 6.6.1
        Adapter    "shuttercontrol": 1.6.3   , installed 1.6.3
        Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
        Adapter    "sonos"        : 3.0.0    , installed 3.0.0
        Adapter    "spotify-premium": 1.3.1  , installed 1.3.1
        Adapter    "sql"          : 2.2.0    , installed 2.2.0
        Adapter    "squeezeboxrpc": 1.3.9    , installed 1.3.9
        Adapter    "synology"     : 3.0.1    , installed 3.0.1
        Adapter    "telegram"     : 2.0.1    , installed 2.0.1
        Adapter    "text2command" : 3.0.2    , installed 3.0.2
        Adapter    "trashschedule": 2.3.0    , installed 2.3.0
        Adapter    "unifi"        : 0.6.6    , installed 0.6.6
        Adapter    "vis"          : 1.4.16   , installed 1.4.16
        Adapter    "vis-icontwo"  : 0.97.1   , installed 0.97.1
        Adapter    "vis-justgage" : 2.0.2    , installed 2.0.1  [Updatable]
        Adapter    "vw-connect"   : 0.0.67   , installed 0.0.67
        Adapter    "web"          : 6.1.10   , installed 6.1.10
        Adapter    "wled"         : 0.7.1    , installed 0.7.1
        Adapter    "ws"           : 2.5.8    , installed 2.5.8
        Adapter    "zigbee"       : 1.8.24   , installed 1.8.24
        Objects and States
        Objects:        54381
        States:         44373
        Sorry, user thuebner is not allowed to execute '/usr/bin/apt-get update' as root on iobroker.huebner.local.
        Pending Updates: 0
        *** Listening Ports ***
        Sorry, user thuebner is not allowed to execute '/usr/bin/netstat -tulpen' as root on iobroker.huebner.local.
        2023-11-26 18:30:06.044  - debug: ical.4 (291961) ev: {"type":"VEVENT","params":[],"start":"2023-10-24T15:00:00.000Z","datetype":"date-time","end":"2023-10-24T16:00:00.000Z","dtstamp":"2023-11-26T17:30:05.000Z","organizer":{"params":{"CN":"do5tj80@gmail.com"},"val":"mailto:do5tj80@gmail.com"},"uid":"f79t37oti7bdm0js41njjjgbic@google.com","attendee":[{"params":{"CUTYPE":"INDIVIDUAL","ROLE":"REQ-PARTICIPANT","PARTSTAT":"NEEDS-ACTION","CN":"huebner.justus.paul@gmail.com","X-NUM-GUESTS":0},"val":"mailto:huebner.justus.paul@gmail.com"},{"params":{"CUTYPE":"INDIVIDUAL","ROLE":"REQ-PARTICIPANT","PARTSTAT":"NEEDS-ACTION","CN":"huebner.ann@googlemail.com","X-NUM-GUESTS":0},"val":"mailto:huebner.ann@googlemail.com"},{"params":{"CUTYPE":"INDIVIDUAL","ROLE":"REQ-PARTICIPANT","PARTSTAT":"NEEDS-ACTION","CN":"huebner.clara.lena@gmail.com","X-NUM-GUESTS":0},"val":"mailto:huebner.clara.lena@gmail.com"},{"params":{"CUTYPE":"INDIVIDUAL","ROLE":"REQ-PARTICIPANT","PARTSTAT":"ACCEPTED","CN":"do5tj80@gmail.com","X-NUM-GUESTS":0},"val":"mailto:do5tj80@gmail.com"}],"GOOGLE-CONFERENCE":"https://meet.google.com/xyu-para-npo","created":"2023-10-23T04:49:38.000Z","description":"Über Google Meet teilnehmen: https://meet.google.com/xyu-para-npo\n\nWeitere Informationen zu Meet: https://support.google.com/a/users/answer/9282720","lastmodified":"2023-10-23T04:49:40.000Z","location":"Festplatz Gelenau, Ernst-Grohmann-Straße, 09423 Gelenau/Erzgeb., Deutschland","sequence":"0","status":"CONFIRMED","summary":"Altpapiersammlung","transparency":"OPAQUE","method":"PUBLISH"}
        2023-11-26 18:30:06.045  - debug: ical.4 (291961) Single event: Altpapiersammlung; start:Tue Oct 24 2023 17:00:00 GMT+0200 (Mitteleuropäische Sommerzeit); end:Tue Oct 24 2023 18:00:00 GMT+0200 (Mitteleuropäische Sommerzeit); endpreview:Sun Dec 03 2023 18:30:06 GMT+0100 (Mitteleuropäische Normalzeit); startpreview:Sun Nov 26 2023 00:00:00 GMT+0100 (Mitteleuropäische Normalzeit); realnow:Sun Nov 26 2023 18:30:06 GMT+0100 (Mitteleuropäische Normalzeit)
        2023-11-26 18:30:06.045  - debug: ical.4 (291961) Event (time) processing. Start: Tue Oct 24 2023 17:00:00 GMT+0200 (Mitteleuropäische Sommerzeit) End: Tue Oct 24 2023 18:00:00 GMT+0200 (Mitteleuropäische Sommerzeit)
        2023-11-26 18:30:06.045  - debug: ical.4 (291961) Event " " Altpapiersammlung at Tue Oct 24 2023 17:00:00 GMT+0200 (Mitteleuropäische Sommerzeit) filtered out, because does not belongs to specified time interval
        2023-11-26 18:30:06.045  - debug: ical.4 (291961) ev: {"type":"VEVENT","params":[],"start":"2023-10-24T15:30:00.000Z","datetype":"date-time","end":"2023-10-24T16:30:00.000Z","dtstamp":"2023-11-26T17:30:05.000Z","organizer":{"params":{"CN":"huebner.justus.paul@gmail.com"},"val":"mailto:huebner.justus.paul@gmail.com"},"uid":"A1E9AD76-8D6D-45B2-A4B7-D22ABDCB3D61","attendee":[{"params":{"CUTYPE":"INDIVIDUAL","ROLE":"REQ-PARTICIPANT","PARTSTAT":"ACCEPTED","CN":"do5tj80@gmail.com","X-NUM-GUESTS":0},"val":"mailto:do5tj80@gmail.com"},{"params":{"CUTYPE":"INDIVIDUAL","ROLE":"REQ-PARTICIPANT","PARTSTAT":"ACCEPTED","CN":"huebner.clara.lena@gmail.com","X-NUM-GUESTS":0},"val":"mailto:huebner.clara.lena@gmail.com"},{"params":{"CUTYPE":"INDIVIDUAL","ROLE":"REQ-PARTICIPANT","PARTSTAT":"ACCEPTED","CN":"huebner.justus.paul@gmail.com","X-NUM-GUESTS":0},"val":"mailto:huebner.justus.paul@gmail.com"}],"GOOGLE-CONFERENCE":"https://meet.google.com/cdk-spjy-ptp","created":"2023-09-26T14:47:05.000Z","description":"Über Google Meet teilnehmen: https://meet.google.com/cdk-spjy-ptp\n\nWeitere Informationen zu Meet: https://support.google.com/a/users/answer/9282720","lastmodified":"2023-10-24T01:42:18.000Z","sequence":"1","status":"CONFIRMED","summary":"Bibo Gelenau","transparency":"OPAQUE","APPLE-CREATOR-IDENTITY":"com.apple.mobilecal","APPLE-CREATOR-TEAM-IDENTITY":"0000000000","method":"PUBLISH"}
        2023-11-26 18:30:06.045  - debug: ical.4 (291961) Single event: Bibo Gelenau; start:Tue Oct 24 2023 17:30:00 GMT+0200 (Mitteleuropäische Sommerzeit); end:Tue Oct 24 2023 18:30:00 GMT+0200 (Mitteleuropäische Sommerzeit); endpreview:Sun Dec 03 2023 18:30:06 GMT+0100 (Mitteleuropäische Normalzeit); startpreview:Sun Nov 26 2023 00:00:00 GMT+0100 (Mitteleuropäische Normalzeit); realnow:Sun Nov 26 2023 18:30:06 GMT+0100 (Mitteleuropäische Normalzeit)
        2023-11-26 18:30:06.045  - debug: ical.4 (291961) Event (time) processing. Start: Tue Oct 24 2023 17:30:00 GMT+0200 (Mitteleuropäische Sommerzeit) End: Tue Oct 24 2023 18:30:00 GMT+0200 (Mitteleuropäische Sommerzeit)
        2023-11-26 18:30:06.045  - debug: ical.4 (291961) Event " " Bibo Gelenau at Tue Oct 24 2023 17:30:00 GMT+0200 (Mitteleuropäische Sommerzeit) filtered out, because does not belongs to specified time interval
        2023-11-26 18:30:06.045  - debug: ical.4 (291961) displaying dates because of callback
        2023-11-26 18:30:06.046  - debug: ical.4 (291961) Dates array (data.table): [{"date":"Day After Tomorrow 15:15-16:45","event":"Pippisport","_class":"ical_Tischdienst Justus ical_dayafter","_date":"2023-11-28T14:15:00.000Z","_end":"2023-11-28T15:45:00.000Z","_IDID":"1spa6nra1auon528393aj0gk9n@google.com","_allDay":false,"_private":false,"_rule":" ","location":"Ringerhalle","_calName":"Tischdienst Justus","_calColor":"#186804","_object":{"type":"VEVENT","params":[],"start":"2023-11-28T14:15:00.000Z","datetype":"date-time","end":"2023-11-28T15:45:00.000Z","dtstamp":"2023-11-26T17:30:05.000Z","uid":"1spa6nra1auon528393aj0gk9n@google.com","created":"2023-09-28T15:35:00.000Z","lastmodified":"2023-09-28T15:35:00.000Z","location":"Ringerhalle","sequence":"0","status":"CONFIRMED","summary":"Pippisport","transparency":"OPAQUE","method":"PUBLISH"}},{"date":"In 4 days 16:30-17:30","event":"Reiten","_class":"ical_Tischdienst Clara ical_4days","_date":"2023-11-30T15:30:00.000Z","_end":"2023-11-30T16:30:00.000Z","_IDID":"1uksojk6m1bp444avbrev14dgg@google.com","_allDay":false,"_private":false,"_rule":" rrule ","location":"Scharfensteiner Str. 24, 09430 Drebach","_calName":"Tischdienst Clara","_calColor":"#e307ff","_object":{"type":"VEVENT","params":[],"start":"2023-11-30T15:30:00.000Z","datetype":"date-time","end":"2023-11-30T16:30:00.000Z","rrule":{"_cache":{"all":false,"before":[],"after":[],"between":[]},"origOptions":{"tzid":"Europe/Berlin","dtstart":"2023-09-07T14:30:00.000Z","freq":2,"byweekday":[{"weekday":3}]},"options":{"freq":2,"dtstart":"2023-09-07T14:30:00.000Z","interval":1,"wkst":0,"count":null,"until":null,"tzid":"Europe/Berlin","bysetpos":null,"bymonth":null,"bymonthday":[],"bynmonthday":[],"byyearday":null,"byweekno":null,"byweekday":[3],"bynweekday":null,"byhour":[14],"byminute":[30],"bysecond":[0],"byeaster":null}},"dtstamp":"2023-11-26T17:30:05.000Z","uid":"1uksojk6m1bp444avbrev14dgg@google.com","created":"2023-09-08T09:18:39.000Z","lastmodified":"2023-09-08T09:18:39.000Z","location":"Scharfensteiner Str. 24, 09430 Drebach","sequence":"0","status":"CONFIRMED","summary":"Reiten","transparency":"OPAQUE","method":"PUBLISH"}}]
        2023-11-26 18:30:06.137  - debug: ical.4 (291961)     todayOnly = false: (Tue Nov 28 2023 15:15:00 GMT+0100 (Mitteleuropäische Normalzeit)-Tue Nov 28 2023 16:45:00 GMT+0100 (Mitteleuropäische Normalzeit)), alreadyStarted=false
        2023-11-26 18:30:06.138  - debug: ical.4 (291961)     todayOnly = false: (Thu Nov 30 2023 16:30:00 GMT+0100 (Mitteleuropäische Normalzeit)-Thu Nov 30 2023 17:30:00 GMT+0100 (Mitteleuropäische Normalzeit)), alreadyStarted=false
        2023-11-26 18:30:06.190  - debug: ical.4 (291961)     todayOnly = false: (Tue Nov 28 2023 15:15:00 GMT+0100 (Mitteleuropäische Normalzeit)-Tue Nov 28 2023 16:45:00 GMT+0100 (Mitteleuropäische Normalzeit)), alreadyStarted=false
        2023-11-26 18:30:06.190  - debug: ical.4 (291961)     todayOnly = false: (Thu Nov 30 2023 16:30:00 GMT+0100 (Mitteleuropäische Normalzeit)-Thu Nov 30 2023 17:30:00 GMT+0100 (Mitteleuropäische Normalzeit)), alreadyStarted=false
        2023-11-26 18:30:06.205  - debug: ical.4 (291961) Checking unprocessed event 0 today Tischdienst = false, state = false
        2023-11-26 18:30:06.205  - debug: ical.4 (291961) Checking unprocessed event 0 now Tischdienst = false, state = false
        2023-11-26 18:30:06.205  - debug: ical.4 (291961) Checking unprocessed event 0 later Tischdienst = false, state = false
        2023-11-26 18:30:06.205  - debug: ical.4 (291961) Checking unprocessed event 1 null Tischdienst = false, state = false
        2023-11-26 18:30:06.206  - debug: ical.4 (291961) Checking unprocessed event 2 null Tischdienst = false, state = false
        2023-11-26 18:30:06.206  - debug: ical.4 (291961) Checking unprocessed event 3 null Tischdienst = false, state = false
        2023-11-26 18:30:06.206  - debug: ical.4 (291961) Checking unprocessed event 4 null Tischdienst = false, state = false
        2023-11-26 18:30:06.206  - debug: ical.4 (291961) Checking unprocessed event 5 null Tischdienst = false, state = false
        2023-11-26 18:30:06.206  - debug: ical.4 (291961) Checking unprocessed event 6 null Tischdienst = false, state = false
        2023-11-26 18:30:06.206  - debug: ical.4 (291961) Checking unprocessed event 7 null Tischdienst = false, state = false
        2023-11-26 18:30:09.348  - info: ical.3 (291984) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
        iob diag has finished.
          Thomas Braun Most Active @do5tj80 last edited by
          @do5tj80 sagte in Sayit Adapter- Probleme nach Update:
          Mach das...
          Zuvor
          iob nodejs-update
            do5tj80 @Thomas Braun last edited by
            thuebner@iobroker:~$ iob nodejs-update
            iobroker nodejs-update [<major-version>]
            Upgrade the Node.JS installation to the current LTS
            Options:
              --help  Show help  [boolean]
            mehr kommt da nicht.
              @do5tj80
              iob stop
              iob fix
              iob nodejs-update
              Und setz den User in die Gruppen 'sudo' und 'iobroker' rein.
                Skript v.2023-10-10
                *** BASE SYSTEM ***
                           Chassis: vm
                    Virtualization: kvm
                            Kernel: Linux 5.10.0-26-amd64
                Docker          : false
                Kernel          : x86_64
                Userland        : amd64
                 18:49:14 up 5 min,  1 user,  load average: 1.05, 0.95, 0.45
                CPU threads: 4
                               Local time: Sun 2023-11-26 18:49:14 CET
                           Universal time: Sun 2023-11-26 17:49:14 UTC
                                 RTC time: Sun 2023-11-26 17:49:15
                              NTP service: active
                          RTC in local TZ: no
                thuebner
                /home/thuebner
                thuebner cdrom floppy sudo audio dip video plugdev netdev iobroker
                X-Server:       false
                Desktop:
                Terminal:       tty
                *** MEMORY ***
                Mem:            4.9G        3.7G        817M        0.0K        410M        1.0G
                Swap:            11G          0B         11G
                Total:           16G        3.7G         12G
                         4921 M total memory
                         3693 M used memory
                          159 M active memory
                         3645 M inactive memory
                          816 M free memory
                           50 M buffer memory
                          359 M swap cache
                        11215 M total swap
                            0 M used swap
                        11215 M free swap
                *** FILESYSTEM ***
                tmpfs                         tmpfs     493M  540K  492M   1% /run
                tmpfs                         tmpfs     493M     0  493M   0% /run/user/0
                [Sun Nov 26 18:43:36 2023] EXT4-fs (dm-0): mounted filesystem with ordered data mode. Opts: (null)
                [Sun Nov 26 18:43:36 2023] EXT4-fs (dm-0): re-mounted. Opts: errors=remount-ro
                [Sun Nov 26 18:43:36 2023] EXT4-fs (vda1): mounting ext2 file system using the ext4 subsystem
                [Sun Nov 26 18:43:36 2023] EXT4-fs (vda1): mounted filesystem without journal. Opts: (null)
                /var:
                2.8G    /var/
                2.2G    /var/log/journal/14cb46b5198d45d6a08ee6b6ab2c73d2
                2.2G    /var/log
                382M    /var/cache
                Archived and active journals take up 32.0M in the file system.
                754M    /opt/iobroker/iobroker-data/
                46M     /opt/iobroker/iobroker-data/objects.jsonl
                USB-Devices by-id:
                /usr/bin/nodejs         v18.18.2
                /usr/bin/node           v18.18.2
                /usr/bin/npm            9.8.1
                /usr/bin/npx            9.8.1
                /usr/bin/corepack       0.19.0
                nodejs:
                  Installed: 18.18.2-1nodesource1
                  Candidate: 18.18.2-1nodesource1
                  Version table:
                 *** 18.18.2-1nodesource1 1001
                        500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                     18.18.1-1nodesource1 1001
                     18.18.0-1nodesource1 1001
                     18.17.1-1nodesource1 1001
                     18.17.0-1nodesource1 1001
                     18.16.1-1nodesource1 1001
                     18.16.0-1nodesource1 1001
                     18.15.0-1nodesource1 1001
                     18.14.2-1nodesource1 1001
                     18.14.1-1nodesource1 1001
                     18.14.0-1nodesource1 1001
                     18.13.0-1nodesource1 1001
                     18.12.0-1nodesource1 1001
                     18.11.0-1nodesource1 1001
                     18.10.0-1nodesource1 1001
                     18.9.1-1nodesource1 1001
                     18.9.0-1nodesource1 1001
                     18.8.0-1nodesource1 1001
                     18.7.0-1nodesource1 1001
                     18.6.0-1nodesource1 1001
                     18.5.0-1nodesource1 1001
                     18.4.0-1nodesource1 1001
                     18.3.0-1nodesource1 1001
                     18.2.0-1nodesource1 1001
                     18.1.0-1nodesource1 1001
                     18.0.0-1nodesource1 1001
                Errors in npm tree:
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                admin:          6.12.0
                javascript:     7.1.6
                Adapter State
                + instance is alive
                Objects and States
                Objects:        54381
                States:         44412
                Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
                Hit:2 https://repos.influxdata.com/debian stable InRelease
                Hit:3 http://ftp.de.debian.org/debian buster InRelease
                Hit:4 http://ftp.tu-chemnitz.de/debian bullseye InRelease
                Hit:5 http://ftp.tu-chemnitz.de/debian bullseye-updates InRelease
                Hit:6 https://deb.nodesource.com/node_18.x nodistro InRelease
                Reading package lists... Done
                Pending Updates: 0
                tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       11979      416/iobroker.js-con
                tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       13463      416/iobroker.js-con
                tcp        0      0 192.168.3.15:9292       0.0.0.0:*               LISTEN      1001       13788      596/io.hm-rpc.0
                tcp        0      0 0.0.0.0:55597           0.0.0.0:*               LISTEN      107        17824      950/rpc.statd
                tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          11441      1/init
                tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13445      430/sshd: /usr/sbin
                tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       15027      784/io.shelly.1
                tcp        0      0 192.168.3.15:2010       0.0.0.0:*               LISTEN      1001       13865      626/io.hm-rpc.2
                tcp        0      0 192.168.3.15:1883       0.0.0.0:*               LISTEN      1001       14822      701/io.mqtt.0
                tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       15471      800/io.sonoff.0
                tcp        0      0 192.168.3.15:8701       0.0.0.0:*               LISTEN      1001       14534      611/io.hm-rpc.1
                tcp6       0      0 :::3500                 :::*                    LISTEN      1001       16498      898/io.sonos.0
                tcp6       0      0 :::50125                :::*                    LISTEN      107        17830      950/rpc.statd
                tcp6       0      0 :::111                  :::*                    LISTEN      0          11445      1/init
                tcp6       0      0 :::8081                 :::*                    LISTEN      1001       13561      449/io.admin.0
                tcp6       0      0 :::8082                 :::*                    LISTEN      1001       22985      1711/io.web.0
                tcp6       0      0 :::8084                 :::*                    LISTEN      1001       21247      1593/io.socketio.0
                tcp6       0      0 :::22                   :::*                    LISTEN      0          13447      430/sshd: /usr/sbin
                tcp6       0      0 :::8087                 :::*                    LISTEN      1001       21185      1577/io.simple-api.
                udp        0      0 0.0.0.0:59512           0.0.0.0:*                           1001       33770      768/io.shelly.0
                udp        0      0 192.168.3.15:39048      0.0.0.0:*                           1001       21048      1496/io.knx.0
                udp        0      0 192.168.3.15:43214      0.0.0.0:*                           1001       21522      1496/io.knx.0
                udp        0      0 192.168.3.15:51574      0.0.0.0:*                           1001       20870      1496/io.knx.0
                udp        0      0 192.168.3.15:47927      0.0.0.0:*                           1001       20355      1496/io.knx.0
                udp        0      0 192.168.3.15:48759      0.0.0.0:*                           1001       20752      1496/io.knx.0
                udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          11442      1/init
                udp        0      0 127.0.0.1:702           0.0.0.0:*                           0          17816      950/rpc.statd
                udp        0      0 0.0.0.0:58089           0.0.0.0:*                           107        17821      950/rpc.statd
                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       23602      1728/io.wled.0
                udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       15383      768/io.shelly.0
                udp6       0      0 :::57382                :::*                                107        17827      950/rpc.statd
                udp6       0      0 :::111                  :::*                                0          11448      1/init
                2023-11-26 18:48:24.757  - warn: influxdb.0 (491) All possible data points were written, others can not really be corrected
                2023-11-26 18:48:26.958  - warn: influxdb.0 (491) Error on writeSeries: HttpError: failure writing points to database: partial write: points beyond retention policy dropped=9
                2023-11-26 18:48:26.959  - warn: influxdb.0 (491) All possible data points were written, others can not really be corrected
                2023-11-26 18:48:26.985  - warn: influxdb.0 (491) Error on writeSeries: HttpError: failure writing points to database: partial write: points beyond retention policy dropped=10
                2023-11-26 18:48:26.985  - warn: influxdb.0 (491) All possible data points were written, others can not really be corrected
                2023-11-26 18:48:27.437  - warn: influxdb.0 (491) Error on writeSeries: HttpError: failure writing points to database: partial write: points beyond retention policy dropped=4
                2023-11-26 18:48:27.437  - warn: influxdb.0 (491) All possible data points were written, others can not really be corrected
                2023-11-26 18:48:29.355  - warn: influxdb.0 (491) Error on writeSeries: HttpError: failure writing points to database: partial write: points beyond retention policy dropped=8
                2023-11-26 18:48:29.356  - warn: influxdb.0 (491) All possible data points were written, others can not really be corrected
                2023-11-26 18:48:29.383  - warn: influxdb.0 (491) Error on writeSeries: HttpError: failure writing points to database: partial write: points beyond retention policy dropped=10
                2023-11-26 18:48:29.383  - warn: influxdb.0 (491) All possible data points were written, others can not really be corrected
                2023-11-26 18:48:29.874  - warn: influxdb.0 (491) Error on writeSeries: HttpError: failure writing points to database: partial write: points beyond retention policy dropped=5
                2023-11-26 18:48:29.874  - warn: influxdb.0 (491) All possible data points were written, others can not really be corrected
                2023-11-26 18:48:32.046  - warn: influxdb.0 (491) Error on writeSeries: HttpError: failure writing points to database: partial write: points beyond retention policy dropped=7
                2023-11-26 18:48:32.046  - warn: influxdb.0 (491) All possible data points were written, others can not really be corrected
                2023-11-26 18:48:32.103  - warn: influxdb.0 (491) Error on writeSeries: HttpError: failure writing points to database: partial write: points beyond retention policy dropped=10
                2023-11-26 18:48:32.103  - warn: influxdb.0 (491) All possible data points were written, others can not really be corrected
                2023-11-26 18:48:32.610  - warn: influxdb.0 (491) Error on writeSeries: HttpError: failure writing points to database: partial write: points beyond retention policy dropped=6
                2023-11-26 18:48:32.610  - warn: influxdb.0 (491) All possible data points were written, others can not really be corrected
                2023-11-26 18:48:34.573  - warn: influxdb.0 (491) Error on writeSeries: HttpError: failure writing points to database: partial write: points beyond retention policy dropped=7
                2023-11-26 18:48:34.573  - warn: influxdb.0 (491) All possible data points were written, others can not really be corrected
                2023-11-26 18:48:34.610  - warn: influxdb.0 (491) Error on writeSeries: HttpError: failure writing points to database: partial write: points beyond retention policy dropped=10
                2023-11-26 18:48:34.610  - warn: influxdb.0 (491) All possible data points were written, others can not really be corrected
                2023-11-26 18:48:43.745  - warn: influxdb.0 (491) Error on writeSeries: HttpError: failure writing points to database: partial write: points beyond retention policy dropped=6
                2023-11-26 18:48:43.745  - warn: influxdb.0 (491) All possible data points were written, others can not really be corrected
                  @do5tj80
                  Der Eintrag
                  muss raus.
                  Und setz den User auch noch in die Gruppe 'adm'.
                    @thomas-braun said in Sayit Adapter- Probleme nach Update:
                    Skript v.2023-10-10
                    *** BASE SYSTEM ***
                               Chassis: vm
                        Virtualization: kvm
                    Docker          : false
                    Kernel          : x86_64
                    Userland        : amd64
                     19:08:23 up 24 min,  1 user,  load average: 0.34, 0.48, 0.53
                    CPU threads: 4
                                   Local time: Sun 2023-11-26 19:08:23 CET
                               Universal time: Sun 2023-11-26 18:08:23 UTC
                                     RTC time: Sun 2023-11-26 18:08:24
                                  NTP service: active
                              RTC in local TZ: no
                    thuebner
                    /home/thuebner
                    thuebner adm cdrom floppy sudo audio dip video plugdev netdev iobroker
                    X-Server:       false
                    Desktop:
                    Terminal:       tty
                    *** MEMORY ***
                    Mem:            4.9G        4.0G        502M        0.0K        464M        746M
                    Swap:            11G        308M         10G
                    Total:           16G        4.3G         11G
                             4921 M total memory
                             3954 M used memory
                              475 M active memory
                             3651 M inactive memory
                              502 M free memory
                               29 M buffer memory
                              434 M swap cache
                            11215 M total swap
                              308 M used swap
                            10907 M free swap
                    *** FILESYSTEM ***
                    tmpfs                         tmpfs     493M  560K  492M   1% /run
                    /dev/mapper/iobroker--vg-root ext4       38G  9.5G   27G  27% /
                    /var:
                    2.8G    /var/
                    2.2G    /var/log
                    382M    /var/cache
                    Archived and active journals take up 2.1G in the file system.
                    767M    /opt/iobroker/iobroker-data/
                    59M     /opt/iobroker/iobroker-data/objects.jsonl
                    USB-Devices by-id:
                    /usr/bin/npm            9.8.1
                    /usr/bin/npx            9.8.1
                    nodejs:
                      Version table:
                    Errors in npm tree:
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    admin:          6.12.0
                    javascript:     7.1.6
                    Adapter State
                    + instance is alive
                    Objects and States
                    Objects:        54381
                    States:         44373
                    Hit:3 http://ftp.tu-chemnitz.de/debian bullseye InRelease
                    Hit:4 http://ftp.tu-chemnitz.de/debian bullseye-updates InRelease
                    Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
                    Pending Updates: 0
                    2023-11-26 19:00:06.574  - debug: ical.4 (3412) Checking unprocessed event 7 null Tischdienst = false, state = false
                    2023-11-26 19:00:07.195  - info: daswetter.0 (3395) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
                    2023-11-26 19:00:07.700  - info: daswetter.0 (3395) cleaned everything up...
                    2023-11-26 19:00:09.489  - info: ical.3 (3428) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                    2023-11-26 19:00:09.597  - info: ical.3 (3428) starting. Version 1.13.3 in /opt/iobroker/node_modules/iobroker.ical, node: v18.18.2, js-controller: 5.0.16
                    2023-11-26 19:00:10.151  - info: ical.3 (3428) processing URL: Clara https://calendar.google.com/calendar/ical/huebner.clara.lena%40gmail.com/private-c7b2ebacd70794015b5c85a248f7381a/basic.ics
                    2023-11-26 19:00:10.197  - info: ical.3 (3428) processing URL: Justus https://calendar.google.com/calendar/ical/huebner.justus.paul%40gmail.com/private-9522b9790da1082a532c5fba6ab42a2f/basic.ics
                    2023-11-26 19:00:10.310  - info: ical.3 (3428) processing URL: Anne https://calendar.google.com/calendar/ical/huebner.ann%40googlemail.com/private-b54c816b59835b0a4511e025822684c7/basic.ics
                    2023-11-26 19:00:10.488  - info: ical.3 (3428) processing URL: Tobias https://calendar.google.com/calendar/ical/do5tj80%40gmail.com/private-5cef9aaf7076853a604f44550c38fec5/basic.ics
                    2023-11-26 19:00:11.578  - debug: ical.4 (3412) Plugin sentry destroyed
                    2023-11-26 19:00:11.579  - info: ical.4 (3412) Terminated (NO_ERROR): Without reason
                    2023-11-26 19:00:13.114  - info: ical.2 (3444) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                    2023-11-26 19:00:13.244  - info: ical.2 (3444) starting. Version 1.13.3 in /opt/iobroker/node_modules/iobroker.ical, node: v18.18.2, js-controller: 5.0.16
                    2023-11-26 19:00:13.819  - info: ical.2 (3444) processing URL: Abfallkalender https://calendar.google.com/calendar/ical/vk2p9rt7v6kj28111j11mkh9i4%40group.calendar.google.com/private-b873761754a89930da3e7513a5680d17/basic.ics
                    2023-11-26 19:00:13.924  - warn: trashschedule.0 (1625) no events matches type "Biotonnenwäsche" with match "Biotonnenwäsche"
                    2023-11-26 19:00:15.578  - info: ical.3 (3428) Terminated (NO_ERROR): Without reason
                    2023-11-26 19:00:17.806  - info: ical.1 (3460) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                    2023-11-26 19:00:18.098  - info: ical.1 (3460) starting. Version 1.13.3 in /opt/iobroker/node_modules/iobroker.ical, node: v18.18.2, js-controller: 5.0.16
                    2023-11-26 19:00:18.920  - info: ical.2 (3444) Terminated (NO_ERROR): Without reason
                    2023-11-26 19:00:19.912  - info: ical.1 (3460) processing URL: Theater https://calendar.google.com/calendar/ical/gelenauermarionettenspiele%40googlemail.com/private-c5262fd3590ceb70dd87a8f8f5873b64/basic.ics
                    2023-11-26 19:00:25.451  - info: ical.1 (3460) Terminated (NO_ERROR): Without reason
                    2023-11-26 19:01:20.968  - info: javascript.0 (506) script.js.Verknuepfungen.BW_Flur_OG: true
                    2023-11-26 19:01:21.056  - info: javascript.0 (506) script.js.Verknuepfungen.BW_Flur_OG: true
                    2023-11-26 19:03:23.989  - info: javascript.0 (506) script.js.Verknuepfungen.BW_Flur_OG: true
                    2023-11-26 19:03:24.047  - info: javascript.0 (506) script.js.Verknuepfungen.BW_Flur_OG: true
                    in adm ist er jetzt und http://ftp.de.debian.org/debian buster InRelease sollte raus sein.
                      @do5tj80
                      Dann würde ich den Arbeitsspeicher anders verteilen.
                      11GB für SWAP mach keinen Sinn, wenn nur 4GB primär zugeteilt werden.
                        do5tj80 @Thomas Braun last edited by do5tj80
                        Ok das schaue ich mir an.
                        Aber generel erst mal Danke , das du so viele Tip's gibst.
                          fvp @do5tj80 last edited by
                          Ich habe Version 4.0 ausprobiert. Leider noch mit dem gleichen Problem.
                          Zum Test habe ich eine Windows VM genommen und die 3.0.5 dort probiert. Auch hier kein Ankündigungston .
                          sayit.0
                          	2023-12-12 12:02:29.026	error	Cannot write file: TypeError [ERR_INVALID_ARG_TYPE]: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                          sayit.0
                          	2023-12-12 12:02:29.016	info	Upload announce mp3 files
                          sayit.0
                          	2023-12-12 12:02:29.012	info	starting. Version 3.0.5 in C:/ioBroker/node_modules/iobroker.sayit, node: v18.19.0, js-controller: 5.0.16
                          Ich hoffe er erbarmt sich jemand mich zu Unterstützen.
                          • bahnuhr
                            bahnuhr Forum Testing Most Active @fvp last edited by
                            @fvp
                            Sende erst das mp3
                            und nach x Sek. dann den Text.
                            Dies funktioniert.
                              fvp last edited by
                              @bahnuhr Danke für die Rückmeldung! Da habe ich aktuell noch keine Idee wie ich das geht. Bis jetzt habe ich einfach den Datenpunkt sayit.0.tts.text oder die Blockly-Funktion genutzt.
                              • bahnuhr
                                @fvp sagte in Sayit Adapter- Probleme nach Update:
                                Man muss halt auch mal die Hilfe der Adapter lesen.
                                Bringt manchmal Erleuchtung.
                                Denn da steht alles was du gerade suchst.
                                • bahnuhr
                                  per js so:
                                  setState('sayit.x.tts.text', '/opt/iobroker/iobroker-data/files/vis.0/mp3/xxx.mp3');
                                  setTimeout(function() { setState('sayit.x.tts.text', "Spülmaschine ist fertig.") } , 3000);
                                  F D 3 Replies Last reply Reply Quote 0
                                    fvp @bahnuhr last edited by
                                    @bahnuhr
                                    Erstmal vielen Dank für den Code.
                                    Das ich an dieser Stelle auch eine Datei angeben kann habe ich noch nicht gewusst.
                                    In der Hilfe steht hier
                                    sayit.N.tts.text: Phrase to be spoken.
                                    Hast du den Ankündigungston im Adapter abgeschaltet ?
                                    Ansonsten würde der Adapter in Zeile 2 ja versuchen diesen auszugeben ?
                                      @bahnuhr
                                      Ich habe deinen Tipp gerade ausprobiert.
                                      Als Workaround kann man das so machen.
                                      Aber die Idee hinter dem Adapter ist doch eigentlich das man sich darum nicht kümmern muss
                                              // place as first the announcement mp3
                                              tasks.push({
                                                  text: announce,
                                                  language,
                                                  volume: Math.round((volume || 70) / 100 * (parseInt(annoVolume, 10) || 50)),
                                                  ts: task.ts,
                                                  testOptions
                                              // and then text
                                              tasks.push(task);
                                      • bahnuhr
                                        @fvp
                                        Dein Script sagt jetzt aber absolut nix mit sayit.
                                          @bahnuhr
                                          Das ist nicht von mir.
                                          Ist ein Ausschnitt der Funktion addToQueue aus der main.js des Sayit Adapter.
                                          • bahnuhr
                                            Uns was willst du jetzt damit ?
                                            mal kritisch von mir:
                                            Du weißt nicht wie man eine mp3 sendet.
                                            und dann beschäftigst du dich mit der main.js
                                            Passt m.E. nicht zusammen.
                                            Aber einen workflow von mir hast du ja jetzt.
                                            51
                                            4230
