    4. Test Adapter sureflap v3.4.0
      Matt77CHE last edited by
      Bei mir das selbe; habe ebenfalls die main.js getauscht - jetzt tuts wieder 👍 danke
      • Sickboy78
        Sickboy78 @M-A Hueb last edited by
        Problem ist in der v1.1.8 gefixt.
        VG
          Matis @Sickboy78 last edited by
          @sickboy78
          Ich fürchte mit js 5 ist der Adapter nicht mehr lauffähig, wird nach einigen Sekunden angehalten, da zuviele Fehler.
          2023-06-29 00:09:46.292 - error: sureflap.0 (896) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          2023-06-29 00:09:46.296 - error: sureflap.0 (896) unhandled promise rejection: undefined is not a valid state value
          2023-06-29 00:09:46.301 - error: sureflap.0 (896) Error: undefined is not a valid state value
          at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/maybeCallback.js:35:17)
          at Sureflap._setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5376:49)
          at Sureflap.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5337:21)
          at Sureflap.setSerialNumberToAdapter (/opt/iobroker/node_modules/iobroker.sureflap/main.js:1288:9)
          at /opt/iobroker/node_modules/iobroker.sureflap/main.js:576:13
          at new Promise ()
          at Sureflap.getDeviceStatusFromData (/opt/iobroker/node_modules/iobroker.sureflap/main.js:554:39)
          at /opt/iobroker/node_modules/iobroker.sureflap/main.js:300:21
          2023-06-29 00:09:46.302 - error: sureflap.0 (896) undefined is not a valid state value
          2023-06-29 00:09:46.315 - warn: sureflap.0 (896) Terminated (UNCAUGHT_EXCEPTION): Without reason
          2023-06-29 00:09:46.874 - warn: sureflap.0 (896) redis get sureflap.0.Eisvogel.Eisvogel.Katzenklappe.curfew.0.enabled, error - Connection is closed.
          2023-06-29 00:09:46.876 - error: sureflap.0 (896) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          2023-06-29 00:09:46.876 - error: sureflap.0 (896) unhandled promise rejection: null
          2023-06-29 00:09:46.892 - warn: sureflap.0 (896) redis get sureflap.0.Eisvogel.Eisvogel.Katzenklappe.curfew.0.lock_time, error - Connection is closed.
          2023-06-29 00:09:46.894 - warn: sureflap.0 (896) redis get sureflap.0.Eisvogel.Eisvogel.Katzenklappe.curfew.0.unlock_time, error - Connection is closed.
          2023-06-29 00:09:46.966 - warn: sureflap.0 (896) get state error: Connection is closed.
          2023-06-29 00:09:46.968 - warn: sureflap.0 (896) get state error: Connection is closed.
          2023-06-29 00:09:46.970 - warn: sureflap.0 (896) get state error: Connection is closed.
          2023-06-29 00:09:46.979 - error: sureflap.0 (896) could not delete object 'Eisvogel.history.2' (Error: DB closed)
          2023-06-29 00:09:46.980 - error: sureflap.0 (896) updating event history failed (undefined)
          2023-06-29 00:09:46.980 - error: sureflap.0 (896) could not delete object 'Eisvogel.history.3' (Error: DB closed)
          2023-06-29 00:09:46.981 - error: sureflap.0 (896) could not delete object 'Eisvogel.history.4' (Error: DB closed)
          2023-06-29 00:09:46.981 - error: sureflap.0 (896) could not delete object 'Eisvogel.history.5' (Error: DB closed)
          2023-06-29 00:09:46.982 - error: sureflap.0 (896) could not delete object 'Eisvogel.history.6' (Error: DB closed)
          2023-06-29 00:09:46.982 - error: sureflap.0 (896) could not delete object 'Eisvogel.history.7' (Error: DB closed)
          2023-06-29 00:09:46.983 - error: sureflap.0 (896) could not delete object 'Eisvogel.history.8' (Error: DB closed)
          2023-06-29 00:09:46.984 - error: sureflap.0 (896) could not delete object 'Eisvogel.history.9' (Error: DB closed)
          2023-06-29 00:09:46.985 - error: sureflap.0 (896) could not delete object 'Eisvogel.history.10' (Error: DB closed)
          2023-06-29 00:09:46.985 - error: sureflap.0 (896) could not delete object 'Eisvogel.history.11' (Error: DB closed)
          2023-06-29 00:09:46.986 - error: sureflap.0 (896) could not delete object 'Eisvogel.history.12' (Error: DB closed)
          2023-06-29 00:09:46.987 - error: sureflap.0 (896) could not delete object 'Eisvogel.history.13' (Error: DB closed)
          2023-06-29 00:09:46.987 - error: sureflap.0 (896) could not delete object 'Eisvogel.history.14' (Error: DB closed)
          2023-06-29 00:09:46.988 - error: sureflap.0 (896) could not delete object 'Eisvogel.history.15' (Error: DB closed)
          2023-06-29 00:09:46.989 - error: sureflap.0 (896) could not delete object 'Eisvogel.history.16' (Error: DB closed)
          2023-06-29 00:09:46.989 - error: sureflap.0 (896) could not delete object 'Eisvogel.history.17' (Error: DB closed)
          2023-06-29 00:09:46.990 - error: sureflap.0 (896) could not delete object 'Eisvogel.history.18' (Error: DB closed)
          2023-06-29 00:09:46.991 - error: sureflap.0 (896) could not delete object 'Eisvogel.history.19' (Error: DB closed)
          2023-06-29 00:09:46.992 - error: sureflap.0 (896) could not delete object 'Eisvogel.history.20' (Error: DB closed)
          2023-06-29 00:09:46.992 - error: sureflap.0 (896) could not delete object 'Eisvogel.history.21' (Error: DB closed)
          2023-06-29 00:09:46.993 - error: sureflap.0 (896) could not delete object 'Eisvogel.history.22' (Error: DB closed)
          2023-06-29 00:09:46.994 - error: sureflap.0 (896) could not delete object 'Eisvogel.history.23' (Error: DB closed)
          2023-06-29 00:09:46.994 - error: sureflap.0 (896) could not delete object 'Eisvogel.history.24' (Error: DB closed)
          2023-06-29 00:09:46.995 - error: sureflap.0 (896) could not delete object 'Eisvogel.history.0' (Error: DB closed)
          2023-06-29 00:09:46.996 - error: sureflap.0 (896) could not delete object 'Eisvogel.history.1' (Error: DB closed)
          2023-06-29 00:09:47.164 - error: host.buanet-iobroker instance system.adapter.sureflap.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
          Sickboy78 1 Reply Last reply Reply Quote 0
          • Sickboy78
            Sickboy78 @Matis last edited by
            Hi @matis, sollte seit v1.1.9 gefixed sein.
            • Sickboy78
              Sickboy78 @Sickboy78 last edited by Sickboy78
              Version 1.2.0 ist da mit einigen Verbesserungen bei Timeout und Fehlerbehandlung.
              Außerdem kann der Adapter nun mit umbenannten oder gelöschten Haustiere umgehen.
              English:
              Version 1.2.0 is out with improvemnents for timeout and error handling.
              Also renamed or removed pets are now handeled by the adapter.
              • Sickboy78
                Surepet hat einige kritische Änderungen an der API vorgenommen. Ich arbeite daran, das Problem zu beheben, habe bereits 3 Änderungen gefunden und sie behoben/umgangen. Eine neue Version kommt in den nächsten Stunden/Tagen. Als schnelle Lösung, kann der Adapter direkt von Github installiert werden. Falls danach immer noch Probleme auftreten, bitte hier oder auf github melden.
                English:
                Surepet has made some breaking changes to the API. I'm working to resolve the issue, already found 3 changes and fixed/worked around them. I'll probably push a new version in the next hours/days. Feel free to update directly from github, for a quick fix. If you still have issues after this, please report them here or on github.
                Sickboy78 1 Reply Last reply Reply Quote 1
                • Sickboy78
                  Es scheint, dass Surepet seine Änderungen an der API zurückgerollt hat. Vielleicht weil sie auch Probleme mit ihrer App gemacht haben. Jedenfalls habe ich eine Version 1.2.1 erstellt, die für die API-Änderungen vorbereitet ist, falls sie wieder ausgerollt werden.
                  English:
                  It seems Surepet has rolled back it's changes to their API. Probably because it made also problems with their App.
                  Anyway I made a 1.2.1 version which is prepared for the API changes, when they are released again.
                    Stefi @Sickboy78 last edited by
                    @sickboy78 kannst du mir eventuell weiterhelfen? Seit dem Update des js-controllers bekomme ich den Adapter weder mit der 1.2.0 noch mit der 1.1.9 ans Laufen 😞
                    2023-10-17 21:02:29.544 - info: sureflap.0 (288818) starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.sureflap, node: v18.17.1, js-controller: 5.0.12
                    2023-10-17 21:02:29.588 - info: sureflap.0 (288818) checking adapter configuration...
                    2023-10-17 21:02:29.589 - info: sureflap.0 (288818) sureflap battery voltage full: 6.1
                    2023-10-17 21:02:29.590 - info: sureflap.0 (288818) sureflap battery voltage empty: 5.1
                    2023-10-17 21:02:29.591 - info: sureflap.0 (288818) surefeed battery voltage full: 6.2
                    2023-10-17 21:02:29.592 - info: sureflap.0 (288818) surefeed battery voltage empty: 5.2
                    2023-10-17 21:02:29.593 - info: sureflap.0 (288818) felaqua battery voltage full: 6.2
                    2023-10-17 21:02:29.593 - info: sureflap.0 (288818) felaqua battery voltage empty: 5.2
                    2023-10-17 21:02:29.594 - info: sureflap.0 (288818) adapter configuration ok
                    2023-10-17 21:02:29.598 - info: sureflap.0 (288818) connecting...
                    2023-10-17 21:02:30.369 - info: sureflap.0 (288818) connected
                    2023-10-17 21:02:30.371 - info: sureflap.0 (288818) starting update loop...
                    2023-10-17 21:02:30.379 - info: sureflap.0 (288818) update loop started
                    2023-10-17 21:02:37.407 - info: admin.0 (174) <== Disconnect system.user.admin from ::ffff:192.168.178.100
                    2023-10-17 21:02:39.022 - warn: sureflap.0 (288818) no remaining food data for feeder 'Lia_s_Futterbox' found
                    2023-10-17 21:02:39.024 - warn: sureflap.0 (288818) no remaining food data for feeder 'Benjis_Futterbox' found
                    2023-10-17 21:02:39.028 - warn: sureflap.0 (288818) aggregated report for pet 'Benji' does not contain feeding data
                    2023-10-17 21:02:39.029 - warn: sureflap.0 (288818) aggregated report for pet 'Lia' does not contain feeding data
                    2023-10-17 21:02:39.057 - error: sureflap.0 (288818) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                    2023-10-17 21:02:39.058 - error: sureflap.0 (288818) unhandled promise rejection: undefined is not a valid state value
                    2023-10-17 21:02:39.062 - error: sureflap.0 (288818) Error: undefined is not a valid state value
                    at Sureflap._setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5439:49)
                    at Sureflap.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5400:21)
                    at Immediate. (/opt/iobroker/node_modules/iobroker.sureflap/main.js:1099:12)
                    at process.processImmediate (node:internal/timers:478:21)
                    2023-10-17 21:02:39.063 - error: sureflap.0 (288818) undefined is not a valid state value
                    2023-10-17 21:02:39.093 - info: sureflap.0 (288818) everything cleaned up
                    2023-10-17 21:02:39.095 - info: sureflap.0 (288818) terminating
                    2023-10-17 21:02:39.096 - warn: sureflap.0 (288818) Terminated (UNCAUGHT_EXCEPTION): Without reason
                    2023-10-17 21:02:39.640 - info: sureflap.0 (288818) terminating
                    • Sickboy78
                      Sickboy78 @Stefi last edited by
                      Hallo @stefi, das sieht mir nach einem der Probleme durch die API Änderungen aus. Probier doch bitte mal die 1.2.1 aus.
                      Falls das nicht hilft, sag Bescheid, dann muss ich es mir genauer ansehen.
                        @sickboy78 Hi, habe es endlich geschafft auf die 1.2.1 zu aktualisieren. Aber es scheint noch immer nicht zu gehen:
                        sureflap.0
                        2023-11-26 20:46:34.517	warn	Terminated (NO_ADAPTER_CONFIG_FOUND): Without reason
                        sureflap.0
                        2023-11-26 20:46:34.461	error	adapter disabled
                        sureflap.0
                        2023-11-26 20:46:01.951	info	terminating
                        sureflap.0
                        2023-11-26 20:46:01.438	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                        sureflap.0
                        2023-11-26 20:46:01.436	info	terminating
                        sureflap.0
                        2023-11-26 20:46:01.435	info	everything cleaned up
                        sureflap.0
                        2023-11-26 20:46:01.433	error	unhandled promise rejection: null
                        sureflap.0
                        2023-11-26 20:46:01.432	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                        sureflap.0
                        2023-11-26 20:45:51.866	info	update loop started
                        sureflap.0
                        2023-11-26 20:45:51.858	info	starting update loop...
                        sureflap.0
                        2023-11-26 20:45:51.857	info	connected
                        sureflap.0
                        2023-11-26 20:45:50.894	info	connecting...
                        sureflap.0
                        2023-11-26 20:45:50.889	info	adapter configuration ok
                        sureflap.0
                        2023-11-26 20:45:50.888	info	felaqua battery voltage empty: 5.2
                        sureflap.0
                        2023-11-26 20:45:50.888	info	felaqua battery voltage full: 6.2
                        sureflap.0
                        2023-11-26 20:45:50.887	info	surefeed battery voltage empty: 5.2
                        sureflap.0
                        2023-11-26 20:45:50.886	info	surefeed battery voltage full: 6.2
                        sureflap.0
                        2023-11-26 20:45:50.886	info	sureflap battery voltage empty: 5.1
                        sureflap.0
                        2023-11-26 20:45:50.884	info	sureflap battery voltage full: 6.1
                        sureflap.0
                        2023-11-26 20:45:50.883	info	checking adapter configuration...
                        sureflap.0
                        2023-11-26 20:45:50.839	info	starting. Version 1.2.1 in /opt/iobroker/node_modules/iobroker.sureflap, node: v18.17.1, js-controller: 5.0.16
                        Hilft dir das etwas?
                        Liebe Grüße,
                        Stefi
                        Thomas Braun Sickboy78 2 Replies Last reply Reply Quote 0
                          Thomas Braun Most Active @Stefi last edited by
                          @stefi sagte in Test Adapter sureflap v1.0.x GitHub:
                          node: v18.17.1
                          Zu alt, aktualisier das per
                          iob nodejs-update
                          • Sickboy78
                            Sure Petcare hat seine App auf eine neue API umgestellt. Ich weiß nicht, wann die alte API abgeschaltet wird.
                            Ab Version 1.2.3 kann man die API konfigurieren und standardmäßig wird die neue API verwendet.
                            Falls der Adapter also plötzlich nicht mehr funktioniert, bitte auf eine Version >=1.2.3 upgraden.
                            Ich habe alle Funktionen mit der neuen API erfolgreich getestet. Falls euch Probleme oder Funktionen auffallen, die nicht mehr funktionieren, bitte hier im Forum oder auf Github https://github.com/Sickboy78/ioBroker.sureflap/issues bescheid geben.
                            Ich wünsche euch allen einen Guten Rutsch ins neue Jahr!
                            English:
                            Sure Petcare has changed its app to a new API. I don't know when the old API will be switched off.
                            From version 1.2.3 you can configure the API and the new API is used by default.
                            So if the adapter suddenly stops working for you, please upgrade to a version >=1.2.3.
                            I have successfully tested all functions with the new API. If you notice any problems or functions that no longer work, please let me know here in the forum or on Github https://github.com/Sickboy78/ioBroker.sureflap/issues.
                            I wish you all a Happy New Year!
                            @Stefi
                            Ich hoffe ich habe dein Problem mit der neuesten Version behoben. Bitte probier mal Version 1.2.3 (auf dem latest repository oder direkt von github) und gib mir Bescheid, ob es funktioniert hat.
                            • Sickboy78
                              Version 2.0.1 ist da und zeigt nun an, welches Tier zuletzt durch welche Klappe gegangen ist. Das ist vor allem für diejenigen interessant, die sich mit mehreren Klappen eine "Schleuse" gebaut haben. Außerdem gibt es Datenpunkte für wie oft und wie lange jedes Tier draußen war.
                              Anmerkung: Die movement.last_* Datenpunkte enthalten nur tatsächliche Bewegungen durch eine Klappe, aber keine Änderung der Position, die per App oder Adapter vorgenommen wurde.
                              English:
                              Version 2.0.1 is now available and shows which animal last passed through which flap. This is particularly interesting for those who have built a "sluice" with several flaps. There are also data points for how often and for how long each animal was outside.
                              Note: The movement.last_* data points only contain actual movements through a flap, but no location change made via app or adapter.
                              C 1 Reply Last reply Reply Quote 2
                                christianfeu @Sickboy78 last edited by
                                @sickboy78
                                Hallo, vielen Dank erstmal für diesen Adapter. Ich bin noch relativ neu bei SureFlap und habe meine Katzenklappe erst seit vergangener Woche. Bei mir hat die Stable 1.3.2 ein paar Tage funktioniert und auch die 2.0.1 lief bei mir. Seit ein paar Tagen gibt es bei mir aber Probleme. Ich kann die Klappe nicht mehr per Adapter verriegeln oder entriegeln. Das manuelle Setzen der An- oder Abwesenheit funktioniert aber. Weiterhin stürzt bei mir mir alle 20-30 min der javascript Adapter ab. Nur dann wenn der Sureflap Adapter läuft. Sobald er gestoppt wird, läuft wieder alles stabil. Die Probleme betreffen sowohl 1.3.2 als auch 2.0.1 & 2.0.2. Mein iobroker ist auf dem aktuellen Stand, node und js sind aktuell.
                                Bin ich der Einzige mit diesen Problemen? Sind das Probleme durch die neue API seitens SureFlap?
                                  Thomas Braun Most Active @christianfeu last edited by
                                  @christianfeu
                                  Und im Log steht dazu genau was?
                                    christianfeu @Thomas Braun last edited by christianfeu
                                    Sehr schwierige Frage: kein Error, kein Warn, weder bei javascript noch beim sureflap
                                    Was genau ist die Frage? Das Protokoll ist groß….
                                      @christianfeu sagte in Test Adapter sureflap v1.0.x GitHub:
                                      Das tut der unter Garantie nicht lautlos.
                                      Schau in
                                      iob logs --watch
                                      uns spiel mit dem Adapter herum.
                                        ok mache ich. Vielen Dank.
                                        Wollte erstmal rausfinden, ob ich der einzige bin mit Problemen…
                                          christianfeu @christianfeu last edited by
                                          @christianfeu
                                          Also, in dem Moment wo ich eine Aktion über den SureFlap Adapter ansteuere und ein paar Sekunden später stürzt der Javascript Adapter ab. Habe das jetzt exakt beobachtet. Beim Absturz kommen Meldungen, die mit Redis zusammenhängen.
                                          Hilft das weiter?
                                          2024-02-08 19:57:40.560 - silly: sureflap.0 (102333) doing http request with tag get_data
                                          2024-02-08 19:57:50.615 - silly: sureflap.0 (102333) redis message expired/evicted keyevent@0:expired:io.system.adapter.javascript.0.inputCount
                                          2024-02-08 19:57:50.716 - silly: sureflap.0 (102333) redis message expired/evicted keyevent@0:expired:io.system.adapter.javascript.0.cputime
                                          2024-02-08 19:57:50.717 - silly: sureflap.0 (102333) redis message expired/evicted keyevent@0:expired:io.system.adapter.javascript.0.alive
                                          2024-02-08 19:57:51.019 - silly: sureflap.0 (102333) redis message expired/evicted keyevent@0:expired:io.system.adapter.javascript.0.cpu
                                          2024-02-08 19:57:51.052 - silly: sureflap.0 (102333) doing http request with tag get_data
                                          2024-02-08 19:57:51.122 - silly: sureflap.0 (102333) redis message expired/evicted keyevent@0:expired:io.system.adapter.javascript.0.outputCount
                                          2024-02-08 19:57:51.123 - silly: sureflap.0 (102333) redis message expired/evicted keyevent@0:expired:io.system.adapter.javascript.0.eventLoopLag
                                          2024-02-08 19:57:51.632 - silly: sureflap.0 (102333) redis message expired/evicted keyevent@0:expired:io.system.adapter.javascript.0.memHeapUsed
                                          2024-02-08 19:57:51.935 - silly: sureflap.0 (102333) redis message expired/evicted keyevent@0:expired:io.system.adapter.javascript.0.memHeapTotal
                                          2024-02-08 19:57:52.140 - silly: sureflap.0 (102333) redis message expired/evicted keyevent@0:expired:io.system.adapter.javascript.0.memRss
                                          2024-02-08 19:57:52.343 - silly: sureflap.0 (102333) redis message expired/evicted keyevent@0:expired:io.system.adapter.javascript.0.connected
                                          2024-02-08 19:57:52.344 - silly: sureflap.0 (102333) redis message expired/evicted keyevent@0:expired:io.system.adapter.javascript.0.uptime
                                          2024-02-08 19:58:01.520 - silly: sureflap.0 (102333) doing http request with tag get_data
                                            cooper2k4 @Sickboy78 last edited by cooper2k4
                                            ich habe seit ca. 3 Wochen das Problem, dass die Protokollierung via SQL-Adapter (sqlite) nicht mehr funktioniert. Ich kann mich leider an keine Änderung an der ioBroker Installation erinnern...
                                            Wenn ich den sureflap-Adapter neustarte wird das Logging automatisch deaktiviert. Ich habe gerade von v1.2.3 auf v2.0.1 aktualisiert. Das hat aber keine Änderung gebracht. Mit anderen Adaptern funktioniert das SQL-Logging ohne Probleme. Liegt es am sureflap- oder SQL-Adapter?
                                            Ich habe schon alles Mögliche probiert (npm cache clean/rebuild, iob Objekte löschen etc.). Weiß jemand noch Rat?
                                            Viele Grüße
                                            Thorsten
                                            pi@iobroker:/opt/iobroker $ iob info
                                            Platform       : linux
                                            os             : linux
                                            Architecture   : arm64
                                            CPUs           : 4
                                            Speed          : 1700 MHz
                                            Model          : Cortex-A72
                                            RAM            : 3.7 GB
                                            System uptime  : 1d. 15:52:06
                                            Node.js        : v20.5.1
                                            time           : 1707651469831
                                            timeOffset     : -60
                                            NPM            : 10.4.0
                                            adapters count : 530
                                            Disk size      : 29.1 GiB
                                            Disk free      : 9.2 GiB
                                            153
                                            32532
