    4. deconz App unter Ubuntu wird nicht angezeigt
      smarti2015 @Thomas Braun last edited by smarti2015
      Skript v.2023-10-25
      *** BASE SYSTEM ***
       Static hostname: deconz
             Icon name: computer-vm
               Chassis: vm
        Virtualization: kvm
      Operating System: Ubuntu 22.04.3 LTS
                Kernel: Linux 5.15.0-89-generic
          Architecture: x86-64
       Hardware Vendor: QEMU
        Hardware Model: Standard PC _i440FX + PIIX, 1996_
      model name      : QEMU Virtual CPU version 2.5+
      Docker          : false
      Virtualization  : kvm
      Kernel          : x86_64
      Userland        : amd64
      Systemuptime and Load:
       14:11:59 up  4:16,  2 users,  load average: 0.00, 0.00, 0.00
      CPU threads: 4
      *** Time and Time Zones ***
                     Local time: Mon 2023-11-27 14:11:59 CET
                 Universal time: Mon 2023-11-27 13:11:59 UTC
                       RTC time: Mon 2023-11-27 13:11:58
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      root
      /root
      root dialout
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:
      *** MEMORY ***
      Mem:            3.9G        227M        3.3G        1.0M        380M        3.5G
      Swap:           3.1G          0B        3.1G
      Total:          7.0G        227M        6.4G
               3911 M total memory
                227 M used memory
                151 M active memory
                293 M inactive memory
               3303 M free memory
                 21 M buffer memory
                358 M swap cache
               3061 M total swap
                  0 M used swap
               3061 M free swap
      *** FAILED SERVICES ***
        UNIT                  LOAD   ACTIVE SUB    DESCRIPTION
      * deconz-init.service   loaded failed failed deCONZ: ZigBee gateway -- Initialisation
      * deconz-update.service loaded failed failed deCONZ: ZigBee gateway -- Update Service
      LOAD   = Reflects whether the unit definition was properly loaded.
      ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
      SUB    = The low-level unit activation state, values depend on unit type.
      2 loaded units listed.
      *** FILESYSTEM ***
      Filesystem                        Type   Size  Used Avail Use% Mounted on
      tmpfs                             tmpfs  392M  1.1M  391M   1% /run
      /dev/mapper/ubuntu--vg-ubuntu--lv ext4    15G  6.4G  7.6G  46% /
      tmpfs                             tmpfs  2.0G     0  2.0G   0% /dev/shm
      tmpfs                             tmpfs  5.0M     0  5.0M   0% /run/lock
      /dev/sda2                         ext4   2.0G  129M  1.7G   8% /boot
      tmpfs                             tmpfs  392M  4.0K  392M   1% /run/user/1000
      [Mon Nov 27 09:55:09 2023] EXT4-fs (dm-0): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
      [Mon Nov 27 09:55:09 2023] EXT4-fs (dm-0): re-mounted. Opts: (null). Quota mode: none.
      [Mon Nov 27 09:55:10 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
      Show mounted filesystems:
      TARGET                                        SOURCE                            FSTYPE      OPTIONS
      /                                             /dev/mapper/ubuntu--vg-ubuntu--lv ext4        rw,relatime
      |-/sys                                        sysfs                             sysfs       rw,nosuid,nodev,noexec,relatime
      | |-/sys/kernel/security                      securityfs                        securityfs  rw,nosuid,nodev,noexec,relatime
      | |-/sys/fs/cgroup                            cgroup2                           cgroup2     rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
      | |-/sys/fs/pstore                            pstore                            pstore      rw,nosuid,nodev,noexec,relatime
      | |-/sys/fs/bpf                               bpf                               bpf         rw,nosuid,nodev,noexec,relatime,mode=700
      | |-/sys/kernel/debug                         debugfs                           debugfs     rw,nosuid,nodev,noexec,relatime
      | |-/sys/kernel/tracing                       tracefs                           tracefs     rw,nosuid,nodev,noexec,relatime
      | |-/sys/fs/fuse/connections                  fusectl                           fusectl     rw,nosuid,nodev,noexec,relatime
      | `-/sys/kernel/config                        configfs                          configfs    rw,nosuid,nodev,noexec,relatime
      |-/proc                                       proc                              proc        rw,nosuid,nodev,noexec,relatime
      | `-/proc/sys/fs/binfmt_misc                  systemd-1                         autofs      rw,relatime,fd=29,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=15212
      |   `-/proc/sys/fs/binfmt_misc                binfmt_misc                       binfmt_misc rw,nosuid,nodev,noexec,relatime
      |-/dev                                        udev                              devtmpfs    rw,nosuid,relatime,size=1944712k,nr_inodes=486178,mode=755,inode64
      | |-/dev/pts                                  devpts                            devpts      rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
      | |-/dev/shm                                  tmpfs                             tmpfs       rw,nosuid,nodev,inode64
      | |-/dev/hugepages                            hugetlbfs                         hugetlbfs   rw,relatime,pagesize=2M
      | `-/dev/mqueue                               mqueue                            mqueue      rw,nosuid,nodev,noexec,relatime
      |-/run                                        tmpfs                             tmpfs       rw,nosuid,nodev,noexec,relatime,size=400540k,mode=755,inode64
      | |-/run/lock                                 tmpfs                             tmpfs       rw,nosuid,nodev,noexec,relatime,size=5120k,inode64
      | |-/run/credentials/systemd-sysusers.service none                              ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
      | |-/run/snapd/ns                             tmpfs[/snapd/ns]                  tmpfs       rw,nosuid,nodev,noexec,relatime,size=400540k,mode=755,inode64
      | | `-/run/snapd/ns/lxd.mnt                   nsfs[mnt:[4026532309]]            nsfs        rw
      | `-/run/user/1000                            tmpfs                             tmpfs       rw,nosuid,nodev,relatime,size=400536k,nr_inodes=100134,mode=700,uid=1000,gid=1000,inode64
      |-/snap/snapd/20290                           /dev/loop0                        squashfs    ro,nodev,relatime,errors=continue
      |-/snap/core20/2015                           /dev/loop2                        squashfs    ro,nodev,relatime,errors=continue
      |-/snap/lxd/24322                             /dev/loop1                        squashfs    ro,nodev,relatime,errors=continue
      |-/snap/snapd/19457                           /dev/loop3                        squashfs    ro,nodev,relatime,errors=continue
      |-/snap/core20/1974                           /dev/loop4                        squashfs    ro,nodev,relatime,errors=continue
      `-/boot                                       /dev/sda2                         ext4        rw,relatime
      /var:
      684M    /var/
      551M    /var/lib
      335M    /var/lib/snapd
      229M    /var/lib/snapd/seed/snaps
      Archived and active journals take up 24.0M in the file system.
      /opt/iobroker/backups:
      du: cannot access '/opt/iobroker/backups/': No such file or directory
      /opt/iobroker/iobroker-data:
      du: cannot access '/opt/iobroker/iobroker-data/': No such file or directory
      find: '/opt/iobroker/iobroker-data': No such file or directory
      USB-Devices by-id:
      /dev/serial/by-id/usb-dresden_elektronik_ConBee_III_DE03110757-if00-port0
      *** NodeJS-Installation ***
      ./iob_diag: line 283: nodejs: command not found
      ./iob_diag: line 284: node: command not found
      ./iob_diag: line 285: npm: command not found
      ./iob_diag: line 286: npx: command not found
      ./iob_diag: line 287: corepack: command not found
      ./iob_diag: line 294: nodejs: command not found
      ./iob_diag: line 295: node: command not found
      ./iob_diag: line 296: npm: command not found
      ./iob_diag: line 297: npx: command not found
      *** nodejs is NOT correctly installed ***
      Run ob nodejs-update to fix it.
      nodejs:
        Installed: (none)
        Candidate: 12.22.9~dfsg-1ubuntu3.2
        Version table:
           12.22.9~dfsg-1ubuntu3.2 500
              500 http://de.archive.ubuntu.com/ubuntu jammy-updates/universe amd64 Packages
              500 http://security.ubuntu.com/ubuntu jammy-security/universe amd64 Packages
           12.22.9~dfsg-1ubuntu3 500
              500 http://de.archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
      find: '/opt/iobroker/node_modules': No such file or directory
      No problems detected
      Errors in npm tree:
      ./iob_diag: line 368: cd: /opt/iobroker: No such file or directory
      *** ioBroker-Installation ***
      ioBroker Status
      ./iob_diag: line 373: iobroker: command not found
      Core adapters versions
      ./iob_diag: line 379: iob: command not found
      js-controller:
      ./iob_diag: line 380: iob: command not found
      admin:
      ./iob_diag: line 381: iob: command not found
      javascript:
      ./iob_diag: line 383: cd: /opt/iobroker: No such file or directory
      Adapters from github:
      Adapter State
      ./iob_diag: line 386: iob: command not found
      ./iob_diag: line 389: iob: command not found
      ioBroker-Repositories
      ./iob_diag: line 392: iob: command not found
      Installed ioBroker-Instances
      ./iob_diag: line 395: iob: command not found
      Objects and States
      Objects:        0
      States:         0
      W: http://phoscon.de/apt/deconz/dists/jammy-beta/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
      Hit:1 http://phoscon.de/apt/deconz jammy-beta InRelease
      Hit:2 http://de.archive.ubuntu.com/ubuntu jammy InRelease
      Hit:3 http://de.archive.ubuntu.com/ubuntu jammy-updates InRelease
      Hit:4 http://de.archive.ubuntu.com/ubuntu jammy-backports InRelease
      Hit:5 http://security.ubuntu.com/ubuntu jammy-security InRelease
      Reading package lists... Done
      Pending Updates: 0
      *** Listening Ports ***
      Netid               State                Recv-Q               Send-Q                               Local Address:Port                               Peer Address:Port               Process
      udp                 UNCONN               0                    0                                          0.0.0.0:1900                                    0.0.0.0:*                   users:(("deCONZ",pid=680,fd=11))
      udp                 UNCONN               0                    0                                    127.0.0.53%lo:53                                      0.0.0.0:*                   users:(("systemd-resolve",pid=663,fd=13))
      tcp                 LISTEN               0                    50                                         0.0.0.0:443                                     0.0.0.0:*                   users:(("deCONZ",pid=680,fd=9))
      tcp                 LISTEN               0                    50                                         0.0.0.0:80                                      0.0.0.0:*                   users:(("deCONZ",pid=680,fd=4))
      tcp                 LISTEN               0                    4096                                 127.0.0.53%lo:53                                      0.0.0.0:*                   users:(("systemd-resolve",pid=663,fd=14))
      tcp                 LISTEN               0                    128                                        0.0.0.0:22                                      0.0.0.0:*                   users:(("sshd",pid=719,fd=3))
      tcp                 LISTEN               0                    128                                           [::]:22                                         [::]:*                   users:(("sshd",pid=719,fd=4))
      tail: cannot open '/opt/iobroker/log/iobroker.current.log' for reading: No such file or directory
      iob diag has finished.
        Thomas Braun Most Active @smarti2015 last edited by
        @smarti2015 sagte in deconz App unter Ubuntu wird nicht angezeigt:
        root
        /root
        root dialout
        Leg dir einen user an und verwende den.
        • deconz-init.service loaded failed failed deCONZ: ZigBee gateway -- Initialisation
        • deconz-update.service loaded failed failed deCONZ: ZigBee gateway -- Update Service
        Schau warum die Services nicht gestartet werden.
        systemctl status deconz*
        sagt vielleicht mehr dazu.
        Boot Target: graphical.target
        Setz das auf multi-user
        sudo systemctl default-set multi-user.target
          @thomas-braun Danke für deine Hilfe und Tipps. Lege mir einen User an und dann versuche ich die Installation nochmal neu.
          Das hier kommt bei systemctl status deconz*:
          × deconz-update.service - deCONZ: ZigBee gateway -- Update Service
               Loaded: loaded (/lib/systemd/system/deconz-update.service; disabled; vendor preset: enabled)
               Active: failed (Result: exit-code) since Mon 2023-11-27 09:55:16 CET; 6h ago
              Process: 773 ExecStart=/usr/bin/deCONZ-update2.sh (code=exited, status=203/EXEC)
             Main PID: 773 (code=exited, status=203/EXEC)
                  CPU: 496us
          Nov 27 09:55:16 deconz systemd[1]: deconz-update.service: Scheduled restart job, restart counter is at 5.
          Nov 27 09:55:16 deconz systemd[1]: Stopped deCONZ: ZigBee gateway -- Update Service.
          Nov 27 09:55:16 deconz systemd[1]: deconz-update.service: Start request repeated too quickly.
          Nov 27 09:55:16 deconz systemd[1]: deconz-update.service: Failed with result 'exit-code'.
          Nov 27 09:55:16 deconz systemd[1]: Failed to start deCONZ: ZigBee gateway -- Update Service.
          ● deconz.service - deCONZ: ZigBee gateway -- REST API
               Loaded: loaded (/lib/systemd/system/deconz.service; enabled; vendor preset: enabled)
               Active: active (running) since Mon 2023-11-27 09:55:15 CET; 6h ago
             Main PID: 680 (deCONZ)
                Tasks: 5 (limit: 4557)
               Memory: 91.0M
                  CPU: 2min 20.999s
               CGroup: /system.slice/deconz.service
                       └─680 /usr/bin/deCONZ -platform minimal --http-port=80
          Nov 27 09:55:15 deconz systemd[1]: Started deCONZ: ZigBee gateway -- REST API.
          Nov 27 09:55:15 deconz deCONZ[680]: QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-hwadmin'
          Nov 27 09:55:15 deconz deCONZ[680]: libpng warning: iCCP: known incorrect sRGB profile
          Nov 27 09:55:16 deconz deCONZ[680]: This plugin does not support propagateSizeHints()
          × deconz-init.service - deCONZ: ZigBee gateway -- Initialisation
               Loaded: loaded (/lib/systemd/system/deconz-init.service; disabled; vendor preset: enabled)
               Active: failed (Result: exit-code) since Mon 2023-11-27 09:55:15 CET; 6h ago
              Process: 678 ExecStart=/usr/bin/deCONZ-init.sh (code=exited, status=203/EXEC)
             Main PID: 678 (code=exited, status=203/EXEC)
                  CPU: 289us
          Nov 27 09:55:15 deconz systemd[1]: Starting deCONZ: ZigBee gateway -- Initialisation...
          Nov 27 09:55:15 deconz systemd[678]: deconz-init.service: Failed to locate executable /usr/bin/deCONZ-init.sh: No such file or directory
          Nov 27 09:55:15 deconz systemd[678]: deconz-init.service: Failed at step EXEC spawning /usr/bin/deCONZ-init.sh: No such file or directory
          Nov 27 09:55:15 deconz systemd[1]: deconz-init.service: Main process exited, code=exited, status=203/EXEC
          Nov 27 09:55:15 deconz systemd[1]: deconz-init.service: Failed with result 'exit-code'.
          Nov 27 09:55:15 deconz systemd[1]: Failed to start deCONZ: ZigBee gateway -- Initialisation.
          Wenn ich versuche Multi-User einzurichten mit dem Befehl kommt das hier:
          Unknown command verb default-set.
            @smarti2015
            Mein Fehler, das muss
            sudo systemctl set-default multi-user.target
            lauten.
              So, also nochmal alles frisch installiert und mit Benutzer eingerichtet. Jetzt sieht es ganz gut aus:
              Es gibt beim booten immer noch eine Fehlermeldung, das rattert aber so schnell vorbei, seh nicht was es ist.
              Am Linux-Rechner direkt konnte man ja immer über die F-Tasten nochmal in das Bootlog direkt wechseln, das geht unter Proxmox irgendwie nicht und im /var/log/syslog finde ich die Meldung nicht.
              Ich würde mal schauen, ob ich Geräte anlernen kann, vielleicht haut es hin. Ich danke dir erstmal !!!! 🙂
                Ok hier hab ich nochmal die Fehlermeldungen beim Booten:
                  @smarti2015
                  Da steht aber auch dabei wie/wo man genaueres sehen kann.
                    Kannst du mir dabei bitte helfen? Ich glaub er meldet, das eine Datei oder Verzeichnis fehltr?
                    hwadmin@deconz:/$ systemctl status deconz-init.service
                         Active: failed (Result: exit-code) since Mon 2023-11-27 16:59:54 CET; 17h ago
                        Process: 677 ExecStart=/usr/bin/deCONZ-init.sh (code=exited, status=203/EXEC)
                       Main PID: 677 (code=exited, status=203/EXEC)
                            CPU: 268us
                    Nov 27 16:59:54 deconz systemd[1]: Starting deCONZ: ZigBee gateway -- Initialisation...
                    Nov 27 16:59:54 deconz systemd[677]: deconz-init.service: Failed to locate executable /usr/bin/deCONZ-init.sh: No such file or directory
                    Nov 27 16:59:54 deconz systemd[677]: deconz-init.service: Failed at step EXEC spawning /usr/bin/deCONZ-init.sh: No such file or directory
                    Nov 27 16:59:54 deconz systemd[1]: deconz-init.service: Main process exited, code=exited, status=203/EXEC
                    Nov 27 16:59:54 deconz systemd[1]: deconz-init.service: Failed with result 'exit-code'.
                    Nov 27 16:59:54 deconz systemd[1]: Failed to start deCONZ: ZigBee gateway -- Initialisation.
                    hwadmin@deconz:/$ systemctl status deconz-update.service
                         Active: failed (Result: exit-code) since Mon 2023-11-27 16:59:55 CET; 17h ago
                        Process: 766 ExecStart=/usr/bin/deCONZ-update2.sh (code=exited, status=203/EXEC)
                       Main PID: 766 (code=exited, status=203/EXEC)
                            CPU: 495us
                    Nov 27 16:59:55 deconz systemd[1]: deconz-update.service: Scheduled restart job, restart counter is at 5.
                    Nov 27 16:59:55 deconz systemd[1]: Stopped deCONZ: ZigBee gateway -- Update Service.
                    Nov 27 16:59:55 deconz systemd[1]: deconz-update.service: Start request repeated too quickly.
                    Nov 27 16:59:55 deconz systemd[1]: deconz-update.service: Failed with result 'exit-code'.
                    Nov 27 16:59:55 deconz systemd[1]: Failed to start deCONZ: ZigBee gateway -- Update Service.
                    Ich habe aber gestern erfolgreich eine Lampe und einen Schalter verbinden können.
                      @smarti2015
                      Wie wurde das Paket 'deconz' installiert?
                      sudo apt update
                      apt policy deconz
                      sagt?
                        hwadmin@deconz:~$ sudo apt update
                        OK:1 http://phoscon.de/apt/deconz jammy InRelease
                        OK:2 http://de.archive.ubuntu.com/ubuntu jammy InRelease
                        OK:3 http://de.archive.ubuntu.com/ubuntu jammy-updates InRelease
                        OK:4 http://de.archive.ubuntu.com/ubuntu jammy-backports InRelease
                        OK:5 http://security.ubuntu.com/ubuntu jammy-security InRelease
                        Paketlisten werden gelesen… Fertig
                        Abhängigkeitsbaum wird aufgebaut… Fertig
                        Statusinformationen werden eingelesen… Fertig
                        Aktualisierung für 1 Paket verfügbar. Führen Sie »apt list --upgradable« aus, um es anzuzeigen.
                        W: http://phoscon.de/apt/deconz/dists/jammy/InRelease: Schlüssel ist im veralteten Schlüsselbund trusted.gpg gespeichert (/etc/apt/trusted.gpg), siehe den Abschnitt MISSBILLIGUNG in apt-key(8) für Details.
                        hwadmin@deconz:~$ apt policy deconz
                        deconz:
                          Installiert:           2.24.2
                          Installationskandidat: 2.24.2
                          Versionstabelle:
                         *** 2.24.2 500
                                500 http://phoscon.de/apt/deconz jammy/main amd64 Packages
                                100 /var/lib/dpkg/status
                        deconz ubuntu
                        1848
