    4. [Neuer Adapter] EuSec
    • Marko1974
      Marko1974 @Gonzokalle last edited by
      @gonzokalle könntest du den mal eben exportieren, wenn du so nett bist?
        Gonzokalle @Marko1974 last edited by
        @marko1974
        Probiere mal.
          <variables>
            <variable id="Q,~ra/H[5HUV[%s`z?yR">Path_Pic</variable>
            <variable id="HG,5+Q1IK)XD#v$T4*hl">URL_CAM</variable>
            <variable id="oN*3XW_?QS7$:FwR$CbD">Check</variable>
          </variables>
          <block type="procedures_defcustomreturn" id="J!Bvoqs}(Lq/G?ZW,-(]" x="188" y="-38">
            <mutation statements="false">
              <arg name="Path_Pic" varid="Q,~ra/H[5HUV[%s`z?yR"></arg>
              <arg name="URL_CAM" varid="HG,5+Q1IK)XD#v$T4*hl"></arg>
            </mutation>
            <field name="NAME">create_picHaus</field>
            <field name="SCRIPT">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</field>
            <comment pinned="true" h="80" w="160">Hier nichts eintragen!</comment>
          <block type="on_ext" id="lj}ZLW[;A1d9#)F2:qTh" x="188" y="13">
            <value name="OID0">
              <shadow type="field_oid" id="7jX*;aDCT+9n:QK{O;i{">
                <field name="oid">eusec.0.T8010N2321140533.cameras.T8142N63211?????.person_detected</field>
            <value name="OID1">
              <shadow type="field_oid" id="Ur{bT%D;hgi[Ih.S$(BX">
                <field name="oid">eusec.0.T8010N2321140533.cameras.T8142N63211?????.motion_detected</field>
              <block type="controls_if" id="[]?wBvQKG+/oWV8D#KMi">
                  <block type="logic_operation" id="@DTS#/zP:/,egh@))(z8" inline="false">
                    <field name="OP">OR</field>
                      <block type="logic_compare" id="fYN`2tS(C!3HvI$qt({C">
                        <field name="OP">EQ</field>
                          <block type="get_value" id="cMV]8HE)U{vx8DW*O]uD">
                            <field name="OID">eusec.0.T8010N2321140533.cameras.T8142N63211?????.person_detected</field>
                          <block type="logic_boolean" id="X,q7h=/A:z@0KDf0}Bmt">
                      <block type="logic_compare" id="G{QwWHz?ehP;_J%,|!1`">
                          <block type="get_value" id="wEb.0`VM/LH-[J[f#47?">
                            <field name="OID">eusec.0.T8010N2321140533.cameras.T8142N63211?????.motion_detected</field>
                          <block type="logic_boolean" id="FTEO*ZI+hZzQ=uys[8jQ">
                  <block type="comment" id="jQG_)|eb:ix{t3xGat`}">
                    <field name="COMMENT">Pfad zu Kamera rtsp_stream (switch.enable)</field>
                      <block type="control" id="lN7OPGS,BYEuQ@]tdjAV">
                        <field name="OID">eusec.0.T8010N2321140533.cameras.T8142N63211?????.rtsp_stream</field>
                        <comment pinned="false" h="83" w="856">Path Kamera rtsp.streamBsp eusec.0.1234567890123456.cameras.1234567890123456.rtsp_stream       </comment>
                          <block type="logic_boolean" id="pBb4#,2FShkMf9DWMg6D">
                          <block type="comment" id="%,G{6)oa~?Z~s+ieUom8">
                            <field name="COMMENT">Path_Pic --&gt; Pfad wo das Bild angelegt werden soll (Schreibrechte notwendig!!</field>
                              <block type="comment" id=";myiyDOtfEZ+MSy~y=/S">
                                <field name="COMMENT">URL_CAM --&gt; RTSP muss vorher in der App konfiguriert werden!!</field>
                                  <block type="variables_set" id="f~O~*,YL5.W@65-.lGf9">
                                    <field name="VAR" id="oN*3XW_?QS7$:FwR$CbD">Check</field>
                                    <comment pinned="false" h="118" w="722">Path = Speicherort jpgBsp. '/opt/iobroker/iobroker-data/backup-objects/Eufy/Beispiel.jpeg' rtsp://user:passwort@ip/live0                   </comment>
                                      <block type="procedures_callcustomreturn" id="HRD7cJ{40v0Y%W3MkFuW">
                                        <mutation name="create_picHaus">
                                          <arg name="Path_Pic"></arg>
                                          <arg name="URL_CAM"></arg>
                                        </mutation>
                                        <value name="ARG0">
                                          <block type="text" id="0]6j[8=u`;kcgni7!oT`">
                                            <field name="TEXT">/opt/iobroker/Kamerabilder/Haustuer.jpeg</field>
                                        <value name="ARG1">
                                          <block type="convert_tostring" id="L9g6b9r{-+K?NdU3s$G=">
                                              <block type="get_value" id="mgW_61f13,(6M{4~:-`n">
                                                <field name="OID">eusec.0.T8010N2321140533.cameras.T8142N63211?????.rtsp_stream_url</field>
                                      <block type="controls_if" id="AH%upH|y(afK(2}sVr#7">
                                          <block type="logic_compare" id="D_;;c_hk!dF83JX[p/M`">
                                              <block type="variables_get" id="zO@w4w~4LFmb1,p)l*vs">
                                              <block type="logic_boolean" id="~934R*fRj3g6d~/JEX.p">
                                          <block type="telegram" id="8r90W{b2|I21hZT)$_*`">
                                            <field name="LOG"></field>
                                            <field name="ESCAPING">FALSE</field>
                                            <field name="DISABLE_WEB_PAGE_PREVIEW">FALSE</field>
                                            <value name="MESSAGE">
                                              <shadow type="text" id="rO)Fwr+*@@m~T-KRk6HO">
                                            <value name="CHATID">
                                              <block type="text" id="yPU-v?IPv*eJzmns?-p#">
                                                <field name="TEXT">?????</field>
        Marko1974 1 Reply Last reply Reply Quote 0
        • Marko1974
          Marko1974 @Gonzokalle last edited by Marko1974
          @gonzokalle said in [Neuer Adapter] EuSec:
          @marko1974
          Probiere mal.
            <variables>
            </variables>
              </mutation>
              <value name="OID0">
              <value name="OID1">
                                          </mutation>
                                          <value name="ARG0">
                                          <value name="ARG1">
          Dankeschön....habe es mal nun so nachgebaut...motion löst auch aus...aber er schreibt kein Bild ins Verzeichnis. Muss man das vielleicht von der Station holen?
            @marko1974
            Ich denke, dass das die JS-Funktion macht.
            Bei der JS-Funktion wird nichts eingetragen.
            Die sehe ich jetzt bei dir nicht.
            • Marko1974
              @marko1974
              Da habe ich nichts gemacht
                @marko1974
                Eventuell "opt/iobroker/XXXX" als Verzeichnis probieren.
                Mehr fällt mir auch nicht ein.
                • Marko1974
                  @gonzokalle
                  Hast du auf deinem Raspi noch irgendwas installiert was rtsp kann?
                  In der App konfiguriert man ja quasi eine Station die rtsp beherrscht.
                    @marko1974 sagte in [Neuer Adapter] EuSec:
                    @gonzokalle
                    Nein
                    Du konfigurierst, dass es einen RTSP Stream gibt.
                    • Marko1974
                      Marko1974 last edited by Marko1974
                      @gonzokalle Ich habe es bis jetzt nicht rausbekommen, warum er das Pic nicht schreibt. Mal drüber schlafen. 3 verschiedene Verzeichnisse angelegt. Alle mit user und owner iobroker...nix```
                      Das schmeisst er im Log aus
                      script.js.common.Alarm.Eufy_Telegramm_Innenkamera: exec: ffmpeg -loglevel fatal -rtsp_transport tcp -i rtsp://xxxxpGz6ZF7o:xxxxV25RJCr2@192.168.178.77/live1 -f image2 -vframes 1 -pix_fmt yuvj420p /opt/iobroker/Kamerabilder/innen.jpeg
                        @marko1974
                        Da kann ich dir nicht weiter helfen.
                        Der Homebase hast du eine feste IP gegeben?
                        • Marko1974
                          @gonzokalle ich hab´s herausbekommen.
                          Ich muss den Eusec Ordner angeben, dann funktioniert es auf Anhieb.
                          /opt/iobroker/iobroker-data/eusec.0/T8010N232xxxx/last_event/innen.jpeg
                          Der hat aber auch keine anderen Besitzer und auch keine anderen Rechte. Weiss der Geier, warum das so ist.
                          Weisst Du ob man auch ein short Video anstatt eines Bildes senden könnte?
                          Danke für Deine Geduld und @TbsJah für das Blockly. Da habe ich soooo lange mit rumgemacht. Danke danke!
                            @marko1974
                            Das freut mich.
                            Etwas komisch ist das aber schon mit dem Ordner.
                            Keine Ahnung, ob man ein Video auch senden kann.
                            @ alle
                            Vielleicht geht ja hier etwas?
                            Mit go2rtc kann man wohl einen RTSP Stream in ein anderes Format bekommen.
                            Weiß hier jemand etwas genaues?
                              Gonzokalle @Gonzokalle last edited by
                              @gonzokalle
                              Alle 10 Minuten kommt
                              Station: TXXXXXXXXXXXXXX command CMD_SDINFO_EX failed with error: undefined (-148)
                              Ein Neustart des Adapters bringt auch nichts.
                              Fabio 1 Reply Last reply Reply Quote 0
                              • Fabio
                                Fabio @Gonzokalle last edited by
                                @gonzokalle @bropat fixt das in der nächsten Version: https://github.com/bropat/ioBroker.eusec/issues/397#issuecomment-1848911612
                                GM-Jokemaster created this issue in bropat/ioBroker.eusec
                                closed Station: T8030Pxxxxxxxxxx command CMD_SDINFO_EX failed with error: undefined (-148) #397
                                Fabio 1 Reply Last reply Reply Quote 1
                                • Arne Dieckmann
                                  Arne Dieckmann last edited by
                                  Ich habe 5 Kameras an einer S380, 4x eufy 2c und 1x eufy solocam c210.
                                  Es werden alle Kameras in den Objekten angezeigt, die 2c als cameras, die c210 als unknown. Bei der c210 fehlen auch die ganzen Datenpunkte wie z.B. für livestream etc. Es werden nur 5 informative Punkte angelegt (Name, Modell, etc.)
                                  Wird die c210 nicht von dem eusec adapter unterstützt?
                                  Gruß Arne
                                  • Fabio
                                    Fabio @Arne Dieckmann last edited by
                                    @arne-dieckmann schau bitte hier mal nach https://bropat.github.io/eufy-security-client/#/supported_devices ansonsten wenn nicht aufgeführt mache bitte eine Anfrage bei GitHub
                                    • Longbow
                                      Longbow last edited by
                                      So habe nach langem mal wieder den Adapter heute gestartet...
                                      alle Datenpunkte sind, Code neu eingetragen...
                                      Aber ich bekomme jetzt von jeder Cam diese Fehler Meldung
                                      All address lookup tentatives failed. [{"stationSN":"T8124XXXXXX"}] und
                                      Station: T8030Pxxxx command CMD_SDINFO_EX failed with error: undefined (-148)
                                      exception in 5DaysForecast [TypeError: Cannot read properties of undefined (reading 'city')]
                                      Was bedeutet das nun? Was stimmt dem jetzt nicht ?
                                      • Fabio
                                        Fabio @Longbow last edited by
                                        @longbow 3 Beiträge über dir lesen.
                                        Longbow 1 Reply Last reply Reply Quote 0
                                        • Longbow
                                          Longbow @Fabio last edited by
                                          @fa-bio Oh, danke... Also kann ich wieder deaktivieren.
                                          Michael Ahlers 1 Reply Last reply Reply Quote 0
                                          • Michael Ahlers
                                            Michael Ahlers @Longbow last edited by Michael Ahlers
                                            @Arne-Dieckmann
                                            Status: work in progress
                                            https://github.com/bropat/eufy-security-client/issues/369
                                            johannes1984 created this issue in bropat/eufy-security-client
                                            closed [Feature request]: Support for SoloCam C210 (T8B00) #369
                                            adapter cameras doorbell eufy eufycam security
                                            160
                                            1173
                                            457861
