    4. Stiebel-ISG - Modbus
    • frana120500
      frana120500 @MarkusL last edited by frana120500
      Nach dem Update auf JS Controller 5 erhalte ich im Log die nachfolgenden Fehler und der Adapter bleibt rot:
      stiebel-isg.0
      2023-06-13 09:39:35.438	error	Parameter "options" needs to be a real object but type "object" has been passed
      stiebel-isg.0
      2023-06-13 09:39:35.438	error	Error: Parameter "options" needs to be a real object but type "object" has been passed at Validator.assertObject (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/validator.js:215:19) at AdapterClass.setObjectNotExists (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:3388:35) at main (/opt/iobroker/node_modules/iobroker.stiebel-isg/main.js:703:10) at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.stiebel-isg/main.js:63:6) at process.processImmediate (node:internal/timers:478:21)
      stiebel-isg.0
      2023-06-13 09:39:35.436	error	uncaught exception: Parameter "options" needs to be a real object but type "object" has been passed
      stiebel-isg.0
      2023-06-13 09:37:48.624	error	Parameter "options" needs to be a real object but type "object" has been passed
      stiebel-isg.0
      2023-06-13 09:37:48.624	error	Error: Parameter "options" needs to be a real object but type "object" has been passed at Validator.assertObject (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/validator.js:215:19) at AdapterClass.setObjectNotExists (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:3388:35) at main (/opt/iobroker/node_modules/iobroker.stiebel-isg/main.js:703:10) at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.stiebel-isg/main.js:63:6) at process.processImmediate (node:internal/timers:478:21)
      stiebel-isg.0
      2023-06-13 09:37:48.622	error	uncaught exception: Parameter "options" needs to be a real object but type "object" has been passed
      stiebel-isg.0
      2023-06-13 09:37:17.185	error	Parameter "options" needs to be a real object but type "object" has been passed
      stiebel-isg.0
      2023-06-13 09:37:17.185	error	Error: Parameter "options" needs to be a real object but type "object" has been passed at Validator.assertObject (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/validator.js:215:19) at AdapterClass.setObjectNotExists (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:3388:35) at main (/opt/iobroker/node_modules/iobroker.stiebel-isg/main.js:703:10) at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.stiebel-isg/main.js:63:6) at process.processImmediate (node:internal/timers:478:21)
      stiebel-isg.0
      2023-06-13 09:37:17.183	error	uncaught exception: Parameter "options" needs to be a real object but type "object" has been passed
      stiebel-isg.0
      2023-06-13 09:36:58.404	error	Parameter "options" needs to be a real object but type "object" has been passed
      stiebel-isg.0
      2023-06-13 09:36:58.404	error	Error: Parameter "options" needs to be a real object but type "object" has been passed at Validator.assertObject (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/validator.js:215:19) at AdapterClass.setObjectNotExists (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:3388:35) at main (/opt/iobroker/node_modules/iobroker.stiebel-isg/main.js:703:10) at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.stiebel-isg/main.js:63:6) at process.processImmediate (node:internal/timers:478:21)
      stiebel-isg.0
      2023-06-13 09:36:58.402	error	uncaught exception: Parameter "options" needs to be a real object but type "object" has been passed
      unltdnetworx 1 Reply Last reply Reply Quote 0
      • unltdnetworx
        unltdnetworx Developer @frana120500 last edited by
        @frana120500
        Bitte mal über Github updaten. Sollte wieder laufen.
        frana120500 1 Reply Last reply Reply Quote 0
        • frana120500
          frana120500 @unltdnetworx last edited by
          @unltdnetworx Schnell wie die Feuerwehr 🙂
          Adapter läuft wieder. Vielen Dank dafür
            Fraat @kreuzundkwer last edited by Fraat
            @kreuzundkwer @unltdnetworx Hallo, ich habe das gleiche Problem. Alle Holdingregister sind 0 bei einer LWZ 303 SOL. Gibt es dafür eine Lösung?
            • unltdnetworx
              unltdnetworx Developer @Fraat last edited by
              @fraat
              Was zeigt denn die Weboberfläche für die jeweiligen Werte?
                Android51 last edited by Android51
                Ist das bei eurem isg (bei mir isg Web) auch so, wenn das Gerät stromlos war, dass es nach dem Hochfahren sg ready aktiviert und die forcierten Werte aus dem Energiemanagement ansteuert? Ist halt blöd, wenn sich unnötig der Heizstab einschaltet, wenn z. B. kein PV Überschuss vorhanden ist.
                • unltdnetworx
                  unltdnetworx Developer @Android51 last edited by unltdnetworx
                  @android51
                  Das kann ich leider nicht beantworten, da bei mir das ISG nie stromlos ist.
                    Ist bei mir auch nicht der Regelfall. Habe nur die Tage was an meiner Elektroinstallation ergänzt und musste die Sicherung rausnehmen. Da war das isg kurzzeitig stromlos. Als ich die Sicherung wieder eingeschaltet habe, fuhr das isg hoch und die Warmwasserbereitung wurde aktiviert, weil das System die forcierten Werte erreichen wollte. Habe es glücklicherweise sofort erkannt. Wenn aber mal, aus welchen Gründen auch immer, der Netzbetreiber einen Stromausfall verursacht oder durch höhere Gewalt und ich nicht zu Hause bin, würde man es nicht mitbekommen. Nicht dramatisch, aber auch nicht schön.
                      litithio last edited by litithio
                      Ich habe ein Problem mit der Kombination aus ISG mit EMI Modul und Modbus.
                      Prinzipiell sollte ja seit 2-3 Jahren Modbus auch weiterhin funktionieren, wenn das EMI Modul installiert ist.
                      Vor etwa einem Monat habe ich das EMI Modul bekommen. Modbus funktioniert zwar noch, aber ich kann nur noch ca. 10 Werte abrufen.
                      Speziell ist es zudem bei 32501 Beitriebsstatus. Hier werden ganz andere Zahlen übermittelt als vorher. Im Heizbetrieb steht hier nun z. B. eine 81 und im Warmwasserbetrieb eine 97. Werte dieser Art tauchen in der Modbus-Doku nicht auf ...
                      Bei den anderen Werte kommt entweder nichts an, oder der Modbus-Adapter startet erst gar nicht. Vor der Installation des EMI Moduls hat alles wunderbar geklappt.
                      Gibt es hier andere Nutzer die diese Kombination ebenfalls betreiben? Wie sieht das bei euch aus? Bekommt ihr nach wie vor alle Werte, die auch vor der Installation des EMI Moduls kamen?
                      Auf dem ISG läuft bei mir Version 12.1.2., gibt es da mittlerweile eine neuere Version? Hatte bei der Bestellung des EMI Moduls eigentlich auch darum gebeten, Updates einzuspielen, falls welche verfügbar wären.
                        Schimi @litithio last edited by
                        @litithio Die neuste ist "v12.2.3"
                        könnte sein das durch das Modul, Modbus register dazu gekommen sind und nun "verschoben" ausgelesen werden.....
                        Ich wüsste jetzt keine art sich zu helfen... ausser ausprobieren (vielleicht die abfrage auch verkleiner/verlangsamen um das ISG nicht zu überlasten) oder Stiebel mal zu fragen ob sich da was geändert hat.....
                          Mein ISG-Web wurde vor kurzem aktualisiert. Bin jetzt auf Version 12.2.3. Habe festgestellt, das mir inzwischen auch die Inverter Aufnahmeleistung angezeigt wird. Weiß jemand zufällig, ob es dafür auch eine Modbus Adresse gibt?
                            SaarlandUHU last edited by
                            da wir kürzlich eine PV-Anlage bekommen haben, kann ich die Abgerufene Leistung der Heizung nicht mehr direkt am Stromzähler abgreifen, da zum einen die beiden Zähler für Wärme- und Hausstrom hintereinander hängen und zum anderen der Stromzähler ja nichts zählt, wenn die Heizung über den Strom der PV-Anlage läuft. Ich habe zwar die Daten der Erzeugung, die Daten vom anderen Stromzähler usw. und könnte mir die Leistung der Heizung berechnen. Aber bevor ich das umsetze wollte die Daten direkt aus der Heizung abfragen. Über das ISG und den ISG-Adapter wird mit der Tages-Verbrauch von Warmwasser und Heizung ja angezeigt. Hierüber wollte ich dann die aktuelle Leistung als Delta der beiden letzten Werte errechnen. Im ISG-Adapter werden die Werte mit drei Dezimalstellen angezeigt, womit man ja gut arbeiten kann.
                            Ziehe ich mir die Daten über den Modbus, werden mir nur ganze kWh angezeigt. Damit kann ich ja dann relativ wenig mit anfangen, wenn ich einen Tagesverlauf darstellen will.
                            Ist das eine Einstellungssache oder gibt der Modbus die Daten einfach nur als ganze kWh weiter?
                            Vielen Dank schonmal.
                              derdominik @SaarlandUHU last edited by
                              @saarlanduhu ich habe keine direkte Lösung für das Modbus-Problem, bei mir sind das auch nur ganze kWh.
                              Aber wenn du eine PV-Anlage hast, hast du dann auch das EMI-Modul? Wenn ja, dann lässt sich der aktuelle Verbrauch per https://github.com/unltdnetworx/ioBroker.stiebel-isg von der EMI-Status-Seite auslesen.
                                ChrisWitt last edited by ChrisWitt
                                Ich versuche gerade meine LWZ504 mittels ISG Plus und NEUESTER Software über Modbus anzusteuern.
                                Mit geht es um den SG Ready Eingang den ich ansteuern will.
                                Dies soll dann später automatisiert den Status von Tibber an die Schnittstelle übergeben und die Anlage forcieren.
                                Angelegt habe ich zum Test die Holding Register wie folgt :
                                Steuere ich nun im Baum die Eingänge mit 1/0 kann ich alle 4 Betriebszustände steuern bzw. Sehe ich dann als Betriebszustand.
                                Steuere ich das ganze aber dann via Skript (dies ist nur ein Testskript) , sehe ich zwar auch den sich ändernden Wert im Baum, jedoch ändert sich der Betriebszustand nicht.
                                Was mache ich im Skript falsch bzw. Wie muss das Holding Register angelegt werden ?
                                Ich danke euch
                                • unltdnetworx
                                  unltdnetworx Developer @ChrisWitt last edited by unltdnetworx
                                  @chriswitt
                                  Hallo Chris,
                                  ich persönlich würde statt "aktualisiere" die Funktion "setze" (heißt die so?) verwenden, aber das ist nicht das Problem.
                                  Du brauchst für deine Funktion einen Trigger. Den einfach um deinen Block herumsetzen. Z.B. "Wenn geändert Wert von Auto 11..."
                                    ChrisWitt @unltdnetworx last edited by
                                    @unltdnetworx
                                    Habe es auch mit diesem versucht :
                                    Trigger ist klar, brauche ich dann später. Aktuell ändere ich im Skript halt manuell die Werte und speichere neu ab.
                                    Es ändert sich ja auch der Wert im Baum, nur „überträgt“ es irgendwie nicht auf das ISG . Also vermute ich irgendwo einen Fehler im Modbus- Adapter ?
                                    • unltdnetworx
                                      @chriswitt
                                      Ich meinte "steuere Ready1 auf 0". So klappt es jeden Falls bei mir.
                                      Edit:
                                      "Steuere" heißt die Fuktion die ich meinte, nicht "Setze".
                                        @unltdnetworx hey super. Scheint zu funktionieren.
                                        Da ich an den Basics offenbar schon scheitere wird es ein Spaß das ganze mit Tibber zu steuern....
                                        Forcieren uns. max werte anzusteuern ist ja kein Problem, aber sicherzustellen, dass Heizung trotzdem x stunden läuft und WW da ist, das wird spannend...
                                        • unltdnetworx
                                          unltdnetworx Developer last edited by
                                          @chriswitt
                                          Naja, der Eingang 1 ist ja eigentlich dafür gedacht, den vorhandenen Stromüberschuss zu verwenden. Dass die Heizung warm ist sollte sie selbst sicherstellen.
                                            axel @unltdnetworx last edited by
                                            @unltdnetworx Ich verfolge das Thema sehr interessiert. Habe meine TTL 7.6 mit dem Adapter verbunden. Eigentlich ganz ok. Nun wollte ich Werte setzen und stosse an Grenzen. Ich möchte die maximale Vorlauftemperatur verändern, das geht aber nicht. Der neue Wert wird zwar vom Datenpunkt akzeptiert, aber nicht in den WPM geschrieben. Bein nächsten Auslesen ist der alte Wert wieder da. Woran liegt das? Muss ich das wirklich am Display einstellen? Ich wollte meine Heizkurve und den Vorlauf in Abhängigkeit der Wetterprognose optimieren. Kann mir jemand erklären, warum ich die Werte nicht über das Interface verändern kann?
                                            1.2k
                                            modbus stiebel-isg
                                            35
                                            486
                                            117125
