    2. English
    3. Visualization
    4. Node-Red Adapter: Error: EACCES: permission denied
    • Bit Mage
      Bit Mage last edited by
      Hello,
      I am using a Linux system with IO-Broker and Node-Red.
      iobroker V6.10.1
      node-red v4.0.3
      I created a ".json" on my linux system under "/home/bitmage/x.json". I am trying to read the file inside Node-Red and I am always getting the following fault: "Error: EACCES: permission denied, open '/home/bitmage/x.json'".
      I did not find any solution in the internet. I opened a post on Node-red forum, but the community said I should ask here, because it seems to be a permission thing of the iobroker.
      My target is to read a .json file with the "read file" node and use the information in node-red.
      I saw this post here: Node-red-contrib-persist on DietPi : EACCES: permission denied, open '/root/data/persistence.json' - #46 by devifast
      but my /mnt folder is empty.
      Thank you in advance
        Thomas Braun Most Active @Bit Mage last edited by
        @bit-mage
        Put it in /home/iobroker and change the owner of the file to iobroker:iobroker.
        Bit Mage 1 Reply Last reply Reply Quote 1
        • Bit Mage
          Bit Mage @Thomas Braun last edited by
          First of all thank you for your reply. Really cool from you.
          When I try to move the file into the folder "/home/iobroker" my linux system says "permission denied".
          I then tried the sudo chown command for the file and the the new user and group is now iobroker:iobroker.
          I can see it in my terminal that the user has changed correctly.
          However I still can not move the file into the path: "/home/iobroker".
          Do you know what I am missing?
          Bit Mage Thomas Braun 2 Replies Last reply Reply Quote 0
          • Bit Mage
            Bit Mage @Bit Mage last edited by
            @bit-mage @Thomas-Braun
            Ahhh I found out by myself and it is working now!
            I used the command " sudo mv" command to move the file 🙂
            YOU ARE A GIANT! TYVM!
            Bit Mage 1 Reply Last reply Reply Quote 0
              @bit-mage sagte in Node-Red Adapter: Error: EACCES: permission denied:
              Proper rights...
              Your user 'bitmage' should be member of group 'iobroker' and therefore able to write into /home/iobroker.
              Check it:
              groups
              as user 'bitmage' gives?
              • Bit Mage
                You dont accept crypto as donation?
                We all use crypto, right?
                • Bit Mage
                  @thomas-braun Thank you - i added the user now too 🙂 Everything is working and I can read the file. Awesome 🙂
