      TT-Tom last edited by TT-Tom
      @cluni sagte in SONOFF NSPanel mit Lovelace UI:
      Habe gerade das Skript mal neu gestartet, aber die Warnungen sind noch da. Aber das stört mich nicht wirklich - ich schaue eh von Zeit zu Zeit immer mal überall durch, ob man was auf den neusten Stand bringen kann.
      Morgen
      habe die aktuelle Scriptversion mal gestartet, ohne Probleme bzw. Warnungen. Welche Version hast du grade am laufen, kannst du mal in die Tasmota Konsole schauen, ob Daten gesendet werden. sollte so aussehen.
      09:26:38.078 MQT: SmartHome/NSPanel_1/tele/STATE = {"Time":"2023-11-27T09:26:38","Uptime":"8T16:15:28","UptimeSec":749728,"Heap":85,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":33,"Berry":{"HeapUsed":53,"Objects":652},"POWER1":"ON","POWER2":"ON","Wifi":{"AP":1,"SSId":"TomTom24","BSSId":"2C:91:AB:AF:46:A7","Channel":2,"Mode":"11n","RSSI":68,"Signal":-66,"LinkCount":14,"Downtime":"0T00:02:35"}}
      09:26:38.099 MQT: SmartHome/NSPanel_1/tele/SENSOR = {"Time":"2023-11-27T09:26:38","ANALOG":{"Temperature1":-3.6},"ESP32":{"Temperature":70.0},"TempUnit":"C"}
      09:26:46.233 MQT: SmartHome/NSPanel_1/stat/STATUS0 = {"Status":{"Module":0,"DeviceName":"NSPanelBuero","FriendlyName":["NSPanelBuero",""],"Topic":"NSPanel_1","ButtonTopic":"0","Power":3,"PowerOnState":3,"LedState":1,"LedMask":"FFFF","SaveData":1,"SaveState":1,"SwitchTopic":"0","SwitchMode":[0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0],"ButtonRetain":0,"SwitchRetain":0,"SensorRetain":0,"PowerRetain":0,"InfoRetain":0,"StateRetain":0,"StatusRetain":0},"StatusPRM":{"Baudrate":115200,"SerialConfig":"8N1","GroupTopic":"tasmotas","OtaUrl":"http://ota.tasmota.com/tasmota32/release/tasmota32-DE.bin","RestartReason":"Software reset CPU","Uptime":"8T16:15:36","StartupUTC":"2023-11-18T16:11:10","Sleep":50,"CfgHolder":4617,"BootCount":32,"BCResetTime":"2023-01-05T06:15:40","SaveCount":277},"StatusFWR":{"Version":"13.2.0(tasmota32)","BuildDateTime":"2023.10.19 09:11:03","Core":"2_0_14","SDK":"4.4.6.231011","CpuFrequency":160,"Hardware":"ESP32-D0WD-V3 v3.0","CR":"452/699"},"StatusLOG":{"SerialLog":2,"WebLog":2,"MqttLog":2,"SysLog":0,"LogHost":"192.168.178.121","LogPort":514,"SSId":["TomTom24",""],"TelePeriod":300,"Resolution":"558180C0","SetOption":["00008009","2805C80001000600003C5A0A192800000000","00000080","00006000","00004000","00000001"]},"StatusMEM":{"ProgramSize":1873,"Free":1006,"Heap":87,"StackLowMark":4,"PsrMax":0,"PsrFree":0,"ProgramFlashSize":4096,"FlashSize":4096,"FlashChipId":"16405E","FlashFrequency":40,"FlashMode":"DIO","Features":["00000407","9F9AD7DF","0015A001","B7F7BFCF","05DA9BC4","E0360DC7","480840D2","20200000","D4BC482D","010A80B1"],"Drivers":"1,2,3,4,5,7,8,9,10,11,12,14,16,17,20,21,24,26,27,29,34,35,38,50,52,59,60,62,63,66,67,68,82,86,87,88","Sensors":"1,2,3,5,6,7,8,9,10,11,12,13,14,15,17,18,19,20,21,22,26,31,34,37,39,40,42,43,45,51,52,55,56,58,59,64,66,67,74,85,92,95,98,103,105,109,127","I2CDriver":"7,8,9,10,11,12,13,14,15,17,18,20,24,29,31,36,41,42,44,46,48,58,62,65,69,76,77,82"},"StatusNET":{"Hostname":"NSPanelBuero","IPAddress":"192.168.178.101","Gateway":"192.168.178.1","Subnetmask":"255.255.255.0","DNSServer1":"192.168.178.1","DNSServer2":"2a02:8109:a301:a900:b2f2:8ff:fe43:c159","Mac":"7C:87:CE:C6:1B:74","IP6Global":"2a02:8109:a301:a900:7e87:ceff:fec6:1b74","IP6Local":"fe80::7e87:ceff:fec6:1b74","Ethernet":{"Hostname":"","IPAddress":"0.0.0.0","Gateway":"0.0.0.0","Subnetmask":"0.0.0.0","DNSServer1":"192.168.178.1","DNSServer2":"2a02:8109:a301:a900:b2f2:8ff:fe43:c159","Mac":"00:00:00:00:00:00","IP6Global":"","IP6Local":""},"Webserver":2,"HTTP_API":1,"WifiConfig":4,"WifiPower":17.0},"StatusMQT":{"MqttHost":"192.168.178.121","MqttPort":1886,"MqttClientMask":"NSPanelBüro","MqttClient":"NSPanelBüro","MqttUser":"Iobroker","MqttCount":33,"MAX_PACKET_SIZE":1200,"KEEPALIVE":30,"SOCKET_TIMEOUT":4},"StatusTIM":{"UTC":"2023-11-27T08:26:46","Local":"2023-11-27T09:26:46","StartDST":"2023-03-26T02:00:00","EndDST":"2023-10-29T03:00:00","Timezone":"+01:00","Sunrise":"08:16","Sunset":"16:58"},"StatusSNS":{"Time":"2023-11-27T09:26:46","ANALOG":{"Temperature1":-3.8},"ESP32":{"Temperature":70.0},"TempUnit":"C"},"StatusSTS":{"Time":"2023-11-27T09:26:46","Uptime":"8T16:15:36","UptimeSec":749736,"Heap":86,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":21,"MqttCount":33,"Berry":{"HeapUsed":53,"Objects":652},"POWER1":"ON","POWER2":"ON","Wifi":{"AP":1,"SSId":"TomTom24","BSSId":"2C:91:AB:AF:46:A7","Channel":2,"Mode":"11n","RSSI":68,"Signal":-66,"LinkCount":14,"Downtime":"0T00:02:35"}}}
      zusätzlich kannst du im Browser mal eingeben:
      http:// ip vom Panel /cm?cmnd=Status0
      Armilar Cluni 2 Replies Last reply Reply Quote 1
      • Armilar
        Armilar Most Active Forum Testing @TT-Tom last edited by Armilar
        @tt-tom
        @Cluni
        Ja, wird diese Zeile sein:
        Der Datenpunkt currentVersion wird leer sein. Könnten wir noch abfangen und etwas schöner ausgeben.
        @TT-Tom liegt da schon richtig. Einfach mal den Status abrufen und in den Datenpunkt der Tasmota-Version sehen...
        Das Limit und die Warnung des 2. Fehlers kommt durch zu viele Starts des Skriptes zustande...
        Ist, obwohl ich viel am Testen war, aber ebenfalls ohne Warnungen...
        Hat aber keinen Einfluss auf die Funktionalität des NSPanels
        • Cluni
          Cluni @TT-Tom last edited by Cluni
          @tt-tom said in SONOFF NSPanel mit Lovelace UI:
          Sieht bei mir so aus:
          11:21:05.953 MQT: SmartHome/NSPanel_Flur/tele/STATE = {"Time":"2023-11-27T11:21:05","Uptime":"0T14:00:09","UptimeSec":50409,"Heap":122,"SleepMode":"Dynamic","Sleep":0,"LoadAvg":999,"MqttCount":2,"Berry":{"HeapUsed":35,"Objects":475},"POWER1":"OFF","POWER2":"OFF","Wifi":{"AP":1,"SSId":"Virus4free","BSSId":"38:10:D5:04:65:36","Channel":7,"Mode":"11n","RSSI":100,"Signal":-45,"LinkCount":2,"Downtime":"0T00:00:07"}}
          11:21:05.970 MQT: SmartHome/NSPanel_Flur/tele/SENSOR = {"Time":"2023-11-27T11:21:05","ANALOG":{"Temperature1":22.6},"ESP32":{"Temperature":53.9},"TempUnit":"C"}
          11:21:26.802 MQT: SmartHome/NSPanel_Flur/stat/STATUS0 = {"Status":{"Module":0,"DeviceName":"Tasmota","FriendlyName":["Tasmota",""],"Topic":"NSPanel_Flur","ButtonTopic":"0","Power":0,"PowerOnState":3,"LedState":1,"LedMask":"FFFF","SaveData":1,"SaveState":1,"SwitchTopic":"0","SwitchMode":[0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0],"ButtonRetain":0,"SwitchRetain":0,"SensorRetain":0,"PowerRetain":0,"InfoRetain":0,"StateRetain":0,"StatusRetain":0},"StatusPRM":{"Baudrate":115200,"SerialConfig":"8N1","GroupTopic":"tasmotas","OtaUrl":"http://ota.tasmota.com/tasmota32/release/tasmota32-nspanel.bin","RestartReason":"Software reset CPU","Uptime":"0T14:00:30","StartupUTC":"2023-11-26T19:20:56","Sleep":0,"CfgHolder":4617,"BootCount":59,"BCResetTime":"2023-04-12T07:44:20","SaveCount":1218},"StatusFWR":{"Version":"13.2.0(nspanel)","BuildDateTime":"2023-10-19T09:05:12","Core":"2_0_14","SDK":"4.4.6.231011","CpuFrequency":160,"Hardware":"ESP32-D0WD-V3 v3.0","CR":"519/699"},"StatusLOG":{"SerialLog":2,"WebLog":2,"MqttLog":2,"SysLog":0,"LogHost":"192.168.0.88","LogPort":514,"SSId":["Virus4free","Telemeasurement"],"TelePeriod":300,"Resolution":"558180C0","SetOption":["00008009","2805C80001000600003C5A0A192800000000","00000080","20006000","00004000","00000001"]},"StatusMEM":{"ProgramSize":1872,"Free":1007,"Heap":114,"StackLowMark":3,"PsrMax":0,"PsrFree":0,"ProgramFlashSize":4096,"FlashSize":4096,"FlashChipId":"16405E","FlashFrequency":40,"FlashMode":"DIO","Features":["00000809","9F9AD7DF","0015A001","B7F7BFCF","05DA9BC4","E0360DC7","480840D2","20200000","D4BC482D","010A80B1"],"Drivers":"1,2,3,4,5,7,8,9,10,11,12,14,16,17,20,21,24,26,27,29,34,35,38,50,52,59,60,62,63,66,67,68,82,86,87,88","Sensors":"1,2,3,5,6,7,8,9,10,11,12,13,14,15,17,18,19,20,21,22,26,31,34,37,39,40,42,43,45,51,52,55,56,58,59,64,66,67,74,85,92,95,98,103,105,109,127","I2CDriver":"7,8,9,10,11,12,13,14,15,17,18,20,24,29,31,36,41,42,44,46,48,58,62,65,69,76,77,82"},"StatusNET":{"Hostname":"NSPanel-Flur-0792","IPAddress":"192.168.0.126","Gateway":"192.168.0.1","Subnetmask":"255.255.255.0","DNSServer1":"192.168.0.1","DNSServer2":"2003:c9:1f1f:3d00:7642:7fff:fe22:1eae","Mac":"80:64:6F:C3:A3:18","IP6Global":"2003:c9:1f1f:3d00:8264:6fff:fec3:a318","IP6Local":"fe80::8264:6fff:fec3:a318","Ethernet":{"Hostname":"","IPAddress":"0.0.0.0","Gateway":"0.0.0.0","Subnetmask":"0.0.0.0","DNSServer1":"192.168.0.1","DNSServer2":"2003:c9:1f1f:3d00:7642:7fff:fe22:1eae","Mac":"00:00:00:00:00:00","IP6Global":"","IP6Local":""},"Webserver":2,"HTTP_API":1,"WifiConfig":4,"WifiPower":17.0},"StatusMQT":{"MqttHost":"192.168.0.88","MqttPort":1883,"MqttClientMask":"DVES_%06X","MqttClient":"DVES_C3A318","MqttUser":"tasmota","MqttCount":2,"MAX_PACKET_SIZE":1200,"KEEPALIVE":30,"SOCKET_TIMEOUT":4},"StatusTIM":{"UTC":"2023-11-27T09:21:26","Local":"2023-11-27T11:21:26","StartDST":"2023-03-26T02:00:00","EndDST":"2023-10-29T03:00:00","Timezone":"+02:00","Sunrise":"09:16","Sunset":"17:58"},"StatusSNS":{"Time":"2023-11-27T11:21:26","ANALOG":{"Temperature1":22.6},"ESP32":{"Temperature":53.9},"TempUnit":"C"},"StatusSTS":{"Time":"2023-11-27T11:21:26","Uptime":"0T14:00:30","UptimeSec":50430,"Heap":112,"SleepMode":"Dynamic","Sleep":0,"LoadAvg":999,"MqttCount":2,"Berry":{"HeapUsed":35,"Objects":475},"POWER1":"OFF","POWER2":"OFF","Wifi":{"AP":1,"SSId":"Virus4free","BSSId":"38:10:D5:04:65:36","Channel":7,"Mode":"11n","RSSI":100,"Signal":-45,"LinkCount":2,"Downtime":"0T00:00:07"}}}
          PS: Ich hab mal die Timezone korrigiert... 🙈
          Cluni 1 Reply Last reply Reply Quote 0
          • Cluni
            Cluni @Cluni last edited by
            Mal so als allgemeine Frage - ich bin nicht ganz so firm in JS: Wäre es nicht möglich, dass man für die eigenen Konfigurationen irgendwo (vielleicht unter global) eine Datei anlegt, so dass man nicht jedes Mal bei einem Update vom Skript mühsam die Sachen hin und her kopieren muss? Dass dann auch dort in der eigenen (ich nenne sie mal) Config-Datei ggf. Anpassungen notwendig sein könnten, ist logisch. Aber das würde die Sache denke ich stark vereinfachen.
            T Armilar 2 Replies Last reply Reply Quote 1
              TT-Tom @Cluni last edited by
              @cluni
              Möglich ist fast alles, nur der Aufwand ist da sehr groß und steht nicht in Relation zum Nutzen. Der Support würde auch steigen, der zu leisten wäre. Was dieser Thread auch zeigt. Wir haben den Bereich auch schon zusammengefasst und optimiert, damit ein Update nicht so kompliziert ist. Und so oft muss ja nicht mit gezogen werden, nur weil wir etwas anpassen. Erst wenn es deine Konstellation betrifft oder wir ein Breaking Change machen müssen.
              Ps sind deine Daten jetzt eigentlich da oder bekommst du immer noch Fehlermeldungen?
              Cluni 1 Reply Last reply Reply Quote 1
              • Armilar
                Armilar Most Active Forum Testing @Cluni last edited by
                Muss auch nicht... Die paar Variablen im Config-Bereich kann man sicher mit Hilfe der Wiki erstellen. Den Rest muss eigentlich niemand anfassen und das steht ja auch explizit drin 😉
                Updates bedeutet eigentlich nur Copy/Paste des unteren Teils und dauert je Panel ca. 1-2 Minuten...
                Nein - da die TypeScript - Typenprüfung dann nicht mehr stattfinden kann und das wird massive Probleme im Support erzeugen, da jede fehlerhafte Variablendefinition zur Stecknadel im Heuhaufen wird...
                • Cluni
                  @tt-tom Beide Warnings kommen nach wie vor. Aber damit kann ich leben. So richtig den Unterschied sehe ich nicht in den Ausgaben bei dir und bei mir in der Tasmota Konsole. Oder habe ich was übersehen?
                  @Armilar Ok, das ist dann natürlich ein guter Grund. War ja auch nur so eine Idee.
                    @cluni
                    also auspacken tut das Panel die Info
                    wie sieht den dein Zweig von Tasmota aus??
                    Cluni 2 Replies Last reply Reply Quote 0
                    • Cluni
                      Ja, da sehen die Infos dürftig aus:
                      • Cluni
                        @tt-tom gibt es denn einen bestimmten Grund, warum du die "normale", deutsche Version von Tasmota benutzt und nicht die Version extra fürs NSPanel?
                        Dein OTA-Link: http://ota.tasmota.com/tasmota32/release/tasmota32-DE.bin
                        Mein OTA-Link: http://ota.tasmota.com/tasmota32/release/tasmota32-nspanel.bin
                        Wo genau liegt denn der Unterschied in den Versionen?
                          @cluni
                          Ist bei dir in der Java Instanz die SetObject Option aktiviert???
                          • Cluni
                            @tt-tom jops
                              TT-Tom @Cluni last edited by TT-Tom
                              @cluni
                              Warum es damals für das Panel eine Extra Version gab, kann ich dir nicht hundertprozentig sagen. Aber aktuell ist es egal welche Variante du einsetzt. Ich habe auf meinen Panels auch unterschiedliche Varianten. Stell aber keine Unterschiede fest.
                              Armilar 1 Reply Last reply Reply Quote 1
                                @cluni
                                Kannst du bitte den Debug Modus vom Panel aktivieren und das Script nochmals starten und das log dann posten.
                                • Armilar
                                  @tt-tom
                                  Verzeichnisse löschen und anlegen lassen...
                                  Die tasmota32-nspanel Version wurde entwickelt, da es einen Bug gab, der das Panel in einen Boot-Loop brachte und zur Nutzung des optionale RAM. Ist aber mittlerweile in den regulären Versionen ebenfalls enthalten.
                                  • Cluni
                                    Cluni @Armilar last edited by
                                    @armilar said in SONOFF NSPanel mit Lovelace UI:
                                    Soll ich den kompletten NSPanel-Zweig im Userbereich vor dem Start des Panels löschen, oder was meinst du?
                                    • Armilar
                                      @cluni
                                      Nein, Alle Verzeichnisse (Datenpunkte) in 0_userdata.0 und alias.0, die das NSPanel automatisch angelegt hat löschen...
                                      Dann das Script neu starten und erneut anlegen lassen... Dann sollte auch alles gefüllt sein...
                                      Cluni Armilar 2 Replies Last reply Reply Quote 0
                                      • Cluni
                                        @cluni
                                        Das hat nichts geändert.
                                        Hier das LOG:
                                        16:12:46.069	info	javascript.0 (1030239) script.js.NSPanels.Panel_Flur: compiling TypeScript source...
                                        16:12:47.598	info	javascript.0 (1030239) script.js.NSPanels.Panel_Flur: source code did not change, using cached compilation result...
                                        16:12:47.937	info	javascript.0 (1030239) script.js.NSPanels.Panel_Flur: setObjects enabled - create Alias Channels possible
                                        16:12:47.968	info	javascript.0 (1030239) script.js.NSPanels.Panel_Flur: weather alias for accuweather.0. already exists
                                        16:12:48.104	warn	javascript.0 (1030239) script.js.NSPanels.Panel_Flur: error at function check_updates: Cannot read properties of null (reading 'split')
                                        16:12:48.105	info	javascript.0 (1030239) script.js.NSPanels.Panel_Flur: registered 30 subscriptions, 7 schedules, 0 messages, 0 logs and 0 file subscriptions
                                        16:12:48.843	info	javascript.0 (1030239) script.js.NSPanels.Panel_Flur: Desired TFT Firmware: 53 / v4.3.3
                                        16:12:48.844	info	javascript.0 (1030239) script.js.NSPanels.Panel_Flur: Installed TFT Firmware: 53 / v4.3.3
                                        16:12:49.139	warn	javascript.0 (1030239) script.js.NSPanels.Panel_Flur: error setState in function get_tasmota_status0Cannot read properties of undefined (reading 'Version')
                                        16:12:49.154	info	javascript.0 (1030239) script.js.NSPanels.Panel_Flur: Debug mode activated
                                        16:12:49.395	info	javascript.0 (1030239) script.js.NSPanels.Panel_Flur: get_current_tasmota_ip_address: 192.168.0.126
                                        16:12:49.814	info	javascript.0 (1030239) script.js.NSPanels.Panel_Flur: Requesting tasmota firmware version
                                        16:12:49.819	info	javascript.0 (1030239) script.js.NSPanels.Panel_Flur: Requesting current berry driver version
                                        16:12:49.820	info	javascript.0 (1030239) script.js.NSPanels.Panel_Flur: get_current_tasmota_ip_address: 192.168.0.126
                                        16:12:49.822	info	javascript.0 (1030239) script.js.NSPanels.Panel_Flur: Requesting online berry driver version
                                        16:12:49.823	info	javascript.0 (1030239) script.js.NSPanels.Panel_Flur: Requesting online TFT version
                                        16:12:49.825	info	javascript.0 (1030239) script.js.NSPanels.Panel_Flur: Requesting online firmware version
                                        16:12:50.192	info	javascript.0 (1030239) script.js.NSPanels.Panel_Flur: online display firmware version => 53
                                        16:12:50.310	info	javascript.0 (1030239) script.js.NSPanels.Panel_Flur: online TFT firmware version => 4.3.3
                                        16:12:50.334	info	javascript.0 (1030239) script.js.NSPanels.Panel_Flur: current berry driver version => undefined
                                        16:12:50.417	info	javascript.0 (1030239) script.js.NSPanels.Panel_Flur: online berry driver version => 9
                                        16:12:50.509	info	javascript.0 (1030239) script.js.NSPanels.Panel_Flur: online tasmota firmware version => 13.2.0
                                        16:12:53.489	info	javascript.0 (1030239) script.js.NSPanels.Panel_Flur: Start MQTT-Port-Check -------------------------------------
                                        16:12:53.490	info	javascript.0 (1030239) script.js.NSPanels.Panel_Flur: -- admin.0 - 8081
                                        16:12:53.490	info	javascript.0 (1030239) script.js.NSPanels.Panel_Flur: -- hm-rpc.0 - 0
                                        16:12:53.491	info	javascript.0 (1030239) script.js.NSPanels.Panel_Flur: -- hue.0 - 443
                                        16:12:53.491	info	javascript.0 (1030239) script.js.NSPanels.Panel_Flur: -- influxdb.0 - 8086
                                        16:12:53.491	info	javascript.0 (1030239) script.js.NSPanels.Panel_Flur: -- mihome-vacuum.0 - 5432
                                        16:12:53.492	info	javascript.0 (1030239) script.js.NSPanels.Panel_Flur: -- mqtt.0 - 1883
                                        16:12:53.492	info	javascript.0 (1030239) script.js.NSPanels.Panel_Flur: -- shelly.0 - 1882
                                        16:12:53.492	info	javascript.0 (1030239) script.js.NSPanels.Panel_Flur: -- telegram.0 - 8443
                                        16:12:53.493	info	javascript.0 (1030239) script.js.NSPanels.Panel_Flur: -- web.0 - 8082
                                        16:12:53.493	info	javascript.0 (1030239) script.js.NSPanels.Panel_Flur: -- zigbee.0 - /dev
                                        16:12:53.493	info	javascript.0 (1030239) script.js.NSPanels.Panel_Flur: - MQTT-Port-Check OK: Instance of Adapter: mqtt.0 is running on Port:1883
                                        16:12:53.494	info	javascript.0 (1030239) script.js.NSPanels.Panel_Flur: End MQTT-Port-Check ---------------------------------------
                                        16:12:59.307	info	javascript.0 (1030239) script.js.NSPanels.Panel_Flur: moments.js --> Datum 2023-11-27T08:10:00+01:00 valid?: true
                                        16:12:59.310	info	javascript.0 (1030239) script.js.NSPanels.Panel_Flur: HandleScreensaverUpdate payload: weatherUpdate~~~~25407~~4.5 °C~~~~65363~Sonne~08:10~~~~26095~Wind~4.7m/s~~~~34351~Böen~9.5m/s~~~~65535~Windr.~180°~
                                        16:12:59.315	info	javascript.0 (1030239) script.js.NSPanels.Panel_Flur: HandleMessage -> sleepReached
                                        16:13:00.039	info	javascript.0 (1030239) script.js.NSPanels.Panel_Flur: moments.js --> Datum 2023-11-27T08:10:00+01:00 valid?: true
                                        16:13:00.042	info	javascript.0 (1030239) script.js.NSPanels.Panel_Flur: HandleScreensaverUpdate payload: weatherUpdate~~~~25407~~4.5 °C~~~~65363~Sonne~08:10~~~~26095~Wind~4.7m/s~~~~34351~Böen~9.5m/s~~~~65535~Windr.~180°~
                                        • Cluni
                                          Liegt das am Berry driver?
                                          Den habe ich aber auch gestern noch auf den neusten Stand gebracht über den Befehl:
                                          Backlog UrlFetch https://raw.githubusercontent.com/joBr99/nspanel-lovelace-ui/main/tasmota/autoexec.be; Restart 1
                                          • Armilar
                                            Armilar Most Active Forum Testing @Armilar last edited by Armilar
                                            Update v4.3.3.14
                                            Was ist passiert?
                                            Der Sonos-Media-Player hat ne Menge Funktionalität bekommen und hat sich zu einem richtig coolen Player entwickelt...
                                            • anlegen von Playlists jetzt Möglich
                                            • automatisches Abgreifen der Tracklist
                                            • Favoritenliste wird angezeigt (und kann natürlich auch bedient werden)
                                            • Equalizer kann alternativ zur Favoritenliste genutzt werden
                                            • kleinere Fixes zu den Funktionen von gestern (Die anderen Player)
                                            Tester gesucht:
                                            Da ich leider nur eine der ersten Sonos One habe, ist ein umfänglicher Sonos Test natürlich nicht einfach. Daher würde ich die Sonos-User unter euch kurz um ein Feedback bitten...
                                            Was ist neu an der Seitenvariable?
                                            Player mit Favoriten:
                                            let Sonos = <PageMedia>
                                                'type': 'cardMedia',
                                                'heading': 'Sonos',
                                                'useColor': true,
                                                'items': [<PageItem>{
                                                            id: AliasPath + 'Media.PlayerSonos',
                                                            adapterPlayerInstance: 'sonos.0.',
                                                            mediaDevice: '192_168_1_212',
                                                            speakerList: ['Terrasse'],
                                                            playList: ['Hartmann','Armilars Playlist'],
                                                            colorMediaIcon: colorSonos,
                                                            colorMediaArtist: Yellow,
                                                            colorMediaTitle: Yellow,
                                                            alwaysOnDisplay: true,
                                                            autoCreateALias: true
                                            Player mit Equalizer:
                                                'heading': 'Sonos',
                                                'useColor': true,
                                                            equalizerList: ['Bassboost','Klassik','Dance', 'Deep', 'Electronic', 'Flat', 'Hip-Hop', 'Rock',
        'Metal', 'Jazz', 'Latin', 'Tonstärke', 'Lounge', 'Piano'],
                                            wie gestern im Update schon verfügbar, gibt es die Funktion alwaysOnDisplay: true,. Damit bekommt der Player noch einmal einen richtigen Schub...
                                            Da es kein verfügbares Sonos-Logo gibt, habe ich mal einen Kreis mit einem "S" verwendet und die aktuellen Sonosfarben benutzt.
                                            const colorSonos:       RGB = { red: 216, green: 161, blue:  88 };
                                            einfach irgendwo zwischen den Konstanten einfügen, falls ihr die Farbe nutzen möchtet:
                                            So und das wars auch schon wieder...
                                            Viel Spaß beim ausprobieren.
                                            LG
                                            @TT-Tom & Armilar 😊
                                            P.S: Den Rest der Woche habt ihr jetzt "Release-Ruhe" von meiner Seite 😉
                                            EDIT: Das NSPanelTs.ts bekommt ihr natürlich wie immer hier:
                                            https://github.com/joBr99/nspanel-lovelace-ui/blob/main/ioBroker/NsPanelTs.ts
                                            Es reicht, den unteren Teil ab:
                                            zu tauschen.
                                            D 1 Reply Last reply Reply Quote 3
                                            lovelace ui nspanel sonoff
                                            270
                                            7630
                                            6221832
