    4. Frigate Adapter für ioBroker
      crunchip Forum Testing Most Active last edited by crunchip
      @wal das kommt für alle Cams die ich angelegt hab und halt bei jedem Ereignis im log
      EDIT:
      hab jetzt nochmal alle Datenpunkte gelöscht und neu anlegen lassen
      frigate.0
      2023-11-26 09:54:39.893	info	MQTT Frigate URL: http://localhost:5000
      frigate.0
      2023-11-26 09:54:39.891	info	MQTT Frigate Object: mqtt.0.frigate
      frigate.0
      2023-11-26 09:54:39.846	info	starting. Version 0.2.6 in /opt/iobroker/node_modules/iobroker.frigate, node: v18.18.2, js-controller: 5.0.16
      frigate.0
      2023-11-26 09:54:32.649	info	terminating
      frigate.0
      2023-11-26 09:54:32.146	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      frigate.0
      2023-11-26 09:54:32.144	info	terminating
      frigate.0
      2023-11-26 09:54:32.142	info	Got terminate signal TERMINATE_YOURSELF
      frigate.0
      2023-11-26 09:54:15.600	warn	State "frigate.0.uptime" has no existing object, this might lead to an error in future versions
      frigate.0
      2023-11-26 09:54:15.599	warn	State "frigate.0.latest_version" has no existing object, this might lead to an error in future versions
      frigate.0
      2023-11-26 09:54:15.597	warn	State "frigate.0.version" has no existing object, this might lead to an error in future versions
      frigate.0
      2023-11-26 09:54:15.556	warn	State "frigate.0.available" has no existing object, this might lead to an error in future versions
      sobald ich nen toggle Button in der Gui drücke
      frigate.0
      2023-11-26 09:56:17.120	info	State value to set for "frigate.0.Buero.person.snapshot" has to be type "boolean" but received type "string"
      frigate.0
      2023-11-26 09:56:06.850	info	State value to set for "frigate.0.Buero.person.snapshot" has to be type "boolean" but received type "string"
      Bewegung erkannt
      frigate.0
      2023-11-26 09:59:41.993	info	State value to set for "frigate.0.Terrasse.person.snapshot" has to be type "boolean" but received type "string"
      frigate.0
      2023-11-26 09:59:29.054	info	State value to set for "frigate.0.Terrasse.person.snapshot" has to be type "boolean" but received type "string"
      frigate.0
      2023-11-26 09:59:28.937	warn	This object will not be created in future versions. Please report this to the developer.
      frigate.0
      2023-11-26 09:59:28.930	warn	Object frigate.0.Terrasse.person.snapshot is invalid: Default value has to be type "boolean" but received type "string"
      docker auf unraid
      System 0.12.1-367d724
      Beispieldatenpunkt
        "type": "state",
        "common": {
          "name": "Terrasse.person.snapshot",
          "type": "boolean",
          "role": "value",
          "read": true,
          "write": false,
          "def": "����\u0000\u0010JFIF\u0000\u0001\u0001\u0000\u0000\u0001\u0000\u0001\u0000\u0000��\u0000C\u0000\n\u0007\u0007\b\u0007\u0006\n\b\b\b\u000b\n\n\u000b\u000e\u0018\u0010\u000e\r\r\u000e\u001d\u0015\u0016\u0011\u0018#\u001f%$\"\u001f\"!&+7/&)4)!\"0A149;>>>%.DIC<H7=>;��\u0000C\u0001\n\u000b\u000b\u000e\r\u000e\u001c\u0010\u0010\u001c;(\"(;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;��\u0000\u0011\b\u0001\u000e\u0001\u000e\u0003\u0001\"\u0000\u0002\u0011\u0001\u0003\u0011\u0001��\u0000\u001f\u0000\u0000\u0001\u0005\u0001\u0001\u0001\u0001\u0001\u0001\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0001\u0002\u0003\u0004\u0005\u0006\u0007\b\t\n\u000b��\u0000�\u0010\u0000\u0002\u0001\u0003\u0003\u0002\u0004\u0003\u0005\u0005\u0004\u0004\u0000\u0000\u0001}\u0001\u0002\u0003\u0000\u0004\u0011\u0005\u0012!1A\u0006\u0013Qa\u0007\"q\u00142���\b#B��\u0015R��$3br�\t\n\u0016\u0017\u0018\u0019\u001a%&'()*456789:CDEFGHIJSTUVWXYZcdefghijstuvwxyz���������������������������������������������������������������������������\u0000\u001f\u0001\u0000\u0003\u0001\u0001\u0001\u0001\u0001\u0001\u0001\u0001\u0001\u0000\u0000\u0000\u0000\u0000\u0000\u0001\u0002\u0003\u0004\u0005\u0006\u0007\b\t\n\u000b��\u0000�\u0011\u0000\u0002\u0001\u0002\u0004\u0004\u0003\u0004\u0007\u0005\u0004\u0004\u0000\u0001\u0002w\u0000\u0001\u0002\u0003\u0011\u0004\u0005!1\u0006\u0012AQ\u0007aq\u0013\"2�\b\u0014B����\t#3R�\u0015br�\n\u0016$4�%�\u0017\u0018\u0019\u001a&'()*56789:CDEFGHIJSTUVWXYZcdefghijstuvwxyz��������������������������������������������������������������������������\u0000\f\u0003\u0001\u0000\u0002\u0011\u0003\u0011\u0000?\u0000��~\b��<\u001f�k+����\u0016�4pB�6�.�7��'n9\u0000}�g�\u001b�\u0007��?��nmH\u0018��!.� \u0003DÑ�\\�����}VAg���\u000fsj�SE\u0018\u0001r\u0019pO��\b�\u0007�:�\u001b�=\u0002�V��Y�\u0017\u0010��\u0002d);�\u001f��~��8��7Qe_\rxA%�\u0002}�y�i|�I}�h�\u0012\u0001�=2\u000f\u0019��-�={z\\Ÿ�&ح�\f����\u0003�s�\fv�i���|?�y&Ho�\u0017{\u0006L�S؀28��8�4]SE��2�8\u0013����Ǡ\u0018\u001c\u000f��J)-\u0019roW\u0011��r�\\ܳ��\u0011��\u0012\u0010�\u0016�T�O\u001f���޲5-4C��.��f}�C���� s�9\u0003�¶\"�t�n���h����:\u0002�X�#�{zz�3\\�@�.��qH�\u0016��|�'���H�\\\u0003�Uh�Ni�f\\�xn��Z\\�\u0004�|A�hՖK�a�#�c�q�\u0000�rm\u0007E����1�{8���\u0012X�h�\u0019m����:�汴'�,u)/�\u0011*��ub\f�\\�I\u0003'=�ӯ|V�ھ�\r��s�]�\u0016�\u0016\u001eFS�F\b��0}:��&��)��I\nJ[+����ht�Zp��F�leB��H\u0002���?3.�\u0001�P��@�R:=����&�%Ů�\u001e�d��J���l��6\u0018n\u0018,1�⬦���-���\u001a�����\u0019�I2x|��g<|��\u0014�����\u0013q{uq=�A�\u0019D� T ��v�'9�I�\u0003��գg�\u0015��3nKr����;G�Z���;i\u0013-���A�����z\u000fư�5\u0013�jz��`�;\r2�<�v�|�\u00030V�$\u0012\u0014(�X}\t�\u001f\u001a�gI��t�SQ��Ϟn�;�\u001d�R[i=s�\u0018\u0003���\u0000]�՟P�f���\u0003!i�\u0011m���pN�s�Ȭ�\u0004��m=4���N�t�\u001bO��\\IdK\u0001nn�,{[f7�\u0003�\u000e��z���:ė�m��\u0005���L��d��|�Z�\u0019^[�\f�OS[-�iv�Z���v�D|���q�;1�\u001d����O\u0003L7�/�V\u0019�'�\ft�?ȭ��JK�����ciւo\tZ^�sj7���&R_/{8\u0007#'\u0000\f���#�\u001f�$rǢO5����\u0012\\%�p;A\u000e�\u0000Rz\u001e��O?wr�݊;H\u001a7X�'D�\u0015\u0007\u0018�Fq�<Ԃ�\u0014@]���Q�Ϧj�\u001a\u000e����5\u00179�c�\u0015���΂�,�(\u000eIc��\u001c���z\u001c\n��>�q�\[yУ�U\u0000�\u000f�3��\u0006=�T\u001fn�^���i�Į� �Un��ϧ�5cR�\u0016���w<�ȱ�V\t\u001eDa�\u0005�\u0019���2qڶ�\u001eX���}�\u0017��\u0012�t�!o�-���;�\u0002�,��`A;��9?�\u0011ž3���:����b>[H�_�\u0011�W��ʺ\u001doľ\u001f\u001e\u001a�F��u-T�J\u001d��,�\u0000T�.\u0017���=I���+XbҦ���\n]K�\u0019@\u0007\t�\u0018�iΧ.�p�5.�����U\u000b@Y���\u001a��ʼn���N��Q�5��\ry4�\"�n%�Ϸ֧ڮ��\u000b\r�&�Q6��$�j\b�3�?�j�7Iu�j\u001a�?�yX��\u0000�i��\u0007�Tm|A� �q4�,1��\r��|�^y#5=���X��I..�aR1�z�L��Wg�\r�����>\u001f�Y8wF��>��c���(��5\u001d~w�M�� bx\u0004���&�C�\u0017���\u0012}�)\u001b\r��\u0019 \u0001�3�+�!���\u0002���]�\u0012ѧ�\u0015Z��vq\u000e:�$O\u0016w\u000e7�dr\tS�P��Zq�i�\u0016\u00172��q�p$�*�^YT�<\u001eG�T\b\u001bN)BJw�@j�I��?�7\u001ek\u000f��\u0019�\u0000r?��\u0000��Evw\u0000���K�\n��\u001d;�\u001akn\u001f4q�_�#��@�+CP�lle�|m���9�V�DZ�G�<\u001e&���\re�\u0011�\u0000a�r���\u001aކC\u0013\b��F�6�\u0000��W\u0013j$�\u0003,�2H6�n��-�WE�HR�\u001b9�>r#$��\u0002��L���޹�ڣ\u0004�j���\u001c�)���o�\u000f�@�9\u0018��\"Y�e��YZ!E����fF\u0019bG���\u0003\u0003�\u0018�e�\u001an\u000b`�\u001d9隧\f7v���\t�0�\u0006!���\u0007����:\\F<̓ d\u000f��{W\r�QG�x��\u001d�C��rFx\u0003\u0003��D\u0011��`\u001c\u0014t�s���\u001e��-\u0019!O\u0004t�OC RǑ�i�\u000e\u0016\u001d��H�\u0000إ��2Gҝ����\r�\"^wGʂq�\u0007�?*f�d;��r����'���R�v�\u000b8i\u0015\u000e\u0002�j�\u0011f�\u0003����܂\t*\u000e��w$�\"�Ĵ8\u0003��8\u0019�4��Ǔ\u001c��~��#ךu���\b`\u0016L��0s�23�VR�*���2�R�/�8\t\u0005O��0�\u0007�ɫZ\u0015��YEb�\u0011��c`N\u0006�=i��\u001a�K�y%�8�y�W;s�=*Ƌ��m�2�\f[�\u0007\u001cWd\u001e�%]\f˯����u\t\u0014��\t\"�\u0000z\u0002+���KїO2���d�s*�l�^����\u0005�Sۨ�m�p�\u000b9�^�~[׎ͥ#l��,j?�#���jg���U���k�̗~$���ʳ�\u0002��\u000e\u0000\b>�~'�\u0002�\u0017H�u\b��\u0007)\u001d�|��\f!\\^�\u0006��}��Ŕo(���B[\u0018\u001f�+��֟����;3��\u0015\r���h�F7��������V(e��j�<օ��k��\u0018�\u0017��!����oOƴn�\"�ʶ\n�9u9W���a\u0007�W����\u0017��]Z�\f�Uͤ�Е\u0004:Ԑ(h����{z\u0005Q��/�\u001a�jz��\u0004�I�cw\b�S��8��;ir�vq8x\u0003� >d$���q^��؍?I���0�\u0003�\u0000�yoԚ��Qs��Xv�\"�\u0017R}\u0017%�\u0000U�k�rO��ɦ���\u001dvk[\u0018���C��\u00125��\u0015�z��u�ə��k�b^\u0015\u000f_z�|k1:}�Y��b}�\u001f�z�\u001e\u0006�CCv*1��I\u001f5\u0010��\u0017\u000f\u001c���*U� �Ӧ]���U)\u000b9��ph��<G�k\u0016����\n���Y%6�g\f���W�����\\�\u000e��e\\�E;܆_Ҳ4�\\�?���\u0000F�;E��5kh\u0018�,7�/����X�h҇�J�a�\u0000N��\u0000�R��\u001f�F��[�\u001f+��?�\u001f;��\u000fƱ������\u001e�en�i�D�����?�c���X>6�n�\r��og\u0001��|���~5�ɖvj�Or'�\u001c�O[q��~g?�\u001f�tEY\\L�l��8\\�l��\b*���w.j�梯\u0010\u0005\u0015s�p���M���Wr�\u000eT��\u001d+\u0019����\u0019��G��Dx?�օ��H\u0001 �H �=띵{�ظ\u0000m\u001b�?��Z�3���f+�|��8>�ވK�ڹllc��>�UQm4W�U�[��\u001f����N�n k�4��_�9�\u001b�\u0003����ݬ�\u0010��2A��W5�M��\u000bՈ�\u0004q��Q�\u0004��;�Rgf\u001eh;:\u001f,��\u0000\u001a��`�La��қ+C\n�ɏ|��z�\u001cP��-\u0010\"�2<�t�|c�К\u001eK�v���Y��\u0000�\u0001��q\u0015�?�9\u0012��\u0004�w�L\u001ad�*a��J�y\r���SBܹ/�r78I\u0003��G\u001e���L�^H��F\u0019Q6�I\u001f��\u0000�\u001d=jx\"��\u001aE�60����u�\u000b4�v��E?7c��\u0000Uf��\u0017��\u0005f̫k�c���a\u0013q,j�Y\u0001� ��ҡ�t��\u0001�ۦ�I�\u0000Md�\u0017)1Y\u0017�\u001fÎ+v��(o��W1���\u0019�B�\u0018����\"�T�aR\u0017:\u000b\u000bO݋W™@����A�\u0015N�v��y�U<\"�\u0000uGAT��\u0010�h�t\u0006H#�R�I�h��E\u0017�\u001d�~F�_��J����\u0016=J0aN�vs�N�G@a]V���fD�hX�\u0000��3!^�Ne\u0000W\u0017��\u0012�Sk�bc��(�1�|\u0013�\u0000����e\u0013\r�3\u001c\u0005\u001c�ݳ\u000bt2��E-D�~i\u0006\u0015Tu$���[Cj�\u001f��������R@�5F��A��� ��\n�\u001f���ܖ42����m��|?p\u000e�hŴ_�?_��W��j�i�������#p;�\r�~���F�9���=��Q�x_�Y�\n�Aiu˥�͹+n�Ѥ��E�tM��pWgm\u0002 �\u0012\\\u0002Q\u001e5n�\u0012\u000f�����r\u0001�n+/D\u000fu;�3?��<�'��+Nr\u001d��TCmBv��>��E��\u0013��6͌����\u001fʹ�{\bn�[��F\u0007#ܚ�.��-�\u001c4�h?ΰ\u0016��˴.���ڊ�\u001dXe��x�L�\rbU�-�2��\u001e��\u0000�+\u001c�\")\u0005H�+��h\r��0F\u0017����.<#\u0017��\ts�F���8\u0019�*T�4�\u001eg��S!�u~\u0016{�4fڅ���*�H�����%Q�W�8�t��l0��H����k\u0016pԍ��[��i|�F��J$\u0018��޽�����zLZm�\b\u0015�D�F�]�f�6����{\rane��\u000e��!\u0018`\u0015Տ\u001f@kѬ!�4�c#\u0012I��\u001e�𩎲����DS�\u001d���sq\u001c\u0011���@3�򋖙�S+by��S��s�����j�t�}=xkـ��3~�G�^qr�גI#m�O'ҷzD��s5���ȁ�\u0006\u000bw\u00153Dm\u0014\u0018\u0014�\u0018��9\u001e�f/\t��}�.L�~bB�\u000fcZQY[?���ʔ�Ϙ�\u000f�s����+E;;��2\\\u001f�\u001c�jr�SX;�\u001cbhe8(N0{\u001fʲ���>颻���\u0012�*���w���,<�S���a-N�\u001b��k�.`w�RA2���b\t����in�xn.!���a��_�*Tդ��f\f\u000e|�\u0017�\u001d���SJȑyΤ�I�#\"��g���FGm�Y\u0011�����SgA+\u0015\u0019*˴\u000f/8���YGmy!\u0011��|8r��W\\����N)y0BB��&%\f1�)44�\u0014��in�\u001d�q�{\u0011���<�O�<(\u001cn$����b�G�e ��\bA\\���\t�P�5����#����2\u0017\u0003�)�\u0003}ªd�E�\u001d~�\u0019\f*�n̛�[����Mt�+��\u0006�D/���\u001d�\u0019\u0011z?Ф��\u001b\u000b�$�>J�j�럭_��\u0010�����\u0000G��.�C�\u0000-\u0018}��\u000e*\u000bx�|��p�3������Uդ6�w6Hq\u001c���=}\u0006}+u\u001b��R��ܳoak�_\u0010<��f@g�\u0012v�p\u0011G��\u0000\n��\u000f��ֶp��w�<��1\u0005�\u0002\u001b>��5VK����i?�r�\u0006B3�\u000e��:kP�'�(\u0004y.б��=@�[ӒKRe\u000b�D�T/\u001e�\u001eT\t$��X\u0003���*�զ�ji������\u001f�sY~\f�����W\u0013��\u001a�I9'\u000eա�A3G.�t1qyʩ�\u0000�q�\u001f�j��\u0016��bJ�kh ��(�=�� �C�}�\bA��\u0000��R]|�\u0017ҳ�;��i�Wǥ��8�s���Mt3Z�\u0016�\u0004�$�ͭ����>od�8f�ug_���g�(lI\u0019\"�?v.�\u0000�rMMf��\u000b�����ڃ �!�U>����\u0002�ɨx�}F��6�]��m�\u001f��f�;�Dm�#� �m�\n�\n���L��d��N��ɵb:��S4\u001e毡�R��\u0003^m����\u0019u'�煮sN��o��)*�2�Z��2�z���Q+ϟ�Ta:���V�I��.�e�hr��<��Q(�\u001d\u0014�r�\u001dl\n�jH�\u0000¬\u0018�tr#H�Ba��q�\u0003�\u0015��w���~�e8Qԩ\r�WYg�_\u000e�\u0005U�|�?�4eq���yFI�u¢}N3Śd�\u0000�nL{�\u0007\u0015�B�&��\u001d��I���]A+n\u0004\u0004ps\\LN���\u0007��=�z{jrb-͡�|>�R�i�[�v\u0011\u000f��a��\n���N}�W7�=3�2��H��ym��K?�@�+~��t�.�P�gȌ�\u001e��#�8�I^s��\u0011��G\u001b�D\\k7N�rZ�����C���W\u0011�����Y�H���\u0011�4�V,�摏w<���g�i�\u0013�s\u0014~r�۱~�\u001e���$�\u0011�\u000f�Z�dh-�u�� \u001f��\u0005n�\u0000f����~��Z�?������\u0011M\u0017����1�á� ի�\u0010̷D\u001bf�\u0014�>7���\u000f��\\|ϛC���e]��Y+��fU��!�|�\u001f�z楈4�c\u0018Rs�ڻ\u001dZ���ݩ]�1D#�q�\\�\b6��5���SWf�Z��7\u0015\u0003��\u001fδ�\u000b͐\\��J'B��cn�v����ٞ\u00014o��#z}�\u0007�\u0007>�c�\u001a�D��\\�,�\u0017j���A��EJGO:\u0016�[���]A,qț$\u0016���|{S\r�o\u0011ki\u0003 b���ڞ�� �\u0000����~YR \u0019\u000fc�\u0006����޸��\n�Ə\u001e�'��1���JJ�4-\u001ak�i\u001c\u0000�nrK\u0011�}9��tbe\u00063#;m\u001eX�Uo#-1�-�Ą��\u0018!H�<�h�Y\"L\u0016\u0012�\u0000��*\u001a��.��Bp\u001b�F=\u0004�A\u0015jh��#y�+\n2&߽��5BB�\u0016�N����s|�����ⴜ41-ɞ/�5P��\u00001\u001bFr+\u0019+T^��\u000b�%o�id�\u0019�\fۈ�T\u001f�5����>�x�c�+.��s�\u0002qןJ��\u000b��C�\f�[d�\u0015�˒\u0005szL*��W��\u0018`2\t�i\u0007�\u0013���vٙ�d\n7{Tw��WgL�:ըa��>R�1�X/\\z�i6��Nnf�\u0000�[_��ћ��\u0000SE�c����ɧi�d��\fJg�[�\u0018�\n:�'|�J�+y��I�Nw=�\u0003����m��cc�]����egy39�|�����,r��\u001c�\u001a6��u?ŷ��\n�[j;��\u0015�x�\\+\u0003�[ɉe\u001bI_�N�\u0000�Jrw�\n\u000b�9�\u0013�-�j,\u0015�mn�!�\u000e���\n�|\u000b����Vy\u0017\u0012^���gE�9�k�`�{ۘ,a\u001f=ċ\u0012�N+��-�\b���E�~�c�SJ�\nN�\u001dE��G\u0010�q����l�y�^U�q�H퀤�ֳ�+M>\u000b�R�B���X�\n=�yo��U�x���l�l�j��_s�}��o�\u0007��^\"�-4�l�R����\u0012S\u0019�V\u0014��\u001e�\u0002��\u001fx�L�\u000e�l�dO��3\u001b\\0ǚ\u000f8\u0003�\u00075ʒ=(\u0014+!�!\u0014�A�M\u001cS�T�r2�t\u0018��\bY����\u0010�yW�/A��\u0005em�zW��\u0014�v��9�������\u0000ʓ\u0003�����Y�\u001f���\u001fV ���_�n\u0014Gg����i�\u001f�O�\u000fՏ�[c2^���\u001f��\u0013^�\u0016����NVg��\u0000�I�?���j(�)�?�\nOc\"�a�G�qT��A�e�\u0000ec�\u000fj�Q��l`�ƪBc����F\u0014��k\u0007c��M���^�d���oO_jǖ)�&u�ݑ�\"H�\u001f���\u000b\u000b�w\u0018�f\u0018\u001f#zT��&Fy\n���^3Y$օ�W0n�^DT.YT�g֫����6v�`UIK�\u0004jY�\u0005SBNǡ�\u0014F\u0002\u0004��\u0004\u0015?3V���by.m�q:�\u00191֡��\u0006�}\u001c�!\u000b*�*��ǧ\u0002�\u0017�wG��N\u001a\u0015\u0001@�����M6\u000fW�\n���” `�s��*T�k�X�Ky#9\u0007��튎�����d�FU\u001b''r��:z��Z�r\u001e��Z�r�NC{�Q{�b���\u0004���ôdBT��\b�C�YC$v�-���@t>^2?#�N\u0017J7H\u000b��\u000e\u0007o�\u001e}���\u0013\u001b�K\u0016U��9�dW<�+:i�[�qx6�r�F\u0018n�q��\n~��\b$��Y�\u0011.��>n0\u000e~���if�2��>�M\u0019�<����Y�Β\f��[q�-�\n�k�����Fr\u001b�Z[�\u0002�H��1�7>�s�?�]����\u0001�܏�\u0015�xت�.%�\u001f4 q��Y�\\�g\u0002(̎��n�P}�c\u001ft�u�U�V��\\F�M�rG��9\u001e����\u0014c�6\u001d�\u0015���\u0002ǭI��C��I��+��\u001e�U3�;�*�{\u0003*��q �B~p{�\u0018ى��h��\u000e\u0007�.��&\u0007�_��m�?\u0001\u0007s�s�\u000f����R3˽�ɓ��-l^K�7sҺ��\u0013�j�\f�f�-�$�8b2�\u001dN?�+�.g��V�c�$;�����Ƴ\u001b/\rE\u0019R&Ԯq#z\"\r��y�MTV��R}\u0011��\u0006��k�_0�v\u0011�����2k����h�:�\u0007�Y>\u0005Ӿ��hfeķ�n\u001b�މ�s�Սr�\u000b8�{�\u0002[�'�!�=���%r\u0019�?��Ϋ\u0016�\u001b\u001f&�\u0001a��ܟ�b�Z���MB���Q����#�'�EU.����妓�(�\u0018�Pi���\u001c�@O\u00042��\u0015�\u00032��4\u001e��W�Z\u001e�\u000e���q�\u00164Xc#�^3��My'Í-�|Bn�\\'\u001f���_�d�\u0015�\n��k\u0018�\"QS�\u0003#�SOe�4�����jGb�n\f���D\u0017\t\n�C\u0002\u0005�\u0000+��6��y5�g�VP\r��\u0007�\u0000~u�ڤ�]����\u001d��ޕ=��\u0000D'Ѕ�\u0013�#�n\fx�aQ���j���\u001c\f֢�D�z\u0018�%��\u0006��\n�{x\r�T<����\u0004@����I�M��\u0004��v�\u000e|9o{\u0005α}\u0007�\u0013\u001f\"\u0014n�\u0018,��W\u001c��u4V�.�fq\u001a\u000fRN+�t�6-+K��`\u001f���&}Os���\u0014އ���\"9�X�\u0004p;ִ��7�\u0016\r>\u000bg���\u001c���!^7`�b�sVj��2[I�S۞k$�����R��f\"\bd�����p)���Ƒ!hQN8�&��>��tK\u000b�Mn.\u0011������Pp\u0019�r\t\u001d+:f�����#h�|��#\u001d���=�=�^���\\�4�\u0014�C�\u0000\u0011�:�j�y4\u000f�XIc\u0004G�2\r���&�a�g��g�_93\u001a\b[p)ө�VA��\u000b��\fď����\u0004�-^�\u001a]����n59&�\u0013¢�g��\u001f�6�T��I\n�b �_O֥�`��)j�&�\u0015Q�����G)�[�I\u0000��p=���r�\"��q��'��5�\u001e�\u001f0\r�\u0002�w䊭�[\u0005��t�b CN��(�\u0019�<S�}3H�t\u0011��$�0�'8\u001c\u001f��W�|=�&�\t�yt7]:�\u0000\u000ex��_�\u001a��t���H�Q�~�}!��R(�DR�7�5��#`F\u00139�g\u0014��l6�ml�+\fT\u0013f s���5Kby\u0011��Z\u0019 ��\u0004�͂��\t���^���x�Å\u001c\u0003ܓ�T�+K�}\u0006��l��ZF\u0004���<��\u001e��X�4`�\u001c\u001e�V����$�+g\u0015�:\u0006���d\u001d#�e���\u0000�^wgi&��[i�}��V1��O��/�Q��\u0004 ����Ʌr�\u000et�k�\u001a���c\u0016\u0010�\u0000�G��\u0006:�j�G:g��\u0002�H!\\G\u0012��Q�\u0001�^A�\u0017\]CXm6�����)S���\u001f��A�S�:\u0003yL?�/A��{��\\�;{ׇ�I�O$��дW\r�4��F)�%\u0000<҃H\u000f4��\u000b�M�摍hh\u001ao���khA�o��\"����\f�_��\u0012+�W\u000e���?�a���u��;K9�\u000b��q)����2����pۀ\u0003�w8\u001d���\u001cV��U`��G\u0002S���\u001a\u001e\u0007������\u0014���K)���y��y��\u0000��8�\u0006\u0007�\\\u0016�8��NR/�Z�o�muK��\u0011\u0018�Ժ�\\Gל�A����\u0010tD��\u000ekF�F$Vr�+B�mZlE��0���~�Y��MR��\t5,����s���\u00106����\u0005%I�da��\f���\u0007��r�\u000e�[K���\u0012.٥\u001et��n��\u0018��#��+�6y�e2\u0005WF9�\u0005���֭��e��<�.\u0019Rf\f�\u001c�~]\rTK�\u0010g!�\b�(�!wU2\u0006\u0007��`�Bh�,'���i,�F��q�\u0007v\u0007_^1V\u001c$�\t#I01�n?\u001a欵Q�i�o\r��\u000b�wv�A>��\u0000�C�_$���ɸ����\u0011�EC���J-�\u001a���ܵ�\u0016)o�\u0019D@3c�1�V%ͬz���\"���?\u001b�OZ��Pc<0��1�S����\u0007�Y�w\u0016ӆ�xLruFN��*�E�VW ���6�\u0016a�y�_jՎ\u0004�Ӳvm�!��\u000f����Vu�Yq��6�\u0000 \u0011[V\u0010�u[~HX��\u001d~�\u001fֱo���?ж��I����5���=67\u0010!��1���X�|�����\u0016��b�c�\u0000�U|k��.�c�F�--�\u0013\u0011�\u0000=\u0018�\u0004�1R��\u0019\u000e6\u001d�i�3�\u0015��(+\"?/d���\u0003�Xb�|?��붽���m� \u001e���\u000e��ok>�x�����.O�(�kS�W�i�Q�v\u0003j�\u001ei\u001dU}>��������\u001df�y\u0016�b���\u001ew@Ǹ\\\u0000kE:W?�φ\u0010\u001e�2�\u0000J�F�`����S�g=�\u0005\u0003�.��H^9\u000f����T�)k\u0006��Ի�\"\u0015uk˖�\u0014��}p\u0007�[���ZMŃ�ۂ��M���W��V�\n$q�r�A����/�(���*�{\"\u0011�x�\\��&�>�q�\u000ev�\u001fh�\u001fuEf�( �*d�RCZ�>�#q�3\u0004���\n1�v�R��\u0002\"�^��C���N&l)�\u0000�jy��\u0003�>��[˨� \u0019�w\b�ܚ�\u000bú\\z.�\u0012D��,Q\u001e�G\u0019�NMK�\u0006ͳyӴ��W�\u0007�w�?�u��k���\u0000�̛!\u001e�/\u0003�9?�u~#�k\r\bZ@ظ�>B\u001e�\u001e]�\u0001�μ�U���R8���0\u0007��J��=Y^��5��h�>]�;�\u0000�eO��뜍w>*�+�g��!��X�\u0000�ԨmԖ\u0018�\\�����\"�ȱ\u0015�N{U�\u0004b�T\b�Z���hJ\u001b+��𦖺LjcIWu���\u0007��A���f;Kv\u001dk��\u0013��7��,х��>k���\u0011�s�Բӱ���6�WQ��P\u000e*ʜU\u0012q�\bn���\u0014F\u0001n8#�qIp\u0005Ğd1`�7*�\u0007�S��/\u0000�����␯�\u001eA\f�:��}Er����ƅv�w݁�@�I\r�5��$���ڠr�\u001e�JW��%\u0017;q�a�U�����\u0006\u0000�\u0014���I�T��b�d\f�\u0000�L|���z���0��\u000b/@\u0000��j�n�\u001bo'\u001cT���\u0001�\f9�\u0007�$�)E-\f��\u001b\u0002���;��5�ijMԳ\u0004\u000b\u0019�UU\u001fÒ?²\fЍ�]簭� \u0017����1\"��~\\�\u0000QY��/G�\u0013?��F�M�{��2\u001a=��9��j�K\"*LJ�p\u0002\u0001�?J�r�O\u0015�*��N�ns�\u000e?�v�\"4�h�\u0015H�\u0013!\u0018�\u001d�\u0000\u000f�[�FW5�\u001f\u0000O\u000e��|�M��\u0015=A�A��1\"���+�f%��RkZmBmQ�_�\fG����Q���ٷ��#)8��I-\u0004�ge��?�\u001e��~d�B�\u000485�x,c���\u0000_O������v\u001e\u0016�\u0005�����!�>��\u0003ֻ)꬏:��e/\u001bx���v���q�L3\f\u0019�\u0007����׆�<�w2�]He�g/#��M\\�5y�A���+��\u001b!\u0001��\u001c\u0005�\u0005P<V�i+#4���\u0006�b6�ֳ(A�\u001fjv�P�(��4\u0000�3�)�i@�(\u0004�\u001e\u0000\u001dϥ\u0000v�\f<<u=jK�_��\u000f.2G�S�/�g� n�\u0014_�\u0005\u0000\u000fz��N��\u001d��(�y���#�����𫺽�iZ,�jA���O�H�\u000f��*b��I�o��Q%���l�h�����\u0000�~|~\u0015���얱Z���|�>��uZ�#\\Eb\u001f1ڦ�X�=I?�k����n��\u0003��z\u000eիfi\u0016t��\u0000�v�������J��\u0010�su����zv�����J�\u001b\u0002�a�O��F�dX��Z���\u0003�\u0001��I\u000b6=*9\u000e��h$��\u001dқXס��\u0010��NG�\u0007Q���Y\\n�\u0018\u0003�=\u0005s^\u0003�Z�C{�W\u0013_�W#�\u0018�����2\u0003\n\u0016��й\u000f\u0002�5Z3���S\u0011�G4~@�V*�\u000e�\u001b��Ol���\t|¬<�\u001f�\u001bi����S\u0019\u0004��[�S>�$�\u0015�]F7y}��,�\u000fi\"\u00127�_c\f\u001cӃ\u00028\"�m�\f���r(X�\"���;�\u0006���\u0014;zS-��B�̉���9ݕ<�U��$�\u0019]\u0018\u0010T���Ih;6\u000e�g2\u0005c4�Dv���H����*��k%�ᤸ��\"(�\"?\u0005?�V��n�\u0019BŌ'a���1�Vo�����G��\u001em�6Mo\\�+�!���|䪖'\u001fSҺ�r�̖=>�쵀a����?\u000f�J�A�\u000eA�[7��]�#���ϰ�+%\u001br��\u001e�l��\\ih\n̄�8\u0015\u001c͹��Y��\u000f�\u0015\u001c�(z\u0017\rY�x)\u000f�#������_\u0015/&��Y�~��\u0018�5�\u000b(b_ҽ\u000f�$��e�\u0000���\u0000�V�_��\u001a���u�f_2B�L��{+gۡ��R�8*��g���c8\u0002��d�4�\u0016F(�K!�8�5I�*�\u001e�f\"ri�\u0005(\u001cR��!�\u0005<\u001cTdњ\u0000~y���΄u�\u0014G+��,@��о~A���W$\u0018\f�ҽ��~�����t�4�\u0000��������L�\u001a;\u0016�~��z ������RC|�\u00007�t�ϱ���\u001fκ���Ӵ���\\�2\u0017�\u001e���W���\u001d0˹������ɫ���=NSU��Ȃ|�oP��R!���T��nԥ�q\u0010�\"\u001f�\u0000\n���\u0019j�cO��\u0000��Ī\u0005��j���\u0000�~��\u0000\\W�\u0000F%f���\u0006���O��C{!Q�sZZ>��ޱo��¹�+u\u0007S�+: \u0015w7J��\u0002i\u000ba���D�\u0000J��$r���ǭ[)++�\u000bF�*F�c@\u0015\u0014v\u0003�)�VOJ��:S�,u\u0015D\u0010 !pEG)��N\u0000\u0015RNM01/�2\"�\u0004��\u0018uS��֪�(��P�9\u0001~��������NH�\u0006��\u000b�Ue\r\f�p\u0019yS�W!���\f�\t`��М\u000fQ��#�D\u001b�*�\u001d\u0018��*V�xr7\u0006R0J�G�*'�HX$��z\u001eƑi�yh�Si\u0007nK �cڙ�ӑ�SF#�r�� ð�9�\u0014\\'�º���!�CR�QЯ�4L�\u0019\u000e�\u001b�P���omc�\t�%��\u0010Y\u0001�\u0003�Ȫ;c�8��\u00152����#�\u0015N��iH\u0011.�E\u0004��\u0011���+&�x�\u001f�'i3/̟P��P�m�O�; ��SϘ\u0014��\u0002�{Q\u0012g�\\c#����\u001d�_z�L\u001aOb\u0000Io�g�Ӌ�\u0018+�zp\u0019\u001e���\f��%�F�:o\b^Ɩri�7ݽ�ݑ���*\u001f\u001fk�LғL�k^��Đ\u000f�\u001f����:f�k��P�R�Е�1�G���\"���T�'��}���c�G`=���+K�ί��T�\u0000\u0000\n�=�JمK0\u0004�\u001e��hEi%–\u000e�D\u000e\u001aV\u001c\u000f����\f�E\u0007��т7��\\|����z����[\u0012�G �\u0018>�����!Ni\u0015r��M�V\u001a��S\u001e\u0006A��\u0001sW��1�|Imj�Z\u0014>l��\u000fO��W����V�Z�'�|W�|#��mJt\u0001�\u0000���\u0000\b�g�\u0015�]���ơ?�E-��\u000e��Z��\u000b�\u001a�i>�?��zy��3�\u0000\u0002�\u001d*��_Q�\u001d6{�$]j�@�T�]7�f����Y�����vGoo�\u0000?\n��kQ\u001a��$���/�D?�\u001d�\u0000\u001a���k�V#�\u0001�T�Z�\u0011��3TܣNŇ�f���Ĭ�\u001bڮ��v��\u000f�`��5*\u0018\u0013b�j�����\"�{\u001a�\u001bѿ���m\u001c\u0013n�����\u000e߉�z5��\n\u0015@¨\u001c\u0001�W/��/�\u001a?�d\\OzC�UA�G���\u00000*�p��M\u001c\\S�<\n�1�,��Q&\\�U�5r�u�-�i�ô�'��kŌG\t\u0000��\u001e��h�h\rդr\u0019A*#f\u0007i���Wf��\u0012\u0019f�\u0001\u001c��P��\u0013�j�in�o3[��,�&�\u001cg\u0007>��!�\u0010-�#fS\u0014g��f��=�6�Cqp���#�\u0007�?ST@1\r�����\"��u�4�{9D�\u001co�I\u0015r\u000f���&�m%�6n\u0015�15��{v\u0019\f�\u0004\u000fqP\u000b��P\u001c�uSҨ��m+���8�p�x��4W1bR���D�7֛�1�ܑ�ڍ�K\ng�\n����\u0007j��\u0018�$�wx��m\u000b��\u001f�S�\u000f\u000bE\u0002nX�C�8�ǩ��\u001eIDE�+\u0004j\u000fԀrk)/�G����v\u0012F�Ko,>J\u001c�a�;��[y\"`�(\r�z� �4[C�$|���Z�s'��\u0000)eR�/`\u000f\u0015��̯dP�\t?yW�P�\u0012�h���)8Q�j�!#��b�MV���1\u001cG\u001fʃ���i��EY�F�]\\=ě����’��O�YX�o\u0019������M%��έ<�b���}�o�T��\r��\b#�>#�z/��z�K��7wv:Y��\u0000]�'\t\u0018��ip1ҡ\u0007\u0002�ˁ�x�!�\u0012\u0005CT\u0017�5�\u000e��j�$�V\u0013�\fC,�~\u001e��gʋ�v\nHppGLQ`#''����GY�`���'|�vA�����T.Q�?�Mz�¯\u000f���K���q��\u0007���?�Kv)#���\u0016v0Y\"�\u0002�v\u001e�Ҳ�O\u0018�-\t�\u0016�'���\u0000\u0002�\u0000_�V�\u0011�[\\j\u0013}�R@�@�?\u001a�mvY�'�Lf��.no\u001b����\u0006\u0007�N\n�ɜε��\u0015���c��E�'�)��UɄ�(\u001c\n��n\u0005��(�1�.%�Q��\b�8�\u0011\u0014jKb��݁5<\u0011�S�J�\u0000\u001d�9;\u001aA\\M*\u0012�\u001a�a�\u0014�\u0000щZ>\u001cю���\f���<ۃ�|���4�R��P$�\u0015��\u0000]\u0016�\u0007�z'�&��ȸ��ķ\u0004�\u0007��\u0002���)����^�4`\u0000�\u0000(\u001c\u0000:\u0001�Z\u0010\u000ej�#\rW�=+s$hD�\u0014�Dž���N�\u0005i\fȸNMgJ�nkb�:�U��u�D���ϛ\u0012�39�[\u0018PG�T\u001bA��ø�\u000b�\u0004�T�I\u0011���\"��o%��=�a���#p\u001b\u0018�A\u001fZ�=U���>�yw�3�\u001c\r�\t9�:��˙�̗\u0017\\\u00014��\u001e��],W1ZMz�\u001a��\u0019�+�A\u0000�W\u0016�%�@��MoOf�J���,r}G�:7)�K/��\u0014�y�)Bzt�0/A��6����\u001fd�n������Bl���g��\u0018`�����5�l f��'�1?�_�-k\u0019$�����)4���6�UbU��\u0014ck�G�\"��iq���'�75ƒI�ꧪ���2�V����Kx$u��U�X���8�>�\u0003t�z\"\u000e���;F��F\nz��Z\u0017\u0003�vb��[ω.�\u001f���֐VFug�U��\u0017\u0013\r��\b��c����s��C\u0011I�4�p+C 2\u0000\t&�gЮm4x�9���t�lソ~o�*�t\u0016�n�w\u001em���V�\u0000��:��:��1.�w�<�4�3��ֽa����$[i`P$�\u0003\u001eW��\u001e�����Q�{�-%\u0004w�d�\f,���ι�ำ���\u0000N��s\u0017�a������=�Hu��r ��%���������Y�b�\u0016��Yu�n-1��m�\u0000�\u0004`������k�M:�,l!��6�\u001c��+��qX��\u001d����R�\u0006�\f��÷�ֶ�[;9�\t��U{�A�&�W`�H��\u0015�K'��}��D��\u0016�\u0005����0��W��k�Ȼ�\u001f\u000b��c�t\u001a��O4zl�\u0003�M������\u000e+ϵ]Ljw�r\u0006\"\u0003d+胧�ִ��3�\u0004ҫ\u001c\u000e�� �B�\u001a\u0017�K`h�aw\u001crjc��\u0001eZ���u�4.��QGROAY7��\u0018�t�\u0007�[�V_>-��\u0017q�\\\u0010�?���I��I9&��m-4]>��\u0000�\u0014����9\u001c�\u0000�i�ɬ�z~��\"n�#�������\u001c՘�\u0001[�\u0011�\u0013\u0010)�<�\u0011�+�\u0015# �<\u001ek&v���x��d���\u0018[\u001bT`\t\u001fm�x��(��\u0015P�q\u0014�X�Y\u0004\u0012\f�\u0007��N���ԭ�O\"A�w��`\u0010^M\u000e0\u0003�>���\u001a�]�S������ڌ�΍\u0014�\"�g\u001b�d\u001f�5�Jv��\u001d\u0006+_�\n\u0012\b\"B\u0002K.H\u001d�?���q�9��D>\u0013���D�&��\u0014�1�H�l9\u001c�֨�\u0017?�Z�\u0017�9�_�-j�Th��C�\u001f.:�\\խ_\u001fm^�_�-k'�X�?�}\f¸5\u001b\u001a���C��* ,�@\u0000w5�%��\"E�{8�6�m��������P��$�,�ZI\u0018���M]��@���\u0010Vߙ[�򞿀�>����KC;ݖ\u0015�mxg�\u0013���Δ�:lg����\u001f���\u000f\u000f�\u001e!Ԗ�\"c�L5�������]��\u000bKX�-c\u0011[��#A��&ƑOU�8mm��5�\u0018�čz(\u0002��`���ô��\u0000�\n�5��\u000f��9��<;t@�:\u001f�|U��+s>\u0019�\u0000t\u0001�S���]�\u0016�l�\u0014��1:�\u001d>�B7�@�:�y�m'˶7�\nCH7`�^���U����m�D\"<�3\u0017��k\u0013�\u001a�k7�H�=�\u0012H?�)\u001f\"�\u001d*ٻ�\u001a}������\u0011�vc¨�k�5���d�P�k���{4��?�i\u0015��L���b��7rn�\u0003�S�c��k�f�\u0001Үj\u0017���{�\u001bL��\\��\u001d\u0005Rde#p �4�\u0010��!���5n�W$�f�.;��d\u0000+��\u001e�g�mfu�ͱ)\u0000#�I��\u001fι�;O�VԠӬ��9�o�/v?A^�mi\u0005��66�l\u0016�}�I�5�Wfҕ��������F�#5\u0003�����X�iS����#'�\u0018�\u0014�����S�I\u001f�� S�`\u0013�R/���;h\u001d�e��MVs���1ɨ�\"�FJ\\i���~J\u001e�<��O\r��w�ġB�F��ʎ\t.%�፤|r\u0017�֬6�2���@�p\t'��4�z2�OF`x�&�T��2�\u0002#  c����Y2\u0002\u001a�����G>�� �#�q���e͍خ�����n쌂\u001b=��\u0005W\u0003\u0007� \u001d\u0006iF\u0003b�\u0016��\tuK��\"`��gs�*:���i\u0006��\u001bv���\b�r\u0018\u0004\u001dj��p��Ҥl\u0016Y�h�'�n�~<�ꍣOs\u001812DZrA�ôqX���>��\u001d�<�������@q��eO�R���c%�\u000f�!�\u0010GY\u000f�s]\u001e�^]֐�*E\t���0��s޹��\u0012�T�\u0000V�pZ�KK��#�˂r{��8�iDq��=\u0005H@ۜѥ�mYB�\u000256�*���\ti���^�b@�82��݉=kl\fqU4D)���F\u000f����*P��~�1\r��f�B�}T��w����\u0000�ֺmu�um��!\\����\u0011���p��[/�˩\u0006�`ڝ�6�e3�_�}?\u001e��ۈ��p\u0000\u001b�\u001fʹ\u0002h���i��\\K.\u001c��uϭtw�Oc`]\u00007W\r�0��\u001c�\u0015�Sfs�*�V9$�`�c�D���r1�\u0000�����\u0010L���1��7�vޤ�Z����D�!c%���\t?�?�5�\u001a�ij��4�2�Ř���#\"��x�EX��_�\n\u0000j��j���J���j\u0006E-��˲A�����a\u0004�J�\u0010Gy\u000e�\u001c��V|'�\u0017ּF!�S�\u001b@&��q��\u0013I�'i�\r\u0013�?F:�ˋ��\f`�R.ߟZ�ߊ��=\u0014*��\u0003�\u001d�V��U���\"o���\u0000��\r[O�T����\u001f�j�\u001c�YC⟯��DEp� -K\"��Hq[\u0012\"`�����BFI����@\u0014�\u0014���,�v�\u0004\nb\"��-�0�&��I����;�\r��i\u0003�¸��3�{�з��I�\u001f.��^@��B��B�kֺ�z���/�8���/��\u0017gvp��幾�\u0007�t��f��'4B�;\b�~��j,�[3��(=)�zTA����ր\u001eW~\b$\u00159\u0004u\u0006�\u000b}y �6w��K\fG�\u001dF���Ԟk�Lb�57\u000bp���/�\u0001k\t\u0016>��)=\u000e���U��� �\u0015�q�$\u0002���rx9�qRxcP�����\u0012\u0015��_隮����e���sԣc?_Z��|WdD��ŗ`\u0002˳r�\\�յ�\u0015�9��\u001bP�q\u0004��\u0014�\tP�|�J���E��\u0007?ʺmcS��i&�\u0011��0�Zc\u0003�V?����)F�bm�pG\u001dE6�)&{M�{,�S\u0018\u000bo\u0018\u001f�ȧ��&͑ƣ�j?AU�q\u0018,�*��؇���\u0003�m}ٿ�eh����l˾!0g\u001e� ��U�r�9�\u0011�p�\u001cw'\u0015�xWL];M�s+�����\u0000\u000e��~�\tjm�\n\u0002B>�|���KĚ�*�\u0010���mf?�'��A]\u0006�p`�[8�l�\u0000��'�7�\u001fZ�ۑ\u001cQ](\u0000#\u0018�ǧ\u001d!S\u0015�o��k��榟\u000b���c\u0003��z�¹ɏ���[�\u0018��?�s�j�S��m�\u0012�\u0004G�<��\u001d�\u0007\u0002�G\u0015,\u0003\u001dj\n44����(�$�lX��+��m14m=mF\fχ��_\u001d>���Z\u0000\u0005�Cr���f�����\n�\u0014��in\u001b\u000ec�V��YlUi��Vs���U�wɪm˧��U�N�X�⟯�{\"Խ*��ڭ���Bvɭ�,#�\u0015)�Uc��ht�\u0005yF8�JՉG\u0004�bi�WH��Ź�kM�}\u0007j���1]\"(UI�\t8�\u0003�\u0003[\u001a��\u001d�����/�1Y�q\u000e�p�\u0012C$ci`A���U��f�38\u0016�\u0007�Ds��\u0001��4��\u0001�]�햘\u0018���g�r9��\u001eM\u0006�؛f���>�����\u0016�0�`pEJ��kI<7{$�8��l.�d\u0004g�ˉ��S\u0015�h�w���N���\u0013�\n���S�G\n\u001e��V\n\u0017s�d�0:\u001fAY�s\u001c�<���;�\u0016%���*q��ݣ@����A�G�\u0002�\u0000�U4���\u001f���\u0000����4��5>�\u001f�a��o�8R=�ٖ@��[�\u0000���\u001c���R�N�k\u001b\u0018�V�[$�prƹ�r�kk�\u000b�]�s����z��\u000b�eA��c�\u0002$+��q�Q�\u0015\u0014�ۗ\u0006Wa�q�\u0015i�es�i�ҩP��ٛ�0�y5�6�\u0016?!�4��y}\b�۽u\tl�B�\u001b��\u0005��x\u0003�\u0019Q����V©�Xx\u0015'�V��+&�i\u0010?���U���\u0002q��W�x;/Փ��{���;������\u0007޹�v�$1\u001f&9\u0011dڡ��cZ\u000fp���1����\u0003Ҳ5�����\u000f�h�0��\u0016\u001c���\r;(�옖 e_��z�%ɇ�f�f�T�*�2�t�럚���!�X��5\u000e�?��M��Q��\r*�?�?�\u0000\u0015[\u001e\u001f�:�\r�zm�#|�>��\u0010u?{�\u0015�<�q�d\u0016�a��\u0015��\u000f�\"�|?\f�\u0006��Q,�\u000fC�T{\n^�\u001f�avhEc\u0015�)ol�G\u0004K�4\u0004|��\b?����U�Ҙ�^�\u001f�b�d-\u0011\u001f��O��C$g�z��EZ5\u0014������s2\u0004��Ř�i��ԣ����\\!\u0018�&�\u0002Ċ�౩\u001d�\r\b��Z\u0012\u0010�I�Z1�K\f|�\u001e\u0005Lɀ*\u0006Q�~SUJ֋��U)\u0000\fj���"
        "native": {},
        "from": "system.adapter.frigate.0",
        "user": "system.user.admin",
        "ts": 1700989168929,
        "_id": "frigate.0.Terrasse.person.snapshot",
        "acl": {
          "object": 1636,
          "state": 1636,
          "owner": "system.user.admin",
      im mqtt Adapter ist er korrekt
        "_id": "mqtt.0.frigate.Terrasse.person.snapshot",
        "common": {
          "name": "frigate/Terrasse/person/snapshot",
          "write": true,
          "read": true,
          "role": "variable",
          "desc": "mqtt client variable",
          "type": "string"
        "native": {
          "topic": "frigate/Terrasse/person/snapshot"
        "type": "state",
        "from": "system.adapter.mqtt.0",
        "ts": 1700976115142,
        "acl": {
          "object": 1636,
          "state": 1636,
      • Wal
        Wal Developer @crunchip last edited by
        @crunchip ,
        ich wandle im Adapter die Strings in Boolean um, da True/False besser ist als On/Off.
        Du bist aber der Erste der die Fehler bekommt.
          crunchip Forum Testing Most Active @Wal last edited by crunchip
          @wal sagte in Test Frigate Adapter 0.2.5:
          da steht aber weder true/false noch On/Off
          bei mir steht da dieser Wert drin
          ����JFIF��C
          #%$""!&+7/&)4)!"0A149;>>>%.DIC<H7=>;��C
          ���}!1AQa"q2���#B��R��$3br�
          ���w!1AQaq"2�B����	#3R�br�
          $4�%�&'()*56789:CDEFGHIJSTUVWXYZcdefghijstuvwxyz��������������������������������������������������������������������������?�4}��M��K�2X�g�!�H�>���<����������X�C��;Ej��\����cv9��4�.+�+�qm,�#�h�vq��F����9�ֹ��n�\���{��^�A���dT=0@|��sM3ws��ڽ֟�,����y���s�w
          �X4��ޱ����@$�=��}j���#E��`^��_5Cʠ`�z���5��=�wj��s��Y$
          �O8 �`~At&r�i��J!c��^���Ÿ[�o������㊞�e�6�)[��C��8���jg���N�@{����Q+1Ú$L�DV)�w���N��/~�5#����mʀn+Ume����w��?�N.`|�H�����<Υ4�e�%����jZ.�%�څ�E��,�0��	#(\� >�*@���/4
          �M�{K�-uv`��s34�!G�rB���e�w���M:X<�Uc.�P���l�9��ϵ&��}���q+FV6�#�5�g���d�����տ9^���-�M𝭛[�̂i$
          �m��m������9�g����]��5	���������*������_�U���m���4ʒ!i�O3w�O9�A���=xĵ���R�y��M����H�pA�y��XV�U�ԝ�����Iǖ�~E�u�x_�z���%��j�b�ӗ����O@d ���������X���h"8�猼�t�<�
          �>V��bpq�O>�!��f�ޫs
          �a�����<d��������.�P��m��V�_2�%���0�$��g��Nr�M����~]HN7Л×���H��:Kmt���
          �#f\�����߾3V� � �&��9���q*�d[>��۶���0�����v�fZ�Kc��!����b2O^����0��<r $Ĥ�9��jҜgȔ�_���OC/C��&�K���e����-�%N69����z�R�"�n�9�"1�DQ�����<Ϩ�nB�v�g���LIf ��q��Y��5Ũ���Yf/+S ��3��ȧI{8����������h�K
          �2I��5c�`[{����#��<6;�q]��u�14��K���~~��>Znpq�����ƪ���I�~��V�(���2msc����_�+
          �1�k�U�jLZ�n�4���O늟J����x��pe�'q��q���Iڐ����6�W#'��~�*�{?���Vc�mR[�-�M/���cɾ��ׄ��p�fy�!���5�xt��U��P2p�1��P��ld�Ѝׄ�ݿ��<`gօZ=����9Y����s���p��d˞O�+oǷIg�L�q���@��v�מ1�+��T�h����;���;V_�B�Y�k@��l��lg9�튨օ�����Vg�8�z��⥶�KY�&)*6�u8*i鰁�������'��cĐ�����SP�~�>�����u��8$�W�x�g�Q9���B"�6d��}���|�!%�נ w�š��1��}0��zS�aA�	���x瑓�Q$xn���<�c�#w>��0*���Ra�N}�Cށ��յ�쭧4�C�񴄎���j�<oy>����I,pϖ�
          �;��`�Zu�nA��	%�yo�NA�c��5Z�-n�L�A�%�k�#'ҹa&vu;;�p��C=�Jf�,�`/NT������Gy�h�+��u6ۆr�
          [���`WW�YX�i�ז�M(;T��� ��^�ut����Y|�UAR6���֡��+��K�w�BRd���RwӧO�Y7�i=�S�
          T��r�X�H������C�I��(���1�����A����P�8Tdb�W�v�*(c�C�C�zma�����I�G��'
          ԎMQ�#�pڠ&I�/,��me��z�ޞOBb8�R3߭F�R����a� z�?�DL���j�����F�)�n���C�I���9���\)o-�h�I5�H�9p�^:���_>ݗ��Z3�Hu$�:��j�=��rc�w��?�p7�5����k׏s$�UC��r|�������V
          ��)ؤ�Z��$��
          �B��,����D��F�����d��Irܟ�G��b�l�li�ٺz[��3$����5]�I���qW�|+7�j�I��{֛#+܍]���r<�2��k�"�I솙s{iǖ�A�m8\}7�Vƿz�pٔp��hs���?���K���KV-7�Ef_�?�Cܵ��kS�5k�ԍ��Lz ��A�cQ#�e‡`�����A%i1$�/!21�'5�{tL��R{Ӑ%vz��
          �_&9d�TA�r���r��^����B�1��I/�NqY�Jʼn��VH�#xuw�DM�aU9��l�TΗZ���ǔ������	�/�:�Xj���JǸ�$��N����㽇�%?zgM�Գ�B7<m*�T�mmJ��D�~���jP�^�����8�w�����#���g����dוY��I�$���G�x���;���w)�N��z��I!:U�"�jZ�����~�� ��@��oi_`�����7���4�i�{�@��!�zѴ�1��$���H=��¹O�WWmi I�V���cؒ$�u�L��������=�=����q�V&������[�o��<�c�v��
          ��GޤeY{�LM
          ��g=A�������� �mǁ��ޔ��k��:v�I̵�r1�g�%l�)>�����:��W���u�)\���%��QZ���,�L0ë)��EZ��-��e�b�c���k�s�	�����ˑhV�3��M4Dq�|�Q�Z��p��g�1���W��[Tds�М{U��)B����i�R�n���6�A�D�G|���\6v�獘��Q���,���v��4�eہ$Ѷ8�7�UpJڍ�0쮎���*�ʂ���p�"9q�b��,���QJ)Wps��Ek3F���C����Q ��' ��x�w��,��˖P�A�!z~5��"@,I�Td�Y��|�!�X4��##p�k<:^�>�R��s>8�8�Gb�3,��y�����ZG1��;��g]���?Z�|MW+i�|������~�;V=��bOsl��j61]͟�� ��k�[#���֒[�m`���U�O��\g��k���h�"30bOrz���K;�i�I�$W�Af�yQ����5��/Y��k�4r&����S=G�O�J]B�莖����0�C�Ҩ���N3]���Mp-�ˠ�m#	��w�����yuO	\Z�n��͢l�U_��$ɫ��s��C#,g�wy?!��+[×��M���Ɉ_����9��βm��+Oy3%�(1�S�Yj&��������r�x��ݓ;�я�[��NԴt�ux��/ig<g?�4���RI�3���ʑ��]Ԏ+���Ǜ��8��Wzp��_�_��;{T)#GE���7C��k�Z�_��Kӱ����?�NG����䉹��^��7�����[E��o�T�v�!������핾i���C����.�e��C�Z��׌jr�p??Ƴ�?������K�R�_�J[���<�ơ�O)�
          �)�{%���oθ�w�`�u���@��$t37��}���Tخt�o��QՎկ6�&Y���*�,
          }�n�x��B�.���I��[Dҷ��������G��T�RN71���^�H�ҵ4Ӧ�g�"�1G��WUmr��/���Y���{���V8����j��.���&|�=�o��u������$�9��H#fbW��U2R�d8�!�����O�*���ϓ��h��	�قi���1�n�pwGp?ⷥ���Hd@�D�bA
          ��9��,,-���y�D�UA9'rߠ}�
          �3
          ޕ�wcӄWQ��@3����d���`D���O�R?P�M�1@�Hos֕�l���������t�$[p��!Wa���1�;�a���v�:���Py�$'��r{���O�X�	Ġ�'iG �y���$P�8�G����a����ʠ_/�a�����}j�$K,S�	8s�OG�������)�+C:�(�X��3�<U]Jp���۠����DNPy�'�:H���\����G�Z��f-�e���E	Z�dL�u���\G&�p���������l~���R:�G�T�H�I�S����v����֞�E�������z�Swv0Q��0f�X1?J��m��5�SSa�id��d���k�V<2
          ���}u��6��g��v�|��r?��V�k�{����5�����i֤���w��}�=lOw�d�7-�8�q8��;ԟd7W@�ޢ�{��C�O�'ު�܆��m�C�$l�������5d�����~��@��o�x�j�!Z��gO�����N3�����Ƹm5%k���Դ�bQԾr*mY�(�>ݭi�*
          \纯�?��r�.�+�s̐nR������kG_�5#��:4��Li��a���swR�札p�l��q�7H��x�=ϥg}�P��V��R�*�)�
          �{���G�Q�B܂;cҨ�Uw�#�Ӣ�I$!Oҧ�CE?z5]��kj�U��t�`��Ǔ"�;Y[$z��E�
          )md���V�+X録ˌIp>�{/����m�:�
          :����sr�r�_��%�?݋�C���\֮�� ]S�ؿ�1U]�?5���nW�l���Zة���c'���k���xఅ#]����z �-yWí,_kr���J}�	�5z���c�T´[�r^5�
          k
          �nn�����G���h�!����RH\�3����ެڵܪ�[e��G.3�°���3|����`�DK��[9㊴�(%���E:����H��Q!��
          r�b�GS�j-F|_Zۻ��?��Mmr.���9ç�q��+��ki"�����Gf��"��n~�m��\<jᶞT�S�4Ӱ5s�yqF���;w���}��Ro�18«w��Aď�Cn��N	�P���M}n��� f^#��_q���ZoW�P�M�\����W���Բ�/�8�z�T��6�����<�����L\J�b��ǝ��I�Ԛ�I$�D��W+»z{t�����C���T��*y�u���)�0#���K4���A����ZԗM!�����օ�Mo����N�:��`�+��w���֙�����u�(�+��++�,�!���j�����-g�!Z*�$���
          \%)c�rz��z%���#.B��B�f��EeA7�!NID�.����kkHU���G�~���-v���"��a�y!V!H��
          �Kh�v�=��R��%@�~����X�nt��[{�b�cB�$�κ�y�D�x�y߆.�-J�k)�i<͖��g8'�e�{@�cX��aB���\&���j�3�JXF��.�ά3��*�\�]��~�}�x̻����y���k�N��ӱR�ִ�n��Ȓ���^���S�Vn�+]�����ƒ�u�I��+X�M$ǻ�0�M4���ԟ��1l�!{�7H��'��O�y�>�m��1�a�����9��Q
          ���j���]#L�ėY�
          �o�_�?�����/m;��g�±�͞�?RĊ��ݟ���u��V���#�v�I������f�h��l`�ϛs�A�'���c\5�0��Y�Ni�7��<h���\v��Ƅ�������PLʐ�g�`�U}�z��4�kF�ڵ�tv��;F��Q��98�3L�I��m�MG
          �An�3�q��{
          �-���l���T�s�9=����ʴ"�A	����*�#�K�	����+^�b�t�4mP����Y9���:{���/sB�.�X�Y�j��~h#���ϱh1��GS)��'����}WA�_��c-ی��FLz�����U��+(�@��r�����(�c�W�����~�/���G����x.�����r���3;��嘜��i���-��,i#jѱ�=�N��c�ݧ�s�\�
          e][�L�!8n��_��D��/y�Ap�@|�pOҫ�ڶ��Q�����-�M��f�p�r��,���*����bpRF-��2s�4���"9 P��{�Z/�nt�˅n"��s�aч��Rgh�hl�U�������+;�h����j7o$���ìcc�܎pߥM�o<��{33��9��	'hw�l�Q�h�B����PMg3�=��w� |�����"��:�W:w��H7H���k6�=�n�
          ��ȗ�dVV�G��ұ�Ga��H�2H8�Q�2}i�I��8���F̣�@��Z@��6.'�ϙ����<q�P��/�W����6G֩[��5�i��uˎ2zqǭJ�5��H��;��a��IŲ��d��Ʌ�K��#��iNF9���
          \<rΘe$�bps�$T�m�L$�9@���$�����]���1��#lm�N:ՍN�t�����,�D�(�Ð}�t�qTL�-�>�Um�|��>�|G��t-��D�A���_ʌ6���1�\�E+�/l�ܐ���q��cKuio{lc��f �Cc�Z�ѭ���ز0R�o�����.�9�ޮ�����hlu�i!�$q�bs�`���K��j/��?qa�C����}I�{Vc͒ �ja`pR�����]�"EE�5
          �{jqb_����)�i�p����O���[@%)�2�;�c���(�*�/��$c�c?S���V���J���`���
          ��Y����[I�抹���7���6�{'�{ �t���E'��U|g�j��>H���Ow~?�j¿�����dbA'n��>�w�
          ��'� r���ힸ</�3��ة3�~%�<.w*B�A�����Es�6�a��~��o��|Z���T��Q��b%����~u��q-��r8�j"���Yj��kB{ę�&�>[�P�a�~5D�jg��!1!8\��Ҡ�����%asHMT3^��N����p1����>?Ƽ��}+�<�>���Dxb��z��s~@��+�
          �_���&b���pyƱtچ�{r�4a��p�q��l��<C~t�&�h��������Y��^za�dH��)���zDQW���.o�+�-�OӸ�76�q�����Bܨ��ySR��x��r���)�>�S�}��.G'���\�N���"Kig<r	8dl~��qh ����7jў.��?CYwA�SHͷ����Y��*Hr���G��7���"�l1��X���ǀ��Q�'
          =Mz���.��[���ȋ�S��<��~*7vݑ`K �式"�$��֬�^������\�^=ꭥ�P΋qm�v��_c���j^M��a�97�Ni�ڒFҖ���������AT���66w1��հ����>��z�Ď$��,lϑ�W�'�'�j����B�ɹ���<�f�1԰`���)��*I�=A<U;�%EfX<�S�Z����ӭ[�[keG����c(G*}}��{�&�Β�l~56)NIܮ4���X��n	�G(���maeb�i|�7���1J�н��m�N����q�J�A���	E'2���H�TW��.��	�%���[�
          ���c�b-n��.��m���cW෎�R�r�s:2��9�O�/�17��_;�m��'?²��wE�B����T��Ⲏ'�Ѕ��T{U�-^����b�C��pYs�H�=�H�E?wbw\�:�j�����,V���+Ēv���R�cG]K���ߥ��ysI:��PF��Wo�<�ָ��n�\���%y��WW�Jc��/
          !�����f�ihsb�0�au~�R���3;���p�*�_R�h����O��s���޺�?�`$A
          �A��n�����5��t��̄�<�V��w3~�[Z���Q��A�l�?�ɯS�o��-"�PtE�?�N��E�N+��
          ���O~�䳋j���~�Γ���C�i����H��
          0?��U�^Fo��׷w�����'�r�7������Mg��4I݌Ri:
          niI��R���M1u_��*��2f�z����~5����ۖP��Տ'��?�Q���R�?����������zԉY&m�����d�u_5���G���k�l���|�?� �'�K=�ù�fs����]I;\H��C+� ���(����?t`V�^�5mL�X3J���Z��U�X�����β!
          �{�T�m��r�@�	&[��i��h�����e�He���O��P�s�tSڡn捴�lx;L}K�Q9�,O+����?ʽA��Y���7L������h+4��{��#�����ϡ��p�e7�F	W�,o�$������G
          �J���4��Ztir�*�Zrƣj�K7E\f���A���ؽ�'7@uR6�=�q�ig�[�����Q��{c�&3,��`B�mq��m)./��Zn��(�����01��բ���˩%����%��;��7��֒���FE�А�^A�7�Wo$p,nΠ� z�"�m�].�ݣ�Ь����k��s�4���V�D�kfc����x�Y6�+<<��F�V%w��2H�)�2�4�[F��<�;��O��6��$KfT���q��?Q��͓h�K�A�&F(��Q������"\x��6���݁+�sZZU�MI'�<�ۏM�8��'ZX�>#��V;{L��8�}�:?�O��N�L�e�%�~Qa�@������SF�g��VA!�d��N=j��>n�B��a���Ϲ�jI�R�6�r9�Jf���^�e�D��®{���+W���b�D�2�a��w���e�����*ܙds�Tַ4;&��Mn�?��v����\^��o�ړ�0��YKN�H���;���9�'%���?���^G��(���{実
          �L��"C��l��~$�u�cL��W�K4�&?�����LW��V�����y����^1�o����?:�?������.#R;�S�I�I�g.8�a�p1�T���5��Ե����yK(���)�H�.�sS:S��5���Rb�8�-����+Xt����'�5��3ю����/�h�C��h�g�?�&��t:=7H��/�����U�?���k?Ťɥ4K.�5�q��������Tڃ¨��=��גjw6�e�w�O���UV����k#66/+JW�&�^0r���5�,KHX���c�9}
          Cwfֲ�W-���V�%��,]�pT�Ux��'������4�͞
          �v����K�i��j��($pd>�9c�S�|�s]g������Uu�c�D����?
          {��GXdRw*m\�@(�=��`n�=
          s�pK{�L,�׃���X����=�<���9���9�'���Tv���p�d~m�'�*iev�L��dg#�q�P���	����;�q)F��t�L�|����P��s��\��Y��*�ʕ�O�^ӯ�������%���8��S�J'S,QN�HM˜W5�Mgבmb��#�*�	��O�(�o��7�\�+�Ǧ*
          F�;��@!�z��c�iE[��z��-E��$s�)�X����E��N�1�n$�X-n��h�Td?Ҫ���V32�F��Oj:�b��&]�C����u��-_���ȃ�=Ċn�h��	?�i٬������)�"s��a�\v�򾿫c+Gpb��%I��K��DE^�gH���b7B�W�#�L�z��3c�}��1Z��J�c�?��TFSeۆ����^���摵�$����t3)�aяQ�w��8v�:�A�լ��8fsՉ<����^��Kc���7j�X��-�u_��ya����s���:�<W9
          ���Lf[�fb;�o��OF�~������w�"yЪ���F�D��^+�<jeԢ���l46�5�r>f�J���Î�f���B����sF���j
          ރҖ���
          &���������D���d��?��~u����;x7C�e�O��~5�q��q�'Տ_֧w`3|C�6���4G�������?�'�K�d��n�Q1�����^�<e����~��2}�?��:Ȳ-o��!�����j�K��_�*����,�q$���VM�nX��@�j��2T���'��
          ��5��蕚+����5
          ܠ��Y7���ڲd��Q�psV���O�7pY[�p�5����zͽ�Vv�Y[�"�@�������>����d�a�Ա��}�v����1WD�}�n8�~9��R<�>��+B.�'t53�&�B��{�a�b���]O��`��H�k���Qd��"���y �ޙ�	P\c�����3$)',��{�NSp9>��VD�*�FFv���>`)�"G@an�A��枂1UUF���
          �3Sr�*��W�"���h���t$�Q:��&qS	�d!����}(i�!S^��Zn⍎���WN����I	�t����5�r\ۘ�>e����H�_��R{�Tm�YF����W�x7�}:'>cJ�	���R����M���`L����VЍ��{�z�ҫ;Mu3�L�T�
          ���"�t^�Q�^��%m֖ϙ�OK�=��N�t�r�v򻳒QNûn�n��5;,�c�'�^��k�,���r~�_��zy5��lJ���EnϜ0>����Y��r�!B��=�\V��&Lqz|��W3�K�A
          �����쎟�򮄎C�'�9>�3��9ɮ+Y���ҥ�
          ����MvW�"�1*σ���/����xd?�QZ�ivg'��;d���ִ�D1݀�3@˹N9�QU&���U�;f���2(���Z�����ZҴ���;{$��8�uz��Խ�=/�>��]5�I�rۗ?�/�r]֡{�a5伬\����8i����ColUQ��`��x�QlV��s?�ȿ�O�(�����_�׷ٻn�W2�6����"9�dl �N��tے�r^���N6����H$Ӯ<��]�Jg#�j��;���Ѭ4fL�$cA���E�|�cq��>��NAW�5FQ�����L�$� -�|�P��*����"�M%�yq9@������N�z�=�s�zC\��j3gɱ�W�Ұ����U�D�S��t��m.�O�@�sy��?��ۖ������=j>�h����Ԋ���{{�DЯ<�LE�����L��Fڪ\��ǥ$q�<��ބq��H�[�r@OS�v�;�:{�4|��߻n�<�����1P��SQ
          ����TŘ&��z7j
          J�i�F� �=�@r��Q����9���{��>�h�B�D�[����D���L�B�6�9�⤸x�y�p@`��s��tn;8�5k�m���mʤٸ��<~k�ѡ�L�텴`��uww�#�c�OA]V�%����^0;�?ǵ���}�\ݼ�ܻ_;%��OA��{
          �o�1^H�ղh�K�b�'��iF�|/��Ҝ_��ש�ڣT�� �T)!�y�UX�������}�?�W�	�9����������!^�w!�=
          چ�>/tP�������}+�������������׮�V��&�+�Ď6G����s��t�B#�|�0\�Oj�8LmJ�%������
          �c8�j��V��y������?�;g�m��v2�yR�	�x�29��c�8�j�͓�j��DR6OZ��~}�ڴ����Ϡ���8�pp[Kus�+�Y�"rk��;�Ťh�Z�8}@����Ʊ����B��������R�E&��[���F�@D��e�u��]��o�`�M�w�g��O�o�k�r�R���DST􈖬��=���'p
          L
          �����[9�T/9^Ze�T�s
          �.uU8�U�1����B�����掘ěQՅ���qg��5�qX�7R9�<����M
          JۍH�D�䑂��OA^��i��iPX)ь��ސ���~��'N{��5Y򭲐�}�R>���fs��p]L����Hp�=鞵��͌9�v�ˀP�=�2	#��0*2=���P"ẖ!VX�@��9�gCFFH���"�6]���|Ӵ�•v��r�����K���ƌF
          Ƞ�G��b�Ef��Tp����ӧ���eD���>��?A�#�����D��B������T`�C��H�<��)�����I�4���G�'��i\�����o�K,���X�d�~�nSocY����1�Hf
          �nn?�'�a��"�9�qҮΊX��m����2�L��B�*�
          Ζ����h#���8 �I�\�1Q�H�$p��=�U�)a��{V�]	;1�����Xt#���EI���\L��۸��˸����ۺ��C!<,
          ��i\����v�,R]�����H�x.�Յ�j�[�c��s�M�o��q�+r��Z��|�,+�һ�͔���k=�spd�!�rk���ӵ:�o1��U�o�Q��H�7�7�n6{���1�r*��P�Ă�[��*w!QGv=+3D��ᾇ���=��peT�����^��BF�$�����X�ѓF���:��׹?���U�_~"�M=[k]�?݅~��p?:�+����u�F]F�����������P3Cx�*� ? =	�"�8���[dC�E"���n�C{*ja4�6��ftn{g����{ۘ��.�B1*~n��S�d99⥷�m���	��WD�~k�GRM2��H�G֡6rJ�K�$`������gd%O�V��4���Y�C��?����+pn���lt���>(NV��7R:�?9����g�N{V�Ym��a9b;����;����D��?�0����x�;c��z�t<�i0NAn�Ґ�MFRN���b��t��]��s+�H��z'�(�p����$�t��<�G����ҹ:�����e�B�����Y��1���.Kq��K�� �`����:(��8��EH<�{P+[P{�#��v
          ��O�! �3���W�}��'{}^�Xgp� Edb1�֫���\��yܠ��n�;��;W"4��OQK�ĉ�O4�nb�
          ��=뙷�\��"2]�W?����t�4��C#���#>�?�G#-UOCj{�[��#�pH�#����Ĩ��Ѧs�1���w
          DF%]�Vp2T��d�������y�ȌC��u�T�r��0x�L�X��jH�.̽3Wf_2���[asp�y�p�~u'�]�;[w�4s��0��3�Q���^�9't�q�	��V��j�%`c�L}3��?��WMs����j���v;�j�.'��Wu{�f����p+"./n��K��!G�&����J�+��nu�=�*;���d����N��H�|u�Y������-��\s�x;W����;�\��c|���?�N���?unp�X���+�Eg�Q�1@�OA^���
          tM
          $ y�>f�=X�|}�%��#��JF�$$h�OEP?¼��:��wʤ��8��8��}�]~"�]9_k]e9������?:�y���-�0�|��E��#vA-˼�%��<*֔'�Vm�V�V�c VU67����H�jkuΟx��?�*B��R�1cw�O�
          ��/uz���{)�'KX9�v����u�K���O����G��ǹ>��X>��MVQ����z�o�]dWLS�����z*3�ߍ9�r	�Q���Zpm�	�5��C���O|f���H��P�$�8<S��>ԌN)J��Hy�
          V�H#(%_������>I�bI���R-ۤA"H�_EZF�w��y���q��m���E0¤����8#���"��9�p�Ha�OQ�Q��Mʊ�G\����W�y�w[5��	�
          �c�i\$�>��\��m!g�ߞ���P���>4N�@5UFMt��v�R啅;'��ܽ:Rƪ���2�<�������x0�,C���:�����3��@Z������G�_5c���ΎA�M#�*巈��ڔ��r�\�T���2y5�i�	�q��-�x����ew��ʜ��@�u���c�c��O'ޡ2����3r���=��J�&�a��GQ�����H�'�5��C�ͦi�_�Ƕ��ج9�"8�O_ʹ->����L4hFw���W@�!��2K�4�ߙF���\SFt�Lw�!]"A�ʸ�H21;WU�\ȚJ���|���<��C��8Գ�
          �:�z
          KH��Ϋ�ւڮ�.�\�hs����^��Q�f	k�OEP:�/�t$�t`���3#z��?RMF���ޑ��g������3s8�m���Zב\�f�����cQ;VK�@*۹6��e'uj/��iUa��r�Z�t�d��CH�}L�im�6no��O�YL����v^����^�g��)��~|�ʱ���4[v7#�$�	jv�A&�;�C�]iX�#9��J��NG#d��I'�1
          �$pOQM#��֜A.���
          <����9�?�5��ך8#��HXq�:R����Y��S���V�J��Kr���g�4g�D���\
          ��=t%����D��<9��Vy��g_5�M���"�.-�ꊯ����w_��)9S�h�늸�̈��#���r�ۊ����RLN�f}�fr�e
          T�$08�*�V�M�$E�m�g����Ҭ[\[���ʍ�ǧC@����}�nq TJ|��8=�UY|;r�;�i6�g$s�V����$K"��
          ��q�u�>��<Ѭ3K��^26zuǭeC�Q�C��[h�fO.GY$�$t�����{�f�?s[�K�bl�
          ��s�7�!s���B�V9g�z���$[�
          �����p
          i��?������e�;HOx�,e���D2��Ԩ�>�햰[��Gki
          �C������"�j�Wƞ����za[[�hv��xtQ��y�yԩx�9R5�SF�.���a<t��sNc��<��	��Mo|9����W�g�>����EdI��#��i%�j/�'��/��:��[o���=���6ݹB�jjM4V�I4�#�,�����^��R�p�l�DM0?��!��e�F}�=��o$�"9��
          X�Ʈr8#���������%����� �dR��h�x$U�u�a&�|�+:�)"�Ur�0>�=b�o�
          iGW�Dr/�%��}��U��s"�UmL]K���l=��s��*����:�u����М�Ɩ��Q����#�Lc����d7��O�2})����s�Ll��ϵ?���q���?`0�w�:�%q����za;[#��f���ž���UP1�p:փ����ef5���u?��\*���%e����sܶ�Y�#.#���t�b;d�g����c�V���9;��>��\V�3�n��������[���ܣve͌�H��֑�9�i�}jو��b���9�j;R��1[�*FW?�v/J�n'P�.�]�#��_�I�������
          >�rݓ��pA>&*F����qU^��G'w�����=�'��6R6���;�Ztvډ������9�w����p�x�A��7��x ��|���7iZ��	��K��H^pq��&R��<#���ػe�6`���'�~5�^]�ag-���p�v��z��TM�XX�j�,3����~���
          |��X�����>�%wr��K[������U��v��\�O��s��y���Ս\��Fbf�+���Սeʤ7��IhJ-Ox�GJx��|c�jX�N	�8̇���]�lR�N� �gm�a��V�?�rz~�s��p����i����ߕz���6p�Z&�{t	�z�s֣q�Y�׭B~��5!䚉����4�C��O �J��)�쎽���S��)p�����6�8�<�A,Si���n8�4������\qh�jS��e��8�̼�yAܧ�#�+ϯ.~�quu���3��+����3�\� O���9Q�U�F�osJ� �<Uc��*�� �32e`��Xb�r���):��&��%���.�V�����P�E?�g�|��U$��,Ed��t��v_��C�0�?����d��� �3�o�*��c�O���l.�M�*��eu�-��A���V��x������O��s��iE���x���Y�)F�?��9;�Ҹ
          �&�����Ukk_���ڃ,}=\�O�ۑ��1����'�M�A������Z�����ɭ[�3rw*j���`�if; RG��n���W-x�,��(��w����kKV�k�^Pr#�ck��M���
          ���4����)�0Z~�JL�/.\}���ԫs��f�����g���U6�"���UrjM���b�5<i����Uj=N-��ڌz+�eg5��[]g��Ad�f��z6p��MO�����ge���OK��`��P\F1���\SH�S��Hx�#[<zf�pG��<♓��`'F �L#��9�9lr4�19�Cd=�~)�`Cq����Ll�u�@��
          als Ergänzung
          mqtt läuft im docker auf dem Unraid und im iobroker als client
          • Wal
            @crunchip ,
            was hast du für eine Version installiert, da er diese Datenpunkte nicht mehr erstellen sollte ?
            Installiere mal über Github.
              @wal ganz normal aus dem Repo
              hab ich, allerdings bekomm ich dieses, der Adapter stürzt kontinuierlich ab
              host.IoBroker
              2023-11-26 22:13:16.866	info	Restart adapter system.adapter.frigate.0 because enabled
              host.IoBroker
              2023-11-26 22:13:16.865	error	instance system.adapter.frigate.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
              frigate.0
              2023-11-26 22:13:16.371	info	terminating
              frigate.0
              2023-11-26 22:13:15.867	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
              frigate.0
              2023-11-26 22:13:15.864	info	terminating
              frigate.0
              2023-11-26 22:13:15.822	error	Cannot read properties of null (reading 'val')
              frigate.0
              2023-11-26 22:13:15.820	error	TypeError: Cannot read properties of null (reading 'val') at Frigate.onEventChange (/opt/iobroker/node_modules/iobroker.frigate/main.js:322:39)
              frigate.0
              2023-11-26 22:13:15.818	error	unhandled promise rejection: Cannot read properties of null (reading 'val')
              frigate.0
              2023-11-26 22:13:15.816	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
              frigate.0
              2023-11-26 22:13:01.160	info	MQTT Frigate URL: http://10.1.1.219:5000
              frigate.0
              2023-11-26 22:13:01.158	info	MQTT Frigate Object: mqtt.0.frigate
              frigate.0
              2023-11-26 22:13:01.117	info	starting. Version 0.2.6 (non-npm: Bettman66/ioBroker.frigate) in /opt/iobroker/node_modules/iobroker.frigate, node: v18.18.2, js-controller: 5.0.16
              host.IoBroker
              2023-11-26 22:12:56.755	info	instance system.adapter.frigate.0 started with pid 3318229
              host.IoBroker
              2023-11-26 22:12:55.635	info	"system.adapter.frigate.0" enabled
              host.IoBroker
              2023-11-26 22:12:51.255	info	"system.adapter.frigate.0" disabled
              diese Datenpunkte/Fehlermeldungen sind zwar jetzt weg, dafür fehlt mir jetzt eine Cam
              4 waren eingebunden, es tauchen aber nur noch 3 in den Objekte auf und Adapter stürzt immer wieder ab
              hab auch nochmal gelöscht und per Github Link installiert, brachte den selben Fehler aber die 4 cam ist nach wie vor nicht da, in den mqtt Objekten ist sie aber vorhanden
              • Wal
                @crunchip ,
                schalte den frigate Adapter mal in den Debugmodus und poste bitte den Log.
                  @wal
                  2023-11-27 10:48:00.049 - info: host.IoBroker "system.adapter.frigate.0" enabled
                  2023-11-27 10:48:01.164 - info: host.IoBroker instance system.adapter.frigate.0 started with pid 3603597
                  2023-11-27 10:48:02.353 - debug: frigate.0 (3603597) Redis Objects: Use Redis connection: 127.0.0.1:9001
                  2023-11-27 10:48:02.444 - debug: frigate.0 (3603597) Objects client ready ... initialize now
                  2023-11-27 10:48:02.484 - debug: frigate.0 (3603597) Objects create System PubSub Client
                  2023-11-27 10:48:02.486 - debug: frigate.0 (3603597) Objects create User PubSub Client
                  2023-11-27 10:48:02.865 - debug: frigate.0 (3603597) Objects client initialize lua scripts
                  2023-11-27 10:48:02.872 - debug: frigate.0 (3603597) Objects connected to redis: 127.0.0.1:9001
                  2023-11-27 10:48:02.978 - debug: frigate.0 (3603597) Redis States: Use Redis connection: 127.0.0.1:9000
                  2023-11-27 10:48:03.075 - debug: frigate.0 (3603597) States create System PubSub Client
                  2023-11-27 10:48:03.078 - debug: frigate.0 (3603597) States create User PubSub Client
                  2023-11-27 10:48:03.463 - debug: frigate.0 (3603597) States connected to redis: 127.0.0.1:9000
                  2023-11-27 10:48:05.530 - info: frigate.0 (3603597) starting. Version 0.2.6 (non-npm: Bettman66/ioBroker.frigate#7062e2ceb9142495619cb210daf0190bd87dbfe4) in /opt/iobroker/node_modules/iobroker.frigate, node: v18.18.2, js-controller: 5.0.16
                  2023-11-27 10:48:05.569 - info: frigate.0 (3603597) MQTT Frigate Object: mqtt.0.frigate
                  2023-11-27 10:48:05.572 - info: frigate.0 (3603597) MQTT Frigate URL: http://10.1.1.219:5000/
                  2023-11-27 10:48:18.156 - debug: frigate.0 (3603597) id: mqtt.0.frigate.stats changed: {"Haustuer": {"camera_fps": 5.1, "process_fps": 5.0, "skipped_fps": 0.0, "detection_fps": 4.5, "detection_enabled": 1, "pid": 731, "capture_pid": 737, "ffmpeg_pid": 742}, "Terrasse": {"camera_fps": 5.0, "process_fps": 5.1, "skipped_fps": 0.0, "detection_fps": 0.0, "detection_enabled": 1, "pid": 733, "capture_pid": 740, "ffmpeg_pid": 750}, "Schlafzimmer": {"camera_fps": 5.1, "process_fps": 5.1, "skipped_fps": 0.0, "detection_fps": 0.1, "detection_enabled": 1, "pid": 734, "capture_pid": 745, "ffmpeg_pid": 754}, "Buero": {"camera_fps": 5.1, "process_fps": 5.1, "skipped_fps": 0.0, "detection_fps": 1.1, "detection_enabled": 1, "pid": 735, "capture_pid": 753, "ffmpeg_pid": 761}, "detectors": {"cpu1": {"inference_speed": 35.03, "detection_start": 0.0, "pid": 720}, "cpu2": {"inference_speed": 32.76, "detection_start": 0.0, "pid": 722}, "cpu3": {"inference_speed": 36.27, "detection_start": 1701078493.863862, "pid": 724}, "cpu4": {"inference_speed": 34.9, "detection_start": 0.0, "pid": 726}}, "detection_fps": 5.7, "gpu_usages": {"amd-vaapi": {"gpu": "1.67 %", "mem": "53.87 %"}}, "cpu_usages": {"top": {"cpu": "users,", "mem": "load"}, "Tasks:": {"cpu": "stopped,", "mem": "0"}, "%Cpu(s):": {"cpu": "id,", "mem": "0.2"}, "MiB": {"cpu": "24378.4", "mem": "avail"}, "PID": {"cpu": "%CPU", "mem": "%MEM"}, "722": {"cpu": "8.0", "mem": "0.4"}, "731": {"cpu": "6.3", "mem": "0.5"}, "745": {"cpu": "2.7", "mem": "0.3"}, "754": {"cpu": "3.3", "mem": "0.4"}, "1": {"cpu": "0.0", "mem": "0.0"}, "15": {"cpu": "0.0", "mem": "0.0"}, "17": {"cpu": "0.0", "mem": "0.0"}, "24": {"cpu": "0.0", "mem": "0.0"}, "25": {"cpu": "0.0", "mem": "0.0"}, "26": {"cpu": "0.0", "mem": "0.0"}, "27": {"cpu": "0.0", "mem": "0.0"}, "28": {"cpu": "0.0", "mem": "0.0"}, "29": {"cpu": "0.0", "mem": "0.0"}, "30": {"cpu": "0.0", "mem": "0.0"}, "31": {"cpu": "0.0", "mem": "0.0"}, "32": {"cpu": "0.0", "mem": "0.0"}, "41": {"cpu": "0.0", "mem": "0.0"}, "42": {"cpu": "0.0", "mem": "0.0"}, "80": {"cpu": "0.0", "mem": "0.0"}, "81": {"cpu": "0.0", "mem": "0.0"}, "82": {"cpu": "0.0", "mem": "0.0"}, "88": {"cpu": "0.0", "mem": "0.1"}, "97": {"cpu": "0.0", "mem": "0.0"}, "98": {"cpu": "2.0", "mem": "0.8"}, "113": {"cpu": "0.0", "mem": "0.0"}, "134": {"cpu": "0.0", "mem": "0.0"}, "135": {"cpu": "0.0", "mem": "0.0"}, "136": {"cpu": "0.0", "mem": "0.0"}, "137": {"cpu": "0.0", "mem": "0.0"}, "138": {"cpu": "0.0", "mem": "0.0"}, "143": {"cpu": "0.0", "mem": "0.0"}, "160": {"cpu": "0.0", "mem": "0.0"}, "191": {"cpu": "0.0", "mem": "0.0"}, "232": {"cpu": "0.0", "mem": "0.1"}, "267": {"cpu": "0.0", "mem": "0.0"}, "314": {"cpu": "0.0", "mem": "0.0"}, "358": {"cpu": "0.0", "mem": "0.0"}, "392": {"cpu": "0.0", "mem": "0.0"}, "419": {"cpu": "0.0", "mem": "0.0"}, "441": {"cpu": "0.0", "mem": "0.0"}, "483": {"cpu": "0.0", "mem": "0.0"}, "713": {"cpu": "0.0", "mem": "0.3"}, "719": {"cpu": "0.0", "mem": "0.0"}, "720": {"cpu": "8.0", "mem": "0.4"}, "724": {"cpu": "8.0", "mem": "0.4"}, "726": {"cpu": "12.0", "mem": "0.4"}, "728": {"cpu": "1.3", "mem": "0.3"}, "732": {"cpu": "0.0", "mem": "0.1"}, "733": {"cpu": "0.7", "mem": "0.5"}, "734": {"cpu": "0.3", "mem": "0.4"}, "735": {"cpu": "0.7", "mem": "0.5"}, "736": {"cpu": "0.0", "mem": "0.1"}, "737": {"cpu": "2.7", "mem": "0.3"}, "740": {"cpu": "3.0", "mem": "0.3"}, "741": {"cpu": "0.0", "mem": "0.1"}, "742": {"cpu": "4.3", "mem": "0.4"}, "750": {"cpu": "3.3", "mem": "0.4"}, "751": {"cpu": "0.0", "mem": "0.1"}, "752": {"cpu": "0.3", "mem": "0.1"}, "753": {"cpu": "3.0", "mem": "0.3"}, "761": {"cpu": "4.3", "mem": "0.4"}, "762": {"cpu": "0.7", "mem": "0.1"}, "763": {"cpu": "0.0", "mem": "0.1"}, "772": {"cpu": "0.3", "mem": "0.1"}, "11808": {"cpu": "0.0", "mem": "0.0"}, "11836": {"cpu": "0.0", "mem": "0.0"}, "11838": {"cpu": "0.0", "mem": "0.0"}}, "service": {"uptime": 22069, "version": "0.12.1-367d724", "latest_version": "0.12.1", "storage": {"/media/frigate/recordings": {"total": 5024751.3, "used": 182616.8, "free": 4837359.0, "mount_type": "fuse.shfs"}, "/media/frigate/clips": {"total": 5024751.3, "used": 182616.8, "free": 4837359.0, "mount_type": "fuse.shfs"}, "/tmp/cache": {"total": 1000.0, "used": 2.6, "free": 997.4, "mount_type": "tmpfs"}, "/dev/shm": {"total": 268.4, "used": 14.5, "free": 253.9, "mount_type": "tmpfs"}}, "temperatures": {}, "last_updated": 1701078498}} (ack = false)
                  2023-11-27 10:48:18.159 - debug: frigate.0 (3603597) changed: {"Haustuer": {"camera_fps": 5.1, "process_fps": 5.0, "skipped_fps": 0.0, "detection_fps": 4.5, "detection_enabled": 1, "pid": 731, "capture_pid": 737, "ffmpeg_pid": 742}, "Terrasse": {"camera_fps": 5.0, "process_fps": 5.1, "skipped_fps": 0.0, "detection_fps": 0.0, "detection_enabled": 1, "pid": 733, "capture_pid": 740, "ffmpeg_pid": 750}, "Schlafzimmer": {"camera_fps": 5.1, "process_fps": 5.1, "skipped_fps": 0.0, "detection_fps": 0.1, "detection_enabled": 1, "pid": 734, "capture_pid": 745, "ffmpeg_pid": 754}, "Buero": {"camera_fps": 5.1, "process_fps": 5.1, "skipped_fps": 0.0, "detection_fps": 1.1, "detection_enabled": 1, "pid": 735, "capture_pid": 753, "ffmpeg_pid": 761}, "detectors": {"cpu1": {"inference_speed": 35.03, "detection_start": 0.0, "pid": 720}, "cpu2": {"inference_speed": 32.76, "detection_start": 0.0, "pid": 722}, "cpu3": {"inference_speed": 36.27, "detection_start": 1701078493.863862, "pid": 724}, "cpu4": {"inference_speed": 34.9, "detection_start": 0.0, "pid": 726}}, "detection_fps": 5.7, "gpu_usages": {"amd-vaapi": {"gpu": "1.67 %", "mem": "53.87 %"}}, "cpu_usages": {"top": {"cpu": "users,", "mem": "load"}, "Tasks:": {"cpu": "stopped,", "mem": "0"}, "%Cpu(s):": {"cpu": "id,", "mem": "0.2"}, "MiB": {"cpu": "24378.4", "mem": "avail"}, "PID": {"cpu": "%CPU", "mem": "%MEM"}, "722": {"cpu": "8.0", "mem": "0.4"}, "731": {"cpu": "6.3", "mem": "0.5"}, "745": {"cpu": "2.7", "mem": "0.3"}, "754": {"cpu": "3.3", "mem": "0.4"}, "1": {"cpu": "0.0", "mem": "0.0"}, "15": {"cpu": "0.0", "mem": "0.0"}, "17": {"cpu": "0.0", "mem": "0.0"}, "24": {"cpu": "0.0", "mem": "0.0"}, "25": {"cpu": "0.0", "mem": "0.0"}, "26": {"cpu": "0.0", "mem": "0.0"}, "27": {"cpu": "0.0", "mem": "0.0"}, "28": {"cpu": "0.0", "mem": "0.0"}, "29": {"cpu": "0.0", "mem": "0.0"}, "30": {"cpu": "0.0", "mem": "0.0"}, "31": {"cpu": "0.0", "mem": "0.0"}, "32": {"cpu": "0.0", "mem": "0.0"}, "41": {"cpu": "0.0", "mem": "0.0"}, "42": {"cpu": "0.0", "mem": "0.0"}, "80": {"cpu": "0.0", "mem": "0.0"}, "81": {"cpu": "0.0", "mem": "0.0"}, "82": {"cpu": "0.0", "mem": "0.0"}, "88": {"cpu": "0.0", "mem": "0.1"}, "97": {"cpu": "0.0", "mem": "0.0"}, "98": {"cpu": "2.0", "mem": "0.8"}, "113": {"cpu": "0.0", "mem": "0.0"}, "134": {"cpu": "0.0", "mem": "0.0"}, "135": {"cpu": "0.0", "mem": "0.0"}, "136": {"cpu": "0.0", "mem": "0.0"}, "137": {"cpu": "0.0", "mem": "0.0"}, "138": {"cpu": "0.0", "mem": "0.0"}, "143": {"cpu": "0.0", "mem": "0.0"}, "160": {"cpu": "0.0", "mem": "0.0"}, "191": {"cpu": "0.0", "mem": "0.0"}, "232": {"cpu": "0.0", "mem": "0.1"}, "267": {"cpu": "0.0", "mem": "0.0"}, "314": {"cpu": "0.0", "mem": "0.0"}, "358": {"cpu": "0.0", "mem": "0.0"}, "392": {"cpu": "0.0", "mem": "0.0"}, "419": {"cpu": "0.0", "mem": "0.0"}, "441": {"cpu": "0.0", "mem": "0.0"}, "483": {"cpu": "0.0", "mem": "0.0"}, "713": {"cpu": "0.0", "mem": "0.3"}, "719": {"cpu": "0.0", "mem": "0.0"}, "720": {"cpu": "8.0", "mem": "0.4"}, "724": {"cpu": "8.0", "mem": "0.4"}, "726": {"cpu": "12.0", "mem": "0.4"}, "728": {"cpu": "1.3", "mem": "0.3"}, "732": {"cpu": "0.0", "mem": "0.1"}, "733": {"cpu": "0.7", "mem": "0.5"}, "734": {"cpu": "0.3", "mem": "0.4"}, "735": {"cpu": "0.7", "mem": "0.5"}, "736": {"cpu": "0.0", "mem": "0.1"}, "737": {"cpu": "2.7", "mem": "0.3"}, "740": {"cpu": "3.0", "mem": "0.3"}, "741": {"cpu": "0.0", "mem": "0.1"}, "742": {"cpu": "4.3", "mem": "0.4"}, "750": {"cpu": "3.3", "mem": "0.4"}, "751": {"cpu": "0.0", "mem": "0.1"}, "752": {"cpu": "0.3", "mem": "0.1"}, "753": {"cpu": "3.0", "mem": "0.3"}, "761": {"cpu": "4.3", "mem": "0.4"}, "762": {"cpu": "0.7", "mem": "0.1"}, "763": {"cpu": "0.0", "mem": "0.1"}, "772": {"cpu": "0.3", "mem": "0.1"}, "11808": {"cpu": "0.0", "mem": "0.0"}, "11836": {"cpu": "0.0", "mem": "0.0"}, "11838": {"cpu": "0.0", "mem": "0.0"}}, "service": {"uptime": 22069, "version": "0.12.1-367d724", "latest_version": "0.12.1", "storage": {"/media/frigate/recordings": {"total": 5024751.3, "used": 182616.8, "free": 4837359.0, "mount_type": "fuse.shfs"}, "/media/frigate/clips": {"total": 5024751.3, "used": 182616.8, "free": 4837359.0, "mount_type": "fuse.shfs"}, "/tmp/cache": {"total": 1000.0, "used": 2.6, "free": 997.4, "mount_type": "tmpfs"}, "/dev/shm": {"total": 268.4, "used": 14.5, "free": 253.9, "mount_type": "tmpfs"}}, "temperatures": {}, "last_updated": 1701078498}}
                  2023-11-27 10:48:18.161 - debug: frigate.0 (3603597) {"total":5024751.3,"used":182616.8,"free":4837359,"mount_type":"fuse.shfs"}
                  2023-11-27 10:48:18.425 - debug: frigate.0 (3603597) {"total":5024751.3,"used":182616.8,"free":4837359,"mount_type":"fuse.shfs"}
                  2023-11-27 10:48:18.609 - debug: frigate.0 (3603597) {"total":1000,"used":2.6,"free":997.4,"mount_type":"tmpfs"}
                  2023-11-27 10:48:18.709 - debug: frigate.0 (3603597) {"total":268.4,"used":14.5,"free":253.9,"mount_type":"tmpfs"}
                  2023-11-27 10:48:24.116 - debug: frigate.0 (3603597) id: mqtt.0.frigate.Terrasse.motion changed: ON (ack = false)
                  2023-11-27 10:48:24.121 - debug: frigate.0 (3603597) onObjectChange -> id: mqtt.0.frigate.Terrasse.motion changed: ON (ack = false)
                  2023-11-27 10:48:24.123 - debug: frigate.0 (3603597) Object available: [object Object] type: string
                  2023-11-27 10:48:33.858 - debug: frigate.0 (3603597) id: mqtt.0.frigate.Schlafzimmer.motion changed: OFF (ack = false)
                  2023-11-27 10:48:33.863 - debug: frigate.0 (3603597) onObjectChange -> id: mqtt.0.frigate.Schlafzimmer.motion changed: OFF (ack = false)
                  2023-11-27 10:48:33.865 - debug: frigate.0 (3603597) Object available: [object Object] type: string
                  2023-11-27 10:48:56.056 - debug: frigate.0 (3603597) id: mqtt.0.frigate.events changed: {"before": {"id": "1701078201.815111-ch00l6", "camera": "Buero", "frame_time": 1701078483.19947, "snapshot_time": 1701078422.014361, "label": "person", "sub_label": null, "top_score": 0.84375, "false_positive": false, "start_time": 1701078201.815111, "end_time": null, "score": 0.75390625, "box": [407, 281, 943, 850], "area": 304984, "ratio": 0.9420035149384886, "region": [301, 211, 1001, 911], "stationary": true, "motionless_count": 1398, "position_changes": 1, "current_zones": [], "entered_zones": [], "has_clip": true, "has_snapshot": false}, "after": {"id": "1701078201.815111-ch00l6", "camera": "Buero", "frame_time": 1701078535.798322, "snapshot_time": 1701078535.798322, "label": "person", "sub_label": null, "top_score": 0.84375, "false_positive": false, "start_time": 1701078201.815111, "end_time": null, "score": 0.84375, "box": [417, 245, 897, 810], "area": 271200, "ratio": 0.8495575221238938, "region": [168, 32, 1216, 1080], "stationary": true, "motionless_count": 1661, "position_changes": 1, "current_zones": [], "entered_zones": [], "has_clip": true, "has_snapshot": false}, "type": "update"} (ack = false)
                  2023-11-27 10:48:56.063 - error: frigate.0 (3603597) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                  2023-11-27 10:48:56.065 - error: frigate.0 (3603597) unhandled promise rejection: Cannot read properties of null (reading 'val')
                  2023-11-27 10:48:56.066 - error: frigate.0 (3603597) TypeError: Cannot read properties of null (reading 'val')
                  2023-11-27 10:48:56.067 - error: frigate.0 (3603597) Cannot read properties of null (reading 'val')
                  2023-11-27 10:48:56.071 - info: frigate.0 (3603597) terminating
                  2023-11-27 10:48:56.073 - warn: frigate.0 (3603597) Terminated (UNCAUGHT_EXCEPTION): Without reason
                  2023-11-27 10:48:56.576 - info: frigate.0 (3603597) terminating
                  2023-11-27 10:48:56.896 - error: host.IoBroker instance system.adapter.frigate.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                  2023-11-27 10:48:56.897 - info: host.IoBroker Restart adapter system.adapter.frigate.0 because enabled
                  2023-11-27 10:49:27.317 - info: host.IoBroker instance system.adapter.frigate.0 started with pid 3604227
                  2023-11-27 10:49:28.609 - debug: frigate.0 (3604227) Redis Objects: Use Redis connection: 127.0.0.1:9001
                  2023-11-27 10:49:28.711 - debug: frigate.0 (3604227) Objects client ready ... initialize now
                  2023-11-27 10:49:28.714 - debug: frigate.0 (3604227) Objects create System PubSub Client
                  2023-11-27 10:49:28.716 - debug: frigate.0 (3604227) Objects create User PubSub Client
                  2023-11-27 10:49:28.885 - debug: frigate.0 (3604227) Objects client initialize lua scripts
                  2023-11-27 10:49:28.892 - debug: frigate.0 (3604227) Objects connected to redis: 127.0.0.1:9001
                  2023-11-27 10:49:28.999 - debug: frigate.0 (3604227) Redis States: Use Redis connection: 127.0.0.1:9000
                  2023-11-27 10:49:29.133 - debug: frigate.0 (3604227) States create System PubSub Client
                  2023-11-27 10:49:29.135 - debug: frigate.0 (3604227) States create User PubSub Client
                  2023-11-27 10:49:29.481 - debug: frigate.0 (3604227) States connected to redis: 127.0.0.1:9000
                  2023-11-27 10:49:31.782 - info: frigate.0 (3604227) starting. Version 0.2.6 (non-npm: Bettman66/ioBroker.frigate#7062e2ceb9142495619cb210daf0190bd87dbfe4) in
                  Wal 2 Replies Last reply Reply Quote 0
                  • Wal
                    @crunchip ,
                    danke ich kann den Fehler nachvollziehen, ich kümmere mich drum.
                    • Wal
                      Wal Developer @crunchip last edited by Wal
                      @crunchip ,
                      schau mal ob es bei dir die Objekte "frigate.0.Buero.snapshots.state" und "frigate.0.Buero.recordings.state" gibt und der Wert muss Boolean sein.
                      Hintergrund:
                      Wenn ich dein Json eingebe ohne das es die Objekte gibt, bekomme ich den Error.
                      Ändere ich den Kameranamen in deinem Json in einem von meinen Kameras, bekomme ich kein Error.
                        @wal irgendwie fehl da einiges
                        komisch ist aber, als ich zuerst direkt aus dem Repo installiert hatte, gab es diesbezüglich kein Fehler und alle Datenpunkte waren vorhanden
                          martinschm last edited by
                          Hi @Wal
                          Mir ist aufgefallen, das hier in der URL zweimal ein "/" vorkommt und die URL daher nicht funktioniert
                          Liegt das an Frigate oder kommt das aus dem Adapter ?
                          • Wal
                            Wal Developer @martinschm last edited by
                            @martinschm sagte in Test Frigate Adapter 0.2.5:
                            Schau mal in der Adapter Config, da hast du bestimmt bei Frigate Url ein "/" am Ende stehen.
                              martinschm @Wal last edited by
                              @wal said in Test Frigate Adapter 0.2.5:
                              Eigentlich nicht. Sieht bei mir so aus
                              • Wal
                                Wal Developer @martinschm last edited by Wal
                                @martinschm ,
                                das wäre so richtig, ich schaue nochmal drüber an was es liegen könnte.
                                Edit: sehe gerade das ich das auch habe, aber die Links funktionieren bei mir.
                                Du hast quasi ein Bug gefunden.👍
                                Edit: Installiere nochmal über Github, müsste jetzt funktionieren.
                                crunchip 1 Reply Last reply Reply Quote 1
                                  • hab ich jetzt auch mal
                                  • Links haben noch den //, funktionieren aber
                                  zum besagten Fehler, der blieb bzw war einmalig beim Neustart des Adapters.
                                  • ich hatte zwischenzeitlich in der Gui sämtliche toogle mal de/aktiviert und bin auch mal vor jede cam gelaufen, dadurch tauchten auch sämtliche Datenpunkte nun auf.
                                  • Ein anschließender Neustart des Adapters verursachte dann keinen Fehler mehr.
                                  • hab den Adapter gestoppt
                                  • im Objektbaum mal alle Datenpunkte gelöscht und Adapter neu gestartet
                                  • nur frigate.0.stats wurde angelegt, der Rest blieb aus
                                  • Bewegung vor der cam, erschien frigate.0.Buero.motion aber sonst wird nichts angelegt auch nach längerem warten
                                  • Neustart des mqtt Adapters und zack, sind alle Datenpunkte unter frigate.0 vorhanden
                                  • Neustart des frigate Adapters kein Fehler mehr
                                  Schlussfolgerung
                                  Timing / mqtt Adapter Problem(falsche Einstellung)?
                                  • Wal
                                    @crunchip sagte in Test Frigate Adapter 0.2.5:
                                    Ja habe ich auch so jetzt festgestellt. Werden die Datenpunkte im MQTT Adapter schon erstellt ohne das der Frigate Adapter läuft, gibt es danach ein Problem.
                                    Ich muss beim erstellen oder starten der Frigate Instanz erst alle Datenpunkte aus dem MQTT Adapter auslesen, damit die Objekte synchron sind oder ich muss einen eigenen MQTT Server einbauen was aber wieder einen neuen Port bedeutet. Mal sehen wie ich das mache.
                                    crunchip MartinP 2 Replies Last reply Reply Quote 0
                                    • Wal
                                      @crunchip ,
                                      habe eine Lösung gefunden.
                                      Ich fange den Fehler ab und bringe im Log eine Meldung den MQTT Broker neu zu starten.
                                      Kannst du das mal testen ?
                                      Einmal Github bitte.
                                        ja und die waren ja bei meinem Test nach wie vor vorhanden im mqtt Adapter
                                        kann ich machen, also
                                        • frigate Adapter stoppen, Objekte löschen, von git installieren und danach starten?
                                        • oder soll ich mqtt auch noch mal löschen?
                                        Wal 1 Reply Last reply Reply Quote 1
                                        • Wal
                                          @crunchip ,
                                          nein MQTT nicht löschen.
                                            @wal ok, sieht so aus
                                            figate.0
                                            2023-11-28 15:17:58.660	info	restart MQTT Broker please !!!
                                            frigate.0
                                            2023-11-28 15:17:53.487	info	restart MQTT Broker please !!!
                                            frigate.0
                                            2023-11-28 15:17:48.275	info	restart MQTT Broker please !!!
                                            frigate.0
                                            2023-11-28 15:17:40.447	info	restart MQTT Broker please !!!
                                            frigate.0
                                            2023-11-28 15:17:35.479	info	restart MQTT Broker please !!!
                                            frigate.0
                                            2023-11-28 15:17:30.442	info	restart MQTT Broker please !!!
                                            frigate.0
                                            2023-11-28 15:17:25.468	info	restart MQTT Broker please !!!
                                            frigate.0
                                            2023-11-28 15:17:20.139	info	restart MQTT Broker please !!!
                                            frigate.0
                                            2023-11-28 15:17:13.054	info	restart MQTT Broker please !!!
                                            frigate.0
                                            2023-11-28 15:17:10.229	info	restart MQTT Broker please !!!
                                            frigate.0
                                            2023-11-28 15:16:09.913	info	restart MQTT Broker please !!!
                                            frigate.0
                                            2023-11-28 15:15:39.643	info	MQTT Frigate URL: http://10.1.1.219:5000/
                                            frigate.0
                                            2023-11-28 15:15:39.641	info	MQTT Frigate Object: mqtt.0.frigate
                                            frigate.0
                                            2023-11-28 15:15:39.602	info	starting. Version 0.2.6 (non-npm: Bettman66/ioBroker.frigate#72d8fc0bd18a7463eab0c312d5778b477c3e7436) in /opt/iobroker/node_modules/iobroker.frigate, node: v18.18.2, js-controller: 5.0.16
                                            host.IoBroker
                                            2023-11-28 15:15:34.277	info	instance system.adapter.frigate.0 started with pid 606808
                                            host.IoBroker
                                            2023-11-28 15:15:33.513	info	"system.adapter.frigate.0" enabled
                                            mqtt neu gestartet
                                            host.IoBroker
                                            2023-11-28 15:20:30.179	info	instance system.adapter.mqtt.0 started with pid 608938
                                            host.IoBroker
                                            2023-11-28 15:20:27.345	info	instance system.adapter.mqtt.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                            host.IoBroker
                                            2023-11-28 15:20:26.883	info	stopInstance system.adapter.mqtt.0 send kill signal
                                            host.IoBroker
                                            2023-11-28 15:20:26.506	info	stopInstance system.adapter.mqtt.0 (force=false, process=true)
                                            frigate.0
                                            2023-11-28 15:20:13.051	info	restart MQTT Broker please !!!
                                            frigate.0
                                            2023-11-28 15:19:12.601	info	restart MQTT Broker please !!!
                                            frigate.0
                                            2023-11-28 15:19:02.459	info	restart MQTT Broker please !!!
                                            frigate.0
                                            2023-11-28 15:18:42.688	info	restart MQTT Broker please !!!
                                            367
                                            98856
