    4. Vis-2(.0) - Neuer Adapter als Beta
    • Agrippinenser
      Agrippinenser @sigi234 last edited by
      @sigi234 sagte in Vis-2(.0) - Neuer Adapter als Beta:
      Zeig mal den DP
      gerne noch einmal alles.:
      Datenpunkt:
        "_id": "alias.0.Temperatur-Luftfeuchte.Terrasse.ACTUAL",
        "common": {
          "name": "ACTUAL",
          "role": "value.temperature",
          "type": "number",
          "read": true,
          "write": false,
          "alias": {
            "id": "hm-rpc.2.000EDBE98B9C10.1.ACTUAL_TEMPERATURE"
          "unit": "°C",
          "custom": {
            "influxdb.2": {
              "enabled": true,
              "storageType": "Number",
              "aliasId": "temperatur.terrasse",
              "debounceTime": 0,
              "blockTime": 0,
              "changesOnly": true,
              "changesRelogInterval": 0,
              "changesMinDelta": 0,
              "ignoreBelowNumber": "",
              "disableSkippedValueLogging": false,
              "enableDebugLogs": false,
              "debounce": 1000
            "history.0": {
              "enabled": true,
              "debounceTime": 0,
              "blockTime": 0,
              "retention": 259200,
              "customRetentionDuration": 365,
              "maxLength": 960,
              "debounce": 0
        "native": {},
        "type": "state",
        "acl": {
          "object": 1636,
          "state": 1636,
          "owner": "system.user.admin",
        "user": "system.user.admin",
        "ts": 1701286293051
      Widget:
         "tpl": "tplMaterial2Actual",
         "data": {
           "bindings": [],
           "timeInterval": 1,
           "g_common": true,
           "updateInterval": 10,
           "oid-main": "alias.0.Temperatur-Luftfeuchte.Terrasse.ACTUAL",
           "title-main": "",
           "icon-main": "",
           "unit-main": "",
           "noChart": false,
           "color-main": "rgba(232,85,85,1)",
           "font-size-main": 37,
           "font-style-main": null,
           "g_main": true,
           "widgetTitle": "Terrasse",
           "noCard": false,
           "name": null,
           "comment": null,
           "class": null,
           "filterkey": null,
           "multi-views": null,
           "locked": null,
           "g_fixed": true,
           "oid-secondary": null,
           "title-secondary": null,
           "icon-secondary": null,
           "unit-secondary": null,
           "noChart-secondary": null,
           "color-secondary": null,
           "font-size-secondary": null,
           "font-style-secondary": null,
           "g_secondary": true,
           "g_css_background": true,
           "g_css_font_text": true
         "style": {
           "bindings": [],
           "left": -681,
           "top": 210,
           "width": "100%",
           "height": "237.969px",
           "position": "relative",
           "background": null,
           "background-color": "rgba(209,209,245,1)",
           "background-image": null,
           "background-repeat": null,
           "background-attachment": null,
           "background-position": null,
           "background-size": null,
           "background-clip": null,
           "background-origin": null,
           "color": "rgba(93,108,218,1)",
           "text-align": null,
           "text-shadow": null,
           "font-family": null,
           "font-style": null,
           "font-variant": null,
           "font-weight": null,
           "font-size": null,
           "line-height": null,
           "letter-spacing": null,
           "word-spacing": null
         "widgetSet": "vis-2-widgets-material",
         "_id": "i000001"
      Ergebnis:
      • Feuersturm
        Feuersturm @Agrippinenser last edited by Feuersturm
        @agrippinenser Hier https://github.com/ioBroker/ioBroker.vis-2-widgets-material/issues/177#issuecomment-1832511962 hat ein user gemeldet, dass er auch Probleme hat, wenn die Instanz nicht influx.0 ist. So wie ich es bei dir sehen, hast du eine influxdb.2 Instanz für deinen Datenpunkt. Das könnte dein Problem erklären.
        Du könntest auch einmal einen Testdatenpunkt hinterlegen, welcher mal nur in History und mal nur in Influxdb historisiert wird ob dann das Diagramm angezeigt wird. Vielleicht gibt es auch noch ein Problem, wenn ein Datenpunkt über influx und history historisiert wird.
        Morluktom created this issue in ioBroker/ioBroker.vis-2-widgets-material
        closed Istwert mit Diagramm funktioniert nicht bei SQL #177
        sigi234 Agrippinenser 3 Replies Last reply Reply Quote 0
          sigi234 Forum Testing Most Active @Feuersturm last edited by
          @feuersturm sagte in Vis-2(.0) - Neuer Adapter als Beta:
          Jupp, das Widget habe ich getestet, funktioniert mit einen History DP einwandfrei.
          Denke wie du vermutest die Kombination aus History und influx funktioniert nicht.
          • Feuersturm
            Feuersturm @sigi234 last edited by
            Mit influx.0 funktioniert es bei mir auch.
            Agrippinenser sigi234 2 Replies Last reply Reply Quote 0
            • Agrippinenser
              Agrippinenser @Feuersturm last edited by
              influx.0 geht bei mir auch, aber irgendetwas ist da nicht in Ordnung.
              Ich gehe das morgen noch einmal strukturierter an. Danke für eure Unterstützung.
              • Agrippinenser
                .. mache ich.
                • Agrippinenser
                  ich habe nun 6 Alias mit identischer Quell-ID angelegt und diese jeweils wie dargestellt mit Historie-Instanzen verknüpft.
                  Bei mir funktioniert nur Influxdb.0.
                  So wie ich @sigi234 verstanden habe funktioniert es bei ihm mit History. Dann scheint es kein generelles Problem zu sein. Das macht mich etwas ratlos.
                    Kail last edited by
                    kann ich mit einem Material-Design-Widget einen Navigationsbutton erstellen, der auf eine andere Seite verweist. Wenn ja, welcher ist es und in welche Felde muss ich definieren?
                    Danke und Grüße Kail
                    Agrippinenser 1 Reply Last reply Reply Quote 0
                    • Agrippinenser
                      Agrippinenser @Kail last edited by Agrippinenser
                      @kail
                      bspw. mit Button - Link wenn es unbedingt MaterialDesign sein soll. Ansonsten passt der "Gestylt
                      Schaltfläche=>Seitendialog" .
                      EDIT: "materialdesign Button Navigation"
                        Kail @Agrippinenser last edited by
                        @agrippinenser
                        super Danke. Habe mich für den Gestylt Button entschieden, der scheint für die neue VIS bereit zu sein 😉
                        • I
                          intruder7 @Agrippinenser last edited by
                          @agrippinenser wie ich schon bei git geschrieben habe, liegt es bei Influx wohl eher an der Instanz. denn Instanz 0 geht bei mir auch. Eine Instanz 2 z.B. nicht
                            hosabeni last edited by
                            Ich habe Vis-2 über das Beta Repo installiert. Der Adapter geht nach dem eingeben der Liezens in eine Neustartschleife mit diesen Meldungen im Log. Der Vis Adapter läuft ohne Probleme.
                            Habe ich etwas falsch konfiguriert oder ist das ein Bug?
                            Vis-2 2.9.2
                            host.iobroker
                            	2023-12-01 21:51:32.120	error	instance system.adapter.vis-2.0 terminated with code 3 (NO_ADAPTER_CONFIG_FOUND)
                            vis-2.0
                            	2023-12-01 21:51:31.429	warn	Terminated (NO_ADAPTER_CONFIG_FOUND): Without reason
                            vis-2.0
                            	2023-12-01 21:51:31.369	error	adapter disabled
                            host.iobroker
                            	2023-12-01 21:50:58.651	error	instance system.adapter.vis-2.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                            vis-2.0
                            	2023-12-01 21:50:57.976	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                            vis-2.0
                            	2023-12-01 21:50:57.463	error	Exception-Code: EACCES: EACCES: permission denied, scandir '/opt/iobroker/'
                            vis-2.0
                            	2023-12-01 21:50:57.462	error	Error: EACCES: permission denied, scandir '/opt/iobroker/' at Object.readdirSync (node:fs:1527:3) at collectWidgetSets (/opt/iobroker/node_modules/iobroker.vis-2/main.js:512:19) at /opt/iobroker/node_modules/iobroker.vis-2/main.js:562:51 at Array.forEach (<anonymous>) at readAdapterList (/opt/iobroker/node_modules/iobroker.vis-2/main.js:562:36) at async buildHtmlPages (/opt/iobroker/node_modules/iobroker.vis-2/main.js:827:25) at async Object.main [as ready] (/opt/iobroker/node_modules/iobroker.vis-2/main.js:1009:5)
                            vis-2.0
                            	2023-12-01 21:50:57.460	error	unhandled promise rejection: EACCES: permission denied, scandir '/opt/iobroker/'
                            vis-2.0
                            	2023-12-01 21:50:57.456	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                            host.iobroker
                            	2023-12-01 21:33:18.133	warn	Do not restart adapter system.adapter.vis-2.0 because restart loop detected
                            host.iobroker
                            	2023-12-01 21:33:18.132	error	instance system.adapter.vis-2.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                            vis-2.0
                            	2023-12-01 21:33:17.444	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                            vis-2.0
                            	2023-12-01 21:33:16.937	error	Exception-Code: EACCES: EACCES: permission denied, scandir '/opt/iobroker/'
                            vis-2.0
                            	2023-12-01 21:33:16.936	error	Error: EACCES: permission denied, scandir '/opt/iobroker/' at Object.readdirSync (node:fs:1527:3) at collectWidgetSets (/opt/iobroker/node_modules/iobroker.vis-2/main.js:512:19) at /opt/iobroker/node_modules/iobroker.vis-2/main.js:562:51 at Array.forEach (<anonymous>) at readAdapterList (/opt/iobroker/node_modules/iobroker.vis-2/main.js:562:36) at async buildHtmlPages (/opt/iobroker/node_modules/iobroker.vis-2/main.js:827:25) at async Object.main [as ready] (/opt/iobroker/node_modules/iobroker.vis-2/main.js:1009:5)
                            vis-2.0
                            	2023-12-01 21:33:16.934	error	unhandled promise rejection: EACCES: permission denied, scandir '/opt/iobroker/'
                            vis-2.0
                            	2023-12-01 21:33:16.930	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                            • Dr. Bakterius
                              Dr. Bakterius Most Active @hosabeni last edited by
                              @hosabeni sagte in Vis-2(.0) - Neuer Adapter als Beta:
                              Mach mal
                              iob stop
                              iob fix
                              iob start
                                hosabeni @Dr. Bakterius last edited by
                                @dr-bakterius Hab ich versuchen, hat aber nicht geholfen.
                                DJMarc75 apollon77 2 Replies Last reply Reply Quote 0
                                • DJMarc75
                                  DJMarc75 @hosabeni last edited by
                                  na dann zeig mal die Ausgabe von
                                  iob diag
                                  und bitte die Langfassung in Codetags posten
                                    apollon77 @hosabeni last edited by
                                    @hosabeni Also an sich darf /opt/iobroker keinen Zugriffsfehler geben ...
                                      lub104 last edited by
                                      Hallo zusammen, ich habe mit selbst hochgeladen Bilder sie werden im Vis2 nicht angezeigt. PNG Bilder wurden in den Projektordner hochgeladen, Bilder werden als kleines Icon erkannt aber nicht angezeigt was ist mein Fehler. Für kurze Hilfe wäre ich dankbar.
                                        hosabeni @DJMarc75 last edited by
                                        @djmarc75 Hallo hier die Langfassung von iob diag im Spoiler
                                        Skript v.2023-10-10
                                        *** BASE SYSTEM ***
                                           Static hostname: iobroker
                                                 Icon name: computer
                                          Operating System: Debian GNU/Linux 11 (bullseye)
                                                    Kernel: Linux 6.1.21-v8+
                                              Architecture: arm64
                                        Model           : Raspberry Pi 4 Model B Rev 1.4
                                        Docker          : false
                                        Virtualization  : none
                                        Kernel          : aarch64
                                        Userland        : arm64
                                        Systemuptime and Load:
                                         10:41:30 up 1 day, 12:36,  3 users,  load average: 2.16, 1.86, 1.27
                                        CPU threads: 4
                                        *** RASPBERRY THROTTLING ***
                                        Current issues:
                                        Previously detected issues:
                                        *** Time and Time Zones ***
                                                       Local time: Sun 2023-12-03 10:41:30 CET
                                                   Universal time: Sun 2023-12-03 09:41:30 UTC
                                                         RTC time: n/a
                                                      NTP service: active
                                                  RTC in local TZ: no
                                        *** User and Groups ***
                                        pi
                                        /home/pi
                                        pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
                                        *** X-Server-Setup ***
                                        X-Server:       true
                                        Desktop:
                                        Terminal:       tty
                                        *** MEMORY ***
                                        Mem:            7.8G        3.4G        665M         21M        3.8G        4.3G
                                        Swap:            99M          0B         99M
                                        Total:          7.9G        3.4G        765M
                                                 7812 M total memory
                                                 3376 M used memory
                                                 3812 M active memory
                                                 3075 M inactive memory
                                                  664 M free memory
                                                  219 M buffer memory
                                                 3550 M swap cache
                                                   99 M total swap
                                                    0 M used swap
                                                   99 M free swap
                                        Raspberry only:
                                        oom events: 0
                                        *** FAILED SERVICES ***
                                        0 loaded units listed.
                                        *** FILESYSTEM ***
                                        /dev/root      ext4       59G   15G   42G  26% /
                                        devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
                                        tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
                                        tmpfs          tmpfs     1.6G  1.3M  1.6G   1% /run
                                        /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
                                        /dev/sda1      ext4      458G  2.4G  432G   1% /media/usb0
                                        tmpfs          tmpfs     782M   20K  782M   1% /run/user/1000
                                        [Fri Dec  1 22:05:27 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:CB:CD:86 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=tty1 root=PARTUUID=0e2244e3-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                                        [Fri Dec  1 22:05:28 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                                        [Fri Dec  1 22:05:28 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                                        [Fri Dec  1 22:05:31 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                                        [Fri Dec  1 22:05:34 2023] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
                                        TARGET        SOURCE         FSTYPE OPTIONS
                                        /             /dev/mmcblk0p2 ext4   rw,noatime
                                        |-/boot       /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                                        `-/media/usb0 /dev/sda1      ext4   rw,relatime
                                        /var:
                                        3.8G    /var/
                                        1.9G    /var/cache/apt
                                        1.9G    /var/cache
                                        1.8G    /var/cache/apt/archives
                                        1.6G    /var/log/journal/2cd78d8029364b2bbf6704cd23c592f6
                                        Archived and active journals take up 1.5G in the file system.
                                        /opt/iobroker/backups:
                                        2.5G    /opt/iobroker/backups/
                                        /opt/iobroker/iobroker-data:
                                        565M    /opt/iobroker/iobroker-data/
                                        422M    /opt/iobroker/iobroker-data/files
                                        124M    /opt/iobroker/iobroker-data/files/vis-2
                                        100M    /opt/iobroker/iobroker-data/backup-objects
                                        90M     /opt/iobroker/iobroker-data/files/echarts.admin
                                        37M     /opt/iobroker/iobroker-data/objects.jsonl
                                        24M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.5f66c5d9.js.map
                                        24M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.9f2a6569.js.map
                                        24M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.5f66c5d9.js.map
                                        21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
                                        USB-Devices by-id:
                                        /dev/serial/by-id/usb-FTDI_USB_HS_SERIAL_CONVERTER_FTELTVKZ-if00-port0
                                        /dev/serial/by-id/usb-FTDI_USB_HS_SERIAL_CONVERTER_FTELTVKS-if00-port0
                                        /dev/serial/by-id/usb-Silicon_Labs_CP2104_USB_to_UART_Bridge_Controller_01A64D1A-if00-port0
                                        *** NodeJS-Installation ***
                                        /usr/bin/nodejs         v18.19.0
                                        /usr/bin/node           v18.19.0
                                        /usr/bin/npm            10.2.3
                                        /usr/bin/npx            10.2.3
                                        /usr/bin/corepack       0.22.0
                                        nodejs:
                                          Installed: 18.19.0-1nodesource1
                                          Candidate: 18.19.0-1nodesource1
                                          Version table:
                                         *** 18.19.0-1nodesource1 1001
                                                100 /var/lib/dpkg/status
                                             18.18.2-1nodesource1 1001
                                             18.18.1-1nodesource1 1001
                                             18.18.0-1nodesource1 1001
                                             18.17.1-1nodesource1 1001
                                             18.17.0-1nodesource1 1001
                                             18.16.1-1nodesource1 1001
                                             18.16.0-1nodesource1 1001
                                             18.15.0-1nodesource1 1001
                                             18.14.2-1nodesource1 1001
                                             18.14.1-1nodesource1 1001
                                             18.14.0-1nodesource1 1001
                                             18.13.0-1nodesource1 1001
                                             18.12.0-1nodesource1 1001
                                             18.11.0-1nodesource1 1001
                                             18.10.0-1nodesource1 1001
                                             18.9.1-1nodesource1 1001
                                             18.9.0-1nodesource1 1001
                                             18.8.0-1nodesource1 1001
                                             18.7.0-1nodesource1 1001
                                             18.6.0-1nodesource1 1001
                                             18.5.0-1nodesource1 1001
                                             18.4.0-1nodesource1 1001
                                             18.3.0-1nodesource1 1001
                                             18.2.0-1nodesource1 1001
                                             18.1.0-1nodesource1 1001
                                             18.0.0-1nodesource1 1001
                                             12.22.12~dfsg-1~deb11u4 500
                                                500 http://deb.debian.org/debian bullseye/main arm64 Packages
                                                500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                                        No problems detected
                                        Errors in npm tree:
                                        *** ioBroker-Installation ***
                                        ioBroker Status
                                        Objects type: jsonl
                                        States  type: jsonl
                                        Core adapters versions
                                        js-controller:  5.0.16
                                        admin:          6.12.0
                                        javascript:     7.1.6
                                        Adapters from github:   5
                                        Adapter State
                                        + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: horst
                                        + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
                                          system.adapter.alias-manager.0          : alias-manager         : iobroker                                 - disabled
                                        + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                                        + system.adapter.beckhoff.0               : beckhoff              : iobroker                                 -  enabled
                                        + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
                                        + system.adapter.echarts.0                : echarts               : iobroker                                 -  enabled
                                        + system.adapter.ecovacs-deebot.0         : ecovacs-deebot        : iobroker                                 -  enabled
                                        + system.adapter.enocean.0                : enocean               : iobroker                                 -  enabled
                                        + system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker                                 -  enabled
                                          system.adapter.flot.0                   : flot                  : iobroker                                 - disabled
                                          system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
                                        + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
                                        + system.adapter.jarvis.0                 : jarvis                : iobroker                                 -  enabled
                                        + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                                        + system.adapter.kecontact.0              : kecontact             : iobroker                                 -  enabled
                                        + system.adapter.net-tools.0              : net-tools             : iobroker                                 -  enabled
                                          system.adapter.proxy.0                  : proxy                 : iobroker                                 -  enabled
                                        + system.adapter.pvforecast.0             : pvforecast            : iobroker                                 -  enabled
                                        + system.adapter.rpi2.0                   : rpi2                  : iobroker                                 -  enabled
                                          system.adapter.schoolfree.0             : schoolfree            : iobroker                                 -  enabled
                                        + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                                        + system.adapter.smartmeter.0             : smartmeter            : iobroker                                 -  enabled
                                        + system.adapter.smartmeter.1             : smartmeter            : iobroker                                 -  enabled
                                        + system.adapter.smartmeter.2             : smartmeter            : iobroker                                 -  enabled
                                        + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
                                        + system.adapter.sql.0                    : sql                   : iobroker                                 -  enabled, port: 3306
                                        + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                                        + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
                                        + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
                                          system.adapter.vis-2.0                  : vis-2                 : iobroker                                 - disabled
                                          system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
                                        + system.adapter.vw-connect.0             : vw-connect            : iobroker                                 -  enabled
                                        + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0 (SSL), run as: admin
                                        + instance is alive
                                        ioBroker-Repositories
                                        Stable (default): http://download.iobroker.net/sources-dist.json
                                        Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
                                        Active repo(s): Stable (default)
                                        Installed ioBroker-Instances
                                        Used repository: Stable (default)
                                        Adapter    "admin"        : 6.12.0   , installed 6.12.0
                                        Adapter    "alexa2"       : 3.26.3   , installed 3.26.3
                                        Adapter    "backitup"     : 2.8.7    , installed 2.8.7
                                        Adapter    "beckhoff"     : 1.5.3    , installed 1.5.3
                                        Adapter    "echarts"      : 1.5.4    , installed 1.5.4
                                        Adapter    "ecovacs-deebot": 1.4.13  , installed 1.4.13
                                        Adapter    "fb-checkpresence": 1.2.2 , installed 1.2.2
                                        Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
                                        Adapter    "javascript"   : 7.1.6    , installed 7.1.6
                                        Controller "js-controller": 5.0.16   , installed 5.0.16
                                        Adapter    "kecontact"    : 2.0.2    , installed 2.0.2
                                        Adapter    "proxy"        : 1.3.2    , installed 1.3.2
                                        Adapter    "pvforecast"   : 2.9.0    , installed 2.9.0
                                        Adapter    "schoolfree"   : 1.1.3    , installed 1.1.3
                                        Adapter    "shelly"       : 6.6.1    , installed 6.6.1
                                        Adapter    "smartmeter"   : 3.3.4    , installed 3.3.4
                                        Adapter    "sql"          : 2.2.0    , installed 2.2.0
                                        Adapter    "telegram"     : 2.0.1    , installed 3.0.0
                                        Adapter    "trashschedule": 2.3.0    , installed 2.3.0
                                        Adapter    "vis"          : 1.4.16   , installed 1.5.1
                                        Adapter    "vw-connect"   : 0.0.67   , installed 0.1.0
                                        Adapter    "web"          : 6.1.10   , installed 6.1.10
                                        Adapter    "ws"           : 2.5.8    , installed 2.5.8
                                        Objects and States
                                        Objects:        11773
                                        States:         11226
                                        Hit:1 http://deb.debian.org/debian bullseye InRelease
                                        Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
                                        Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
                                        Hit:4 https://apt.grafana.com stable InRelease
                                        Hit:5 http://security.debian.org/debian-security bullseye-security InRelease
                                        Hit:6 https://deb.nodesource.com/node_18.x nodistro InRelease
                                        Reading package lists...
                                        Pending Updates: 0
                                        *** Listening Ports ***
                                        tcp        0      0 0.0.0.0:5900            0.0.0.0:*               LISTEN      0          3890       567/vncserver-x11-c
                                        tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       21748      2075/io.shelly.0
                                        tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       16801      538/iobroker.js-con
                                        tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       17740      538/iobroker.js-con
                                        tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          1677795    82700/cupsd
                                        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          1906       597/sshd: /usr/sbin
                                        tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       22614      2582/io.jarvis.0
                                        tcp        0      0 0.0.0.0:3306            0.0.0.0:*               LISTEN      116        13806      641/mariadbd
                                        tcp6       0      0 :::5900                 :::*                    LISTEN      0          3889       567/vncserver-x11-c
                                        tcp6       0      0 :::22                   :::*                    LISTEN      0          1908       597/sshd: /usr/sbin
                                        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       18186      1314/io.admin.0
                                        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       23804      2789/io.web.0
                                        tcp6       0      0 ::1:631                 :::*                    LISTEN      0          1677794    82700/cupsd
                                        tcp6       0      0 :::3000                 :::*                    LISTEN      117        18929      722/grafana
                                        udp        0      0 0.0.0.0:7090            0.0.0.0:*                           1001       23656      2626/io.kecontact.0
                                        udp        0      0 0.0.0.0:7092            0.0.0.0:*                           1001       23657      2626/io.kecontact.0
                                        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          3932       562/dhcpcd
                                        udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          1677820    82704/cups-browsed
                                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        1784       430/avahi-daemon: r
                                        udp        0      0 0.0.0.0:54804           0.0.0.0:*                           108        1786       430/avahi-daemon: r
                                        udp        0      0 0.0.0.0:42882           0.0.0.0:*                           1001       21429      2626/io.kecontact.0
                                        udp6       0      0 :::56214                :::*                                108        1787       430/avahi-daemon: r
                                        udp6       0      0 :::546                  :::*                                0          13960      562/dhcpcd
                                        udp6       0      0 :::5353                 :::*                                108        1785       430/avahi-daemon: r
                                        2023-12-03 00:02:00.293  - info: javascript.0 (1605) script.js.common.Sonstige.Update_TimeStamp: {'error':null,'result':{'fieldCount':0,'affectedRows':127,'insertId':0,'info':'','serverStatus':16418,'warningStatus':0,'stateChanges':{'systemVariables':{},'schema':'','trackStateChange':null}}}
                                        2023-12-03 02:05:11.036  - warn: ical.0 (88825) get state error: Connection is closed.
                                        2023-12-03 03:16:00.283  - warn: javascript.0 (1605) Read-only state "vw-connect.0.WVWZZZE1ZPP020635.status.chargingSettings.targetSOC_pct" has been written without ack-flag with value "65"
                                        2023-12-03 04:39:32.200  - warn: telegram.0 (25541) polling_error: EFATAL, EFATAL: Error: read ECONNRESET
                                        2023-12-03 04:39:48.595  - warn: ecovacs-deebot.0 (2356) Request Timeout (command 'getAdvancedMode')
                                        2023-12-03 04:40:27.315  - warn: ecovacs-deebot.0 (2356) Connection is interrupted: read ECONNRESET
                                        2023-12-03 04:41:19.259  - warn: ecovacs-deebot.0 (2356) Connection is interrupted: MQTT client error: read ECONNRESET
                                        2023-12-03 07:44:45.662  - warn: javascript.0 (1605) Read-only state "vw-connect.0.WVWZZZE1ZPP020635.status.chargingSettings.targetSOC_pct" has been written without ack-flag with value "80"
        v.2023-10-10
                                                 Icon name: computer
                                              Architecture: arm64
                                        Installation:           native
                                        Kernel:                 aarch64
                                        Userland:               arm64
                                        Timezone:               Europe/Berlin (CET, +0100)
                                        User-ID:                1000
                                        X-Server:               true
                                        Boot Target:            graphical.target
                                        Pending OS-Updates:     0
                                        Pending iob updates:    0
                                        Nodejs-Installation:    /usr/bin/nodejs         v18.19.0
        /usr/bin/npm            10.2.3
        /usr/bin/npx            10.2.3
                                        Recommended versions are nodejs 18.19.0 and npm 10.2.3
                                        MEMORY:
                                        Mem:            7.8G        3.5G        526M         21M        3.8G        4.2G
                                        Swap:            99M          0B         99M
                                        Total:          7.9G        3.5G        626M
                                        Active iob-Instances:   28
                                        ioBroker Core:          js-controller           5.0.16
        admin                   6.12.0
                                        Objects type: jsonl
                                        States  type: jsonl
                                        Objects:                11773
                                        States:                 11226
                                        Size of iob-Database:
                                        4.6M    /opt/iobroker/iobroker-data/states.jsonl
                                          hosabeni @apollon77 last edited by hosabeni
                                          @apollon77 Ich habe die Berechtigung von /opt/iobroker auf 777 geändert und dann funktioniert es.
                                          Haben sich die Berechtigungsanforderungen für vis-2 im Verhältnis zu vis geändert?
                                          Werden die Berechtigungen auf das Verzeichnis nicht mit iob fix geprüft?
                                          apollon77 Thomas Braun 2 Replies Last reply Reply Quote 0
                                            @hosabeni Ich glaube iob fix prüft alles IM Ordner aber nicht den ordner selbst weil es zb bei Docker sein kann das der prozess darauf keine schreibrechtr hat ... was ja auch nicht nötig ist.
                                            81.1k
                                            691
                                            220108
