    4. Frigate Adapter für ioBroker
    • Wal
      Wal Developer @crunchip last edited by
      @crunchip ,
      was hast du für eine Version installiert, da er diese Datenpunkte nicht mehr erstellen sollte ?
      Installiere mal über Github.
        crunchip Forum Testing Most Active @Wal last edited by crunchip
        @wal ganz normal aus dem Repo
        @wal sagte in Test Frigate Adapter 0.2.5:
        hab ich, allerdings bekomm ich dieses, der Adapter stürzt kontinuierlich ab
        host.IoBroker
        2023-11-26 22:13:16.866	info	Restart adapter system.adapter.frigate.0 because enabled
        host.IoBroker
        2023-11-26 22:13:16.865	error	instance system.adapter.frigate.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
        frigate.0
        2023-11-26 22:13:16.371	info	terminating
        frigate.0
        2023-11-26 22:13:15.867	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
        frigate.0
        2023-11-26 22:13:15.864	info	terminating
        frigate.0
        2023-11-26 22:13:15.822	error	Cannot read properties of null (reading 'val')
        frigate.0
        2023-11-26 22:13:15.820	error	TypeError: Cannot read properties of null (reading 'val') at Frigate.onEventChange (/opt/iobroker/node_modules/iobroker.frigate/main.js:322:39)
        frigate.0
        2023-11-26 22:13:15.818	error	unhandled promise rejection: Cannot read properties of null (reading 'val')
        frigate.0
        2023-11-26 22:13:15.816	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        frigate.0
        2023-11-26 22:13:01.160	info	MQTT Frigate URL: http://10.1.1.219:5000
        frigate.0
        2023-11-26 22:13:01.158	info	MQTT Frigate Object: mqtt.0.frigate
        frigate.0
        2023-11-26 22:13:01.117	info	starting. Version 0.2.6 (non-npm: Bettman66/ioBroker.frigate) in /opt/iobroker/node_modules/iobroker.frigate, node: v18.18.2, js-controller: 5.0.16
        host.IoBroker
        2023-11-26 22:12:56.755	info	instance system.adapter.frigate.0 started with pid 3318229
        host.IoBroker
        2023-11-26 22:12:55.635	info	"system.adapter.frigate.0" enabled
        host.IoBroker
        2023-11-26 22:12:51.255	info	"system.adapter.frigate.0" disabled
        diese Datenpunkte/Fehlermeldungen sind zwar jetzt weg, dafür fehlt mir jetzt eine Cam
        4 waren eingebunden, es tauchen aber nur noch 3 in den Objekte auf und Adapter stürzt immer wieder ab
        hab auch nochmal gelöscht und per Github Link installiert, brachte den selben Fehler aber die 4 cam ist nach wie vor nicht da, in den mqtt Objekten ist sie aber vorhanden
        • Wal
          @crunchip ,
          schalte den frigate Adapter mal in den Debugmodus und poste bitte den Log.
            @wal
            2023-11-27 10:48:00.049 - info: host.IoBroker "system.adapter.frigate.0" enabled
            2023-11-27 10:48:01.164 - info: host.IoBroker instance system.adapter.frigate.0 started with pid 3603597
            2023-11-27 10:48:02.353 - debug: frigate.0 (3603597) Redis Objects: Use Redis connection: 127.0.0.1:9001
            2023-11-27 10:48:02.444 - debug: frigate.0 (3603597) Objects client ready ... initialize now
            2023-11-27 10:48:02.484 - debug: frigate.0 (3603597) Objects create System PubSub Client
            2023-11-27 10:48:02.486 - debug: frigate.0 (3603597) Objects create User PubSub Client
            2023-11-27 10:48:02.865 - debug: frigate.0 (3603597) Objects client initialize lua scripts
            2023-11-27 10:48:02.872 - debug: frigate.0 (3603597) Objects connected to redis: 127.0.0.1:9001
            2023-11-27 10:48:02.978 - debug: frigate.0 (3603597) Redis States: Use Redis connection: 127.0.0.1:9000
            2023-11-27 10:48:03.075 - debug: frigate.0 (3603597) States create System PubSub Client
            2023-11-27 10:48:03.078 - debug: frigate.0 (3603597) States create User PubSub Client
            2023-11-27 10:48:03.463 - debug: frigate.0 (3603597) States connected to redis: 127.0.0.1:9000
            2023-11-27 10:48:05.530 - info: frigate.0 (3603597) starting. Version 0.2.6 (non-npm: Bettman66/ioBroker.frigate#7062e2ceb9142495619cb210daf0190bd87dbfe4) in /opt/iobroker/node_modules/iobroker.frigate, node: v18.18.2, js-controller: 5.0.16
            2023-11-27 10:48:05.569 - info: frigate.0 (3603597) MQTT Frigate Object: mqtt.0.frigate
            2023-11-27 10:48:05.572 - info: frigate.0 (3603597) MQTT Frigate URL: http://10.1.1.219:5000/
            2023-11-27 10:48:18.156 - debug: frigate.0 (3603597) id: mqtt.0.frigate.stats changed: {"Haustuer": {"camera_fps": 5.1, "process_fps": 5.0, "skipped_fps": 0.0, "detection_fps": 4.5, "detection_enabled": 1, "pid": 731, "capture_pid": 737, "ffmpeg_pid": 742}, "Terrasse": {"camera_fps": 5.0, "process_fps": 5.1, "skipped_fps": 0.0, "detection_fps": 0.0, "detection_enabled": 1, "pid": 733, "capture_pid": 740, "ffmpeg_pid": 750}, "Schlafzimmer": {"camera_fps": 5.1, "process_fps": 5.1, "skipped_fps": 0.0, "detection_fps": 0.1, "detection_enabled": 1, "pid": 734, "capture_pid": 745, "ffmpeg_pid": 754}, "Buero": {"camera_fps": 5.1, "process_fps": 5.1, "skipped_fps": 0.0, "detection_fps": 1.1, "detection_enabled": 1, "pid": 735, "capture_pid": 753, "ffmpeg_pid": 761}, "detectors": {"cpu1": {"inference_speed": 35.03, "detection_start": 0.0, "pid": 720}, "cpu2": {"inference_speed": 32.76, "detection_start": 0.0, "pid": 722}, "cpu3": {"inference_speed": 36.27, "detection_start": 1701078493.863862, "pid": 724}, "cpu4": {"inference_speed": 34.9, "detection_start": 0.0, "pid": 726}}, "detection_fps": 5.7, "gpu_usages": {"amd-vaapi": {"gpu": "1.67 %", "mem": "53.87 %"}}, "cpu_usages": {"top": {"cpu": "users,", "mem": "load"}, "Tasks:": {"cpu": "stopped,", "mem": "0"}, "%Cpu(s):": {"cpu": "id,", "mem": "0.2"}, "MiB": {"cpu": "24378.4", "mem": "avail"}, "PID": {"cpu": "%CPU", "mem": "%MEM"}, "722": {"cpu": "8.0", "mem": "0.4"}, "731": {"cpu": "6.3", "mem": "0.5"}, "745": {"cpu": "2.7", "mem": "0.3"}, "754": {"cpu": "3.3", "mem": "0.4"}, "1": {"cpu": "0.0", "mem": "0.0"}, "15": {"cpu": "0.0", "mem": "0.0"}, "17": {"cpu": "0.0", "mem": "0.0"}, "24": {"cpu": "0.0", "mem": "0.0"}, "25": {"cpu": "0.0", "mem": "0.0"}, "26": {"cpu": "0.0", "mem": "0.0"}, "27": {"cpu": "0.0", "mem": "0.0"}, "28": {"cpu": "0.0", "mem": "0.0"}, "29": {"cpu": "0.0", "mem": "0.0"}, "30": {"cpu": "0.0", "mem": "0.0"}, "31": {"cpu": "0.0", "mem": "0.0"}, "32": {"cpu": "0.0", "mem": "0.0"}, "41": {"cpu": "0.0", "mem": "0.0"}, "42": {"cpu": "0.0", "mem": "0.0"}, "80": {"cpu": "0.0", "mem": "0.0"}, "81": {"cpu": "0.0", "mem": "0.0"}, "82": {"cpu": "0.0", "mem": "0.0"}, "88": {"cpu": "0.0", "mem": "0.1"}, "97": {"cpu": "0.0", "mem": "0.0"}, "98": {"cpu": "2.0", "mem": "0.8"}, "113": {"cpu": "0.0", "mem": "0.0"}, "134": {"cpu": "0.0", "mem": "0.0"}, "135": {"cpu": "0.0", "mem": "0.0"}, "136": {"cpu": "0.0", "mem": "0.0"}, "137": {"cpu": "0.0", "mem": "0.0"}, "138": {"cpu": "0.0", "mem": "0.0"}, "143": {"cpu": "0.0", "mem": "0.0"}, "160": {"cpu": "0.0", "mem": "0.0"}, "191": {"cpu": "0.0", "mem": "0.0"}, "232": {"cpu": "0.0", "mem": "0.1"}, "267": {"cpu": "0.0", "mem": "0.0"}, "314": {"cpu": "0.0", "mem": "0.0"}, "358": {"cpu": "0.0", "mem": "0.0"}, "392": {"cpu": "0.0", "mem": "0.0"}, "419": {"cpu": "0.0", "mem": "0.0"}, "441": {"cpu": "0.0", "mem": "0.0"}, "483": {"cpu": "0.0", "mem": "0.0"}, "713": {"cpu": "0.0", "mem": "0.3"}, "719": {"cpu": "0.0", "mem": "0.0"}, "720": {"cpu": "8.0", "mem": "0.4"}, "724": {"cpu": "8.0", "mem": "0.4"}, "726": {"cpu": "12.0", "mem": "0.4"}, "728": {"cpu": "1.3", "mem": "0.3"}, "732": {"cpu": "0.0", "mem": "0.1"}, "733": {"cpu": "0.7", "mem": "0.5"}, "734": {"cpu": "0.3", "mem": "0.4"}, "735": {"cpu": "0.7", "mem": "0.5"}, "736": {"cpu": "0.0", "mem": "0.1"}, "737": {"cpu": "2.7", "mem": "0.3"}, "740": {"cpu": "3.0", "mem": "0.3"}, "741": {"cpu": "0.0", "mem": "0.1"}, "742": {"cpu": "4.3", "mem": "0.4"}, "750": {"cpu": "3.3", "mem": "0.4"}, "751": {"cpu": "0.0", "mem": "0.1"}, "752": {"cpu": "0.3", "mem": "0.1"}, "753": {"cpu": "3.0", "mem": "0.3"}, "761": {"cpu": "4.3", "mem": "0.4"}, "762": {"cpu": "0.7", "mem": "0.1"}, "763": {"cpu": "0.0", "mem": "0.1"}, "772": {"cpu": "0.3", "mem": "0.1"}, "11808": {"cpu": "0.0", "mem": "0.0"}, "11836": {"cpu": "0.0", "mem": "0.0"}, "11838": {"cpu": "0.0", "mem": "0.0"}}, "service": {"uptime": 22069, "version": "0.12.1-367d724", "latest_version": "0.12.1", "storage": {"/media/frigate/recordings": {"total": 5024751.3, "used": 182616.8, "free": 4837359.0, "mount_type": "fuse.shfs"}, "/media/frigate/clips": {"total": 5024751.3, "used": 182616.8, "free": 4837359.0, "mount_type": "fuse.shfs"}, "/tmp/cache": {"total": 1000.0, "used": 2.6, "free": 997.4, "mount_type": "tmpfs"}, "/dev/shm": {"total": 268.4, "used": 14.5, "free": 253.9, "mount_type": "tmpfs"}}, "temperatures": {}, "last_updated": 1701078498}} (ack = false)
            2023-11-27 10:48:18.159 - debug: frigate.0 (3603597) changed: {"Haustuer": {"camera_fps": 5.1, "process_fps": 5.0, "skipped_fps": 0.0, "detection_fps": 4.5, "detection_enabled": 1, "pid": 731, "capture_pid": 737, "ffmpeg_pid": 742}, "Terrasse": {"camera_fps": 5.0, "process_fps": 5.1, "skipped_fps": 0.0, "detection_fps": 0.0, "detection_enabled": 1, "pid": 733, "capture_pid": 740, "ffmpeg_pid": 750}, "Schlafzimmer": {"camera_fps": 5.1, "process_fps": 5.1, "skipped_fps": 0.0, "detection_fps": 0.1, "detection_enabled": 1, "pid": 734, "capture_pid": 745, "ffmpeg_pid": 754}, "Buero": {"camera_fps": 5.1, "process_fps": 5.1, "skipped_fps": 0.0, "detection_fps": 1.1, "detection_enabled": 1, "pid": 735, "capture_pid": 753, "ffmpeg_pid": 761}, "detectors": {"cpu1": {"inference_speed": 35.03, "detection_start": 0.0, "pid": 720}, "cpu2": {"inference_speed": 32.76, "detection_start": 0.0, "pid": 722}, "cpu3": {"inference_speed": 36.27, "detection_start": 1701078493.863862, "pid": 724}, "cpu4": {"inference_speed": 34.9, "detection_start": 0.0, "pid": 726}}, "detection_fps": 5.7, "gpu_usages": {"amd-vaapi": {"gpu": "1.67 %", "mem": "53.87 %"}}, "cpu_usages": {"top": {"cpu": "users,", "mem": "load"}, "Tasks:": {"cpu": "stopped,", "mem": "0"}, "%Cpu(s):": {"cpu": "id,", "mem": "0.2"}, "MiB": {"cpu": "24378.4", "mem": "avail"}, "PID": {"cpu": "%CPU", "mem": "%MEM"}, "722": {"cpu": "8.0", "mem": "0.4"}, "731": {"cpu": "6.3", "mem": "0.5"}, "745": {"cpu": "2.7", "mem": "0.3"}, "754": {"cpu": "3.3", "mem": "0.4"}, "1": {"cpu": "0.0", "mem": "0.0"}, "15": {"cpu": "0.0", "mem": "0.0"}, "17": {"cpu": "0.0", "mem": "0.0"}, "24": {"cpu": "0.0", "mem": "0.0"}, "25": {"cpu": "0.0", "mem": "0.0"}, "26": {"cpu": "0.0", "mem": "0.0"}, "27": {"cpu": "0.0", "mem": "0.0"}, "28": {"cpu": "0.0", "mem": "0.0"}, "29": {"cpu": "0.0", "mem": "0.0"}, "30": {"cpu": "0.0", "mem": "0.0"}, "31": {"cpu": "0.0", "mem": "0.0"}, "32": {"cpu": "0.0", "mem": "0.0"}, "41": {"cpu": "0.0", "mem": "0.0"}, "42": {"cpu": "0.0", "mem": "0.0"}, "80": {"cpu": "0.0", "mem": "0.0"}, "81": {"cpu": "0.0", "mem": "0.0"}, "82": {"cpu": "0.0", "mem": "0.0"}, "88": {"cpu": "0.0", "mem": "0.1"}, "97": {"cpu": "0.0", "mem": "0.0"}, "98": {"cpu": "2.0", "mem": "0.8"}, "113": {"cpu": "0.0", "mem": "0.0"}, "134": {"cpu": "0.0", "mem": "0.0"}, "135": {"cpu": "0.0", "mem": "0.0"}, "136": {"cpu": "0.0", "mem": "0.0"}, "137": {"cpu": "0.0", "mem": "0.0"}, "138": {"cpu": "0.0", "mem": "0.0"}, "143": {"cpu": "0.0", "mem": "0.0"}, "160": {"cpu": "0.0", "mem": "0.0"}, "191": {"cpu": "0.0", "mem": "0.0"}, "232": {"cpu": "0.0", "mem": "0.1"}, "267": {"cpu": "0.0", "mem": "0.0"}, "314": {"cpu": "0.0", "mem": "0.0"}, "358": {"cpu": "0.0", "mem": "0.0"}, "392": {"cpu": "0.0", "mem": "0.0"}, "419": {"cpu": "0.0", "mem": "0.0"}, "441": {"cpu": "0.0", "mem": "0.0"}, "483": {"cpu": "0.0", "mem": "0.0"}, "713": {"cpu": "0.0", "mem": "0.3"}, "719": {"cpu": "0.0", "mem": "0.0"}, "720": {"cpu": "8.0", "mem": "0.4"}, "724": {"cpu": "8.0", "mem": "0.4"}, "726": {"cpu": "12.0", "mem": "0.4"}, "728": {"cpu": "1.3", "mem": "0.3"}, "732": {"cpu": "0.0", "mem": "0.1"}, "733": {"cpu": "0.7", "mem": "0.5"}, "734": {"cpu": "0.3", "mem": "0.4"}, "735": {"cpu": "0.7", "mem": "0.5"}, "736": {"cpu": "0.0", "mem": "0.1"}, "737": {"cpu": "2.7", "mem": "0.3"}, "740": {"cpu": "3.0", "mem": "0.3"}, "741": {"cpu": "0.0", "mem": "0.1"}, "742": {"cpu": "4.3", "mem": "0.4"}, "750": {"cpu": "3.3", "mem": "0.4"}, "751": {"cpu": "0.0", "mem": "0.1"}, "752": {"cpu": "0.3", "mem": "0.1"}, "753": {"cpu": "3.0", "mem": "0.3"}, "761": {"cpu": "4.3", "mem": "0.4"}, "762": {"cpu": "0.7", "mem": "0.1"}, "763": {"cpu": "0.0", "mem": "0.1"}, "772": {"cpu": "0.3", "mem": "0.1"}, "11808": {"cpu": "0.0", "mem": "0.0"}, "11836": {"cpu": "0.0", "mem": "0.0"}, "11838": {"cpu": "0.0", "mem": "0.0"}}, "service": {"uptime": 22069, "version": "0.12.1-367d724", "latest_version": "0.12.1", "storage": {"/media/frigate/recordings": {"total": 5024751.3, "used": 182616.8, "free": 4837359.0, "mount_type": "fuse.shfs"}, "/media/frigate/clips": {"total": 5024751.3, "used": 182616.8, "free": 4837359.0, "mount_type": "fuse.shfs"}, "/tmp/cache": {"total": 1000.0, "used": 2.6, "free": 997.4, "mount_type": "tmpfs"}, "/dev/shm": {"total": 268.4, "used": 14.5, "free": 253.9, "mount_type": "tmpfs"}}, "temperatures": {}, "last_updated": 1701078498}}
            2023-11-27 10:48:18.161 - debug: frigate.0 (3603597) {"total":5024751.3,"used":182616.8,"free":4837359,"mount_type":"fuse.shfs"}
            2023-11-27 10:48:18.425 - debug: frigate.0 (3603597) {"total":5024751.3,"used":182616.8,"free":4837359,"mount_type":"fuse.shfs"}
            2023-11-27 10:48:18.609 - debug: frigate.0 (3603597) {"total":1000,"used":2.6,"free":997.4,"mount_type":"tmpfs"}
            2023-11-27 10:48:18.709 - debug: frigate.0 (3603597) {"total":268.4,"used":14.5,"free":253.9,"mount_type":"tmpfs"}
            2023-11-27 10:48:24.116 - debug: frigate.0 (3603597) id: mqtt.0.frigate.Terrasse.motion changed: ON (ack = false)
            2023-11-27 10:48:24.121 - debug: frigate.0 (3603597) onObjectChange -> id: mqtt.0.frigate.Terrasse.motion changed: ON (ack = false)
            2023-11-27 10:48:24.123 - debug: frigate.0 (3603597) Object available: [object Object] type: string
            2023-11-27 10:48:33.858 - debug: frigate.0 (3603597) id: mqtt.0.frigate.Schlafzimmer.motion changed: OFF (ack = false)
            2023-11-27 10:48:33.863 - debug: frigate.0 (3603597) onObjectChange -> id: mqtt.0.frigate.Schlafzimmer.motion changed: OFF (ack = false)
            2023-11-27 10:48:33.865 - debug: frigate.0 (3603597) Object available: [object Object] type: string
            2023-11-27 10:48:56.056 - debug: frigate.0 (3603597) id: mqtt.0.frigate.events changed: {"before": {"id": "1701078201.815111-ch00l6", "camera": "Buero", "frame_time": 1701078483.19947, "snapshot_time": 1701078422.014361, "label": "person", "sub_label": null, "top_score": 0.84375, "false_positive": false, "start_time": 1701078201.815111, "end_time": null, "score": 0.75390625, "box": [407, 281, 943, 850], "area": 304984, "ratio": 0.9420035149384886, "region": [301, 211, 1001, 911], "stationary": true, "motionless_count": 1398, "position_changes": 1, "current_zones": [], "entered_zones": [], "has_clip": true, "has_snapshot": false}, "after": {"id": "1701078201.815111-ch00l6", "camera": "Buero", "frame_time": 1701078535.798322, "snapshot_time": 1701078535.798322, "label": "person", "sub_label": null, "top_score": 0.84375, "false_positive": false, "start_time": 1701078201.815111, "end_time": null, "score": 0.84375, "box": [417, 245, 897, 810], "area": 271200, "ratio": 0.8495575221238938, "region": [168, 32, 1216, 1080], "stationary": true, "motionless_count": 1661, "position_changes": 1, "current_zones": [], "entered_zones": [], "has_clip": true, "has_snapshot": false}, "type": "update"} (ack = false)
            2023-11-27 10:48:56.063 - error: frigate.0 (3603597) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            2023-11-27 10:48:56.065 - error: frigate.0 (3603597) unhandled promise rejection: Cannot read properties of null (reading 'val')
            2023-11-27 10:48:56.066 - error: frigate.0 (3603597) TypeError: Cannot read properties of null (reading 'val')
            2023-11-27 10:48:56.067 - error: frigate.0 (3603597) Cannot read properties of null (reading 'val')
            2023-11-27 10:48:56.071 - info: frigate.0 (3603597) terminating
            2023-11-27 10:48:56.073 - warn: frigate.0 (3603597) Terminated (UNCAUGHT_EXCEPTION): Without reason
            2023-11-27 10:48:56.576 - info: frigate.0 (3603597) terminating
            2023-11-27 10:48:56.896 - error: host.IoBroker instance system.adapter.frigate.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
            2023-11-27 10:48:56.897 - info: host.IoBroker Restart adapter system.adapter.frigate.0 because enabled
            2023-11-27 10:49:27.317 - info: host.IoBroker instance system.adapter.frigate.0 started with pid 3604227
            2023-11-27 10:49:28.609 - debug: frigate.0 (3604227) Redis Objects: Use Redis connection: 127.0.0.1:9001
            2023-11-27 10:49:28.711 - debug: frigate.0 (3604227) Objects client ready ... initialize now
            2023-11-27 10:49:28.714 - debug: frigate.0 (3604227) Objects create System PubSub Client
            2023-11-27 10:49:28.716 - debug: frigate.0 (3604227) Objects create User PubSub Client
            2023-11-27 10:49:28.885 - debug: frigate.0 (3604227) Objects client initialize lua scripts
            2023-11-27 10:49:28.892 - debug: frigate.0 (3604227) Objects connected to redis: 127.0.0.1:9001
            2023-11-27 10:49:28.999 - debug: frigate.0 (3604227) Redis States: Use Redis connection: 127.0.0.1:9000
            2023-11-27 10:49:29.133 - debug: frigate.0 (3604227) States create System PubSub Client
            2023-11-27 10:49:29.135 - debug: frigate.0 (3604227) States create User PubSub Client
            2023-11-27 10:49:29.481 - debug: frigate.0 (3604227) States connected to redis: 127.0.0.1:9000
            2023-11-27 10:49:31.782 - info: frigate.0 (3604227) starting. Version 0.2.6 (non-npm: Bettman66/ioBroker.frigate#7062e2ceb9142495619cb210daf0190bd87dbfe4) in
            Wal 2 Replies Last reply Reply Quote 0
            • Wal
              @crunchip ,
              danke ich kann den Fehler nachvollziehen, ich kümmere mich drum.
              • Wal
                Wal Developer @crunchip last edited by Wal
                @crunchip ,
                schau mal ob es bei dir die Objekte "frigate.0.Buero.snapshots.state" und "frigate.0.Buero.recordings.state" gibt und der Wert muss Boolean sein.
                Hintergrund:
                Wenn ich dein Json eingebe ohne das es die Objekte gibt, bekomme ich den Error.
                Ändere ich den Kameranamen in deinem Json in einem von meinen Kameras, bekomme ich kein Error.
                  @wal irgendwie fehl da einiges
                  komisch ist aber, als ich zuerst direkt aus dem Repo installiert hatte, gab es diesbezüglich kein Fehler und alle Datenpunkte waren vorhanden
                    martinschm last edited by
                    Hi @Wal
                    Mir ist aufgefallen, das hier in der URL zweimal ein "/" vorkommt und die URL daher nicht funktioniert
                    Liegt das an Frigate oder kommt das aus dem Adapter ?
                    • Wal
                      Wal Developer @martinschm last edited by
                      @martinschm sagte in Test Frigate Adapter 0.2.5:
                      Schau mal in der Adapter Config, da hast du bestimmt bei Frigate Url ein "/" am Ende stehen.
                        martinschm @Wal last edited by
                        @wal said in Test Frigate Adapter 0.2.5:
                        Eigentlich nicht. Sieht bei mir so aus
                        • Wal
                          Wal Developer @martinschm last edited by Wal
                          @martinschm ,
                          das wäre so richtig, ich schaue nochmal drüber an was es liegen könnte.
                          Edit: sehe gerade das ich das auch habe, aber die Links funktionieren bei mir.
                          Du hast quasi ein Bug gefunden.👍
                          Edit: Installiere nochmal über Github, müsste jetzt funktionieren.
                          crunchip 1 Reply Last reply Reply Quote 1
                            • hab ich jetzt auch mal
                            • Links haben noch den //, funktionieren aber
                            zum besagten Fehler, der blieb bzw war einmalig beim Neustart des Adapters.
                            • ich hatte zwischenzeitlich in der Gui sämtliche toogle mal de/aktiviert und bin auch mal vor jede cam gelaufen, dadurch tauchten auch sämtliche Datenpunkte nun auf.
                            • Ein anschließender Neustart des Adapters verursachte dann keinen Fehler mehr.
                            • hab den Adapter gestoppt
                            • im Objektbaum mal alle Datenpunkte gelöscht und Adapter neu gestartet
                            • nur frigate.0.stats wurde angelegt, der Rest blieb aus
                            • Bewegung vor der cam, erschien frigate.0.Buero.motion aber sonst wird nichts angelegt auch nach längerem warten
                            • Neustart des mqtt Adapters und zack, sind alle Datenpunkte unter frigate.0 vorhanden
                            • Neustart des frigate Adapters kein Fehler mehr
                            Schlussfolgerung
                            Timing / mqtt Adapter Problem(falsche Einstellung)?
                            • Wal
                              @crunchip sagte in Test Frigate Adapter 0.2.5:
                              Ja habe ich auch so jetzt festgestellt. Werden die Datenpunkte im MQTT Adapter schon erstellt ohne das der Frigate Adapter läuft, gibt es danach ein Problem.
                              Ich muss beim erstellen oder starten der Frigate Instanz erst alle Datenpunkte aus dem MQTT Adapter auslesen, damit die Objekte synchron sind oder ich muss einen eigenen MQTT Server einbauen was aber wieder einen neuen Port bedeutet. Mal sehen wie ich das mache.
                              crunchip MartinP 2 Replies Last reply Reply Quote 0
                              • Wal
                                @crunchip ,
                                habe eine Lösung gefunden.
                                Ich fange den Fehler ab und bringe im Log eine Meldung den MQTT Broker neu zu starten.
                                Kannst du das mal testen ?
                                Einmal Github bitte.
                                  ja und die waren ja bei meinem Test nach wie vor vorhanden im mqtt Adapter
                                  kann ich machen, also
                                  • frigate Adapter stoppen, Objekte löschen, von git installieren und danach starten?
                                  • oder soll ich mqtt auch noch mal löschen?
                                  Wal 1 Reply Last reply Reply Quote 1
                                  • Wal
                                    @crunchip ,
                                    nein MQTT nicht löschen.
                                      @wal ok, sieht so aus
                                      figate.0
                                      2023-11-28 15:17:58.660	info	restart MQTT Broker please !!!
                                      frigate.0
                                      2023-11-28 15:17:53.487	info	restart MQTT Broker please !!!
                                      frigate.0
                                      2023-11-28 15:17:48.275	info	restart MQTT Broker please !!!
                                      frigate.0
                                      2023-11-28 15:17:40.447	info	restart MQTT Broker please !!!
                                      frigate.0
                                      2023-11-28 15:17:35.479	info	restart MQTT Broker please !!!
                                      frigate.0
                                      2023-11-28 15:17:30.442	info	restart MQTT Broker please !!!
                                      frigate.0
                                      2023-11-28 15:17:25.468	info	restart MQTT Broker please !!!
                                      frigate.0
                                      2023-11-28 15:17:20.139	info	restart MQTT Broker please !!!
                                      frigate.0
                                      2023-11-28 15:17:13.054	info	restart MQTT Broker please !!!
                                      frigate.0
                                      2023-11-28 15:17:10.229	info	restart MQTT Broker please !!!
                                      frigate.0
                                      2023-11-28 15:16:09.913	info	restart MQTT Broker please !!!
                                      frigate.0
                                      2023-11-28 15:15:39.643	info	MQTT Frigate URL: http://10.1.1.219:5000/
                                      frigate.0
                                      2023-11-28 15:15:39.641	info	MQTT Frigate Object: mqtt.0.frigate
                                      frigate.0
                                      2023-11-28 15:15:39.602	info	starting. Version 0.2.6 (non-npm: Bettman66/ioBroker.frigate#72d8fc0bd18a7463eab0c312d5778b477c3e7436) in /opt/iobroker/node_modules/iobroker.frigate, node: v18.18.2, js-controller: 5.0.16
                                      host.IoBroker
                                      2023-11-28 15:15:34.277	info	instance system.adapter.frigate.0 started with pid 606808
                                      host.IoBroker
                                      2023-11-28 15:15:33.513	info	"system.adapter.frigate.0" enabled
                                      mqtt neu gestartet
                                      host.IoBroker
                                      2023-11-28 15:20:30.179	info	instance system.adapter.mqtt.0 started with pid 608938
                                      host.IoBroker
                                      2023-11-28 15:20:27.345	info	instance system.adapter.mqtt.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                      host.IoBroker
                                      2023-11-28 15:20:26.883	info	stopInstance system.adapter.mqtt.0 send kill signal
                                      host.IoBroker
                                      2023-11-28 15:20:26.506	info	stopInstance system.adapter.mqtt.0 (force=false, process=true)
                                      frigate.0
                                      2023-11-28 15:20:13.051	info	restart MQTT Broker please !!!
                                      frigate.0
                                      2023-11-28 15:19:12.601	info	restart MQTT Broker please !!!
                                      frigate.0
                                      2023-11-28 15:19:02.459	info	restart MQTT Broker please !!!
                                      frigate.0
                                      2023-11-28 15:18:42.688	info	restart MQTT Broker please !!!
                                        MrHenker27 @crunchip last edited by
                                        moin.
                                        wie kann ich mit Blockly den letzten Snapshot in in Telegramm senden? Hat da jemand mal ein Beispiel.
                                        Bei den Objekten ist ja im mqtt was zu finden. ( mqtt.0.frigate.Kamera_hinten.person.snapshot )
                                        Die Kamera variiert ja wie auch das Objekt ( Person, Bird, Cat ) .....
                                        Marco
                                        crunchip Wal 2 Replies Last reply Reply Quote 0
                                          crunchip Forum Testing Most Active @MrHenker27 last edited by crunchip
                                          @mrhenker27 weiter oben ist ein Beispiel
                                          https://forum.iobroker.net/post/1065896
                                          oder direkt von der cam bei Ereignis
                                          • Wal
                                            Wal Developer @MrHenker27 last edited by Wal
                                            @mrhenker27 ,
                                            hier hatte ich ein Javascript gepostet.
                                            Und hier der Link für die Frigate Snapshot Api.
                                            367
                                            98771
