    4. Frigate Adapter für ioBroker
      crunchip Forum Testing Most Active last edited by crunchip
      @wal bin jetzt auch endlich mal dazu gekommen, erste Meldung beim anlegen
      frigate.0
      2023-11-25 23:31:01.265	info	State value to set for "frigate.0.Buero.cat.snapshot" has to be type "boolean" but received type "string"
      frigate.0
      2023-11-25 23:31:01.221	info	State value to set for "frigate.0.Buero.person.snapshot" has to be type "boolean" but received type "string"
      frigate.0
      2023-11-25 23:31:00.602	info	State value to set for "frigate.0.Haustuer.person.snapshot" has to be type "boolean" but received type "string"
      frigate.0
      2023-11-25 23:31:00.471	warn	This object will not be created in future versions. Please report this to the developer.
      frigate.0
      2023-11-25 23:31:00.458	warn	Object frigate.0.Buero.cat.snapshot is invalid: Default value has to be type "boolean" but received type "string"
      frigate.0
      2023-11-25 23:31:00.456	warn	This object will not be created in future versions. Please report this to the developer.
      frigate.0
      2023-11-25 23:31:00.454	warn	Object frigate.0.Buero.person.snapshot is invalid: Default value has to be type "boolean" but received type "string"
      frigate.0
      2023-11-25 23:31:00.164	warn	This object will not be created in future versions. Please report this to the developer.
      frigate.0
      2023-11-25 23:31:00.158	warn	Object frigate.0.Haustuer.person.snapshot is invalid: Default value has to be type "boolean" but received type "string"
      • Wal
        Wal Developer @crunchip last edited by
        @crunchip ,
        die Meldung hatte ich noch nicht, muss mal mit deinen Kameranamen durchtesten.
          @wal das kommt für alle Cams die ich angelegt hab und halt bei jedem Ereignis im log
          EDIT:
          hab jetzt nochmal alle Datenpunkte gelöscht und neu anlegen lassen
          frigate.0
          2023-11-26 09:54:39.893	info	MQTT Frigate URL: http://localhost:5000
          frigate.0
          2023-11-26 09:54:39.891	info	MQTT Frigate Object: mqtt.0.frigate
          frigate.0
          2023-11-26 09:54:39.846	info	starting. Version 0.2.6 in /opt/iobroker/node_modules/iobroker.frigate, node: v18.18.2, js-controller: 5.0.16
          frigate.0
          2023-11-26 09:54:32.649	info	terminating
          frigate.0
          2023-11-26 09:54:32.146	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          frigate.0
          2023-11-26 09:54:32.144	info	terminating
          frigate.0
          2023-11-26 09:54:32.142	info	Got terminate signal TERMINATE_YOURSELF
          frigate.0
          2023-11-26 09:54:15.600	warn	State "frigate.0.uptime" has no existing object, this might lead to an error in future versions
          frigate.0
          2023-11-26 09:54:15.599	warn	State "frigate.0.latest_version" has no existing object, this might lead to an error in future versions
          frigate.0
          2023-11-26 09:54:15.597	warn	State "frigate.0.version" has no existing object, this might lead to an error in future versions
          frigate.0
          2023-11-26 09:54:15.556	warn	State "frigate.0.available" has no existing object, this might lead to an error in future versions
          sobald ich nen toggle Button in der Gui drücke
          frigate.0
          2023-11-26 09:56:17.120	info	State value to set for "frigate.0.Buero.person.snapshot" has to be type "boolean" but received type "string"
          frigate.0
          2023-11-26 09:56:06.850	info	State value to set for "frigate.0.Buero.person.snapshot" has to be type "boolean" but received type "string"
          Bewegung erkannt
          frigate.0
          2023-11-26 09:59:41.993	info	State value to set for "frigate.0.Terrasse.person.snapshot" has to be type "boolean" but received type "string"
          frigate.0
          2023-11-26 09:59:29.054	info	State value to set for "frigate.0.Terrasse.person.snapshot" has to be type "boolean" but received type "string"
          frigate.0
          2023-11-26 09:59:28.937	warn	This object will not be created in future versions. Please report this to the developer.
          frigate.0
          2023-11-26 09:59:28.930	warn	Object frigate.0.Terrasse.person.snapshot is invalid: Default value has to be type "boolean" but received type "string"
          docker auf unraid
          System 0.12.1-367d724
          Beispieldatenpunkt
            "type": "state",
            "common": {
              "name": "Terrasse.person.snapshot",
              "type": "boolean",
              "role": "value",
              "read": true,
              "write": false,
              "def": "����\u0000\u0010JFIF\u0000\u0001\u0001\u0000\u0000\u0001\u0000\u0001\u0000\u0000��\u0000C\u0000\n\u0007\u0007\b\u0007\u0006\n\b\b\b\u000b\n\n\u000b\u000e\u0018\u0010\u000e\r\r\u000e\u001d\u0015\u0016\u0011\u0018#\u001f%$\"\u001f\"!&+7/&)4)!\"0A149;>>>%.DIC<H7=>;��\u0000C\u0001\n\u000b\u000b\u000e\r\u000e\u001c\u0010\u0010\u001c;(\"(;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;��\u0000\u0011\b\u0001\u000e\u0001\u000e\u0003\u0001\"\u0000\u0002\u0011\u0001\u0003\u0011\u0001��\u0000\u001f\u0000\u0000\u0001\u0005\u0001\u0001\u0001\u0001\u0001\u0001\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0001\u0002\u0003\u0004\u0005\u0006\u0007\b\t\n\u000b��\u0000�\u0010\u0000\u0002\u0001\u0003\u0003\u0002\u0004\u0003\u0005\u0005\u0004\u0004\u0000\u0000\u0001}\u0001\u0002\u0003\u0000\u0004\u0011\u0005\u0012!1A\u0006\u0013Qa\u0007\"q\u00142���\b#B��\u0015R��$3br�\t\n\u0016\u0017\u0018\u0019\u001a%&'()*456789:CDEFGHIJSTUVWXYZcdefghijstuvwxyz���������������������������������������������������������������������������\u0000\u001f\u0001\u0000\u0003\u0001\u0001\u0001\u0001\u0001\u0001\u0001\u0001\u0001\u0000\u0000\u0000\u0000\u0000\u0000\u0001\u0002\u0003\u0004\u0005\u0006\u0007\b\t\n\u000b��\u0000�\u0011\u0000\u0002\u0001\u0002\u0004\u0004\u0003\u0004\u0007\u0005\u0004\u0004\u0000\u0001\u0002w\u0000\u0001\u0002\u0003\u0011\u0004\u0005!1\u0006\u0012AQ\u0007aq\u0013\"2�\b\u0014B����\t#3R�\u0015br�\n\u0016$4�%�\u0017\u0018\u0019\u001a&'()*56789:CDEFGHIJSTUVWXYZcdefghijstuvwxyz��������������������������������������������������������������������������\u0000\f\u0003\u0001\u0000\u0002\u0011\u0003\u0011\u0000?\u0000��~\b��<\u001f�k+����\u0016�4pB�6�.�7��'n9\u0000}�g�\u001b�\u0007��?��nmH\u0018��!.� \u0003DÑ�\\�����}VAg���\u000fsj�SE\u0018\u0001r\u0019pO��\b�\u0007�:�\u001b�=\u0002�V��Y�\u0017\u0010��\u0002d);�\u001f��~��8��7Qe_\rxA%�\u0002}�y�i|�I}�h�\u0012\u0001�=2\u000f\u0019��-�={z\\Ÿ�&ح�\f����\u0003�s�\fv�i���|?�y&Ho�\u0017{\u0006L�S؀28��8�4]SE��2�8\u0013����Ǡ\u0018\u001c\u000f��J)-\u0019roW\u0011��r�\\ܳ��\u0011��\u0012\u0010�\u0016�T�O\u001f���޲5-4C��.��f}�C���� s�9\u0003�¶\"�t�n���h����:\u0002�X�#�{zz�3\\�@�.��qH�\u0016��|�'���H�\\\u0003�Uh�Ni�f\\�xn��Z\\�\u0004�|A�hՖK�a�#�c�q�\u0000�rm\u0007E����1�{8���\u0012X�h�\u0019m����:�汴'�,u)/�\u0011*��ub\f�\\�I\u0003'=�ӯ|V�ھ�\r��s�]�\u0016�\u0016\u001eFS�F\b��0}:��&��)��I\nJ[+����ht�Zp��F�leB��H\u0002���?3.�\u0001�P��@�R:=����&�%Ů�\u001e�d��J���l��6\u0018n\u0018,1�⬦���-���\u001a�����\u0019�I2x|��g<|��\u0014�����\u0013q{uq=�A�\u0019D� T ��v�'9�I�\u0003��գg�\u0015��3nKr����;G�Z���;i\u0013-���A�����z\u000fư�5\u0013�jz��`�;\r2�<�v�|�\u00030V�$\u0012\u0014(�X}\t�\u001f\u001a�gI��t�SQ��Ϟn�;�\u001d�R[i=s�\u0018\u0003���\u0000]�՟P�f���\u0003!i�\u0011m���pN�s�Ȭ�\u0004��m=4���N�t�\u001bO��\\IdK\u0001nn�,{[f7�\u0003�\u000e��z���:ė�m��\u0005���L��d��|�Z�\u0019^[�\f�OS[-�iv�Z���v�D|���q�;1�\u001d����O\u0003L7�/�V\u0019�'�\ft�?ȭ��JK�����ciւo\tZ^�sj7���&R_/{8\u0007#'\u0000\f���#�\u001f�$rǢO5����\u0012\\%�p;A\u000e�\u0000Rz\u001e��O?wr�݊;H\u001a7X�'D�\u0015\u0007\u0018�Fq�<Ԃ�\u0014@]���Q�Ϧj�\u001a\u000e����5\u00179�c�\u0015���΂�,�(\u000eIc��\u001c���z\u001c\n��>�q�\[yУ�U\u0000�\u000f�3��\u0006=�T\u001fn�^���i�Į� �Un��ϧ�5cR�\u0016���w<�ȱ�V\t\u001eDa�\u0005�\u0019���2qڶ�\u001eX���}�\u0017��\u0012�t�!o�-���;�\u0002�,��`A;��9?�\u0011ž3���:����b>[H�_�\u0011�W��ʺ\u001doľ\u001f\u001e\u001a�F��u-T�J\u001d��,�\u0000T�.\u0017���=I���+XbҦ���\n]K�\u0019@\u0007\t�\u0018�iΧ.�p�5.�����U\u000b@Y���\u001a��ʼn���N��Q�5��\ry4�\"�n%�Ϸ֧ڮ��\u000b\r�&�Q6��$�j\b�3�?�j�7Iu�j\u001a�?�yX��\u0000�i��\u0007�Tm|A� �q4�,1��\r��|�^y#5=���X��I..�aR1�z�L��Wg�\r�����>\u001f�Y8wF��>��c���(��5\u001d~w�M�� bx\u0004���&�C�\u0017���\u0012}�)\u001b\r��\u0019 \u0001�3�+�!���\u0002���]�\u0012ѧ�\u0015Z��vq\u000e:�$O\u0016w\u000e7�dr\tS�P��Zq�i�\u0016\u00172��q�p$�*�^YT�<\u001eG�T\b\u001bN)BJw�@j�I��?�7\u001ek\u000f��\u0019�\u0000r?��\u0000��Evw\u0000���K�\n��\u001d;�\u001akn\u001f4q�_�#��@�+CP�lle�|m���9�V�DZ�G�<\u001e&���\re�\u0011�\u0000a�r���\u001aކC\u0013\b��F�6�\u0000��W\u0013j$�\u0003,�2H6�n��-�WE�HR�\u001b9�>r#$��\u0002��L���޹�ڣ\u0004�j���\u001c�)���o�\u000f�@�9\u0018��\"Y�e��YZ!E����fF\u0019bG���\u0003\u0003�\u0018�e�\u001an\u000b`�\u001d9隧\f7v���\t�0�\u0006!���\u0007����:\\F<̓ d\u000f��{W\r�QG�x��\u001d�C��rFx\u0003\u0003��D\u0011��`\u001c\u0014t�s���\u001e��-\u0019!O\u0004t�OC RǑ�i�\u000e\u0016\u001d��H�\u0000إ��2Gҝ����\r�\"^wGʂq�\u0007�?*f�d;��r����'���R�v�\u000b8i\u0015\u000e\u0002�j�\u0011f�\u0003����܂\t*\u000e��w$�\"�Ĵ8\u0003��8\u0019�4��Ǔ\u001c��~��#ךu���\b`\u0016L��0s�23�VR�*���2�R�/�8\t\u0005O��0�\u0007�ɫZ\u0015��YEb�\u0011��c`N\u0006�=i��\u001a�K�y%�8�y�W;s�=*Ƌ��m�2�\f[�\u0007\u001cWd\u001e�%]\f˯����u\t\u0014��\t\"�\u0000z\u0002+���KїO2���d�s*�l�^����\u0005�Sۨ�m�p�\u000b9�^�~[׎ͥ#l��,j?�#���jg���U���k�̗~$���ʳ�\u0002��\u000e\u0000\b>�~'�\u0002�\u0017H�u\b��\u0007)\u001d�|��\f!\\^�\u0006��}��Ŕo(���B[\u0018\u001f�+��֟����;3��\u0015\r���h�F7��������V(e��j�<օ��k��\u0018�\u0017��!����oOƴn�\"�ʶ\n�9u9W���a\u0007�W����\u0017��]Z�\f�Uͤ�Е\u0004:Ԑ(h����{z\u0005Q��/�\u001a�jz��\u0004�I�cw\b�S��8��;ir�vq8x\u0003� >d$���q^��؍?I���0�\u0003�\u0000�yoԚ��Qs��Xv�\"�\u0017R}\u0017%�\u0000U�k�rO��ɦ���\u001dvk[\u0018���C��\u00125��\u0015�z��u�ə��k�b^\u0015\u000f_z�|k1:}�Y��b}�\u001f�z�\u001e\u0006�CCv*1��I\u001f5\u0010��\u0017\u000f\u001c���*U� �Ӧ]���U)\u000b9��ph��<G�k\u0016����\n���Y%6�g\f���W�����\\�\u000e��e\\�E;܆_Ҳ4�\\�?���\u0000F�;E��5kh\u0018�,7�/����X�h҇�J�a�\u0000N��\u0000�R��\u001f�F��[�\u001f+��?�\u001f;��\u000fƱ������\u001e�en�i�D�����?�c���X>6�n�\r��og\u0001��|���~5�ɖvj�Or'�\u001c�O[q��~g?�\u001f�tEY\\L�l��8\\�l��\b*���w.j�梯\u0010\u0005\u0015s�p���M���Wr�\u000eT��\u001d+\u0019����\u0019��G��Dx?�օ��H\u0001 �H �=띵{�ظ\u0000m\u001b�?��Z�3���f+�|��8>�ވK�ڹllc��>�UQm4W�U�[��\u001f����N�n k�4��_�9�\u001b�\u0003����ݬ�\u0010��2A��W5�M��\u000bՈ�\u0004q��Q�\u0004��;�Rgf\u001eh;:\u001f,��\u0000\u001a��`�La��қ+C\n�ɏ|��z�\u001cP��-\u0010\"�2<�t�|c�К\u001eK�v���Y��\u0000�\u0001��q\u0015�?�9\u0012��\u0004�w�L\u001ad�*a��J�y\r���SBܹ/�r78I\u0003��G\u001e���L�^H��F\u0019Q6�I\u001f��\u0000�\u001d=jx\"��\u001aE�60����u�\u000b4�v��E?7c��\u0000Uf��\u0017��\u0005f̫k�c���a\u0013q,j�Y\u0001� ��ҡ�t��\u0001�ۦ�I�\u0000Md�\u0017)1Y\u0017�\u001fÎ+v��(o��W1���\u0019�B�\u0018����\"�T�aR\u0017:\u000b\u000bO݋W™@����A�\u0015N�v��y�U<\"�\u0000uGAT��\u0010�h�t\u0006H#�R�I�h��E\u0017�\u001d�~F�_��J����\u0016=J0aN�vs�N�G@a]V���fD�hX�\u0000��3!^�Ne\u0000W\u0017��\u0012�Sk�bc��(�1�|\u0013�\u0000����e\u0013\r�3\u001c\u0005\u001c�ݳ\u000bt2��E-D�~i\u0006\u0015Tu$���[Cj�\u001f��������R@�5F��A��� ��\n�\u001f���ܖ42����m��|?p\u000e�hŴ_�?_��W��j�i�������#p;�\r�~���F�9���=��Q�x_�Y�\n�Aiu˥�͹+n�Ѥ��E�tM��pWgm\u0002 �\u0012\\\u0002Q\u001e5n�\u0012\u000f�����r\u0001�n+/D\u000fu;�3?��<�'��+Nr\u001d��TCmBv��>��E��\u0013��6͌����\u001fʹ�{\bn�[��F\u0007#ܚ�.��-�\u001c4�h?ΰ\u0016��˴.���ڊ�\u001dXe��x�L�\rbU�-�2��\u001e��\u0000�+\u001c�\")\u0005H�+��h\r��0F\u0017����.<#\u0017��\ts�F���8\u0019�*T�4�\u001eg��S!�u~\u0016{�4fڅ���*�H�����%Q�W�8�t��l0��H����k\u0016pԍ��[��i|�F��J$\u0018��޽�����zLZm�\b\u0015�D�F�]�f�6����{\rane��\u000e��!\u0018`\u0015Տ\u001f@kѬ!�4�c#\u0012I��\u001e�𩎲����DS�\u001d���sq\u001c\u0011���@3�򋖙�S+by��S��s�����j�t�}=xkـ��3~�G�^qr�גI#m�O'ҷzD��s5���ȁ�\u0006\u000bw\u00153Dm\u0014\u0018\u0014�\u0018��9\u001e�f/\t��}�.L�~bB�\u000fcZQY[?���ʔ�Ϙ�\u000f�s����+E;;��2\\\u001f�\u001c�jr�SX;�\u001cbhe8(N0{\u001fʲ���>颻���\u0012�*���w���,<�S���a-N�\u001b��k�.`w�RA2���b\t����in�xn.!���a��_�*Tդ��f\f\u000e|�\u0017�\u001d���SJȑyΤ�I�#\"��g���FGm�Y\u0011�����SgA+\u0015\u0019*˴\u000f/8���YGmy!\u0011��|8r��W\\����N)y0BB��&%\f1�)44�\u0014��in�\u001d�q�{\u0011���<�O�<(\u001cn$����b�G�e ��\bA\\���\t�P�5����#����2\u0017\u0003�)�\u0003}ªd�E�\u001d~�\u0019\f*�n̛�[����Mt�+��\u0006�D/���\u001d�\u0019\u0011z?Ф��\u001b\u000b�$�>J�j�럭_��\u0010�����\u0000G��.�C�\u0000-\u0018}��\u000e*\u000bx�|��p�3������Uդ6�w6Hq\u001c���=}\u0006}+u\u001b��R��ܳoak�_\u0010<��f@g�\u0012v�p\u0011G��\u0000\n��\u000f��ֶp��w�<��1\u0005�\u0002\u001b>��5VK����i?�r�\u0006B3�\u000e��:kP�'�(\u0004y.б��=@�[ӒKRe\u000b�D�T/\u001e�\u001eT\t$��X\u0003���*�զ�ji������\u001f�sY~\f�����W\u0013��\u001a�I9'\u000eա�A3G.�t1qyʩ�\u0000�q�\u001f�j��\u0016��bJ�kh ��(�=�� �C�}�\bA��\u0000��R]|�\u0017ҳ�;��i�Wǥ��8�s���Mt3Z�\u0016�\u0004�$�ͭ����>od�8f�ug_���g�(lI\u0019\"�?v.�\u0000�rMMf��\u000b�����ڃ �!�U>����\u0002�ɨx�}F��6�]��m�\u001f��f�;�Dm�#� �m�\n�\n���L��d��N��ɵb:��S4\u001e毡�R��\u0003^m����\u0019u'�煮sN��o��)*�2�Z��2�z���Q+ϟ�Ta:���V�I��.�e�hr��<��Q(�\u001d\u0014�r�\u001dl\n�jH�\u0000¬\u0018�tr#H�Ba��q�\u0003�\u0015��w���~�e8Qԩ\r�WYg�_\u000e�\u0005U�|�?�4eq���yFI�u¢}N3Śd�\u0000�nL{�\u0007\u0015�B�&��\u001d��I���]A+n\u0004\u0004ps\\LN���\u0007��=�z{jrb-͡�|>�R�i�[�v\u0011\u000f��a��\n���N}�W7�=3�2��H��ym��K?�@�+~��t�.�P�gȌ�\u001e��#�8�I^s��\u0011��G\u001b�D\\k7N�rZ�����C���W\u0011�����Y�H���\u0011�4�V,�摏w<���g�i�\u0013�s\u0014~r�۱~�\u001e���$�\u0011�\u000f�Z�dh-�u�� \u001f��\u0005n�\u0000f����~��Z�?������\u0011M\u0017����1�á� ի�\u0010̷D\u001bf�\u0014�>7���\u000f��\\|ϛC���e]��Y+��fU��!�|�\u001f�z楈4�c\u0018Rs�ڻ\u001dZ���ݩ]�1D#�q�\\�\b6��5���SWf�Z��7\u0015\u0003��\u001fδ�\u000b͐\\��J'B��cn�v����ٞ\u00014o��#z}�\u0007�\u0007>�c�\u001a�D��\\�,�\u0017j���A��EJGO:\u0016�[���]A,qț$\u0016���|{S\r�o\u0011ki\u0003 b���ڞ�� �\u0000����~YR \u0019\u000fc�\u0006����޸��\n�Ə\u001e�'��1���JJ�4-\u001ak�i\u001c\u0000�nrK\u0011�}9��tbe\u00063#;m\u001eX�Uo#-1�-�Ą��\u0018!H�<�h�Y\"L\u0016\u0012�\u0000��*\u001a��.��Bp\u001b�F=\u0004�A\u0015jh��#y�+\n2&߽��5BB�\u0016�N����s|�����ⴜ41-ɞ/�5P��\u00001\u001bFr+\u0019+T^��\u000b�%o�id�\u0019�\fۈ�T\u001f�5����>�x�c�+.��s�\u0002qןJ��\u000b��C�\f�[d�\u0015�˒\u0005szL*��W��\u0018`2\t�i\u0007�\u0013���vٙ�d\n7{Tw��WgL�:ըa��>R�1�X/\\z�i6��Nnf�\u0000�[_��ћ��\u0000SE�c����ɧi�d��\fJg�[�\u0018�\n:�'|�J�+y��I�Nw=�\u0003����m��cc�]����egy39�|�����,r��\u001c�\u001a6��u?ŷ��\n�[j;��\u0015�x�\\+\u0003�[ɉe\u001bI_�N�\u0000�Jrw�\n\u000b�9�\u0013�-�j,\u0015�mn�!�\u000e���\n�|\u000b����Vy\u0017\u0012^���gE�9�k�`�{ۘ,a\u001f=ċ\u0012�N+��-�\b���E�~�c�SJ�\nN�\u001dE��G\u0010�q����l�y�^U�q�H퀤�ֳ�+M>\u000b�R�B���X�\n=�yo��U�x���l�l�j��_s�}��o�\u0007��^\"�-4�l�R����\u0012S\u0019�V\u0014��\u001e�\u0002��\u001fx�L�\u000e�l�dO��3\u001b\\0ǚ\u000f8\u0003�\u00075ʒ=(\u0014+!�!\u0014�A�M\u001cS�T�r2�t\u0018��\bY����\u0010�yW�/A��\u0005em�zW��\u0014�v��9�������\u0000ʓ\u0003�����Y�\u001f���\u001fV ���_�n\u0014Gg����i�\u001f�O�\u000fՏ�[c2^���\u001f��\u0013^�\u0016����NVg��\u0000�I�?���j(�)�?�\nOc\"�a�G�qT��A�e�\u0000ec�\u000fj�Q��l`�ƪBc����F\u0014��k\u0007c��M���^�d���oO_jǖ)�&u�ݑ�\"H�\u001f���\u000b\u000b�w\u0018�f\u0018\u001f#zT��&Fy\n���^3Y$օ�W0n�^DT.YT�g֫����6v�`UIK�\u0004jY�\u0005SBNǡ�\u0014F\u0002\u0004��\u0004\u0015?3V���by.m�q:�\u00191֡��\u0006�}\u001c�!\u000b*�*��ǧ\u0002�\u0017�wG��N\u001a\u0015\u0001@�����M6\u000fW�\n���” `�s��*T�k�X�Ky#9\u0007��튎�����d�FU\u001b''r��:z��Z�r\u001e��Z�r�NC{�Q{�b���\u0004���ôdBT��\b�C�YC$v�-���@t>^2?#�N\u0017J7H\u000b��\u000e\u0007o�\u001e}���\u0013\u001b�K\u0016U��9�dW<�+:i�[�qx6�r�F\u0018n�q��\n~��\b$��Y�\u0011.��>n0\u000e~���if�2��>�M\u0019�<����Y�Β\f��[q�-�\n�k�����Fr\u001b�Z[�\u0002�H��1�7>�s�?�]����\u0001�܏�\u0015�xت�.%�\u001f4 q��Y�\\�g\u0002(̎��n�P}�c\u001ft�u�U�V��\\F�M�rG��9\u001e����\u0014c�6\u001d�\u0015���\u0002ǭI��C��I��+��\u001e�U3�;�*�{\u0003*��q �B~p{�\u0018ى��h��\u000e\u0007�.��&\u0007�_��m�?\u0001\u0007s�s�\u000f����R3˽�ɓ��-l^K�7sҺ��\u0013�j�\f�f�-�$�8b2�\u001dN?�+�.g��V�c�$;�����Ƴ\u001b/\rE\u0019R&Ԯq#z\"\r��y�MTV��R}\u0011��\u0006��k�_0�v\u0011�����2k����h�:�\u0007�Y>\u0005Ӿ��hfeķ�n\u001b�މ�s�Սr�\u000b8�{�\u0002[�'�!�=���%r\u0019�?��Ϋ\u0016�\u001b\u001f&�\u0001a��ܟ�b�Z���MB���Q����#�'�EU.����妓�(�\u0018�Pi���\u001c�@O\u00042��\u0015�\u00032��4\u001e��W�Z\u001e�\u000e���q�\u00164Xc#�^3��My'Í-�|Bn�\\'\u001f���_�d�\u0015�\n��k\u0018�\"QS�\u0003#�SOe�4�����jGb�n\f���D\u0017\t\n�C\u0002\u0005�\u0000+��6��y5�g�VP\r��\u0007�\u0000~u�ڤ�]����\u001d��ޕ=��\u0000D'Ѕ�\u0013�#�n\fx�aQ���j���\u001c\f֢�D�z\u0018�%��\u0006��\n�{x\r�T<����\u0004@����I�M��\u0004��v�\u000e|9o{\u0005α}\u0007�\u0013\u001f\"\u0014n�\u0018,��W\u001c��u4V�.�fq\u001a\u000fRN+�t�6-+K��`\u001f���&}Os���\u0014އ���\"9�X�\u0004p;ִ��7�\u0016\r>\u000bg���\u001c���!^7`�b�sVj��2[I�S۞k$�����R��f\"\bd�����p)���Ƒ!hQN8�&��>��tK\u000b�Mn.\u0011������Pp\u0019�r\t\u001d+:f�����#h�|��#\u001d���=�=�^���\\�4�\u0014�C�\u0000\u0011�:�j�y4\u000f�XIc\u0004G�2\r���&�a�g��g�_93\u001a\b[p)ө�VA��\u000b��\fď����\u0004�-^�\u001a]����n59&�\u0013¢�g��\u001f�6�T��I\n�b �_O֥�`��)j�&�\u0015Q�����G)�[�I\u0000��p=���r�\"��q��'��5�\u001e�\u001f0\r�\u0002�w䊭�[\u0005��t�b CN��(�\u0019�<S�}3H�t\u0011��$�0�'8\u001c\u001f��W�|=�&�\t�yt7]:�\u0000\u000ex��_�\u001a��t���H�Q�~�}!��R(�DR�7�5��#`F\u00139�g\u0014��l6�ml�+\fT\u0013f s���5Kby\u0011��Z\u0019 ��\u0004�͂��\t���^���x�Å\u001c\u0003ܓ�T�+K�}\u0006��l��ZF\u0004���<��\u001e��X�4`�\u001c\u001e�V����$�+g\u0015�:\u0006���d\u001d#�e���\u0000�^wgi&��[i�}��V1��O��/�Q��\u0004 ����Ʌr�\u000et�k�\u001a���c\u0016\u0010�\u0000�G��\u0006:�j�G:g��\u0002�H!\\G\u0012��Q�\u0001�^A�\u0017\]CXm6�����)S���\u001f��A�S�:\u0003yL?�/A��{��\\�;{ׇ�I�O$��дW\r�4��F)�%\u0000<҃H\u000f4��\u000b�M�摍hh\u001ao���khA�o��\"����\f�_��\u0012+�W\u000e���?�a���u��;K9�\u000b��q)����2����pۀ\u0003�w8\u001d���\u001cV��U`��G\u0002S���\u001a\u001e\u0007������\u0014���K)���y��y��\u0000��8�\u0006\u0007�\\\u0016�8��NR/�Z�o�muK��\u0011\u0018�Ժ�\\Gל�A����\u0010tD��\u000ekF�F$Vr�+B�mZlE��0���~�Y��MR��\t5,����s���\u00106����\u0005%I�da��\f���\u0007��r�\u000e�[K���\u0012.٥\u001et��n��\u0018��#��+�6y�e2\u0005WF9�\u0005���֭��e��<�.\u0019Rf\f�\u001c�~]\rTK�\u0010g!�\b�(�!wU2\u0006\u0007��`�Bh�,'���i,�F��q�\u0007v\u0007_^1V\u001c$�\t#I01�n?\u001a欵Q�i�o\r��\u000b�wv�A>��\u0000�C�_$���ɸ����\u0011�EC���J-�\u001a���ܵ�\u0016)o�\u0019D@3c�1�V%ͬz���\"���?\u001b�OZ��Pc<0��1�S����\u0007�Y�w\u0016ӆ�xLruFN��*�E�VW ���6�\u0016a�y�_jՎ\u0004�Ӳvm�!��\u000f����Vu�Yq��6�\u0000 \u0011[V\u0010�u[~HX��\u001d~�\u001fֱo���?ж��I����5���=67\u0010!��1���X�|�����\u0016��b�c�\u0000�U|k��.�c�F�--�\u0013\u0011�\u0000=\u0018�\u0004�1R��\u0019\u000e6\u001d�i�3�\u0015��(+\"?/d���\u0003�Xb�|?��붽���m� \u001e���\u000e��ok>�x�����.O�(�kS�W�i�Q�v\u0003j�\u001ei\u001dU}>��������\u001df�y\u0016�b���\u001ew@Ǹ\\\u0000kE:W?�φ\u0010\u001e�2�\u0000J�F�`����S�g=�\u0005\u0003�.��H^9\u000f����T�)k\u0006��Ի�\"\u0015uk˖�\u0014��}p\u0007�[���ZMŃ�ۂ��M���W��V�\n$q�r�A����/�(���*�{\"\u0011�x�\\��&�>�q�\u000ev�\u001fh�\u001fuEf�( �*d�RCZ�>�#q�3\u0004���\n1�v�R��\u0002\"�^��C���N&l)�\u0000�jy��\u0003�>��[˨� \u0019�w\b�ܚ�\u000bú\\z.�\u0012D��,Q\u001e�G\u0019�NMK�\u0006ͳyӴ��W�\u0007�w�?�u��k���\u0000�̛!\u001e�/\u0003�9?�u~#�k\r\bZ@ظ�>B\u001e�\u001e]�\u0001�μ�U���R8���0\u0007��J��=Y^��5��h�>]�;�\u0000�eO��뜍w>*�+�g��!��X�\u0000�ԨmԖ\u0018�\\�����\"�ȱ\u0015�N{U�\u0004b�T\b�Z���hJ\u001b+��𦖺LjcIWu���\u0007��A���f;Kv\u001dk��\u0013��7��,х��>k���\u0011�s�Բӱ���6�WQ��P\u000e*ʜU\u0012q�\bn���\u0014F\u0001n8#�qIp\u0005Ğd1`�7*�\u0007�S��/\u0000�����␯�\u001eA\f�:��}Er����ƅv�w݁�@�I\r�5��$���ڠr�\u001e�JW��%\u0017;q�a�U�����\u0006\u0000�\u0014���I�T��b�d\f�\u0000�L|���z���0��\u000b/@\u0000��j�n�\u001bo'\u001cT���\u0001�\f9�\u0007�$�)E-\f��\u001b\u0002���;��5�ijMԳ\u0004\u000b\u0019�UU\u001fÒ?²\fЍ�]簭� \u0017����1\"��~\\�\u0000QY��/G�\u0013?��F�M�{��2\u001a=��9��j�K\"*LJ�p\u0002\u0001�?J�r�O\u0015�*��N�ns�\u000e?�v�\"4�h�\u0015H�\u0013!\u0018�\u001d�\u0000\u000f�[�FW5�\u001f\u0000O\u000e��|�M��\u0015=A�A��1\"���+�f%��RkZmBmQ�_�\fG����Q���ٷ��#)8��I-\u0004�ge��?�\u001e��~d�B�\u000485�x,c���\u0000_O������v\u001e\u0016�\u0005�����!�>��\u0003ֻ)꬏:��e/\u001bx���v���q�L3\f\u0019�\u0007����׆�<�w2�]He�g/#��M\\�5y�A���+��\u001b!\u0001��\u001c\u0005�\u0005P<V�i+#4���\u0006�b6�ֳ(A�\u001fjv�P�(��4\u0000�3�)�i@�(\u0004�\u001e\u0000\u001dϥ\u0000v�\f<<u=jK�_��\u000f.2G�S�/�g� n�\u0014_�\u0005\u0000\u000fz��N��\u001d��(�y���#�����𫺽�iZ,�jA���O�H�\u000f��*b��I�o��Q%���l�h�����\u0000�~|~\u0015���얱Z���|�>��uZ�#\\Eb\u001f1ڦ�X�=I?�k����n��\u0003��z\u000eիfi\u0016t��\u0000�v�������J��\u0010�su����zv�����J�\u001b\u0002�a�O��F�dX��Z���\u0003�\u0001��I\u000b6=*9\u000e��h$��\u001dқXס��\u0010��NG�\u0007Q���Y\\n�\u0018\u0003�=\u0005s^\u0003�Z�C{�W\u0013_�W#�\u0018�����2\u0003\n\u0016��й\u000f\u0002�5Z3���S\u0011�G4~@�V*�\u000e�\u001b��Ol���\t|¬<�\u001f�\u001bi����S\u0019\u0004��[�S>�$�\u0015�]F7y}��,�\u000fi\"\u00127�_c\f\u001cӃ\u00028\"�m�\f���r(X�\"���;�\u0006���\u0014;zS-��B�̉���9ݕ<�U��$�\u0019]\u0018\u0010T���Ih;6\u000e�g2\u0005c4�Dv���H����*��k%�ᤸ��\"(�\"?\u0005?�V��n�\u0019BŌ'a���1�Vo�����G��\u001em�6Mo\\�+�!���|䪖'\u001fSҺ�r�̖=>�쵀a����?\u000f�J�A�\u000eA�[7��]�#���ϰ�+%\u001br��\u001e�l��\\ih\n̄�8\u0015\u001c͹��Y��\u000f�\u0015\u001c�(z\u0017\rY�x)\u000f�#������_\u0015/&��Y�~��\u0018�5�\u000b(b_ҽ\u000f�$��e�\u0000���\u0000�V�_��\u001a���u�f_2B�L��{+gۡ��R�8*��g���c8\u0002��d�4�\u0016F(�K!�8�5I�*�\u001e�f\"ri�\u0005(\u001cR��!�\u0005<\u001cTdњ\u0000~y���΄u�\u0014G+��,@��о~A���W$\u0018\f�ҽ��~�����t�4�\u0000��������L�\u001a;\u0016�~��z ������RC|�\u00007�t�ϱ���\u001fκ���Ӵ���\\�2\u0017�\u001e���W���\u001d0˹������ɫ���=NSU��Ȃ|�oP��R!���T��nԥ�q\u0010�\"\u001f�\u0000\n���\u0019j�cO��\u0000��Ī\u0005��j���\u0000�~��\u0000\\W�\u0000F%f���\u0006���O��C{!Q�sZZ>��ޱo��¹�+u\u0007S�+: \u0015w7J��\u0002i\u000ba���D�\u0000J��$r���ǭ[)++�\u000bF�*F�c@\u0015\u0014v\u0003�)�VOJ��:S�,u\u0015D\u0010 !pEG)��N\u0000\u0015RNM01/�2\"�\u0004��\u0018uS��֪�(��P�9\u0001~��������NH�\u0006��\u000b�Ue\r\f�p\u0019yS�W!���\f�\t`��М\u000fQ��#�D\u001b�*�\u001d\u0018��*V�xr7\u0006R0J�G�*'�HX$��z\u001eƑi�yh�Si\u0007nK �cڙ�ӑ�SF#�r�� ð�9�\u0014\\'�º���!�CR�QЯ�4L�\u0019\u000e�\u001b�P���omc�\t�%��\u0010Y\u0001�\u0003�Ȫ;c�8��\u00152����#�\u0015N��iH\u0011.�E\u0004��\u0011���+&�x�\u001f�'i3/̟P��P�m�O�; ��SϘ\u0014��\u0002�{Q\u0012g�\\c#����\u001d�_z�L\u001aOb\u0000Io�g�Ӌ�\u0018+�zp\u0019\u001e���\f��%�F�:o\b^Ɩri�7ݽ�ݑ���*\u001f\u001fk�LғL�k^��Đ\u000f�\u001f����:f�k��P�R�Е�1�G���\"���T�'��}���c�G`=���+K�ί��T�\u0000\u0000\n�=�JمK0\u0004�\u001e��hEi%–\u000e�D\u000e\u001aV\u001c\u000f����\f�E\u0007��т7��\\|����z����[\u0012�G �\u0018>�����!Ni\u0015r��M�V\u001a��S\u001e\u0006A��\u0001sW��1�|Imj�Z\u0014>l��\u000fO��W����V�Z�'�|W�|#��mJt\u0001�\u0000���\u0000\b�g�\u0015�]���ơ?�E-��\u000e��Z��\u000b�\u001a�i>�?��zy��3�\u0000\u0002�\u001d*��_Q�\u001d6{�$]j�@�T�]7�f����Y�����vGoo�\u0000?\n��kQ\u001a��$���/�D?�\u001d�\u0000\u001a���k�V#�\u0001�T�Z�\u0011��3TܣNŇ�f���Ĭ�\u001bڮ��v��\u000f�`��5*\u0018\u0013b�j�����\"�{\u001a�\u001bѿ���m\u001c\u0013n�����\u000e߉�z5��\n\u0015@¨\u001c\u0001�W/��/�\u001a?�d\\OzC�UA�G���\u00000*�p��M\u001c\\S�<\n�1�,��Q&\\�U�5r�u�-�i�ô�'��kŌG\t\u0000��\u001e��h�h\rդr\u0019A*#f\u0007i���Wf��\u0012\u0019f�\u0001\u001c��P��\u0013�j�in�o3[��,�&�\u001cg\u0007>��!�\u0010-�#fS\u0014g��f��=�6�Cqp���#�\u0007�?ST@1\r�����\"��u�4�{9D�\u001co�I\u0015r\u000f���&�m%�6n\u0015�15��{v\u0019\f�\u0004\u000fqP\u000b��P\u001c�uSҨ��m+���8�p�x��4W1bR���D�7֛�1�ܑ�ڍ�K\ng�\n����\u0007j��\u0018�$�wx��m\u000b��\u001f�S�\u000f\u000bE\u0002nX�C�8�ǩ��\u001eIDE�+\u0004j\u000fԀrk)/�G����v\u0012F�Ko,>J\u001c�a�;��[y\"`�(\r�z� �4[C�$|���Z�s'��\u0000)eR�/`\u000f\u0015��̯dP�\t?yW�P�\u0012�h���)8Q�j�!#��b�MV���1\u001cG\u001fʃ���i��EY�F�]\\=ě����’��O�YX�o\u0019������M%��έ<�b���}�o�T��\r��\b#�>#�z/��z�K��7wv:Y��\u0000]�'\t\u0018��ip1ҡ\u0007\u0002�ˁ�x�!�\u0012\u0005CT\u0017�5�\u000e��j�$�V\u0013�\fC,�~\u001e��gʋ�v\nHppGLQ`#''����GY�`���'|�vA�����T.Q�?�Mz�¯\u000f���K���q��\u0007���?�Kv)#���\u0016v0Y\"�\u0002�v\u001e�Ҳ�O\u0018�-\t�\u0016�'���\u0000\u0002�\u0000_�V�\u0011�[\\j\u0013}�R@�@�?\u001a�mvY�'�Lf��.no\u001b����\u0006\u0007�N\n�ɜε��\u0015���c��E�'�)��UɄ�(\u001c\n��n\u0005��(�1�.%�Q��\b�8�\u0011\u0014jKb��݁5<\u0011�S�J�\u0000\u001d�9;\u001aA\\M*\u0012�\u001a�a�\u0014�\u0000щZ>\u001cю���\f���<ۃ�|���4�R��P$�\u0015��\u0000]\u0016�\u0007�z'�&��ȸ��ķ\u0004�\u0007��\u0002���)����^�4`\u0000�\u0000(\u001c\u0000:\u0001�Z\u0010\u000ej�#\rW�=+s$hD�\u0014�Dž���N�\u0005i\fȸNMgJ�nkb�:�U��u�D���ϛ\u0012�39�[\u0018PG�T\u001bA��ø�\u000b�\u0004�T�I\u0011���\"��o%��=�a���#p\u001b\u0018�A\u001fZ�=U���>�yw�3�\u001c\r�\t9�:��˙�̗\u0017\\\u00014��\u001e��],W1ZMz�\u001a��\u0019�+�A\u0000�W\u0016�%�@��MoOf�J���,r}G�:7)�K/��\u0014�y�)Bzt�0/A��6����\u001fd�n������Bl���g��\u0018`�����5�l f��'�1?�_�-k\u0019$�����)4���6�UbU��\u0014ck�G�\"��iq���'�75ƒI�ꧪ���2�V����Kx$u��U�X���8�>�\u0003t�z\"\u000e���;F��F\nz��Z\u0017\u0003�vb��[ω.�\u001f���֐VFug�U��\u0017\u0013\r��\b��c����s��C\u0011I�4�p+C 2\u0000\t&�gЮm4x�9���t�lソ~o�*�t\u0016�n�w\u001em���V�\u0000��:��:��1.�w�<�4�3��ֽa����$[i`P$�\u0003\u001eW��\u001e�����Q�{�-%\u0004w�d�\f,���ι�ำ���\u0000N��s\u0017�a������=�Hu��r ��%���������Y�b�\u0016��Yu�n-1��m�\u0000�\u0004`������k�M:�,l!��6�\u001c��+��qX��\u001d����R�\u0006�\f��÷�ֶ�[;9�\t��U{�A�&�W`�H��\u0015�K'��}��D��\u0016�\u0005����0��W��k�Ȼ�\u001f\u000b��c�t\u001a��O4zl�\u0003�M������\u000e+ϵ]Ljw�r\u0006\"\u0003d+胧�ִ��3�\u0004ҫ\u001c\u000e�� �B�\u001a\u0017�K`h�aw\u001crjc��\u0001eZ���u�4.��QGROAY7��\u0018�t�\u0007�[�V_>-��\u0017q�\\\u0010�?���I��I9&��m-4]>��\u0000�\u0014����9\u001c�\u0000�i�ɬ�z~��\"n�#�������\u001c՘�\u0001[�\u0011�\u0013\u0010)�<�\u0011�+�\u0015# �<\u001ek&v���x��d���\u0018[\u001bT`\t\u001fm�x��(��\u0015P�q\u0014�X�Y\u0004\u0012\f�\u0007��N���ԭ�O\"A�w��`\u0010^M\u000e0\u0003�>���\u001a�]�S������ڌ�΍\u0014�\"�g\u001b�d\u001f�5�Jv��\u001d\u0006+_�\n\u0012\b\"B\u0002K.H\u001d�?���q�9��D>\u0013���D�&��\u0014�1�H�l9\u001c�֨�\u0017?�Z�\u0017�9�_�-j�Th��C�\u001f.:�\\խ_\u001fm^�_�-k'�X�?�}\f¸5\u001b\u001a���C��* ,�@\u0000w5�%��\"E�{8�6�m��������P��$�,�ZI\u0018���M]��@���\u0010Vߙ[�򞿀�>����KC;ݖ\u0015�mxg�\u0013���Δ�:lg����\u001f���\u000f\u000f�\u001e!Ԗ�\"c�L5�������]��\u000bKX�-c\u0011[��#A��&ƑOU�8mm��5�\u0018�čz(\u0002��`���ô��\u0000�\n�5��\u000f��9��<;t@�:\u001f�|U��+s>\u0019�\u0000t\u0001�S���]�\u0016�l�\u0014��1:�\u001d>�B7�@�:�y�m'˶7�\nCH7`�^���U����m�D\"<�3\u0017��k\u0013�\u001a�k7�H�=�\u0012H?�)\u001f\"�\u001d*ٻ�\u001a}������\u0011�vc¨�k�5���d�P�k���{4��?�i\u0015��L���b��7rn�\u0003�S�c��k�f�\u0001Үj\u0017���{�\u001bL��\\��\u001d\u0005Rde#p �4�\u0010��!���5n�W$�f�.;��d\u0000+��\u001e�g�mfu�ͱ)\u0000#�I��\u001fι�;O�VԠӬ��9�o�/v?A^�mi\u0005��66�l\u0016�}�I�5�Wfҕ��������F�#5\u0003�����X�iS����#'�\u0018�\u0014�����S�I\u001f�� S�`\u0013�R/���;h\u001d�e��MVs���1ɨ�\"�FJ\\i���~J\u001e�<��O\r��w�ġB�F��ʎ\t.%�፤|r\u0017�֬6�2���@�p\t'��4�z2�OF`x�&�T��2�\u0002#  c����Y2\u0002\u001a�����G>�� �#�q���e͍خ�����n쌂\u001b=��\u0005W\u0003\u0007� \u001d\u0006iF\u0003b�\u0016��\tuK��\"`��gs�*:���i\u0006��\u001bv���\b�r\u0018\u0004\u001dj��p��Ҥl\u0016Y�h�'�n�~<�ꍣOs\u001812DZrA�ôqX���>��\u001d�<�������@q��eO�R���c%�\u000f�!�\u0010GY\u000f�s]\u001e�^]֐�*E\t���0��s޹��\u0012�T�\u0000V�pZ�KK��#�˂r{��8�iDq��=\u0005H@ۜѥ�mYB�\u000256�*���\ti���^�b@�82��݉=kl\fqU4D)���F\u000f����*P��~�1\r��f�B�}T��w����\u0000�ֺmu�um��!\\����\u0011���p��[/�˩\u0006�`ڝ�6�e3�_�}?\u001e��ۈ��p\u0000\u001b�\u001fʹ\u0002h���i��\\K.\u001c��uϭtw�Oc`]\u00007W\r�0��\u001c�\u0015�Sfs�*�V9$�`�c�D���r1�\u0000�����\u0010L���1��7�vޤ�Z����D�!c%���\t?�?�5�\u001a�ij��4�2�Ř���#\"��x�EX��_�\n\u0000j��j���J���j\u0006E-��˲A�����a\u0004�J�\u0010Gy\u000e�\u001c��V|'�\u0017ּF!�S�\u001b@&��q��\u0013I�'i�\r\u0013�?F:�ˋ��\f`�R.ߟZ�ߊ��=\u0014*��\u0003�\u001d�V��U���\"o���\u0000��\r[O�T����\u001f�j�\u001c�YC⟯��DEp� -K\"��Hq[\u0012\"`�����BFI����@\u0014�\u0014���,�v�\u0004\nb\"��-�0�&��I����;�\r��i\u0003�¸��3�{�з��I�\u001f.��^@��B��B�kֺ�z���/�8���/��\u0017gvp��幾�\u0007�t��f��'4B�;\b�~��j,�[3��(=)�zTA����ր\u001eW~\b$\u00159\u0004u\u0006�\u000b}y �6w��K\fG�\u001dF���Ԟk�Lb�57\u000bp���/�\u0001k\t\u0016>��)=\u000e���U��� �\u0015�q�$\u0002���rx9�qRxcP�����\u0012\u0015��_隮����e���sԣc?_Z��|WdD��ŗ`\u0002˳r�\\�յ�\u0015�9��\u001bP�q\u0004��\u0014�\tP�|�J���E��\u0007?ʺmcS��i&�\u0011��0�Zc\u0003�V?����)F�bm�pG\u001dE6�)&{M�{,�S\u0018\u000bo\u0018\u001f�ȧ��&͑ƣ�j?AU�q\u0018,�*��؇���\u0003�m}ٿ�eh����l˾!0g\u001e� ��U�r�9�\u0011�p�\u001cw'\u0015�xWL];M�s+�����\u0000\u000e��~�\tjm�\n\u0002B>�|���KĚ�*�\u0010���mf?�'��A]\u0006�p`�[8�l�\u0000��'�7�\u001fZ�ۑ\u001cQ](\u0000#\u0018�ǧ\u001d!S\u0015�o��k��榟\u000b���c\u0003��z�¹ɏ���[�\u0018��?�s�j�S��m�\u0012�\u0004G�<��\u001d�\u0007\u0002�G\u0015,\u0003\u001dj\n44����(�$�lX��+��m14m=mF\fχ��_\u001d>���Z\u0000\u0005�Cr���f�����\n�\u0014��in\u001b\u000ec�V��YlUi��Vs���U�wɪm˧��U�N�X�⟯�{\"Խ*��ڭ���Bvɭ�,#�\u0015)�Uc��ht�\u0005yF8�JՉG\u0004�bi�WH��Ź�kM�}\u0007j���1]\"(UI�\t8�\u0003�\u0003[\u001a��\u001d�����/�1Y�q\u000e�p�\u0012C$ci`A���U��f�38\u0016�\u0007�Ds��\u0001��4��\u0001�]�햘\u0018���g�r9��\u001eM\u0006�؛f���>�����\u0016�0�`pEJ��kI<7{$�8��l.�d\u0004g�ˉ��S\u0015�h�w���N���\u0013�\n���S�G\n\u001e��V\n\u0017s�d�0:\u001fAY�s\u001c�<���;�\u0016%���*q��ݣ@����A�G�\u0002�\u0000�U4���\u001f���\u0000����4��5>�\u001f�a��o�8R=�ٖ@��[�\u0000���\u001c���R�N�k\u001b\u0018�V�[$�prƹ�r�kk�\u000b�]�s����z��\u000b�eA��c�\u0002$+��q�Q�\u0015\u0014�ۗ\u0006Wa�q�\u0015i�es�i�ҩP��ٛ�0�y5�6�\u0016?!�4��y}\b�۽u\tl�B�\u001b��\u0005��x\u0003�\u0019Q����V©�Xx\u0015'�V��+&�i\u0010?���U���\u0002q��W�x;/Փ��{���;������\u0007޹�v�$1\u001f&9\u0011dڡ��cZ\u000fp���1����\u0003Ҳ5�����\u000f�h�0��\u0016\u001c���\r;(�옖 e_��z�%ɇ�f�f�T�*�2�t�럚���!�X��5\u000e�?��M��Q��\r*�?�?�\u0000\u0015[\u001e\u001f�:�\r�zm�#|�>��\u0010u?{�\u0015�<�q�d\u0016�a��\u0015��\u000f�\"�|?\f�\u0006��Q,�\u000fC�T{\n^�\u001f�avhEc\u0015�)ol�G\u0004K�4\u0004|��\b?����U�Ҙ�^�\u001f�b�d-\u0011\u001f��O��C$g�z��EZ5\u0014������s2\u0004��Ř�i��ԣ����\\!\u0018�&�\u0002Ċ�౩\u001d�\r\b��Z\u0012\u0010�I�Z1�K\f|�\u001e\u0005Lɀ*\u0006Q�~SUJ֋��U)\u0000\fj���"
            "native": {},
            "from": "system.adapter.frigate.0",
            "user": "system.user.admin",
            "ts": 1700989168929,
            "_id": "frigate.0.Terrasse.person.snapshot",
            "acl": {
              "object": 1636,
              "state": 1636,
              "owner": "system.user.admin",
          im mqtt Adapter ist er korrekt
            "_id": "mqtt.0.frigate.Terrasse.person.snapshot",
            "common": {
              "name": "frigate/Terrasse/person/snapshot",
              "write": true,
              "read": true,
              "role": "variable",
              "desc": "mqtt client variable",
              "type": "string"
            "native": {
              "topic": "frigate/Terrasse/person/snapshot"
            "type": "state",
            "from": "system.adapter.mqtt.0",
            "ts": 1700976115142,
            "acl": {
              "object": 1636,
              "state": 1636,
          • Wal
            @crunchip ,
            ich wandle im Adapter die Strings in Boolean um, da True/False besser ist als On/Off.
            Du bist aber der Erste der die Fehler bekommt.
              crunchip Forum Testing Most Active @Wal last edited by crunchip
              @wal sagte in Test Frigate Adapter 0.2.5:
              da steht aber weder true/false noch On/Off
              bei mir steht da dieser Wert drin
              ����JFIF��C
              #%$""!&+7/&)4)!"0A149;>>>%.DIC<H7=>;��C
              ���}!1AQa"q2���#B��R��$3br�
              ���w!1AQaq"2�B����	#3R�br�
              $4�%�&'()*56789:CDEFGHIJSTUVWXYZcdefghijstuvwxyz��������������������������������������������������������������������������?�4}��M��K�2X�g�!�H�>���<����������X�C��;Ej��\����cv9��4�.+�+�qm,�#�h�vq��F����9�ֹ��n�\���{��^�A���dT=0@|��sM3ws��ڽ֟�,����y���s�w
              �X4��ޱ����@$�=��}j���#E��`^��_5Cʠ`�z���5��=�wj��s��Y$
              �O8 �`~At&r�i��J!c��^���Ÿ[�o������㊞�e�6�)[��C��8���jg���N�@{����Q+1Ú$L�DV)�w���N��/~�5#����mʀn+Ume����w��?�N.`|�H�����<Υ4�e�%����jZ.�%�څ�E��,�0��	#(\� >�*@���/4
              �M�{K�-uv`��s34�!G�rB���e�w���M:X<�Uc.�P���l�9��ϵ&��}���q+FV6�#�5�g���d�����տ9^���-�M𝭛[�̂i$
              �m��m������9�g����]��5	���������*������_�U���m���4ʒ!i�O3w�O9�A���=xĵ���R�y��M����H�pA�y��XV�U�ԝ�����Iǖ�~E�u�x_�z���%��j�b�ӗ����O@d ���������X���h"8�猼�t�<�
              �>V��bpq�O>�!��f�ޫs
              �a�����<d��������.�P��m��V�_2�%���0�$��g��Nr�M����~]HN7Л×���H��:Kmt���
              �#f\�����߾3V� � �&��9���q*�d[>��۶���0�����v�fZ�Kc��!����b2O^����0��<r $Ĥ�9��jҜgȔ�_���OC/C��&�K���e����-�%N69����z�R�"�n�9�"1�DQ�����<Ϩ�nB�v�g���LIf ��q��Y��5Ũ���Yf/+S ��3��ȧI{8����������h�K
              �2I��5c�`[{����#��<6;�q]��u�14��K���~~��>Znpq�����ƪ���I�~��V�(���2msc����_�+
              �1�k�U�jLZ�n�4���O늟J����x��pe�'q��q���Iڐ����6�W#'��~�*�{?���Vc�mR[�-�M/���cɾ��ׄ��p�fy�!���5�xt��U��P2p�1��P��ld�Ѝׄ�ݿ��<`gօZ=����9Y����s���p��d˞O�+oǷIg�L�q���@��v�מ1�+��T�h����;���;V_�B�Y�k@��l��lg9�튨օ�����Vg�8�z��⥶�KY�&)*6�u8*i鰁�������'��cĐ�����SP�~�>�����u��8$�W�x�g�Q9���B"�6d��}���|�!%�נ w�š��1��}0��zS�aA�	���x瑓�Q$xn���<�c�#w>��0*���Ra�N}�Cށ��յ�쭧4�C�񴄎���j�<oy>����I,pϖ�
              �;��`�Zu�nA��	%�yo�NA�c��5Z�-n�L�A�%�k�#'ҹa&vu;;�p��C=�Jf�,�`/NT������Gy�h�+��u6ۆr�
              [���`WW�YX�i�ז�M(;T��� ��^�ut����Y|�UAR6���֡��+��K�w�BRd���RwӧO�Y7�i=�S�
              T��r�X�H������C�I��(���1�����A����P�8Tdb�W�v�*(c�C�C�zma�����I�G��'
              ԎMQ�#�pڠ&I�/,��me��z�ޞOBb8�R3߭F�R����a� z�?�DL���j�����F�)�n���C�I���9���\)o-�h�I5�H�9p�^:���_>ݗ��Z3�Hu$�:��j�=��rc�w��?�p7�5����k׏s$�UC��r|�������V
              ��)ؤ�Z��$��
              �B��,����D��F�����d��Irܟ�G��b�l�li�ٺz[��3$����5]�I���qW�|+7�j�I��{֛#+܍]���r<�2��k�"�I솙s{iǖ�A�m8\}7�Vƿz�pٔp��hs���?���K���KV-7�Ef_�?�Cܵ��kS�5k�ԍ��Lz ��A�cQ#�e‡`�����A%i1$�/!21�'5�{tL��R{Ӑ%vz��
              �_&9d�TA�r���r��^����B�1��I/�NqY�Jʼn��VH�#xuw�DM�aU9��l�TΗZ���ǔ������	�/�:�Xj���JǸ�$��N����㽇�%?zgM�Գ�B7<m*�T�mmJ��D�~���jP�^�����8�w�����#���g����dוY��I�$���G�x���;���w)�N��z��I!:U�"�jZ�����~�� ��@��oi_`�����7���4�i�{�@��!�zѴ�1��$���H=��¹O�WWmi I�V���cؒ$�u�L��������=�=����q�V&������[�o��<�c�v��
              ��GޤeY{�LM
              ��g=A�������� �mǁ��ޔ��k��:v�I̵�r1�g�%l�)>�����:��W���u�)\���%��QZ���,�L0ë)��EZ��-��e�b�c���k�s�	�����ˑhV�3��M4Dq�|�Q�Z��p��g�1���W��[Tds�М{U��)B����i�R�n���6�A�D�G|���\6v�獘��Q���,���v��4�eہ$Ѷ8�7�UpJڍ�0쮎���*�ʂ���p�"9q�b��,���QJ)Wps��Ek3F���C����Q ��' ��x�w��,��˖P�A�!z~5��"@,I�Td�Y��|�!�X4��##p�k<:^�>�R��s>8�8�Gb�3,��y�����ZG1��;��g]���?Z�|MW+i�|������~�;V=��bOsl��j61]͟�� ��k�[#���֒[�m`���U�O��\g��k���h�"30bOrz���K;�i�I�$W�Af�yQ����5��/Y��k�4r&����S=G�O�J]B�莖����0�C�Ҩ���N3]���Mp-�ˠ�m#	��w�����yuO	\Z�n��͢l�U_��$ɫ��s��C#,g�wy?!��+[×��M���Ɉ_����9��βm��+Oy3%�(1�S�Yj&��������r�x��ݓ;�я�[��NԴt�ux��/ig<g?�4���RI�3���ʑ��]Ԏ+���Ǜ��8��Wzp��_�_��;{T)#GE���7C��k�Z�_��Kӱ����?�NG����䉹��^��7�����[E��o�T�v�!������핾i���C����.�e��C�Z��׌jr�p??Ƴ�?������K�R�_�J[���<�ơ�O)�
              �)�{%���oθ�w�`�u���@��$t37��}���Tخt�o��QՎկ6�&Y���*�,
              }�n�x��B�.���I��[Dҷ��������G��T�RN71���^�H�ҵ4Ӧ�g�"�1G��WUmr��/���Y���{���V8����j��.���&|�=�o��u������$�9��H#fbW��U2R�d8�!�����O�*���ϓ��h��	�قi���1�n�pwGp?ⷥ���Hd@�D�bA
              ��9��,,-���y�D�UA9'rߠ}�
              �3
              ޕ�wcӄWQ��@3����d���`D���O�R?P�M�1@�Hos֕�l���������t�$[p��!Wa���1�;�a���v�:���Py�$'��r{���O�X�	Ġ�'iG �y���$P�8�G����a����ʠ_/�a�����}j�$K,S�	8s�OG�������)�+C:�(�X��3�<U]Jp���۠����DNPy�'�:H���\����G�Z��f-�e���E	Z�dL�u���\G&�p���������l~���R:�G�T�H�I�S����v����֞�E�������z�Swv0Q��0f�X1?J��m��5�SSa�id��d���k�V<2
              ���}u��6��g��v�|��r?��V�k�{����5�����i֤���w��}�=lOw�d�7-�8�q8��;ԟd7W@�ޢ�{��C�O�'ު�܆��m�C�$l�������5d�����~��@��o�x�j�!Z��gO�����N3�����Ƹm5%k���Դ�bQԾr*mY�(�>ݭi�*
              \纯�?��r�.�+�s̐nR������kG_�5#��:4��Li��a���swR�札p�l��q�7H��x�=ϥg}�P��V��R�*�)�
              �{���G�Q�B܂;cҨ�Uw�#�Ӣ�I$!Oҧ�CE?z5]��kj�U��t�`��Ǔ"�;Y[$z��E�
              )md���V�+X録ˌIp>�{/����m�:�
              :����sr�r�_��%�?݋�C���\֮�� ]S�ؿ�1U]�?5���nW�l���Zة���c'���k���xఅ#]����z �-yWí,_kr���J}�	�5z���c�T´[�r^5�
              k
              �nn�����G���h�!����RH\�3����ެڵܪ�[e��G.3�°���3|����`�DK��[9㊴�(%���E:����H��Q!��
              r�b�GS�j-F|_Zۻ��?��Mmr.���9ç�q��+��ki"�����Gf��"��n~�m��\<jᶞT�S�4Ӱ5s�yqF���;w���}��Ro�18«w��Aď�Cn��N	�P���M}n��� f^#��_q���ZoW�P�M�\����W���Բ�/�8�z�T��6�����<�����L\J�b��ǝ��I�Ԛ�I$�D��W+»z{t�����C���T��*y�u���)�0#���K4���A����ZԗM!�����օ�Mo����N�:��`�+��w���֙�����u�(�+��++�,�!���j�����-g�!Z*�$���
              \%)c�rz��z%���#.B��B�f��EeA7�!NID�.����kkHU���G�~���-v���"��a�y!V!H��
              �Kh�v�=��R��%@�~����X�nt��[{�b�cB�$�κ�y�D�x�y߆.�-J�k)�i<͖��g8'�e�{@�cX��aB���\&���j�3�JXF��.�ά3��*�\�]��~�}�x̻����y���k�N��ӱR�ִ�n��Ȓ���^���S�Vn�+]�����ƒ�u�I��+X�M$ǻ�0�M4���ԟ��1l�!{�7H��'��O�y�>�m��1�a�����9��Q
              ���j���]#L�ėY�
              �o�_�?�����/m;��g�±�͞�?RĊ��ݟ���u��V���#�v�I������f�h��l`�ϛs�A�'���c\5�0��Y�Ni�7��<h���\v��Ƅ�������PLʐ�g�`�U}�z��4�kF�ڵ�tv��;F��Q��98�3L�I��m�MG
              �An�3�q��{
              �-���l���T�s�9=����ʴ"�A	����*�#�K�	����+^�b�t�4mP����Y9���:{���/sB�.�X�Y�j��~h#���ϱh1��GS)��'����}WA�_��c-ی��FLz�����U��+(�@��r�����(�c�W�����~�/���G����x.�����r���3;��嘜��i���-��,i#jѱ�=�N��c�ݧ�s�\�
              e][�L�!8n��_��D��/y�Ap�@|�pOҫ�ڶ��Q�����-�M��f�p�r��,���*����bpRF-��2s�4���"9 P��{�Z/�nt�˅n"��s�aч��Rgh�hl�U�������+;�h����j7o$���ìcc�܎pߥM�o<��{33��9��	'hw�l�Q�h�B����PMg3�=��w� |�����"��:�W:w��H7H���k6�=�n�
              ��ȗ�dVV�G��ұ�Ga��H�2H8�Q�2}i�I��8���F̣�@��Z@��6.'�ϙ����<q�P��/�W����6G֩[��5�i��uˎ2zqǭJ�5��H��;��a��IŲ��d��Ʌ�K��#��iNF9���
              \<rΘe$�bps�$T�m�L$�9@���$�����]���1��#lm�N:ՍN�t�����,�D�(�Ð}�t�qTL�-�>�Um�|��>�|G��t-��D�A���_ʌ6���1�\�E+�/l�ܐ���q��cKuio{lc��f �Cc�Z�ѭ���ز0R�o�����.�9�ޮ�����hlu�i!�$q�bs�`���K��j/��?qa�C����}I�{Vc͒ �ja`pR�����]�"EE�5
              �{jqb_����)�i�p����O���[@%)�2�;�c���(�*�/��$c�c?S���V���J���`���
              ��Y����[I�抹���7���6�{'�{ �t���E'��U|g�j��>H���Ow~?�j¿�����dbA'n��>�w�
              ��'� r���ힸ</�3��ة3�~%�<.w*B�A�����Es�6�a��~��o��|Z���T��Q��b%����~u��q-��r8�j"���Yj��kB{ę�&�>[�P�a�~5D�jg��!1!8\��Ҡ�����%asHMT3^��N����p1����>?Ƽ��}+�<�>���Dxb��z��s~@��+�
              �_���&b���pyƱtچ�{r�4a��p�q��l��<C~t�&�h��������Y��^za�dH��)���zDQW���.o�+�-�OӸ�76�q�����Bܨ��ySR��x��r���)�>�S�}��.G'���\�N���"Kig<r	8dl~��qh ����7jў.��?CYwA�SHͷ����Y��*Hr���G��7���"�l1��X���ǀ��Q�'
              =Mz���.��[���ȋ�S��<��~*7vݑ`K �式"�$��֬�^������\�^=ꭥ�P΋qm�v��_c���j^M��a�97�Ni�ڒFҖ���������AT���66w1��հ����>��z�Ď$��,lϑ�W�'�'�j����B�ɹ���<�f�1԰`���)��*I�=A<U;�%EfX<�S�Z����ӭ[�[keG����c(G*}}��{�&�Β�l~56)NIܮ4���X��n	�G(���maeb�i|�7���1J�н��m�N����q�J�A���	E'2���H�TW��.��	�%���[�
              ���c�b-n��.��m���cW෎�R�r�s:2��9�O�/�17��_;�m��'?²��wE�B����T��Ⲏ'�Ѕ��T{U�-^����b�C��pYs�H�=�H�E?wbw\�:�j�����,V���+Ēv���R�cG]K���ߥ��ysI:��PF��Wo�<�ָ��n�\���%y��WW�Jc��/
              !�����f�ihsb�0�au~�R���3;���p�*�_R�h����O��s���޺�?�`$A
              �A��n�����5��t��̄�<�V��w3~�[Z���Q��A�l�?�ɯS�o��-"�PtE�?�N��E�N+��
              ���O~�䳋j���~�Γ���C�i����H��
              0?��U�^Fo��׷w�����'�r�7������Mg��4I݌Ri:
              niI��R���M1u_��*��2f�z����~5����ۖP��Տ'��?�Q���R�?����������zԉY&m�����d�u_5���G���k�l���|�?� �'�K=�ù�fs����]I;\H��C+� ���(����?t`V�^�5mL�X3J���Z��U�X�����β!
              �{�T�m��r�@�	&[��i��h�����e�He���O��P�s�tSڡn捴�lx;L}K�Q9�,O+����?ʽA��Y���7L������h+4��{��#�����ϡ��p�e7�F	W�,o�$������G
              �J���4��Ztir�*�Zrƣj�K7E\f���A���ؽ�'7@uR6�=�q�ig�[�����Q��{c�&3,��`B�mq��m)./��Zn��(�����01��բ���˩%����%��;��7��֒���FE�А�^A�7�Wo$p,nΠ� z�"�m�].�ݣ�Ь����k��s�4���V�D�kfc����x�Y6�+<<��F�V%w��2H�)�2�4�[F��<�;��O��6��$KfT���q��?Q��͓h�K�A�&F(��Q������"\x��6���݁+�sZZU�MI'�<�ۏM�8��'ZX�>#��V;{L��8�}�:?�O��N�L�e�%�~Qa�@������SF�g��VA!�d��N=j��>n�B��a���Ϲ�jI�R�6�r9�Jf���^�e�D��®{���+W���b�D�2�a��w���e�����*ܙds�Tַ4;&��Mn�?��v����\^��o�ړ�0��YKN�H���;���9�'%���?���^G��(���{実
              �L��"C��l��~$�u�cL��W�K4�&?�����LW��V�����y����^1�o����?:�?������.#R;�S�I�I�g.8�a�p1�T���5��Ե����yK(���)�H�.�sS:S��5���Rb�8�-����+Xt����'�5��3ю����/�h�C��h�g�?�&��t:=7H��/�����U�?���k?Ťɥ4K.�5�q��������Tڃ¨��=��גjw6�e�w�O���UV����k#66/+JW�&�^0r���5�,KHX���c�9}
              Cwfֲ�W-���V�%��,]�pT�Ux��'������4�͞
              �v����K�i��j��($pd>�9c�S�|�s]g������Uu�c�D����?
              {��GXdRw*m\�@(�=��`n�=
              s�pK{�L,�׃���X����=�<���9���9�'���Tv���p�d~m�'�*iev�L��dg#�q�P���	����;�q)F��t�L�|����P��s��\��Y��*�ʕ�O�^ӯ�������%���8��S�J'S,QN�HM˜W5�Mgבmb��#�*�	��O�(�o��7�\�+�Ǧ*
              F�;��@!�z��c�iE[��z��-E��$s�)�X����E��N�1�n$�X-n��h�Td?Ҫ���V32�F��Oj:�b��&]�C����u��-_���ȃ�=Ċn�h��	?�i٬������)�"s��a�\v�򾿫c+Gpb��%I��K��DE^�gH���b7B�W�#�L�z��3c�}��1Z��J�c�?��TFSeۆ����^���摵�$����t3)�aяQ�w��8v�:�A�լ��8fsՉ<����^��Kc���7j�X��-�u_��ya����s���:�<W9
              ���Lf[�fb;�o��OF�~������w�"yЪ���F�D��^+�<jeԢ���l46�5�r>f�J���Î�f���B����sF���j
              ރҖ���
              &���������D���d��?��~u����;x7C�e�O��~5�q��q�'Տ_֧w`3|C�6���4G�������?�'�K�d��n�Q1�����^�<e����~��2}�?��:Ȳ-o��!�����j�K��_�*����,�q$���VM�nX��@�j��2T���'��
              ��5��蕚+����5
              ܠ��Y7���ڲd��Q�psV���O�7pY[�p�5����zͽ�Vv�Y[�"�@�������>����d�a�Ա��}�v����1WD�}�n8�~9��R<�>��+B.�'t53�&�B��{�a�b���]O��`��H�k���Qd��"���y �ޙ�	P\c�����3$)',��{�NSp9>��VD�*�FFv���>`)�"G@an�A��枂1UUF���
              �3Sr�*��W�"���h���t$�Q:��&qS	�d!����}(i�!S^��Zn⍎���WN����I	�t����5�r\ۘ�>e����H�_��R{�Tm�YF����W�x7�}:'>cJ�	���R����M���`L����VЍ��{�z�ҫ;Mu3�L�T�
              ���"�t^�Q�^��%m֖ϙ�OK�=��N�t�r�v򻳒QNûn�n��5;,�c�'�^��k�,���r~�_��zy5��lJ���EnϜ0>����Y��r�!B��=�\V��&Lqz|��W3�K�A
              �����쎟�򮄎C�'�9>�3��9ɮ+Y���ҥ�
              ����MvW�"�1*σ���/����xd?�QZ�ivg'��;d���ִ�D1݀�3@˹N9�QU&���U�;f���2(���Z�����ZҴ���;{$��8�uz��Խ�=/�>��]5�I�rۗ?�/�r]֡{�a5伬\����8i����ColUQ��`��x�QlV��s?�ȿ�O�(�����_�׷ٻn�W2�6����"9�dl �N��tے�r^���N6����H$Ӯ<��]�Jg#�j��;���Ѭ4fL�$cA���E�|�cq��>��NAW�5FQ�����L�$� -�|�P��*����"�M%�yq9@������N�z�=�s�zC\��j3gɱ�W�Ұ����U�D�S��t��m.�O�@�sy��?��ۖ������=j>�h����Ԋ���{{�DЯ<�LE�����L��Fڪ\��ǥ$q�<��ބq��H�[�r@OS�v�;�:{�4|��߻n�<�����1P��SQ
              ����TŘ&��z7j
              J�i�F� �=�@r��Q����9���{��>�h�B�D�[����D���L�B�6�9�⤸x�y�p@`��s��tn;8�5k�m���mʤٸ��<~k�ѡ�L�텴`��uww�#�c�OA]V�%����^0;�?ǵ���}�\ݼ�ܻ_;%��OA��{
              �o�1^H�ղh�K�b�'��iF�|/��Ҝ_��ש�ڣT�� �T)!�y�UX�������}�?�W�	�9����������!^�w!�=
              چ�>/tP�������}+�������������׮�V��&�+�Ď6G����s��t�B#�|�0\�Oj�8LmJ�%������
              �c8�j��V��y������?�;g�m��v2�yR�	�x�29��c�8�j�͓�j��DR6OZ��~}�ڴ����Ϡ���8�pp[Kus�+�Y�"rk��;�Ťh�Z�8}@����Ʊ����B��������R�E&��[���F�@D��e�u��]��o�`�M�w�g��O�o�k�r�R���DST􈖬��=���'p
              L
              �����[9�T/9^Ze�T�s
              �.uU8�U�1����B�����掘ěQՅ���qg��5�qX�7R9�<����M
              JۍH�D�䑂��OA^��i��iPX)ь��ސ���~��'N{��5Y򭲐�}�R>���fs��p]L����Hp�=鞵��͌9�v�ˀP�=�2	#��0*2=���P"ẖ!VX�@��9�gCFFH���"�6]���|Ӵ�•v��r�����K���ƌF
              Ƞ�G��b�Ef��Tp����ӧ���eD���>��?A�#�����D��B������T`�C��H�<��)�����I�4���G�'��i\�����o�K,���X�d�~�nSocY����1�Hf
              �nn?�'�a��"�9�qҮΊX��m����2�L��B�*�
              Ζ����h#���8 �I�\�1Q�H�$p��=�U�)a��{V�]	;1�����Xt#���EI���\L��۸��˸����ۺ��C!<,
              ��i\����v�,R]�����H�x.�Յ�j�[�c��s�M�o��q�+r��Z��|�,+�һ�͔���k=�spd�!�rk���ӵ:�o1��U�o�Q��H�7�7�n6{���1�r*��P�Ă�[��*w!QGv=+3D��ᾇ���=��peT�����^��BF�$�����X�ѓF���:��׹?���U�_~"�M=[k]�?݅~��p?:�+����u�F]F�����������P3Cx�*� ? =	�"�8���[dC�E"���n�C{*ja4�6��ftn{g����{ۘ��.�B1*~n��S�d99⥷�m���	��WD�~k�GRM2��H�G֡6rJ�K�$`������gd%O�V��4���Y�C��?����+pn���lt���>(NV��7R:�?9����g�N{V�Ym��a9b;����;����D��?�0����x�;c��z�t<�i0NAn�Ґ�MFRN���b��t��]��s+�H��z'�(�p����$�t��<�G����ҹ:�����e�B�����Y��1���.Kq��K�� �`����:(��8��EH<�{P+[P{�#��v
              ��O�! �3���W�}��'{}^�Xgp� Edb1�֫���\��yܠ��n�;��;W"4��OQK�ĉ�O4�nb�
              ��=뙷�\��"2]�W?����t�4��C#���#>�?�G#-UOCj{�[��#�pH�#����Ĩ��Ѧs�1���w
              DF%]�Vp2T��d�������y�ȌC��u�T�r��0x�L�X��jH�.̽3Wf_2���[asp�y�p�~u'�]�;[w�4s��0��3�Q���^�9't�q�	��V��j�%`c�L}3��?��WMs����j���v;�j�.'��Wu{�f����p+"./n��K��!G�&����J�+��nu�=�*;���d����N��H�|u�Y������-��\s�x;W����;�\��c|���?�N���?unp�X���+�Eg�Q�1@�OA^���
              tM
              $ y�>f�=X�|}�%��#��JF�$$h�OEP?¼��:��wʤ��8��8��}�]~"�]9_k]e9������?:�y���-�0�|��E��#vA-˼�%��<*֔'�Vm�V�V�c VU67����H�jkuΟx��?�*B��R�1cw�O�
              ��/uz���{)�'KX9�v����u�K���O����G��ǹ>��X>��MVQ����z�o�]dWLS�����z*3�ߍ9�r	�Q���Zpm�	�5��C���O|f���H��P�$�8<S��>ԌN)J��Hy�
              V�H#(%_������>I�bI���R-ۤA"H�_EZF�w��y���q��m���E0¤����8#���"��9�p�Ha�OQ�Q��Mʊ�G\����W�y�w[5��	�
              �c�i\$�>��\��m!g�ߞ���P���>4N�@5UFMt��v�R啅;'��ܽ:Rƪ���2�<�������x0�,C���:�����3��@Z������G�_5c���ΎA�M#�*巈��ڔ��r�\�T���2y5�i�	�q��-�x����ew��ʜ��@�u���c�c��O'ޡ2����3r���=��J�&�a��GQ�����H�'�5��C�ͦi�_�Ƕ��ج9�"8�O_ʹ->����L4hFw���W@�!��2K�4�ߙF���\SFt�Lw�!]"A�ʸ�H21;WU�\ȚJ���|���<��C��8Գ�
              �:�z
              KH��Ϋ�ւڮ�.�\�hs����^��Q�f	k�OEP:�/�t$�t`���3#z��?RMF���ޑ��g������3s8�m���Zב\�f�����cQ;VK�@*۹6��e'uj/��iUa��r�Z�t�d��CH�}L�im�6no��O�YL����v^����^�g��)��~|�ʱ���4[v7#�$�	jv�A&�;�C�]iX�#9��J��NG#d��I'�1
              �$pOQM#��֜A.���
              <����9�?�5��ך8#��HXq�:R����Y��S���V�J��Kr���g�4g�D���\
              ��=t%����D��<9��Vy��g_5�M���"�.-�ꊯ����w_��)9S�h�늸�̈��#���r�ۊ����RLN�f}�fr�e
              T�$08�*�V�M�$E�m�g����Ҭ[\[���ʍ�ǧC@����}�nq TJ|��8=�UY|;r�;�i6�g$s�V����$K"��
              ��q�u�>��<Ѭ3K��^26zuǭeC�Q�C��[h�fO.GY$�$t�����{�f�?s[�K�bl�
              ��s�7�!s���B�V9g�z���$[�
              �����p
              i��?������e�;HOx�,e���D2��Ԩ�>�햰[��Gki
              �C������"�j�Wƞ����za[[�hv��xtQ��y�yԩx�9R5�SF�.���a<t��sNc��<��	��Mo|9����W�g�>����EdI��#��i%�j/�'��/��:��[o���=���6ݹB�jjM4V�I4�#�,�����^��R�p�l�DM0?��!��e�F}�=��o$�"9��
              X�Ʈr8#���������%����� �dR��h�x$U�u�a&�|�+:�)"�Ur�0>�=b�o�
              iGW�Dr/�%��}��U��s"�UmL]K���l=��s��*����:�u����М�Ɩ��Q����#�Lc����d7��O�2})����s�Ll��ϵ?���q���?`0�w�:�%q����za;[#��f���ž���UP1�p:փ����ef5���u?��\*���%e����sܶ�Y�#.#���t�b;d�g����c�V���9;��>��\V�3�n��������[���ܣve͌�H��֑�9�i�}jو��b���9�j;R��1[�*FW?�v/J�n'P�.�]�#��_�I�������
              >�rݓ��pA>&*F����qU^��G'w�����=�'��6R6���;�Ztvډ������9�w����p�x�A��7��x ��|���7iZ��	��K��H^pq��&R��<#���ػe�6`���'�~5�^]�ag-���p�v��z��TM�XX�j�,3����~���
              |��X�����>�%wr��K[������U��v��\�O��s��y���Ս\��Fbf�+���Սeʤ7��IhJ-Ox�GJx��|c�jX�N	�8̇���]�lR�N� �gm�a��V�?�rz~�s��p����i����ߕz���6p�Z&�{t	�z�s֣q�Y�׭B~��5!䚉����4�C��O �J��)�쎽���S��)p�����6�8�<�A,Si���n8�4������\qh�jS��e��8�̼�yAܧ�#�+ϯ.~�quu���3��+����3�\� O���9Q�U�F�osJ� �<Uc��*�� �32e`��Xb�r���):��&��%���.�V�����P�E?�g�|��U$��,Ed��t��v_��C�0�?����d��� �3�o�*��c�O���l.�M�*��eu�-��A���V��x������O��s��iE���x���Y�)F�?��9;�Ҹ
              �&�����Ukk_���ڃ,}=\�O�ۑ��1����'�M�A������Z�����ɭ[�3rw*j���`�if; RG��n���W-x�,��(��w����kKV�k�^Pr#�ck��M���
              ���4����)�0Z~�JL�/.\}���ԫs��f�����g���U6�"���UrjM���b�5<i����Uj=N-��ڌz+�eg5��[]g��Ad�f��z6p��MO�����ge���OK��`��P\F1���\SH�S��Hx�#[<zf�pG��<♓��`'F �L#��9�9lr4�19�Cd=�~)�`Cq����Ll�u�@��
              als Ergänzung
              mqtt läuft im docker auf dem Unraid und im iobroker als client
              • Wal
                @crunchip ,
                was hast du für eine Version installiert, da er diese Datenpunkte nicht mehr erstellen sollte ?
                Installiere mal über Github.
                  @wal ganz normal aus dem Repo
                  hab ich, allerdings bekomm ich dieses, der Adapter stürzt kontinuierlich ab
                  host.IoBroker
                  2023-11-26 22:13:16.866	info	Restart adapter system.adapter.frigate.0 because enabled
                  host.IoBroker
                  2023-11-26 22:13:16.865	error	instance system.adapter.frigate.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                  frigate.0
                  2023-11-26 22:13:16.371	info	terminating
                  frigate.0
                  2023-11-26 22:13:15.867	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                  frigate.0
                  2023-11-26 22:13:15.864	info	terminating
                  frigate.0
                  2023-11-26 22:13:15.822	error	Cannot read properties of null (reading 'val')
                  frigate.0
                  2023-11-26 22:13:15.820	error	TypeError: Cannot read properties of null (reading 'val') at Frigate.onEventChange (/opt/iobroker/node_modules/iobroker.frigate/main.js:322:39)
                  frigate.0
                  2023-11-26 22:13:15.818	error	unhandled promise rejection: Cannot read properties of null (reading 'val')
                  frigate.0
                  2023-11-26 22:13:15.816	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                  frigate.0
                  2023-11-26 22:13:01.160	info	MQTT Frigate URL: http://10.1.1.219:5000
                  frigate.0
                  2023-11-26 22:13:01.158	info	MQTT Frigate Object: mqtt.0.frigate
                  frigate.0
                  2023-11-26 22:13:01.117	info	starting. Version 0.2.6 (non-npm: Bettman66/ioBroker.frigate) in /opt/iobroker/node_modules/iobroker.frigate, node: v18.18.2, js-controller: 5.0.16
                  host.IoBroker
                  2023-11-26 22:12:56.755	info	instance system.adapter.frigate.0 started with pid 3318229
                  host.IoBroker
                  2023-11-26 22:12:55.635	info	"system.adapter.frigate.0" enabled
                  host.IoBroker
                  2023-11-26 22:12:51.255	info	"system.adapter.frigate.0" disabled
                  diese Datenpunkte/Fehlermeldungen sind zwar jetzt weg, dafür fehlt mir jetzt eine Cam
                  4 waren eingebunden, es tauchen aber nur noch 3 in den Objekte auf und Adapter stürzt immer wieder ab
                  hab auch nochmal gelöscht und per Github Link installiert, brachte den selben Fehler aber die 4 cam ist nach wie vor nicht da, in den mqtt Objekten ist sie aber vorhanden
                  • Wal
                    @crunchip ,
                    schalte den frigate Adapter mal in den Debugmodus und poste bitte den Log.
                      @wal
                      2023-11-27 10:48:00.049 - info: host.IoBroker "system.adapter.frigate.0" enabled
                      2023-11-27 10:48:01.164 - info: host.IoBroker instance system.adapter.frigate.0 started with pid 3603597
                      2023-11-27 10:48:02.353 - debug: frigate.0 (3603597) Redis Objects: Use Redis connection: 127.0.0.1:9001
                      2023-11-27 10:48:02.444 - debug: frigate.0 (3603597) Objects client ready ... initialize now
                      2023-11-27 10:48:02.484 - debug: frigate.0 (3603597) Objects create System PubSub Client
                      2023-11-27 10:48:02.486 - debug: frigate.0 (3603597) Objects create User PubSub Client
                      2023-11-27 10:48:02.865 - debug: frigate.0 (3603597) Objects client initialize lua scripts
                      2023-11-27 10:48:02.872 - debug: frigate.0 (3603597) Objects connected to redis: 127.0.0.1:9001
                      2023-11-27 10:48:02.978 - debug: frigate.0 (3603597) Redis States: Use Redis connection: 127.0.0.1:9000
                      2023-11-27 10:48:03.075 - debug: frigate.0 (3603597) States create System PubSub Client
                      2023-11-27 10:48:03.078 - debug: frigate.0 (3603597) States create User PubSub Client
                      2023-11-27 10:48:03.463 - debug: frigate.0 (3603597) States connected to redis: 127.0.0.1:9000
                      2023-11-27 10:48:05.530 - info: frigate.0 (3603597) starting. Version 0.2.6 (non-npm: Bettman66/ioBroker.frigate#7062e2ceb9142495619cb210daf0190bd87dbfe4) in /opt/iobroker/node_modules/iobroker.frigate, node: v18.18.2, js-controller: 5.0.16
                      2023-11-27 10:48:05.569 - info: frigate.0 (3603597) MQTT Frigate Object: mqtt.0.frigate
                      2023-11-27 10:48:05.572 - info: frigate.0 (3603597) MQTT Frigate URL: http://10.1.1.219:5000/
                      2023-11-27 10:48:18.156 - debug: frigate.0 (3603597) id: mqtt.0.frigate.stats changed: {"Haustuer": {"camera_fps": 5.1, "process_fps": 5.0, "skipped_fps": 0.0, "detection_fps": 4.5, "detection_enabled": 1, "pid": 731, "capture_pid": 737, "ffmpeg_pid": 742}, "Terrasse": {"camera_fps": 5.0, "process_fps": 5.1, "skipped_fps": 0.0, "detection_fps": 0.0, "detection_enabled": 1, "pid": 733, "capture_pid": 740, "ffmpeg_pid": 750}, "Schlafzimmer": {"camera_fps": 5.1, "process_fps": 5.1, "skipped_fps": 0.0, "detection_fps": 0.1, "detection_enabled": 1, "pid": 734, "capture_pid": 745, "ffmpeg_pid": 754}, "Buero": {"camera_fps": 5.1, "process_fps": 5.1, "skipped_fps": 0.0, "detection_fps": 1.1, "detection_enabled": 1, "pid": 735, "capture_pid": 753, "ffmpeg_pid": 761}, "detectors": {"cpu1": {"inference_speed": 35.03, "detection_start": 0.0, "pid": 720}, "cpu2": {"inference_speed": 32.76, "detection_start": 0.0, "pid": 722}, "cpu3": {"inference_speed": 36.27, "detection_start": 1701078493.863862, "pid": 724}, "cpu4": {"inference_speed": 34.9, "detection_start": 0.0, "pid": 726}}, "detection_fps": 5.7, "gpu_usages": {"amd-vaapi": {"gpu": "1.67 %", "mem": "53.87 %"}}, "cpu_usages": {"top": {"cpu": "users,", "mem": "load"}, "Tasks:": {"cpu": "stopped,", "mem": "0"}, "%Cpu(s):": {"cpu": "id,", "mem": "0.2"}, "MiB": {"cpu": "24378.4", "mem": "avail"}, "PID": {"cpu": "%CPU", "mem": "%MEM"}, "722": {"cpu": "8.0", "mem": "0.4"}, "731": {"cpu": "6.3", "mem": "0.5"}, "745": {"cpu": "2.7", "mem": "0.3"}, "754": {"cpu": "3.3", "mem": "0.4"}, "1": {"cpu": "0.0", "mem": "0.0"}, "15": {"cpu": "0.0", "mem": "0.0"}, "17": {"cpu": "0.0", "mem": "0.0"}, "24": {"cpu": "0.0", "mem": "0.0"}, "25": {"cpu": "0.0", "mem": "0.0"}, "26": {"cpu": "0.0", "mem": "0.0"}, "27": {"cpu": "0.0", "mem": "0.0"}, "28": {"cpu": "0.0", "mem": "0.0"}, "29": {"cpu": "0.0", "mem": "0.0"}, "30": {"cpu": "0.0", "mem": "0.0"}, "31": {"cpu": "0.0", "mem": "0.0"}, "32": {"cpu": "0.0", "mem": "0.0"}, "41": {"cpu": "0.0", "mem": "0.0"}, "42": {"cpu": "0.0", "mem": "0.0"}, "80": {"cpu": "0.0", "mem": "0.0"}, "81": {"cpu": "0.0", "mem": "0.0"}, "82": {"cpu": "0.0", "mem": "0.0"}, "88": {"cpu": "0.0", "mem": "0.1"}, "97": {"cpu": "0.0", "mem": "0.0"}, "98": {"cpu": "2.0", "mem": "0.8"}, "113": {"cpu": "0.0", "mem": "0.0"}, "134": {"cpu": "0.0", "mem": "0.0"}, "135": {"cpu": "0.0", "mem": "0.0"}, "136": {"cpu": "0.0", "mem": "0.0"}, "137": {"cpu": "0.0", "mem": "0.0"}, "138": {"cpu": "0.0", "mem": "0.0"}, "143": {"cpu": "0.0", "mem": "0.0"}, "160": {"cpu": "0.0", "mem": "0.0"}, "191": {"cpu": "0.0", "mem": "0.0"}, "232": {"cpu": "0.0", "mem": "0.1"}, "267": {"cpu": "0.0", "mem": "0.0"}, "314": {"cpu": "0.0", "mem": "0.0"}, "358": {"cpu": "0.0", "mem": "0.0"}, "392": {"cpu": "0.0", "mem": "0.0"}, "419": {"cpu": "0.0", "mem": "0.0"}, "441": {"cpu": "0.0", "mem": "0.0"}, "483": {"cpu": "0.0", "mem": "0.0"}, "713": {"cpu": "0.0", "mem": "0.3"}, "719": {"cpu": "0.0", "mem": "0.0"}, "720": {"cpu": "8.0", "mem": "0.4"}, "724": {"cpu": "8.0", "mem": "0.4"}, "726": {"cpu": "12.0", "mem": "0.4"}, "728": {"cpu": "1.3", "mem": "0.3"}, "732": {"cpu": "0.0", "mem": "0.1"}, "733": {"cpu": "0.7", "mem": "0.5"}, "734": {"cpu": "0.3", "mem": "0.4"}, "735": {"cpu": "0.7", "mem": "0.5"}, "736": {"cpu": "0.0", "mem": "0.1"}, "737": {"cpu": "2.7", "mem": "0.3"}, "740": {"cpu": "3.0", "mem": "0.3"}, "741": {"cpu": "0.0", "mem": "0.1"}, "742": {"cpu": "4.3", "mem": "0.4"}, "750": {"cpu": "3.3", "mem": "0.4"}, "751": {"cpu": "0.0", "mem": "0.1"}, "752": {"cpu": "0.3", "mem": "0.1"}, "753": {"cpu": "3.0", "mem": "0.3"}, "761": {"cpu": "4.3", "mem": "0.4"}, "762": {"cpu": "0.7", "mem": "0.1"}, "763": {"cpu": "0.0", "mem": "0.1"}, "772": {"cpu": "0.3", "mem": "0.1"}, "11808": {"cpu": "0.0", "mem": "0.0"}, "11836": {"cpu": "0.0", "mem": "0.0"}, "11838": {"cpu": "0.0", "mem": "0.0"}}, "service": {"uptime": 22069, "version": "0.12.1-367d724", "latest_version": "0.12.1", "storage": {"/media/frigate/recordings": {"total": 5024751.3, "used": 182616.8, "free": 4837359.0, "mount_type": "fuse.shfs"}, "/media/frigate/clips": {"total": 5024751.3, "used": 182616.8, "free": 4837359.0, "mount_type": "fuse.shfs"}, "/tmp/cache": {"total": 1000.0, "used": 2.6, "free": 997.4, "mount_type": "tmpfs"}, "/dev/shm": {"total": 268.4, "used": 14.5, "free": 253.9, "mount_type": "tmpfs"}}, "temperatures": {}, "last_updated": 1701078498}} (ack = false)
                      2023-11-27 10:48:18.159 - debug: frigate.0 (3603597) changed: {"Haustuer": {"camera_fps": 5.1, "process_fps": 5.0, "skipped_fps": 0.0, "detection_fps": 4.5, "detection_enabled": 1, "pid": 731, "capture_pid": 737, "ffmpeg_pid": 742}, "Terrasse": {"camera_fps": 5.0, "process_fps": 5.1, "skipped_fps": 0.0, "detection_fps": 0.0, "detection_enabled": 1, "pid": 733, "capture_pid": 740, "ffmpeg_pid": 750}, "Schlafzimmer": {"camera_fps": 5.1, "process_fps": 5.1, "skipped_fps": 0.0, "detection_fps": 0.1, "detection_enabled": 1, "pid": 734, "capture_pid": 745, "ffmpeg_pid": 754}, "Buero": {"camera_fps": 5.1, "process_fps": 5.1, "skipped_fps": 0.0, "detection_fps": 1.1, "detection_enabled": 1, "pid": 735, "capture_pid": 753, "ffmpeg_pid": 761}, "detectors": {"cpu1": {"inference_speed": 35.03, "detection_start": 0.0, "pid": 720}, "cpu2": {"inference_speed": 32.76, "detection_start": 0.0, "pid": 722}, "cpu3": {"inference_speed": 36.27, "detection_start": 1701078493.863862, "pid": 724}, "cpu4": {"inference_speed": 34.9, "detection_start": 0.0, "pid": 726}}, "detection_fps": 5.7, "gpu_usages": {"amd-vaapi": {"gpu": "1.67 %", "mem": "53.87 %"}}, "cpu_usages": {"top": {"cpu": "users,", "mem": "load"}, "Tasks:": {"cpu": "stopped,", "mem": "0"}, "%Cpu(s):": {"cpu": "id,", "mem": "0.2"}, "MiB": {"cpu": "24378.4", "mem": "avail"}, "PID": {"cpu": "%CPU", "mem": "%MEM"}, "722": {"cpu": "8.0", "mem": "0.4"}, "731": {"cpu": "6.3", "mem": "0.5"}, "745": {"cpu": "2.7", "mem": "0.3"}, "754": {"cpu": "3.3", "mem": "0.4"}, "1": {"cpu": "0.0", "mem": "0.0"}, "15": {"cpu": "0.0", "mem": "0.0"}, "17": {"cpu": "0.0", "mem": "0.0"}, "24": {"cpu": "0.0", "mem": "0.0"}, "25": {"cpu": "0.0", "mem": "0.0"}, "26": {"cpu": "0.0", "mem": "0.0"}, "27": {"cpu": "0.0", "mem": "0.0"}, "28": {"cpu": "0.0", "mem": "0.0"}, "29": {"cpu": "0.0", "mem": "0.0"}, "30": {"cpu": "0.0", "mem": "0.0"}, "31": {"cpu": "0.0", "mem": "0.0"}, "32": {"cpu": "0.0", "mem": "0.0"}, "41": {"cpu": "0.0", "mem": "0.0"}, "42": {"cpu": "0.0", "mem": "0.0"}, "80": {"cpu": "0.0", "mem": "0.0"}, "81": {"cpu": "0.0", "mem": "0.0"}, "82": {"cpu": "0.0", "mem": "0.0"}, "88": {"cpu": "0.0", "mem": "0.1"}, "97": {"cpu": "0.0", "mem": "0.0"}, "98": {"cpu": "2.0", "mem": "0.8"}, "113": {"cpu": "0.0", "mem": "0.0"}, "134": {"cpu": "0.0", "mem": "0.0"}, "135": {"cpu": "0.0", "mem": "0.0"}, "136": {"cpu": "0.0", "mem": "0.0"}, "137": {"cpu": "0.0", "mem": "0.0"}, "138": {"cpu": "0.0", "mem": "0.0"}, "143": {"cpu": "0.0", "mem": "0.0"}, "160": {"cpu": "0.0", "mem": "0.0"}, "191": {"cpu": "0.0", "mem": "0.0"}, "232": {"cpu": "0.0", "mem": "0.1"}, "267": {"cpu": "0.0", "mem": "0.0"}, "314": {"cpu": "0.0", "mem": "0.0"}, "358": {"cpu": "0.0", "mem": "0.0"}, "392": {"cpu": "0.0", "mem": "0.0"}, "419": {"cpu": "0.0", "mem": "0.0"}, "441": {"cpu": "0.0", "mem": "0.0"}, "483": {"cpu": "0.0", "mem": "0.0"}, "713": {"cpu": "0.0", "mem": "0.3"}, "719": {"cpu": "0.0", "mem": "0.0"}, "720": {"cpu": "8.0", "mem": "0.4"}, "724": {"cpu": "8.0", "mem": "0.4"}, "726": {"cpu": "12.0", "mem": "0.4"}, "728": {"cpu": "1.3", "mem": "0.3"}, "732": {"cpu": "0.0", "mem": "0.1"}, "733": {"cpu": "0.7", "mem": "0.5"}, "734": {"cpu": "0.3", "mem": "0.4"}, "735": {"cpu": "0.7", "mem": "0.5"}, "736": {"cpu": "0.0", "mem": "0.1"}, "737": {"cpu": "2.7", "mem": "0.3"}, "740": {"cpu": "3.0", "mem": "0.3"}, "741": {"cpu": "0.0", "mem": "0.1"}, "742": {"cpu": "4.3", "mem": "0.4"}, "750": {"cpu": "3.3", "mem": "0.4"}, "751": {"cpu": "0.0", "mem": "0.1"}, "752": {"cpu": "0.3", "mem": "0.1"}, "753": {"cpu": "3.0", "mem": "0.3"}, "761": {"cpu": "4.3", "mem": "0.4"}, "762": {"cpu": "0.7", "mem": "0.1"}, "763": {"cpu": "0.0", "mem": "0.1"}, "772": {"cpu": "0.3", "mem": "0.1"}, "11808": {"cpu": "0.0", "mem": "0.0"}, "11836": {"cpu": "0.0", "mem": "0.0"}, "11838": {"cpu": "0.0", "mem": "0.0"}}, "service": {"uptime": 22069, "version": "0.12.1-367d724", "latest_version": "0.12.1", "storage": {"/media/frigate/recordings": {"total": 5024751.3, "used": 182616.8, "free": 4837359.0, "mount_type": "fuse.shfs"}, "/media/frigate/clips": {"total": 5024751.3, "used": 182616.8, "free": 4837359.0, "mount_type": "fuse.shfs"}, "/tmp/cache": {"total": 1000.0, "used": 2.6, "free": 997.4, "mount_type": "tmpfs"}, "/dev/shm": {"total": 268.4, "used": 14.5, "free": 253.9, "mount_type": "tmpfs"}}, "temperatures": {}, "last_updated": 1701078498}}
                      2023-11-27 10:48:18.161 - debug: frigate.0 (3603597) {"total":5024751.3,"used":182616.8,"free":4837359,"mount_type":"fuse.shfs"}
                      2023-11-27 10:48:18.425 - debug: frigate.0 (3603597) {"total":5024751.3,"used":182616.8,"free":4837359,"mount_type":"fuse.shfs"}
                      2023-11-27 10:48:18.609 - debug: frigate.0 (3603597) {"total":1000,"used":2.6,"free":997.4,"mount_type":"tmpfs"}
                      2023-11-27 10:48:18.709 - debug: frigate.0 (3603597) {"total":268.4,"used":14.5,"free":253.9,"mount_type":"tmpfs"}
                      2023-11-27 10:48:24.116 - debug: frigate.0 (3603597) id: mqtt.0.frigate.Terrasse.motion changed: ON (ack = false)
                      2023-11-27 10:48:24.121 - debug: frigate.0 (3603597) onObjectChange -> id: mqtt.0.frigate.Terrasse.motion changed: ON (ack = false)
                      2023-11-27 10:48:24.123 - debug: frigate.0 (3603597) Object available: [object Object] type: string
                      2023-11-27 10:48:33.858 - debug: frigate.0 (3603597) id: mqtt.0.frigate.Schlafzimmer.motion changed: OFF (ack = false)
                      2023-11-27 10:48:33.863 - debug: frigate.0 (3603597) onObjectChange -> id: mqtt.0.frigate.Schlafzimmer.motion changed: OFF (ack = false)
                      2023-11-27 10:48:33.865 - debug: frigate.0 (3603597) Object available: [object Object] type: string
                      2023-11-27 10:48:56.056 - debug: frigate.0 (3603597) id: mqtt.0.frigate.events changed: {"before": {"id": "1701078201.815111-ch00l6", "camera": "Buero", "frame_time": 1701078483.19947, "snapshot_time": 1701078422.014361, "label": "person", "sub_label": null, "top_score": 0.84375, "false_positive": false, "start_time": 1701078201.815111, "end_time": null, "score": 0.75390625, "box": [407, 281, 943, 850], "area": 304984, "ratio": 0.9420035149384886, "region": [301, 211, 1001, 911], "stationary": true, "motionless_count": 1398, "position_changes": 1, "current_zones": [], "entered_zones": [], "has_clip": true, "has_snapshot": false}, "after": {"id": "1701078201.815111-ch00l6", "camera": "Buero", "frame_time": 1701078535.798322, "snapshot_time": 1701078535.798322, "label": "person", "sub_label": null, "top_score": 0.84375, "false_positive": false, "start_time": 1701078201.815111, "end_time": null, "score": 0.84375, "box": [417, 245, 897, 810], "area": 271200, "ratio": 0.8495575221238938, "region": [168, 32, 1216, 1080], "stationary": true, "motionless_count": 1661, "position_changes": 1, "current_zones": [], "entered_zones": [], "has_clip": true, "has_snapshot": false}, "type": "update"} (ack = false)
                      2023-11-27 10:48:56.063 - error: frigate.0 (3603597) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                      2023-11-27 10:48:56.065 - error: frigate.0 (3603597) unhandled promise rejection: Cannot read properties of null (reading 'val')
                      2023-11-27 10:48:56.066 - error: frigate.0 (3603597) TypeError: Cannot read properties of null (reading 'val')
                      2023-11-27 10:48:56.067 - error: frigate.0 (3603597) Cannot read properties of null (reading 'val')
                      2023-11-27 10:48:56.071 - info: frigate.0 (3603597) terminating
                      2023-11-27 10:48:56.073 - warn: frigate.0 (3603597) Terminated (UNCAUGHT_EXCEPTION): Without reason
                      2023-11-27 10:48:56.576 - info: frigate.0 (3603597) terminating
                      2023-11-27 10:48:56.896 - error: host.IoBroker instance system.adapter.frigate.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                      2023-11-27 10:48:56.897 - info: host.IoBroker Restart adapter system.adapter.frigate.0 because enabled
                      2023-11-27 10:49:27.317 - info: host.IoBroker instance system.adapter.frigate.0 started with pid 3604227
                      2023-11-27 10:49:28.609 - debug: frigate.0 (3604227) Redis Objects: Use Redis connection: 127.0.0.1:9001
                      2023-11-27 10:49:28.711 - debug: frigate.0 (3604227) Objects client ready ... initialize now
                      2023-11-27 10:49:28.714 - debug: frigate.0 (3604227) Objects create System PubSub Client
                      2023-11-27 10:49:28.716 - debug: frigate.0 (3604227) Objects create User PubSub Client
                      2023-11-27 10:49:28.885 - debug: frigate.0 (3604227) Objects client initialize lua scripts
                      2023-11-27 10:49:28.892 - debug: frigate.0 (3604227) Objects connected to redis: 127.0.0.1:9001
                      2023-11-27 10:49:28.999 - debug: frigate.0 (3604227) Redis States: Use Redis connection: 127.0.0.1:9000
                      2023-11-27 10:49:29.133 - debug: frigate.0 (3604227) States create System PubSub Client
                      2023-11-27 10:49:29.135 - debug: frigate.0 (3604227) States create User PubSub Client
                      2023-11-27 10:49:29.481 - debug: frigate.0 (3604227) States connected to redis: 127.0.0.1:9000
                      2023-11-27 10:49:31.782 - info: frigate.0 (3604227) starting. Version 0.2.6 (non-npm: Bettman66/ioBroker.frigate#7062e2ceb9142495619cb210daf0190bd87dbfe4) in
                      Wal 2 Replies Last reply Reply Quote 0
                      • Wal
                        Wal Developer @crunchip last edited by
                        @crunchip ,
                        danke ich kann den Fehler nachvollziehen, ich kümmere mich drum.
                        • Wal
                          Wal Developer @crunchip last edited by Wal
                          @crunchip ,
                          schau mal ob es bei dir die Objekte "frigate.0.Buero.snapshots.state" und "frigate.0.Buero.recordings.state" gibt und der Wert muss Boolean sein.
                          Hintergrund:
                          Wenn ich dein Json eingebe ohne das es die Objekte gibt, bekomme ich den Error.
                          Ändere ich den Kameranamen in deinem Json in einem von meinen Kameras, bekomme ich kein Error.
                            @wal irgendwie fehl da einiges
                            komisch ist aber, als ich zuerst direkt aus dem Repo installiert hatte, gab es diesbezüglich kein Fehler und alle Datenpunkte waren vorhanden
                              martinschm last edited by
                              Hi @Wal
                              Mir ist aufgefallen, das hier in der URL zweimal ein "/" vorkommt und die URL daher nicht funktioniert
                              Liegt das an Frigate oder kommt das aus dem Adapter ?
                              • Wal
                                Wal Developer @martinschm last edited by
                                @martinschm sagte in Test Frigate Adapter 0.2.5:
                                Schau mal in der Adapter Config, da hast du bestimmt bei Frigate Url ein "/" am Ende stehen.
                                  martinschm @Wal last edited by
                                  @wal said in Test Frigate Adapter 0.2.5:
                                  Eigentlich nicht. Sieht bei mir so aus
                                  • Wal
                                    Wal Developer @martinschm last edited by Wal
                                    @martinschm ,
                                    das wäre so richtig, ich schaue nochmal drüber an was es liegen könnte.
                                    Edit: sehe gerade das ich das auch habe, aber die Links funktionieren bei mir.
                                    Du hast quasi ein Bug gefunden.👍
                                    Edit: Installiere nochmal über Github, müsste jetzt funktionieren.
                                    crunchip 1 Reply Last reply Reply Quote 1
                                      • hab ich jetzt auch mal
                                      • Links haben noch den //, funktionieren aber
                                      zum besagten Fehler, der blieb bzw war einmalig beim Neustart des Adapters.
                                      • ich hatte zwischenzeitlich in der Gui sämtliche toogle mal de/aktiviert und bin auch mal vor jede cam gelaufen, dadurch tauchten auch sämtliche Datenpunkte nun auf.
                                      • Ein anschließender Neustart des Adapters verursachte dann keinen Fehler mehr.
                                      • hab den Adapter gestoppt
                                      • im Objektbaum mal alle Datenpunkte gelöscht und Adapter neu gestartet
                                      • nur frigate.0.stats wurde angelegt, der Rest blieb aus
                                      • Bewegung vor der cam, erschien frigate.0.Buero.motion aber sonst wird nichts angelegt auch nach längerem warten
                                      • Neustart des mqtt Adapters und zack, sind alle Datenpunkte unter frigate.0 vorhanden
                                      • Neustart des frigate Adapters kein Fehler mehr
                                      Schlussfolgerung
                                      Timing / mqtt Adapter Problem(falsche Einstellung)?
                                      • Wal
                                        @crunchip sagte in Test Frigate Adapter 0.2.5:
                                        Ja habe ich auch so jetzt festgestellt. Werden die Datenpunkte im MQTT Adapter schon erstellt ohne das der Frigate Adapter läuft, gibt es danach ein Problem.
                                        Ich muss beim erstellen oder starten der Frigate Instanz erst alle Datenpunkte aus dem MQTT Adapter auslesen, damit die Objekte synchron sind oder ich muss einen eigenen MQTT Server einbauen was aber wieder einen neuen Port bedeutet. Mal sehen wie ich das mache.
                                        crunchip MartinP 2 Replies Last reply Reply Quote 0
                                        • Wal
                                          @crunchip ,
                                          habe eine Lösung gefunden.
                                          Ich fange den Fehler ab und bringe im Log eine Meldung den MQTT Broker neu zu starten.
                                          Kannst du das mal testen ?
                                          Einmal Github bitte.
                                            ja und die waren ja bei meinem Test nach wie vor vorhanden im mqtt Adapter
                                            kann ich machen, also
                                            • frigate Adapter stoppen, Objekte löschen, von git installieren und danach starten?
                                            • oder soll ich mqtt auch noch mal löschen?
                                            Wal 1 Reply Last reply Reply Quote 1
                                            367
                                            98846
