    4. Vis-2(.0) - Neuer Adapter als Beta
      sigi234 Forum Testing Most Active @Agrippinenser last edited by
      @agrippinenser sagte in Vis-2(.0) - Neuer Adapter als Beta:
      Der Datenpunkt ist mit History
      Zeig mal den DP
      Agrippinenser 1 Reply Last reply Reply Quote 0
      • Agrippinenser
        Agrippinenser @sigi234 last edited by
        @sigi234 sagte in Vis-2(.0) - Neuer Adapter als Beta:
        Zeig mal den DP
        gerne noch einmal alles.:
        Datenpunkt:
          "_id": "alias.0.Temperatur-Luftfeuchte.Terrasse.ACTUAL",
          "common": {
            "name": "ACTUAL",
            "role": "value.temperature",
            "type": "number",
            "read": true,
            "write": false,
            "alias": {
              "id": "hm-rpc.2.000EDBE98B9C10.1.ACTUAL_TEMPERATURE"
            "unit": "°C",
            "custom": {
              "influxdb.2": {
                "enabled": true,
                "storageType": "Number",
                "aliasId": "temperatur.terrasse",
                "debounceTime": 0,
                "blockTime": 0,
                "changesOnly": true,
                "changesRelogInterval": 0,
                "changesMinDelta": 0,
                "ignoreBelowNumber": "",
                "disableSkippedValueLogging": false,
                "enableDebugLogs": false,
                "debounce": 1000
              "history.0": {
                "enabled": true,
                "debounceTime": 0,
                "blockTime": 0,
                "retention": 259200,
                "customRetentionDuration": 365,
                "maxLength": 960,
                "debounce": 0
          "native": {},
          "type": "state",
          "acl": {
            "object": 1636,
            "state": 1636,
            "owner": "system.user.admin",
          "user": "system.user.admin",
          "ts": 1701286293051
        Widget:
           "tpl": "tplMaterial2Actual",
           "data": {
             "bindings": [],
             "timeInterval": 1,
             "g_common": true,
             "updateInterval": 10,
             "oid-main": "alias.0.Temperatur-Luftfeuchte.Terrasse.ACTUAL",
             "title-main": "",
             "icon-main": "",
             "unit-main": "",
             "noChart": false,
             "color-main": "rgba(232,85,85,1)",
             "font-size-main": 37,
             "font-style-main": null,
             "g_main": true,
             "widgetTitle": "Terrasse",
             "noCard": false,
             "name": null,
             "comment": null,
             "class": null,
             "filterkey": null,
             "multi-views": null,
             "locked": null,
             "g_fixed": true,
             "oid-secondary": null,
             "title-secondary": null,
             "icon-secondary": null,
             "unit-secondary": null,
             "noChart-secondary": null,
             "color-secondary": null,
             "font-size-secondary": null,
             "font-style-secondary": null,
             "g_secondary": true,
             "g_css_background": true,
             "g_css_font_text": true
           "style": {
             "bindings": [],
             "left": -681,
             "top": 210,
             "width": "100%",
             "height": "237.969px",
             "position": "relative",
             "background": null,
             "background-color": "rgba(209,209,245,1)",
             "background-image": null,
             "background-repeat": null,
             "background-attachment": null,
             "background-position": null,
             "background-size": null,
             "background-clip": null,
             "background-origin": null,
             "color": "rgba(93,108,218,1)",
             "text-align": null,
             "text-shadow": null,
             "font-family": null,
             "font-style": null,
             "font-variant": null,
             "font-weight": null,
             "font-size": null,
             "line-height": null,
             "letter-spacing": null,
             "word-spacing": null
           "widgetSet": "vis-2-widgets-material",
           "_id": "i000001"
        Ergebnis:
        • Feuersturm
          Feuersturm @Agrippinenser last edited by Feuersturm
          @agrippinenser Hier https://github.com/ioBroker/ioBroker.vis-2-widgets-material/issues/177#issuecomment-1832511962 hat ein user gemeldet, dass er auch Probleme hat, wenn die Instanz nicht influx.0 ist. So wie ich es bei dir sehen, hast du eine influxdb.2 Instanz für deinen Datenpunkt. Das könnte dein Problem erklären.
          Du könntest auch einmal einen Testdatenpunkt hinterlegen, welcher mal nur in History und mal nur in Influxdb historisiert wird ob dann das Diagramm angezeigt wird. Vielleicht gibt es auch noch ein Problem, wenn ein Datenpunkt über influx und history historisiert wird.
          Morluktom created this issue in ioBroker/ioBroker.vis-2-widgets-material
          closed Istwert mit Diagramm funktioniert nicht bei SQL #177
          sigi234 Agrippinenser 3 Replies Last reply Reply Quote 0
            sigi234 Forum Testing Most Active @Feuersturm last edited by
            @feuersturm sagte in Vis-2(.0) - Neuer Adapter als Beta:
            Jupp, das Widget habe ich getestet, funktioniert mit einen History DP einwandfrei.
            Denke wie du vermutest die Kombination aus History und influx funktioniert nicht.
            • Feuersturm
              Feuersturm @sigi234 last edited by
              Mit influx.0 funktioniert es bei mir auch.
              Agrippinenser sigi234 2 Replies Last reply Reply Quote 0
              • Agrippinenser
                Agrippinenser @Feuersturm last edited by
                influx.0 geht bei mir auch, aber irgendetwas ist da nicht in Ordnung.
                Ich gehe das morgen noch einmal strukturierter an. Danke für eure Unterstützung.
                • Agrippinenser
                  .. mache ich.
                  • Agrippinenser
                    ich habe nun 6 Alias mit identischer Quell-ID angelegt und diese jeweils wie dargestellt mit Historie-Instanzen verknüpft.
                    Bei mir funktioniert nur Influxdb.0.
                    So wie ich @sigi234 verstanden habe funktioniert es bei ihm mit History. Dann scheint es kein generelles Problem zu sein. Das macht mich etwas ratlos.
                      Kail last edited by
                      kann ich mit einem Material-Design-Widget einen Navigationsbutton erstellen, der auf eine andere Seite verweist. Wenn ja, welcher ist es und in welche Felde muss ich definieren?
                      Danke und Grüße Kail
                      • Agrippinenser
                        Agrippinenser @Kail last edited by Agrippinenser
                        @kail
                        bspw. mit Button - Link wenn es unbedingt MaterialDesign sein soll. Ansonsten passt der "Gestylt
                        Schaltfläche=>Seitendialog" .
                        EDIT: "materialdesign Button Navigation"
                          Kail @Agrippinenser last edited by
                          @agrippinenser
                          super Danke. Habe mich für den Gestylt Button entschieden, der scheint für die neue VIS bereit zu sein 😉
                          • I
                            intruder7 @Agrippinenser last edited by
                            @agrippinenser wie ich schon bei git geschrieben habe, liegt es bei Influx wohl eher an der Instanz. denn Instanz 0 geht bei mir auch. Eine Instanz 2 z.B. nicht
                              hosabeni last edited by
                              Ich habe Vis-2 über das Beta Repo installiert. Der Adapter geht nach dem eingeben der Liezens in eine Neustartschleife mit diesen Meldungen im Log. Der Vis Adapter läuft ohne Probleme.
                              Habe ich etwas falsch konfiguriert oder ist das ein Bug?
                              Vis-2 2.9.2
                              host.iobroker
                              	2023-12-01 21:51:32.120	error	instance system.adapter.vis-2.0 terminated with code 3 (NO_ADAPTER_CONFIG_FOUND)
                              vis-2.0
                              	2023-12-01 21:51:31.429	warn	Terminated (NO_ADAPTER_CONFIG_FOUND): Without reason
                              vis-2.0
                              	2023-12-01 21:51:31.369	error	adapter disabled
                              host.iobroker
                              	2023-12-01 21:50:58.651	error	instance system.adapter.vis-2.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                              vis-2.0
                              	2023-12-01 21:50:57.976	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                              vis-2.0
                              	2023-12-01 21:50:57.463	error	Exception-Code: EACCES: EACCES: permission denied, scandir '/opt/iobroker/'
                              vis-2.0
                              	2023-12-01 21:50:57.462	error	Error: EACCES: permission denied, scandir '/opt/iobroker/' at Object.readdirSync (node:fs:1527:3) at collectWidgetSets (/opt/iobroker/node_modules/iobroker.vis-2/main.js:512:19) at /opt/iobroker/node_modules/iobroker.vis-2/main.js:562:51 at Array.forEach (<anonymous>) at readAdapterList (/opt/iobroker/node_modules/iobroker.vis-2/main.js:562:36) at async buildHtmlPages (/opt/iobroker/node_modules/iobroker.vis-2/main.js:827:25) at async Object.main [as ready] (/opt/iobroker/node_modules/iobroker.vis-2/main.js:1009:5)
                              vis-2.0
                              	2023-12-01 21:50:57.460	error	unhandled promise rejection: EACCES: permission denied, scandir '/opt/iobroker/'
                              vis-2.0
                              	2023-12-01 21:50:57.456	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                              host.iobroker
                              	2023-12-01 21:33:18.133	warn	Do not restart adapter system.adapter.vis-2.0 because restart loop detected
                              host.iobroker
                              	2023-12-01 21:33:18.132	error	instance system.adapter.vis-2.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                              vis-2.0
                              	2023-12-01 21:33:17.444	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                              vis-2.0
                              	2023-12-01 21:33:16.937	error	Exception-Code: EACCES: EACCES: permission denied, scandir '/opt/iobroker/'
                              vis-2.0
                              	2023-12-01 21:33:16.936	error	Error: EACCES: permission denied, scandir '/opt/iobroker/' at Object.readdirSync (node:fs:1527:3) at collectWidgetSets (/opt/iobroker/node_modules/iobroker.vis-2/main.js:512:19) at /opt/iobroker/node_modules/iobroker.vis-2/main.js:562:51 at Array.forEach (<anonymous>) at readAdapterList (/opt/iobroker/node_modules/iobroker.vis-2/main.js:562:36) at async buildHtmlPages (/opt/iobroker/node_modules/iobroker.vis-2/main.js:827:25) at async Object.main [as ready] (/opt/iobroker/node_modules/iobroker.vis-2/main.js:1009:5)
                              vis-2.0
                              	2023-12-01 21:33:16.934	error	unhandled promise rejection: EACCES: permission denied, scandir '/opt/iobroker/'
                              vis-2.0
                              	2023-12-01 21:33:16.930	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                              • Dr. Bakterius
                                Dr. Bakterius Most Active @hosabeni last edited by
                                @hosabeni sagte in Vis-2(.0) - Neuer Adapter als Beta:
                                Mach mal
                                iob stop
                                iob fix
                                iob start
                                  hosabeni @Dr. Bakterius last edited by
                                  @dr-bakterius Hab ich versuchen, hat aber nicht geholfen.
                                  DJMarc75 apollon77 2 Replies Last reply Reply Quote 0
                                  • DJMarc75
                                    DJMarc75 @hosabeni last edited by
                                    na dann zeig mal die Ausgabe von
                                    iob diag
                                    und bitte die Langfassung in Codetags posten
                                      apollon77 @hosabeni last edited by
                                      @hosabeni Also an sich darf /opt/iobroker keinen Zugriffsfehler geben ...
                                        lub104 last edited by
                                        Hallo zusammen, ich habe mit selbst hochgeladen Bilder sie werden im Vis2 nicht angezeigt. PNG Bilder wurden in den Projektordner hochgeladen, Bilder werden als kleines Icon erkannt aber nicht angezeigt was ist mein Fehler. Für kurze Hilfe wäre ich dankbar.
                                          hosabeni @DJMarc75 last edited by
                                          @djmarc75 Hallo hier die Langfassung von iob diag im Spoiler
                                          Skript v.2023-10-10
                                          *** BASE SYSTEM ***
                                             Static hostname: iobroker
                                                   Icon name: computer
                                            Operating System: Debian GNU/Linux 11 (bullseye)
                                                      Kernel: Linux 6.1.21-v8+
                                                Architecture: arm64
                                          Model           : Raspberry Pi 4 Model B Rev 1.4
                                          Docker          : false
                                          Virtualization  : none
                                          Kernel          : aarch64
                                          Userland        : arm64
                                          Systemuptime and Load:
                                           10:41:30 up 1 day, 12:36,  3 users,  load average: 2.16, 1.86, 1.27
                                          CPU threads: 4
                                          *** RASPBERRY THROTTLING ***
                                          Current issues:
                                          Previously detected issues:
                                          *** Time and Time Zones ***
                                                         Local time: Sun 2023-12-03 10:41:30 CET
                                                     Universal time: Sun 2023-12-03 09:41:30 UTC
                                                           RTC time: n/a
                                                        NTP service: active
                                                    RTC in local TZ: no
                                          *** User and Groups ***
                                          pi
                                          /home/pi
                                          pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
                                          *** X-Server-Setup ***
                                          X-Server:       true
                                          Desktop:
                                          Terminal:       tty
                                          *** MEMORY ***
                                          Mem:            7.8G        3.4G        665M         21M        3.8G        4.3G
                                          Swap:            99M          0B         99M
                                          Total:          7.9G        3.4G        765M
                                                   7812 M total memory
                                                   3376 M used memory
                                                   3812 M active memory
                                                   3075 M inactive memory
                                                    664 M free memory
                                                    219 M buffer memory
                                                   3550 M swap cache
                                                     99 M total swap
                                                      0 M used swap
                                                     99 M free swap
                                          Raspberry only:
                                          oom events: 0
                                          *** FAILED SERVICES ***
                                          0 loaded units listed.
                                          *** FILESYSTEM ***
                                          /dev/root      ext4       59G   15G   42G  26% /
                                          devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
                                          tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
                                          tmpfs          tmpfs     1.6G  1.3M  1.6G   1% /run
                                          /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
                                          /dev/sda1      ext4      458G  2.4G  432G   1% /media/usb0
                                          tmpfs          tmpfs     782M   20K  782M   1% /run/user/1000
                                          [Fri Dec  1 22:05:27 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:CB:CD:86 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=tty1 root=PARTUUID=0e2244e3-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                                          [Fri Dec  1 22:05:28 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                                          [Fri Dec  1 22:05:28 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                                          [Fri Dec  1 22:05:31 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                                          [Fri Dec  1 22:05:34 2023] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
                                          TARGET        SOURCE         FSTYPE OPTIONS
                                          /             /dev/mmcblk0p2 ext4   rw,noatime
                                          |-/boot       /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                                          `-/media/usb0 /dev/sda1      ext4   rw,relatime
                                          /var:
                                          3.8G    /var/
                                          1.9G    /var/cache/apt
                                          1.9G    /var/cache
                                          1.8G    /var/cache/apt/archives
                                          1.6G    /var/log/journal/2cd78d8029364b2bbf6704cd23c592f6
                                          Archived and active journals take up 1.5G in the file system.
                                          /opt/iobroker/backups:
                                          2.5G    /opt/iobroker/backups/
                                          /opt/iobroker/iobroker-data:
                                          565M    /opt/iobroker/iobroker-data/
                                          422M    /opt/iobroker/iobroker-data/files
                                          124M    /opt/iobroker/iobroker-data/files/vis-2
                                          100M    /opt/iobroker/iobroker-data/backup-objects
                                          90M     /opt/iobroker/iobroker-data/files/echarts.admin
                                          37M     /opt/iobroker/iobroker-data/objects.jsonl
                                          24M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.5f66c5d9.js.map
                                          24M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.9f2a6569.js.map
                                          24M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.5f66c5d9.js.map
                                          21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
                                          USB-Devices by-id:
                                          /dev/serial/by-id/usb-FTDI_USB_HS_SERIAL_CONVERTER_FTELTVKZ-if00-port0
                                          /dev/serial/by-id/usb-FTDI_USB_HS_SERIAL_CONVERTER_FTELTVKS-if00-port0
                                          /dev/serial/by-id/usb-Silicon_Labs_CP2104_USB_to_UART_Bridge_Controller_01A64D1A-if00-port0
                                          *** NodeJS-Installation ***
                                          /usr/bin/nodejs         v18.19.0
                                          /usr/bin/node           v18.19.0
                                          /usr/bin/npm            10.2.3
                                          /usr/bin/npx            10.2.3
                                          /usr/bin/corepack       0.22.0
                                          nodejs:
                                            Installed: 18.19.0-1nodesource1
                                            Candidate: 18.19.0-1nodesource1
                                            Version table:
                                           *** 18.19.0-1nodesource1 1001
                                                  100 /var/lib/dpkg/status
                                               18.18.2-1nodesource1 1001
                                               18.18.1-1nodesource1 1001
                                               18.18.0-1nodesource1 1001
                                               18.17.1-1nodesource1 1001
                                               18.17.0-1nodesource1 1001
                                               18.16.1-1nodesource1 1001
                                               18.16.0-1nodesource1 1001
                                               18.15.0-1nodesource1 1001
                                               18.14.2-1nodesource1 1001
                                               18.14.1-1nodesource1 1001
                                               18.14.0-1nodesource1 1001
                                               18.13.0-1nodesource1 1001
                                               18.12.0-1nodesource1 1001
                                               18.11.0-1nodesource1 1001
                                               18.10.0-1nodesource1 1001
                                               18.9.1-1nodesource1 1001
                                               18.9.0-1nodesource1 1001
                                               18.8.0-1nodesource1 1001
                                               18.7.0-1nodesource1 1001
                                               18.6.0-1nodesource1 1001
                                               18.5.0-1nodesource1 1001
                                               18.4.0-1nodesource1 1001
                                               18.3.0-1nodesource1 1001
                                               18.2.0-1nodesource1 1001
                                               18.1.0-1nodesource1 1001
                                               18.0.0-1nodesource1 1001
                                               12.22.12~dfsg-1~deb11u4 500
                                                  500 http://deb.debian.org/debian bullseye/main arm64 Packages
                                                  500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                                          No problems detected
                                          Errors in npm tree:
                                          *** ioBroker-Installation ***
                                          ioBroker Status
                                          Objects type: jsonl
                                          States  type: jsonl
                                          Core adapters versions
                                          js-controller:  5.0.16
                                          admin:          6.12.0
                                          javascript:     7.1.6
                                          Adapters from github:   5
                                          Adapter State
                                          + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: horst
                                          + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
                                            system.adapter.alias-manager.0          : alias-manager         : iobroker                                 - disabled
                                          + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                                          + system.adapter.beckhoff.0               : beckhoff              : iobroker                                 -  enabled
                                          + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
                                          + system.adapter.echarts.0                : echarts               : iobroker                                 -  enabled
                                          + system.adapter.ecovacs-deebot.0         : ecovacs-deebot        : iobroker                                 -  enabled
                                          + system.adapter.enocean.0                : enocean               : iobroker                                 -  enabled
                                          + system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker                                 -  enabled
                                            system.adapter.flot.0                   : flot                  : iobroker                                 - disabled
                                            system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
                                          + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
                                          + system.adapter.jarvis.0                 : jarvis                : iobroker                                 -  enabled
                                          + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                                          + system.adapter.kecontact.0              : kecontact             : iobroker                                 -  enabled
                                          + system.adapter.net-tools.0              : net-tools             : iobroker                                 -  enabled
                                            system.adapter.proxy.0                  : proxy                 : iobroker                                 -  enabled
                                          + system.adapter.pvforecast.0             : pvforecast            : iobroker                                 -  enabled
                                          + system.adapter.rpi2.0                   : rpi2                  : iobroker                                 -  enabled
                                            system.adapter.schoolfree.0             : schoolfree            : iobroker                                 -  enabled
                                          + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                                          + system.adapter.smartmeter.0             : smartmeter            : iobroker                                 -  enabled
                                          + system.adapter.smartmeter.1             : smartmeter            : iobroker                                 -  enabled
                                          + system.adapter.smartmeter.2             : smartmeter            : iobroker                                 -  enabled
                                          + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
                                          + system.adapter.sql.0                    : sql                   : iobroker                                 -  enabled, port: 3306
                                          + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                                          + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
                                          + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
                                            system.adapter.vis-2.0                  : vis-2                 : iobroker                                 - disabled
                                            system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
                                          + system.adapter.vw-connect.0             : vw-connect            : iobroker                                 -  enabled
                                          + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0 (SSL), run as: admin
                                          + instance is alive
                                          ioBroker-Repositories
                                          Stable (default): http://download.iobroker.net/sources-dist.json
                                          Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
                                          Active repo(s): Stable (default)
                                          Installed ioBroker-Instances
                                          Used repository: Stable (default)
                                          Adapter    "admin"        : 6.12.0   , installed 6.12.0
                                          Adapter    "alexa2"       : 3.26.3   , installed 3.26.3
                                          Adapter    "backitup"     : 2.8.7    , installed 2.8.7
                                          Adapter    "beckhoff"     : 1.5.3    , installed 1.5.3
                                          Adapter    "echarts"      : 1.5.4    , installed 1.5.4
                                          Adapter    "ecovacs-deebot": 1.4.13  , installed 1.4.13
                                          Adapter    "fb-checkpresence": 1.2.2 , installed 1.2.2
                                          Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
                                          Adapter    "javascript"   : 7.1.6    , installed 7.1.6
                                          Controller "js-controller": 5.0.16   , installed 5.0.16
                                          Adapter    "kecontact"    : 2.0.2    , installed 2.0.2
                                          Adapter    "proxy"        : 1.3.2    , installed 1.3.2
                                          Adapter    "pvforecast"   : 2.9.0    , installed 2.9.0
                                          Adapter    "schoolfree"   : 1.1.3    , installed 1.1.3
                                          Adapter    "shelly"       : 6.6.1    , installed 6.6.1
                                          Adapter    "smartmeter"   : 3.3.4    , installed 3.3.4
                                          Adapter    "sql"          : 2.2.0    , installed 2.2.0
                                          Adapter    "telegram"     : 2.0.1    , installed 3.0.0
                                          Adapter    "trashschedule": 2.3.0    , installed 2.3.0
                                          Adapter    "vis"          : 1.4.16   , installed 1.5.1
                                          Adapter    "vw-connect"   : 0.0.67   , installed 0.1.0
                                          Adapter    "web"          : 6.1.10   , installed 6.1.10
                                          Adapter    "ws"           : 2.5.8    , installed 2.5.8
                                          Objects and States
                                          Objects:        11773
                                          States:         11226
                                          Hit:1 http://deb.debian.org/debian bullseye InRelease
                                          Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
                                          Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
                                          Hit:4 https://apt.grafana.com stable InRelease
                                          Hit:5 http://security.debian.org/debian-security bullseye-security InRelease
                                          Hit:6 https://deb.nodesource.com/node_18.x nodistro InRelease
                                          Reading package lists...
                                          Pending Updates: 0
                                          *** Listening Ports ***
                                          tcp        0      0 0.0.0.0:5900            0.0.0.0:*               LISTEN      0          3890       567/vncserver-x11-c
                                          tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       21748      2075/io.shelly.0
                                          tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       16801      538/iobroker.js-con
                                          tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       17740      538/iobroker.js-con
                                          tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          1677795    82700/cupsd
                                          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          1906       597/sshd: /usr/sbin
                                          tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       22614      2582/io.jarvis.0
                                          tcp        0      0 0.0.0.0:3306            0.0.0.0:*               LISTEN      116        13806      641/mariadbd
                                          tcp6       0      0 :::5900                 :::*                    LISTEN      0          3889       567/vncserver-x11-c
                                          tcp6       0      0 :::22                   :::*                    LISTEN      0          1908       597/sshd: /usr/sbin
                                          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       18186      1314/io.admin.0
                                          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       23804      2789/io.web.0
                                          tcp6       0      0 ::1:631                 :::*                    LISTEN      0          1677794    82700/cupsd
                                          tcp6       0      0 :::3000                 :::*                    LISTEN      117        18929      722/grafana
                                          udp        0      0 0.0.0.0:7090            0.0.0.0:*                           1001       23656      2626/io.kecontact.0
                                          udp        0      0 0.0.0.0:7092            0.0.0.0:*                           1001       23657      2626/io.kecontact.0
                                          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          3932       562/dhcpcd
                                          udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          1677820    82704/cups-browsed
                                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        1784       430/avahi-daemon: r
                                          udp        0      0 0.0.0.0:54804           0.0.0.0:*                           108        1786       430/avahi-daemon: r
                                          udp        0      0 0.0.0.0:42882           0.0.0.0:*                           1001       21429      2626/io.kecontact.0
                                          udp6       0      0 :::56214                :::*                                108        1787       430/avahi-daemon: r
                                          udp6       0      0 :::546                  :::*                                0          13960      562/dhcpcd
                                          udp6       0      0 :::5353                 :::*                                108        1785       430/avahi-daemon: r
                                          2023-12-03 00:02:00.293  - info: javascript.0 (1605) script.js.common.Sonstige.Update_TimeStamp: {'error':null,'result':{'fieldCount':0,'affectedRows':127,'insertId':0,'info':'','serverStatus':16418,'warningStatus':0,'stateChanges':{'systemVariables':{},'schema':'','trackStateChange':null}}}
                                          2023-12-03 02:05:11.036  - warn: ical.0 (88825) get state error: Connection is closed.
                                          2023-12-03 03:16:00.283  - warn: javascript.0 (1605) Read-only state "vw-connect.0.WVWZZZE1ZPP020635.status.chargingSettings.targetSOC_pct" has been written without ack-flag with value "65"
                                          2023-12-03 04:39:32.200  - warn: telegram.0 (25541) polling_error: EFATAL, EFATAL: Error: read ECONNRESET
                                          2023-12-03 04:39:48.595  - warn: ecovacs-deebot.0 (2356) Request Timeout (command 'getAdvancedMode')
                                          2023-12-03 04:40:27.315  - warn: ecovacs-deebot.0 (2356) Connection is interrupted: read ECONNRESET
                                          2023-12-03 04:41:19.259  - warn: ecovacs-deebot.0 (2356) Connection is interrupted: MQTT client error: read ECONNRESET
                                          2023-12-03 07:44:45.662  - warn: javascript.0 (1605) Read-only state "vw-connect.0.WVWZZZE1ZPP020635.status.chargingSettings.targetSOC_pct" has been written without ack-flag with value "80"
        v.2023-10-10
                                                   Icon name: computer
                                                Architecture: arm64
                                          Installation:           native
                                          Kernel:                 aarch64
                                          Userland:               arm64
                                          Timezone:               Europe/Berlin (CET, +0100)
                                          User-ID:                1000
                                          X-Server:               true
                                          Boot Target:            graphical.target
                                          Pending OS-Updates:     0
                                          Pending iob updates:    0
                                          Nodejs-Installation:    /usr/bin/nodejs         v18.19.0
        /usr/bin/npm            10.2.3
        /usr/bin/npx            10.2.3
                                          Recommended versions are nodejs 18.19.0 and npm 10.2.3
                                          MEMORY:
                                          Mem:            7.8G        3.5G        526M         21M        3.8G        4.2G
                                          Swap:            99M          0B         99M
                                          Total:          7.9G        3.5G        626M
                                          Active iob-Instances:   28
                                          ioBroker Core:          js-controller           5.0.16
        admin                   6.12.0
                                          Objects type: jsonl
                                          States  type: jsonl
                                          Objects:                11773
                                          States:                 11226
                                          Size of iob-Database:
                                          4.6M    /opt/iobroker/iobroker-data/states.jsonl
                                            hosabeni @apollon77 last edited by hosabeni
                                            @apollon77 Ich habe die Berechtigung von /opt/iobroker auf 777 geändert und dann funktioniert es.
                                            Haben sich die Berechtigungsanforderungen für vis-2 im Verhältnis zu vis geändert?
                                            Werden die Berechtigungen auf das Verzeichnis nicht mit iob fix geprüft?
                                            apollon77 Thomas Braun 2 Replies Last reply Reply Quote 0
                                            81.1k
                                            691
                                            220117
