    3. Entwicklung
    4. Re-New DoorBird Adapter v1.0.x
      memberx @memberx last edited by
      @memberx Ohhhhh man, ich habs jetzt. Datei im Script hiess Motion1 nicht Motion_1
        Ritschy2000 @memberx last edited by
        @Schmakus jetzt kam mal wieder die Fehlermeldung:
        Error in Parsing Schedules: RangeError: Maximum call stack size exceeded. Error-Stack: RangeError: Maximum call stack size exceeded at strEscape (/opt/iobroker/node_modules/safe-stable-stringify/index.js:29:54) at stringifyFnReplacer (/opt/iobroker/node_modules/safe-stable-stringify/index.js:188:16) at stringifyFnReplacer (/opt/iobroker/node_modules/safe-stable-stringify/index.js:256:23) at stringify (/opt/iobroker/node_modules/safe-stable-stringify/index.js:598:18) at Format.transform (/opt/iobroker/node_modules/logform/json.js:28:19) at Format.transform (/opt/iobroker/node_modules/logform/combine.js:20:24) at DerivedLogger._transform (/opt/iobroker/node_modules/winston/lib/winston/logger.js:313:29) at Transform._read (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_transform.js:166:10) at Transform._write (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_transform.js:155:83) at doWrite (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_writable.js:390:139)
          PEPITO82 last edited by
          ich bekomme alle 3 Minuten den Fehler "Error in checkFavoritesAsync()" im Log:
          Ist da was nicht richtig in meiner Doorbird Installation?
          • Negalein
            Negalein Global Moderator @PEPITO82 last edited by
            @pepito82 sagte in Re-New DoorBird Adapter v1.0.x:
            siehe hier.
            https://forum.iobroker.net/topic/69197/warnmeldung-beim-doorbird-adapter/4?_=1698524491089
            versuch das mal.
              PEPITO82 @Negalein last edited by
              @negalein Danke für den Tipp! Nachdem ich manuell einen Dummy Favoriten für HTTP Aufrufe hinzugefügt habe, hat ioBroker nun den doorbird.0 1 Ring und Motion Favoriten angelegt.
              Die Warnungen sind damit auch verschwunden. Danke 🙂
              • Segway
                Segway @Schmakus last edited by Segway
                @schmakus
                ich kämpfe gerade mit den Bilder.
                Ich bekomme diese nicht angezeigt und in dem Verzeichnis sind beide Dateien abgelegt aber mit 0 kb.
                Ist da eine Einstellung noch falsch bei mir ?
                Update:
                Okay das Bild wird erstellt. Ich kann es per Browser aufrufen aber leider in der APP Doorbird nicht 😞 Jemand eine Idee?
                Schmakus 1 Reply Last reply Reply Quote 0
                • Schmakus
                  Schmakus Developer @Segway last edited by
                  @segway
                  Rechte in der App richtig gesetzt?
                  Siehe Readme:
                  The Username which needs to have the API-Operator and Watch always permissions on the Doorbird device.
                  • Segway
                    @schmakus sagte in Re-New DoorBird Adapter v1.0.x:
                    @segway
                    Siehe Readme:
                    In der APP ist das sowieso nur im Administartorbereich. Daher kann ich mich da auch nur mit dem admin anmelden. Dann kommt schon die Meldung, dass er sich nciht zur Cloud verbinden kann und das Feld um Cloud-Recording Free zu aktivieren ist komplett ausgebaut. ... kann es nicht aktivieren. Keine Ahnung wieso.
                    • Schmakus
                      @segway
                      Segway 2 Replies Last reply Reply Quote 0
                      • Segway
                        @schmakus
                        Ja genau das ist und war genauso eingestellt
                        • Segway
                          @schmakus
                          Also ich krieg immer einen Fehler. Es scheint so das ich mit der neuen Versuon die Probleme habe. Mit der 0.x Versuon ging alles
                          Muss ich denn unter http Aufrufe ausser Ring und Motion noch was eintragen?
                          Woher holt sich die App denn das Bild wenn ich die linke Option auf dem Bild wähle? Vom iobroker Verzeichnis ? Dann hab ich anscheinend keine Zugriff ?
                          • Schmakus
                            @segway sagte in Re-New DoorBird Adapter v1.0.x:
                            @schmakus
                            Dann stimmt was mit deiner DoorBird nicht.
                            Die DoorBird App hat nichts mit ioBroker zu tun! Die holt sich die Bilder und live Video direkt von der DoorBird.
                            • Segway
                              Du meinst, dass die quasi in dieser free cloud gespeichert werden ? Und von daher das aufgerufen wird ?
                              Dann würde ich mal behaupten, dass kein Zugriff auf die Cloud da ist - keine Ahnung was ich da wie konfigurieren soll.
                              • Negalein
                                schreib dem Support.
                                Da stimmt mit deiner Doorbird etwas nicht.
                                • Hant0r
                                  Hant0r last edited by
                                  Moin zusammen,
                                  seit heute 14:23 Uhr bekomme ich wieder folgende Meldung (alle paar Minuten) im Log:
                                  Version: 1.3.0
                                  doorbird.0
                                  2023-12-16 21:19:29.044	warn	Error in Parsing Schedules: RangeError: Maximum call stack size exceeded. Error-Stack: RangeError: Maximum call stack size exceeded at strEscape (/opt/iobroker/node_modules/safe-stable-stringify/index.js:29:54) at stringifyFnReplacer (/opt/iobroker/node_modules/safe-stable-stringify/index.js:188:16) at stringifyFnReplacer (/opt/iobroker/node_modules/safe-stable-stringify/index.js:256:23) at stringify (/opt/iobroker/node_modules/safe-stable-stringify/index.js:598:18) at Format.transform (/opt/iobroker/node_modules/logform/json.js:28:19) at Format.transform (/opt/iobroker/node_modules/logform/combine.js:20:24) at DerivedLogger._transform (/opt/iobroker/node_modules/winston/lib/winston/logger.js:313:29) at Transform._read (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_transform.js:166:10) at Transform._write (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_transform.js:155:83) at doWrite (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_writable.js:390:139)
                                    Ritschy2000 @Hant0r last edited by
                                    @Schmakus Hallo,
                                    ich bekomme auch noch alle 2-4 Tage die "Maximum call stack size" Warnung.
                                    Gibt es genauere Infos darüber, wann diese erscheinen bzw. wie lange der Adapter deaktiviert werden muss, bevor es wieder funktioniert?
                                    Dann würde ich zur Not den Adapter alle x Tage für ein paar Stunden deaktiveren...
                                    • Schmakus
                                      Schmakus Developer @Ritschy2000 last edited by
                                      @ritschy2000 sagte in Re-New DoorBird Adapter v1.0.x:
                                      @Schmakus Hallo,
                                      Ein einfacher Neustart des Adapters sollte reichen. Damit werden sämtliche Schleifen beendet.
                                      • Segway
                                        Segway @Negalein last edited by
                                        @negalein sagte in Re-New DoorBird Adapter v1.0.x:
                                        Nach langem hin und her wird dann natürlich gesagt ... oh Wunder ... das Teil scheint teil-defekt zu sein, dabei funktionieren alle Funktionen nur keine Bilder in der Free-Cloud.
                                        ich bezweifle es dass die Kaputt ist zumal natürlich Garantie abgelaufen ist und ich den Austausch zumindest zu einem grossen Teil selber bezahlen muss.
                                        Also keine Alternative für mich.
                                        Frage daher ob ich es irgendwie anders einrichten kann mir beim Klingeln ein Bild oder das Live video zu schicken ? Geht glaube ich über Telegram oder ? Das ist aber irgendwie nicht mein wünsch App. Gibts Alternativen ?
                                        • Negalein
                                          Negalein Global Moderator @Segway last edited by
                                          Live-Video hole ich mir mit Motioneye in die VIS.
                                          und in meinem Fall die Bilder nach Telegram.
                                          on({id: 'doorbird.0.Doorbell.102.trigger', val: true}, function (obj) {
                                            const timeout = setTimeout(function () {
                                              readFile("doorbird.0", "Doorbell102_1.jpg", function (error, data) {
                                              if (error) {
                                                  console.error(error);
                                              } else {
                                                  sendTo("telegram.0", {
                                                  text: data,
                                                  type: "photo",
                                            }, 1000);
                                          • Segway
                                            Hast du das in einer VM oder CT laufen ?
                                            Wie kommst du an den Livestream dran ? Wenn es schellt verbindest du dich manuell zu dem Stream ?
                                            Jo das geht immer denke ich.
                                            135
                                            21125
