    4. Test Adapter MercedesMe v0.0.x
    • wendy2702
      wendy2702 @tombox last edited by
      @tombox Ja,
      das liegt wahrscheinlich an einem der aktuellen Probleme die das Fahrzeug hat. Kann gerade auch per App nichts machen.
        kiste01 @wendy2702 last edited by
        der Adapter ist heute dauerhaft rot
        host.iobroker
        2023-11-19 16:20:47.165	error	instance system.adapter.mercedesme.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        host.iobroker
        2023-11-19 16:20:47.165	error	Caught by controller[0]: Node.js v18.18.2
        host.iobroker
        2023-11-19 16:20:47.165	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1256:14)
        host.iobroker
        2023-11-19 16:20:47.164	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.mercedesme/main.js:16:25)
        host.iobroker
        2023-11-19 16:20:47.164	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:119:18)
        host.iobroker
        2023-11-19 16:20:47.164	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1143:19)
        host.iobroker
        2023-11-19 16:20:47.164	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:960:12)
        host.iobroker
        2023-11-19 16:20:47.164	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1119:32)
        host.iobroker
        2023-11-19 16:20:47.164	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
        host.iobroker
        2023-11-19 16:20:47.164	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1220:27)
        host.iobroker
        2023-11-19 16:20:47.164	error	Caught by controller[0]: at wrapSafe (node:internal/modules/cjs/loader:1178:20)
        host.iobroker
        2023-11-19 16:20:47.164	error	Caught by controller[0]: at internalCompileFunction (node:internal/vm:73:18)
        host.iobroker
        2023-11-19 16:20:47.164	error	Caught by controller[0]: SyntaxError: missing ) after argument list
        host.iobroker
        2023-11-19 16:20:47.164	error	Caught by controller[0]: ^
        host.iobroker
        2023-11-19 16:20:47.163	error	Caught by controller[0]: return jspb.Message.setOneofWrapperField(this, 38, proto.proto.CmmandRequest.oneofGroups_[0], value);
        host.iobroker
        2023-11-19 16:20:47.163	error	Caught by controller[0]: /opt/iobroker/node_modules/iobroker.mercedesme/Proto/vehicle-commands_pb.js:3679
        host.iobroker
        2023-11-19 16:20:46.244	info	instance system.adapter.mercedesme.0 started with pid 933538
        host.iobroker
        2023-11-19 16:20:15.949	info	Restart adapter system.adapter.mercedesme.0 because enabled
          tombox @kiste01 last edited by
          @kiste01 Kann ich nicht nachvollziehen.. neuinstallierten bringt nichts?
            kiste01 @tombox last edited by
            @tombox
            na gut, das wollte ich zwar vermeiden, aber hab's gemacht. Es kommen nach Adapterstart 2-3 Emails mit dem Code. Trotz mehrerer Versuche wird der Code nicht akzeptiert.
            mercedesme.0
            2023-11-19 20:06:24.895	error	Login was not successful.
            mercedesme.0
            2023-11-19 20:06:24.895	error	""
            mercedesme.0
            2023-11-19 20:06:24.895	error	AxiosError: Request failed with status code 429
            mercedesme.0
            2023-11-19 20:06:24.894	error	Not able to request login code
            mercedesme.0
            2023-11-19 20:06:24.440	info	starting. Version 0.1.3 (non-npm: TA2k/ioBroker.mercedesme) in /opt/iobroker/node_modules/iobroker.mercedesme, node: v18.18.2, js-controller: 5.0.16
              @kiste01 429 bedeutet zu oft falsch eingegeben jetzt musst du abwarten
                @tombox
                Ok. Läuft wieder.
                  ThePhantom79 last edited by ThePhantom79
                  ich nutze die Integrtion, um über MQTT Werte auszulesen (in meine Loxone).
                  Ich würde nun aber auch gerne aktiv einen Befehl setzen : Vorklimatisierung.
                  1. Kann mir jemand sagen, welche Variable ich hier anfassen muss? Es gibt so viele ähnliche - unter remote oder unter command. Wenn ich direkt im IoBroker auf den "Button" drücke, schaltet die Klimatisierung sogar an - aber wenn ich das in MQTT sehe, gibt's da unzählige Variablen plötzlich.
                  2. Hat das schon jemand mit MQTT im Einsatz? Kann mir jemand einen Tipp geben, wie der Publish Befehl auszusehen hat?
                  Für meine anderen MQTT Geräte sieht der in etwa so aus:
                  publish bestway/set {"filter_power": 1}
                    tombox @ThePhantom79 last edited by
                    @thephantom79 start_val = true sollte funktionieren
                      Also in der IOBroker Oberfläche klappt es mit dem Button
                      mercedesme/0/xxxxxx/commands/ZEV PRECONDITIONING STOP/start
                      Leider bekomme ich diesen "Button" von außen nicht angesteuert ...
                      • wendy2702
                        ich bin gerade dabei die oder den richtigen Datenpunkt zur Aktivierung der Vorklimatisierung zu suchen.
                        Habe keine E Auto aber eine Standheizung und Sitzheizung. Habe unter remote folgende Objekte:
                        Weiss jemand was der Unterschied zwischen AuxHeat und Vorklimatisierung ist?
                        Sind das die richtigen Objekte oder muss ich unter commands gucken?
                        Bei dem Datenpunkt der einen Beitrag vorher erwähnt ist, habe ich keinen "Start", da heisst der Ordner so:
                        Oder welchen von denen muss man wie ändern?
                          tombox @wendy2702 last edited by
                          @wendy2702 unter command schauen welche isAvailable = true haben und dann gibt es auch ein Start Objekt
                          • wendy2702
                            @tombox Danke für die schnelle Antwort.
                            Dann muss ich das scheinbar über die Remote Objekte machen.
                            Hast du geplant die Zeitangaben in den Objekten in ein lesbares Format umzurechnen? Aktuell ist es ja Unix Timestamp:
                              @wendy2702 Remote Objekte macht nichts anderes als ein command aufzurufen
                              Ich kann den Datentyp anpassen das es besser angezeigt wird aber den Inhalt werde ich nicht anpassen da er auch so in der vis verwendet werden kann
                              • wendy2702
                                @tombox ne, das passt schon so für mich.
                                Ich wollte ja nur wissen ob du planst die Timestamps im Adapter umzurechnen damit im Objekt ein sofort lesbares Format steht.
                                  @wendy2702 in der GitHub version wird die rolle von timestampInMs korrekt gesetzt
                                    martin @tombox last edited by
                                    Mich würden mal eure Views zu diesem Adapter interessieren und ob ihr die evtl. auch zur Verfügung stellen würdet.
                                    Ich suche noch was schönes für meinen GLE.
                                    • wendy2702
                                      Muss nochmal fragen ob jemand den Unterschied bei Remote zwischen "Auxheat = Standheizung" und "Vorklimatisierung = Precondition" kennt bzw. welche Auswahl in der App die beiden entsprechen?
                                      Und was verbirgt sich hinter dem Commands "40"
                                      XBiT 1 Reply Last reply Reply Quote 0
                                      • XBiT
                                        XBiT @wendy2702 last edited by
                                        @wendy2702
                                        ist "Vorklimatisierung" vielleicht die Funktion die auch beim öffnen vom Auto gestartet wird und die Lüftung an geht (wenn es warm ist).
                                          bishop9191 @XBiT last edited by
                                          @xbit
                                          Ich würde davon ausgehen, dass Vorklimatisierung die Funktion bei den EQ-Modellen ist.
                                          • H-a-m-i
                                            H-a-m-i last edited by
                                            Guten Morgen,
                                            ich habe seit heut morgen das Problem, dass der Adapter nur noch gelb bleibt. Auch im Log wirft er einige Fehler raus, u.A. AxiosError: Request failed with status code 418. Den Fehler gab es hier wohl letztes Jahr im November schon mal und konnte dort wohl durch ein Update behoben werden. Mein Adapter scheint mit Version v0.1.3 aber aktuell zu sein.
                                            Der iobroker läuft bei mir seit zwei Wochen auf einem frisch aufgesetzten und aktuellem Raspberry Pi OS, bisher ohne Probleme.
                                            Hier mal die Fehler die der Adapter auswirft, das waren die ersten Fehler heute morgen:
                                            2023-12-14 08:46:08.685 - info: mercedesme.0 (139217) Lost WebSocket connection. Reconnect WebSocket
                                            2023-12-14 08:46:10.866 - error: mercedesme.0 (139217) Websocket parse error
                                            2023-12-14 08:46:10.867 - error: mercedesme.0 (139217) Error: Failure: Invalid wire type: %s (at position %s)
                                            2023-12-14 08:46:16.038 - error: mercedesme.0 (139217) Websocket parse error
                                            2023-12-14 08:46:16.039 - error: mercedesme.0 (139217) Error: Failure: Invalid wire type: %s (at position %s)
                                            2023-12-14 08:46:21.188 - error: mercedesme.0 (139217) Websocket parse error
                                            2023-12-14 08:46:21.189 - error: mercedesme.0 (139217) Error: Failure: Invalid wire type: %s (at position %s)
                                            2023-12-14 08:47:26.343 - info: mercedesme.0 (139217) Lost WebSocket connection. Reconnect WebSocket
                                            2023-12-14 08:47:28.515 - error: mercedesme.0 (139217) Websocket parse error
                                            2023-12-14 08:47:28.516 - error: mercedesme.0 (139217) Error: Failure: Invalid wire type: %s (at position %s)
                                            2023-12-14 08:47:33.665 - error: mercedesme.0 (139217) Websocket parse error
                                            2023-12-14 08:47:33.665 - error: mercedesme.0 (139217) Error: Assertion failed
                                            Das steht so alle ein bis zwei Minuten im Log. Und wenn ich den Adapter neustarte bzw. den Token erneuere:
                                            2023-12-14 09:47:20.255 - error: mercedesme.0 (156851) AxiosError: Request failed with status code 418
                                            2023-12-14 09:47:20.256 - error: mercedesme.0 (156851) ""
                                            2023-12-14 09:47:20.261 - info: mercedesme.0 (156851) Start Websocket Connection
                                            2023-12-14 09:48:20.457 - info: mercedesme.0 (156851) Lost WebSocket connection. Reconnect WebSocket
                                            2023-12-14 09:49:22.627 - info: mercedesme.0 (156851) Lost WebSocket connection. Reconnect WebSocket
                                            2023-12-14 09:49:24.797 - error: mercedesme.0 (156851) Error: Assertion failed
                                            mercedes
                                            120
                                            929
                                            231099
