Update auf neuen NODE.JS und nichts geht mehr
Skript v.2023-10-10 *** BASE SYSTEM *** Static hostname: iobroker2 Icon name: computer Operating System: Debian GNU/Linux 11 (bullseye) Kernel: Linux 6.1.21-v8+ Architecture: arm64 Model : Raspberry Pi 4 Model B Rev 1.5 Docker : false Virtualization : none Kernel : aarch64 Userland : arm64 Systemuptime and Load: 22:56:02 up 7:18, 1 user, load average: 0.41, 0.12, 0.04 CPU threads: 4 *** RASPBERRY THROTTLING *** Current issues: No throttling issues detected. Previously detected issues: No throttling issues detected. *** Time and Time Zones *** Local time: Tue 2023-11-28 22:56:02 CET Universal time: Tue 2023-11-28 21:56:02 UTC RTC time: n/a Time zone: Europe/Berlin (CET, +0100) System clock synchronized: yes NTP service: active RTC in local TZ: no *** User and Groups *** iobroker /home/iobroker iobroker adm tty dialout cdrom sudo audio video plugdev games users input render netdev bluetooth gpio i2c spi *** X-Server-Setup *** X-Server: false Desktop: Terminal: tty Boot Target: multi-user.target *** MEMORY *** total used free shared buff/cache available Mem: 7.8G 1.1G 6.2G 1.0M 512M 6.6G Swap: 99M 0B 99M Total: 7.9G 1.1G 6.3G 7812 M total memory 1097 M used memory 1289 M active memory 207 M inactive memory 6202 M free memory 47 M buffer memory 465 M swap cache 99 M total swap 0 M used swap 99 M free swap Raspberry only: oom events: 0 lifetime oom required: 0 Mbytes total time in oom handler: 0 ms max time spent in oom handler: 0 ms *** FAILED SERVICES *** UNIT LOAD ACTIVE SUB DESCRIPTION 0 loaded units listed. *** FILESYSTEM *** Filesystem Type Size Used Avail Use% Mounted on /dev/root ext4 29G 5.6G 22G 21% / devtmpfs devtmpfs 3.6G 0 3.6G 0% /dev tmpfs tmpfs 3.9G 0 3.9G 0% /dev/shm tmpfs tmpfs 1.6G 1.2M 1.6G 1% /run tmpfs tmpfs 5.0M 4.0K 5.0M 1% /run/lock /dev/mmcblk0p1 vfat 255M 31M 225M 13% /boot tmpfs tmpfs 782M 0 782M 0% /run/user/1000 Messages concerning ext4 filesystem in dmesg: [Tue Nov 28 15:37:48 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 smsc95xx.macaddr=D8:3A:DD:46:09:79 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 console=ttyS0,115200 console=tty1 root=PARTUUID=4662fcaa-02 rootfstype=ext4 fsck.repair=yes rootwait [Tue Nov 28 15:37:49 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none. [Tue Nov 28 15:37:49 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2. [Tue Nov 28 15:37:51 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none. Show mounted filesystems \(real ones only\): TARGET SOURCE FSTYPE OPTIONS / /dev/mmcblk0p2 ext4 rw,noatime,commit=600 `-/boot /dev/mmcblk0p1 vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro Files in neuralgic directories: /var: 1.9G /var/ 766M /var/cache 761M /var/cache/apt 660M /var/cache/apt/archives 641M /var/lib Archived and active journals take up 336.0M in the file system. /opt/iobroker/backups: 192M /opt/iobroker/backups/ /opt/iobroker/iobroker-data: 217M /opt/iobroker/iobroker-data/ 121M /opt/iobroker/iobroker-data/files 67M /opt/iobroker/iobroker-data/files/javascript.admin 67M /opt/iobroker/iobroker-data/backup-objects 48M /opt/iobroker/iobroker-data/files/javascript.admin/static The five largest files in iobroker-data are: 21M /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map 20M /opt/iobroker/iobroker-data/objects.jsonl 8.3M /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js 7.5M /opt/iobroker/iobroker-data/files/javascript.admin/static/js/691.26ff76ce.chunk.js.map 7.1M /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.d3cce782.chunk.js.map USB-Devices by-id: USB-Sticks - Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id': find: '/dev/serial/by-id/': No such file or directory *** NodeJS-Installation *** /usr/bin/nodejs v18.18.2 /usr/bin/node v18.18.2 /usr/bin/npm 10.2.4 /usr/bin/npx 10.2.4 /usr/bin/corepack 0.19.0 nodejs: Installed: 18.18.2-1nodesource1 Candidate: 18.18.2-1nodesource1 Version table: *** 18.18.2-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 100 /var/lib/dpkg/status 18.18.1-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.18.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.17.1-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.17.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.16.1-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.16.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.15.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.14.2-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.14.1-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.14.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.13.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.12.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.11.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.10.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.9.1-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.9.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.8.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.7.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.6.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.5.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.4.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.3.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.2.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.1.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.0.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 12.22.12~dfsg-1~deb11u4 500 500 http://deb.debian.org/debian bullseye/main arm64 Packages 500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages Temp directories causing npm8 problem: 0 No problems detected Errors in npm tree: *** ioBroker-Installation *** ioBroker Status iobroker is running on this host. Objects type: jsonl States type: jsonl Core adapters versions js-controller: 5.0.16 admin: 6.12.0 javascript: 7.1.6 Adapters from github: 0 Adapter State system.adapter.acme.0 : acme : iobroker2 - disabled, port: 81, bind: 0.0.0.0 + system.adapter.admin.0 : admin : iobroker2 - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.backitup.0 : backitup : iobroker2 - enabled + system.adapter.followthesun.0 : followthesun : iobroker2 - enabled + system.adapter.hmip.0 : hmip : iobroker2 - enabled + system.adapter.javascript.0 : javascript : iobroker2 - enabled + system.adapter.mqtt.0 : mqtt : iobroker2 - enabled, port: 1883, bind: 0.0.0.0 + system.adapter.mqtt.1 : mqtt : iobroker2 - enabled, port: 1885, bind: 0.0.0.0 + system.adapter.mqtt.3 : mqtt : iobroker2 - enabled, port: 1887, bind: 0.0.0.0 + system.adapter.node-red.0 : node-red : iobroker2 - enabled, port: 1880, bind: 0.0.0.0 (SSL) + system.adapter.sql.0 : sql : iobroker2 - enabled, port: 3306 + instance is alive Enabled adapters with bindings + system.adapter.admin.0 : admin : iobroker2 - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.mqtt.0 : mqtt : iobroker2 - enabled, port: 1883, bind: 0.0.0.0 + system.adapter.mqtt.1 : mqtt : iobroker2 - enabled, port: 1885, bind: 0.0.0.0 + system.adapter.mqtt.3 : mqtt : iobroker2 - enabled, port: 1887, bind: 0.0.0.0 + system.adapter.node-red.0 : node-red : iobroker2 - enabled, port: 1880, bind: 0.0.0.0 (SSL) + system.adapter.sql.0 : sql : iobroker2 - enabled, port: 3306 ioBroker-Repositories stable : http://download.iobroker.net/sources-dist.json beta : http://download.iobroker.net/sources-dist-latest.json Active repo(s): stable Installed ioBroker-Instances Used repository: stable Adapter "acme" : 0.1.2 , installed 0.1.2 Adapter "admin" : 6.12.0 , installed 6.12.0 Adapter "backitup" : 2.8.7 , installed 2.8.7 Adapter "followthesun" : 0.4.2 , installed 0.4.2 Adapter "hmip" : 1.20.0 , installed 1.20.0 Adapter "javascript" : 7.1.6 , installed 7.1.6 Controller "js-controller": 5.0.16 , installed 5.0.16 Adapter "mqtt" : 5.1.0 , installed 5.1.0 Adapter "node-red" : 4.0.3 , installed 4.0.3 Adapter "simple-api" : 2.7.2 , installed 2.7.2 Adapter "socketio" : 6.6.0 , installed 6.6.0 Adapter "sql" : 2.2.0 , installed 2.2.0 Adapter "web" : 6.1.10 , installed 6.1.10 Adapter "ws" : 2.5.8 , installed 2.5.8 Objects and States Please stand by - This may take a while Objects: 2340 States: 1983 *** OS-Repositories and Updates *** Hit:1 http://deb.debian.org/debian bullseye InRelease Hit:2 http://security.debian.org/debian-security bullseye-security InRelease Hit:3 http://deb.debian.org/debian bullseye-updates InRelease Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease Hit:5 https://packages.grafana.com/enterprise/deb stable InRelease Hit:6 https://packages.grafana.com/oss/deb stable InRelease Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease Reading package lists... Pending Updates: 0 *** Listening Ports *** Active Internet connections (only servers) Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name tcp 0 0 0.0.0.0:1880 0.0.0.0:* LISTEN 1000 18081 989/node-red tcp 0 0 0.0.0.0:1883 0.0.0.0:* LISTEN 1000 14273 1181/io.mqtt.0 tcp 0 0 0.0.0.0:1884 0.0.0.0:* LISTEN 1000 14274 1181/io.mqtt.0 tcp 0 0 0.0.0.0:1885 0.0.0.0:* LISTEN 1000 18059 1327/io.mqtt.1 tcp 0 0 0.0.0.0:1886 0.0.0.0:* LISTEN 1000 18060 1327/io.mqtt.1 tcp 0 0 0.0.0.0:1887 0.0.0.0:* LISTEN 1000 16614 1403/io.mqtt.3 tcp 0 0 127.0.0.1:6010 0.0.0.0:* LISTEN 1000 69968 7621/sshd: iobroker tcp 0 0 127.0.0.1:9001 0.0.0.0:* LISTEN 1000 846 491/iobroker.js-con tcp 0 0 127.0.0.1:9000 0.0.0.0:* LISTEN 1000 850 491/iobroker.js-con tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 14662 545/sshd: /usr/sbin tcp 0 0 0.0.0.0:3306 0.0.0.0:* LISTEN 110 13736 595/mariadbd tcp6 0 0 ::1:6010 :::* LISTEN 1000 69967 7621/sshd: iobroker tcp6 0 0 :::22 :::* LISTEN 0 14664 545/sshd: /usr/sbin tcp6 0 0 :::8081 :::* LISTEN 1000 2031 776/io.admin.0 tcp6 0 0 :::3000 :::* LISTEN 111 16494 854/grafana udp 0 0 0.0.0.0:68 0.0.0.0:* 0 13762 853/dhcpcd udp 0 0 0.0.0.0:5353 0.0.0.0:* 108 1743 386/avahi-daemon: r udp 0 0 0.0.0.0:35918 0.0.0.0:* 108 1745 386/avahi-daemon: r udp6 0 0 :::546 :::* 0 39701 853/dhcpcd udp6 0 0 :::5353 :::* 108 1744 386/avahi-daemon: r udp6 0 0 :::50716 :::* 108 1746 386/avahi-daemon: r *** Log File - Last 25 Lines *** 2023-11-28 22:45:01.728 - info: javascript.0 (860) script.js.common.Kachelmann-Messwerte: State exists, updating... 2023-11-28 22:45:01.728 - info: javascript.0 (860) script.js.common.Kachelmann-Messwerte: State exists, updating... 2023-11-28 22:45:01.729 - info: javascript.0 (860) script.js.common.Kachelmann-Messwerte: State exists, updating... 2023-11-28 22:45:01.729 - info: javascript.0 (860) script.js.common.Kachelmann-Messwerte: State exists, updating... 2023-11-28 22:45:01.729 - info: javascript.0 (860) script.js.common.Kachelmann-Messwerte: State exists, updating... 2023-11-28 22:45:01.730 - info: javascript.0 (860) script.js.common.Kachelmann-Messwerte: State exists, updating... 2023-11-28 22:45:01.730 - info: javascript.0 (860) script.js.common.Kachelmann-Messwerte: State exists, updating... 2023-11-28 22:45:01.730 - info: javascript.0 (860) script.js.common.Kachelmann-Messwerte: State exists, updating... 2023-11-28 22:45:01.731 - info: javascript.0 (860) script.js.common.Kachelmann-Messwerte: State exists, updating... 2023-11-28 22:45:01.731 - info: javascript.0 (860) script.js.common.Kachelmann-Messwerte: State exists, updating... 2023-11-28 22:45:01.731 - info: javascript.0 (860) script.js.common.Kachelmann-Messwerte: State exists, updating... 2023-11-28 22:45:01.732 - info: javascript.0 (860) script.js.common.Kachelmann-Messwerte: State exists, updating... 2023-11-28 22:45:01.732 - info: javascript.0 (860) script.js.common.Kachelmann-Messwerte: State exists, updating... 2023-11-28 22:45:01.732 - info: javascript.0 (860) script.js.common.Kachelmann-Messwerte: State exists, updating... 2023-11-28 22:45:01.732 - info: javascript.0 (860) script.js.common.Kachelmann-Messwerte: State exists, updating... 2023-11-28 22:45:01.733 - info: javascript.0 (860) script.js.common.Kachelmann-Messwerte: State exists, updating... 2023-11-28 22:45:01.733 - info: javascript.0 (860) script.js.common.Kachelmann-Messwerte: State exists, updating... 2023-11-28 22:45:01.733 - info: javascript.0 (860) script.js.common.Kachelmann-Messwerte: State exists, updating... 2023-11-28 22:45:01.734 - info: javascript.0 (860) script.js.common.Kachelmann-Messwerte: State exists, updating... 2023-11-28 22:45:01.734 - info: javascript.0 (860) script.js.common.Kachelmann-Messwerte: State exists, updating... 2023-11-28 22:45:01.734 - info: javascript.0 (860) script.js.common.Kachelmann-Messwerte: State exists, updating... 2023-11-28 22:45:01.735 - info: javascript.0 (860) script.js.common.Kachelmann-Messwerte: State exists, updating... 2023-11-28 22:45:01.735 - info: javascript.0 (860) script.js.common.Kachelmann-Messwerte: State exists, updating... 2023-11-28 22:45:01.735 - info: javascript.0 (860) script.js.common.Kachelmann-Messwerte: State exists, updating... 2023-11-28 22:45:01.736 - info: javascript.0 (860) script.js.common.Kachelmann-Messwerte: State exists, updating...
iob diag has finished.
======================= SUMMARY ======================= v.2023-10-10 Static hostname: iobroker2 Icon name: computer Operating System: Debian GNU/Linux 11 (bullseye) Kernel: Linux 6.1.21-v8+ Architecture: arm64 Installation: native Kernel: aarch64 Userland: arm64 Timezone: Europe/Berlin (CET, +0100) User-ID: 1000 X-Server: false Boot Target: multi-user.target Pending OS-Updates: 0 Pending iob updates: 0 Nodejs-Installation: /usr/bin/nodejs v18.18.2 /usr/bin/node v18.18.2 /usr/bin/npm 10.2.4 /usr/bin/npx 10.2.4 /usr/bin/corepack 0.19.0 Recommended versions are nodejs and npm Your nodejs installation is correct MEMORY: total used free shared buff/cache available Mem: 7.8G 1.2G 5.9G 1.0M 787M 6.5G Swap: 99M 0B 99M Total: 7.9G 1.2G 6.0G Active iob-Instances: 11 Active repo(s): stable ioBroker Core: js-controller 5.0.16 admin 6.12.0 ioBroker Status: iobroker is running on this host. Objects type: jsonl States type: jsonl Status admin and web instance: + system.adapter.admin.0 : admin : iobroker2 - enabled, port: 8081, bind: 0.0.0.0, run as: admin Objects: 2340 States: 1983 Size of iob-Database: 20M /opt/iobroker/iobroker-data/objects.jsonl 1.7M /opt/iobroker/iobroker-data/states.jsonl =================== END OF SUMMARY ====================
Ich würde sagen, das Kachelmann-Ding tickt da aus.
@thomas-braun Das Script ist von mir selber
Und es läuft unverändert seit mindestens 6 Monaten. Es erzeugt nur ein bisschen viel Debug-Info.
Also das Logfile sah immer so aus. Es werden jede Stunde Daten dort abgerufen und es sind sicher 50 States, die dann ein Update bekommen.Allerdings sehe ich die Daten dann normal auch in Grafana, wo seit vielen Stunden nichts mehr neues angezeigt wird.
Aber warum ballert das Ding im Millisekunden-Takt ins Log? Komplett unnötig. Und bremst das ganze aus und rappelt auch auf das Dateisystem.
@thomas-braun wie gesagt: AUCH ein guter Punkt, den ich sicher angehen werde, sobald ich wieder auf das System zugreifen kann.
@sven-schumacher sagte in Update auf neuen NODE.JS und nichts geht mehr:
Im Unterschied zum defekten Admin läuft der IOBROKER aber wohl gar nicht wirklich
Was ist denn nun genau dein Problem? Ich verstehe den Satz nicht.
Bis auf das Logfile vollkachelnde Skript ist da nichts auffälliges zu sehen.
@sven-schumacher
Das script läuft nicht wie erwartet -iobroker stop javascript.0
dann sollte es mit dem Zugriff klappen... kann auch was anders sein, aber 3 log Einträge jede ms ist schon kritisch. was sagt den htop oder top?edit kannst gerne das Skript zeigen, dann schaue ich mal drüber.
@thomas-braun also: heute Nacht irgendwann hat sich der Zugriff wieder repariert...
Und auch in Grafana sind wieder Werte. Über 8h war beides nicht möglich. Ich weiß nicht, was heute Nacht passiert ist. Ich habe vor dem Beitrag in Forum alles gemacht, was man machen konnte. Aber ohne Zugriff zu bekommen oder Werte in Grafana zu sehen.
Kann der Aufruf von dem Script, mit dem ich den Status erfassen konnte, irgendetwas repariert haben?
@ticaki dafür mache ich gerne ein neues Thema auf. Hat ja vermutlich nichts mit dem Problem zu tun.
Nein, das liest nur aus, führt aber keine Änderungen durch.
/usr/bin/npm 10.2.4
/usr/bin/npx 10.2.4
/usr/bin/corepack 0.19.0das passt nicht zusammen ... so :
@glasfaser das ist nicht von mir, das Bild. Oder?
Das Bild zeigt, wie es sein sollte. Dein Log obendrüber zeigt, wie es NICHT sein sollte.
sudo apt install --reinstall nodejs
sollte das korrigieren.
Lass die Finger von npm-Updates, egal ob das irgendwo im Terminal als Empfehlung drin steht.
