    4. Backup Größe ioBroker
      Homoran Global Moderator Administrators @IceD112 last edited by
      @iced112 wie wär's mit zeigen?
      • I
        IceD112 @Homoran last edited by
        @homoran said in Backup Größe ioBroker:
        Als Beispiel der Heos Adapter, dort steht eine installierte Instanz
        Taucht aber hier nicht auf
        Skript v.2023-10-10
        *** BASE SYSTEM ***
           Static hostname: ioBroker
                 Icon name: computer
          Operating System: Debian GNU/Linux 11 (bullseye)
                    Kernel: Linux 6.1.21-v8+
              Architecture: arm64
        Model           : Raspberry Pi 4 Model B Rev 1.5
        Docker          : false
        Virtualization  : none
        Kernel          : aarch64
        Userland        : arm64
        Systemuptime and Load:
         14:37:36 up 17:06,  3 users,  load average: 0.27, 0.51, 0.44
        CPU threads: 4
        *** RASPBERRY THROTTLING ***
        Current issues:
        Previously detected issues:
        *** Time and Time Zones ***
                       Local time: Mon 2023-11-27 14:37:36 CET
                   Universal time: Mon 2023-11-27 13:37:36 UTC
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        *** User and Groups ***
        pi
        /home/pi
        pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
        *** X-Server-Setup ***
        X-Server:       true
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Mem:            7.8G        1.5G        3.6G         35M        2.7G        6.2G
        Swap:            99M          0B         99M
        Total:          7.9G        1.5G        3.7G
                 7812 M total memory
                 1457 M used memory
                 1643 M active memory
                 2166 M inactive memory
                 3630 M free memory
                  119 M buffer memory
                 2604 M swap cache
                   99 M total swap
                    0 M used swap
                   99 M free swap
        Raspberry only:
        oom events: 0
        *** FAILED SERVICES ***
        0 loaded units listed.
        *** FILESYSTEM ***
        /dev/root      ext4       59G  6.1G   50G  11% /
        devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
        tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
        tmpfs          tmpfs     1.6G  1.2M  1.6G   1% /run
        /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
        tmpfs          tmpfs     782M   20K  782M   1% /run/user/1000
        [Sun Nov 26 21:30:53 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:46:90:AF vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=49bd46ba-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
        [Sun Nov 26 21:30:54 2023] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
        [Sun Nov 26 21:30:54 2023] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
        [Sun Nov 26 21:30:55 2023] EXT4-fs (mmcblk0p2): recovery complete
        [Sun Nov 26 21:30:55 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
        [Sun Nov 26 21:30:55 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
        [Sun Nov 26 21:30:57 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
        TARGET  SOURCE         FSTYPE OPTIONS
        /       /dev/mmcblk0p2 ext4   rw,noatime,commit=600
        `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
        /var:
        576M    /var/
        177M    /var/lib
        167M    /var/cache
        155M    /var/cache/apt
        132M    /var/log
        Archived and active journals take up 128.0M in the file system.
        /opt/iobroker/backups:
        146M    /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        522M    /opt/iobroker/iobroker-data/
        295M    /opt/iobroker/iobroker-data/files
        89M     /opt/iobroker/iobroker-data/backup-objects
        74M     /opt/iobroker/iobroker-data/files/vis.0
        67M     /opt/iobroker/iobroker-data/files/javascript.admin
        81M     /opt/iobroker/iobroker-data/states.jsonl
        59M     /opt/iobroker/iobroker-data/objects.jsonl
        21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
        8.9M    /opt/iobroker/iobroker-data/files/scenes.admin/static/js/2.7de3299d.chunk.js.map
        8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js
        USB-Devices by-id:
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v18.18.2
        /usr/bin/node           v18.18.2
        /usr/bin/npm            9.8.1
        /usr/bin/npx            9.8.1
        /usr/bin/corepack       0.19.0
        nodejs:
          Installed: 18.18.2-1nodesource1
          Candidate: 18.18.2-1nodesource1
          Version table:
         *** 18.18.2-1nodesource1 500
                100 /var/lib/dpkg/status
             18.18.1-1nodesource1 500
             18.18.0-1nodesource1 500
             18.17.1-1nodesource1 500
             18.17.0-1nodesource1 500
             18.16.1-1nodesource1 500
             18.16.0-1nodesource1 500
             18.15.0-1nodesource1 500
             18.14.2-1nodesource1 500
             18.14.1-1nodesource1 500
             18.14.0-1nodesource1 500
             18.13.0-1nodesource1 500
             18.12.0-1nodesource1 500
             18.11.0-1nodesource1 500
             18.10.0-1nodesource1 500
             18.9.1-1nodesource1 500
             18.9.0-1nodesource1 500
             18.8.0-1nodesource1 500
             18.7.0-1nodesource1 500
             18.6.0-1nodesource1 500
             18.5.0-1nodesource1 500
             18.4.0-1nodesource1 500
             18.3.0-1nodesource1 500
             18.2.0-1nodesource1 500
             18.1.0-1nodesource1 500
             18.0.0-1nodesource1 500
             12.22.12~dfsg-1~deb11u4 500
                500 http://deb.debian.org/debian bullseye/main arm64 Packages
                500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
        No problems detected
        Errors in npm tree:
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Core adapters versions
        js-controller:  5.0.16
        admin:          6.12.4
        javascript:     7.1.6
        Adapters from github:   1
        Adapter State
        + system.adapter.accuweather.0            : accuweather           : ioBroker                                 -  enabled
        + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.alexa2.0                 : alexa2                : ioBroker                                 -  enabled
        + system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
        + system.adapter.bring.0                  : bring                 : ioBroker                                 -  enabled
          system.adapter.daswetter.0              : daswetter             : ioBroker                                 -  enabled
        + system.adapter.denon.0                  : denon                 : ioBroker                                 -  enabled
          system.adapter.dwd.0                    : dwd                   : ioBroker                                 -  enabled
        + system.adapter.energiefluss.1           : energiefluss          : ioBroker                                 -  enabled
        + system.adapter.fb-checkpresence.0       : fb-checkpresence      : ioBroker                                 -  enabled
          system.adapter.followthesun.0           : followthesun          : ioBroker                                 - disabled
          system.adapter.fronius-solarweb.0       : fronius-solarweb      : ioBroker                                 - disabled
        + system.adapter.fronius-solarweb.1       : fronius-solarweb      : ioBroker                                 -  enabled
          system.adapter.ham.0                    : ham                   : ioBroker                                 - disabled
          system.adapter.harmony.0                : harmony               : ioBroker                                 - disabled
          system.adapter.heos.0                   : heos                  : ioBroker                                 - disabled
          system.adapter.hue-extended.0           : hue-extended          : ioBroker                                 - disabled
          system.adapter.hue.0                    : hue                   : ioBroker                                 - disabled, port: 443
          system.adapter.ical.0                   : ical                  : ioBroker                                 - disabled
          system.adapter.icons-icons8.0           : icons-icons8          : ioBroker                                 - disabled
          system.adapter.icons-material-png.0     : icons-material-png    : ioBroker                                 - disabled
          system.adapter.icons-mfd-png.0          : icons-mfd-png         : ioBroker                                 - disabled
          system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : ioBroker                                 - disabled
          system.adapter.javascript.0             : javascript            : ioBroker                                 - disabled
          system.adapter.lgtv11.0                 : lgtv11                : ioBroker                                 - disabled, port: 8080
          system.adapter.meross.0                 : meross                : ioBroker                                 - disabled
          system.adapter.panasonic-viera.0        : panasonic-viera       : ioBroker                                 - disabled
          system.adapter.ping.0                   : ping                  : ioBroker                                 - disabled
          system.adapter.scenes.0                 : scenes                : ioBroker                                 - disabled
          system.adapter.shelly.0                 : shelly                : ioBroker                                 - disabled, port: 1882, bind: 0.0.0.0
          system.adapter.spotify-premium.0        : spotify-premium       : ioBroker                                 - disabled
          system.adapter.telegram.0               : telegram              : ioBroker                                 - disabled, port: 8443, bind: 0.0.0.0
          system.adapter.tr-064.0                 : tr-064                : ioBroker                                 - disabled
          system.adapter.trashschedule.0          : trashschedule         : ioBroker                                 - disabled
          system.adapter.vis-colorpicker.0        : vis-colorpicker       : ioBroker                                 - disabled
          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBroker                                 - disabled
          system.adapter.vis-icontwo.0            : vis-icontwo           : ioBroker                                 - disabled
          system.adapter.vis-inventwo.0           : vis-inventwo          : ioBroker                                 - disabled
          system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBroker                                 - disabled
          system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBroker                                 - disabled
          system.adapter.vis.0                    : vis                   : ioBroker                                 - disabled
          system.adapter.web.0                    : web                   : ioBroker                                 - disabled, port: 8082, bind: 0.0.0.0, run as: admin
          system.adapter.yr.0                     : yr                    : ioBroker                                 - disabled
        + instance is alive
        ioBroker-Repositories
        Active repo(s): beta
        Installed ioBroker-Instances
        Used repository: beta
        Adapter    "accuweather"  : 1.3.1    , installed 1.3.1
        Adapter    "admin"        : 6.12.5   , installed 6.12.4 [Updatable]
        Adapter    "alexa2"       : 3.26.3   , installed 3.26.1 [Updatable]
        Adapter    "backitup"     : 2.9.4    , installed 2.9.4
        Adapter    "bring"        : 1.8.4    , installed 1.8.4
        Adapter    "daswetter"    : 3.1.11   , installed 3.1.11
        Adapter    "denon"        : 1.15.4   , installed 1.15.4
        Adapter    "energiefluss" : 3.6.0    , installed 3.6.0
        Adapter    "fb-checkpresence": 1.2.2 , installed 1.2.2
        Adapter    "followthesun" : 0.4.2    , installed 0.4.2
        Adapter    "fronius-solarweb": 0.0.3 , installed 0.0.3
        Adapter    "ham"          : 5.3.1    , installed 5.3.1
        Adapter    "harmony"      : 1.3.0    , installed 1.3.0
        Adapter    "heos"         : 2.1.0    , installed 2.1.0
        Adapter    "hue"          : 3.10.1   , installed 3.10.1
        Adapter    "hue-extended" : 2.0.0    , installed 2.0.0
        Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
        Adapter    "javascript"   : 7.1.6    , installed 7.1.6
        Controller "js-controller": 5.0.16   , installed 5.0.16
        Adapter    "lgtv11"       : 1.0.5    , installed 1.0.5
        Adapter    "meross"       : 1.16.1   , installed 1.15.1 [Updatable]
        Adapter    "panasonic-viera": 2.0.0  , installed 2.0.0
        Adapter    "shelly"       : 6.6.1    , installed 6.6.1
        Adapter    "spotify-premium": 1.3.1  , installed 1.3.1
        Adapter    "telegram"     : 3.0.0    , installed 3.0.0
        Adapter    "trashschedule": 2.3.0    , installed 2.3.0
        Adapter    "vis"          : 1.5.1    , installed 1.5.1
        Adapter    "vis-icontwo"  : 0.98.0   , installed 0.97.3 [Updatable]
        Adapter    "web"          : 6.1.10   , installed 6.1.10
        Adapter    "ws"           : 2.5.8    , installed 2.5.8
        Adapter    "yr"           : 5.3.0    , installed 5.3.0
        Objects and States
        Objects:        39455
        States:         32474
        Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
        Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
        Hit:3 http://deb.debian.org/debian bullseye InRelease
        Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
        Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
        Reading package lists...
        Pending Updates: 1
        *** Listening Ports ***
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          11072      554/sshd: /usr/sbin
        tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          29990      6904/cupsd
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       18178      2241/iobroker.js-co
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       18185      2241/iobroker.js-co
        tcp6       0      0 :::22                   :::*                    LISTEN      0          11074      554/sshd: /usr/sbin
        tcp6       0      0 ::1:631                 :::*                    LISTEN      0          29989      6904/cupsd
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       27543      6030/io.admin.0
        udp        0      0 0.0.0.0:36350           0.0.0.0:*                           108        13741      396/avahi-daemon: r
        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12872      469/dhcpcd
        udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          30793      6909/cups-browsed
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13739      396/avahi-daemon: r
        udp6       0      0 :::33105                :::*                                108        13742      396/avahi-daemon: r
        udp6       0      0 :::546                  :::*                                0          16441      469/dhcpcd
        udp6       0      0 :::5353                 :::*                                108        13740      396/avahi-daemon: r
        2023-11-27 14:29:38.109  - info: admin.0 (6030) Unsubscribe from all states, except system's, because over 3 seconds the number of events is over 200 (in last second 0)
        2023-11-27 14:30:00.144  - info: host.ioBroker instance system.adapter.dwd.0 started with pid 16169
        2023-11-27 14:30:03.091  - info: dwd.0 (16169) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.18.2, js-controller: 5.0.16
        2023-11-27 14:30:04.210  - info: host.ioBroker instance system.adapter.daswetter.0 started with pid 16184
        2023-11-27 14:30:07.157  - info: daswetter.0 (16184) starting. Version 3.1.11 in /opt/iobroker/node_modules/iobroker.daswetter, node: v18.18.2, js-controller: 5.0.16
        2023-11-27 14:30:08.590  - info: dwd.0 (16169) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2023-11-27 14:30:09.142  - info: host.ioBroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2023-11-27 14:30:22.962  - info: daswetter.0 (16184) still wrong data structure from server received! repaired...
        2023-11-27 14:30:27.521  - info: daswetter.0 (16184) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
        2023-11-27 14:30:28.037  - info: daswetter.0 (16184) cleaned everything up...
        2023-11-27 14:30:28.060  - info: host.ioBroker instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2023-11-27 14:30:39.032  - info: admin.0 (6030) Subscribe to all states again
        2023-11-27 14:31:39.156  - info: admin.0 (6030) Unsubscribe from all states, except system's, because over 3 seconds the number of events is over 200 (in last second 0)
        2023-11-27 14:32:39.250  - info: admin.0 (6030) Subscribe to all states again
        2023-11-27 14:33:38.387  - info: admin.0 (6030) Unsubscribe from all states, except system's, because over 3 seconds the number of events is over 200 (in last second 0)
        2023-11-27 14:34:39.314  - info: admin.0 (6030) Subscribe to all states again
        2023-11-27 14:35:00.076  - info: host.ioBroker instance system.adapter.dwd.0 started with pid 16204
        2023-11-27 14:35:03.289  - info: dwd.0 (16204) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.18.2, js-controller: 5.0.16
        2023-11-27 14:35:07.239  - info: dwd.0 (16204) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2023-11-27 14:35:07.775  - info: host.ioBroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2023-11-27 14:35:38.438  - info: admin.0 (6030) Unsubscribe from all states, except system's, because over 3 seconds the number of events is over 200 (in last second 0)
        2023-11-27 14:36:39.358  - info: admin.0 (6030) Subscribe to all states again
        2023-11-27 14:37:38.485  - info: admin.0 (6030) Unsubscribe from all states, except system's, because over 3 seconds the number of events is over 200 (in last second 0)
        2023-11-27 14:38:39.454  - info: admin.0 (6030) Subscribe to all states again
        2023-11-27 14:38:42.576  - info: admin.0 (6030) Unsubscribe from all states, except system's, because over 3 seconds the number of events is over 200 (in last second 0)
          Thomas Braun Most Active @IceD112 last edited by
          @iced112 sagte in Backup Größe ioBroker:
          X-Server: true
          Ausschalten...
          sudo systemctl default-set multi-user.target
          Wassen da passiert?
          IMMER die Kiste ordentlich herunterfahren. Stromentzug ist kein ordentliches Herunterfahren...
          • I
            IceD112 last edited by IceD112
            Reicht es nicht mit
            iob stop
            und dann ausschalten?
            @thomas-braun said in Backup Größe ioBroker:
            X-Server: true
            Ausschalten...
            ist das der Befehl für den pi runter zu fahren?
            Codierknecht Thomas Braun 2 Replies Last reply Reply Quote 0
            • Codierknecht
              Codierknecht Developer Most Active @IceD112 last edited by
              Nein - damit wird der Desktop abgeschaltet.
              Runterfahren mit
              sudo shutdown -h 0
                Nein, die Kiste muss komplett heruntergefahren werden.
                Du schredderst sonst das Dateisystem. (Siehe oben...)
                sudo poweroff
                und dann auch gerne eine Weile warten, das dauert bis zu einer Minute.
                • I
                  IceD112 @Thomas Braun last edited by
                  ok, das wusste ich tatsächlich alles nicht
                  Also wenn ich den pi vom Strom trennen möchte oder muss, dann
                  iob stop
                  sudo shutdown -h 0
                  sudo poweroff
                  oder ist das zuviel des Guten?
                    zuviel des Guten
                    die 2. Zeile nur jetzt einmalig
                    und die 3. oder 4.
                      Das ist nur einmal für das geänderte Boot Target zumachen.
                      Und
                      sudo shutdown -h 0
                      sudo poweroff
                      ist synonym. Du kannst also einen der beiden Befehle verwenden.
                      • I
                        pi@ioBroker:~ $ sudo systemctl default-set multi-user.target
                        Unknown command verb default-set.
                        pi@ioBroker:~ $
                        • I
                          ok, danke
                            Wenn man aus der Erinnerung schreibt...
                            Das muss natürlich
                            sudo systemctl set-default multi-user.target
                            lauten.
                            • I
                              pi@ioBroker:~ $ sudo systemctl set-default multi-user.target
                              Removed /etc/systemd/system/default.target.
                              Created symlink /etc/systemd/system/default.target → /lib/systemd/system/multi-user.target.
                                @iced112
                                Ja, das ist so richtig.
                                • I
                                  Muss ich die Instanzen, die aktuell nicht angezeigt werden, denn evtl mit
                                  iobroker restart adapterName.instance
                                  starten.
                                  Also alle die laut diag auf disabled stehen?
                                  Thomas Braun I 2 Replies Last reply Reply Quote 0
                                    @iced112
                                    Kannst du machen.
                                    • I
                                      IceD112 @IceD112 last edited by
                                      @iced112 said in Backup Größe ioBroker:
                                      starten.
                                      ok, da sind zwei Instanzen schonmal 🙂 vis.0 und fronius-solarweb.0, aber ich komme bei beiden nicht drauf. Seiten-Ladefehler
                                      einen Sammelbefehl für alle zu starten gibts nicht? oder?
                                        oder!
                                        iob start all
                                        wie versuchst du es?
                                        • I
                                          IceD112 @Homoran last edited by IceD112
                                          Ich visualisiere u.a. meine PV-Analge über den Energiefluss Adapter, die Daten kommen aus dem Fronius-Solarweb Adapter.
                                          links im Menü konnte ich unten auf die Energiefluss instanz mir die Visualisierung anzeigen. Da kommt der Seiten-Ladefehler
                                          bei der VIS gehe ich wie gewohnt auf die VIS in der Übersicht, auch da, das selbe. Bei den Instanzen fehlt mir bei der VIS auch der Schraubenschlüssel, um in die Einstellungen da zu kommen
                                          mit
                                          iob start all
                                          sind die Instanzen nun alle enabled... 👍 und sichtbar
                                          EDIT: Die Visualisierung des Energifluss Adapters ist nun sichtbar, die VIS selber ebenfalls
                                          • I
                                            Ich glaube die Wiederherstellung hat nun funktioniert. Adapter, Instanzen und Objekte sind wieder da. Werte lassen sich setzen und Automationen und Routinen über Skripte funktionieren auch, ebenso wie die einzelnen VIS Projekte.
                                            Glücklich bis hier her 😊
                                            Nu, aber vielleicht nochmal gerade zurück zum Backup
                                            Der Adapter ist eingestellt, dass zur FritzBox sichern soll. EIne gerade ausgeführtes Backup wurde aber nach /opt/iobroker/backups gesichert?
                                            7443
